Enterprise Storage Array Recovery
# SAN Storage Data Recovery
We recover data from failed SAN arrays by extracting drives, imaging them through SAS HBAs, and reconstructing LUN layouts from vendor-specific on-disk metadata. Dell EMC, NetApp, HPE, Pure Storage. Free evaluation. **No data = no charge.**
[FREE ESTIMATE](/contact)[Mail-In Service](/mail-in-data-recovery)
![Louis Rossmann](/_next/image?url=%2Fimages%2Flouis-rossmann-portrait.jpg&w=3840&q=75)
[Louis Rossmann](/louis-rossmann)Founder & Chief Technician
Updated June 2026
13 min read
Overview
## How SAN Storage Arrays Fail and How We Recover Them
**A SAN (Storage Area Network) presents block-level storage to host servers over iSCSI or Fibre Channel. The SAN controller manages RAID groups, thin provisioning, snapshots, and LUN mapping. When the controller fails or multiple drives in a RAID group degrade simultaneously, the LUNs go offline and all connected hosts lose access to their storage. Recovery requires extracting the physical drives, imaging them with SAS-aware hardware, and reconstructing the vendor-specific RAID group and LUN metadata from raw images.**
The key distinction between SAN recovery and standard RAID recovery is the additional abstraction layers. A SAN controller maps physical drives into RAID groups, carves RAID groups into pools, and presents pools as LUNs. Each layer has its own metadata structure that must be reconstructed correctly. Standard RAID recovery tools designed for consumer NAS or Linux mdadm arrays cannot parse these vendor-proprietary formats.
Supported SAN Platforms
## Supported SAN Platforms and Their Storage Architectures
Every major SAN vendor writes its RAID-group geometry to the member drives, not just the controller. We image each SAS member at its native 512-byte, 520-byte, or 528-byte sector size, parse the on-disk metadata, and rebuild the array in software. The failed storage processor, controller pair, or chassis is never required.
Each SAN vendor implements RAID, LUN mapping, and data placement differently. Below is how we approach recovery for each major platform.
### Dell EMC Unity and VNX
Dell EMC Unity runs its own Unity Operating Environment (OE) on dual storage processors. Legacy CLARiiON and VNX1 systems used FLARE; VNX2 used MCx (Multi-Core Everything). Unity has a distinct storage stack. All three platforms write proprietary RAID metadata to reserved sectors on each member drive. RAID groups are carved into storage pools, which are thin-provisioned into LUNs.
- **RAID types:** RAID 5, RAID 6, RAID 1/0 with hot spares. Unity also supports dynamic RAID pools that distribute data across all drives in a pool.
- **Sector format:** VNX historically used 520-byte sectors on SAS drives. Unity supports both 512-byte and 520-byte depending on the drive model and firmware. Our imaging process auto-detects and preserves the native sector size.
- **Common failure:** Storage processor panic loop after firmware update. Both SPs reboot continuously, making all LUNs inaccessible. The drives themselves remain healthy.
### NetApp FAS and AFF (ONTAP)
[NetApp ONTAP](/services/server-data-recovery/netapp-fas-ontap) uses WAFL (Write Anywhere File Layout), a copy-on-write filesystem that writes modified data to new disk locations on each consistency point. WAFL maintains consistency through consistency points (CPs) triggered at a default maximum interval of 10 seconds. The underlying RAID uses RAID-DP (double parity, similar to RAID 6) or RAID-TEC (triple parity for large aggregates).
- **WAFL structure:** Data blocks are organized into aggregates, which contain flexible volumes (FlexVols). Each FlexVol contains NFS exports or iSCSI LUNs. WAFL's write-anywhere design means data blocks are scattered across the aggregate rather than sequentially allocated.
- **Sector format:** NetApp uses 4KB block sizes internally on WAFL, typically on drives formatted with 520-byte sectors. ONTAP 9.x added support for 512e Advanced Format drives.
- **Common failure:** Multiple drive failures exceed RAID-DP parity tolerance. WAFL goes read-only, then offline if additional drives fail. Aggregate reconstruction requires all surviving members plus accurate RAID-DP geometry.
