Monolith Flash Recovery Database | Rossmann Group
[Skip to main content](#main-content)[Skip to navigation](#site-navigation)[Rossmann Repair Group](/)
Services
Reviews
About
Learn
[Mail-in](/mail-in-data-recovery)[Contact](/contact)[(512) 212-9111](tel:+15122129111)[Get Free Estimate](/contact)Open menu
Add one to two months to every turnaround time published on this site.
We've had a temporary influx of work that put us behind. Until that changes, **plan on one to two months on top of whatever turnaround you read on any service or pricing page here for estimates, diagnosis, and repairs.** We hope to be back to normal soon.
If you need your data back sooner, please take a look at the labs on our [list of honest data recovery companies](/honest-data-recovery-companies). These are trusted industry colleagues who love doing good work for their customers.
**October 5 to October 19:** Chris, who handles our hard drive, SSD, SD card, and RAID/NAS cases, will be at ACE Lab TechWeek. Estimates on those cases will take longer while he is out. You can still ship your drive in. We'll log it, and it will be in his queue when he gets back.
# Monolith Flash Recovery Database
Modern SD cards, MicroSD cards, and many USB flash drives use monolithic construction: the NAND memory and controller are sealed together in a single epoxy package with no separately accessible NAND chip. When the controller portion fails, no card reader or software tool can detect the device. The only path to the data is direct NAND extraction through the chip's internal test points.
This page documents the monolithic chip families we encounter most frequently, the signal interfaces used in direct NAND access, and the spider board technique that makes extraction possible without soldering wires onto microscopic pads.
[Request Monolith Recovery Evaluation](/contact)[Call (512) 212-9111](tel:+15122129111)
![Monolithic microSD card wired to PC-3000 Flash spider board for direct NAND extraction](/_next/image?url=%2Fimages%2Fservices%2Fmicrosd-recovery%2Fmicrosd_spider_optimized.jpg&w=3840&q=75)Spider board adapter with needle probes contacting exposed NAND test points on a monolithic microSD card. Each needle maps to a specific flash signal line.
![Louis Rossmann](/_next/image?url=%2Fimages%2Flouis-rossmann-portrait.jpg&w=3840&q=75)
[Louis Rossmann](/louis-rossmann)Founder & Chief Technician
Updated February 27, 2026
Why monoliths are different
## Why Monolithic Flash Chips Cannot Be Read When the Controller Fails
In a traditional SD card or USB drive, the NAND flash memory and the controller are separate components on a small PCB. If the controller fails, a technician can desolder the NAND chip and read it directly in a programmer. The chip has standardized pins (TSOP48 or BGA) that connect to off-the-shelf adapters.
Monolithic designs eliminate the PCB entirely. The controller logic and NAND memory are sealed together in one plastic or epoxy package with only the external contact pads exposed. There is no NAND chip to desolder because the dies are wire-bonded inside a single package rather than mounted as a separate, removable chip.
When a monolithic controller fails, the external contacts go completely dead. The device does not appear in Disk Management, does not show in` lsblk`, and cannot be detected by any software. The NAND memory cells still hold your data, but the only way to reach them is through test points on the silicon die that sit beneath a layer of protective epoxy.
Accessing those test points requires sanding away the epoxy with a fiberglass pen, identifying each pad's signal assignment from a pinout database, and making electrical contact with each one simultaneously. This is why monolith recovery is the most labor-intensive form of flash data recovery.
NAND Signal Reference
## NAND Flash Signal Reference
Every monolithic flash chip routes the standard NAND interface signals to internal test points. The spider board must make contact with each of these signals to read the raw memory. Missing or misidentified signals produce a corrupt dump or no data at all.
SignalFull NameDirectionFunction`D0-D7`Data BusBidirectional8-bit parallel data transfer between host and NAND. All read/write data passes through these lines.`CE#`Chip EnableInputActive-low. Selects the NAND die for communication. Multi-die packages may have CE0# and CE1#.`CLE`Command Latch EnableInputWhen high, tells the NAND that the data bus carries a command byte (read, write, erase, status check).`ALE`Address Latch EnableInputWhen high, tells the NAND that the data bus carries an address byte (which page/block to access).`WE#`Write EnableInputActive-low. Latches data, commands, or addresses from the data bus on the rising edge.`RE#`Read EnableInputActive-low. Clocks data out of the NAND onto the data bus during read operations.`WP#`Write ProtectInputActive-low. Prevents write and erase operations. Must be held high during recovery reads.`R/B#`Ready/BusyOutputOpen-drain output. Low when the NAND is busy (internal read/write/erase in progress). High when ready for next command.`VCC`Power SupplyPower3.3V for most SD/MicroSD NAND. Some newer dies use 1.8V I/O with 3.3V core. Incorrect voltage damages the die.`VSS`GroundPowerGround reference. Multiple VSS pads often exist on the die. All must be connected for stable signal integrity.
