Seagate Rosewood Data RecoveryST1000LM035 / ST2000LM007
If your Seagate Backup Plus Slim is beeping, stop powering it on. The Rosewood architecture (7mm height) causes heads to stick to the platter surface. We recover these drives at our Austin lab with preamp matching and firmware unlocking. It's part of our broader hard drive data recovery service.
12 min read
What is rosewood / identification
Is Your Drive a Rosewood?
Rosewood is Seagate's internal codename for their 7mm 2.5-inch mobile drives manufactured from 2016 onwards. According to Aesonlabs, a Canadian data recovery lab, these drives make up 80% of their incoming hard drive recovery volume due to their ubiquity and fragility.
You can identify a Rosewood drive by its thickness (only 7mm) and the top cover. Unlike older drives with a rigid steel lid, Rosewood drives often use a heavy-duty foil sticker as the top seal.
Common Enclosures:
  • Seagate Backup Plus Slim (2016+)
  • LaCie Rugged Mini (USB-C)
  • LaCie Porsche Design Mobile
  • Various HP and Dell laptops with a 7mm bay
Model Number Reference
ModelCapacityNotes
ST1000LM0351TBMost common 1TB
ST2000LM0072TBMost common 2TB
ST2000LM0152TBBarraCuda branded
ST500LM030500GBLow capacity variant
ST2000LM0092TB
ST1000LX0151TBFireCuda
Check the label on the internal drive assembly for the model number.
Why they fail
Why Rosewood Drives Fail
To fit 2TB into a 7mm profile, Seagate made engineering compromises. Understanding these failures helps explain why professional recovery is necessary.
Head Stiction on the 7mm Chassis
When the heads come to rest on the platter instead of the ramp (stiction), the drive tries to spin, fails, and emits the characteristic beep.
Myths & warnings
How DIY Attempts Destroy Rosewood Data
Why the Freezer Trick Kills Rosewoods
A common myth suggests freezing a drive to shrink metal components. On a Rosewood, this is fatal. Take a drive out of a freezer and water condenses on the platters. Because modern read heads fly on an air bearing less than 10 nanometers thick, even microscopic condensation droplets act as massive physical obstacles.
Spinning the drive with this condensation creates an immediate head crash, equivalent to a plane hitting a mountain.
Recovery Software on a Beeping Drive
If your drive is beeping, software cannot help. The beep is the sound of the motor failing to spin.
Every time you plug it in, the drive attempts to spin up. If the heads are stuck or physically damaged, they drag across the micro-smooth platter surface. Keep powering it on and you permanently strip the magnetic coating. After that, the data is unrecoverable.
Recovery process
Our Recovery Process
We don't just swap parts and hope things are fixed. Recovery from Rosewood drives requires a protocol that respects the drive's unique architecture. Our lead technician has completed ACE Lab advanced Seagate training, which specifically covers Rosewood firmware unlocking and Media Cache repair.
  1. Preamp Matching: We validate the donor part not just by model, but by the preamp vendor code (Agilent, TI, or LSI) found on the head connector. A mismatch here means the heads won't read, even if they fit physically.
  2. Safe Unstick: We use specialized tools to lift the heads vertically off the platter before moving them to the ramp. Dragging them back, which is a common amateur mistake, leaves scratches.
  3. Firmware Stabilization: Lock the drive's background firmware processes through the Service Area. This stops the drive from trying to reorganize itself during the imaging process.
Turnaround Times
  • Firmware-only (drive spins)3-6 weeks
  • Head unstick/swap4-8 weeks
  • Multiple donor attempts4-8 weeks
Already Tried DIY?
If you powered it on once or twice, damage is typically limited to a small area of the platter and recovery is still viable. If you ran multiple scan attempts, the damaged area is larger. We will tell you during evaluation if the damage is too severe to justify the cost.
Media cache mcmt
Media Cache Management Table Corruption on Rosewood
Our approach starts by locking the drive's background firmware processes through the Service Area, before we attempt to read any user data. A SATA write-blocker cannot do this. It stops the host from issuing writes, but the controller keeps running cache migration on its own for as long as the drive has power. Freezing those processes first is what stops the firmware from making the corruption worse during imaging.
Our Process
  1. Lock the background firmware processes through the Service Area
  2. Read the MCMT to verify cache integrity
  3. If MCMT is intact, image user data through the cache layer
  4. If MCMT is partially corrupt, reconstruct the mapping from fragments
Bsy terminal warning
Legacy BSY Terminal Commands and Rosewood MCMT
If you found a guide online for fixing a Seagate drive stuck in a BSY (Busy) state using terminal commands, that guide was written for legacy 7200.11 drives. This type of firmware corruption on legacy CMR drives was a known, reversible condition.
