We have a multitude of parts available, so that we can repair your machine in most cases without time consuming parts orders. We have an exhaustive inventory of anything & everything that is likely to break as a result of liquid damage on a Macbook – from chipsets to batteries to screens, wiring, and more,
On the 2010-2017 model Macbook Airs, liquid on the DC-in board on the inside of the machine will typically result in
This is because three fundamental circuits are located on the DC in board. The onewire circuit that allows the Macbook Air to communicate with the charger, the hall sensor that detects the magnet in the display that alerts the SMC that it is closed, and the audio circuit.
The trackpad is not just a trackpad! On Macbook Airs, the trackpad
If the light on your charger is orange, then resets to green when you hit power – your trackpad cable is likely corroded, or your trackpad is malfunctioning and registering power button presses as SMC resets. The SMC is what speaks to the charger: once reset, the light on the charger will change. The machine may also run slow with the fans on full speed if the trackpad temperature sensor malfunctions.
Many have learned from us via free YouTube content, guides, and personal instruction. Check out an example of how we repair devices below.