ONFI vs Toggle: Micron and Intel/SK Hynix NAND use the ONFI (Open NAND Flash Interface) protocol. Samsung, SanDisk/WD, and Kioxia (formerly Toshiba) NAND use the Toggle-mode interface. Both protocols use the same signal names but differ in timing and data latching behavior. PC-3000 Flash supports both protocols but requires selecting the correct mode before attempting a read.
Spider Board vs Soldering
## Spider Board vs. Wire Soldering
### Spider Board (Needle Probe)
The spider board is a PC-3000 Flash adapter that holds adjustable needle probes on micro-positioners. Each needle makes contact with one test point on the exposed NAND die. The technician aligns each needle by hand under a microscope, matching probe positions to signal assignments from the PC-3000 pinout database.
The process demonstrated in our [filmed spider board recovery](/videos/acelab-spiderboard-pc3000-microsd) shows the full procedure: scraping the epoxy with a fiberglass pen, identifying pad locations against the database, and placing each needle onto its assigned signal. Chris, our flash recovery technician, placed 17 individual needles on a single microSD card in that session.
No soldering heat applied to the die
Repositionable if initial placement misses a pad
Lower risk of trace damage from flux and solder wick
Spider board and PC-3000 Flash system are costly professional equipment
Sharp needles can scratch traces if pressure is too high
### Direct Wire Soldering
The older method: solder 30 AWG (or finer) jumper wires directly onto each test point, then connect each wire to the corresponding pin on a PC-3000 Flash circuit board adapter. This was the standard approach before spider boards existed and is still used when test points are too deeply recessed for needle contact.
Wire soldering requires a micro-tipped iron, flux, and magnification. Each solder joint must bridge a pad that may be smaller than 0.1 mm across. A solder bridge between adjacent pads creates a short that can corrupt the read or damage the die. Flux residue can also cause intermittent signal issues if not cleaned.
Works on deeply recessed pads where needles cannot reach
Lower equipment cost (standard soldering station)
Heat risk to the NAND die from soldering iron
One-shot: lifting a pad from excess heat destroys that signal path
Solder bridges between adjacent pads risk shorts
![Spider board needles contacting exposed NAND test points on a microSD card connected to PC-3000 Flash](/_next/image?url=%2Fimages%2Fservices%2Fmicrosd-recovery%2Fmicrosd_spider_1.1.3_optimized.jpg&w=1920&q=75)Spider board wiring from our lab: each needle contacts a single test point on the monolithic die. This particular card required 17 needle placements to capture all data bus, control, and power signals.
Monolith Chip Database Table
## Common Monolithic Flash Chip Families
The table below lists monolithic flash families we encounter regularly. Recovery success depends on whether the specific hardware revision matches an entry in the PC-3000 Flash pinout database and whether the NAND die is physically intact.
BrandModelForm FactorCapacitiesNAND TypeInterfaceSamsungEVO Plus (2021+)MicroSD32 GB, 64 GB, 128 GB, 256 GB`V-NAND TLC``8-bit Toggle`SamsungEVO SelectMicroSD64 GB, 128 GB, 256 GB, 512 GB`V-NAND TLC``8-bit Toggle`SamsungPRO Plus / PRO UltimateMicroSD / SD128 GB, 256 GB, 512 GB`V-NAND TLC``8-bit Toggle`SanDiskUltra / Ultra PlusMicroSD16 GB, 32 GB, 64 GB, 128 GB, 256 GB`BiCS TLC (WD/Kioxia)``8-bit Toggle`SanDiskExtreme / Extreme ProMicroSD / SD32 GB, 64 GB, 128 GB, 256 GB, 512 GB, 1 TB`BiCS TLC (WD/Kioxia)``8-bit Toggle`KingstonCanvas Select Plus / Canvas Go PlusMicroSD / SD32 GB, 64 GB, 128 GB, 256 GB`TLC (various suppliers)``8-bit ONFI or Toggle`Generic / UnbrandedVarious (no-name, promotional, counterfeit)MicroSD / SD / USBVaries (often misreported)`Recycled or downbinned TLC/QLC``8-bit ONFI (typical)`LexarPLAY / 1066x / SILVERMicroSD / SD64 GB, 128 GB, 256 GB, 512 GB, 1 TB`TLC (Micron/Longsys)``8-bit ONFI`
Samsung EVO Plus (2021+)
Transition from discrete controller (Marvell 88NV1120) to monolithic began in 2021 revisions. Older EVO Plus cards with separate controller are recoverable via standard chip-off.
