Lab Operational Since: 17 Years, 7 Months, 21 DaysFacility Status: Fully Operational & Accepting New Cases
Data Recovery Pricing
Hard drive data recovery from $100. Free diagnostic evaluation. No data = no charge on qualifying jobs.
Quick answer01/14
Data recovery cost depends on failure type and drive class: hard drives $100–$2,000, SATA SSDs $200–$1,500, NVMe $200–$2,500. Every job starts with a free diagnostic and firm quote, no diagnostic fee. If we can't recover your data, you don't pay. All work is performed in-house at our Austin, TX lab. Published tiers follow, no-fix-no-fee guarantee.
Updated June 11, 2026
Why we publish02/14
How Much Does Data Recovery Cost?
Hard drive data recovery costs $100–$2,000 across five published tiers: $100 for a simple data copy off a working drive, From $250 for file system corruption, $600–$900 for firmware repair, $1,200–$1,500 for head swaps, and $2,000 for platter surface damage. Free diagnostic, firm quote, no-fix-no-fee.
Your SymptomHDDSSD / FlashETA
Drive works, need data copied off$100$2003-5 days
Drive not recognized by your computerFrom $250From $2502-4 weeks
Drive detected but inaccessible or shows wrong size$600–$900$600–$9003-6 weeks
Drive completely dead, no spin, no detectionQuoted after eval$450–$6003-6 weeks
Clicking, beeping, or grinding sounds$1,200–$1,500N/A4-8 weeks
Drive dropped, platters scratched$2,000N/A4-8 weeks
SSD or flash with dead controllerN/A$1,200–$1,5004-8 weeks
All prices + tax + target drive. Head swap, surface damage, and NAND swap tiers require 50% deposit. Donor parts additional on mechanical tiers. Helium-sealed HDDs (Exos, Ultrastar, MG series) have higher pricing at every tier.
No data recovered = no charge. Free diagnostic evaluation. +$100 rush fee available on any job to move to the front of the queue.
HDD pricing03/14
Standard Hard Drive Data Recovery
Standard hard drive data recovery costs $100–$2,000 for non-helium consumer and enterprise drives, depending on the failure type. Simple copies start at $100. Firmware repair runs $600–$900. Head swaps run $1,200–$1,500 plus donor drive cost. Surface damage is $2,000. Pricing reflects worst-case per tier; many jobs come in lower after the free evaluation.
    Your drive is clicking, beeping, or won't spin. The internal read/write heads have failed
By brand: Seagate · Western Digital · Toshiba · Full HDD recovery details
Helium HDD pricing04/14
Helium Hard Drive Data Recovery
Helium-sealed enterprise drives (Seagate Exos, WD Ultrastar, Toshiba MG series) cost more to recover at every tier. Opening the sealed chamber for head swaps requires helium refill and a compatible helium donor drive, both additional costs. Head swaps start at $3,000. Tighter tolerances and specialized donor parts drive pricing higher than standard HDDs.
Helium drives cost more to recover
Helium-sealed drives (Seagate Exos, WD Ultrastar HC series, HGST Ultrastar He, Toshiba MG series) have sealed chambers filled with helium gas. Opening these drives for head swaps requires breaking the hermetic seal, swapping heads from a matching helium donor, and refilling the chamber with helium before re-sealing. Helium refill cost and compatible donor drives are additional on mechanical tiers; see per-tier details below.
    From $600
    Helium drive firmware recovery is more complex due to sealed chamber architecture
    Your helium drive is clicking, beeping, or won't spin. The internal read/write heads have failed
    50% deposit required (usually $1,100 non-refundable deposit). Helium cost ($400-$800) and donor drive cost additional.
    $3,000–$4,500
    $4,000–$5,000
Helium cost
Full helium drive recovery details
SSD pricing05/14
SSD Data Recovery Pricing
SSD data recovery pricing depends on the failure type and drive interface. SATA SSD recovery runs $200–$1,500. NVMe SSD recovery runs $200–$2,500. NAND swap recovery, required when the controller fails, is the highest tier for both types. Free diagnostic evaluation included before any paid work begins.
SATA SSD Recovery
The destination drive we copy recovered data onto. You can supply your own or we provide one at cost plus a small markup. All prices are plus applicable tax.
Full SATA SSD recovery details
NVMe SSD Recovery
Full NVMe SSD recovery details
Flash and mobile pricing06/14
Flash Storage, Mobile & NAS/RAID Recovery
iPhone data recovery runs $300–$650 and requires board-level microsoldering to restore power to the encrypted storage subsystem. Flash drive and SD card recovery starts at $200. NAS and RAID recovery is priced per member drive based on its condition, plus a $400-$800 array reconstruction fee. Free diagnostic evaluation on all device types.