### HPE Nimble and 3PAR
HPE Nimble uses a CASL (Cache Accelerated Sequential Layout) architecture that writes data sequentially to flash-backed cache, then destages to spinning disk in large sequential writes. 3PAR uses a chunklet-based architecture that distributes data across all physical drives in fixed allocations (1GB on modern StoreServ; 256MB on legacy F-Class and T-Class).
- **Nimble recovery:** CASL's sequential layout simplifies drive-level imaging because data is written in large contiguous blocks. The flash cache (SSD tier) must be imaged alongside spinning capacity drives to capture in-flight writes.
- **3PAR chunklets:** 3PAR breaks every physical drive into chunklets (small fixed-size allocations). RAID groups are built from chunklets scattered across multiple drives. This fine-grained distribution requires precise chunklet mapping to reconstruct the virtual volume.
- **Common failure:** Controller node failure in a multi-controller 3PAR cluster. If the surviving node cannot assume ownership of all virtual volumes, LUNs go offline. The chunklet metadata is stored on dedicated metadata drives that must be identified and imaged first.
### Pure Storage FlashArray
Pure Storage FlashArray is an all-flash platform that uses proprietary data reduction (deduplication and compression) with RAID-HA (a distributed RAID implementation). Data is written in variable-length segments after deduplication, making traditional RAID reconstruction insufficient.
- **Deduplication-aware recovery:** FlashArray stores deduplicated segments with a metadata index that maps logical addresses to physical segment locations. Losing the metadata index makes data unrecoverable through standard RAID methods. Recovery requires parsing Pure's proprietary segment tables.
- **NVMe drives:** Newer FlashArray//X and //XL models use NVMe DirectFlash modules. These require NVMe-capable imaging hardware, not SAS HBAs.
- **Common failure:** Controller pair failure with corrupted NVRAM cache. The NVRAM holds uncommitted writes that have been acknowledged to the host but not yet written to flash. Losing NVRAM can result in data loss for recent writes.
### How do you recover a Pure DirectFlash Module (DFM)?
A Pure DirectFlash Module is raw NAND managed globally by the Purity//FA controller, not an off-the-shelf NVMe SSD with its own self-contained flash translation layer. Purity owns the FTL, garbage collection, and global deduplication across the entire DFM set, so a single module holds no independently coherent volume. Imaging a pulled DFM requires NVMe-capable imaging hardware, not a SAS HBA, because the module presents an NVMe interface rather than SAS.
A per-DFM image is necessary but not sufficient. The image yields controller-addressed, globally-deduplicated variable-length segments that only resolve through Purity's global metadata index, and that index is parsed across the surviving DFM set as a whole. This is the procedural distinction from traditional SAS RAID-group recovery, where each imaged SAS member is independently coherent under a parseable on-disk RAID label and can be destriped against its peers. With a FlashArray, no module is self-describing; the segment index is the map, and every DFM image feeds it.
### Why are Purity snapshots and replication lost when the metadata index is corrupted?
Purity snapshots are metadata-only pointers into the deduplicated segment pool, not full data copies. A snapshot records the segment references that were live at a point in time; it does not duplicate a single byte of NAND. Async replication ships only the changed segments to the target array and tracks them through the same segment index.
If the segment metadata index is lost or corrupted, every snapshot and every replication baseline is orphaned at once, because all of them reference physical segments through that one index. This is categorically different from losing a single drive in a parity group. A failed drive costs one member that parity or a head swap can rebuild; a corrupted Purity index detaches the entire history of the volume from the data that backs it. Recovery work centers on reconstructing the index from its on-flash structures, not on rebuilding any one module.
Non-standard Sector Sizes
## Non-Standard Sector Sizes in Enterprise SAN Drives
**Enterprise SAN platforms commonly format SAS drives with 520-byte or 528-byte sectors instead of the standard 512-byte sectors used by consumer drives. The additional 8 or 16 bytes per sector carry T10 DIF (Data Integrity Field) checksums, reference tags, and application tags used by the SAN controller for end-to-end data integrity verification.**
### 520-Byte Sectors (T10 DIF Protection)
Used by Dell EMC VNX/Unity, NetApp FAS, and older HP EVA arrays. Each sector contains 512 bytes of user data plus an 8-byte protection information field: 2-byte guard tag (CRC), 2-byte application tag, and 4-byte reference tag. The SAN controller verifies these checksums on every read and write.
