Don't Panic.
Helium-sealed drives (WD and HGST Ultrastar He, the Seagate Exos X series, and the helium-sealed members of the Toshiba MG line) are a separate, higher tier at $200–$5,000+: sealed chamber, exact-match donor, and in-house helium refill push the cost above standard air drives. Capacity alone won't tell you which kind you have. Seagate also ships air-filled enterprise drives such as the Exos 7E8.
Our Austin lab takes HDD and SSD recoveries by local drop-off and nationwide mail-in. We extract files in-house with PC-3000 tools and clean-bench procedures. No data = no charge. Every tier is published on this page before you ship.
Professional hard drive recovery clean bench with head swap tools in Austin lab
Updated August 28, 2026
15 min read
First steps
SymptomLikely failure layerAustin lab route
Clicking or repeated tickingHardware fault. We find out which part failed on the benchBench diagnosis first. If the heads failed, a donor head swap on the 0.02 micron ULPA clean bench, then imaging on PC-3000 Portable III or DeepSpar Disk Imager
Beeping or buzzingOn an external drive, most often not enough powerRule out the cable, port, and power supply. If it still beeps, we diagnose it on the bench
Spins but is not detectedService area corruption, ROM adaptive mismatch, translator damage, or PCB faultFLIR thermal inspection, ROM extraction when required, and PC-3000 SA diagnostics before any filesystem repair is attempted
Dropped external driveUSB bridge damage, head slap, spindle shock, or contaminated mediaBoard and connector triage first, then mechanical inspection or firmware imaging based on the actual HDD failure
Process
    Evaluate & Protect
    Stabilize Access
    Clean-Bench Mechanics
    For failed heads, we do an exact-match donor head swap on the 0.02 micron ULPA-filtered laminar clean bench. Whenever an HDD data recovery case needs mechanical work, the donor has to match the patient drive's preamp revision, head map, and firmware. A simple PCB or head swap without this matching step won't work.
    Image First, Always
  5. 5
    Recover from Image
  6. 6
    Deliver & Purge
How the Austin lab is equipped
4.9 stars across 1,837+ verified Google reviews. No data, no recovery fee.
Primary HDD imager
Firmware and service area
Clean bench
Thermal diagnostics
FLIR thermal imaging cameras locate shorted components on burned PCBs.
Donor inventory
Single Austin lab
PC-3000 by ACE Lab
Our hard drive and SSD recovery is powered by PC-3000. It's a high-quality product, and it's what makes our work possible.
What is Hard Drive Data
Professional data retrieval services use specialized hardware such as the PC-3000 by ACE Lab and DeepSpar Disk Imager to recover data from hard drives when standard software solutions fail. According to Backblaze's Drive Stats data covering a fleet of hundreds of thousands of drives, annualized failure rates are published per model line every quarter. Drives fail in normal service, and some of those failures need professional recovery.
Recovery methods include:
Logical repair
Recovering corrupted partitions, formatted filesystems, and deleted files using sector-level imaging and advanced file carving.
Firmware repair
Restoring access to drives not detected by the system; includes ROM extraction, translator module rebuilding, and adaptive parameter correction using PC-3000-class tools
Mechanical repair
Clean bench head swaps and platter work for clicking or beeping drives with physical head damage, performed under ULPA-filtered laminar flow bench with 0.02 micron ULPA filtration
On clicking, beeping, or not-detected drives, attempting repair before imaging risks scoring platters and pushing the job from our firmware tier into our platter-damage tier. At our Austin lab, we only do head swaps or translator rebuilds to get the data off the drive. For a deeper breakdown, see our hard drive repair vs recovery explainer.
Head stack replacement runs on a 0.02 micron ULPA-filtered clean bench with donor-matched parts; firmware corruption is addressed through SA module access on the PC-3000 Portable III; and imaging of the stabilized drive runs on the DeepSpar Disk Imager with head-map control so we read good surfaces before risking weak ones.
Almost no consumer can do a PCB swap on a modern drive, and here's what real hard drive repair looks like when we do one. Modern HDDs store boot code and calibration unique to that drive, including head-specific adaptive parameters, on an 8-pin SPI flash ROM on the PCB.
Modern PMR heads keep a baseline aerodynamic clearance of a few nanometers and use thermal fly-height control to hold the transducer at an active magnetic spacing of about 1 to 2 nanometers. A donor PCB without the patient's ROM won't initialize the drive, because the adaptive parameters in that ROM belong to this drive's own heads.
We move the original ROM, or its contents, to a family-matched and firmware-matched donor board, and only then power the drive long enough to image it on the DeepSpar. Firmware-tier work follows the same logic: translator rebuilds, P-list and G-list edits, and module repairs such as WD Module 32 through SA access on the PC-3000 Portable III, performed in service of the image rather than to return a working disk to you.
Recover the data first, then RMA the drive afterward. A manufacturer warranty RMA gets you a replacement or refurbished drive. It doesn't get you the data that was on the failed unit.
When the data matters, the order is fixed. Send the drive to a recovery lab first. Once the image is done and your files are back, RMA the dead unit if the warranty terms still let you return a drive that's been through recovery.
Last updated: June 16, 2026
What the service includes
Our hard drive data recovery service runs end to end from one Austin, TX lab: a free evaluation with no diagnostic fee, in-house head-stack & PCB work, head-by-head imaging on the DeepSpar Disk Imager & PC-3000 Portable III, nationwide mail-in, & no data, no recovery fee. Standard drive pricing runs $100–$2,000.
The goal is a sector-by-sector image, not a drive returned to working order. Drives that still spin up are read head-by-head on the DeepSpar Disk Imager & the PC-3000 Portable III, so strong surfaces come off first & weak ones last. When a drive is clicking or electronically dead, we stabilize it first with a head swap, PCB ROM transfer, or firmware repair, then image it once it can be read.
Head-stack swaps, PCB ROM transfers, & firmware service-area work all happen at our Austin, TX lab. Single location, no franchises, no outsourcing. Head swaps run on a 0.02 micron ULPA-filtered clean bench with a donor matched to the family, head map, and firmware revision. Helium drives get an in-house head swap plus a helium refill once we open the sealed chamber.
Nationwide, the service is mail-in. You pack the drive in ESD-safe materials, hand it to the carrier, & it is logged into the queue on arrival. We have run the lab this way since 2008 out of a single shop, not a network of intake storefronts.
You pay no recovery fee if the files cannot be read off. Standard tiers run $100–$2,000; helium drives run higher because the sealed-chamber work & refill add cost. Turnaround tracks the failure class: a simple copy moves in 3-5 business days, while a head swap is a 4-8 weeks job, & there is a +$100 rush fee to move to the front of the queue.
  1. Request the free evaluation. There is no diagnostic fee & no charge to look.
  2. Pack the drive in ESD-safe materials & ship it to the Austin, TX lab.
  3. We identify the failure class & quote a firm price from the tier schedule before any billable work begins.
  4. Approve the price. We recover, return your files on healthy media, & bill no recovery fee if the data cannot be read off.
HDD imaging via DeepSpar
If a drive is mechanically stable, we image it before we try any repair. The PC-3000 Portable III and DeepSpar Disk Imager pull a head-by-head, sector-by-sector image with head-map control, so good surfaces are read first and weak surfaces last. We only do a head swap when bench diagnosis shows the read/write heads, not the firmware, have failed.
Head swaps run on a 0.02 micron ULPA-filtered laminar flow bench with a donor matched to the family, head map, and firmware revision; platter handling stays inside that bench from de-lid to image. We handle firmware faults through SA module access on the PC-3000 rather than mechanical work. Standard pricing tiers run $100–$2,000. If we can't read the files off, there's no recovery fee. That's our no-data, no-recovery-fee policy.
Hard drive jobs in our Austin lab go through four procedures.
First, PCB ROM transfer with a board-revision-matched donor, when the original board is dead or has a burned TVS diode. We move the 8-pin SPI flash that holds the drive's own adaptive parameters, or its contents, to a family, firmware, and board-revision-matched donor before we apply any power. A donor PCB without the patient ROM won't initialize the drive.
Second, head and media work on the 0.02 micron ULPA-filtered clean bench when bench diagnosis shows the heads have failed. Third, firmware service-area edits on the PC-3000 Portable III for translator rebuilds, P-list and G-list repairs, and module-level fixes that bring the drive back into a readable state.
Fourth, physical imaging on the DeepSpar Disk Imager once the drive is stable enough to read, with head-map control sequencing the strongest surfaces first. Hard drive recovery and HDD data recovery describe the same four-step workflow; the original drive is never the deliverable, the image is.
Enterprise and forensic
Corporate and forensic hard drive recoveries use the same Austin lab, the same engineers, and the same workflow as consumer jobs, with two additions: NDAs counter-signed before the drive is unboxed, and chain-of-custody documentation.
Corporate and forensic-tier HDD recoveries get the same lab, the same engineers, and the same workflow as a consumer drive, with two additions. NDAs are available on request for legal, medical, financial, and regulated-industry clients; send the document with the intake form and we counter-sign before the drive is unboxed.
We document chain of custody for the case.
Standard hard drive data recovery costs $100–$2,000, depending on the failure type. Every recovery begins with a free evaluation and a firm quote before any work begins. If we can't recover your data, there's no recovery fee. Simple data copies from a functional drive cost $100.
File system recovery for corrupted partitions, formatted drives, or volumes the operating system no longer recognizes starts at $250. Firmware repair costs $600–$900. That's when the drive's internal software is corrupted and we have to rebuild the translator tables, ROM data, and adaptive parameters on the PC-3000 Portable III.
Mechanical failures that require a donor head swap on our 0.02 micron ULPA-filtered laminar clean bench run $1,200–$1,500 and require a 50% deposit because donor parts are consumed in the procedure. The most severe tier covers platter surface damage from head crashes and starts at $2,000.
We set our data recovery price structure by the failure type, not by how many gigabytes are stored on the platters.
Helium refill manifold attached to a resealed enterprise helium drive lid during the in-house recharge cycle in the Austin lab
Helium drives sit in their own tier because the chassis is hermetically sealed at the factory. When we open one for a head swap, we have to refill the chamber with helium afterward. Donor drives are also scarcer and pricier than equivalent air-filled models. On helium designs with up to nine platters, the head-stack geometry means the donor has to match the exact firmware revision and head map.
WD and HGST Ultrastar He and Ultrastar DC HC5xx and above are helium, and so is the Seagate Exos X series. The air-filled enterprise drives are separate sub-lines, such as the Seagate Exos 7E8, the WD Ultrastar DC HC310, HC320 and HC330, and the Toshiba MG08ADA. Capacity alone won't tell you which kind a drive is.
If it turns out easier than expected, you pay less. You aren't billed a flat "worst-case" tier. If we can't get your data, there's no recovery fee. The only thing you'd pay for is return shipping, and that's optional. See all service pricing.
Seagate Rosewood (stuck heads): If the heads are stuck to the platters but undamaged (stiction-only), we unstick and reuse them with no donor drive needed. This falls into the firmware-tier range at $600–$900. If the heads are stuck and damaged, a full donor head swap is required at $1,200–$1,500 plus donor drive cost.
Estimate Your Recovery Cost
Timeline, repair vs recovery
Simple transfers from a healthy drive take 3-5 business days; firmware repairs take 3-6 weeks; head swaps take 4-8 weeks. We only repair the drive in service of getting your files off it. What you get back is your data, never a working original drive.
Turnaround depends on the failure tier and donor availability. A healthy 1 TB drive images in a few hours. Light bad sectors add time as PC-3000 retries weak areas. Firmware corruption (drive not detected, wrong reported capacity, busy state) takes 3-6 weeks including SA module diagnostics and translator rebuilding.
Head swaps take 4-8 weeks because we source an exact-match donor with the correct firmware revision, head map, and manufacturing batch. Helium head swaps add time for the resealing and refill cycle. +$100 rush fee to move to the front of the queue; rush moves your job to the front of the queue but does not shorten the procedures themselves. Every quote includes a time estimate alongside the price.
Professional Recovery
Get a Free Estimate
FREE
DIY Recovery
Try Free DIY Guide
Mail-In Service
Mail-In Instructions
Nationwide
Mail-in recovery eliminates the middleman. You ship directly to our Austin lab; your drive goes straight onto the bench.
Our nationwide mail-in shipping protocol eliminates the middleman. You ship directly to our Austin lab, your drive goes straight onto the bench, and you talk to the engineer doing the work.
We take mail-in recoveries nationwide. Our shipping process uses USPS Priority or FedEx. Pack your drive in an anti-static bag inside a padded box (no bubble wrap directly on the drive).
We provide status updates from intake through delivery.
Why Mail-In Beats Local
  • Direct access to PC-3000, DeepSpar, and ULPA-filtered clean bench
  • No middleman markup
  • Same published pricing whether you are in New York, Los Angeles, or Austin
How to Ship Your Drive
Order of operations
Drive conditionWhat runs firstWhy that order
Drive is detected at the right capacity (deleted files, lost partitions, or bad sectors)Sector-by-sector imaging on the DeepSpar Disk Imager or PC-3000, write-blockedThe address map is intact, so a forensic clone is the safe first move. Reconstruction then happens on the clone, never the patient drive.
Drive-managed SMR drive (shingled consumer Barracuda, Rosewood, and similar families)PC-3000 firmware-level write lock, then DeepSpar imagingThe drive runs its own background garbage collection whenever it has power. Only a firmware write lock halts it; a SATA write-blocker cannot.
Firmware-tier work runs $600 on a CMR drive and $900 on an SMR drive, because the shingled mapping is harder to rebuild.
Shingled drives add one more rule. A drive-managed SMR drive keeps rewriting its own shingle bands through background garbage collection every time it has power, with no command from us. A SATA write-blocker stops our writes but not the drive's internal housekeeping, so we issue a firmware-level write lock through the PC-3000 first, then connect the DeepSpar Disk Imager. Skip that order and the drive can overwrite the very data we were sent to recover.
Every one of these calls is made in-house at our Austin, TX lab, on the bench, before the meter starts. There is no diagnostic fee, and no recovery fee if we can't get your files back.
Cost tracks the class of work a drive needs, not the model on the label. Logical faults, firmware faults, and mechanical faults each take a different bench path and land in a different published tier. Which one your drive has is established at evaluation, on the bench. Find your symptom in the table below for the tier it usually falls into.
SymptomRecovery ClassRecovery MethodPrice Range
Not detected, spins normallyFirmware / translator corruptionPC-3000 firmware repair$600–$900
Clicking or tickingMechanical, diagnosed at the labClean-bench diagnosis, then a donor head swap if the heads are at fault$1,200–$1,500
Beeping or buzzingMost often not enough power on an external. Otherwise we diagnose it at the labRule out the cable, port, and power supply, then bench diagnosis$1,200–$1,500
Not spinning at allPCB, power, or motor fault, diagnosed at the labPCB repair, or mechanical work if the motor failed$600–$900 - $1,200–$1,500
Grinding or scrapingPhysical contact inside the driveClean-bench inspection, then platter cleaning and a head swap$2,000
Comparison
How Does Our Pricing Compare to a National Lab?