Rosewood drives handle the computational overhead of Shingled Magnetic Recording with a fundamentally different translation architecture. The controller does not use static defect lists for translation. It maintains a live, dynamic database called the Media Cache Management Table (MCMT), which tracks data moving between the CMR write cache and the final shingled bands.
Destructive Terminal Commands
  • i4,1,22 : G-List clear.
Correct PC-3000 Workflow
  1. Read the original ROM via COM port before any terminal interaction
  2. Apply a Technological Mode unlock patch
  3. Back up SysFiles 1B, 28, and 35 plus the media cache map
  4. Lock background cache migration through the Service Area
  5. Parse and verify the Media Cache Management Table before imaging
We reconstruct damaged MCMT mappings using PC-3000's parsing plugin as part of our hard drive data recovery process, but the longer the drive runs after a destructive command, the less recoverable data remains. Contact us for a free evaluation; if no data is recovered, there is no charge.
SMR translator architecture
SMR Translator Architecture on Rosewood Drives
On a conventional CMR drive, the translator is a static lookup: each LBA points to one physical sector, and that mapping rarely changes after manufacturing. SMR breaks this model. Incoming writes land in a CMR cache zone first, then the firmware migrates cached data to overlapping shingled bands during idle periods. The translator must track both the cache location & the final shingled destination for every pending write. This is why Rosewood firmware corruption is fundamentally different from older Seagate failures.
Western Digital SMR drives carry the T2 translator in Module 190, which is covered on our SMR translator repair page.
Critical System Files for Translation
SysFile 28 (Primary Translator)
SysFile 28 holds the primary translator. That's the forward & reverse mapping between LBAs and physical locations. Corruption here produces ABR (Abort) errors on random LBA ranges.
The Media Cache Management Table stores the extents map for data pending migration from the CMR cache zone to shingled bands.
SysFile 35 (NRG List)
The Non-Resident G-List tracks defects. Clearing it with i4,1,22 destroys that record of which sectors were remapped after manufacturing.
ROM extraction & firmware unlock
ROM Extraction and Firmware Unlock Workflow
Every Rosewood recovery begins with reading the ROM.
COM Port ROM Read
The ROM read uses the drive's serial diagnostic port. PC-3000 connects via the COM interface & issues a Boot Code mode entry command. In Boot Code mode, the ARM Cortex controller halts normal operation & exposes the ROM contents for transfer over that link.
If the COM port is unresponsive (no terminal echo at all), the ROM can be read via an external SPI programmer connected directly to the ROM chip on the PCB. This bypass is necessary when the bootcode itself is corrupted & the drive cannot enter Boot Code mode through the serial interface.
Technological Mode Unlock Patch
The Rosewood F3 Diagnostic Port Lock disables UART access at boot. We dump the SPI ROM with PC-3000 & apply a Technological Mode unlock patch.
The patch restores diagnostic-terminal access for Service Area repair. It does not decrypt user data & it does not defeat an SED or ATA password lock. Anyone claiming otherwise is describing something the tool does not do.
Once the terminal is unlocked, we immediately back up SysFiles 1B, 28, & 35 plus the media cache map before any further interaction.
Read channel tuning
Read Channel Tuning for Weak Heads
Why SMR Makes Weak Heads Worse
On a CMR drive, each track has a guard band separating it from its neighbors. On an SMR drive, tracks overlap by design. The read head must resolve the target track's signal from a composite waveform that includes energy from both adjacent tracks.
With a weak head, the data isn't gone. The head can't decode it at the default channel settings.
Donor matching for rosewood
Donor Matching for Rosewood Family Codes
Rosewood donor head matching goes beyond model number & head count. The preamp vendor on the head stack assembly determines electrical compatibility. Installing heads with the wrong preamp vendor produces a servo lock failure that prevents the drive from reading any data, regardless of physical fit.
Preamp Vendor Identification
Each Rosewood head stack contains a preamp chip from Texas Instruments (TI), Agilent (AG), or LSI. The vendor code is identified through the Ctrl+L terminal command on a working drive, which outputs the preamp register values. On a non-functional drive, the code is extracted from the ROM hex dump.
We maintain a donor inventory organized by preamp vendor code, not just model number. When a Rosewood arrives for head swap recovery, we identify the preamp vendor before pulling a donor from stock. This eliminates trial-and-error swaps that risk additional platter contamination from repeated open/close cycles on the ULPA clean bench.