### 528-Byte Sectors (Legacy Format)
Used by IBM DS8000, some Hitachi VSP configurations, and older mainframe-attached storage. The additional 16 bytes per sector include 8 bytes of T10 DIF-style protection plus 8 bytes of vendor-specific or legacy metadata fields inherited from mainframe CKD-to-FBA conversion. These sectors must be preserved during imaging to maintain RAID parity calculations that include the protection fields.
Consumer imaging tools that strip the extra bytes or zero-fill them will produce images that fail RAID reconstruction. Our imaging hardware preserves the full sector contents, including DIF fields, at the native sector size. For RAID reconstruction, Data Extractor Express RAID Edition accounts for the non-standard sector size when calculating parity and stripe offsets.
Failure Scenarios
## Common SAN Failure Scenarios
Most SAN outages are controller-side, not media-side. Storage-processor panic loops, failed firmware updates, cache-battery loss, and accidental LUN deletion leave the member drives healthy. We image each member drive individually through a write-blocked SAS interface before any rebuild, then reconstruct the RAID groups and LUNs from the on-disk metadata.
### Controller Pair Failure
Both SAN controllers fail simultaneously (firmware bug, power event, or environmental failure). Drives are healthy but no controller is available to present LUNs. We bypass the controller entirely.
### RAID Group Degradation
Multiple drives in a RAID group fail beyond the parity tolerance (two drives in RAID 5, three in RAID 6). The SAN marks the RAID group as faulted and the LUNs on it go offline. Imaging every member before any parity rebuild is the same discipline our [RAID data recovery](/services/raid-data-recovery) team applies to standalone arrays.
### Firmware Update Gone Wrong
Storage processor firmware update fails mid-write, corrupting the controller's internal configuration database. All RAID group definitions and LUN mappings become unreadable from the controller, but the on-disk metadata on each member drive is intact.
### Cache Battery Failure
SAN write cache uses battery-backed or supercapacitor-backed RAM. When the battery fails during a power outage, uncommitted cached writes are lost. The SAN may force a full parity consistency check or refuse to bring LUNs online.
### Accidental LUN Deletion
Administrator accidentally deletes a LUN or destroys a storage pool. The SAN controller marks the space as free, but the data remains on the physical drives until overwritten by new allocations. Stop all I/O to the pool immediately.
### Environmental Damage
Flooding, fire suppression discharge, or HVAC failure causes condensation on drive platters or PCB corrosion. Individual members require board-level repair or head swaps before imaging can begin.
Lun Reconstruction And Destriping
## LUN Reconstruction and Destriping Methodology
LUN reconstruction is staged. We image each member, parse the RAID-group metadata the controller wrote to the disks, and assemble the array geometry virtually in software against the image files. We then locate the LUN container, mount it as a block device, and extract the VMFS, NTFS, or ext4 filesystem the host wrote inside it.
This section details the technical process for IT administrators evaluating our capability to handle SAN-level recoveries.
### 1. Drive Extraction and Slot Mapping
Drives are extracted from the SAN chassis with precise slot labeling (enclosure ID, slot number). SAN controllers map drives to RAID groups by physical slot, so preserving this mapping is essential. We photograph each enclosure and label drives before removal. If the SAN uses multiple enclosures (DAEs/JBODs), each enclosure is documented separately with its SAS topology (SAS expander chain order).
### 2. SAS Imaging with Sector-Size Preservation
Each drive is connected to an imaging workstation through a SAS HBA (Host Bus Adapter). The imaging software queries the drive's reported sector size and configures imaging accordingly. For 520-byte sector drives, the full 520-byte sector is captured; the extra 8 bytes are not stripped or modified. Imaging throughput for healthy SAS 10K/15K drives averages 150-200MB/s. Drives with media defects are imaged with head maps and adaptive retry parameters.