Samsung EVO Select
Amazon-exclusive variant of EVO Plus. Same monolithic silicon with different labeling. Identical recovery procedure.
Samsung PRO Plus / PRO Ultimate
Higher-endurance variant with the same monolithic architecture. UHS-I and UHS-II versions exist with different pinout layouts.
SanDisk Ultra / Ultra Plus
SanDisk uses Toggle-mode NAND interface (not ONFI). Requires Toggle-mode support in PC-3000 Flash. Multiple hardware revisions exist under the same model name with different internal layouts.
SanDisk Extreme / Extreme Pro
V30/A2 rated cards. Monolithic packaging in MicroSD form factor. Full-size SD versions may use discrete controller in older revisions.
Kingston Canvas Select Plus / Canvas Go Plus
Kingston sources NAND from multiple suppliers (Micron, SK Hynix, Kioxia) across production runs. The same model number may have different internal architectures depending on manufacturing date.
Generic / Unbranded Various (no-name, promotional, counterfeit)
No-name and counterfeit cards frequently use recycled NAND dies from failed production runs. Pinout databases may not have matching entries. Recovery requires manual signal probing with an oscilloscope to identify the data bus configuration.
Lexar PLAY / 1066x / SILVER
Lexar (now owned by Longsys/Shenzhen Foresee) uses Micron NAND in most models. Recovery success depends on whether the specific revision matches a known pinout in the PC-3000 Flash database.
Hardware revisions change without notice
Manufacturers regularly change internal silicon while keeping the same external model number and packaging. A Samsung EVO Plus purchased in 2022 may have a different die layout than one purchased in 2024. The PC-3000 Flash pinout database is updated regularly, but newly released revisions may require manual signal probing before a known-good pinout entry exists.
Recovery Process
## Monolith Recovery Process
- 1
### Epoxy Decapsulation
Sand away the protective coating using a fiberglass pen, starting coarse and progressing to fine grit. The goal is to expose the copper test points on the silicon die without gouging them. One slip with too much pressure severs a trace and eliminates that signal path permanently. This step alone can take over an hour depending on the epoxy thickness and chip layout.
- 2
### Pinout Identification
Match the exposed pad layout against the PC-3000 Flash pinout database. Each monolithic chip family has a different arrangement of data bus lines, control signals, and power connections. If the exact chip revision exists in the database, the pinout map shows which pad carries which signal. If no match exists, the technician must probe each pad with an oscilloscope to identify signals manually by their electrical characteristics (data lines toggle during read attempts; CE# pulls low on selection; R/B# transitions indicate busy states).
- 3
### Needle Placement or Wire Bonding
Using the spider board, position a spring-loaded needle probe on each identified test point. A typical monolithic MicroSD requires 15 to 20 needle placements. Each needle must make firm contact with its pad without shorting to adjacent pads or scratching the trace beneath it. If the pads are too recessed for needle contact, micro-soldered jumper wires are used instead.
- 4
### Raw NAND Dump
PC-3000 Flash sends low-level read commands directly to the NAND die, bypassing the dead controller entirely. The tool reads every page of flash memory sequentially, including spare area bytes that contain ECC data and metadata. A 128 GB card produces a raw dump file larger than 128 GB because spare areas add overhead. Multiple read passes verify consistency.
- 5
### Data Reconstruction
The raw dump is not a usable disk image. The controller scrambled data using proprietary algorithms before writing it to NAND. Four transformations reverse this process: **bad column removal** (realign data around defective physical columns mapped out during manufacturing), **XOR descrambling** (reverse the bitwise XOR pattern the controller applied to each page), **ECC correction** (use spare area parity bytes to fix bit errors from NAND wear), and **page assembly** (reconstruct logical sectors from physical NAND pages using the block mapping table). The result is a raw disk image with a recognizable file system (FAT32, exFAT) that can be mounted and files extracted.