Mismatched Preamp Servo Error
A mismatched preamp produces the terminal error FAIL Servo Op=0100 Resp=0003, meaning the servo system sent an initialization command (Op=0100) & received a rejection (Resp=0003). The heads physically installed and the motor spins, but the drive cannot lock onto any servo track.
Inner-Diameter Crash Signature, Drive-Not-Detected SA Repair, HSA Part-Number Matching, and ROM Region Transplant
A Rosewood that spins smoothly but never appears in the BIOS is a System Area firmware case. The donor and ROM workflows below are what separate a Rosewood recovery from a generic Seagate recovery.
Inner-Diameter Head-Crash Signature
The ST1000LM035 and ST2000LM007 use QuietStep ramp-load architecture, with the parking ramp at the outer diameter. During sudden power loss, the spindle's back-EMF is supposed to drive the Voice Coil Motor outward to retract the heads onto that ramp. Actuator bias and the absence of restoring force tend to pull the heads toward the inner diameter, where they bond to the platter surface through stiction. The air bearing under modern read heads is thinner than 10 nanometers and provides no lift once rotation stops.
Under the ULPA-filtered clean bench, we inspect the parking ramp first. If the heads are off the ramp, we look for platter shaving or magnetic-coating debris.
Drive-Not-Detected: Service Area Corruption, Not Mechanical Failure
A Rosewood drive that spins smoothly, makes no beeping or clicking, and still fails to enumerate to the host is almost never a mechanical failure. The ARM controller cannot complete the ATA identify handshake until it has loaded its operating microcode out of the Service Area on the platters. The host never sees a SATA device.
On the PC-3000 Portable III's F3 terminal, LED:000000BD indicates a Media Cache exception. The MCMT is desynchronized relative to the conventional cache zone, usually because the drive lost power in the middle of a background flush from CMR cache to a shingled band.
A second BSY variant enumerates as a SATA device but reports zero LBA capacity to the host. This is the corrupted translator returning a zero-user-capacity map. It is still SA corruption, not a mechanical fault, and the workflow below applies.
The PC-3000 SA repair workflow on Rosewood is a reconstruction of damaged firmware structures, not a bypass of any drive security mechanism. The order matters because several of the steps disable destructive auto-recovery routines that would otherwise overwrite the only intact map of user data on the drive:
  1. Apply a Technological Mode unlock patch so the F3 terminal accepts SA commands.
  2. Back up SysFile 1B, SysFile 28, SysFile 35, and the Media Cache Management Table.
  3. Lock the drive's background firmware processes through the Service Area so cache migration stops. This freezes the drive's internal state so the firmware cannot destroy user data during imaging.
  4. Parse and reconstruct the Media Cache Management Table to repair the LBA-to-physical mapping between the conventional cache zone and the shingled bands.
  5. Inject the Loader (LDR) microcode directly into controller RAM to stabilize the drive for PC-3000 imaging.
The destructive command m0 is never used on a Rosewood.
HSA Part-Number Cross-Reference: Six-Layer Donor Fingerprint
Preamp vendor matching is necessary but not sufficient for a Rosewood donor. Two drives with the same model number, the same head count, and the same preamp vendor can still be electrically incompatible because the calibration generation differs. The six-layer fingerprint we reference against donor inventory before opening any drive is:
  1. Model number and capacity. A two-head donor will not function in a four-head patient regardless of every other match.
  2. Firmware revision family.
  3. Manufacturing site code. We match Seagate donors by site code, like WU, SU, or TK. The site code is printed on the drive label.
  4. Date of manufacture and preamp revision.
  5. Drive part-number prefix on the label. Strings such as 1RK172-566 or 1R8174-568 encode the generation tier and density class for ST1000LM035 and ST2000LM007 builds respectively.
  6. Internal flex connector code. Once the patient is open on the clean bench, stamped codes on the head-stack flex (RY2-T, AGB1-D, LSIB1-G) tie the slider geometry to the preamp circuitry.
The donor inventory at our Austin lab is organized along these six layers rather than by model number alone. The point of the fingerprint is to avoid the trial-and-error open-and-close cycles that progressively contaminate a patient on the clean bench, even at ULPA filtration.
ROM Region Transplant via PC-3000
Three different PCB-level operations on a Rosewood are often described in shorthand as ROM work. They are not interchangeable, and choosing the wrong one destroys data:
Full ROM swap.
On older Rosewood drives, the complete patient ROM image is written to a donor PCB. This works when the patient ROM data is healthy but the PCB hardware is dead, for example after a TVS-diode short or motor-driver burnout. Adaptive parameters are preserved because the entire ROM is preserved. On newer Rosewood models, a microcontroller (MCU) swap is necessary.
