# eMMC Data Recovery
BGA-Soldered Managed NAND in Chromebooks, Tablets, and Embedded Devices
eMMC chips are soldered directly to the motherboard. When the board dies or the eMMC controller locks out, the storage cannot be removed like a standard SSD. We recover eMMC data through ISP (In-System Programming) via test points on the board, or by desoldering the BGA chip and reading the NAND directly with [PC-3000 Flash](/pc-3000-data-recovery-tool).
[FREE ESTIMATE](/contact)[Mail-In Service](/mail-in-data-recovery)
No Data, No Charge. Free evaluation for all eMMC devices.
![Louis Rossmann](/_next/image?url=%2Fimages%2Flouis-rossmann-portrait.jpg&w=3840&q=75)
[Louis Rossmann](/louis-rossmann)Founder & Chief Technician
8 min read
eMMC Data Recovery
## What Is eMMC Data Recovery?
eMMC (embedded MultiMediaCard) is a managed NAND flash storage package soldered to a device's motherboard as a BGA (Ball Grid Array) component. The chip combines a NAND flash die, a flash controller, and the MMC interface into a single package defined by the JEDEC eMMC 5.1 standard. Chromebooks, budget laptops, tablets, smart TVs, set-top boxes, and IoT devices use eMMC as their primary storage.
When the host device fails, the eMMC chip cannot be removed and plugged into a reader like an SSD or SD card. Recovery requires either connecting to the chip's data lines through ISP test points on the PCB, or desoldering the BGA package and mounting it in a chip reader. Both methods bypass the dead host board and communicate with the eMMC controller directly using the MMC protocol.
eMMC Architecture
## eMMC Architecture
Understanding the internal design of eMMC storage explains why recovery requires board-level access and why it differs from SSD or SD card recovery.
SpeceMMCeUFSSATA SSDInterfaceParallel MMC bus (8-bit)Serial SCSI (M-PHY lanes)SATA III (serial ATA)ProtocolMMC command set (JEDEC 5.1)UFS command set (SCSI)ATA command setMax throughput400 MB/s (HS400)2,900 MB/s (UFS 3.1)550 MB/s (SATA III)DuplexHalf-duplexFull-duplexHalf-duplexTypical capacity16 GB to 256 GB64 GB to 1 TB120 GB to 8 TBMountingBGA soldered to boardBGA soldered to boardRemovable (2.5" or M.2)Recovery toolPC-3000 Flash + ISP/BGA adapterPC-3000 Flash + UFS adapterPC-3000 SSD / PC-3000 Portable
### Managed NAND
"Managed NAND" means the eMMC package contains its own flash controller that handles wear leveling, ECC, bad block management, and garbage collection internally. The host device sends standard MMC read/write commands; the eMMC controller translates these to raw NAND page operations. This is the same principle as an SSD, but in a smaller BGA form factor with lower performance targets. When the internal controller fails, the data on the NAND is intact but the MMC interface stops responding.
### BGA Package
eMMC chips use a Ball Grid Array solder connection with 153 or 169 solder balls on the underside of the package (defined by the JEDEC standard). These balls connect power, ground, clock, command, and 8 data lines to the host board. The solder joints are approximately 0.35 mm in diameter. Removing the chip for chip-off recovery requires a hot-air rework station at 260-280°C with appropriate flux and preheating to prevent thermal shock to the NAND die.
Device Categories
## Devices That Use eMMC Storage
eMMC is the default storage in cost-optimized devices. When these devices fail, the data is trapped on a chip that cannot be removed without microsoldering equipment.
### Chromebooks
Google Chromebooks from Samsung, Acer, HP, Lenovo, and ASUS use 32 GB to 128 GB eMMC chips as their sole internal storage. Common models include the Acer Chromebook 311, HP Chromebook 14, Samsung Chromebook 4, and Lenovo Chromebook S330. When the motherboard fails due to a power surge, liquid spill, or component failure, the user's local files, Downloads folder, and Linux container data are locked on the eMMC chip.