Our five HDD tiers run $100–$2,000 and every one of them is on this page before you ship. DriveSavers publishes no rate card, so their number arrives after the drive does. We do not publish figures for any other lab, because we have no sourced ones to publish.
What you can check before you commit is the only comparison worth making. Our tiers are $100 for a simple copy, From $250 for file system recovery, $600–$900 for firmware repair, $1,200–$1,500 for a donor head swap, and $2,000 for platter surface damage. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Evaluation is free, there is no diagnostic fee, and there is no recovery fee if we cannot get your files back. The work happens in-house at the Austin lab. One location, no franchises, nothing shipped to a third party.
For what to ask any lab before you ship, see how to choose a hard drive recovery service, and for the sourced write-up on one national lab, read our analysis of DriveSavers pricing.
Watch a Real Recovery
We film our recoveries so you can see the process before sending your drive. This video covers why a Seagate external hard drive beeps.
YouTube Authority & HDD Recovery
Louis Rossmann's YouTube channel has 2.64M subscribers. The same Austin lab that diagnoses MacBooks on camera also performs mechanical hard drive recovery with PC-3000 tools, donor head matching, & clean bench work.
Chris, our lead data recovery technician, runs the day-to-day HDD recovery queue. He matches donor heads from our cataloged inventory by family & firmware revision, rebuilds the translator module in PC-3000 Express, and images damaged drives sector-by-sector with DeepSpar Disk Imager.
Who performs the recovery
Louis Rossmann founded the lab in 2008. Chris leads bench recovery work on physically failed drives. No work is routed to a third-party lab. See earlier on-camera bench-recovery work recorded at the lab: data recovery technician and hard drive recovery queue.
  1. Isolate the drive under the ULPA bench. We move the drive to the 0.02 micron ULPA-filtered laminar flow clean bench before we open it.
  2. Inspect the tribological stack for scoring or contamination from DIY attempts. The damaged head stack is removed using head combs to prevent any slider from contacting platter media during extraction. Platter surfaces are then inspected under magnification to map zones with visible scoring or magnetic layer removal. Metallic shavings, carbon debris, and displaced lubricant from prior opening attempts are catalogued before cleaning begins.
  3. Perform the donor-matched head swap on the clean bench. We clean debris off the platter surfaces inside the laminar flow zone of the 0.02 micron ULPA bench. Then we guide a donor head stack assembly, matched on preamp revision, head map, and firmware, onto the load/unload ramps with head combs so no slider contacts platter media during seating.
  4. We image the drive after the swap, with head-map control. After the donor heads are seated, the PC-3000 Portable III accesses the drive service area to adjust adaptive parameters so the new heads can read weak sectors adjacent to cleaned damage zones. Head-map imaging on the DeepSpar Disk Imager then sequences clean surfaces first, leaving degraded zones for the end of the imaging session to maximize data yield before the donor heads potentially degrade.
  5. Retire the original drive. File system parsing and file extraction run from the cloned image, never from the patient drive. The original drive is held under the customer's shipping instruction. If the image cannot be produced, the no-data-no-recovery-fee guarantee applies and the customer pays nothing (optional return shipping only).
A laminar flow bench fitted with a 0.02 micron ULPA filter. The 0.3 micron figure quoted for HEPA filters is their most penetrating particle size, the point of minimum efficiency, not the smallest particle they stop.
The interface between the read/write head sliders and the magnetic platter surface. When a slider contacts the rotating platter, it strips the magnetic recording layer off the platter. That generates metallic and carbon debris, which circulates inside the sealed head-disk assembly and scores every data track the damaged head passes over.
Donor-matched head swap
A mechanical recovery procedure that replaces a failed head stack assembly with a compatible donor. Before any swap, we check the donor drive against its head map, preamp silicon revision, and firmware, plus the site code on Seagate drives.
Hardware imager for head-by-head, sector-by-sector imaging with head-map control on weak heads. It operates at the SATA PHY layer, below the host operating system. The engineer configures millisecond-level hardware timeouts so a degrading head is pulled off a weak track before extended internal firmware retry loops permanently damage the platter surface.
ScenarioFailure ModeOutcome
Home / unfiltered room openingDust particles larger than head flying height contact platter surface on spin-up; head slider contacts platter and strips magnetic recording layerMetallic and carbon debris circulates inside the sealed HDA, scoring data tracks
0.02 micron ULPA clean bench (Austin lab)Laminar airflow through the 0.02 micron ULPA filter keeps ambient particulates away from the open chassisPlatter surfaces remain clean during head stack transfer; donor heads seat on ramps via head combs without slider-to-platter contact; imaging proceeds on surviving data tracks
From PCB diagnostics to PC-3000
Component-level PCB repair restores power-on electrical viability so a drive can boot its own microcode. It is the prerequisite for PC-3000 firmware work, not a substitute. PCB rework does not decrypt user data or alter hardware encryption on SED or OPAL drives.
Modern hard drives store boot code and unique factory calibration data in a SOIC-8 serial flash ROM on the PCB, including head-specific adaptive parameters and servo calibration tables. These values are tuned to the specific physical head stack assembly inside the patient drive.
A donor board booted with its own ROM will not initialize the patient drive.
When a Transient Voltage Suppression (TVS) diode shorts to ground after an overvoltage event, or a motor driver IC burns open, the recovery workflow starts at the bench supply with a multimeter in diode mode and a FLIR thermal camera to localize the fault. The shorted diode is removed with an Atten 862 hot air station; the SOIC-8 ROM is desoldered with hot air and soldered onto an identical donor board using a Hakko FM-2032 micro-soldering iron.
This restores power-on electrical viability so the drive can load its own Service Area microcode. It does not decrypt user data or alter hardware encryption. See PCB diagnostics versus logic board repair and water damaged drives with corroded SPI pins.
On a Western Digital Drive-Managed Shingled Magnetic Recording (DM-SMR) drive, data first lands in a persistent Conventional Magnetic Recording (CMR) cache zone, then a background garbage collection process migrates it into the final shingled bands during idle time.
The dynamic translator module in the Service Area maps logical blocks across the CMR cache and the SMR bands. A power loss during garbage collection desynchronizes that translator. The drive powers on, identifies with the correct capacity, and reads as a string of zeros across the entire logical address space.
For mechanical helium recovery, see helium drive recovery in the Austin lab.
Seagate F3 drives have a Universal Asynchronous Receiver-Transmitter (UART) serial diagnostic terminal on the PCB. That goes for everything from the Barracuda 7200.11 generation through Rosewood and Exos. We talk to that terminal at 38400 baud over a COM cable on the test pads. Modern F3 drives ship that terminal locked, so we have to unlock the diagnostic port before any command runs.
The danger on a modern Seagate SMR drive is that the legacy translator regeneration command from the CMR era will permanently zero the MCMT on an F3 SMR drive. The cached writes still sit on the platters magnetically. The pointers linking them to their final destinations are gone.
The safe way to handle one of these drives on PC-3000 is to back up the translator and MCMT and lock the drive's background media cache migration before any imaging begins. See the mechanical complement at dropped hard drive recovery and donor head alignment.
Where the lab stops and the key begins
The Austin lab solves the first problem at the physical and firmware layer. The second problem belongs to whoever holds the key. What comes off a BitLocker or FileVault drive during imaging is ciphertext, a stream of encrypted binary that stays unreadable until the correct credential decrypts it.
Lock typeWhat the Austin lab doesWhat you must supply
BitLocker (Windows)Stabilize heads and PCB, then run multi-pass PC-3000 imaging that preserves the redundant -FVE-FS- metadata headers holding the volume master keyThe 48-digit recovery key, often backed up to a Microsoft account, Entra ID, or Active Directory
FileVault (macOS)Resolve bad sectors and firmware faults so the APFS volume can be imaged and mounted on Mac hardwareThe alphanumeric recovery key, or the user login password
Hardware-encrypted SED / TCG OPALRepair the drive or bridge so its own controller can run the on-board AES engineThe OPAL or pre-boot authentication password
ATA firmware passwordRead and edit the drive Service Area on the PC-3000 Portable III to clear the security flag; the platter data is plaintext, not scrambledNothing. This is the one lock the lab clears at the firmware level
A BIOS or HDD password set on a laptop drive without hardware encryption is an ATA Security lock. It does not scramble the data on the platters into ciphertext. The bytes sit in plaintext; the drive firmware simply refuses to grant the host access to the user area until the correct password arrives at power-up.
The password itself lives in a firmware module in the drive Service Area, the hidden reserved tracks that hold the drive operating system, defect lists, and security settings. On Western Digital drives that security state is held in Module 02.
Our engineers interface with the Service Area on the PC-3000 Portable III, read the relevant module into RAM, and clear the security flag so the user area becomes readable again. This is firmware Service Area access, not cracking or bypassing encryption, and it is the only case here where no customer key is needed.
If the data matters, do not let anyone run a PSID Revert on the drive. On a hardware-encrypted WD external, the key material survives a dead bridge board. A lost user-set password doesn't. That password still has to come from you.
Drives We Recover From
What we run on the bench
We publish which tools do the work, and we film them doing it.
A 0.02 micron ULPA-filtered laminar clean bench. Vertical filtered airflow pushes airborne particles down and away from the work surface while a drive is open.
PC-3000 Recovery Platform
Every Recovery on Camera
No stock photos of bunny suits. Watch us work on YouTube, where recoveries are performed on camera, start to finish. The channel has 2.64M subscribers.
Lab Capability and Guarantee Summary
Customer Rating
Recovery Fee Policy
Lab Location
Operating Since
Named HDD Recovery Equipment
DeepSpar Disk Imager for head-by-head sector imaging, FLIR thermal cameras for PCB short and burned-rail diagnosis, PC-3000 Express and PC-3000 Portable III for service area access and translator rebuilds, and a 0.02 micron ULPA-filtered laminar flow clean bench for head stack swaps and helium drive opening.
The data on a hard drive is magnetic and persists on the platters even when the drive's electronics, firmware, or read/write heads have failed. Recovery requires stabilizing or replacing the failed component, then imaging every readable sector.
A "dead" hard drive can mean one of three things: the PCB has failed (power surge, shorted TVS diode), the firmware is corrupted (drive not detected, shows wrong capacity), or the read/write heads have failed. None of these conditions destroy the data stored on the platters.
If the platter surfaces themselves are physically destroyed, the data there is gone for good. This happens when a head crash scrapes the magnetic coating off the platters, or when someone runs a clicking drive long enough that the heads grind through the recording layer. If your drive stopped working after a crash or sudden failure, power it off immediately.
Classifying the failure during the free evaluation determines the correct PC-3000 module, donor requirements, and cost tier before any work begins.
Recovery time depends on the failure type and drive capacity. File system recoveries take2-4 weeks. Firmware repairs take 3-6 weeks. Head swaps requiring donor parts take 4-8 weeks. A rush fee is available to move to the front of the queue.
Firmware corruption (drive not detected, wrong capacity) takes 3-6 weeks, including terminal diagnostics and translator rebuilding.
Head swaps take 4-8 weeks because we need to source an exact-match donor drive with the correct firmware revision, head map, and preamp revision. Donor availability varies by model.
Technical detail
At a Glance
  • $Cost: From $100 for simple copies, $100–$2,000 for recovery (firm quote after free evaluation)
  • Equipment: PC-3000 Portable III + a 0.02 micron ULPA-filtered laminar clean bench for mechanical failures
2.64M SubscribersBBC FeaturedRight to Repair
I have testified before Congress and State Legislatures fighting for your Right to Repair. I have built a YouTube channel with 2.64M subscribers by showing our work; honestly and transparently; for over a decade. I am not going to throw away that reputation to make a quick buck on your hard drive.
Trust signals
15+ Years Experience
No Data = No Charge
In-House Austin Lab
Why us
Why Choose Our Austin Lab
We do every hard drive recovery in our Austin lab on this equipment: PC-3000 Portable III, PC-3000 Express, PC-3000 SSD, DeepSpar Disk Imager, and a 0.02 micron ULPA-filtered clean bench.
We do not ship your drive to a mystery warehouse. Our in-house engineers recover your data on-site in Austin. Visit our Austin lab page.
The lab runs FLIR thermal cameras for PCB triage, Hakko FM-2032 microsoldering irons on FM-203 or FX-951 base stations with an Atten 862 hot air rework station for board-level rework, and Zhuo Mao precision BGA rework stations when the recovery requires controller-board repair. We open, head-swap, and refill helium drives in-house at the helium HDD pricing tier. We don't refer helium mechanical cases out.
Louis Rossmann at the helium drive workstation in the Austin lab with the helium recharge manifold and ULPA-filtered laminar flow bench
Helium workstation: laminar flow bench, refill manifold, donor stock on hand.
We handle every HDD data recovery case in-house through our hard drive recovery service, and we don't outsource diagnostics. At our Austin, TX lab we work on the PC-3000 Portable III, DeepSpar Disk Imager, and a 0.02 micron ULPA-filtered clean bench.
Austin Lab Since 2008
One physical location at 2410 San Antonio Street, Austin, TX, operating without franchises, satellite offices, or outsourced labor. Founded 2008.
4.9 Stars, 1,837+ Google Reviews
Verified Google Business Profile rating across 1,837+ reviews. We also have 2.64M YouTube subscribers.
Transparent Pricing
Clean bench physics
Modern PMR read and write heads hold a baseline aerodynamic clearance of a few nanometers on an air bearing, and use Thermal Fly-height Control to protrude the transducers to an active magnetic spacing of 1 to 2 nanometers.
The bench on the equipment list is a 0.02 micron ULPA-filtered laminar clean bench, and that filtration rating is what the open-drive work is specified on.
ISO 14644-1 specifies particle concentration per cubic meter of air. Vertical laminar flow pushes filtered air downward across the open chassis, deflecting room contaminants and operator shedding away from the exposed platters.
We do all clean bench mechanical work in this lab in Austin, including head stack assembly transfers, platter cleaning, and helium refill. We do not ship opened drives offsite.
Imaging and firmware tooling
The PC-3000 Portable III runs directly on the clean bench. It accesses each drive through vendor-specific commands rather than the standard ATA stack, which is what makes Service Area work possible after a head swap.
On Western Digital Marvell architectures the engineer transfers Module 47 adaptive parameters from the patient ROM, edits the physical head map in Module 0A, and rebuilds Module 190 translator tables on SMR families. On Seagate F3 drives the same hardware connects to the diagnostic UART at 38400 baud to reach the F3 T> prompt for SysFile 28 and media cache map work on Rosewood and other shingled platforms.
The PC-3000 Express sits on a dedicated PCIe card in a separate workstation with four SATA diagnostic ports and two legacy PATA ports.
The DeepSpar Disk Imager runs on a separate PCIe imager and talks to the drive at the SATA PHY layer, below the host operating system. We set millisecond-level hardware timeouts so a read on a weak track is cut off instead of waiting out the drive's own retries.
Reviews, location, guarantee
We have 4.9 stars across 1,837+ verified Google reviews on the Rossmann Repair Group business profile, and 2.64M YouTube subscribers. Read the reviews; watch the videos. You can see the actual bench, the actual engineer, and the actual jobs.