Flash Drive / SD Card / microSD
    $300–$600
    PCB Repair
    Chip-off Data Recovery
Flash drive recovery details · microSD recovery
iPhone Data Recovery
  1. Standard complexity
    Pre-iPhone X Models
    iPhone 5s through iPhone 8 Plus
    Older iPhones without Face ID
    Single-layer logic board. Simpler power architecture with separate Tristar or Hydra USB controller IC. Fewer board layers to diagnose.
    $300–$450
    2-7 business days after evaluation; difficult cases may take several weeks
  2. Higher complexity
    iPhone X and Newer
    iPhone X, XR, XS, 11, 12, 13, 14, 15, 16 series
    Face ID models with stacked sandwich board design
    Sandwich board architecture (two PCBs soldered together). Hydra USB controller IC. Higher component density increases diagnostic and repair time.
    $450–$650
    2-7 business days after evaluation; difficult cases may take several weeks to 2 months
  3. Case-by-case
    Complex / Catastrophic Cases
    Any model with severe physical or corrosion damage
    Severe corrosion, heavy jumper work, long screw damage, or full CPU/NAND/EEPROM transplant
    Board separation, extensive trace reconstruction, donor board transplant of cryptographic triad (SoC + NAND + EEPROM), or multi-fault repair across both sandwich layers.
    Requires in-person or mail-in evaluation to scope the repair
    Quoted after evaluation
    Several weeks to 2 months
No data, no fee. Free evaluation and no diagnostic charges. Full guarantee details. All work performed in-house at our Austin, TX lab.
Full iPhone recovery details
MacBook & NAS/RAID
MacBook Data Recovery (T2/M1/M2)
Soldered SSD recovery with board-level work
$325-$600
NAS/RAID Recovery (per drive)
Each member drive priced individually by condition. Array reconstruction $400-$800 on top. Multi-drive discounts applied when several drives need the same work
$100–$2,000
NAS/RAID pricing note
NAS and RAID recovery is priced per member drive (each drive imaged individually based on its condition) plus a $400-$800 array reconstruction fee. When multiple drives in an array need the same type of work, we apply multi-drive discounts so total cost stays reasonable. A 2-drive NAS mirror with logical issues may cost $900-$1,300 total. A 4-bay NAS where every drive needs head swaps does not cost 4x the single-drive price; we quote the array as a package. Full RAID pricing breakdown.
Donor drive costs07/14
What Do Donor Drives Cost?
Donor drive cost is additional to the labor fee on head swap, surface damage, and NAND swap tiers. Standard HDD donors run $50 to $150 for common models. Helium HDD donors run $200 to $600 plus $400 to $800 for helium refill. Costs vary by model and are passed through at our purchase price.
Donor drive
A compatible, working drive used solely for its internal components. The donor drive is consumed in the process; it can't be reused.
Head swap
We transplant the read/write heads from the donor drive into the patient drive. The donor drive is consumed in the process.
NAND swap
We move NAND flash chips onto a donor PCB. Required for SSDs and flash media with a dead controller.
We source the cheapest compatible donor available & pass the cost through at our purchase price. Competitor labs that exclude donor costs from their base quote (check the Terms of Service) create a gap between the number on the phone & the number on the invoice. We publish ours here.
Drive TypeTypical Donor CostWhen It Applies
Standard HDD$50$150 common; $200$400 rare/high-capacityHead swap ($1,200–$1,500) & surface damage ($2,000) tiers
Helium HDD$200$600 + helium refill ($400$800)Head swap ($3,000–$4,500) & surface damage ($4,000–$5,000) tiers
SATA SSD$40$100 common; $150$300 rare/discontinuedNAND swap ($1,200–$1,500) tier
NVMe SSD$40$100 common; $150$300 rare/discontinuedNAND swap ($1,200–$2,500) tier
Why we publish donor costs separately
The labor fee covers engineering time, imaging, clean bench work, and firmware rebuilds. The donor fee covers the physical part. We list them separately because the donor cost varies by model and availability. Some common 1 TB desktop drives have $50 donors. A discontinued helium enterprise model from 2018 might cost $500+. Bundling these into one number would force us to quote the worst case on every job.
We do not want to pad every quote with worst-case donor pricing when most jobs use a $50-$150 part. We also believe you should see real price ranges before you ship your drive, not a "call for quote" form that tells you nothing.
A large portion of the data recovery industry operates on opaque, call-for-quote pricing with zero published tiers. We think that model exists because it lets companies charge each customer whatever they think that customer will pay. We publish our pricing because we want you to know what you are getting into before you do business with us, not after your drive is already in someone else's hands in another state.
Rush fees08/14
MacBook Repair Pricing
MacBook logic board repair costs $200 to $600 depending on model year. Liquid damage is quoted per damaged component; when several parts are damaged we quote the whole job together and discount each additional repair instead of charging a flat combined rate. Board-level repairs instead of expensive board replacements. Logic board repairs include a 1-year warranty; liquid damage repairs include a 90-day warranty. No fix, no fee applies.