### Budget Laptops
HP Stream 11 and 14 ship with 32 GB or 64 GB eMMC. These laptops store Windows system files and user data on the same eMMC chip. A failed board means the Windows installation, documents, and photos are inaccessible without ISP or chip-off recovery.
### Tablets
Android tablets, Amazon Fire tablets, and Windows tablets use eMMC storage. Samsung Galaxy Tab A, Amazon Fire HD 10, Lenovo Tab M10, and Microsoft Surface Go (base model) all use eMMC. Tablets are prone to drop damage and charging port failures that kill the main board while the eMMC data remains intact.
### Smart TVs and Set-Top Boxes
Smart TVs from Samsung, LG, and Vizio store firmware, apps, and configuration data on eMMC chips. Streaming devices like Roku, Amazon Fire TV Stick, and Android TV boxes use 8 GB to 32 GB eMMC storage. Recovery is relevant for commercial displays with custom configurations or digital signage systems that store scheduled content locally.
### IoT and Embedded Systems
Single-board computers (Raspberry Pi Compute Module, BeagleBone Black), industrial gateways, POS terminals, kiosks, and automotive infotainment systems use eMMC for boot and data storage. Industrial eMMC chips from Micron, Samsung, and Kingston run for years in harsh environments. When they fail, the device's firmware, configuration, and operational data need to be recovered to restore functionality or investigate failures.
### Dash Cameras and GPS Units
Some dash cameras and GPS navigation units store recorded footage and map data on internal eMMC rather than a removable SD card. When the device dies from a power surge or heat exposure (common in car-mounted electronics), the footage on the eMMC requires chip-level recovery. This is relevant for accident investigations where the dash cam footage is needed as evidence.
Failure Modes
## Common eMMC Failure Modes
eMMC failures fall into four categories. The failure type determines whether we recover through ISP (communicating with the chip's controller in place) or chip-off (bypassing the controller entirely).
### Controller Lockout
The eMMC controller enters a locked state where it refuses standard MMC read commands. This happens after firmware corruption, unexpected power loss during a firmware update, or when the controller's internal table (the Flash Translation Layer) becomes inconsistent. The host device may report "no storage detected" or boot into a recovery screen.
Recovery approach: Connect via ISP to the eMMC's CMD and DAT lines. Send MMC vendor commands to unlock the controller or put it into a diagnostic mode that allows raw sector reads. PC-3000 Flash includes profiles for Samsung, Toshiba/Kioxia, SK Hynix, and Micron eMMC controllers.
### NAND Wear-Out
eMMC chips in Chromebooks and budget laptops use TLC NAND rated for 1,500 to 3,000 program/erase cycles per block. Devices that run for 3 to 5 years with regular use can exhaust the NAND's write endurance. Symptoms include progressively slower write speeds, intermittent read errors, and eventually the device failing to boot. The eMMC controller remaps bad blocks until the spare block pool runs out.
Recovery approach: ISP access first. If the controller still responds, image the chip with multiple read passes, skipping and retrying failed sectors. If the controller is non-responsive due to exhausted remap tables, proceed with chip-off: desolder the BGA package, read the raw NAND with PC-3000 Flash, and reconstruct the data using the controller-specific ECC algorithm.
### Solder Joint Fracture
The 153/169 BGA solder balls connecting the eMMC to the motherboard can fracture from repeated thermal cycling, flex stress from drops, or manufacturing defects. A single cracked solder ball on a data line causes intermittent or permanent communication failure. The device may work inconsistently (booting sometimes but not others) before failing permanently.
Recovery approach: Attempt ISP via test points first (bypasses the BGA connection issue if the ISP pads connect upstream of the fracture). If ISP fails, desolder the eMMC chip, reball it with fresh solder balls, and either mount it on a test board with a working MMC interface or read the NAND directly via chip-off.
### Host Board Failure
The most common reason for eMMC recovery: the host device's motherboard dies from liquid damage, a shorted power rail, or a failed CPU/SoC, but the eMMC chip itself is fine. The user cannot access their data because the eMMC has no removable connector. On a laptop with a standard SSD, you would pull the SSD and plug it into another machine. With eMMC, that is not possible.