Laminar flow vs walk-in cleanroom
Why a Laminar Flow Bench Is Enough for a Head Stack Swap
We do open-drive work on a 0.02 micron ULPA-filtered laminar clean bench. Its vertical filtered airflow pushes airborne particles down and away from the open chassis, without the overhead of a walk-in cleanroom.
0.02 micron ULPA-filtered laminar flow bench in the Austin lab with an open patient drive staged for a head stack transfer
Which air does a head swap actually depend on?
Open-drive work at this lab runs on a 0.02 micron ULPA-filtered laminar clean bench. Vertical filtered airflow pushes airborne particles down and away from the work surface for as long as the drive is open.
What air reaches the open chassis during a head stack swap?
During a head stack transfer the platters are exposed only to the air immediately above them. Vertical laminar flow pushes ULPA-filtered air downward across the open chassis at a consistent face velocity, deflecting operator shedding, room dust, and ambient turbulence away from the platter surfaces.
Engineering requirement at the platter level
The platters need filtered laminar airflow at the work surface, and the 0.02 micron ULPA-filtered bench gives them that.
All head-stack work, helium refill, and platter cleaning happen on this bench in Austin. For the longer-form physics breakdown see cleanrooms vs laminar flow benches, and for the step-by-step bench procedure see what a head swap involves.
Clicking drive procedure
We treat a clicking 3.5 inch drive as a hardware fault and find the failed part on the bench. We check the electronics with FLIR thermal imaging and match donor heads. Then we transplant the head stack on the 0.02 micron ULPA-filtered clean bench and image selectively by head map, pulling healthy surfaces before we retry degraded zones.
  1. Electrical triage on the PCB. Before we open the drive, we isolate the controller board and probe it for shorted TVS diodes on the 5V and 12V rails, blown buck converter outputs, and burned preamp supply lines. A FLIR thermal camera flags hot spots invisible to the eye. If the failure is electrical rather than mechanical, board-level repair with a Hakko FM-2032 microsoldering iron on an FM-203 or FX-951 base station completes the recovery without ever cracking the lid.
  2. Environmental preparation on the ULPA bench. The drive is moved to the 0.02 micron ULPA-filtered clean bench, which generates a vertical laminar airflow envelope over the work surface. ULPA filter media captures 99.9995 percent of particles at 0.12 microns through a combination of diffusion, interception, and inertial impaction. That matters because modern read/write heads fly within a few nanometers of the platter surface.
  3. Donor head matching. A model-number match isn't enough. Before any swap, we check the donor drive against head map and head count, preamp silicon revision, and firmware family and revision. On Western Digital drives, the DCM has to align. On Seagate drives, the part number, site code and date code do.
  4. Head stack transplant inside the bench. We lift the damaged head stack assembly out with head combs and seat the donor stack without letting any slider contact platter media. On helium-sealed drives, we refill the chamber with helium in-house. The helium refill cost is part of the helium HDD pricing tier.
  5. ROM adaptive transfer. The original PCB ROM holds microjog offsets and channel-gain calibration unique to the patient drive. If the PCB also has to be replaced, the PC-3000 Portable III writes the original ROM adaptives to the donor PCB. If the Service Area itself is corrupted, we upload a loader into controller RAM through the vendor-specific diagnostic port so we can repair the firmware in place.
  6. Selective head map imaging via PC-3000. Once mechanical stability is confirmed, the PC-3000 issues vendor-specific commands to log per-head read stability. We disable weak heads in the firmware head map and throttle read requests with imaging-utility timeouts. We image healthy surfaces first onto safe destination media, and we only go back to degraded zones after the rest of the image is locked. The DeepSpar Disk Imager handles the same role for drives that respond to ATA but degrade quickly under sustained imaging load.
  7. File extraction from the clone, not the patient. File system parsing and file extraction run from the cloned image, never from the patient drive. If the image cannot be produced the no-data-no-recovery-fee guarantee applies and the customer pays nothing except optional return shipping. The original drive is held under the customer's shipping instruction.
Head swaps on conventional 3.5 inch drives fall in the head swap tier, $1,200–$1,500. Helium drives carry an additional helium refill cost, listed in the $200–$5,000+ helium HDD tier table.
Why power-cycling a clicking drive destroys data
Every power-on attempt on a clicking drive is another chance to put the read/write heads into contact with spinning platters. Heads that touch down scrape the magnetic coating off, liberating metallic debris that abrasively scores surviving data tracks. The read channel collapses under the resulting signal loss, and sectors become permanently unrecoverable before any donor head swap can be attempted.
A clicking drive has a hardware fault, and the sound alone won't tell you the part behind it. Where the fault is in the heads themselves, each additional power-on attempt forces them across spinning platters and can turn a head swap case into a platter-damage case.
If your drive clicks or grinds, unplug it. Do not run CHKDSK, Recuva, SpinRite, or any recovery software on a mechanically damaged drive. Running repair utilities on a degrading mechanical HDD accelerates the failure and removes data we could otherwise image cleanly. See the clicking hard drive recovery page for symptom-specific detail.
Recovery software vs hardware imaging
  • File-recovery software such as EaseUS Data Recovery Wizard, Disk Drill, Stellar, and R-Studio reads the drive through the OS storage driver, scanning file-system metadata and carving files by signature. It assumes healthy mechanics: the drive must spin up, achieve servo lock, initialize its service area, and report correct capacity. On a clicking drive a deep scan stalls on read timeouts or the drive drops offline mid-scan.
  • Disk-repair utilities such as CHKDSK and SpinRite go a step further and write to the drive. CHKDSK /f fixes errors by writing to the volume, and /r adds a bad-sector scan on top of that. SpinRite hammers a weak sector with repeated read and write cycles to force the firmware to retire it into the growing defect list, which on a head-failure drive means more head passes over damaged media, not a repair.
Why a full-surface deep scan is destructive on a failing drive
Because the scan rides the OS storage driver, each unreadable sector stalls behind the operating system block-layer timeout while the drive grinds through its own retry routine. Hardware imagers invert that relationship: they talk to the drive at the SATA PHY layer below the OS, so they govern the read attempt instead of waiting on it.
BehaviorConsumer software and utilitiesEaseUS, Disk Drill, CHKDSK, SpinRiteHardware imagingDeepSpar Disk Imager, PC-3000
Operating layerStandard ATA reads through the OS storage driver (EaseUS, Disk Drill, CHKDSK) or bare-metal direct hardware polling from a boot environment (SpinRite). Neither has SATA PHY-layer reset control or can reach the service area or firmware.SATA PHY layer with vendor specific command terminal access, below the OS.
On a clicking or head-failure driveSequential scan drags the failing head across every track; utilities force reallocation and overwrite metadata. Damage spreads.Builds a RAM head map to exclude the failing head and image healthy heads first. The marginal head goes last.
Read-timeout controlWaits out the OS block-layer timeout on every bad sector while the drive grinds.Millisecond-level hardware read timeouts, COMRESET or controlled power-cycle on a BSY hang, with auto-relocation turned off.
Hardware imaging is a methodology, not a guarantee, but it is the difference between resting a weak head and punishing it. At the read-channel layer a technician can also tune preamp gain and the equalizer response to pull a marginal signal back into the error-correction window, which no consumer software can touch. Running a deep scan first is how a job that belonged in our head-swap tier ends up in our platter-damage tier.
Platter cleaning before head swap
When Do the Platters Need Cleaning Before a Donor Head Swap?
When the platters carry debris from a head crash or an earlier opening, we clean them on the 0.02 micron ULPA-filtered laminar flow bench before a donor head stack goes in.
Previously opened drives reduce recovery success because dust, fingerprints, or misaligned head assemblies can turn a simple unstick into irreversible platter damage.
All platter handling happens inside the 0.02 micron ULPA-filtered laminar flow bench.
  1. Platter surface inspection under magnification. The damaged head stack is removed using head combs to prevent any slider from contacting platter media during extraction. Platter surfaces are then inspected under magnification to map zones with visible scoring or magnetic layer removal. Cleaning cannot recover data from an abraded zone; it prepares surviving tracks for the incoming donor heads.
  2. Debris and displaced lubricant removal. We clean debris off the platter surfaces inside the laminar flow zone of the 0.02 micron ULPA bench, where filtered air flows down across the open chassis.
  3. Donor head installation via head combs. We guide a matched donor head stack assembly, verified against head count, preamp revision, and firmware family, onto the load/unload ramps with head combs so no slider contacts platter media during seating. On helium-sealed drives, we refill the chamber with helium in-house at our Austin lab.
  4. Read-channel tuning before imaging. After the donor heads are seated, the PC-3000 Portable III accesses the drive service area to adjust adaptive parameters so the new heads can read weak sectors adjacent to cleaned damage zones. Head-map imaging on the DeepSpar Disk Imager then sequences clean surfaces first, leaving degraded zones for the end of the imaging session to maximize data yield before the donor heads potentially degrade.
We do all clean bench mechanical work in our Austin lab, including head stack assembly transfers, platter cleaning, and helium refill. For the full head swap workflow, see the clicking drive procedure section above.
Gloved hand holding a six-slider head stack assembly with the preamp flex circuit visible, inspected before donor matching for a head swap
Repair vs recovery
Hard Drive Repair
Restoring the hard drive itself to a functional, reusable state. Not viable for mechanical failures because head damage, platter scoring, and motor seizure are permanent physical conditions. Spending hundreds to repair the hardware for reuse is not cost-effective.
Our process is Data Recovery. We perform temporary, surgical-grade repairs (like swapping read/write heads from a donor drive) just long enough to extract your data. Once the data is safe, we return it to you on a healthy, new drive.
We don't fix hard drives for reuse. We save the data inside them.
If a drive arrives clicking after a drop and we confirm failed heads on the bench, we open it on the clean bench and replace all read/write heads from a matched donor. Then we image it through PC-3000, using a head map to work around any degraded head. You get your data back on a healthy external drive.
A shop that offers to permanently repair a mechanically failed drive for continued use is conflating repair with recovery; the data should be moved to healthy media, not left on a drive with known physical damage. For more on what works and what does not, see our myths about freezer tricks, board swaps, and DIY platter exposure breakdown.
Clicking on a Seagate Barracuda does not identify the fault on its own. A head-stack failure, a PCB fault, and firmware corruption are separated at the bench, not by ear. Either way, no service visit makes a mechanically compromised drive reliable for reuse. Paying $1,200–$1,500 to fix the failed one for ongoing use isn't cost-effective, and a drive with known mechanical damage shouldn't carry your data going forward.
Firmware-side failures (ROM corruption, translator faults, lost adaptives) fall in the $600–$900 tier. Mechanical failures run $1,200–$1,500 plus donor cost. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. +$100 rush fee to move to the front of the queue.
Simple copies from a working drive: $100. Logical recovery (formatted, corrupted, or deleted): from $250. Firmware work: $600–$900.
Evaluation is free, you get a firm quote before any work starts, & there is no charge if we can't pull the data. For the full hard drive recovery price table, see our detailed breakdown. We have a separate page for each symptom: clicking, beeping, and not detected.
Component-level repair
Component-level repair is board-level diagnostic work on the hard drive PCB. We identify the ROM chip, dump it natively, and replace a shorted TVS diode. We do this work in-house.
The same microsoldering skill that fixes MacBook logic boards diagnoses an HDD PCB without guesswork.
The bridge between the two disciplines is the hard drive PCB itself. Every modern Seagate, Western Digital, and Toshiba drive carries unique adaptive parameters in its board ROM.
A donor PCB without the original ROM will not spin the drive past calibration because the adaptives are unique to the head stack that left the factory with that board. On boards with a discrete 8-pin SOIC ROM, we read it in place with a clip or take it off the board, dump it through a programmer, and write that image to the donor before the swap.
When the original PCB is intact but the SA module is corrupted, we use PC-3000 terminal access to rebuild the translator and rewrite the adaptive tables. On a Seagate F3 drive that means regenerating SysFile 28 (the primary translator) against the P-list and G-list to reconstruct the LBA-to-PBA map; on a Western Digital SMR drive it means regenerating Module 190 (the T2 translator) that controls shingled-zone mapping. PC-3000 talks to the drive in terminal mode, reads what survives, and patches what does not.
The 5V and 12V TVS diodes on a hard drive PCB are sacrificial. They short to ground when the rail spikes, which protects the controller and the motor driver IC but leaves the drive unable to power on. Replacement is straightforward board-level rework with the Hakko iron: confirm the short with a multimeter, lift the failed diode, install a matched part, verify the rail recovers under load.
We use the PC-3000 Portable III in terminal mode to rebuild the translator from the surviving G-list and P-list, and bring the drive ready long enough for the DeepSpar Disk Imager to clone the platters. The drive is then retired.
We do the board work in the same lab, on the same bench, with the same tools used for filmed MacBook board repairs. After the board work, we image the platters through PC-3000 and the DeepSpar Disk Imager in the same lab.
Failures
Physical failures (clicking heads, stuck platters, seized motors), firmware corruption, and logical failures (corrupted file systems, deleted files) each have their own recovery method. The failure type determines the recovery method and cost tier. The data is lost wherever a head crash abrades the magnetic coating off the platters.
Clicking hard drive →
A persistent click is a hardware fault, and we find the failed part on the bench. We stabilize firmware modules, select usable heads, and image conservatively. Brands: Seagate, Western Digital, Toshiba, HGST, etc.
Beeping drive →
Common on 2.5 inch Seagate/LaCie Seagate Rosewood models. A beeping external is most often not getting enough power, so rule out the cable, port and power supply first.
Drive not detected →
When heads contact spinning platters, they scrape the magnetic coating. Grinding noise means active damage. Turn off immediately. We swap the heads on the clean bench and image around the damaged zones.
Drive not spinning →
Logical and Mixed Failures
File system corruption →
Accidentally deleted files or formatted a conventional hard drive? If SMART is clean and reads are fast, DIY software is a reasonable first try. If reads slow or drop, stop and let us image with pro hardware before it degrades.
Bad sectors / SMART errors →
If SMART reports reallocated or pending sectors, the drive is physically degrading. We fast-pass good regions, then revisit weak areas with head-maps and conservative retries (DeepSpar/PC-3000).
RAID and NAS recovery →
Virtual machine disk recovery →
Need an NDA or chain of custody documentation?
Enterprise Services →
Time-Critical Data Emergency?
Emergency Services →
Important: Previously opened drives (home or retail attempts) arrive with contamination inside the sealed chamber. Dust, fingerprints, or misaligned head assemblies can turn a simple unstick into irreversible platter damage. If your data matters, do not open the HDA. Get it imaged on a 0.02 micron ULPA-filtered laminar clean bench.
Supported
We recover data from all major hard drive brands and form factors: Seagate, Western Digital, Toshiba, HGST, Samsung, Maxtor, and Fujitsu. Recovery covers Windows (NTFS), MacOS (APFS, HFS+), Linux (EXT4, XFS, Btrfs, ZFS), and server environments. We price external drives on the same tiers as bare drives.
