Board-Level Failure Modes on iPhone Logic Boards
Most iPhone data recovery failures trace to one of four IC families: the charging controller, the audio codec, the baseband subsystem, or the NAND package. Each has a characteristic symptom pattern and a specific rework procedure. Identifying which IC family failed determines the repair steps and the tools required to restore a bootable board.
Most iPhone data recovery failures trace to one of four IC families: the charging controller (Tristar, Tigris, or Hydra), the audio codec, the baseband subsystem, or the NAND package. Each has a characteristic symptom pattern and a specific rework procedure performed on Hakko FM-2032 irons, an Atten 862 hot air station, and a Zhuo Mao BGA rework station at our Austin lab.
Tristar, Tigris, and Hydra: Three Charging IC Generations
Apple has shipped three distinct charging controller ICs across the iPhone line, and the fault signature differs for each. The Tristar IC (CBTL1608 family, board reference U2 on the iPhone 5, U1700 on the 6, and U4500 on the 6s) runs on iPhone 5 through iPhone 6s and handles Lightning data plus USB power negotiation on a single die.
Tigris (reference U2101 on iPhone 7 and 7 Plus) splits the charging and data functions into separate blocks; a blown Tigris commonly reads as a short on VBUS with the phone drawing 400-500 mA at idle. Hydra (U6300) ships on iPhone 8 through 14, routes the USB 2.0 data lines through the SoC rather than a discrete USB PHY, and fails in a way that looks like a charging fault but is actually a data-handshake fault.
The reason this matters for data recovery: if a phone charges but isn't detected by iTunes or Finder, the fault is almost always the charging IC rather than the NAND. We confirm by measuring pin 7 (USB_DP) and pin 8 (USB_DM) against known-good reference voltages on a bench DC supply.
If those lines float, we remove the Tristar, Tigris, or Hydra with the Atten 862 set to a programmed reflow profile, reball the BGA pads, and solder a replacement using the Zhuo Mao station. That restores the data line without touching the encrypted NAND, which is how data recovery software fails on these devices: the software never sees the phone because the USB subsystem itself is dead before any handshake can occur.
Audio IC Cold Solder on iPhone 7 and 7 Plus
The iPhone 7 and 7 Plus ship with a documented reliability defect in the audio codec IC (U3101 on both models). Normal chassis flex during everyday use propagates into the board underneath the audio IC and fatigues the solder joints on the BGA pads over 12 to 24 months.
Customers see the symptom as a grayed-out voice memo recorder, no microphone audio on phone calls, and a Bluetooth audio icon that refuses to connect. Apple's service answer is board replacement at flat-rate cost, which destroys the data because the NAND is paired to the original SoC, not the board itself.
The recovery path: we remove the audio IC with hot air on the Atten 862 rework station, clean the pads with flux and braid, reball the package on the stencil, and reflow the IC back in place with a programmed thermal profile that compensates for the underfill. This repair doesn't touch the cryptographic pairing between the SoC and NAND.
Once audio is back online, we boot the phone, enter the passcode, and copy your photos and messages. For a phone that was bootlooping on top of the audio fault, we diagnose the secondary cause on the same visit.
Baseband Reflow for No-Service and Water-Damaged Phones
A $750 recovery on an iPhone X or newer often involves the baseband subsystem when the phone has taken liquid damage. The baseband CPU varies by generation and carrier.
iPhone X, XS, XR, and most iPhone 11 units ship with Intel XMM basebands (XMM7480 on X, XMM7560 on XS/XR, XMM7660 on 11); Apple moved the entire line to Qualcomm Snapdragon X55 (SDX55M) on iPhone 12, X60 (SDX60M) on iPhone 13, X65 (SDX65M) on iPhone 14, and X70 (SDX70M) on iPhone 15.
The baseband CPU and its companion baseband PMIC (Infineon PMB-series for Intel basebands, Qualcomm PMX-series for Snapdragon basebands) sit on the bottom layer of the sandwich board. Corrosion under either package creates a short on the VDD_CORE_RF rail; the phone then boots to the Apple logo, displays No Service, and drains the battery in under an hour.
Recovery starts with ultrasonic cleaning to halt active corrosion. We then separate the two sandwich layers on the Zhuo Mao rework station using an underfill-safe profile, inspect the baseband underfill for residue, and reflow the baseband CPU back onto clean pads.
A baseband reflow isn't a chip swap; the same silicon goes back onto the original pads once the underfill is cleared and the joints are remade. That preserves the radio calibration data in EEPROM, which is why the phone returns to service after the repair.
If the baseband CPU itself has died (rare, usually from a direct short), the recovery path changes to water-damage data copy only; cellular service isn't restored because the baseband CPU is paired to the SIM tray and the SoC at manufacture.
NAND Reball vs Chip Swap on Face ID Devices
On iPhone 8 and every model since, the NAND package is cryptographically paired to the Secure Enclave inside the SoC at the point of manufacture.
A chip-off recovery (pulling the NAND and reading the raw flash on a programmer) cannot work on these devices because the AES-XTS master key lives inside the Secure Enclave; the raw bytes read from the NAND are ciphertext with no recoverable plaintext. The NAND has to stay paired with the original SoC for the encryption chain to hold.
The recovery procedure we use is a reball, not a swap. If the NAND package has lifted from the pads after a drop or water damage, we remove it with hot air on the Atten 862, clean the BGA pads on both the chip and the board, reball the same package on a stencil, and reflow it back down.
The NAND never leaves the original board. That keeps the cryptographic pairing of SoC and NAND intact and lets the phone decrypt user data after boot. A competitor who swaps the NAND to a donor chip has broken the pairing; the phone will boot but the data partition will fail to mount, and no software can rebuild the destroyed key.
If the SoC itself is physically broken, recovery would mean moving the paired SoC and NAND together to a donor board. We do not offer that board swap at this time, so those cases are not accepted right now. If either chip is destroyed, the data is unrecoverable and you pay nothing.
Current turnaround is 2-6 weeks, set by the volume of devices in the queue right now, not by outsourcing.
