MacBook Data Recovery and Logic Board Repair in Austin
We do data recovery from soldered SSDs, component-level logic board repair, and liquid damage work on MacBooks. We replace the failed chip on your logic board instead of swapping the entire board. Austin, TX lab with nationwide mail-in.
We do not replace MacBook screens, batteries, keyboards, or trackpads. Our effort is going into data recovery and forensic work, and those parts jobs are not part of it.
If it's not worth fixing, we'll tell you. If you need a screen, a battery, or a keyboard, we'll tell you where to go instead. Why we stopped replacing screens.
MacBook logic board repair with microsoldering tools at Rossmann Repair Group Austin lab
Section 1
Founded in 2008
No Fix = No Fee
Component-Level Board Repair
All Work In-House in Austin
What MacBook Customers Say
My story isn't much different than anyone else on here leaving a Rossmann review, but I feel compelled to write all this anyway. After importing 14GB of RAW photos from my brand new camera to my 13" MBP (A2338), I started to excitedly sift through my gorgeous sunset photos in Lightroom. After 5 minutes of editing, my MacBook died. Wouldn't turn on, wouldn't charge, wouldn't make any sound. It's always been well taken care of and I was dumbfounded as to why this happened. Absolutely clueless as to what to do next, I took it to the "Genius Bar".
Joseph Tischner
MacBook
I used their mail-in service and followed their simple instructions on how to send it it. First fill out a form, then you get a ticket number and write it down and put it in the box you ship the device in. Few days later from delivery I got an email indicating diagnosis was beginning.
Josue Montalvo
MacBook
I had a MacBook Air which was dead because of logic board failure, I took it to apple store only to realize that it would take minimum 500$ to repair excluding tax and labor. I was horrified and found Rossman by god's grace on youtube. I sent my laptop and got it repaired with a fair price.
Charan
MacBook Air
My MacBook Pro (A1990) bricked and would not turn back on. I had years of family photos and important documents that were not backup up. Panicking, I first tried bringing my laptop to the local UBreakIFix.
MP Bankz
MacBook Pro
What This Lab Does on a MacBook
On T2 and Apple Silicon MacBooks the storage is soldered to the logic board. The board is the only route to your files, which makes board repair and data recovery the same work here, done with different goals.
Apple replaces entire assemblies. If a single capacitor fails on your logic board, Apple swaps the whole board; on Apple Silicon machines, that board contains the CPU, GPU, RAM, and SSD, so the swap takes your files with it. Their quote for that swap is set per model through the Apple repair estimator and scales with the original configuration. We find the failed component and replace it; component-level repairs are priced per model after evaluation.
If you have been quoted a board replacement and your files are on that board, ask what happens to them before you approve it. That is the point where machines get sent to us. We recover that data.
We do not replace MacBook screens, batteries, keyboards, or trackpads. This shop is becoming a forensic data recovery lab, and swapping a display assembly or a top case is not part of that. For work we decline, we will tell you where it is done well.
We replace the failed chip, not the whole board. Repairs are priced per model after evaluation.
No Fix, No Fee
If we cannot repair it, you pay nothing. Mail-in: return shipping only.
T2 and Apple Silicon Macs with soldered SSDs. The files are on the logic board, so the board is where we work.
Nationwide Mail-In
Ship from anywhere in the US. All repairs handled in our Austin lab.
Liquid Damage Repair
Ultrasonic cleaning and component replacement. Priced per model after evaluation.
Honest Assessment
We will tell you if the repair doesn't make financial sense, and where to go for the work we no longer take.
Supported MacBook Models
MacBook Pro
13", 14", 15", 16" Models
Unibody, Retina, Touch Bar
A1278 through M3 Max
MacBook Air
11", 13", 15" Models
Legacy and Retina Display
M1, M2, M3 Chips
Apple Silicon
M1, M1 Pro/Max/Ultra
M2, M2 Pro/Max
M3 Family
We also service older and Vintage models. Contact us if you're unsure.
MacBook Repairs We Handle
Logic Board, Data Recovery, and Liquid Damage
MacBook not turning on
Power circuit failures, bad capacitors, failed power ICs. We diagnose with schematics and replace the specific failed component.
Liquid damage repair →
Ultrasonic cleaning, corrosion removal, component replacement. Power off the machine and bring it in as soon as possible; every power-on attempt after liquid exposure causes additional corrosion.
No backlight / dim screen
Backlight circuit repair. Often a failed fuse, filter, or driver IC. We fix the circuit on the logic board rather than replacing the display.
Data recovery from soldered SSDs →
T2 and Apple Silicon MacBooks have storage soldered to the logic board. Apple does not recover data from these machines. We do.