Operating Systems
  • • MacOS (APFS, HFS+)
  • • Server / VMware (VMFS)
Computers
  • • Laptop hard drives (Dell, HP, Lenovo, ASUS)
  • • Apple MacBooks (Pro, Air)
  • • All-in-One PCs
External Drives
  • • WD Passport / Elements
  • • Seagate Backup Plus
  • • LaCie Rugged
Storage Types
  • • 3.5" Desktop HDD
  • • 2.5" Laptop HDD
  • • USB Flash & SD Cards
External Hard Drive Recovery
Shucked external drive PCB with thin wires soldered from the internal SATA test pads up to a SATA cable, bypassing the failing USB bridge board for imaging
External drive shucked: failing USB bridge bypassed, internal SATA wired to a SATA cable.
External hard drives use 2.5-inch or 3.5-inch drive mechanisms. Many sit behind a USB bridge board. Modern WD portables put the USB interface on the drive's own board. When a USB external drive fails, we rule out the bridge first. Where the drive has a SATA connector, we remove it, connect it directly to our PC-3000 via SATA, and diagnose the actual failure: firmware corruption, head damage, or motor seizure.
Common external drive models we recover include Seagate Backup Plus Slim (Rosewood ST2000LM007), WD My Passport (SMR-based WD20SMZW), LaCie Rugged, and G-Technology G-DRIVE. USB bridge bypass and internal SATA imaging on portable enclosures pricing follows the same five tiers as internal drives: $100–$2,000 depending on failure type.
The enclosure brand does not change the recovery goal, but it can change the extraction step. Seagate portables such as the Backup Plus Slim contain standard SATA drives that connect directly to PC-3000. Modern WD My Passport drives use native USB circuit boards with no SATA connector. We have to transfer the ROM to a SATA donor board before diagnostics can begin.
Pick the symptom that matches what your drive is doing and the page behind it covers that case. A drive that makes a noise it never used to make is a bench job, and the specific fault, including stiction, is established once the drive is open. Corrupted drives often have intact data on the platters despite an inaccessible file system.
What Common Hard Drive Problems
What Common Hard Drive Problems Do We Solve?
Four situations have their own pages: drops causing head damage, water or surge causing PCB failure, gradual read errors from media degradation, and firmware corruption from power interruptions. Each scenario has a different recovery procedure. The correct path depends on the failure type, not the drive capacity.
Click your situation for specific guidance.
Other situations: emergency recovery | SSD recovery | cost breakdown | how to choose a service | water damage recovery | fire damage recovery
Specific failure modes: stiction (heads stuck to platters) | motor seizure and bearing failure | firmware corruption symptoms | heat damage and thermal failure
How Does Recovery Approach Differ
Find Your Drive Family
Recovery approach varies by drive family. Match the model number on your drive label to find specific failure modes and repair procedures.
View all drive families → | WD Green recovery walkthrough (Part 1) and Part 2
Logistics
Shipping
Shipping
Mail-in
Real lab
AttributeReal lab (Austin, TX)Virtual-office pattern
Physical facilityOne in-house facility at 2410 San Antonio Street, Austin, TX 78705.Rented mail-drop or coworking suite; no bench, no equipment on site.
Staff at the addressData recovery technicians on staff in the same building as the drive.Receptionist or partner-shop clerk who hands the drive to a courier.
Imaging equipmentPC-3000 Portable III, PC-3000 Express, and DeepSpar Disk Imager owned and racked at the address.No imaging equipment at the listed address.
Open-drive environment0.02 micron ULPA-filtered laminar flow bench on site for head swaps and platter work.No clean bench at the listed address; the drive is sealed in a box and shipped.
Helium drive workHelium head swaps, donor matching, and helium refill performed in-house at the Austin lab.
Donor head matchingDonor library and head-stack matching performed in-house.Donor selection happens at an off-site facility the customer cannot inspect.
Number of hand-offsOne: customer to the Austin lab.Three or more: customer, mail-drop, courier, central lab, return courier.
Diagnostic feeNone. No data, no recovery fee.
  • What is the street address of the building where my drive will be opened, not the address where it will be received?
  • Which PC-3000 unit is on site at that address, and what is the serial number range?
  • Is the laminar flow bench at the same address, and what is its filter rating?
  • Will the technician who opens the drive speak with me directly, or only through a call center?
  • If I decline the quote, what fees apply to return shipping?
Before you ship
The most useful information: the model number from the drive label, the symptom (clicking, beeping, not detected), what happened before the failure (drop, surge, gradual slowdown), and whether anyone previously opened the drive or ran diagnostic software. If you only know the symptom, that is enough to start.
When you contact us for a free estimate, include whatever you know from the list below.
Drive Details
Failure Context
Clean room
No. We do open-drive work on a 0.02 micron ULPA-filtered laminar clean bench, and that covers the minutes the drive is open.
Cleanroom photography sells: technicians in full spacesuits inside a “certified ISO Class 5 clean room”. Clean room classifications are defined by ISO 14644-1, which specifies maximum allowable airborne particle concentrations.
For data recovery, that level of whole-room infrastructure is marketing theater, not a technical requirement. What actually protects your platters is a 0.02 micron ULPA-filtered laminar clean bench and an image-first workflow.
StandardMax Particles ≥0.5µm per m³Filtration LevelRequired For HDD Work?
ISO 14644-1 Class 53,520 particlesNot specified by the standardIndustry marketing standard
Our Laminar BenchNot a room classification0.02 µm ULPAWhere our open-drive work happens
Filter class is what our bench is specified on, and it is on the equipment list: a 0.02 micron ULPA-filtered laminar clean bench. That is a filtration rating for the air moving across the work surface, not a room classification, and the two are not the same measurement.
You only need clean air in the immediate work zone during the brief window when platters are exposed. A laminar bench provides that.
Handheld particle counter held in the airflow at the open work surface of the Austin lab clean bench
Particle counter in the filtered air column above the bench, before a drive is opened
Watch the particle counter run at the bench.
Bottom line: The heads do not see room air. They see the air column directly above the open chassis, and that is what a laminar bench controls. We publish which equipment does the work, we publish what each tier costs, and we film the bench. Ask any lab you are considering to do the same.
Why a Head Swap Does Not Need a Walk-In Cleanroom
Cleanroom photos are the industry's favourite trust signal, and they are a picture of a building rather than of the air over your platters. In this video Louis runs a particle counter at the laminar flow bench so you can watch the number the heads actually depend on.
Full article: ISO Class 5 cleanroom vs 0.02 micron ULPA laminar flow bench particle test results
Advanced failures
The failure mode dictates the recovery procedure. Generic "data recovery" approaches applied blindly to the wrong family can cause permanent data loss.
HDD PRML Read Channel Tuning
PC-3000 can retune a drive's read-channel adaptives, including the FIR equalizer taps and gain, to read data off degraded heads. For more on that, see our HDD PRML read channel tuning technical reference.
The drive can't answer the host's LBA questions because the map from LBA to shingled zone is broken.
Seagate publicly lists this consumer DM-SMR family:
VendorFamilyForm factorDocumented SMR models
SeagateBarraCuda3.5-inchST4000DM004, ST8000DM004
The recovery workflow doesn't look like a standard CMR translator rebuild. Here's the sequence we run instead:
  1. Connect the drive to the PC-3000 Portable III before any imaging attempt and apply a firmware-level write lock to the user area. Drive-managed SMR runs autonomous background garbage collection at the controller level whenever the drive is powered, and a SATA hardware write-blocker on the host cannot stop it. The firmware itself has to be commanded to halt media-cache flushes before the shingle bands are irreversibly overwritten.
  2. On the same PC-3000 session, attach to the drive's service-area terminal and read the firmware modules that hold the translator and the indirection table for that family.
  3. For drives where the translator module is unreachable through the standard service area, the heads have to be stabilized first. That can mean a head-stack transplant under the 0.02 micron ULPA-filtered laminar flow bench, followed by another attempt at service-area access.
  4. Once the imager has the cleanest possible sector dump, file-system reconstruction runs against the image, not against the original drive. The original drive is never the recovery target; the image is.
Seagate Rosewood: LED Errors, Stiction, and Media Cache Failures
The Rosewood platform (ST1000LM035, ST2000LM007) is Seagate's 2.5-inch slim portable drive.
One Rosewood failure is the LED error. When firmware corruption occurs, the drive outputs LED status codes such as LED:000000BD over the serial terminal instead of reaching the F3 T> command prompt.
Media cache corruption is another Rosewood failure. Rosewood drives use a media cache region on the platters to buffer writes before committing them to the final LBA locations. If power is lost during a cache flush, the mapping between cache sectors and their destination LBAs can become inconsistent.
PC-3000's Seagate module can read and reconstruct the media cache map, but only if the heads are stable enough to read the cache zone without further degradation.
Western Digital ships Device-Managed SMR (DMSMR) drives in its WD Blue line. SMR overlaps write tracks like shingles on a roof to increase areal density. The drive manages a translation layer that maps logical block addresses to physical locations across shingled zones.
SMR secondary translator damage from non-SMR repair: WD SMR drives have a secondary translator in addition to the primary one.
We use PC-3000's WD module with SMR-aware procedures that preserve both translator layers before any firmware manipulation begins.
One failure on these drives is Module 190 translator corruption.
The WD Ultrastar DC HC5xx series and above are helium, and so is the Seagate Exos X series. Air-filled enterprise drives come in separate sub-lines such as the Seagate Exos 7E8 and the WD Ultrastar DC HC310, HC320 and HC330. So capacity alone won't tell you whether an enterprise drive is hermetically sealed and filled with helium gas.
Helium has one-seventh the density of air, which reduces aerodynamic drag on the platters and lets manufacturers fit more platters into a standard 3.5-inch form factor.
Once a helium drive is opened, the factory helium charge escapes. The heads were designed to fly in helium's lower-density environment. In normal air, the increased drag changes the fly height, and the heads can contact the platters.
We open the patient drive on our 0.02µm ULPA-filtered clean bench, install the donor heads, and refill the drive with helium before connecting to PC-3000 for imaging. The helium refill restores the fly-height environment long enough to image the drive.
Mechanical helium drive failures require a hard drive recovery service with both the clean-bench tooling for head swaps and helium refill and the PC-3000 firmware expertise to handle multi-platter translator complexities.
Mechanical interventions, including helium drive recovery and clean-bench platter swaps, are performed under the no data, no recovery fee guarantee. The lab-wide aggregate rating is 4.9 stars across 1,837+ Google reviews.
Seagate's F3 firmware architecture arrived in the Barracuda 7200.11 era and is still used on modern drives such as Rosewood.
The 7200.11 was notorious for a firmware bug that bricked drives on power-up. Seagate issued a firmware patch for it.
The system area (also called the service area or SA) is a reserved region on the platters that stores the drive's operating firmware, defect lists (P-list and G-list), and SMART logs.
When the SA degrades due to weak heads or media defects in the service zone, the drive cannot load its operating firmware. It may spin up but fail to identify, or identify with a BSY (busy) state that never resolves.
To recover it, we have to use PC-3000's Seagate F3 utility to access the terminal, read whatever System Files remain, and rebuild the translator.
We back up the original SA before any modification.
Western Digital built its Palmer and Spyglass 2.5-inch drive families on Marvell architecture.
On boards that have a separate 8-pin ROM chip, we desolder the chip from the dead board and transfer it to the donor board.
WD My Passport external drives add another layer: hardware AES encryption, even when no password was ever set. A dead USB board does not take the key with it: the wrapped key sits in the drive's service area and can be read through a compatible SATA donor board.
If the USB board is destroyed, we recover the key material from the drive and decrypt the image with it.
Newer Spyglass-architecture drives use a native USB board with no separate bridge. The wrapped key still sits in the service area on the platters.
When the encryption board is damaged but the internal platters are intact, recovery depends on extracting the encryption key before imaging the user area. On older bridge-board models, PC-3000's WDC Marvell utility reads the key out of the drive's firmware module over a SATA connection. The key sits in Module 25 or Module 38, depending on the bridge chip. The utility then decrypts the user area in software while we image it.
On native USB Spyglass drives, which have no SATA interface, we move the ROM to a compatible SATA donor board to reach the firmware.
If we can't read the key material from the platters, the data stays AES-encrypted and there's no way to decrypt it.
Matching the model number alone is insufficient. The donor has to match on preamplifier revision, physical head map, and firmware microcode.
The adaptive parameters stored in the ROM are calibrated to the specific platter surfaces in each individual drive.
A head swap on a nine-platter drive means aligning 18 heads simultaneously in a single insertion. One bent head contacting a platter surface during installation will scratch the platter and destroy the data under that head. We use manufacturer-specific head comb tools sized for each family and perform the swap under our ULPA-filtered clean bench.
Drives protected by BitLocker, Apple FileVault, VeraCrypt, or LUKS add a decryption step after the physical recovery is complete. The mechanical stabilization (head swap, firmware repair, PCB transplant) happens first. Once the drive is stable and reading sectors, we image the raw encrypted volume with PC-3000.
During extraction, we decrypt the BitLocker volume from the sector-level image with the client's recovery key.
A Seagate PCB carries the MCU (microcontroller unit) and the motor controller. If the board has a separate 8-pin SPI flash ROM chip, that chip holds the bootstrap code and adaptive parameters.
That ROM chip is unique to each drive. During factory calibration, Seagate writes adaptive parameters specific to that individual head-platter combination.
Swap the PCB without transferring the ROM, & the donor board's firmware attempts to operate with calibration data written for a different physical drive.
When a Seagate PCB fails (shorted TVS diode, blown motor driver, corroded trace from liquid damage), we desolder the SPI Flash ROM chip from the dead board & transplant it to the donor PCB.
Translator Module Corruption & PC-3000 Rebuild Procedures
The translator is the firmware module that maps logical block addresses (the sector numbers your operating system reads) to physical locations on the platters.
When the translator corrupts, the drive may spin up & identify normally, but sector reads return wrong data, zeros, or errors. Your operating system sees a drive that exists but can't produce files.
On Seagate F3 drives, the translator lives in the service area as a group of System Files: the primary LBA-to-PBA map is SysFile 28 and the Non-Resident G-List is SysFile 35. Regenerating that map from the terminal recalculates it from the zone tables and the defect data, which is why the defect lists have to be readable before regeneration is attempted at all.
On Rosewood & newer Barracuda models with media cache, running translator regeneration blindly destroys pending cache entries: data queued for reallocation to its final LBA location is permanently lost. We back up all readable translator modules & media cache mapping tables via PC-3000 before any regeneration attempt.
To recover it, we lock the User Area first so background firmware writes can't destroy the damaged translator. Then we rebuild the second-level translator mapping from the saved module data.
SMR firmware cascade
On consumer SMR drives like WD Blue and Seagate Barracuda, a firmware fault can leave the translator and media cache out of step. Before any imaging begins, we lock the drive's background firmware processes on the PC-3000 Portable III.
SMR-Aware Intake Procedure With PC-3000 Portable III
On any drive we identify as device-managed SMR, the first thing we do is lock the user area against background firmware writes with PC-3000 Portable III firmware utilities.
With the user area locked, we read the translator structures into the PC-3000 module database: Module 190 on Western Digital SMR drives, and the Media Cache Management Table on Seagate SMR drives.
A device-managed SMR drive looks identical to a CMR drive from the host's point of view. So people plug it into a USB enclosure and run the same consumer recovery software they'd run on any other drive.
Model reliability data
Backblaze publishes quarterly drive-statistics reports on its own fleet. Here's each HDD model and the failure pattern on record for it. A documented issue does not mean a drive is unrecoverable, but it does change which failure modes we expect at intake.