Why software fails
## Why Recovery Software Cannot Fix a Dead Monolithic Flash Device
Consumer recovery tools (Disk Drill, Recuva, PhotoRec, R-Studio, TestDisk) all operate above the storage controller. They send SCSI or NVMe commands through the OS driver stack, which forwards them to the flash controller, which translates logical addresses to physical NAND locations. Every link in this chain depends on a functioning controller.
In a monolithic flash device with a dead controller, the first link in the chain is broken. The OS cannot enumerate the device. There is no drive letter, no `/dev/sd*` entry, no Disk Management volume. Recovery software cannot scan what does not exist at the OS level.
This is not a limitation of any particular software tool. It is a fundamental architectural boundary. The only way past it is to bypass the controller entirely with hardware that speaks the raw NAND flash protocol (the signal lines documented above) and reads memory cells directly from the silicon.
Video section
## Filmed Monolith Recovery Procedures
### Spider Board MicroSD Recovery
Full procedure from epoxy removal through needle placement on a dead microSD card. Shows the PC-3000 Flash pinout database, signal identification, and the complete spider board wiring process. 33 minutes.
[Watch the spider board recovery video](/videos/acelab-spiderboard-pc3000-microsd)
### MicroSD Data Recovery Guide
Overview of the full monolithic microSD recovery workflow, from initial inspection through data reconstruction and file verification.
[Watch the MicroSD recovery guide](/videos/microsd-card-data-recovery-guide)
Pricing section
## Monolith Recovery Pricing
Monolithic flash recovery is priced based on the labor involved and the complexity of the data reconstruction. Every job includes epoxy decapsulation, pinout identification, raw NAND extraction, and full data reconstruction (bad column removal, ECC correction and XOR descrambling in the order the controller requires, page assembly).
Device TypePrice RangeTypical LaborMicroSD (monolithic)$400 - $1,5008 - 20+ hoursSD Card (monolithic)$400 - $1,5006 - 16 hoursUSB Flash Drive (monolithic)$800 - $1,50010 - 24+ hours
Free evaluation. Firm quote before any paid work begins. No data recovered means no charge. Call [(512) 212-9111](tel:+15122129111) or [request an evaluation online](/contact).
Existing flash recovery pages
## Device-Specific Flash Recovery Pages
For detailed recovery procedures, pricing, and case examples specific to each flash media type, see our dedicated service pages:
[### MicroSD Data Recovery
Monolithic chip-off NAND extraction with spider board. ECC correction, XOR descrambling, page assembly. $400-$1,500.](/microsd-data-recovery)[### SD Card Data Recovery
Full-size SDHC/SDXC/SDUC cards. Controller bypass, PCB repair, and monolithic extraction for newer models. $300-$1,500.](/services/sd-card-data-recovery)[### USB Flash Drive Recovery
Controller failure, NAND corruption, and monolith USB drives. Standard chip-off and monolith extraction. $200-$1,500.](/services/usb-flash-drive-data-recovery)
## Frequently Asked Questions
### What is a monolithic flash chip?
A monolithic flash chip integrates the NAND memory and controller logic into a single sealed package, usually with the NAND and controller dies wire-bonded together under one epoxy coating and no separately desolderable chip. Unlike traditional flash devices where the controller is a separate IC on a PCB, monolithic designs have no removable components. When the controller portion fails, the entire chip appears dead to any card reader or USB port. Recovery requires direct access to the NAND test points buried under the chip's protective epoxy coating.
### Why can't data recovery software recover a dead monolithic SD card?
Data recovery software communicates through the operating system's storage driver, which talks to the flash controller. In a monolithic chip, when the controller fails, there is no communication channel for software to use. The OS cannot see the drive at all. Recovery requires physically bypassing the dead controller by wiring directly into the NAND test points and reading raw flash memory with specialized hardware like PC-3000 Flash.
### What is a spider board and how does it work?
A spider board is a PC-3000 Flash adapter with spring-loaded needle probes that make contact with exposed NAND test points on a monolithic chip. Each needle maps to a specific signal line (data bus, chip enable, read enable, write enable, etc.). The spider board eliminates the need to solder fine wires directly onto microscopic pads, reducing the risk of trace damage. The adapter is specialized professional data recovery equipment and requires the PC-3000 Flash system to operate.