### 3. RAID Group Metadata Parsing
Each SAN vendor stores RAID group definitions in reserved sectors on the member drives. Dell EMC writes metadata in the last sectors of each drive (similar to DDF but proprietary format). NetApp stores RAID-DP geometry in RAID labels written to reserved sectors on each physical disk. Data Extractor Express RAID Edition reads these metadata blocks and constructs a virtual disk definition: RAID level, stripe size (typically 64KB or 256KB for SAN arrays), member ordering, parity placement (left-asymmetric, left-symmetric, right-asymmetric, or right-symmetric), and rebuild state.
For metadata-less scenarios (zeroed or overwritten metadata), we detect parameters through brute-force testing of stripe size and member order permutations against known filesystem signatures (NTFS MFT, VMFS superblock, ext4 superblock).
### 4. LUN Mapping and Thin Provisioning
After reconstructing the RAID group as a virtual disk, we map LUN extents within it. Traditional (thick-provisioned) LUNs occupy contiguous ranges within the RAID group and can be extracted by offset and size. Thin-provisioned LUNs use an allocation table maintained by the SAN controller that maps logical LUN blocks to physical RAID group blocks.
We parse this allocation table from the controller's on-disk metadata to reconstruct the LUN. If the allocation table is damaged, we fall back to filesystem-level carving within the RAID group image.
### 5. Filesystem Extraction
The reconstructed LUN image is mounted read-only for filesystem extraction. Common filesystems on SAN LUNs include VMFS (for ESXi datastores), NTFS/ReFS (for Windows servers), ext4/XFS (for Linux hosts), and raw block devices for databases (Oracle ASM, SQL Server). For VMFS-backed LUNs, we hand off to our [VMware ESXi recovery pipeline](/services/server-data-recovery/vmware-esxi) for .vmdk extraction. Database volumes are delivered as raw LUN images for the client's DBA to attach.
### Controller-Independent Reconstruction From On-Disk Metadata
A dead controller card does not mean unrecoverable data. Enterprise controllers write their RAID structural metadata to the member drives, not to controller NVRAM. [Dell PERC](/services/raid-data-recovery/controllers/dell-perc)and LSI/Broadcom MegaRAID controllers write a variant of the SNIA DDF (Disk Data Format): the 512-byte Anchor Header sits at the absolute last LBA of each member drive, and MegaRAID reserves 512 MB at the end of each member for that metadata.
[HP Smart Array P-series and E-series controllers](/services/raid-data-recovery/controllers/hp-smart-array) do not use DDF; they write a proprietary RAID Information Sector (RIS) to raw reserved physical sectors at the start of each drive, independent of any OS partitioning scheme, a different on-disk format. Newer HPE MR-series controllers are rebranded Broadcom and use DDF on the trailing sectors instead.
Because chunk size, member order, and parity rotation live on the disks, the original controller is never required. We image each member drive individually through a SAS HBA with a hardware write-blocker in the path before any reconstruction is attempted. The array geometry is then parsed and reassembled virtually in software against the image files, never against the live members.
Software-defined arrays are reassembled with mdadm --assemble --readonly; hardware-array geometry is reconstructed in Data Extractor Express RAID Edition running on the PC-3000 Express. The imaging hardware captures the members; the reconstruction is a software operation.
### iSCSI LUN Recovery Is a Layered Extraction
An [iSCSI LUN](/services/filesystem-recovery/iscsi-lun) presented over the SAN is not a physical partition. It is a virtual block device mapped within the vendor's proprietary storage stack (WAFL on NetApp, Unity OE on Dell EMC, CASL on Nimble). Recovery is staged: rebuild the underlying RAID array, parse the vendor's allocation tables to extract the LUN container, then mount that extracted block device to reach the guest filesystem (VMFS, NTFS, or ext4) the initiator wrote inside it.
### Image-First Reconstruction
The engineering reality of SAN reconstruction is concrete and controller-independent. Each member is cloned member-by-member, the 520-byte or 528-byte T10 DIF formatting is preserved during imaging, the DDF or RIS metadata is parsed at the hex level, and the array geometry is rebuilt in software from the image files. There is no proprietary black box and no risky live rebuild on the original members.