ModelCapacityPrimary Failure ModeKnown Issues
ST12000NM000712TBPCB failure (Very common)Elevated Failure Rate
ST14000NM013814TBHead failure (Common)Elevated Failure Rate
ST12000NM000812TBHead failure (Occasional)Moderate Failure Rate
HGST HUH721212ALN60412TBHead failure (Common)Age-Related Failures
ST16000NM001G16TBHead failure (Rare)None documented
WDC WUH721816ALE6L416TBHead failure (Rare)None documented
WDC WUH721414ALE6L414TBHead failure (Rare)None documented
WDC WUH722222ALE6L422TBHead failure (Rare)None documented
TOSHIBA MG07ACA14TA14TBHead failure (Occasional)None documented
TOSHIBA MG08ACA16TA16TBHead failure (Occasional)None documented
TOSHIBA MG10ACA20TE20TBHead failure (Rare)None documented
HGST HMS5C4040BLE6404TBHead failure (Rare)None documented
A model's failure-rate reputation is a fleet observation, not a verdict on any individual drive.
We handle helium drives in-house. The WD and HGST Ultrastar He line (DC HC5xx and above) and the Seagate Exos X series are helium. The air-filled enterprise drives sit in separate sub-lines such as the Seagate Exos 7E8 and the WD Ultrastar DC HC310, HC320 and HC330. Capacity alone won't tell you which kind a drive is. In-house, we do the head stack transplant on the 0.02 micron ULPA-filtered clean bench, refill the helium before the platters spin, and image the drive after the swap through DeepSpar Disk Imager. Pricing for helium-sealed mechanical recovery is published at $200–$5,000+ depending on capacity and donor availability.
Turnaround at the Austin lab
Every recovery moves through four stages at our Austin lab: intake, firmware triage and imaging, mechanical or firmware diagnosis, and return shipping. Healthy donor head swaps take 4-8 weeks, while corrupted SMR translator recoveries take 3-6 weeks. A 100 dollar rush fee prioritizes your drive in the queue without rushing the bench procedure.
Drives arrive at the Austin storefront by mail or in person. The drive is queued for the imaging bench. Rush cases (+$100 rush fee to move to the front of the queue) move to the front of this queue.
Drives identified as device-managed SMR, or that present any sign of translator or service-area corruption, go to the PC-3000 Portable III bench first so that background garbage collection and media cache replay can be locked out before any host-side reads. Drives with a healthy translator and a mechanical or media defect profile move directly to the DeepSpar Disk Imager, which reads sector by sector with full control over command timeouts, retry counts, and head selection. If the drive is unstable, the imager pauses and the case moves to mechanical diagnosis.
Drives that fail to image cleanly move to one of two benches. The firmware bench runs PC-3000 Portable III against the drive's service area to read modules, terminal output, and ROM. The mechanical bench operates inside the 0.02 micron ULPA-filtered clean bench, with FLIR thermal cameras tracking PCB hot spots during pre-swap testing and Hakko FM-2032 stations used for any board-level work. Helium drives get their head swap on the same clean bench, and we refill them with helium before the platters spin. All of that work happens in-house at the Austin lab.
Firmware recoveries on CMR drives generally complete inside the 3-6 weeks window published for the firmware tier. Head swaps fall inside the 4-8 weeks window for the head-swap tier.
Stage 4: Verification, target media, return shipping
Verification before payment
Two tools do two different jobs, and customers conflate them. The DeepSpar Disk Imager & PC-3000 Portable III are imaging hardware; they pull a sector-level clone off the patient drive.
This is why the order matters. We image first on the DeepSpar Disk Imager, then mount the clone read-only and let file-system reconstruction run against the copy. If reconstruction stalls on a corrupt $MFT, we rebuild the metadata from the clone instead of hammering the failing drive for another read pass.
  1. Mount the cloned image read-only so the patient drive is never the working copy.
  2. Rebuild or parse the file system from the clone, not from the failing drive.
  3. Validate the partition geometry & directory tree structure before trusting the listing.
  4. Open representative files of each major type to confirm the file bodies, not just the directory entries.
  5. Produce the recovered file list for your review before final billing.
Single location, in-house, no partner lab ever sees the image. The verification stage is the part of a hard drive recovery service that DIY software has no analog for: it proves the data before money changes hands.
Clean-bench head swaps
Clean-Bench Head Swaps: ULPA Filtration and Donor Matching
A clean-bench head swap replaces a failed head stack assembly inside a 0.02 micron ULPA-filtered laminar flow bench. Donor selection requires matching the HSA by model family, firmware revision, and preamp silicon revision.
Head combs keep each slider off platter media during extraction and seating.
Technical depth on the procedure: what a head swap involves, step by step | cleanrooms vs laminar flow benches: filtration specifications | how donor drives are matched by family, firmware, and revision
The firmware that boots a modern hard drive is split between a small flash chip on the PCB and the firmware modules stored in the Service Area on the platters. The PCB ROM holds the bootstrap loader and the unique adaptive parameters calibrated to this specific drive’s heads at the factory. The Service Area on the platters holds the translator, the P-list (factory defects), the G-list (grown defects), and the SMART logs.
The drive spins up cleanly, makes no clicking, completes the BIOS handshake, and then reports either 0 bytes or a wrong capacity. The Logical Block Address to physical sector mapping is broken. The platters and heads are functional; only the translator module is unreadable or inconsistent.
The drive spins up and never returns a ready signal. It accepts no ATA commands.
On the PC-3000 Portable III, we back up the existing Service Area modules before any repair. Then we image the drive on the DeepSpar Disk Imager with short per-sector timeouts, so a bad read doesn't stall the drive.
On Seagate F3 platforms, the regeneration is invoked over the diagnostic UART serial port at the F3 terminal prompt.
Two situations force a ROM-level workflow. The first is a drive whose PCB is damaged badly enough that the original board cannot boot the spindle: a shorted TVS diode, a burned motor driver, or a cracked solder joint on the controller. The second is an architecture such as Western Digital where a generic donor PCB cannot drive the patient heads until the patient’s adaptive ROM contents are transferred onto the donor.
The extraction itself is component-level rework. The flash chip is desoldered under a microscope with a Hakko FM-2032 precision iron on an FM-203 or FX-951 base station or removed with an Atten 862 hot-air rework station with a shielded nozzle. We read the chip on a programmer and write its contents onto the donor board's ROM.
When a head swap is required, donor heads are transplanted on the 0.02 micron ULPA-filtered clean bench after donor matching against the patient drive’s site code, head map, and firmware revision. Because the donor heads carry their own physical impedance and flight characteristics, the original adaptives no longer track the platters accurately. PC-3000 can retune the read-channel adaptives, such as the FIR equalizer taps and gain, so the read channel resolves sectors with the donor heads in place.
SMART modules are a separate problem. On Seagate F3 drives, a corrupted SMART system file can stop the drive from initializing, which is one of the conditions behind LED:000000CC.
Enterprise helium-sealed drives such as Toshiba's MG08ACA and later helium models and equivalent high-capacity platforms from other vendors are hermetically filled with helium to reduce aerodynamic drag on the platters. Translator corruption, G-list overflow, and ROM faults on these drives are repaired with the PC-3000 Portable III without touching the hermetic seal. When a helium drive also has mechanical failure that requires a head swap, the drive is opened under the 0.02 micron ULPA-filtered clean bench at the Austin lab, then resealed and purged and refilled with helium through a calibrated manifold before the platters are ever spun, with helium refill, platter cleaning, and seal reassembly. Helium head swap, platter cleaning, and high-purity helium refill are performed entirely in-house at the Austin lab.
Mechanical work on helium drives uses the helium tier from $200–$5,000+, with +$100 rush fee to move to the front of the queue available for cases that need to skip the standard queue. Non-helium mechanical recoveries fall under the HDD tier published at $100–$2,000. No diagnostic fee applies in either case; if the data is not recovered, there is no recovery fee.
PCB & Microsoldering Bridge
The same component-level diagnostic work we run on MacBook logic boards is the foundation of our hard drive PCB recovery: schematic-driven rail probing, hot-air rework, & SOIC-8 SPI flash extraction under magnification. We pull adaptive ROM data from a dead HDD PCB & migrate it onto a donor board.
A dead HDD PCB can start with a shorted TVS diode on the 5V or 12V rail, a cracked main controller, or a burned spindle driver. Those are board-repair faults, not data-recovery faults; they get isolated under the stereo microscope before any firmware work begins. When we have to go around the controller, we desolder the SOIC-8 SPI flash that holds the per-head adaptive set with the Atten 862 and read it in an external programmer. Then we either reflow it onto a matched donor PCB with the Hakko FM-2032 or keep it as the patient's ROM of record for SA work.
A straight donor PCB swap fails on every modern hard drive, even when the silkscreen board number matches. The reason is that the adaptive parameters, per-head preamp gain, channel coefficients, microjog offsets, & thermal fly-height control values, are unique to the head stack that left the factory in that chassis. Modern PMR read/write heads hold an active magnetic spacing of about 1 to 2 nanometers over a few nanometers of baseline clearance. If the donor PCB drives the patient heads with the wrong calibration, the drive can't initialize its heads. The actual procedure is ROM transfer first (or, on WD, the ROM copies kept in the Service Area when the chip is cracked), then the donor PCB, then translator work on a PC-3000.
Even with the ROM in the right place, a healthy PCB only buys SATA identification. A drive with a corrupted translator still reports 0-byte capacity, a factory alias, or hangs in BSY because the firmware can't map LBA requests to physical sectors. From there the work moves to the PC-3000 Express. We back up the SA modules, upload the loader (LDR) into controller RAM, and then regenerate the translator. The procedural detail of that workflow is documented in our PC-3000 procedure reference.
On a modern hard drive, the actual job is board-repair work followed by firmware reconstruction. PCB diagnostics, ROM extraction, & SA / translator rebuilds all fall in our Firmware Repair tier at $600–$900 (CMR drive: $600. SMR drive: $900.) with 3-6 weeks turnaround. We do that work at the same Austin bench where we do our MacBook logic-board work.
A degrading read head loses signal-to-noise margin before failing outright. Operating system retries keep that head loaded over the damaged region while the drive's internal error recovery grinds on each sector. DeepSpar Disk Imager controls reads at the ATA command layer, limiting destructive retry loops before a donor head swap is required.
A hard drive's read channel shapes the analog signal off the heads with an FIR equalizer and decodes it with a Partial-Response Maximum-Likelihood (PRML) detector, using per-head adaptive values from the drive's firmware. A failing head does not produce garbage right away: more and more reads need retries before they succeed.
The DeepSpar Disk Imager is the hardware we use to do that extraction. It operates as an independent host bus adapter on the bench, bypasses the host BIOS and operating system, and controls every read at the ATA command layer.
Firmware Retry Loops Grind a Damaged Head Over a Damaged Surface
When an operating system asks a drive to read a marginal sector, the drive's firmware initiates its internal error-recovery routine. It retries the read again and again, and it can keep working a single sector long past the point where a host would have given up. Through all of it, the damaged head stays loaded over the surface that already failed to read once, applying thermal and mechanical stress to the actuator and heads.
This is the destructive failure mode that kills marginal drives in consumer tools. On a drive that is already shedding debris, every additional pass over the damaged zone risks scoring the platter further.
The reliable fix is to keep the internal retry loop from running at all: abort the read quickly, log the sector for a later pass, and move on. That is what DeepSpar does.
DeepSpar Imaging Parameters for a Marginal Drive
DeepSpar Disk Imager controls every read at the ATA command level, which lets us tune the following parameters per drive and per imaging phase. The settings below are starting points; actual values are adjusted by the technician based on how the patient behaves on the bench.
  • Read timeout in milliseconds. If the drive does not return the sector within the configured window, DeepSpar aborts the read. The sector is logged as bad, and the imager advances.
  • Hardware PHY reset and COMRESET. When a drive hangs mid-read, DeepSpar issues a COMRESET or hardware power-cycle to unfreeze the SATA link.
  • Variable read block size. The initial pass uses large multi-sector blocks to maximize throughput on healthy zones. When an error is detected, the imager returns to that block in a later pass with the block size dropped to 1 sector, which isolates the bad LBAs without discarding the healthy sectors that surround them.
  • Background auto-relocation disabled. DeepSpar commands the drive to suppress the firmware's internal reallocation of sectors flagged as weak. Auto-relocation writes to the service area. It also eats spindle time.
  • Healthy heads first. The imager pulls all data mapped to healthy heads before it attempts the degraded head, which means the bulk of the drive is safely cloned before the weak head is ever used.
Every one of these settings is aimed at the same goal: pull the maximum amount of data off the drive while giving the damaged heads and platters the minimum amount of work.
DeepSpar multi-pass imaging is what makes that triage possible. With auto-relocation turned off, the drive doesn't write to the service area during imaging and doesn't add new G-list entries we'd have to clear later. Because the head map tells DeepSpar to use healthy heads first, the weak head is only engaged for the sectors no other head can cover. We run the targeted retry pass on the weak head before we consider a swap.
When the weak-head pass stops producing new sectors, we move to a donor head swap on the 0.02 micron ULPA-filtered clean bench and reimage only the LBAs mapped to that head. That's how a drive that would otherwise go straight to a mechanical quote can sometimes finish imaging.
PC-3000 SA firmware repair
PC-3000 SA firmware repair rebuilds the translator module that maps logical block addresses to physical platter sectors. On WD SMR drives, Module 190 controls the T2 translator architecture that manages shingled-zone mapping. On Seagate F3 drives, the equivalent translator rebuild runs through direct PCB TX/RX pad access at 38400 baud, where the Media Cache Management Table governs whether that rebuild is survivable at all.
ROM extraction transfers the 8-pin SPI flash ROM from the patient PCB to a family-matched donor before any power is applied. That ROM holds microjog offsets, thermal fly-height values, and per-head channel tuning written at the factory. A donor board without that ROM cannot initialize the drive. On WD drives, PC-3000 can rebuild the ROM contents from the copies kept in the Service Area on the platters.
SA defect lists, the G-list and P-list, map bad sectors so the drive routes read and write operations around them.
More detail on each layer: what PC-3000 actually does, module by module | how hard drive firmware works: SA, ROM, translator, and adaptive parameters | hard drive firmware corruption: symptoms, causes, and recovery path | WD SMR translator failure: Module 190 and T2 architecture
Case examples
What Do HDD Failure Modes Look Like On The Bench?
Hard drive recovery starts by classifying the failure before any file work begins. That classification comes from SMART data, how the drive behaves under controlled imaging, and direct inspection once the chamber is open. Each path from there uses different PC-3000, DeepSpar, clean-bench, and donor-matching steps.
Seagate ST2000LM007
Beeping after drop
If an external drive beeps, check the power first: cable, port and supply. If it still beeps on a known-good supply, we find the failed part on the bench.
$600–$900 to $1,200–$1,500
Watch the procedure →
Clicking on startup
Watch process →
Not detected after surge
If the PCB is dead but the HDA is healthy, ROM and adaptive data are extracted or transferred to a compatible donor board before SATA imaging begins.