Recovery approach: ISP is the first choice. We locate the eMMC test points on the board's PCB (CLK, CMD, DAT0-DAT7, VCC, VCCQ, GND) and connect a programmer that speaks the MMC protocol. The chip responds to standard MMC read commands because its controller is healthy. We image the full eMMC, then mount the partition and extract the user's files.
## eMMC Recovery Pricing
eMMC recovery uses the same pricing tiers as flash media recovery. The cost depends on the failure type and recovery method, not the device brand or eMMC capacity. No diagnostic fee.
- 01Low complexity
### Simple Copy
Your flash drive or SD card works, you just need the data moved off itFunctional media; data transfer to new storageRush available: +$100$2003-5 business days
- 02Low complexityMost Common
### File System Recovery
Your flash drive or SD card isn't showing up, but it's not physically damagedFile system corruption. Visible to recovery software (R-Studio, UFS) but not to OSStarting price; final depends on complexity$300–$6002-4 weeks
- 03Medium complexity
### PCB Repair
Your flash drive or SD card has shorted components or won't power onPCB issues: simple shorts, failed components on the drive's circuit boardMay require a donor drive (additional cost)$600–$9003-6 weeks
- 04High complexity
### Chip-off Data Recovery
Your flash drive or SD card needs physical NAND chip extraction to recover the dataNAND chip extraction via soldering, pin-out identification, and raw data reconstruction50% deposit required50% deposit required$1,200–$1,5004-8 weeks
### Hardware Repair vs. Software Locks
**No data, no fee.** Free evaluation and firm quote before any paid work. [Full guarantee details](/no-fix-no-fee). Chip-off recovery requires a 50% deposit because the extraction process is destructive to the original media.
Rush fee+$100 rush fee to move to the front of the queueAll prices are plus applicable tax.
## Data Recovery Standards & Verification
Our Austin lab operates on a transparency-first model. We use industry-standard recovery tools, including [PC-3000](/pc-3000-data-recovery-tool) and DeepSpar, combined with strict environmental controls to maintain drive integrity. This approach allows us to serve clients nationwide with consistent technical standards.
### [Localized Clean Zone](/do-you-really-need-a-clean-room-for-hard-drive-data-recovery)
Open-drive work is performed in a [0.02 micron ULPA-filtered laminar clean bench](/do-you-really-need-a-clean-room-for-hard-drive-data-recovery).
### Transparent History
Serving clients nationwide via mail-in service since 2008. Our lead engineer holds [PC-3000 and HEX Akademia certifications](/data-recovery-certifications) for hard drive firmware repair and mechanical recovery.
### Media Coverage
Our repair work has been covered by [The Wall Street Journal](https://www.wsj.com/tech/personal-tech/how-the-right-to-repair-might-save-your-gadgetsand-save-you-money-11630324800) and [Business Insider](https://www.businessinsider.com/apple-macbook-pro-repair-quote-unauthorized-2018-12), with [CBC News](https://www.cbc.ca/news/thenational/complete-control-apple-accused-of-overpricing-restricting-device-repairs-1.4859099) reporting on our pricing transparency. Louis Rossmann has [testified in Right to Repair hearings](https://en.wikipedia.org/wiki/Louis_Rossmann) in multiple states and founded the Repair Preservation Group.
### Aligned Incentives
### Technical Oversight
[See the particle counter test at the bench](/do-you-really-need-a-clean-room-for-hard-drive-data-recovery)
Technical Methodologies
## Technical Recovery Workflow
### In-System Programming Recovery
ISP is the preferred recovery method for eMMC because it avoids desoldering the chip. Every eMMC-equipped board has test points or pads that connect directly to the eMMC chip's signal lines: CLK (clock), CMD (command), DAT0 through DAT7 (data bus), VCC (3.3V core power), VCCQ (1.8V or 3.3V I/O power), and GND. We identify these test points using board schematics, boardview files, or by tracing the signal routes from the eMMC chip pads.