We use it only to open F3 terminal SA access on a locked diagnostic port. This is a working tool, not a repair.
ROM region transplant.
Used when the patient ROM is partially corrupt (for example a bad checksum in a boot overlay) but the head-specific calibration blocks remain intact. A full patient ROM swap onto a donor PCB simply transfers the failure; a full donor ROM written to the patient PCB destroys the head calibration that was unique to that physical head stack. The region transplant is the only safe path.
The ROM contains adaptive parameter blocks that cannot be reconstructed from a donor because they are tied to the exact physical head stack inside the patient chassis. The three blocks that matter for spin-up are:
  • RAP (Read Adaptive Parameters)
  • SAP (Servo Adaptive Parameters): calibrates the voice-coil motor for accurate track-following against the patient's servo burst pattern.
  • CAP (Controller Adaptive Parameters)
PC-3000 LDR Injection, Donor Micro-Jog, and Multi-Pass Imaging
The Rosewood family fails in three layers: firmware (SysFile 28 and Media Cache Management Table corruption), mechanical (head preamp burnout requiring an HSA transplant), and analog (marginal read signal on aged heads).
1. PC-3000 LDR Microcode Injection on F3 Architecture
When a Rosewood drive enters a BSY state with a fatal boot error (terminal output of LED:000000CC, a bad translator or SMART initialization failure, or LED:000000BD, a Media Cache exception tied to media cache map corruption), the ARM controller cannot finish loading the firmware from the System Area and rejects every standard ATA command. Spinning the drive long enough to retry the boot sequence is the wrong move. The boot sequence triggers MCMT migration on corrupted heads and writes new fault entries that overwrite the data we need.
The PC-3000 Portable III bypasses the corrupted boot path by uploading a Loader (LDR) microcode image directly into the controller's RAM through the COM port. The LDR is a stripped-down firmware that gives the controller just enough instruction to hold the spindle at platform-ready and accept Technological Mode commands. Because the LDR runs entirely from RAM, the corrupted SysFiles on the platter never execute.
  1. SPI ROM dump and Technological Mode patch: The patch only restores terminal access. It doesn't decrypt anything.
  2. LDR upload to controller RAM: The Loader microcode for the Rosewood family is selected from PC-3000's Seagate F3 utility and pushed across the same COM channel into the ARM controller's working RAM.
  3. Interrupt boot at T> prompt: Sending Ctrl+Z during the LDR boot drops the drive into the F3 Tech terminal before any background process starts.
  4. Lock the background firmware processes: Before touching anything else, the drive's background routines are halted through the Service Area so CMR-to-SMR cache migration stops. This freezes the physical state of the platter so the imaging pass that follows operates on an unchanging target.
  5. Backup before any write: SysFiles 1B, 28, and 35 plus the media cache map are copied off to the PC-3000 host before any translator rebuild is attempted. If the rebuild produces an inconsistent MCMT, the originals are reloaded and the work is repeated with different parameters.
2. Donor Head Micro-Jog Calibration Beyond Preamp Vendor Match
Matching the preamp vendor (TI, AG, or LSI) on the donor HSA is required but not sufficient. Every Rosewood read element sits at a slightly different physical offset from its paired writer because of slider manufacturing tolerance. The micro-jog value tells the actuator how far to shift radially so the reader element centers on the servo burst pattern of its target track.
When a donor HSA is installed, its physical micro-jog values do not match the ones stored in the patient drive's ROM and System Area. The patient ROM/PCB stays with the patient drive because it carries the unique adaptive parameters needed to map LBAs back to the patient platters. The result is an immediate mismatch between firmware expectations and donor head geometry.
We keep every micro-jog calibration edit in volatile RAM until a clean read pass confirms alignment. Nothing is committed back to the patient drive's System Area until the pass is verified.
3. Multi-Pass Imaging with Read Channel Tuning
Once the LDR is loaded and the donor HSA is calibrated, imaging begins on PC-3000.
The pass strategy is built around protecting the strong heads from the weak ones. A single failing head can kill an entire imaging session if it is allowed to retry indefinitely on every error.
  1. Pass 1 (forward, head-by-head): We turn off Bad Sector Auto-Relocation. The read timeout is capped at the millisecond level.
  2. Pass 2 (reverse): Sectors that failed forward reads are queued for reverse-direction reads. Reverse imaging is a logical LBA-order technique, and sectors that failed forward sometimes resolve on that second pass.
If a head runs hot for hours, the thermal coefficient of expansion on the slider is enough to shift fly height and change the read channel response.