Opened Before Intake
Contamination after uncontrolled opening
$1,200–$1,500 to $2,000
Watch clean-bench work →
Head swap recovery
Watch head swap case →
Green light, no detection
Watch the workflow →
Helium drive extraction
Helium drive extraction requires breaching the hermetic seal, installing a donor HSA before any spin-up attempt, resealing the chassis, and purging and refilling it with high-purity helium through a calibrated manifold. Helium is roughly one-seventh the density of air, so a chamber left full of atmospheric air alters the aerodynamic lift the sliders were designed around, and spinning the platters in that state risks head-platter contact.
SMART Attribute 22 (0x16) reports helium level on WD and HGST helium drives. Seagate Exos helium drives expose internal environmental telemetry through the F3 diagnostic terminal on the PCB TX/RX pads, which we read before any spin-up attempt on a drive suspected of seal compromise.
Toshiba's MG07ACA, MG08ACA and MG09ACA helium drives use Attributes 23 and 24 instead of Attribute 22. Current flagship helium designs pack up to nine platters and 18 heads into the standard 3.5-inch chassis. Breached-lid staging on the ULPA clean bench requires head-comb alignment fixtures matched to the specific platter spacing of each geometry. We do all mechanical work, including lid reseal and helium refill, in-house at the Austin lab. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
Helium drive data recovery: full tier table and supported models | Seagate Exos 10TB failure modes and recovery procedure | Toshiba MG08 failure: Attribute 23 telemetry and bench staging
Evidence locker
Evidence Locker
Watch recovery
Watch Our Engineers Work
We film our recoveries so you can see the tools and procedures before sending your drive.
We believe in total transparency. That is why we film our work. Watch Louis Rossmann and the team perform real data recovery procedures, such as head swaps, so you know what happens to your drive.
Callout
Not sure what failed? Send the model number, symptoms, and any sounds the drive makes.
Send Drive Details →
DIY check
Sometimes. If the drive spins normally and reads, you can safely image it with ddrescue before attempting file recovery. If the drive clicks or grinds, stop. A beeping external drive is most often short on power, so rule out the cable, port and power supply first. Running CHKDSK or recovery software on a mechanically failing drive forces endless read retries that wear out weak heads and can score the platters.
Safe to Try at Home
  • ✓Try a different cable or port. Test with a known-good SATA or USB cable before assuming the drive is dead.
  • ✓Check Disk Management (Windows) or Disk Utility (Mac). On Windows, if the drive's partition shows up with no drive letter, assigning one in Disk Management can be all it needs.
  • ✓Use ddrescue to clone a readable drive. If the drive spins normally and reads, you can safely image it with our free ddrescue guide before attempting file recovery.
Do NOT Do This
  • ✗Do not open the hard drive. Exposing platters to unfiltered air introduces particles that cause permanent scratches.
  • ✗Do not put it in the freezer. The freezer trick is a myth that puts condensation inside the drive, which can crash the heads and short the board.
  • ✗Do not run CHKDSK or Disk Utility on a clicking/beeping drive. These tools force endless read retries that wear out weak heads and can score the platters.
  • ✗Do not keep power-cycling a failing drive. If it clicks persistently or grinds, power it off.
When to Call a Professional
When contacting a hard drive recovery service, describe the exact sound the drive makes, the event that preceded the failure (drop, surge, or gradual slowdown), and whether anyone has previously opened the drive or run diagnostic software on it.
Is Hard Drive Data Recovery
That depends on what is on the drive. If the files are irreplaceable (family photos, business records, legal documents, research data), the value of recovery exceeds the cost. Our pricing starts at $250 for partition recovery and $1,200–$1,500 for a head swap on a standard hard drive. A free evaluation determines whether recovery is viable before any work begins.
Standard hard drive pricing ranges from $100–$2,000. A corrupted partition recovery starts at $250. A head swap costs $1,200–$1,500. Before committing, you get a free evaluation and a firm quote. We do not start work until you approve the price. If we can't recover your data, there's no recovery fee under our no data, no fee guarantee.
You pay nothing to find out whether recovery is possible, and you only pay if we deliver your files. Our standard hard drive head-swap tier is $1,200–$1,500, and you see that price before you ship.
Failure-Mode Procedures
The procedures below cover mechanical failure modes, firmware and PCB electronics, platter and head media recovery, brand and model specific procedures, and helium-filled drive recovery in the Austin lab.
The sub-procedures below cover each category in technical detail, linking to dedicated write-ups for each symptom, component, platform, and brand we handle in the Austin lab.
Mechanical Failure Modes
Head stack and spindle cases arrive under several symptom names: clicking, grinding, beeping, and drives that will not spin. Physical trauma cases include dropped drives, crashed drives, water damage, and thermal damage. Spindle and bearing work covers motor failure, stiction, and ambiguous noises that do not clearly fit one category. When the failure is electrical rather than mechanical, a power surge event often leaves the platters untouched. Direct platter-contact events are documented in our head crash recovery write-up, along with procedural references for what a head swap involves and what happens during a head crash.
Firmware and PCB Electronics
Firmware and electronics failures present without obvious mechanical noise. The PCB component reference explains the MCU, ROM chip, TVS diodes, and motor controller, while how hard drive firmware works covers translator modules, defect lists, and the System Area architecture. Component-level repair techniques overlap with MacBook logic board work, documented in PCB diagnostics vs. logic board repair. Symptom-side entry points for firmware and electronics cases include SMART error escalation, drives that do not appear in BIOS, RAW or corrupted file systems, firmware corruption with BSY or 0 GB symptoms, and growing bad sector counts. Board-only failures that leave the platters intact are covered in our PCB failure recovery procedure, where ROM transfer rather than a blind board swap preserves the drive's adaptive calibration.
Platter and Head Media Recovery
Media-side work is where clean-bench discipline matters most. The reference on how hard drive platters store data explains the magnetic grain layer that every recovery is built to preserve, and how hard drive heads work covers the voice coil actuator, slider aerodynamics, and preamp chip the head stack depends on. Successful head swaps require strict donor compatibility, documented in how donor drives are matched. For a filmed clean-bench platter transfer onto a donor spindle, with head-comb removal and the imaging pass that followed, see the hard drive platter swap lab video.
Brand and Model Specific Procedures
Each manufacturer uses different firmware architectures and requires different PC-3000 modules. Dedicated procedures exist for Seagate, Western Digital, Toshiba, and Hitachi and HGST drives. Within the Seagate lineup, the 2.5-inch Rosewood platform and external Backup Plus and Expansion drives have their own common failure modes. Specific enterprise failure patterns are documented for the Seagate Exos ST10000NM and the Toshiba MG08 16TB. Recording-technology differences between CMR and SMR drives change firmware repair complexity and are handled at different tier pricing.
Helium-Filled Drive Recovery
An opened helium drive has to be refilled with helium before its platters spin again, because its heads are calibrated to fly in helium, not air. For helium drive data recovery, we do head swaps with helium refill, firmware service area repair, and PCB component-level work in-house on the helium models of the WD Ultrastar, Seagate Exos, and Toshiba MG lines. The work is performed in-house at the Austin lab under the no data, no recovery fee guarantee. Environmental controls and head-stack handling are documented through the lab's clean-bench platter swap procedures. Lab-wide customer feedback aggregates to 4.9 stars across 1,837+ Google reviews.
A healthy-sounding drive that reports the wrong capacity or hangs Busy can have a corrupted Service Area. Repair runs on the PC-3000 Portable III using vendor-specific interfaces: UART for Seagate F3 and SATA commands for WD Marvell.
The repair workflow uses vendor-specific ATA commands routed through the PC-3000 Portable III rather than any host-OS storage driver. For a longer description of how hard drive firmware works end-to-end, and a separate page on what PC-3000 actually does at the hardware level, see the linked technical references.
The Service Area is a reserved set of tracks on the platters that no host operating system can see. It holds the drive's on-platter firmware: the translator, the defect lists, adaptive calibration values for each physical head, vendor housekeeping flags, and on Seagate SMR drives the Media Cache Management Table. When the drive powers on, the controller executes a small bootstrap loader from an SPI flash ROM on the PCB, reads the Service Area, and loads the remaining firmware modules into controller RAM before announcing itself on the ATA bus.
When any of these on-platter modules fail to load, the drive either hangs in a Busy state, reports a capacity of zero, returns a factory default model alias such as "WDC ROM MODEL", or accepts ATA Identify but returns zeros across the full LBA range.
Seagate F3 drives organize firmware as numbered System Files, accessed through the F3 T> diagnostic prompt. Western Digital organizes its firmware as numbered Modules under the ROYL architecture. The table below lists the critical identifiers we read or patch during a typical SA repair.
FunctionSeagate F3 SysFileWD Marvell Module
Configuration / background flagsConfig SysFile in the Service AreaModule 02
Factory defect map (P-list)SysFile 1BP-list inside Module set
Primary LBA translatorSysFile 28Resident translator
Grown defect list (G-list)SysFile 35 (Non-Resident G-List)G-list in the Service Area
Adaptive parameters and microjog offsetsRAP, CAP and SAP adaptives in the PCB ROMModule 47
Media Cache Management TableMCMTModule 190 (T2 translator on SMR)
The translator answers a simple question for every read: given an LBA from the host, which physical track, head, and sector holds the data. When SysFile 28 or the WD resident translator gets corrupted, that mapping is gone, and the host sees zero capacity or an Identify failure.
On legacy Seagate F3 drives the rebuild recalculates the primary translator from the zone tables and the defect data. That is why the defect lists have to read back cleanly before regeneration is attempted at all.
Translator regeneration is catastrophic on shingled drives in the Rosewood family if issued against the platter. The act of regenerating the translator wipes the Media Cache Management Table, and any user data still queued in the conventional cache zone waiting to be shingled is orphaned.
  • Microjog corrections for off-track positioning
  • FIR equalizer tap coefficients
The right way is to desolder the original SPI flash ROM and reflow it onto the donor, or extract the ROM contents on a programmer and write them to the donor board's ROM.
Two failure classes look superficially similar from the host side, but the repair paths are entirely different. Firmware corruption is logical; head-stack degradation is mechanical.
Firmware corruption
Drive spins up smoothly and holds a steady rotational velocity. It either fails the ATA Identify handshake, reports zero capacity, identifies under a factory alias such as "WDC ROM MODEL", or hangs in a Busy state with LED:000000CC (Init SMART Fail / corrupted-translator condition) visible on the diagnostic terminal.
Head-stack degradation
Drive may spin, but the actuator fails to lock onto servo tracks and slams the ramp stops. Reads that do complete are slow and throw uncorrectable read errors.
A simple copy from a working drive takes 3-5 business days. Firmware repairs take 3-6 weeks. Head swaps that need donor parts take 4-8 weeks. Severe platter damage takes 4-8 weeks and may be unrecoverable.
Your device stays inside our Austin lab. We do not claim compliance certifications that are not documented in our canonical business records.
Yes. If you do not power it on wet, do not bake it with heat, and get it to the lab quickly, the odds are better. Salt water is worse than fresh water; fire cases usually include corrosive residue from suppression. Once in-lab, we address PCB corrosion or shorts, transfer ROM adaptives when required, and image with controlled timeouts.
What is hard drive recovery?
Yes. Hard drive recovery, hard disk recovery, and hard drive data recovery all describe the same goal: extracting files from a failing or failed HDD. Sometimes people mean DIY software on a drive that still works, but a clicking or undetected disk needs clean-bench head work or PC-3000 firmware repair, not software. We retire the original drive after imaging it.
Can a hard drive be repaired?
Repairing a hard drive is only worth it if you need the data stored on it. Replacing the failed hardware is cheaper than repairing it for reuse. However, if the drive contains irreplaceable files, paying for professional data recovery ($100–$2,000 depending on failure type) is the practical form of hard drive repair. You pay for the data extraction, not for making the old drive work again. We evaluate the drive for free and tell you whether recovery is possible before you're charged anything. Under our no-data-no-fee guarantee, if we can't recover your files, there's no recovery fee.
On an external drive, a beep most often means the drive is not getting enough power, so try another cable, port and power supply once. If it still beeps, power it down and leave it down. Repeated power-on attempts can turn a recoverable drive into an unrecoverable one. We establish which fault is responsible on the bench, from SMART data, how the drive behaves under controlled imaging, and inspection once it is open. Power-cycling, tapping the drive, opening the HDA, or running repair utilities can scratch platters and turn a $1,200–$1,500 head swap into a $2,000 surface-damage case.
A beeping LaCie external is most often not getting enough power, so try another cable, port and power supply once. If it still beeps, unplug it and stop retrying it. We remove the drive from the enclosure and diagnose it on the bench rather than from the enclosure's behaviour. Do not power-cycle, tap, or open the drive; those moves can turn a $1,200–$1,500 head swap into a $2,000 surface-damage case.
If the drive still spins and is detected, you can try the free SystemRescue + ddrescue method: clone the drive to an equal-or-larger target, then recover from the clone. Do a fast pass to grab good sectors, then a retry pass for bad areas. Do not run CHKDSK/Disk Utility repairs on the original. If it clicks/beeps or isn't detected, stop.
No. Under the Magnuson-Moss Warranty Act (15 U.S.C. 2302, full text at law.cornell.edu), a manufacturer cannot void your warranty simply because you used an independent service provider. The burden of proof is on the manufacturer; they must demonstrate that the independent repair caused the specific defect they are refusing to cover.
Turnaround depends on the failure type. A simple copy takes 3-5 business days. File system recovery takes 2-4 weeks. Firmware repairs take 3-6 weeks. Head swaps take 4-8 weeks, because we have to source a matching donor drive. Rush: +$100 rush fee to move to the front of the queue. We provide status updates throughout.
Yes. Software like Recuva or Disk Drill is safe for logical failures (deleted files, corruption). If your drive clicks or grinds, software can't help and repeated attempts may worsen the damage. Send it in.
We recover drives other shops gave up on. Opening a drive outside a clean environment introduces contamination, which makes recovery harder but not always impossible. We'll look at it and tell you what we can recover. Send it for a free evaluation.
Yes, if it's a hard drive that doesn't support TRIM. On those drives, a 'quick format' only erases the file system index, and your data stays on the platters until new files overwrite it. We clone the drive first with PC-3000/DeepSpar, then carve files from the raw image. Success depends on how much new data was written after formatting. If you accidentally formatted a drive, stop using it immediately and contact us.
Yes. 'Dead' typically means a PCB failure, seized motor, stuck heads, or firmware corruption. Stop powering the drive and ship it for evaluation.
Yes. The clicking sound (sometimes called 'click of death') occurs when the drive cannot lock onto the servo tracks on the platter surface. Servo tracks are pre-written positioning data embedded in each platter during manufacturing; they guide the heads to the correct cylinder. Several faults break that: physical shock from a dropped drive, age-related head degradation, preamplifier failure, Service Area firmware the drive cannot read, and a board carrying adaptive parameters that do not belong to the head stack. The bench separates them before anything is opened. We stabilize access using PC-3000, create a head map to disable failing heads while imaging from healthy heads, and use controlled retry parameters to recover sectors in weak zones. Where the heads themselves are damaged, we perform an exact-match donor head swap on our 0.02 micron ULPA-filtered laminar clean bench. Recovery success depends on whether the platters were scored before the drive was powered off. The sooner you stop powering a clicking drive, the better the recovery odds.