An ISP adapter connects to these test points with fine-pitch probes or soldered fly wires. The adapter provides clean, regulated power to the eMMC chip (bypassing the dead host board's power circuitry) and sends standard MMC read commands. If the eMMC controller responds, we image the chip sector by sector. PC-3000 Flash handles the ISP session, managing read retries, timeout handling, and partition mapping.
### Chip-Off BGA Recovery
When ISP fails (controller locked, damaged test points, or no accessible ISP pads), we desolder the BGA eMMC package. The board is preheated to 150°C to reduce thermal stress, then a focused hot-air nozzle at 260-280°C melts the solder balls. The chip is lifted and cleaned of residual solder. We place the chip in a BGA-to-socket adapter (the socket matches the 153-ball or 169-ball pinout of the specific eMMC package) and connect it to PC-3000 Flash.
PC-3000 Flash communicates with the eMMC controller using the MMC protocol. If the controller responds, we image normally. If the controller is dead, PC-3000 Flash reads the raw NAND pages directly, bypassing the controller. Raw NAND reading requires identifying the eMMC manufacturer and controller model to apply the correct ECC algorithm (BCH or LDPC) and XOR descrambling pattern. After descrambling, we reassemble the logical block layout and reconstruct the file system.
### Common eMMC Controllers
Each eMMC manufacturer uses a proprietary controller with different firmware, ECC configurations, and FTL (Flash Translation Layer) implementations. PC-3000 Flash includes recovery profiles for the major eMMC controller families:
- **Samsung (KLMAG, KLMBG, KLMCG series):** Found in Samsung Chromebooks, Galaxy tablets, and many OEM devices. Samsung eMMC chips use proprietary controller silicon with LDPC ECC. ISP recovery is well-supported; Samsung's controller responds reliably to standard MMC commands via ISP.
- **Toshiba/Kioxia (THGBMHG, THGBMDG series):** Common in Acer and HP Chromebooks, budget Windows laptops. The Toshiba controller uses BCH ECC on older models and LDPC on newer ones. Firmware lockouts on Toshiba eMMC chips can sometimes be resolved through vendor-specific MMC commands accessible via ISP.
- **SK Hynix (H26M, H26T series):** Used in Lenovo Chromebooks, Amazon Fire tablets, and various embedded devices. Hynix eMMC controllers have a known issue where power loss during garbage collection leaves the FTL in an inconsistent state, causing the chip to enter a boot-loop. ISP access with vendor commands can often force the controller to rebuild its tables.
- **Micron (MTFC series):** Found in ASUS Chromebooks and industrial IoT devices. Micron eMMC chips use a controller similar to their SSD line. ECC and FTL profiles in PC-3000 Flash handle Micron eMMC chip-off recovery.
### File System and Encryption Handling
The file system on the eMMC partition varies by device type:
- **Chromebooks:** ChromeOS partitions the eMMC using GPT with a ChromeOS kernel partition, a root filesystem (squashfs, read-only), and a stateful partition (ext4) that stores user data. User data on the stateful partition is encrypted with dm-crypt, keyed to the user's Google account credentials. Recovery of the raw image is possible; decryption requires the user's password.
- **Windows devices:** NTFS or FAT32 on a GPT or MBR layout. Budget Windows laptops with eMMC do not typically enable BitLocker by default, so the data is usually accessible after imaging. Windows 11 24H2 devices may have automatic Device Encryption enabled; check our [Windows 11 encryption recovery](/problems/windows-11-automatic-encryption-recovery) page.
- **Android tablets:** Android uses ext4 on the userdata partition with file-based encryption (FBE) since Android 7. Decryption requires the device's lock screen credentials (PIN, pattern, or password).
- **Embedded/IoT:** Embedded Linux systems on eMMC typically use ext4, F2FS, squashfs, or raw block storage. We deliver a sector-level image of the eMMC so the client can mount it in their development environment.