### Thin-Provisioning Pool Bitmap Corruption
A thin-provisioned LUN can read as empty or truncated even when every RAID-group image is intact. This is distinct from a damaged allocation table. The over-committed pool tracks which physical RAID-group extents back which logical LUN blocks in an allocation bitmap. When that bitmap is corrupted, a normal allocation-table walk follows broken back-pointers and returns an empty or short LUN, while the underlying 64KB or 256KB stripes still hold the data untouched on the reconstructed RAID-group image.
Recovery does not start by trusting the pool geometry. We carve LUN extents directly from the raw reconstructed RAID-group image by scanning for filesystem signatures: the NTFS MFT record header, the VMFS superblock and its heartbeat region, and the ext4 superblock at its fixed 1024-byte offset with the 0xEF53 magic. Located extents are reassembled in logical order first, and only then is the pool geometry rebuilt against the recovered layout. This is the same image-first, forensic-bitmap-parsing discipline applied to proprietary thin-provisioned formats such as the Drobo allocation bitmap, parsed from raw images rather than read back through the failed controller.
### Does an MPIO Path Failover or ALUA LUN Trespass Destroy Data?
No. A path failover or ALUA trespass changes which controller port serves I/O for the LUN and does not rewrite, relocate, or invalidate any block on the member drives. Multipath I/O is a transport-layer fault-tolerance mechanism. It moves logical ownership between storage processors and leaves the on-disk payload intact.
On Dell EMC CLARiiON and VNX storage processors this ownership shift is historically called a trespass. It fires when the owning storage processor fails, hangs, or is queried and found dead, and the peer processor assumes ownership of the LUN. NetApp ONTAP uses ALUA across HA pairs in multi-network and multi-fabric configurations. In every one of those cases the RAID group underneath is the layer that actually holds the data, which is why the triage discipline is the same one our [RAID array recovery](/services/raid-data-recovery) work applies to a standalone controller failure.
ALUA (Asymmetric Logical Unit Access) arrived in the SCSI-3 standard. Volumes are reachable through multiple target ports organized into target port groups, each group carrying an access state:
Active/OptimizedThe preferred path for I/O to the port group that currently owns the LUN.
Active/Non-OptimizedA valid path with higher latency and lower throughput. On Pure Storage FlashArray, which uses ALUA prioritization, Linux hosts need multipath configured with `detect_prio "no"` so the default prioritizer does not override the ALUA setting and leave half the paths sitting in this state.
StandbyThe target port is inactive but can be made active quickly. Reported as `2/0 0x2 0x4 0xb`, NOT READY - LOGICAL UNIT NOT ACCESSIBLE, TARGET PORT IN STANDBY STATE.
TransitioningLUN ownership is actively moving between storage processors. Reported as `2/0 0x2 0x4 0xa`, NOT_READY - LUN IS NOT READY AND TARGET PORT IS IN TRANSITION.
Unavailable and OfflineFurther access states defined by the standard for ports that cannot currently serve the LUN.
What the administrator actually sees is a topology that looks terminal. `multipath -ll` lists paths as failed or degraded while others still report `active ready running`. Path thrashing shows up as a stream of ASYMMETRIC ACCESS STATE CHANGED alerts, `2/0 0x6 0x2a 0x6`, while the host routes I/O to the wrong port group or ownership keeps transitioning. When every path to a LUN returns LOGICAL UNIT NOT SUPPORTED, VMware ESXi marks the device Permanent Device Loss and the datastore vanishes from the host, which is why an [ESXi datastore that disappeared](/services/server-data-recovery/vmware-esxi) is so often a fabric isolation event on an array that is still healthy. None of those symptoms is data loss.
The triage test is to compare what the array management interface reports against what the host reports. If the array lists its LUNs and RAID groups as online and healthy while the hypervisor shows Permanent Device Loss or the SCSI layer returns `DID_NO_CONNECT`, the fault is in the fabric or the multipath configuration and no recovery work is warranted. If the array itself reports a faulted RAID group, an offline disk group, or unreadable LUN metadata, the failure is at one of the layers this page documents: a RAID group faulted beyond its parity tolerance, thin-pool or [LUN container metadata](/services/filesystem-recovery/iscsi-lun) damage, storage-processor write-cache loss with a dirty cache, or physical member failure. At that point the members are pulled and imaged individually through a SAS HBA with a hardware write-blocker in the path, and the array geometry is reconstructed virtually in software with Data Extractor Express RAID Edition against the image files, never against the live members.