Yes. External hard drives (WD Passport, Seagate Backup Plus, LaCie Rugged, G-Technology) contain regular HDDs or SSDs inside a USB enclosure. Where the enclosure holds a standard SATA drive behind a removable USB bridge, we take the drive out and connect it directly. Modern WD My Passport drives have the USB interface built into the drive's own board. Many WD enclosures also encrypt at the bridge. Those take a different path. Once we've got the drive connected, we recover it the same way as an internal drive: logical, firmware, or mechanical repair, depending on the failure. Common external drive failures include dropped drives, beeping 2.5-inch Seagates, and PCB damage from power surges.
First, try a different cable and USB/SATA port. Check Disk Management (Windows) or Disk Utility (Mac) to see if the drive appears without a drive letter. If the drive spins but isn't detected, it's likely a firmware or PCB issue. If the drive doesn't spin at all, it could be a seized motor, stuck heads, or dead PCB. Do not run CHKDSK or repair utilities on an undetected drive. If basic troubleshooting doesn't help, power it off and contact us for a free evaluation.
Yes. Barracuda desktop drives develop firmware issues, head failures, and bad sector growth. We handle Barracuda failure modes with PC-3000: firmware repair for drives not detected, head swaps for clicking drives, and sector-level imaging for degraded media.
WD My Passport drives are 2.5-inch portable drives that commonly fail from drops and cable yanks. Recent models use hardware encryption even when no password was ever set, and modern boards integrate the USB interface and encryption engine into a single native-USB PCB, so a bare drive read over SATA shows only encrypted data. The wrapped Data Encryption Key is stored redundantly in the drive's firmware Service Area; we extract it with PC-3000 and decrypt the imaged data even when the original board is dead. Older My Passport models without encryption are more straightforward: we remove the drive from the enclosure and image via SATA. Common failures include stuck heads from drops.
Toshiba drives carry their own firmware architecture, and firmware work on them runs on PC-3000 like any other family. Some Canvio models, such as the MQ04UBB400, are native-USB drives with no SATA connector. On a Toshiba, the hard part is finding donors for the less common models.
Yes. Hitachi/HGST drives are now part of Western Digital, and we handle their firmware with PC-3000.
We repair Samsung firmware on the PC-3000 and stock compatible donors for head swaps. Samsung exited the HDD market in 2011 (Seagate bought the division), but Samsung SpinPoint drives are still common in older systems. If your Samsung drive clicks or isn't detected, it's likely a firmware or head issue.
We maintain a small Maxtor donor inventory for head swaps on these aging drives. Maxtor was acquired by Seagate in 2006, but Maxtor drives still show up in old NAS units or desktop PCs from the mid-2000s. Recovery success depends on how badly the platters have degraded.
WD Elements are budget external drives. Common failures: dropped drives with stuck/damaged heads, USB port damage, and age-related bad sector growth. If your Elements drive clicks after a drop, stop powering it. We find out whether the heads are damaged at the lab.
Yes. LaCie externals (Rugged, d2, Mobile Drive) contain Seagate mechanisms since Seagate acquired LaCie in 2012. We treat these as Seagate recoveries: remove from enclosure, diagnose via SATA, and apply standard Seagate recovery procedures. LaCie Rugged RAID models require RAID reconstruction after individual drive recovery.
Yes. If the drive was running when dropped, the heads may have scored the platters, which reduces recovery chances. The critical factor: do NOT power the drive on after a drop if it makes unusual sounds. Every power cycle with damaged heads risks platter scoring. Ship it to us unpowered for a free evaluation.
Yes. Power surges typically damage the PCB (printed circuit board) and sometimes the preamplifier inside the head assembly. Recovery involves transplanting the ROM chip (containing drive-specific calibration data) from the damaged PCB to a matching donor PCB, or using PC-3000 to read and rewrite the ROM adaptives. If the surge also damaged the heads or preamplifier, a head swap may be needed.
A drive that won't spin has either a seized spindle motor, stuck heads preventing rotation, or a dead PCB. We diagnose it electrically on the bench. When we free stuck heads on the clean bench and keep the original heads, that falls in the $600–$900 tier. Seized motors and platter damage usually fall in the $2,000 tier. Dead PCB cases may require firmware or file-system recovery work depending on whether the drive can be stabilized. The platters hold your data regardless of why the motor isn't spinning.
It depends on the extent of the damage. Severe scoring from prolonged operation with damaged heads: the recoverable portion drops sharply. Circular scoring (ring of death): data in the scored zone is typically unrecoverable, but data on undamaged tracks can be saved. The earlier you stop powering a clicking drive, the less platter damage accumulates.
A head crash occurs when the read/write heads physically contact the spinning platter surface, scraping off the magnetic coating that stores data. This creates visible circular scoring and metallic debris inside the drive. Recovery depends on severity. If the drive ran for hours with crashed heads, scoring can be extensive. We perform head swaps on our clean bench, clean debris from the platters using specialized techniques, and image conservatively to recover as much data as possible.
Yes, depending on temperature exposure. Water from fire suppression systems causes PCB corrosion, connector oxidation, and head contamination. We clean and inspect fire-damaged drives on our clean bench, transplant ROM chips to donor PCBs, and image the platters.
Yes. We use PC-3000 and DeepSpar to image the drive with controlled read retries, timeouts, and head disabling to work around bad areas. A drive with a growing bad sector zone may indicate degrading heads, in which case we image aggressively before the heads fail completely. Do not run CHKDSK or fsck on a drive with growing bad sectors.
It depends on the encryption type. Hardware-encrypted drives (WD My Passport): we can recover data even when the USB board has failed, since the wrapped encryption key is stored redundantly in the drive's firmware Service Area. We extract the key and decrypt the imaged drive. Software-encrypted drives (BitLocker, FileVault, VeraCrypt): we can recover the encrypted volume, but you need the password or recovery key to decrypt it. We cannot bypass encryption without the key. Full-disk encryption with a working key: we image the drive, then you decrypt the image. The encryption itself doesn't affect our ability to recover the raw data; it's the decryption step that requires your key.
No. Professional data recovery restores the hardware's ability to read sectors from the platters. It does not break AES encryption. BitLocker defaults to AES-128 (configurable to AES-256 via Group Policy). VeraCrypt and LUKS support AES-256. All encrypt the volume at the block level. Without the user's password or recovery key, the sectors we image contain ciphertext that cannot be decrypted by any lab. We can deliver the raw encrypted image, but extracting usable files requires your key. If you have the key, we decrypt the volume during extraction and return your files in the clear.
PC-3000 is professional data recovery hardware and software manufactured by ACE Lab. PC-3000 talks directly to a hard drive's firmware through vendor-specific terminal commands (Seagate F3, WD ATA). It can repair corrupted service area structures, extract and rewrite ROM data, disable failing heads via head maps, and control read timeouts at the sector level. We use the PC-3000 Portable III and PC-3000 Portable PRO along with DeepSpar Disk Imager for controlled sector-level imaging with configurable retry and timeout parameters.
We recover from all common file systems: NTFS and FAT32 (Windows), HFS+ and APFS (Mac), ext2/ext3/ext4 and XFS (Linux), UFS (FreeBSD), and ZFS. We also handle RAID-specific file systems and NAS configurations (Synology, QNAP, TrueNAS). We image the raw drive first (bypassing the file system entirely), then reconstruct files from the image. Even if the file system is completely destroyed, file carving can recover documents, photos, and videos based on file signatures.
Firmware corruption causes a drive to not be detected, misidentify its capacity, or refuse to read data. Hard drive firmware is microcode stored in a reserved area on the platters called the Service Area (SA), plus a small ROM chip on the PCB. The SA contains dozens of modules that control how the drive operates: the translator module maps logical block addresses (LBAs) to physical head/cylinder locations, adaptive parameters store per-head calibration data, and the P-list/G-list track defective sectors. Common causes include power loss during a firmware update, bad sector growth encroaching into the SA tracks, and age-related magnetic degradation of the service area. PC-3000 communicates with drives at the firmware level through vendor-specific terminal protocols (Seagate F3, WD ATA commands) to read, repair, and rewrite these modules.
Why is a Seagate F3 translator regeneration dangerous on newer drives?
Translator regeneration rebuilds a Seagate drive's LBA-to-physical map from scratch through the F3 terminal. On older pre-cache drives (7200.11, 7200.12) that is a viable repair when the heads can still read the service zone. On Rosewood and newer Barracuda models with media cache it is not: running a generic regeneration command on a drive showing media-cache exception codes wipes the Media Cache Management Table (MCMT), and data queued in the media cache for reallocation to its final LBA location is permanently destroyed. A drive that was a recoverable firmware case becomes a permanent data loss. We back up all readable System Files and media cache mapping tables via PC-3000 before any regeneration attempt. If you found a terminal command on a forum, do not run it without knowing whether your specific drive family uses media cache.
Yes, but CHKDSK and Disk Utility can make recovery harder. These tools make write operations to 'repair' the file system: they rebuild directory entries and sometimes move data. On a physically failing drive, the scan forces repeated read retries over damaged sectors, which exhausts weak heads and can score the platters. On a logically corrupted drive, CHKDSK may orphan files or overwrite directory structures. But prevention is better: never run repair tools on a drive with suspected physical issues. Clone first, repair the clone.
Our free evaluation includes: (1) We inspect the outside of the drive for damage. (2) We inspect the PCB for burnt components or corrosion. (3) We listen for mechanical sounds like clicking or grinding. (4) If it's safe, we connect the drive to PC-3000 for firmware-level diagnosis. (5) We work out the failure type: logical, firmware, or mechanical. (6) We give you a firm price quote for recovery. We don't attempt recovery during the evaluation. We diagnose first and quote a fixed price. You approve before any chargeable work begins. If we determine recovery is unlikely to succeed, we'll tell you honestly rather than charge for an attempt.
Wrap the drive in anti-static bubble wrap or an anti-static bag. Place it in a box with at least 2 inches of padding on all sides (foam or bubble wrap). Do NOT use packing peanuts alone; the drive can shift and impact the box walls. Mark the box 'FRAGILE' and use a tracked shipping method (USPS Priority, UPS, FedEx). Include a note with your name, email, phone, and a description of the problem. Customers pay shipping to the lab and are billed for return shipping. Ship to: Rossmann Repair Group, 2410 San Antonio Street, Austin, TX 78705.
Yes. +$100 rush fee to move to the front of the queue. Rush availability depends on current lab workload and the complexity of your case. Firmware and logical recoveries are easiest to rush; head swaps requiring specific donor sourcing may have minimum lead times regardless of priority level.
Your drive stays in our Austin lab.
Level 1 is logical recovery: the drive works physically, but data is lost from deletion, formatting, or corruption. Level 2 is firmware recovery: the drive spins but is not detected or reports the wrong identity, requiring PC-3000 work before imaging. Level 3 is mechanical recovery: stuck or failed heads, a seized motor, or surface damage requiring donor parts and clean-bench work. Our HDD pricing uses 5 published tiers from $100.
You don't pay. Our no-data-no-charge policy means if we cannot recover your target files, there is no charge for the recovery attempt. We provide a file listing before delivery so you can verify we recovered what you need. We eat the cost of technician time and clean bench work on unsuccessful cases. We bill you for return shipping.
Questions to ask any local shop: Do you have PC-3000 equipment? Do you do head swaps in-house? Can I speak to the technician? We do all work in-house in Austin with PC-3000 Portable III and a 0.02 micron ULPA-filtered clean bench. Customers pay shipping to the lab and are billed for return shipping.
Does Rossmann publish hard drive recovery prices before intake?
Magnetic data on hard drive platters can persist for decades under proper storage conditions (cool, dry, away from strong magnetic fields). Modern platters typically use cobalt-based alloys (such as CoCrPt) with high coercivity suitable for perpendicular magnetic recording, meaning the magnetic orientation that encodes data resists change from external fields or thermal fluctuation. The practical risk is mechanical degradation. If you have an old drive you need data from, don't power it on. Send it for professional evaluation.
A grinding noise means severe mechanical failure: something inside the drive is in physical contact that should not be. The documented causes are head-platter contact, debris circulating inside the sealed enclosure, and a failing spindle bearing, and only bench inspection separates them. Power off immediately and do not power it on again. If the heads are on the platters, data is being removed with every rotation, so the drive gets powered off first either way. This is a clean bench case. Ship the drive to us unpowered with padding.
Yes. Mac HDDs use HFS+ or APFS file systems, both of which we support. Fusion Drives combine a hard drive with another storage device into a single logical volume. We image the HDD component and reconstruct the Fusion volume when the companion device is available. For older Macs without T2, the HDD recovery process is the same whether the drive came from a Mac or PC.
Yes. IDE (PATA) drives from the early 2000s and earlier use a 40-pin parallel interface instead of modern SATA. The PC-3000 Express handles PATA drives directly. Common IDE drive brands: Maxtor DiamondMax, Western Digital Caviar, Seagate Barracuda ATA, IBM/Hitachi Deskstar. Age is the biggest challenge; these drives may have dried bearing lubricant and brittle head assemblies. Donor availability is limited for rare models. If you have an old IDE drive, don't power it on without professional evaluation.
HDD data recovery means dealing with mechanical and firmware failures in spinning-platter drives. We replace heads, extract ROMs, and rebuild translator modules with PC-3000 Portable III or PC-3000 Express. The lab goal is to stabilize the hard drive long enough to image the platters, rebuild the file system from the clone, and retire the failed disk. HDD recovery pricing runs $100–$2,000. Solid-state recovery uses a different workflow and belongs on the SSD service page.
Hard drive data recovery costs $100–$2,000 across 5 published tiers. A simple data copy from a working drive is $100. File system recovery is From $250. Firmware repair is $600–$900. Clicking or beeping drives that need a donor head swap on our clean bench are $1,200–$1,500. Platter surface damage is $2,000. Every recovery starts with a free evaluation and a firm quote. If we can't recover your data, there's no recovery fee.
No. Hard drive data recovery prices for external drives follow the same $100–$2,000 tier structure as internal drives. An external drive is a 2.5-inch or 3.5-inch mechanism inside a USB enclosure. On some models, such as modern WD My Passport drives, the USB interface is built into the drive's own board. If only the enclosure electronics failed and the internal drive is healthy, the recovery falls into the lower tiers. If the drive was dropped while running and the heads were damaged, it usually needs $1,200–$1,500 clean-bench work. Some external drives add bridge-board encryption, which can add diagnostic complexity without changing the failure-tier model.
Recovering data from a clicking hard drive usually falls into the $1,200–$1,500 tier. A clicking drive has a hardware fault, and we find out which component failed at the lab. When the heads have failed, we have to open the drive on a laminar-flow clean bench, remove the failed head stack assembly, and install matched donor heads from a compatible drive with the same firmware revision and head map. The donor drive is consumed in this process. After the head swap, we image the drive through PC-3000 using head maps to route around weak or damaged heads. If the clicking drive ran for an extended period before being powered off, the heads may have scored the platters, pushing the case into the $2,000 platter damage tier.