MacBook Logic Board Repair Cost
Standard Repair (Pre-2015)
Unibody/older models up to 2015
$200-$250
MacBooks 2016-2018
2016–2018
$325
Premium Repair (2019+)
Touch Bar, T2 chip models
$425-$600
No fix, no fee guarantee • 1 Year warranty included
MacBook Liquid Damage Repair Cost
Keyboard Repair
Model dependent
$175-$350
Trackpad Repair
Model dependent
$125-$250
Logic Board Repair
Most cases; rare/newer up to ~$600
$250-$425
Multi-Issue Repair
Multiple damaged components quoted together; each additional repair is discounted
Custom quote
90-day warranty on liquid damage repairs
When a MacBook has more than one problem, we quote the whole job as a single multi-issue repair and discount each additional fix instead of charging full price per part. Those quotes can run past $850.
When the total starts to approach what the machine is worth, we tell you so and recommend you do not repair it through us. We would rather lose the job than have you spend more fixing the laptop than it would cost to replace it.
Turnaround09/14
Why Our Data Recovery Costs Less Than Clean Room Labs
We don't pay for pay-per-click ads, affiliate kickbacks, or vanity certifications. We use a validated laminar-flow clean bench at 0.02 µm particle filtration instead of an expensive ISO-certified cleanroom. Your invoice reflects engineering time, donor parts, and imaging hours, not marketing overhead.
You will see competitors advertising multi-million-dollar ISO-certified clean rooms with technicians in full spacesuits. For hard drive data recovery, that level of infrastructure is more theater than necessity.
What actually protects your data is a validated laminar-flow clean bench and an image-first workflow. We validate our bench to zero particle count at 0.02 µm and show the proof on video.
See a full breakdown of how we compare to the big-name labs.
Where Your Money Goes
Engineering time✓ Included
Donor parts (when needed)Billed at cost
PC-3000 imaging hours✓ Included
Clean bench validation✓ Included
Google Ads budget$0
Affiliate kickbacks$0
Vanity certifications$0
What's included10/14
What competitors hide11/14
How to get a quote12/14
Data Recovery Cost Comparison: Rossmann vs Big Labs
ServiceRossmannDriveSavers / Big Labs
Hard drive not detected (firmware)$600–$900$1,500-$3,000
Head swap (standard HDD)$1,200–$1,500$2,500-$4,000+
Head swap (helium drive)$3,000–$4,500 + helium$4,000-$7,000+
Logical recovery (deleted files)$100-$250$700-$1,500
SSD data recovery (SATA)$200–$1,500$1,000-$5,000
NVMe SSD data recovery$200–$2,500$1,000-$5,000
iPhone data recovery$300–$650$3,000-$4,000 typical
MacBook logic board repair$200-$600$750-$1,600+ (board swap)
Evaluation feeFreeFree (device not opened)
Marketing overhead in your bill$0Built into price
Note on iPhone pricing: Multiple documented cases show DriveSavers quoting $2,800-$3,500 for iPhones with simple hardware problems (bad screens, charge ports) that were not data recovery issues at all. Their free evaluation does not involve opening the device. See our full analysis with evidence.
Louis Rossmann discusses DriveSavers iPhone data recovery pricing with Jessa Jones
An important message about DriveSavers regarding iPhone data recovery
Louis Rossmann and Jessa Jones of iPad Rehab discuss documented cases of DriveSavers charging $2,700+ for basic iPhone repairs like screen replacements.
Why the difference? We don't bankroll PPC ads, affiliate kickbacks, or vanity certificates. Your invoice reflects engineering time, donor parts, and imaging hours; not marketing overhead and inflated quotes. Read our analysis →
Data Recovery Cost FAQ
How much does data recovery cost?
Data recovery cost depends on the device type and failure mode, not the brand. Standard hard drive data recovery runs $100–$2,000 across 5 published tiers. Helium HDD recovery (Seagate Exos, WD Ultrastar, Toshiba MG) runs $200–$5,000+ plus a $400-$800 helium refill on mechanical tiers. SATA SSD recovery runs $200–$1,500. NVMe SSD recovery runs $200–$2,500. Flash drive and SD card recovery runs $200–$1,500. iPhone data recovery runs $300–$650. Every job starts with a free diagnostic and a firm quote; if we cannot recover your data, you pay $0.
What are the data recovery prices for each failure type?
