Data recovery prices range from $100–$2,000 depending on the type of failure. This guide explains exactly what you will pay and why, with transparent pricing from a lab that does not hide behind "contact us for quote" tactics.
Hard drive recovery cost, hard disk recovery cost, and hard drive recovery service cost all describe the same 5-tier pricing scale below; only the terminology differs. Hard drive repair price is a narrower subset covering PCB or ROM-level board work on drives that still have healthy heads and undamaged platters.
Hard drive data recovery costs $100–$2,000 across 5 published tiers: $100 for a simple copy, From $250 for file system recovery, $600–$900 for firmware repair on PC-3000, $1,200–$1,500 for a donor-matched head stack swap, and $2,000 for platter surface damage. Helium-sealed enterprise drives (Exos, Ultrastar, MG08) run $200–$5,000+ with helium refill billed separately on opened-chamber tiers. Evaluation is free, there is no diagnostic fee, and a failed recovery costs nothing under the No Data, No Charge policy.
Hard drive recovery price by failure tier
The hard drive recovery price at our Austin lab is set by what failed, not by drive capacity or manufacturer. Five published tiers cover every recoverable mechanical or firmware failure: $100, From $250, $600–$900, $1,200–$1,500, and $2,000. There is no diagnostic fee gating the evaluation.
Hard drive data recovery prices, same scale as hard disk pricing
Our hard drive data recovery prices and our hard disk data recovery cost are one and the same 5-tier scale; the terms are interchangeable because a hard disk drive is a hard drive. Searchers asking how much does data recovery cost for a mechanical drive land on the same published tiers above. Helium-sealed enterprise drives are tracked separately at $200–$5,000+ with helium refill billed on opened-chamber tiers.
Data Recovery Cost: Quick Answer
- Logical Recovery: $100 simple copy or From $250 file system recovery (deleted files, formatted drive, partition issues)
- Firmware Issues: $600–$900 (drive not detected, wrong capacity, translator errors)
- Head Swap: $1,200–$1,500 (clicking, beeping, donor parts required)
- RAID/Complex: quoted after evaluation (RAID arrays, multi-drive systems)
These are Rossmann Repair Group prices, published before you ship. Large corporate labs (DriveSavers, Ontrack) quote the same work only after the drive arrives.
Hard drive data recovery costs $100–$2,000 depending on the failure type. A data copy from a functioning drive costs $100. File system recovery starts at From $250. Firmware repair using PC-3000 costs $600–$900. A head swap requiring matched donor parts costs $1,200–$1,500. Platter surface damage recovery starts at $2,000. Diagnostic evaluation is free. If the data is not recoverable, there is no charge.
Which Hard Drive Recovery Cost Tier Does My Drive Fall Into?
Hard drive recovery cost runs $100–$2,000, starting at $100 for a working drive, and the tier is set by the symptom you can observe, not by the drive's capacity. Match what your drive is doing to the price in the table below. Evaluation carries no diagnostic fee, and a failed recovery costs nothing under No Data, No Charge.
The ladder below maps what the drive is doing right now, your own observation before you ship it, to the published price for that failure class. Find the row that matches your symptom and read the cost straight across. All work is performed in-house at our Austin, TX lab.
| What your drive is doing | Recovery tier | Cost | Deposit |
| Your drive works, you just need the data moved off it | Simple Copy | $100 | No deposit |
| Your drive isn't recognized by your computer, but it's not making unusual sounds | File System Recovery | From $250 | No deposit |
| Your drive is completely inaccessible. It may be detected but shows the wrong size or won't respond | Firmware Repair | $600–$900 | No deposit |
| Your drive is clicking, beeping, or won't spin. The internal read/write heads have failed | Head Swap | $1,200–$1,500 | 50% deposit |
| Your drive was dropped, has visible damage, or a head crash scraped the platters | Surface / Platter Damage | $2,000 | 50% deposit |
Rush is optional: +$100 rush fee to move to the front of the queue. Helium-sealed enterprise drives (Exos, Ultrastar, MG08) run on a separate list, $200–$5,000+, with the refill performed in-house after the sealed chamber is opened. Once you have spotted your row, the full in-house hard drive recovery walkthrough covers what happens on the bench after the drive lands in Austin.
How Do Data Recovery Costs Compare Between Labs?
Rossmann publishes five fixed hard drive tiers before you ship: $100, From $250, $600–$900, $1,200–$1,500, and $2,000. Large corporate labs quote a broad range up front and bill at or near the ceiling. Labs that require a call for a quote control the information asymmetry.
| Provider | Price Range | Pricing Model | No Data, No Fee |
| Rossmann Group | $100 simple copy or From $250 file system recovery $600–$900 (Firmware) $1,200–$1,500 (Head Swap) | Published tiers, firm quote after free evaluation | Yes |
| National Lab Unpublished pricing | Not published | Call for quote | Varies |
| Corporate Lab Unpublished pricing | Not published | Call for quote | Varies |
National and corporate labs do not publish flat rates; quotes are issued case by case after the drive arrives.
Wide-Range Quotes vs. Flat-Rate Tiers
Large corporate labs quote a broad range up front, then bill at or near the ceiling once the work is done. By the time the final invoice arrives, you have already shipped your drive, waited weeks, and have no realistic alternative. The incentive structure rewards quoting high and delivering a number that matches.
We publish our rates on this page before you ship anything. After a free hands-on evaluation, you get a firm number locked to the specific failure type. If the quote does not work for you, we return your drive for a flat return shipping fee. For a full breakdown of how large-lab pricing operates, read our DriveSavers pricing analysis.
What Does Data Recovery Cost by Failure Type?
Hard drive data recovery cost is set by what broke. Logical issues (deleted files, corrupted partitions) run $100 to From $250. Firmware repair using PC-3000 costs $600–$900. A head swap with donor parts costs $1,200–$1,500. Platter surface damage starts at $2,000.
The cost of data recovery depends primarily on what is wrong with your drive. A simple file deletion is cheap to fix; a mechanical head crash requires expensive donor parts and hours of clean bench work. If you are unsure whether your drive needs repair or recovery, that distinction affects pricing.