What to do / not do
## What to Do When Your eMMC Device Fails
If your Chromebook, tablet, or embedded device stops booting and your data is on the internal eMMC storage, follow these steps:
- **Stop powering the device.** Do not repeatedly force-restart or attempt to reflash firmware. Each power cycle risks further corruption to the eMMC controller's state tables.
- **Do not attempt a factory reset.** A [factory reset](/data-recovery-myths#myth-factory-reset-recovery) on a Chromebook or Android tablet formats the user data partition on the eMMC. If the device is still partially responsive, a factory reset will destroy the data you are trying to save.
- **Note the device model and symptoms.** Tell us the exact device model (e.g., "Acer Chromebook 311 CB311-9H"), what happened before the failure (liquid spill, power surge, OS update), and what the device does now (dead, boot loop, error screen).
- **Ship the entire device.** eMMC recovery requires access to the motherboard for ISP. Send the complete device (not just the storage chip) via our [mail-in process](/mail-in-data-recovery).
### What NOT to Do
- Do not factory reset or powerwash the device
- Do not attempt to reflash firmware from recovery mode
- Do not open the device and attempt to desolder the eMMC yourself
- Do not apply heat (hair dryer, heat gun) to "fix" solder joints
- Power off the device and ship it to us for ISP or chip-off evaluation
## eMMC Data Recovery: Common Questions
What is eMMC and how is it different from an SSD?
eMMC (embedded MultiMediaCard) is a managed NAND flash package soldered directly to a device's motherboard. It combines a NAND flash chip and a flash controller in a single BGA package. Unlike a removable SSD with its own PCB and connector (M.2, SATA, or U.2), eMMC is permanently attached to the main board. eMMC uses the MMC protocol over a parallel bus, while SSDs use SATA or NVMe. eMMC capacities typically range from 16 GB to 256 GB.
Can you recover data from a dead Chromebook?
If the Chromebook powers on but the eMMC is not detected, we connect to the eMMC chip via ISP (In-System Programming) test points on the motherboard to image the chip without removal. If the board is dead and ISP is not possible, we desolder the BGA eMMC package using a hot-air rework station and read it with PC-3000 Flash using a BGA-to-socket adapter. ChromeOS data stored on the eMMC can be extracted from the ext4 partition after imaging.
What is ISP recovery for eMMC?
ISP (In-System Programming) recovery connects directly to the eMMC chip's data lines through test points or pads on the device's PCB, without desoldering the chip. A specialized ISP adapter sends MMC commands to the eMMC controller, bypassing the host processor entirely. This is the preferred recovery method because it avoids the risk of thermal damage during BGA removal.
How much does eMMC data recovery cost?
eMMC recovery uses the same pricing tiers as SSD and flash media recovery. Simple data transfer starts at $200 if the eMMC chip is functional. ISP or firmware-level recovery ranges from $600 to $1,200. Chip-off BGA recovery with NAND reconstruction is $1,200 to $1,500. No diagnostic fee, and no charge if we cannot recover your data.
Is data on a Chromebook eMMC encrypted?
ChromeOS encrypts user data stored on the eMMC using dm-crypt with the user's login credentials. If you know the Google account password that was used on the Chromebook, decryption is possible after imaging. If the credentials are lost, the encrypted partition cannot be decrypted. Enterprise-managed Chromebooks may have additional encryption layers controlled by the organization's admin console.
Can eMMC chips be replaced after data recovery?
After recovering the data, we can solder a new eMMC chip onto the board and flash the device firmware so the device boots again. This is a separate board repair service from the data recovery itself.
What is the difference between eMMC and eUFS?
eMMC uses a parallel MMC bus with half-duplex communication (read OR write at a time). eUFS (embedded Universal Flash Storage) uses a serial SCSI interface with full-duplex lanes, supporting simultaneous reads and writes. eUFS is faster (up to 2,900 MB/s vs eMMC's 400 MB/s theoretical max) and is found in flagship phones and newer tablets. Both are BGA-soldered managed NAND, and both require ISP or chip-off recovery when the host board fails.
How long does eMMC recovery take?