Data recovery prices map to the failure mode, not the drive capacity. For HDDs: simple copies start at $100, file system recovery starts at $250, firmware repair runs $600–$900, head swaps run $1,200–$1,500 plus donor drive cost ($50-$150 typical), and surface/platter damage runs $2,000. For SATA SSDs: $200 simple copy, from $250 file system, $450–$600 circuit board, $600–$900 firmware, $1,200–$1,500 NAND swap. NVMe pricing matches SATA at the lower tiers and tops out at $1,200–$2,500 for advanced board rebuild. We publish all 15 HDD/SATA/NVMe tiers so you see the price before you ship the drive.
What does SSD data recovery cost?
SATA SSD data recovery costs $200–$1,500 across 5 tiers. Simple copies cost $200. File system recovery starts at $250. Circuit board repair runs $450–$600. Firmware recovery runs $600–$900. PCB and NAND swap (severe board damage requiring NAND chip transplant to a donor PCB) runs $1,200–$1,500. NVMe pricing follows the same tier structure with a higher ceiling at $1,200–$2,500 for advanced board rebuild. Free diagnostic, firm quote before paid work, and no charge if we cannot recover the data.
What is the rush fee for data recovery?
The rush fee is +$100 flat, applied on top of the tier price, and moves your job to the front of the queue. Same fee applies to HDD ($100), SATA SSD ($100), NVMe SSD ($100), and flash media ($100) jobs. Rush is optional; standard turnaround runs from a few hours for healthy drive imaging to 4-8 weeks for head swaps requiring donor parts. Quoted ETAs reflect realistic queue position, not best-case scenarios.
Are there hidden fees in data recovery pricing?
No. The diagnostic evaluation is free; there is no charge to look at your drive and quote the work. Donor parts on head swap, surface damage, and NAND swap tiers are billed separately at our purchase price (typically $50-$150 for standard HDDs, $200-$600 plus helium refill for helium drives, $40-$100 for SSDs); these are disclosed before you approve the job, not bundled into a worst-case quote. Tax and the target drive for your recovered data are additional. Rush fee is optional. The no-fix-no-fee guarantee means you pay $0 if we cannot recover your files. Compare this to labs that operate on opaque call-for-quote pricing with no published tiers.
Process overview13/14
Data Recovery Prices FAQ
Hard drive data recovery costs $100 to $2,000 for standard drives depending on the failure type. Simple copies start at $100. File system recovery starts at $250. Firmware repair is $600–$900. Head swaps are $1,200–$1,500 plus donor drive cost. Surface/platter damage is $2,000. Helium-sealed drives (Seagate Exos, WD Ultrastar, Toshiba MG series) cost more at every tier due to helium refill and specialized donor requirements; head swaps start at $3,000. We provide a free diagnostic and firm quote before any paid work begins.
Many data recovery companies spend heavily on Google Ads, affiliate programs, and marketing their "ISO-certified clean rooms." These costs get passed to you. We use a validated laminar-flow clean bench (proven on video), do no paid advertising, and let our YouTube channel and word-of-mouth bring customers. Same equipment, lower overhead, lower prices.
Do you charge if you can't recover my data?
No. Our policy is no data, no charge on qualifying recovery jobs. If we cannot recover your files, you pay $0 (optional return shipping only). We provide honest odds of success upfront so you can make an informed decision.
Is there a diagnostic fee?
No. We provide free diagnostic evaluations. After examining your drive, we give you a firm quote and honest assessment of recovery odds before any paid work begins.
Do I need a clean room for hard drive recovery?
For standard hard drive data recovery, a full ISO-certified clean room is not required. What matters is a validated laminar-flow clean bench that is validated to zero particle count at 0.02 µm. We validate our bench and show the proof on video. The clean room in spacesuits marketing is often theater designed to justify higher prices.
How long does data recovery take?
Timing depends on the failure type. Healthy 1TB drives image in a few hours. Light bad sectors add days. Firmware/not-detected issues take 3-6 weeks. Head swaps with donor parts take 4-8 weeks depending on parts availability. A +$100 rush fee to move to the front of the queue is available to move to the front of the queue. We provide time estimates with your quote.
Why is DriveSavers iPhone recovery so expensive?
DriveSavers typically quotes $3,000-$4,000 for iPhone data recovery. Their pricing model is a legacy from hard drive recovery where data is often partially recoverable. iPhone recovery requires component-level repair to restore power to the encrypted storage subsystem. Because the data is cryptographically bound to the main processor, a successful board repair typically allows the processor to decrypt and mount the entire user partition; recovery is nearly all-or-nothing, so DriveSavers charges the top of their range for any recoverable iPhone. Documented cases show them quoting $2,800-$3,500 for phones with simple problems like bad screens that cost $50 to fix. Their "free evaluation" does not involve opening the device. Jessa Jones of iPad Rehab has documented these cases extensively on YouTube.
Nationwide Coverage
View All Locations
Next step14/14
Get a Free Data Recovery Estimate
Tell us about your drive and we'll provide a free diagnostic and firm quote. Mail-in service available from all 50 states.