- Logical Recovery
Call for quote
Software imaging and file system repair. Drive reads normally. $100 simple copy or From $250 file system recovery
Call for quote
Partition table repair, MBR/GPT rebuild, RAW file system recovery.$600–$900
Unpublished
ROM transfer, translator repair, Service Area patching via PC-3000.From $250 to $600–$900
Unpublished
TVS diode replacement, ROM chip transfer, motor driver repair.$1,200–$1,500
Quote after shipping
Clean bench head transplant from donor drive, careful imaging.$1,200–$1,500
Head unstick procedure, often followed by head swap.$200–$1,500
Unpublished
5 tiers: simple copy, file system, PCB repair, firmware, advanced board rebuild.Quoted after evaluation
Unpublished
Multiple drive imaging, array reconstruction, per-member recovery.- Evaluation Fee
FREE
Varies; verify first
We diagnose and quote for free. Some shops charge a diagnostic fee before quoting.
Hard Drive Recovery Cost by Failure Tier
Hard drive recovery cost is set by what broke, not by brand, capacity, or how full the drive is. Rebuilding a translator module in PC-3000 takes the same reverse-engineering work on a 500GB drive as on an 8TB one, so the tiers below are priced by the failure class the drive falls into at intake. Every number is pulled from the same published hard drive recovery price list the lab works off.
| Failure Tier | Hard Drive Recovery Cost | What the Tier Covers | Typical ETA |
| Simple Copy | $100 | Functional drive; data transfer to new media | 3-5 business days |
| File System Recovery | From $250 | File system corruption. Accessible with professional recovery software but not by the OS | 2-4 weeks |
| Firmware Repair | $600–$900 | Firmware corruption: ROM, modules, or translator tables corrupted; requires PC-3000 terminal access | 3-6 weeks |
| Head Swap | $1,200–$1,500 | Head stack assembly failure. Transplanting heads from a matching donor drive on a clean bench | 4-8 weeks |
| Surface / Platter Damage | $2,000 | Platter scoring or contamination. Requires platter cleaning and head swap | 4-8 weeks |
- CMR vs SMR pricing:
- SMR (Shingled Magnetic Recording) drives require more work at the firmware and head-swap tiers due to their overlapping track architecture.
- Donor drive cost:
- Rush option:
- +$100 rush fee to move to the front of the queue.
- Large-capacity drives:
- For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra.
Hard Drive Data Recovery Cost at a Glance
Hard drive data recovery cost at Rossmann Repair Group runs $100–$2,000 across 5 published failure tiers. Simple copy off a working drive is $100. File system recovery on a drive that spins fine but is not recognized starts at From $250. Firmware repair using PC-3000 terminal access is $600–$900. A head swap with donor parts on a clean bench is $1,200–$1,500. Platter surface damage with combined head swap and platter cleaning starts at $2,000.
The same numbers apply whether the search phrase is hard drive data recovery cost, hard disk recovery cost, or hard drive recovery price. Every tier above is the published rate the lab works off for in-house hard drive data recovery in Austin, TX. There is no diagnostic fee and no recovery fee if data cannot be returned.
Three things move the final hard drive data recovery cost inside a given tier: donor drive availability, capacity, and rush. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Capacity surcharge: For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra. Rush option: +$100 rush fee to move to the front of the queue. Sealed helium drives (Exos, Ultrastar, MG08) are quoted from a separate helium price list because the recovery procedure requires a helium refill step.
If the quoted hard drive data recovery cost feels high relative to other services, this breakdown of where the money goes explains the equipment, donor inventory, and clean bench time priced into each tier.
What Does Data Recovery Cost by Device Type?
Hard drive recovery runs $100–$2,000 across the 5 tiers above. SATA SSD recovery runs $200–$1,500. NVMe SSD recovery runs $200–$2,500. iPhone board-level recovery is a flat $500 for pre-X models and a flat $750 for iPhone X and newer. RAID array recovery is quoted after evaluation based on member count and failure type.
All prices below are published Rossmann Repair Group rates.
SATA SSD Data Recovery Cost
iPhone Data Recovery Cost
RAID & NAS Recovery Cost
See also: NAS recovery details
USB & Flash Media Recovery Cost
Helium Hard Drive Recovery Cost
Sealed helium drives (Seagate Exos, WD Ultrastar HC, Toshiba MG08) cost more to recover than standard air-breather HDDs. Opening the sealed chamber requires a controlled environment, and head swaps need helium refill (+ helium cost ($400-$800) + donor drive + tax + target drive). The donor drive must match the exact model, firmware revision, and head map. These enterprise drives use higher platter counts and tighter tolerances, making mechanical recovery more labor-intensive than a standard 2- or 3-platter consumer drive.
From $600
Helium drive firmware recovery is more complex due to sealed chamber architecture
Your helium drive is clicking, beeping, or won't spin. The internal read/write heads have failed
50% deposit required (usually $1,100 non-refundable deposit). Helium cost ($400-$800) and donor drive cost additional.
$3,000–$4,500
$4,000–$5,000
- Helium cost
- Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
- Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
- The destination drive we copy recovered data onto. You can supply your own or we provide one at cost plus a small markup. For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra. All prices are plus applicable tax.
NVMe SSD Recovery Cost
NVMe SSDs use a different bus protocol and controller architecture than SATA SSDs. Recovery requires PC-3000 SSD with NVMe-specific adapters. NVMe controllers (Phison E12, E18; Samsung Elpis; WD/SanDisk in-house) implement AES hardware encryption bound to the controller silicon, so chip-off NAND extraction yields ciphertext that cannot be decrypted without the original controller. Recovery focuses on coaxing the original controller back into a readable state via firmware repair, not desoldering the NAND.
- The destination drive we copy recovered data onto. You can supply your own or we provide one at cost plus a small markup. All prices are plus applicable tax.
USB Flash Drive and SD Card Recovery Cost
Flash media recovery ranges from simple file system repair to full chip-off NAND extraction. Monolithic flash drives (where the controller and NAND are fused into a single package) require direct pin-out identification and raw data reconstruction. Standard USB flash drives with discrete NAND chips are less expensive to recover than monolithic devices.
$300–$600
PCB Repair
Chip-off Data Recovery
Controller-Specific Firmware Failures and Recovery Prices
The $600–$900 firmware recovery price applies across SSD controller families because the engineering labor is similar: connect the drive to PC-3000 in technological mode, bypass the corrupted boot sequence, and reconstruct the Flash Translation Layer from surviving NAND page data. The specific controller determines which mode and command set the technician uses, not the price tier.