Each hard drive is factory-calibrated to the specific head stack assembly installed during manufacturing. The drive writes adaptive parameters (fly height offsets, write current per head, servo tuning) to its system area. A donor drive with the same model number but a different firmware revision, head count, platter count, or manufacturing site will have different calibration data. After a head swap, the donor heads read the patient drive's stored parameters and attempt to operate with calibration values written for a different physical head stack. A close match minimizes this calibration gap. We match on parameters including model family, firmware revision, head count, platter count, and manufacturing site code; which ones have to line up depends on the exact drive.
No. A head swap requires a particle-free environment, manufacturer-specific ESD-safe head combs, and PC-3000 firmware tools. Modern read/write heads fly a few nanometers above the platter surface. Opening the drive outside a ULPA-filtered laminar flow bench introduces airborne particles that act as microscopic abrasives, destroying the heads and gouging the platters when the drive spins up.
A clicking drive has a hardware fault, and a new PCB will not fix damaged heads. Separately, even when the PCB itself is the problem (shorted TVS diode, damaged motor driver), swapping boards requires transferring the ROM chip from the original PCB to the donor. The ROM stores factory-calibrated adaptive parameters unique to the internal head stack and motor. A donor PCB without the original ROM will power the drive but fail to read data because the calibration values do not match the installed components.
Professional data recovery labs don't charge per gigabyte. The cost is determined by the failure type and the equipment required to fix it, not by how much data is on the platters. Repairing a corrupted translator table falls in the $600–$900 firmware tier. A head swap on our 0.02 micron ULPA-filtered clean bench falls in the $1,200–$1,500 tier because donor parts and bench time drive the cost. Our 5 published tiers run $100–$2,000 based on failure severity: simple copy, file system recovery, firmware repair, head swap, or surface damage. For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra.
Seagate data recovery costs $100–$2,000 depending on the failure mode, not the specific model. Firmware repairs requiring PC-3000 F3 terminal access to patch corrupted Service Area SysFiles fall in the $600–$900 tier. A donor head swap places the recovery in the $1,200–$1,500 tier because the donor drive is consumed. Seagate Exos and IronWolf drives use the same pricing tiers; helium-filled mechanisms have separate helium costs when the sealed chamber must be opened.
Laptop hard drive recovery costs $100–$2,000 using the same 5 tiers as desktop drives. If the laptop was dropped while the drive was spinning, the read/write heads likely crashed into the platters. That impact bypasses the $100 and From $250 logical tiers and requires a $1,200–$1,500 donor head swap on our clean bench. If the heads scored the platter surface during the crash, the case escalates to the $2,000 surface damage tier. Laptops that sat on a desk and stopped being recognized usually have firmware corruption ($600–$900) or file system damage (From $250).
Retail stores can sometimes help with simple logical problems when a drive is healthy enough to mount. Physical HDD failures are different. Clicking, grinding, no-spin, firmware faults, and bad-sector growth need lab imaging, PC-3000 access, donor parts, or clean-bench work. Running recovery software on a mechanically failing drive in a retail environment risks permanent platter damage before the drive reaches a qualified lab.
They are different problems with different outcomes, and the bench separates them rather than the ear. Stiction means the read/write sliders are bonded to the platter surface after the drive parked outside its ramp, so the platters never come up to speed. We handle those on the 0.02 micron ULPA-filtered clean bench. We open the drive, lift the heads back onto the ramp with a comb, and reattempt spin-up before imaging. A head crash means a head has already contacted spinning media at speed, which shows up under magnification as scoring and as metallic debris inside the sealed chamber. Crashed drives require a donor head stack and frequently escalate to the $2,000 surface damage tier because debris must be removed before re-imaging. A <a href="/symptoms/clicking-hard-drive">clicking</a> drive is not automatically either one; we power it down and diagnose it before deciding.
ddrescue and the <a href="/pc-3000-data-recovery-tool">PC-3000 Portable III</a> serve different drives. GNU ddrescue runs over standard SATA on a host machine and reads sectors in a forward-then-reverse pass, retrying bad sectors with a logfile so the imaging session is resumable. It works fine on drives that still respond to ATA commands and have a healthy ready-state, which is roughly the $100 simple copy and From $250 file system recovery tiers. We need the PC-3000 once the drive misbehaves at the firmware level: stuck busy after ID, translator corruption, slow responder, head map mismatches, or G-list overflow. ddrescue can't disable a failing head, and PC-3000 can. That's why we image firmware repair and head swap cases ($600–$900 to $1,200–$1,500) on PC-3000, with the DeepSpar Disk Imager as backstop.
Each hard drive's board carries a serial flash ROM with boot code and calibration data unique to that drive, including head-specific adaptive parameters. A stock donor board's ROM describes a different drive, so the drive does not initialize. We move the original ROM to the donor board, either by transplanting the 8-pin chip or by reading its contents and writing them to the donor's chip. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
<a href="/services/helium-drive-data-recovery">Helium hard drives</a> (Seagate Exos X-series, WD Ultrastar DC HC5xx and above, Toshiba MG09ACA) are factory-sealed and filled with helium, which lets them hold up to nine platters. The heads are tuned for helium's low density, so we never spin the drive in air. Air pushes the heads out of their fly-height window and into the platters. We do the head and platter work on our 0.02 micron ULPA-filtered clean bench with the platter stack left clamped in place. Then we purge the chamber, refill it with high-purity helium before the platters spin, and image the data to new media. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber. We do all of it in-house at the Austin lab.
Yes, but the order of operations is non-negotiable: image first, decrypt second. <a href="/services/encrypted-data-recovery">BitLocker-encrypted drives</a> require a complete sector-accurate image because the Full Volume Encryption Key is wrapped in keying material spread across the volume header and key-protector slots. BitLocker writes multiple redundant copies of the FVEK metadata region at distinct offsets across the volume; if unrecovered sectors damage every copy, the volume becomes undecryptable even when most of the disk is readable. We image the drive's raw sectors on PC-3000, with bad-sector retry policies tuned for the failing head. Then we mount the image read-only and decrypt the volume with the 48-digit recovery key you supply or a domain-controller key escrow file. We do not bypass BitLocker; we cannot recover an encrypted drive without the recovery key or a recovery agent certificate. Bring the recovery key or the Microsoft account it was backed up to when you ship the drive; recovery is impossible without it.
On a striped array, one member cannot be recovered in isolation because the file system spans every member. RAID 5 stripes user data across N-1 drives and parity across the Nth, rotating per stripe; RAID 6 adds a second parity (P+Q Reed-Solomon syndromes); RAID 10 mirrors striped pairs. Pulling one drive and imaging it yields fragments of files. We require all members of the array shipped together, image each drive on PC-3000, then rebuild the virtual array in <a href="/services/raid-data-recovery">our RAID recovery workflow</a> using professional RAID reconstruction software. The reconstruction needs the original stripe size, the disk order (which slot held which physical drive), the parity rotation direction (HP SmartArray uses delayed parity), and whether the array was degraded before the second failure. Never let a hardware controller rebuild onto a freshly inserted disk after a multi-member failure.
Shingled Magnetic Recording (SMR) drives are harder because the on-disk translator is more complex than a conventional CMR drive. SMR overlaps adjacent write tracks like roof shingles; a sustained write workload triggers the drive to rewrite entire shingled bands (typically 15 to 40 MiB each), destaging data from a CMR-formatted media cache zone to the shingled main area, updating an internal translation table that maps host LBAs to physical band positions. CMR drives have no such complication. Their LBA-to-track mapping is one-to-one after factory remapping. SMR (Shingled Magnetic Recording) drives require more work at the firmware and head-swap tiers due to their overlapping track architecture.
Modern Western Digital My Passport drives have the USB interface built into the drive's own board, so there is no SATA connector to plug into a PC-3000 or DeepSpar. My Book desktop drives put a separate bridge board over a SATA drive. Most of them encrypt at the bridge even when no password was set, so a bare drive reads as ciphertext. A dead WD USB board does not lose the key: the wrapped key sits in the drive's Service Area, and we read the drive through a compatible SATA donor board and decrypt the image. Ship the original enclosure and board with the drive anyway.
On Seagate F3 drives, the failure can trace to SysFile 28, the primary translator, or to the Media Cache Management Table. On Western Digital SMR drives, it can trace to the second-level translator in Service Area Module 190. We repair the translator on the PC-3000 before imaging. We never put the drive itself back into service.
No. Modern hard drive PCBs carry an 8-pin SPI flash ROM that stores boot code and calibration data unique to that drive, including head-specific adaptive parameters and servo calibration tables. A donor board without that ROM does not match the head stack inside, so the drive fails to initialize. We move the original ROM to the donor board, either by transplanting the chip or by reading its contents and writing them to the donor's chip. Then we validate it on the PC-3000 Portable III before we power the drive. PCB symptoms can also come from a shorted TVS diode or a burned motor controller, which is why we check the board with a FLIR thermal camera and measure its rails before reaching for the ROM.
No. File-recovery apps such as EaseUS Data Recovery Wizard, Disk Drill, Stellar, and R-Studio read the drive through the operating system storage driver using standard ATA block reads. They scan file-system metadata and carve files by signature, which assumes the mechanics are healthy: the drive must spin up, achieve servo lock, initialize its service area, and report correct capacity. A clicking drive meets none of those preconditions, so a deep scan either stalls on read timeouts or the drive drops offline mid-scan. A full-surface deep scan requests every LBA in sequence. That drags the failing head across every track and turns localized damage into rotational scoring. While the drive's firmware retries each failed read, the scan stalls and the drive keeps grinding. Disk-repair utilities such as CHKDSK and SpinRite are more dangerous still, because they write. CHKDSK /f fixes errors by writing to the volume, and /r adds a scan for bad sectors. SpinRite hammers weak sectors with repeated read and write cycles to force reallocation. Hardware imagers like the DeepSpar Disk Imager and PC-3000 instead talk to the drive at the SATA PHY layer below the OS, disable native long retries and read-look-ahead, use millisecond-level read timeouts, issue a COMRESET or controlled power-cycle on a busy hang, and build a RAM head map so a failing head can be excluded while healthy heads image first. Power the drive off and have it imaged on the right hardware before any software touches it.
A drive that spins up to full speed but clicks is usually failing in the read path or the servo loop, not in the spindle motor. After the platters reach speed, the heads have to read the embedded servo wedges to find out where they are on the surface. When a head is degraded, the preamplifier is weak, or the servo adaptive parameters in the Service Area are corrupted, that positioning read fails. The drive responds by sweeping the actuator arm back to the parking ramp to recalibrate and tries again, and the arm hitting the ramp end-stop is the click you hear. It repeats the cycle indefinitely, which is the pattern people call the click of death. Continued power cycles only give a marginal head more chances to score the surface. The drive should be imaged on a hardware imager that can build a head map and exclude the failing head before any further spin-ups.
HAMR (heat-assisted magnetic recording, used in Seagate's Mozaic 3+ platform) writes each bit by briefly laser-heating a high-coercivity media layer so it can be flipped, then letting it cool and lock in. Because of that, every read/write head carries an integrated nanophotonic laser and a plasmonic writer, not just a magnetic transducer. A donor head stack has to come from the exact same HAMR model family; a standard PMR or helium-PMR donor head is structurally incompatible and will not fly or write. Mechanical recovery on these drives is highly constrained. We evaluate each HAMR case individually and give an honest assessment before we quote.
Yes. Helium drives such as WD Ultrastar DC HC5xx and above, HGST He-series, Seagate Exos X-series, and Toshiba MG08ACA and later MG helium models are sealed at the factory with a laser-welded hermetic seal. A partial leak does not shatter platters; it raises the internal gas density, which pushes each slider off its firmware-calibrated fly height and produces escalating read instability, rising reallocated and pending sector counts, and read errors that worsen over time. Modern helium drives monitor gas integrity and report a helium-level value through SMART, so a leak is not silent. A recovery lab cannot recreate the factory laser-welded seal. Once the chamber is opened or leaking, we can only restore aerodynamic lift temporarily by purging and refilling with high-purity helium through a calibrated manifold inside the 0.02 micron ULPA-filtered clean bench, image the data to new media, and retire the patient drive. All helium work is performed in-house at the Austin lab. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
The read/write channel lives inside the main controller. A degrading head usually shows localized, head-specific symptoms: clicking, one head reading while others fail, sector instability confined to certain surfaces, or weak signal on specific heads. A failing read/write channel or controller shows global symptoms instead: the drive will not initialize its firmware, it fails the ATA identify handshake the same way regardless of which head is selected, or it reads garbage uniformly across every head. We confirm by building a head map on the PC-3000, comparing per-head error patterns, and checking whether the drive reaches a ready state at all.
Multi-bay USB enclosures, docks, & JBOD towers hold several drives in one rigid frame, so every neighbor's seeks & spindle imbalance transmit rotational vibration through the shared chassis. That vibration pushes the read/write head off-track, the servo's Position Error Signal climbs, & the drive answers with read retries, throughput collapse, random disconnects, & rising reallocated or pending sector counts. We image the drive on its own, on a PC-3000 Portable III or DeepSpar Disk Imager. If the instability clears off the shaking enclosure, the heads were sound & we image the full surface; if per-head errors persist in a still fixture, the vibration already wore a head or the servo adaptives & the drive moves to clean-bench diagnosis. HDD recovery runs $100–$2,000 depending on what we find, all in-house at the Austin lab.
These guides cover when DIY imaging is safe, when professional recovery is necessary, and how to evaluate a data recovery service before sending your drive. Start with the symptom checker or the DIY guide if your drive still spins. If it clicks, grinds, or is not detected, skip to the professional service guide.
Research your options before making a decision.
Where Do We Serve Hard
Where Do We Serve Hard Drive Recovery Customers?
Hard Drive Data Recovery Topic Hubs
Symptom Diagnosis
Read what a noise or behavior can mean before you ship. We find out what failed on the bench.
Mechanical & Physical Failure
Physical damage cases that require clean bench work, donor parts, or motor transplants.
Drive Family & Model Recovery
Brand and model pages covering the firmware quirks, head-stack revisions, and translator behaviors specific to each manufacturer.
Lab Procedures & Technical Reference
How the clean bench work is performed: tools, donor matching, firmware areas, and chain-of-custody.
Sources & References
We cite Backblaze drive reliability data, ACE Lab PC-3000 documentation, DeepSpar Disk Imager documentation, federal warranty law, and the ISO 14644-1 cleanroom standard.
  1. Backblaze Hard Drive Stats: Annualized failure rate data from Backblaze's production fleet. Model-level reliability observations referenced for general manufacturer trends.
  2. ACE Lab PC-3000 Portable III: Manufacturer specifications referenced for tool capabilities.
  3. DeepSpar Disk Imager: Sector-level imaging tool with controlled retry and timeout features.
  4. Magnuson-Moss Warranty Act (15 U.S.C. 2302): Federal law referenced regarding independent repair and warranty rights. Manufacturers cannot void warranty for using an independent service provider.
  5. ISO 14644-1:2015: ISO 14644-1 Class 5 (formerly Fed Std 209E Class 100), referenced in the clean bench comparison table.
  6. Our own pricing on this page is generated from src/lib/pricing/hdd-pricing.ts, the single source of truth for every published tier.