### How much does monolith data recovery cost?
Monolithic flash recovery at our lab ranges from $400 to $1,500 depending on chip complexity, capacity, and the condition of the NAND die. The process is labor-intensive: epoxy removal, pinout identification, needle placement, raw dump, and data reconstruction (bad column removal, ECC correction and XOR descrambling in the order the controller requires, page assembly) can take 8 to 20+ hours per job. No data recovered means no charge.
### Can you recover data from a snapped or cracked SD card?
If the NAND die itself is intact, yes. Physical damage to the card's plastic shell, contact pads, or PCB traces does not necessarily mean the memory is destroyed. We sand away the packaging to access the NAND directly. The critical factor is whether the silicon die has fractured. A cracked die means the memory cells are physically damaged and the data in the fracture zone is lost.
### What signals are on a monolithic flash pinout?
A standard NAND flash interface exposes these signal lines: D0 through D7 (8-bit data bus), CE (Chip Enable), CLE (Command Latch Enable), ALE (Address Latch Enable), WE (Write Enable), RE (Read Enable), WP (Write Protect), R/B (Ready/Busy), VCC (power supply, typically 3.3V), and VSS (ground). Monolithic chips route these signals to internal test points that are not accessible without removing the protective epoxy layer.
## Data Recovery Standards & Verification
Our Austin lab operates on a transparency-first model. We use industry-standard recovery tools, including [PC-3000](/pc-3000-data-recovery-tool) and DeepSpar, combined with strict environmental controls to maintain drive integrity. This approach allows us to serve clients nationwide with consistent technical standards.
### [Localized Clean Zone](/do-you-really-need-a-clean-room-for-hard-drive-data-recovery)
Open-drive work is performed in a [0.02 micron ULPA-filtered laminar clean bench](/do-you-really-need-a-clean-room-for-hard-drive-data-recovery).
### Transparent History
Serving clients nationwide via mail-in service since 2008. Our lead engineer holds [PC-3000 and HEX Akademia certifications](/data-recovery-certifications) for hard drive firmware repair and mechanical recovery.
### Media Coverage
Our repair work has been covered by [The Wall Street Journal](https://www.wsj.com/tech/personal-tech/how-the-right-to-repair-might-save-your-gadgetsand-save-you-money-11630324800) and [Business Insider](https://www.businessinsider.com/apple-macbook-pro-repair-quote-unauthorized-2018-12), with [CBC News](https://www.cbc.ca/news/thenational/complete-control-apple-accused-of-overpricing-restricting-device-repairs-1.4859099) reporting on our pricing transparency. Louis Rossmann has [testified in Right to Repair hearings](https://en.wikipedia.org/wiki/Louis_Rossmann) in multiple states and founded the Repair Preservation Group.
### Aligned Incentives
### Technical Oversight
[See the particle counter test at the bench](/do-you-really-need-a-clean-room-for-hard-drive-data-recovery)
[No Data, No FeeGuarantee](/no-fix-no-fee)
[2.64MSubscribers](https://www.youtube.com/playlist?list=PLkVbIsAWN2lsPTNFBoEWjDyAHPcEARZtW)
[4.91,837+ Google Reviews](/reviews)
[Repairs on VideoFull Transparency](/videos)
[BBC News](https://www.bbc.com/news/technology-57763037)/
[CBC News](https://www.cbc.ca/news/thenational/complete-control-apple-accused-of-overpricing-restricting-device-repairs-1.4859099)/
[ABC Australia](https://www.abc.net.au/news/2025-07-20/youtuber-louis-rossmann-takes-on-better-way-electronics/105532410)/
[Wall Street Journal](https://www.wsj.com/tech/personal-tech/how-the-right-to-repair-might-save-your-gadgetsand-save-you-money-11630324800)/
[Business Insider](https://www.businessinsider.com/apple-macbook-pro-repair-quote-unauthorized-2018-12)/
[Vice](https://www.vice.com/en/article/dhs-seized-aftermarket-apple-laptop-batteries-from-independent-repair-expert-louis-rossman)/
[Fast Company](https://www.fastcompany.com/91387927/clippy-is-back-as-a-mascot-for-big-tech-protests)/
[404 Media](https://www.404media.co/developer-unlocks-newly-enshittified-echelon-exercise-bikes-but-cant-legally-release-his-software/)/
[Tom's Hardware](https://www.tomshardware.com/pc-components/ssds/louis-rossman-threatens-to-take-samsung-to-court-over-dead-4tb-990-pro-ssd-after-ssd-maker-failed-to-replace-the-drive-under-warranty)/
[Tom's Hardware](https://www.tomshardware.com/3d-printing/louis-rossmann-tells-3d-printer-maker-bambu-lab-to-go-bleep-yourself-over-its-lawsuit-against-enthusiast-right-to-repair-advocate-offers-to-pay-the-legal-fees-for-a-threatened-orcaslicer-developer)
## Related Flash Media Recovery Services
[MicroSD Data RecoveryMonolithic chip-off NAND extraction](/microsd-data-recovery)[SD Card Data RecoveryFull-size SD and SDHC/SDXC cards](/services/sd-card-data-recovery)[USB Flash Drive RecoveryUSB stick controller failure and monolith](/services/usb-flash-drive-data-recovery)[SSD Data RecoveryNVMe, M.2, SATA solid state drives](/services/ssd-data-recovery)[iPhone Data RecoveryNAND flash on mobile devices](/services/iphone-data-recovery)[All Recovery ServicesView complete catalog](/services)