- Silicon Motion SM2259 and SM2258
- These controllers enter a context-table checksum failure when firmware panics during a write operation or when NAND degradation corrupts the boot area. The drive appears in Disk Management showing exactly 0 bytes of capacity. Consumer SSD recovery software requires a valid block device capacity to scan and will not detect the drive. PC-3000 SSD uses Vendor Specific Commands to bypass the stalled boot sequence, read surviving NAND pages directly, and rebuild the FTL mapping tables. Price: $600–$900.
- Phison PS3111-S11
- When this controller loses access to the FTL after an unclean shutdown or excessive NAND wear, the drive resets its identity string to "SATAFIRM S11" in BIOS. The drive appears to be a different device entirely. Recovery requires connecting via PC-3000, entering Phison Technological Mode, and rebuilding the translator from the NAND directly. Price: $600–$900.
- Phison PS5012-E12
- When this PCIe NVMe controller suffers a firmware panic from sudden power loss or NAND wear, it drops off the PCIe bus entirely or reports 0 bytes. Unlike the SATA S11 lockout, there is no altered identity string; the drive simply disappears from BIOS or appears as an unallocated volume. Recovery requires PC-3000 Portable III to force the controller into diagnostic mode and rebuild the FTL mapping tables from surviving NAND data. Price: $900–$1,200.
Both failure types fall under the drive not detected symptom category. If your SSD shows 0 bytes, displays "SATAFIRM S11," or is invisible to the operating system, the firmware recovery price tier applies.
What Does Laptop Data Recovery Cost?
Laptop data recovery costs depend on the drive type, not the laptop brand. Older laptops with 2.5-inch mechanical drives follow HDD pricing: $100 for a data copy, $600–$900 for firmware repair, and $1,200–$1,500 for a head swap. Modern laptops with NVMe SSDs follow SSD pricing: $200–$2,500.
Laptop recovery cost depends on the drive inside the machine, not the laptop brand. Older laptops (pre-2018) typically contain 2.5-inch mechanical drives. These follow standard HDD pricing: $100 for a data copy, $600–$900 for firmware repair, and $1,200–$1,500 for a head swap. Dropped laptops frequently cause stiction in 2.5-inch drives (heads stuck to platters), which falls in the $1,200–$1,500 tier.
Modern laptops (2019+) use soldered NVMe SSDs. Recovery follows SSD pricing: $200–$2,500.
One critical difference: recovering deleted files from a modern laptop SSD is typically impossible. Operating systems issue TRIM commands on file deletion, instructing the SSD controller to discard the data blocks. Software recovery tools cannot retrieve data the controller has already discarded. If the SSD has a controller or firmware failure (not a deletion), recovery through laptop drive recovery follows standard SSD pricing tiers.
What Does Seagate Hard Drive Recovery Cost?
Seagate hard drive data recovery costs $100 for a data copy, $600–$900 for firmware corruption requiring PC-3000 terminal access, and $1,200–$1,500 for a head swap on clicking drives. The price is set by the failure mechanism, not by capacity or Seagate model number.
Seagate drive recovery is priced by the failure mechanism, not by capacity or model number. A functioning Seagate Barracuda needing a data copy costs $100. Firmware corruption costs $600–$900 and requires PC-3000 terminal access to repair translator modules or Service Area data. The Seagate Rosewood family (ST1000LM035, ST2000LM007) is one of the most common drives we see for head swaps at $1,200–$1,500; these 2.5-inch slim drives have lower motor torque, making them prone to stiction after drops.
Some competitors price Seagate recovery by capacity (e.g., flat rates for "up to 2TB" or "over 12TB"). That pricing model ignores the actual work involved. A 1TB Seagate with firmware corruption requiring PC-3000 module reconstruction costs $600–$900 regardless of how much data is on the platters. A 4TB Seagate with a simple deletion costs $100. The failure determines the price; the label on the drive does not.
What Does External Hard Drive Recovery Cost?
External hard drive recovery costs the same as internal drive recovery, $100–$2,000, because the price is set by the internal mechanism's failure, not the plastic enclosure. A simple copy is $100; firmware corruption is $600–$900; a head swap on a clicking drive is $1,200–$1,500. A USB bridge board that died on its own is a separate, lower-cost board repair, not a recovery.
We remove the 2.5-inch internal mechanism from its USB shell and connect it directly; the enclosure brand does not change the failure tier. A Seagate Backup Plus, Seagate Expansion, or Toshiba Canvio is an ordinary hard drive mechanism sitting inside a USB enclosure with a removable bridge board, so it follows the same hard drive recovery tiers.
A simple data copy is $100; firmware corruption is $600–$900; a head swap on a clicking drive is $1,200–$1,500.
The same logic drives our external hard drive recovery service: price the mechanism, not the box around it.
One genuine external-specific wrinkle shows up on modern WD portables like the My Passport. These are native-USB drives: the USB controller is built onto the drive's own circuit board rather than a removable bridge, and WD's hardware encryption is keyed by a wrapped Data Encryption Key stored in the drive's Service Area, which the PC-3000 WD utility reads from the platters.
A physically broken USB port is a board-level repair, not a data loss event, because the key material lives on the drive, not in the port.
The one true dead end is a user-set WD Security password, which we do not promise to defeat. Running chkdsk or Windows "Scan and Fix" on an external drive that keeps dropping offline can overwrite the file table and turn a $600–$900 firmware or bad-sector recovery into a harder logical case; bad sectors are a physical failure of the heads or media, never a logical one.
Enclosure Electronics: Shell Removal, Bridge Repair & Key Recovery
Getting the mechanism out of the shell costs nothing. A clipped or screwed plastic case comes apart in bench minutes, & the drive inside then sits on the same bench as any internal drive, so an external simple copy is still $100 & an external head swap is still $1,200–$1,500 plus a donor billed at cost.
One enclosure design does move the price. When the USB controller is built onto the drive's own circuit board, there is no SATA connector left to fall back to once that port or controller dies, so the job stops being a direct connect & becomes firmware-level work at the $600–$900 tier: the drive's own adaptive ROM data is carried onto a compatible SATA donor board before the platters read.