On NVMe over Fabrics backends, Asymmetric Namespace Access is the multipathing analogue of SCSI ALUA, supported by both DM Multipath and native NVMe multipathing to identify the optimized paths between controller and host. The same reasoning holds: namespace path state is a transport property, not a statement about the media.
## SAN Recovery Pricing
**SAN recovery follows the same transparent pricing model as every other service: per-drive imaging based on each drive's condition, plus a reconstruction fee per RAID group. No data recovered means no charge.**
Service TierPrice Range (Per Drive)DescriptionLogical / Firmware Imaging$250-$900Firmware module damage or SMART threshold failures on individual SAS members. Most healthy SAN drives fall in this tier.Mechanical (Head Swap / Motor)$1,200-$1,50050% depositDonor parts for SAS drives matched by model, firmware revision, head count, and preamp version.RAID Group ReconstructionCustom Quoteper RAID groupMetadata parsing, RAID reconstruction, LUN extraction, and filesystem mount. One fee per RAID group in the SAN.
**No Data = No Charge:** If we recover nothing from your SAN, you owe $0. Free evaluation, no obligation.
We sign NDAs for corporate data recovery. All drives remain in our Austin lab under chain-of-custody documentation. We are willing to discuss specific security and privacy requirements before work begins.
## SAN Storage Recovery; Common Questions
Can you recover data from a SAN with a dead controller?
Yes. SAN controllers manage RAID groups, LUN mapping, and protocol presentation (iSCSI/FC), but the data lives on the physical drives. When the controller dies, we extract the drives, image them through SAS HBAs, and reconstruct the LUN layout from the vendor's on-disk metadata. The original controller hardware is not needed.
What about SAN drives with non-standard sector sizes?
Many SAN platforms format SAS drives with 520-byte or 528-byte sectors. The extra bytes per sector carry checksum and metadata fields used by the SAN controller for data integrity verification. Our imaging hardware captures these sectors intact, which is required for accurate RAID group reconstruction. Standard consumer imaging tools that assume 512-byte sectors will produce unusable images.
Do you recover Dell EMC Unity and VNX arrays?
Yes. Dell EMC Unity and legacy VNX platforms use proprietary RAID group configurations with FLARE (VNX) or MCx (Unity) storage processors. When a storage processor fails or the RAID group degrades beyond the controller's auto-rebuild capability, we image the member drives and reconstruct the LUN layout from Dell's on-disk metadata structures.
Can you recover from NetApp FAS and AFF systems?
Yes. NetApp ONTAP uses WAFL (Write Anywhere File Layout) with RAID-DP (double parity) or RAID-TEC (triple parity). WAFL writes data to new locations on every commit, maintaining a consistent on-disk state through checkpointed consistency points. When hardware fails, we image the member drives and parse the WAFL layout to extract volumes, LUNs, and their underlying files.
Does the SAN protocol (iSCSI vs. Fibre Channel) affect recovery?
No. iSCSI and Fibre Channel are transport protocols between the SAN and the host servers. They do not affect how data is stored on the physical drives. Recovery works at the drive level regardless of which protocol presented the LUN to the host. The only factor that matters is the RAID group configuration and on-disk metadata format.
Does a controller failover or trespassed LUN mean the data is gone?
No. A path failover or ALUA trespass moves logical ownership of the LUN to a peer storage processor and changes which port serves I/O. It does not rewrite, relocate, or invalidate any block on the member drives. Compare the array management interface against the host: if the array reports its LUNs and RAID groups online while the host shows dead paths in multipath -ll, a Permanent Device Loss condition in ESXi, or DID_NO_CONNECT at the SCSI layer, the fault is in the fabric or the multipath configuration and there is nothing to recover. If the array itself reports a faulted RAID group, an offline disk group, or unreadable LUN metadata, that is a genuine data-loss event, and the members should be imaged through a write-blocked SAS interface before any rebuild is attempted.
How is SAN recovery priced?
Same transparent model: per-drive imaging fee based on each drive's condition, plus an array reconstruction fee per RAID group. Large arrays with multiple RAID groups incur one reconstruction fee per group. No data recovered means no charge.
