Broken Hinge
Not Feeling Very Attached?
One of the most physically used & abused parts of a laptop are its hinges; so it is common that they malfunction. Nonstop back & forth movement with half the laptop’s weight resting on this small part cause hinge issues to get worse as time goes on, as loose screws unravel and broken pieces fracture. Our technicians at Rossmann Repair Group can fix most laptop hinge issues at our store.
Let Us Find Out The Cause Of Your Problems
Oftentimes it looks like a hinge issue when it is something else entirely. For example, with cheaper HP & Toshiba laptops, the back cover for the screen that the hinge screws into can be broken. The hinge may be fine, but the part that the hinge screws into is broken. These parts are being made of cheaper and poorer quality plastic as manufacturers race to the bottom to produce $300 laptops. With Apple machines, it is common that the back cover that the hinge screws into comes apart entirely. This piece is glued together on Apple laptops, and to add insult to injury, the exhaust fans blow the hot air out directly onto the glue!
Come In For A Free Estimate
The only way to find out exactly what your hinge issue would cost to repair would be to let our technicians open your machine. We do offer no obligation free estimates. This means we’ll open it up and see what’s wrong for free. Our technicians will explain what’s causing the issue and present you with solutions, and you can choose from there what you would like to do. With free estimates you have nothing to lose!
Top Reasons To Have Your Repairs Done By Us
  • We stock our parts, so that means that you save time.
  • Our pricing is fair.
  • We use grade A+ parts.
  • We can repair motherboard component level issues.
Call or Visit Us
(347) 552-2258
Monday-Friday – 12 PM to 8 PM
Saturday-Sunday 12 PM to 4 PM
186 1st Avenue
New York, NY 10009
WE CAN FIX YOUR PROBLEM