Dead enclosure electronics with the key material intact stays a priced, recoverable job at that same $600–$900 firmware tier. WD writes the wrapped Data Encryption Key redundantly into the Service Area, so we read it out over vendor-specific commands on the PC-3000 & decrypt the sector image in software. There is no separate decryption fee bolted onto that tier.
A lost user-set WD Security password is the opposite outcome, & no tier applies to it. That password gates the key that unwraps the DEK, so without it the image stays ciphertext no matter how healthy the mechanism is; it is a cryptographic dead end rather than a bench problem we can put a number on. You pay nothing on a job that ends there, under the same No Data, No Charge policy that covers every other tier.
Bridge repair is the cheapest external outcome we quote. On an enclosure that passes the drive through unencrypted, a healthy mechanism behind dead enclosure electronics is a board-level repair on the bridge plus a data copy at the $100 tier, not a recovery tier.
That cheap path stops at WD's encrypting enclosures. Most modern My Book desktop units run hardware AES at the bridge even when the customer never set a password, so pulling the bare SATA drive & imaging it directly yields ciphertext. The key material has to be recovered before any image is readable, which puts the identical dead bridge back on the $600–$900 firmware tier instead of a board job.
| External-specific condition | What gets charged |
| Opening a clipped or screwed plastic shell to reach the mechanism | No line item; billed at the mechanism's own failure tier |
| Dead enclosure electronics, unencrypted pass-through, healthy mechanism | Bridge board repair plus a $100 copy |
| USB controller built onto the drive's own board, no SATA fallback | $600–$900 firmware tier, ROM & adaptives migrated to a donor board |
| Dead bridge on a WD enclosure that encrypts at the bridge | $600–$900 firmware tier, key recovery & software decryption included |
| Clicking mechanism inside an external enclosure | $1,200–$1,500 plus a donor billed at cost |
| Lost user-set WD Security password | No tier applies; No Data, No Charge |
Every row above is quoted after a free evaluation on our Austin bench, with no diagnostic fee & nothing owed if the data does not come back. Rush is optional: +$100 rush fee to move to the front of the queue.
What Determines Data Recovery Cost?
Four factors determine the final price: the type of failure, donor parts required, drive capacity, and the lab's overhead structure. Logical issues cost $100 to From $250. Firmware repairs cost $600–$900. Mechanical head swaps requiring exact-match donor drives cost $1,200–$1,500. Labs with marketing overhead charge 2 to 3x more for identical work.
- Type of Failure
- The single biggest factor. Logical issues cost $100 for a simple copy or From $250 for file system corruption. Firmware corruption requiring PC-3000 terminal access costs $600–$900. Mechanical failures requiring donor heads and clean bench work cost $1,200–$1,500. Each tier reflects the complexity, parts, and time required.
- Donor Parts
- Head swaps require exact-match donor drives. The donor must share the same model number, firmware revision, and head configuration. Rare or newer models cost more because the donor parts cost more to source. Rossmann maintains a donor inventory to reduce delays and parts costs.
- Drive Capacity
- Larger drives take longer to image. A 500GB drive might image in hours; an 8TB drive can take days. Imaging time affects labor cost. High-capacity drives (8TB+) also require a larger target drive (~$400+).
- Severity of Damage
- A clicking drive caught early has better odds than one that was powered on repeatedly or opened at home. More damage means more donor attempts, longer imaging passes, and higher cost. A head crash that scores the platters pushes the case into the $2,000 tier.
- Urgency
- Simple copies take 3–5 business days. Firmware and complex tiers take 2–8 weeks depending on failure type and donor availability. Rush service is available on any tier: +$100 rush fee to move to the front of the queue.
- Lab Overhead
- Corporate labs spend on marketing, referral commissions, and walk-in cleanroom facilities. These costs are built into every customer's invoice. Rossmann operates without marketing overhead or referral programs. You pay for engineering work, not advertising budgets.
Why Do Large Data Recovery Labs Cost More?
A $1,200–$1,500 head swap at Rossmann is the same procedure that referral-driven labs quote with a commission to the local shop and marketing overhead baked in. Most people assume the shop accepting their drive is recovering the data. Often it is not. The shop ships your drive to a national lab and collects a percentage of whatever you pay.
Rossmann runs no partner program. There is no middleman cut in your bill.
How the Referral Chain Works
- 1You bring your clicking hard drive to a local repair shop.
- 2The shop accepts it. They tell you they'll "send it to the lab."
- 3Your drive ships to a national data recovery lab: DriveSavers, Ontrack, SalvageData, Gillware, or similar.
- 4The lab performs the recovery and sets the price after the drive arrives.
- 5The referring shop collects a commission on whatever you pay.
- 6You pay the full amount. The shop's contribution was mailing a package.
These are real businesses with real storefronts and real employees. They are not scam operations. They do not do data recovery. The local shop uses language like "our lab" or "our partners," and there is no standard requirement to disclose that your drive is shipping to a third party or that a referral fee is included in your bill.
These Referral Programs Are Public
The labs themselves advertise these programs in their own marketing materials, pitched directly at repair shops looking for additional revenue:
- National labs run "Reseller Referral Partner Programs" with thousands of business partners. Their pitch to shops: "earn passive income" with "no equipment needed" and no signup fees. Each partner gets a unique Partner ID to track referrals and earns commission on every successful recovery with no monthly cap.
- Corporate labs offer Partner Programs that pay commission on successful recoveries, scaling with volume. Partners receive custom ID-coded brochures and co-branded marketing materials designed to create the impression the customer is getting a "special discount" through the local shop.
- Other competitors run "Authorised Partner Programs" that pay a percentage of total fees from signed customer agreements. Partners receive training materials and "Authorised Partner status" branding.
- Legacy labs claim to be "approved and preferred by 5,000+ providers" and offer discounted reseller rates or direct referral commissions.
Best Buy and Geek Squad: The Model Everyone Recognizes
Geek Squad is the most visible version of this outsourcing model. They handle simple logical recoveries (deleted files, basic corruption) in-store. Firmware failures and mechanical problems get shipped to "Geek Squad City" or outsourced to partners. Ontrack has historically served as their exclusive recovery provider for complex cases.