Not charging
USB-C port issues, charging IC failures, battery connector problems. We trace the circuit and fix what failed.
Work We No Longer Take
Screens
We do not replace MacBook displays. The panel supply that made that work honest closed years ago, and what is left is not worth selling. Why we stopped replacing screens.
Batteries
We do not replace MacBook batteries. A swollen one is still worth knowing about, because it deforms the case and pushes up against the trackpad from underneath, but the swap itself is not our work.
Keyboards and trackpads
We do not replace keyboards, top cases, or trackpads. On most MacBooks the keyboard and battery are bonded into one top case assembly, which makes this a parts job rather than a bench job.
Where to send that work instead
CompuPLUS on North Lamar in Austin does displays, batteries, and general Apple service.
Liquid damage? Do not put your MacBook in rice. Do not keep trying to turn it on. Power it off and bring it to us. Every power-on attempt after liquid exposure causes more corrosion and component damage.
Why We Stopped Replacing MacBook Screens
This business started in 2009 replacing broken MacBook displays. We bought new, Grade A LCD panels from LG and Samsung brokers, replaced only the broken LCD cell, and reused the rest of the display assembly. That kept part costs low and meant we could offer screen repairs at a fraction of Apple's price. The customer got a new panel, not a used one. We took pride in that.
That supply chain no longer exists. Apple has closed off LCD panel sales to independent repair shops. The standalone LCD panels still available for modern MacBooks are factory rejects with visible defects; dead pixels, discoloration, backlight bleed that we would not put into a customer's machine. We tried. The quality is not acceptable.
For current-generation MacBooks, the only quality option is a used display assembly pulled from another machine. These assemblies include parts you don't need (back cover, hinges, webcam, antenna cables), which raises the cost. The display will be used, not new.
So we stopped. We do not replace MacBook screens anymore. Fitting a used display assembly pulled off somebody else's machine, and charging real money for it, is not a job worth selling. If a display is what you need, CompuPLUS on North Lamar in Austin does that work, and we would rather send you there than take the job.
What stayed here is logic board repair, liquid damage recovery, and data recovery. That work needs a microscope, a soldering iron and schematics, not a parts order. Batteries, keyboards and trackpads are parts orders, which is why they went the same way as screens.
Work we don't do
Work We Don't Do
This is a data recovery lab. The bench here runs drive imaging, head stack and platter work under a clean bench, firmware and service area repair, NAND and controller work on SSDs, and board-level microsoldering on MacBook logic boards and iPhone boards. That is the whole scope.
We do not replace MacBook screens, batteries, keyboards, or trackpads, and we do not do general PC service. Those are parts jobs. A shop that does them every day will do them faster and cheaper than we would, and our effort is going into data recovery and forensic work instead. We would rather send you there than take the job.
If that is what you need in Austin, go to CompuPLUS on North Lamar. They handle Windows and Apple service, screen replacement, liquid damage, network installation, and general electronics repair, and they publicly list us as the lab they work with on the Austin repair side. We send general repair customers to them, and we keep the recovery and board-level work here.
CompuPLUS
5555 N Lamar Blvd, Ste C-122, Austin, TX 78751
(512) 240-2606
compuplus.shop
Call them for hours before you drive over. If they open your machine and find a failed drive with data on it that matters, that part comes back to us.
MacBook Repair Pricing
These are the three jobs we take on a MacBook. Your exact quote comes after our free diagnosis. No fix, no fee.
Logic Board Repair
Component-level repair for power, charging, backlight, and other board failures. We replace the failed chip, not the whole board.
T2/M1/M2/M3 MacBooks with soldered storage. We read the drive through the board it is soldered to.
$325-$600
Liquid Damage
Rossmann vs. Apple Pricing
Apple quotes out-of-warranty repairs per model through its repair estimator (support.apple.com/mac/repair); check your model there for the current number. Apple Store diagnosis is free. Our diagnosis is free.
Repair TypeRossmannAppleNotes
Logic board repairPriced per model after evaluationFull board swap; quoted by modelWe replace the failed component. Apple replaces the entire board.
Liquid damagePriced per model after evaluationQuoted by modelWe clean the board and replace the corroded parts on it.
Data recovery (soldered SSD)$325-$600Ask themThe storage is soldered to the board. Replace the board and the data goes with the old one.
DiagnosisFreeFree at Apple StoreAASPs may charge a diagnostic fee, often credited toward repair.
Displays, batteries, keyboards and trackpads are missing from this table because we do not do them. Check your model in Apple's estimator for their current number, and ask them directly what they can do about data on a soldered drive.