## Dead SD Card or MicroSD? Send It In.
Free evaluation. Firm quote before any work. No data recovered, no charge. Spider board and chip-off NAND extraction for monolithic SD, MicroSD, and USB flash devices.
[Start Recovery Evaluation](/contact)[Call (512) 212-9111](tel:+15122129111)
[(512) 212-9111](tel:+15122129111)Mon-Fri 10am-6pm CT
## Services
- [Hard Drive Recovery](/hard-drive-data-recovery)
- [SSD Recovery](/services/ssd-data-recovery)
- [RAID Recovery](/services/raid-data-recovery)
- [NAS Recovery](/services/nas-data-recovery)
- [Server Recovery](/services/server-data-recovery)
- [Mac Recovery](/services/macbook-data-recovery)
- [iPhone Recovery](/services/iphone-data-recovery)
- [SD Card Recovery](/services/sd-card-data-recovery)
- [microSD Recovery](/microsd-data-recovery)
- [Seagate](/services/seagate-data-recovery)
- [Western Digital](/services/western-digital-data-recovery)
- [Seagate Rosewood](/services/seagate-rosewood-data-recovery)
- [WD Spyglass](/services/wd-spyglass-data-recovery)
## Company
- [About](/about)
- [Louis Rossmann](/louis-rossmann)
- [Our History](/our-history)
- [Reviews](/reviews)
- [Pricing](/pricing)
- [Contact](/contact)
- [Austin, TX](/data-recovery-austin)
- [All service areas](/services/data-recovery/locations)
- [New York, NY](/services/data-recovery/locations/ny/new-york)
- [Los Angeles, CA](/services/data-recovery/locations/ca/los-angeles)
- [Chicago, IL](/services/data-recovery/locations/il/chicago)
- [Houston, TX](/services/data-recovery/locations/tx/houston)
## Resources
- [Technical Reference](/technical-reference)
- [Developer Resources](/developers)
- [Mail-In Guide](/mail-in-data-recovery)
- [FAQ](/faq)
- [No-Fix-No-Fee Guarantee](/no-fix-no-fee)
- [Data Recovery Myths](/data-recovery-myths)
- [Counterfeit SD cards](/counterfeit-sd-cards)
- [Why It Costs So Much](/why-data-recovery-costs-so-much)
- [Recovery videos](/videos)
- [Clicking hard drive](/symptoms/clicking-hard-drive)
- [Beeping hard drive](/symptoms/beeping-hard-drive)
- [Drive not detected](/symptoms/drive-not-detected)
- [Blog](https://blog.rossmanngroup.com)
- [Full sitemap](/sitemap)
## Connect
- [Best Data Recovery Service](/best-data-recovery-service)
- [Is DriveSavers Legit?](/is-drivesavers-data-recovery-legit)
- [Is WeRecoverData Safe?](/is-werecoverdata-recovery-safe)
- [Honest Companies](/honest-data-recovery-companies)
- [Fake Locations](/fake-data-recovery-locations)
- [Fake Reviews](/fake-reviews-data-recovery)
[Rossmann Repair Group](/)Austin, TX · Mail-in from all 50 states
[(512) 212-9111](tel:+15122129111)[help@rossmanngroup.com](mailto:help@rossmanngroup.com)2410 San Antonio Street, Austin, TX 78705Mon-Fri: 10 AM - 6 PM CT
© 2026 Rossmann Repair Group. All rights reserved.
[Editorial Standards](/editorial-standards)[Privacy Policy](/privacy-policy)[Terms of Service](/terms-of-service)[Data Security](/data-security)