Big-box retail Level 3 data recovery pricing typically starts around $1,450 in labor plus diagnostic fees. The destination drive for your recovered data is often not included. Compare that to our head swap published head swap tier of $1,200–$1,500, which covers the full recovery.
The difference: we own the lab, the equipment, and the process. There is no middleman. The technician who diagnoses your drive is the one who performs the recovery.
Hidden Fees That Inflate the Bill
Beyond referral commissions, some labs build in fees that guarantee revenue even when the recovery fails or you change your mind. Documented examples of bait-and-switch pricing in data recovery show discounts of 30-90% after customers decline initial quotes.
- ✕National labs: Cancellation fee of $200 or 20% of the quoted price, whichever is greater, if you cancel after approving a quote.
- ✕Various labs: Non-refundable "attempt fees" or "parts deposits" on difficult cases. Revenue is guaranteed even when the recovery fails.
- ✕Big-box retailers: Diagnostic fees charged before any work begins.
What Rossmann Charges
- ✓Evaluation fee: $0. We diagnose your drive and provide a firm quote at no cost.
- ✓Diagnostic fee: $0. Included in the free evaluation.
- ✓Cancellation fee: $0. Decline the quote, we return your drive.
- ✓Return shipping on failed recovery: $0 on qualifying jobs under our No Data, No Charge policy.
- ✓Referral commission baked into price: $0. We do not run a partner program. There is no middleman cut in your bill.
Virtual Offices Are a Separate Problem
The referral shops above are real businesses at real addresses. A different pattern: some data recovery companies list dozens of "locations" on Google Maps that are virtual offices, Regus suites, or UPS Store mailboxes. There is no lab, no staff, no equipment at the address. Your drive ships to a centralized facility elsewhere.
We investigated this pattern and documented which companies do it. In Austin, a Google Local Guide visited two listed data recovery addresses and found no lab at either location.
Cleanroom Overhead Added to Your Bill
National labs cite walk-in cleanrooms to justify higher quotes. For the vast majority of mechanical recoveries, a validated laminar-flow bench achieves the same contamination control at the drive surface, at a fraction of the facility overhead a walk-in room carries. The recovery outcome is the same.
Read our full analysis of cleanroom requirements vs. laminar-flow benches.
Why Does Professional Data Recovery Cost So Much?
A $1,200–$1,500 head swap covers a PC-3000 system, a 0.02 micron ULPA-filtered clean bench, exact-match donor inventory, and hours of multi-pass imaging on DeepSpar Disk Imager. A $600–$900 firmware repair pays for PC-3000 Service Area access and translator reconstruction. The price tracks the tools, parts, and engineering time each tier consumes.
Data recovery is not like replacing a phone screen. It requires specialized equipment, years of training, and significant time investment per case.
Equipment Costs
- PC-3000: professional firmware and imaging systems (Portable III, Express, or SSD)
- DeepSpar DDI: dedicated hardware imaging system
- Clean bench: ULPA filtration for open-drive work
- Microscopes: precision optics for head and board work
- Donor inventory: spare drives stocked across model families
- Software licenses: Annual fees for forensic tools
Time Investment
- Diagnosis: 30 minutes to 2 hours per drive
- Imaging: Hours to days depending on capacity and damage
- Mechanical work: 1-4 hours of clean bench time
- Recovery: Hours of file system analysis
- Verification: Checking recovered files open correctly
- Some cases span weeks with multiple recovery attempts
What Recovery Engineering Happens at Each Price Tier?
Each pricing tier reflects a different category of engineering work. Tier 1 ($100) is a hardware-level data copy using DeepSpar. Tier 2 (From $250) rebuilds corrupted file system metadata. Tier 3 ($600–$900) requires PC-3000 Service Area access. Tier 4 ($1,200–$1,500) is a clean bench head transplant with donor matching. Tier 5 ($2,000) adds platter cleaning before imaging.
- Tier 1: Simple Copy ($100)
The drive is functional but the owner can't access or transfer data normally. We connect it to a DeepSpar Disk Imager or PC-3000 Data Extractor, bypassing the operating system entirely. The hardware imager controls the SATA link directly, setting custom read timeouts at the millisecond level so a single bad sector doesn't stall the entire transfer.
Consumer software relies on the OS storage stack, which forces the drive into aggressive retry loops on failing sectors. Each retry drags degraded heads across the same magnetic tracks, generating debris & accelerating damage. The DeepSpar skips unstable sectors on the first pass, images all stable data, then returns to problem areas with progressively shorter timeout windows. A $100 copy using professional hardware is not the same operation as dragging files in Windows Explorer.
- Tier 2: File System Recovery (From $250)
The drive spins & is detected, but the partition table, MBR/GPT, or file system metadata is corrupted. This happens after accidental formatting, abrupt power loss during a write, or a failed OS update that damaged the volume header. The platters & heads are fine; the problem is in the logical structure that maps file names to physical sectors.
We image the drive first (protecting the original), then reconstruct the file system from the clone. For NTFS volumes, this means rebuilding the Master File Table. For HFS+/APFS, it means reconstructing the Catalog File or Object Map. For ext4, we parse the journal & inode tables.
The price starts at From $250 because the physical drive is healthy; the engineering work is in metadata reconstruction, not mechanical intervention.
- Tier 3: Firmware Repair ($600–$900)
The drive powers on, may spin normally, but is not detected by the BIOS or reports 0 bytes. The problem is in the drive's firmware: a hidden set of modules stored in a reserved area of the platters called the Service Area (SA). The SA contains the translator tables, defect lists, adaptive parameters, & ROM data the drive needs to function. When any of these corrupt, the drive becomes a brick.
Recovery requires PC-3000 Portable III or PC-3000 Express to force the drive into factory/technological mode, bypassing standard SATA communication. The technician reads the corrupted SA modules, identifies which ones failed, and patches or rebuilds them. Common repairs include clearing an overflowed defect reallocation list (Module 32 on Western Digital drives), rebuilding the translator table that maps logical addresses to physical sectors, and regenerating corrupted ROM data.
SMR drives cost more ($900) because they add a second translation layer, such as the Media Cache Management Table (MCMT) or T2 translator. When firmware corruption hits an SMR drive, the technician must reconstruct both the primary translator and the Media Cache mapping tables that manage the overlapping track geometry. CMR drives have a simpler translator structure and cost $600.
