Data Recovery Pricing
Hard drive data recovery from $100. Free diagnostic evaluation. No data = no charge on qualifying jobs.
How Much Does Data Recovery Cost?
Hard drive data recovery costs $100 for a simple copy, from $250 for file system corruption, $600–$900 for firmware repair (CMR: $600, SMR: $900), $1,200–$1,500 plus donor drive cost for a head swap (50% deposit required), and $$2,000 plus donor cost for surface/platter damage. All tiers are plus tax and target drive. Helium-sealed drives (Seagate Exos, WD Ultrastar, Toshiba MG series) cost more at every tier: simple copy is $200, firmware is $900, head swaps are $3,000 plus helium refill ($400-$800) plus donor, and surface damage is $4,000 plus helium plus donor. SATA SSD recovery runs $200–$1,500 across 5 tiers. NVMe SSD recovery runs $200–$1,500. Flash drives, SD cards, and microSD recovery runs $200–$1,500 across 4 tiers. Free evaluation and firm quote on every job. No data recovered means no charge.
What Customers Say About Our Pricing
“USE THIS COMPANY!!!! You will not regret it. Extremely professional and transparent about everything, including cost. I sent my hard drive out for repair with another company that quoted me $1500. for a simple recovery. Rossman did better, faster, and significantly more accurately priced ($1300 less!). I loved everything about the interactions I had with their employees.”
Standard Hard Drive Data Recovery
Non-helium consumer and enterprise drives. Pricing ranges reflect worst-case per tier. Many jobs come in lower after evaluation.
Standard HDD Recovery Cost
By brand: Seagate · Western Digital · Toshiba
Helium Hard Drive Data Recovery
Sealed helium-filled enterprise drives require specialized donor parts, helium refill, and tighter tolerances.
Helium drives cost more to recover
Helium-sealed drives (Seagate Exos, WD Ultrastar HC series, HGST Ultrastar He, Toshiba MG series) have sealed chambers filled with helium gas. Opening these drives for head swaps requires breaking the hermetic seal, swapping heads from a matching helium donor, and refilling the chamber with helium before re-sealing. The helium refill alone adds $400-$800, and compatible helium donor drives are more expensive and harder to source than standard air-filled donors.
Helium HDD Recovery Cost
SSD Data Recovery Pricing
SATA and NVMe SSDs have different internal architectures and pricing.
SATA SSD Recovery Cost
NVMe SSD Recovery Cost
Flash Storage, Mobile & NAS/RAID Recovery
Flash Drive / SD Card / microSD
Mobile, MacBook & NAS/RAID
NAS/RAID pricing note
NAS and RAID recovery is priced per member drive (each drive imaged individually based on its condition) plus a $400-$800 array reconstruction fee. When multiple drives in an array need the same type of work, we apply multi-drive discounts so total cost stays reasonable. A 2-drive NAS mirror with logical issues may cost $900-$1,300 total. A 4-bay NAS where every drive needs head swaps does not cost 4x the single-drive price; we quote the array as a package. Full RAID pricing breakdown.
See details: iPhone recovery · microSD recovery · NAS recovery · RAID recovery
MacBook Repair Pricing
Board-level repairs instead of expensive replacements, with clear ranges and warranty coverage.
MacBook Logic Board Repair Cost
MacBook Liquid Damage Repair Cost
Why Our Data Recovery Costs Less Than Clean Room Labs
You will see competitors advertising multi-million-dollar ISO-certified clean rooms with technicians in full spacesuits. For hard drive data recovery, that level of infrastructure is more theater than necessity.
What actually protects your data is a validated laminar-flow clean bench and an image-first workflow. We validate our bench to zero particle count at 0.02 µm and show the proof on video.
The difference in what we charge you is that we do NOT pay for pay-per-click ads, affiliate kickbacks, or vanity certifications. Your cost reflects engineering time, donor parts, & imaging hours, not marketing overhead.
Where Your Money Goes
Our Pricing Promise
All pricing ranges reflect worst-case scenarios. If your repair or recovery is simpler than expected, you pay less. We provide firm quotes after a free evaluation with honest odds of success.
No sales scripts, no pressure. Just an engineer explaining what's wrong, what it takes to fix it, and what it will realistically cost.
Data Recovery Cost Comparison: Rossmann vs Big Labs
| Service | Rossmann | DriveSavers / Big Labs |
| Hard drive not detected (firmware) | $600–$900 | $1,500-$3,000 |
| Head swap (standard HDD) | $1,200–$1,500 | $2,500-$4,000+ |
| Head swap (helium drive) | $3,000–$4,500 + helium | $4,000-$7,000+ |
| Logical recovery (deleted files) | $100-$250 | $700-$1,500 |
| SSD data recovery (SATA) | $200–$1,500 | $1,000-$5,000 |
| NVMe SSD data recovery | $200–$1,500 | $1,000-$5,000 |
| iPhone data recovery | $300-$650 | $3,000-$4,000 typical |
| MacBook logic board repair | $200-$600 | $750-$1,600+ (board swap) |
| Evaluation fee | Free | Free (device not opened) |
| Marketing overhead in your bill | $0 | Built into price |
Note on iPhone pricing: Multiple documented cases show DriveSavers quoting $2,800-$3,500 for iPhones with simple hardware problems (bad screens, charge ports) that were not data recovery issues at all. Their free evaluation does not involve opening the device. See our full analysis with evidence.
Louis Rossmann and Jessa Jones of iPad Rehab discuss documented cases of DriveSavers charging $2,700+ for basic iPhone repairs like screen replacements.
Why the difference? We don't bankroll PPC ads, affiliate kickbacks, or vanity certificates. Your invoice reflects engineering time, donor parts, and imaging hours; not marketing overhead. Read our analysis →
Data Recovery Pricing FAQ
Do you charge if you can't recover my data?
Is there a diagnostic fee?
Do I need a clean room for hard drive recovery?
How long does data recovery take?
Why is DriveSavers iPhone recovery so expensive?
Popular Service Areas
Get a Free Data Recovery Estimate
Tell us about your drive and we'll provide a free diagnostic and firm quote. Mail-in service available from all 50 states.