Our Repair Process
Our Repair Process
Free Diagnosis
Bring it in or mail it. We diagnose the issue at no charge and provide a firm quote. If Apple is the better deal, we tell you.
Approval
You approve the quote. If you decline, you pay nothing. Mail-in: return shipping only.
Repair
We fix the failed component. Board-level microsoldering, not whole-assembly swaps.
4
Testing and Return
Full functional testing, then pickup or shipped back to you.
Related Services
MacBook Repair FAQ
MacBook Repair FAQ
How much does MacBook repair cost?
It depends on the work. Logic board repair, liquid damage repair, and data recovery from a soldered SSD are each priced per model after evaluation. We provide a free evaluation and quote before any work begins, and you pay nothing if we cannot fix it. We do not replace screens, batteries, keyboards, or trackpads, so those are not quoted here at all.
Can you fix a MacBook that won't turn on?
Yes. MacBooks that won't power on are one of our most common repairs. Typical causes include power circuit failures, liquid damage, bad batteries, or failed ICs on the logic board. We diagnose with board-level inspection, find the specific failed component, and replace that component rather than swapping the entire logic board.
Do you repair liquid-damaged MacBooks?
Yes. We ultrasonically clean the logic board, find the corroded components, and replace what failed instead of replacing the board. Liquid damage repairs are priced per model after evaluation. Power the machine off and get it to us quickly; corrosion keeps spreading while current flows, and every attempt to turn it back on makes the repair bigger.
How long does MacBook repair take?
Logic board repairs typically take 2-5 business days depending on complexity and parts availability. Data recovery from a soldered SSD depends on what failed on the board and how much of it has to be rebuilt before the storage will read. We give you a timeline after diagnosis.
Is it worth repairing an old MacBook?
For logic board issues, often yes. A 2017-2019 MacBook Pro that needs a component-level board repair still has years of usable life. We will tell you if repair costs don't make financial sense for your specific model. That assessment is free.
Do you offer mail-in MacBook repair?
Yes. We accept mail-in repairs from all 50 states. Ship your MacBook to our Austin, TX lab. We diagnose and quote, then repair and return it. Our mail-in guide has full shipping instructions.
How does your pricing compare to Apple's?
It depends on the work. For logic board issues, we are typically less expensive than Apple because we repair the failed component rather than replacing the entire board. For liquid damage, our repairs are priced per model after evaluation. For data recovery, ask Apple what they can do for your specific machine and compare; we do not speak for them, and what they offer is not ours to describe. For displays, batteries, keyboards, and trackpads there is nothing to compare, because we stopped doing that work.
Do you replace MacBook screens?
No. This shop started in 2009 doing MacBook displays, buying new Grade A LCD panels from brokers and replacing only the broken LCD cell. Apple closed off that supply chain. The standalone panels still sold for modern MacBooks are factory rejects with dead pixels and backlight bleed we will not install, and the only quality option left is a used display assembly pulled off somebody else's machine at a price that lands near Apple's. That is not work worth selling, so we stopped selling it. CompuPLUS on North Lamar in Austin does display work.
Can you recover data from a dead MacBook?
Yes. That is most of the MacBook work here now. On T2 and Apple Silicon MacBooks the SSD is soldered to the logic board, so your files sit on the board itself and a board replacement takes them with it. We repair the board you already have and read the storage that is on it.
Do you replace MacBook batteries, keyboards, or trackpads?
No. None of those are repairs we take anymore. On most MacBooks the keyboard and battery are bonded into one top case assembly, which makes them a parts job rather than a bench job, and our bench time is going into data recovery and board-level work instead. CompuPLUS on North Lamar in Austin handles that work. If a spill or a failed circuit on the logic board is what is actually behind the symptom, that part is still ours.
Where is your MacBook repair lab in Austin?
Our lab is at 2410 San Antonio Street, Austin, TX 78705, in the West Campus neighborhood one block from UT Austin. Walk in during business hours for a free evaluation. We perform all logic board micro-soldering, ultrasonic cleaning, and data extraction on-site. You speak directly to the technician handling your repair. For customers outside Austin, we accept mail-in MacBook repairs from all 50 states.
Trusted by MacBook Owners
"Upon pick up at my local guy I immediately put it into the mail to Louis and the guys at Rossmann...little more than a week later I am typing this review on said formerly wet and sad MacBook Air. In fact, they even honored the lower of the two quotes I was sent!"
TSC1984
Google review, 2020
Need the data off a dead MacBook?
Free diagnosis. No fix, no fee. Data recovery and board-level repair, mail-in from anywhere in the US.