- Tier 4: Head Swap ($1,200–$1,500)
A clicking or beeping drive has failed read/write heads. The head stack assembly must be replaced with parts from a compatible donor drive, performed in a 0.02 micron ULPA-filtered clean bench. The high cost reflects donor sourcing, the precision of the transplant, & the imaging time afterward.
Donor matching is the bottleneck. A donor drive must share the same model, firmware revision, head count, & compatible preamplifier circuitry.
For Western Digital Marvell-architecture drives, the microjog values (radial alignment offsets between the read and write elements, stored in ROM) must fall within a narrow tolerance range. For Seagate, the firmware family & site code must align exactly. Incompatible donors crash within seconds of spin-up, destroying themselves & potentially the patient platters.
After transplant, the PC-3000 reads the original adaptive parameters from ROM & adjusts them for the donor head tolerances. The drive is then imaged immediately using DeepSpar or PC-3000 Data Extractor in multi-pass mode, prioritizing stable sectors before approaching any weak areas. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
- Tier 5: Platter Surface Damage ($2,000)
A head crash physically gouges the ferromagnetic coating off the platter surface, generating microscopic debris. This debris embeds into undamaged tracks & acts as an abrasive that destroys any newly installed donor heads within minutes. Recovery at this tier combines platter cleaning, head swap, & targeted multi-pass imaging.
Before installing donor heads, the platters are inspected under magnification & cleaned to remove loose particulate. If the drive arrived with stiction (heads seized to the platter surface), model-specific head combs separate the sliders without shearing the mechanisms or scratching additional media.
On multi-platter drives where one surface is deeply scored, the technician physically removes the corresponding head from the donor stack and uses the PC-3000 to electronically disable it in RAM. This lets the remaining platter surfaces be imaged without the donor stack crashing into the scored zone.
The Data Extractor builds a media scan map, skips the physically damaged LBA ranges on the first pass, then returns with reverse imaging & modified timeout parameters to extract residual data from the periphery of the scratch rings.
Does a Failed Circuit Board Cost the Same as a Head Swap?
No. A failed circuit board with intact heads & platters routes to the $600–$900 board-repair and ROM-transplant tier, while a clicking drive that needs a clean-bench head swap routes to the $1,200–$1,500 tier. The free evaluation tells the two apart before any quote, and a board-only fault never gets clean-bench head work.
The free evaluation routes the quote before the lid ever comes off. A board fault & a head fault look identical from the outside (a drive that simply won't mount), but they read as two different faults on the bench. We watch current draw on a lab supply, sweep a FLIR thermal camera across the printed circuit board to find any component pulling current it shouldn't, and listen to spin-up against click acoustics. A shorted board usually shows a dead short on a power rail & a component heating under the FLIR lens; a failed head shows normal current draw with a clicking actuator that never settles into a read.
A drive that took a power surge often shows a shorted transient-voltage-suppression diode. That diode is a protective crowbar: it is designed to fail as a dead short and clamp the rail to ground so the surge never reaches the motor-controller IC behind it. If instead the diode fails open, the surge passes straight through & can take out the voltage regulator it was meant to guard. Either way, the heads & platters are usually untouched, which is what moves the case onto the electronics path rather than the mechanical one.
Dropping a bare donor board onto the drive almost never works, & that is the single most common way a DIY board swap finishes off a recoverable drive. The original board carries a small serial-flash ROM holding adaptive data unique to your drive, the calibration the heads & preamp were tuned to at the factory. A donor board runs its own, wrong, adaptives. A real board repair migrates that ROM and adaptive content onto the matched donor board on the PC-3000 Portable III, or replaces the shorted protective component on your original board so the rest of the electronics power back up. We describe these by function because the exact part changes from model to model, & guessing a part number off a forum is how a recoverable board becomes an unrecoverable one.
Here is where each one lands on the published scale. A board repair with a ROM and adaptive transplant sits at the $600–$900 firmware-repair tier, because the work is electronic & firmware-level rather than mechanical. A clean-bench head transplant sits at the $1,200–$1,500 head-swap tier, since it consumes a matched donor head stack inside the 0.02 micron ULPA-filtered clean bench. A board whose data was never at risk, where the platters & heads are healthy and the electronics just need the drive talking again, can drop to the $100 simple-copy tier once it images cleanly. The principle holds across the whole scale: the further a failure pushes us toward consumable donor parts & clean-bench mechanical work, the higher the tier, and a pure electronics fault stays at the low end.
Every one of these starts with the same free evaluation, carries no diagnostic fee, and runs under No Data, No Charge, all in-house at our Austin, TX lab. See how the board path and the mechanical path fit into the full failure-tier breakdown on the hard drive data recovery overview.
What Drives the Cost Difference Between Recovery Tiers?
The tier itself is set by two drivers: where the labor happens (PC-3000 terminal time versus open-chamber clean-bench occupancy versus a board-repair bench) and whether a consumable donor is harvested. Two more factors move the timeline but not the price: how long a donor takes to source and how many imaging hours the capacity adds. A firmware repair stays at $600–$900 because it spends terminal time and burns no parts; a head swap reaches $1,200–$1,500 because it consumes a matched donor stack.
| Failure Tier | Hard Drive Recovery Cost | Where the Labor Happens | Donor Parts + Sourcing | Clean-Bench Time |
| Simple copy | $100 | Host imaging bench. DeepSpar Disk Imager streams a working drive to fresh media. | None. No part is harvested. | None. The sealed chamber is never opened. |
| File system recovery | From $250 | Host imaging bench, then metadata reconstruction off the clone in PC-3000 Data Extractor. | None. The platters and heads read normally. | None. Work runs on the image, not inside the drive. |
| Firmware repair | $600–$900 | PC-3000 Portable III terminal. Service Area module and translator repair over the diagnostic port. | None for a pure firmware fault. Terminal time, not parts. | None. The lid stays on; the repair is electronic. |
| Head swap | $1,200–$1,500 | 0.02 micron ULPA-filtered clean bench. Head-stack transplant, then selective imaging. | Matched donor head stack consumed. Days to weeks to source a firmware-and-head-map match. | Hours of open-chamber bench time per swap, plus imaging. |
| Surface / platter damage | $2,000 | Clean bench. Platter cleaning, head swap, and reverse multi-pass imaging. | Multiple donor head sets often consumed reading scored platters. | Longest open-chamber occupancy of any tier. |
The table reads the same top to bottom: the further a failure pushes toward consumable donor parts & open-chamber clean-bench work, the higher the tier. A pure firmware or terminal fault stays low because it spends terminal time, not parts or bench-open hours, & capacity only moves imaging hours inside a tier, never the tier itself. See how these drivers sit inside the full failure-tier breakdown on the hard drive data recovery overview, or read what actually gets repaired over the diagnostic port in how hard drive firmware works.