Can you recover a Pure Storage FlashArray DirectFlash module?
Yes, but a single DirectFlash Module (DFM) is not independently coherent. A DFM is raw NAND managed globally by the Purity//FA controller, which owns the flash translation layer, garbage collection, and global deduplication across the whole module set. We image each pulled DFM on NVMe-capable hardware, not a SAS HBA, but a per-module image only yields controller-addressed, globally-deduplicated variable-length segments. Those resolve solely through Purity's global metadata index parsed across the surviving DFM set, which is why FlashArray recovery is fundamentally different from destriping independent SAS RAID members.
Why does a thin provisioned LUN show empty after pool corruption?
Because the pool allocation bitmap, not the data, is corrupted. A thin-provisioned LUN keeps a bitmap that maps logical LUN blocks to physical RAID-group extents. When that bitmap is damaged, a normal allocation-table walk follows broken back-pointers and returns an empty or truncated LUN even though the underlying stripes still hold the data on intact RAID-group images. We carve the LUN extents directly from the raw reconstructed RAID-group image by scanning for filesystem signatures such as the NTFS MFT, the VMFS superblock, and the ext4 superblock, reassemble them in logical order, and rebuild the pool geometry only after the data is located.
[No Data, No FeeGuarantee](/no-fix-no-fee)
[2.64MSubscribers](https://www.youtube.com/playlist?list=PLkVbIsAWN2lsPTNFBoEWjDyAHPcEARZtW)
[4.91,837+ Google Reviews](/reviews)
[Repairs on VideoFull Transparency](/videos)
[BBC News](https://www.bbc.com/news/technology-57763037)/
[CBC News](https://www.cbc.ca/news/thenational/complete-control-apple-accused-of-overpricing-restricting-device-repairs-1.4859099)/
[ABC Australia](https://www.abc.net.au/news/2025-07-20/youtuber-louis-rossmann-takes-on-better-way-electronics/105532410)/
[Wall Street Journal](https://www.wsj.com/tech/personal-tech/how-the-right-to-repair-might-save-your-gadgetsand-save-you-money-11630324800)/
[Business Insider](https://www.businessinsider.com/apple-macbook-pro-repair-quote-unauthorized-2018-12)/
[Vice](https://www.vice.com/en/article/dhs-seized-aftermarket-apple-laptop-batteries-from-independent-repair-expert-louis-rossman)/
[Fast Company](https://www.fastcompany.com/91387927/clippy-is-back-as-a-mascot-for-big-tech-protests)/
[404 Media](https://www.404media.co/developer-unlocks-newly-enshittified-echelon-exercise-bikes-but-cant-legally-release-his-software/)/
[Tom's Hardware](https://www.tomshardware.com/pc-components/ssds/louis-rossman-threatens-to-take-samsung-to-court-over-dead-4tb-990-pro-ssd-after-ssd-maker-failed-to-replace-the-drive-under-warranty)/
[Tom's Hardware](https://www.tomshardware.com/3d-printing/louis-rossmann-tells-3d-printer-maker-bambu-lab-to-go-bleep-yourself-over-its-lawsuit-against-enthusiast-right-to-repair-advocate-offers-to-pay-the-legal-fees-for-a-threatened-orcaslicer-developer)
## Need Recovery for Other Devices?
[Server Data RecoveryDell, HP, IBM enterprise servers](/services/server-data-recovery)[VMware ESXi RecoveryVMFS datastores and vSAN](/services/server-data-recovery/vmware-esxi)[RAID Data RecoveryRAID 0, 1, 5, 6, 10 arrays](/services/raid-data-recovery)[NAS Data RecoverySynology, QNAP, Buffalo](/services/nas-data-recovery)[Hard Drive RecoveryMechanical HDD recovery](/hard-drive-data-recovery)[Drobo Data RecoveryThin-provisioned BeyondRAID pool extraction](/services/drobo-data-recovery)[All ServicesComplete service catalog](/services)
## Ready to recover your SAN array?
[Start a Case](/contact)[Server Recovery Overview](/services/server-data-recovery)
[(512) 212-9111](tel:+15122129111)Mon-Fri 10am-6pm CT