Standard turnaround is 3 to 5 business days. eMMC chips have small capacities (16 GB to 256 GB), so imaging is fast once we establish access via ISP or chip-off. The majority of time is spent on diagnostics and NAND reconstruction if the controller is non-functional.
Cross-link to related flash media
### Need Recovery for a Removable SSD or Flash Card?
eMMC is soldered to the board and requires ISP or chip-off access. If your device has a removable M.2 SSD, SD card, or USB drive, see our dedicated [SSD recovery](/services/ssd-data-recovery), [SD card recovery](/services/sd-card-data-recovery), or [monolithic flash recovery](/services/flash-data-recovery/monolith-database) pages.
[No Data, No FeeGuarantee](/no-fix-no-fee)
[2.64MSubscribers](https://www.youtube.com/playlist?list=PLkVbIsAWN2lsPTNFBoEWjDyAHPcEARZtW)
[4.91,837+ Google Reviews](/reviews)
[Repairs on VideoFull Transparency](/videos)
[BBC News](https://www.bbc.com/news/technology-57763037)/
[CBC News](https://www.cbc.ca/news/thenational/complete-control-apple-accused-of-overpricing-restricting-device-repairs-1.4859099)/
[ABC Australia](https://www.abc.net.au/news/2025-07-20/youtuber-louis-rossmann-takes-on-better-way-electronics/105532410)/
[Wall Street Journal](https://www.wsj.com/tech/personal-tech/how-the-right-to-repair-might-save-your-gadgetsand-save-you-money-11630324800)/
[Business Insider](https://www.businessinsider.com/apple-macbook-pro-repair-quote-unauthorized-2018-12)/
[Vice](https://www.vice.com/en/article/dhs-seized-aftermarket-apple-laptop-batteries-from-independent-repair-expert-louis-rossman)/
[Fast Company](https://www.fastcompany.com/91387927/clippy-is-back-as-a-mascot-for-big-tech-protests)/
[404 Media](https://www.404media.co/developer-unlocks-newly-enshittified-echelon-exercise-bikes-but-cant-legally-release-his-software/)/
[Tom's Hardware](https://www.tomshardware.com/pc-components/ssds/louis-rossman-threatens-to-take-samsung-to-court-over-dead-4tb-990-pro-ssd-after-ssd-maker-failed-to-replace-the-drive-under-warranty)/
[Tom's Hardware](https://www.tomshardware.com/3d-printing/louis-rossmann-tells-3d-printer-maker-bambu-lab-to-go-bleep-yourself-over-its-lawsuit-against-enthusiast-right-to-repair-advocate-offers-to-pay-the-legal-fees-for-a-threatened-orcaslicer-developer)
## Need Recovery for Other Devices?
[Chromebook Data RecoveryDead Chromebook recovery with board repair and eMMC ISP](/services/chromebook-data-recovery)[SSD Data RecoveryNVMe, SATA, and M.2 solid state drive recovery](/services/ssd-data-recovery)[MacBook Data RecoverySoldered SSD recovery for T2 and Apple Silicon Macs](/services/macbook-data-recovery)[iPhone Data RecoveryBoard-level NAND recovery for iPhones](/services/iphone-data-recovery)[Android & Samsung Data RecoveryDead Galaxy and Android phone board-level recovery](/services/android-data-recovery)[SD Card Data RecoveryMicroSD, SDHC, and SDXC card recovery](/services/sd-card-data-recovery)[Dash Cam & Body Cam RecoveryMicroSD wear-out and eMMC chip-off for vehicle cameras](/services/dashcam-body-cam-data-recovery)[Monolithic Flash DatabaseMonolithic NAND chip pinout and recovery database](/services/flash-data-recovery/monolith-database)[View All ServicesComplete service catalog](/services)
## eMMC device not booting?
Free evaluation. No data, no charge. Ship the entire device; we handle the rest.
[Get a Free Estimate](/contact)[Mail-In Instructions](/mail-in-data-recovery)
[(512) 212-9111](tel:+15122129111)Mon-Fri 10am-6pm CT