No Data, No Charge Guarantee
At Rossmann Repair Group, if we cannot recover your files, you pay nothing for the recovery attempt. Evaluation is always free. You only pay return shipping if you want the original drive back. This no data, no charge policy applies to all cases, regardless of complexity, including head swaps and firmware repairs.
Learn more about our guarantee →How the 50% Donor Deposit Works
Two failure tiers take a 50% deposit before bench work starts: a head swap ($1,200–$1,500) and platter surface damage ($2,000). Both consume donor parts that are physically destroyed during the repair and cannot be returned or resold. The deposit is half of the quoted tier price you already agreed to, not an extra line item on top of it.
A head swap pulls the read/write head stack out of a matched donor drive and transplants it into your drive in a 0.02 micron ULPA-filtered clean bench. Once those heads are harvested, the donor is scrap. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The same logic applies to a platter surface damage recovery at $2,000, where several sets of donor heads are often consumed reading scored platters after the surfaces are cleaned in the ULPA bench.
That is why these two tiers collect 50% up front while the $100 simple copy and $600–$900 firmware repair tiers do not. A simple copy reads a working drive. A firmware repair patches the Service Area through PC-3000 Portable III without opening the drive or burning a donor. No consumable part leaves inventory, so no deposit is needed against parts the lab can never recover.
The deposit does not weaken the No Data, No Charge guarantee. The recovery fee stays contingent on results: if we open your drive, swap the heads, and still cannot pull your files, you pay nothing for the attempt and we return the device at no cost.
The deposit exists because donor parts are physically consumed to even attempt the repair, not as a charge against a failed outcome. Read the exact terms on the No Data, No Charge guarantee page, and see how the deposit sits inside the published hard drive recovery tiers above.
What Is the Total Out-of-Pocket Cost Beyond the Recovery Tier?
The recovery fee, the published tier matched to your failure, is the bulk of the bill, and it is the only line item the No Data, No Charge guarantee makes contingent on success. A few non-contingent ancillary costs can sit on top depending on the case: a target drive, donor parts on the mechanical tiers, optional rush, tax, and return shipping if you want the original mailed back.
The recovery fee is whatever tier your drive falls into: $100 for a simple copy, From $250 for file system work, $600–$900 for a Service Area firmware repair, $1,200–$1,500 for a head swap, or $2,000 for platter surface damage. That single number is the only part of the invoice the outcome-based guarantee zeroes out if we cannot pull your files.
The other lines below are never charged against a failed attempt either; each one applies only on a job that succeeds and that you accept.
Recovered data has to land somewhere, so a target drive is its own line item separate from the recovery fee. A standard target drive is a small add-on, but capacity drives the cost. For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra. You can also supply your own blank drive and skip this charge entirely.
Donor parts are billed at cost, and only on the two mechanical tiers: the $1,200–$1,500 head swap and the $2,000 surface damage recovery. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The $100 copy, From $250 file system, and $600–$900 firmware tiers consume no donor at all, because none of them open the drive or harvest a head stack, so no parts cost ever attaches to them.
Rush is optional. +$100 rush fee to move to the front of the queue, so an urgent case adds the flat $100 on top of the tier price. Sales tax applies to the total as it does on any Austin invoice, and return shipping is a real cost only if you ask us to mail the original drive back after the recovery; declining the quote outright still costs nothing toward the recovery itself.
There is no separate diagnostic, attempt, or evaluation fee anywhere in this list.
Helium-sealed enterprise drives run on a separate price list at $200–$5,000+ because opening the sealed chamber adds an in-house helium refill on top of the donor and head work; that work is performed at our Austin bench and never outsourced. The split between a fee that the guarantee can refund by outcome and ancillaries that are real costs on a successful, accepted job is the same across both lists; see how each fee sits inside the five published recovery tiers.
Does a Prior Failed Recovery Attempt Cost More?
Sometimes, yes. A prior attempt can push a drive into a higher published tier, because the tier is set by failure type & a failed attempt can change the failure type itself. Recovery software, a donor-board swap, or opening the drive outside a clean bench can turn a $600–$900 firmware case into a $1,200–$1,500 head swap or a $2,000 surface-damage job.
The published tier is set by what failed, not by how the drive arrived. A working-drive copy is $100, file system work From $250, firmware repair $600–$900, a donor-matched head swap $1,200–$1,500, & platter surface damage $2,000. A prior attempt can move a case up that ladder when it changes the failure type underneath. We never bill you for an attempt that failed somewhere else; we quote the state the drive is in when it lands on our Austin bench.
Recovery software run on a degrading drive is the most common escalator. A drive with reallocated or pending sectors, or one that reads unstably, is a physical failure: the media surface or the read/write heads are giving out, not the file system. Software that keeps hammering a weak head across marginal sectors can finish those heads off, turning a case that might have imaged near the From $250 file-system or $600–$900 firmware level into a $1,200–$1,500 head swap once the heads degrade. Bad sectors & clicking are physical from the first power-on. The software doesn't rewrite a Service Area it can't reach; it runs over standard ATA & stresses the heads.
A DIY donor-board swap can do the same thing for a different reason. The original PCB carries a small serial-flash ROM holding that drive's unique adaptive parameters, & bolting on a bare donor board runs the wrong adaptives. That can leave the original ROM content the only path back. If the original board held the only copy of those adaptives & it gets damaged in the swap, a board-only fault that could have been a $600–$900 ROM & adaptive migration on the PC-3000 Portable III escalates toward firmware & mechanical work.
Opening a drive outside a 0.02 micron ULPA-filtered clean bench is the costliest of these mistakes. Particulate that lands on the platters scores the surface the moment the drive spins back up. That pushes a clean head swap ($1,200–$1,500) toward platter cleaning & surface-damage handling ($2,000), the most consumable-heavy tier we run.
None of this changes the price unless it changed the drive. The free evaluation still tells us the current failure state before any quote, there's still no diagnostic fee, & No Data, No Charge still governs the outcome. We quote the tier the drive is in when it arrives, & we'll tell you honestly if an earlier attempt moved it. See how each tier sits inside the hard drive recovery overview, & read the exact terms on the No Data, No Charge guarantee page.
What Affects the Donor Drive Cost on a Mechanical Recovery?
The donor drive is a separate line billed at cost, & it appears only on the two mechanical tiers: the $1,200–$1,500 head swap & the $2,000 surface-damage job. Donor cost tracks scarcity, not your drive's capacity. A donor has to match firmware revision, head count, & preamplifier circuitry, so rare or high-capacity models cost more to source.
The donor is never marked up. We bill it as its own line at the price we paid, kept separate from the $1,200–$1,500 head-swap fee & the $2,000 surface-damage fee. The recovery tier covers the bench work: opening the drive in a 0.02 micron ULPA-filtered clean bench, transplanting the head stack, & migrating the original adaptive parameters. The donor is the physical hardware that work consumes, quoted on top of the tier.
What moves the donor cost is availability, not how much data sits on your platters. A donor has to match the patient drive on firmware revision, head count, & preamplifier circuitry before its heads will track your surfaces, so a common consumer model with millions of units shipped has cheap, plentiful donors, while a rare or high-capacity model has far fewer compatible candidates on the market.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The exact criteria we check before a part qualifies are laid out in how we match a donor to your drive.
The other three tiers carry no donor cost at all. A $100 simple copy, From $250 file system recovery, & $600–$900 firmware repair never open the drive or harvest a head stack, so there is no part to source & no donor line on the invoice. Firmware work runs entirely through the PC-3000 Portable III against the drive's own Service Area; it spends terminal time, not hardware.
Helium-sealed enterprise drives sit on their own, pricier donor list. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber. Those donors are scarcer than air-drive parts, & the sealed chamber has to be refilled with helium once it's opened, which is part of why the helium recovery range runs $200–$5,000+. We perform that head swap & refill in-house at the Austin bench; the helium mechanical work is never outsourced.
In every case we source the cheapest compatible donor available that still matches; you don't pay for the first part we pull off the shelf. The free evaluation identifies the failure tier & whether a donor is even needed before any quote lands, there's no diagnostic fee, & the No Data, No Charge policy still governs the outcome. See how the donor cost sits beside each tier on the hard drive recovery overview, or read the exact terms on the No Data, No Charge guarantee page.
Data Recovery Cost: Common Questions
What is the average hard drive recovery cost?
Why does physical hard drive recovery cost more than logical?
Is hard drive recovery cost determined by capacity or by failure type?
How much does data recovery cost?
How much do data recovery services cost?
How much does hard disk data recovery cost?
What is the hard drive recovery price for each failure type?
What are hard drive data recovery prices at this lab?
Is the donor drive included in the head swap price, or is it a separate cost?
Why is professional data recovery so expensive?
Is data recovery worth the cost?
Is there a fee if you cannot recover my data?
Why is Rossmann cheaper than DriveSavers?
What does a hard drive head swap involve?
Why does firmware repair require PC-3000 hardware?
How are donor drives matched for a head swap?
How do I get an accurate data recovery quote?
Should I try data recovery software first?
How much does it cost to recover data from an external hard drive?
Does it cost more to recover a high-capacity hard drive?
Does SSD data recovery cost more than hard drive recovery?
What is the average cost of hard drive data recovery?
How much does it cost to recover a 1TB hard drive?
Do you charge per gigabyte for data recovery?
How much does it cost to recover deleted files from a modern laptop SSD?
Why does firmware repair on SMR hard drives cost more than older CMR drives?
What are non-refundable attempt fees in data recovery?
What does SSD firmware recovery cost for specific controller failures?
Does turnaround time affect the price of data recovery?
Does a manufacturer warranty cover hard drive data recovery prices?
How do I compare data recovery prices between labs?
What is a reasonable fee for data recovery from a crashed laptop hard drive?
How much do people pay for hard drive recovery?
What is the typical hard drive recovery cost?
Is hard drive repair price the same as hard drive recovery cost?
Why is hard disk recovery cost lower at this lab than at a large advertising-driven lab?
How is cost figured when one drive has two failure modes at once?
Do I pay anything if I decline the quote after the free evaluation?
Does it cost more if I already ran recovery software on the drive?
Will a prior DIY board swap raise my recovery cost?
What am I actually paying for in a data recovery quote?
Does the donor sourcing time change the price or just the timeline?
Why the quotes get accepted
Why So Many People Trust DriveSavers
A four-figure quote for a job an independent lab does for a few hundred dollars usually gets paid, and the reason is not that customers fail to notice the price. It is that the name arrives pre-trusted. When your drive dies and you walk into an Apple Store, the person at the Genius Bar often points you to DriveSavers. Coming from Apple, that reads as an official blessing, so the quote that follows feels like the price of doing it right rather than a number to question.
That referral is not new marketing. It goes back to a 1999 Apple support memo in which Apple agreed to accept drives that DriveSavers had opened without voiding the hardware warranty. Apple was careful to say the mention was "neither an endorsement nor a recommendation" and that DriveSavers is not an Apple Authorized Service Provider, but the practical effect over the following decades was a steady stream of Apple Store referrals and a trust halo that no amount of advertising can buy. Apple still lists DriveSavers on its current data-recovery support page today.
Understanding that causality is the point. The trust is real, but it traces to a warranty-logistics arrangement from 1999, not to any finding that the work is better or the pricing is fair. The same recovery, on the same PC-3000 hardware, is performed by independent labs for a fraction of the quote. For the full breakdown of the referral and what it costs you, see is DriveSavers legit.
See our clean bench validation data and particle test videoRelated services
Related Pages
The advertising tax explained
Full HDD recovery overview
Step-by-step head transplant procedure
Firmware revision, head map, preamplifier criteria
Service Area modules, translator tables, ROM
Why SMR firmware repair costs more
Five published pricing tiers
Our guarantee policy
How to choose a trustworthy recovery lab
Get an accurate quote for your drive