Watch recovery section
Watch Real Rosewood Recovery
See the process for yourself. These videos from our YouTube channel demonstrate the specific challenges of the Rosewood architecture.
A head swap on a clicking 1TB Rosewood
Seagate drive quality and Rosewood failure patterns
Pricing section
Transparent Pricing
We do not use bait-and-switch quotes. You get a firm quote after our free evaluation. If the data is unrecoverable, you pay nothing.
Service TierRossmann PriceDescription
Firmware / Logical$600–$900Drive spins but is not detected. Includes unlocking the diagnostic port and repairing the translator.
Beeping / Stiction (Heads Reusable)$600–$900Heads stuck to platters but undamaged after inspection. We unstick the original heads, check them, and reuse them. No donor drive needed. Bench labor + PC-3000 imaging.
Beeping / Head Swap (Heads Damaged)$1,200–$1,500Heads stuck and damaged from the stiction event. Full donor head transplant required. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Severe DamageNo ChargeIf the magnetic coating is stripped (rotational scoring), we tell you the truth and do not charge a recovery fee.
Related symptoms
Why is my Seagate Backup Plus Slim beeping?
Seagate documents insufficient power as the most common cause of a beeping external drive, and the Backup Plus Slim is bus-powered, so a known-good cable, port, and supply come first. If the beep survives that, the drive goes to the bench. On Seagate Rosewood drives (ST2000LM007), heads that come to rest on the platters bond to the surface, and that is one of the states the bench finds; the sound on its own does not establish it.
What happens if I run recovery software on a beeping Rosewood?
Software sends a spin-up command. Because the heads are stuck, they drag across the platter surface, scraping off the magnetic data layer. Repeated attempts will permanently destroy the data.
Can I use the freezer trick on a Seagate Rosewood?
No. When you remove a drive from a freezer, water vapor condenses instantly on the platters. Because modern read heads fly on an air bearing less than 10 nanometers thick, even microscopic condensation droplets act as massive physical obstacles. Spinning the drive causes an immediate head crash and rotational scoring.
Why is Rosewood recovery more difficult than older drives?
Rosewood drives use Shingled Magnetic Recording (SMR) with a complex Media Cache Management Table (MCMT).
How much does it cost to recover a Seagate Rosewood?
Firmware repairs (drive spins but not detected) cost $600–$900. For beeping Rosewood drives, the price depends on head condition. If the heads are stuck to the platters but undamaged (stiction-only), we unstick them, check them, and reuse them with no donor drive needed. This falls into the firmware-tier range at $600–$900. If the heads are stuck and damaged, a full donor head swap is required at $1,200–$1,500 plus donor drive cost. Head condition can only be determined after opening the drive and inspecting under magnification on the clean bench. If no data is recovered, there is no charge.
Can I fix a BSY Rosewood drive with terminal commands?
No.
How is the Rosewood ROM unlocked for firmware repair?
We load the ROM image into PC-3000, which generates a Technological Mode unlock patch. Once the terminal is unlocked, we back up all critical System Files before touching anything else.
Why is my Seagate Rosewood spinning but not detected by the BIOS?
A Rosewood that spins smoothly with no beeping or clicking but never appears to the host is almost always Service Area firmware corruption, not a mechanical failure. The ARM controller cannot complete the ATA identify handshake until it loads its operating microcode out of the SA on the platters. If a power loss during a background cache flush corrupts the Media Cache Management Table, the controller hangs in a permanent BSY state. On the PC-3000 F3 terminal, this typically reports LED:000000BD (Media Cache exception). A second variant enumerates the drive but reports zero LBA capacity because the corrupted translator returns a zero-user-capacity map. Repair is a reconstruction of damaged firmware structures via PC-3000, not a security bypass.
How is HSA donor matching done for Rosewood drives beyond model number?
Model number alone is not a sufficient match for a Rosewood donor head stack. Two ST1000LM035 drives with the same head count and the same preamp vendor can still be electrically incompatible because the calibration generation differs. We cross-reference six layers before pulling a donor. The first four are model number and capacity, firmware revision family, Seagate manufacturing site code (WU, SU, TK), and date of manufacture and preamp revision. The fifth is the drive part-number prefix on the label, where formats such as 1RK172-566 for ST1000LM035 or 1R8174-568 for ST2000LM007 encode the generation tier. The sixth is the internal flex connector code (RY2-T, AGB1-D, LSIB1-G), which ties slider geometry to preamp circuitry. The fingerprint exists to avoid trial-and-error open-and-close cycles that progressively contaminate the patient on the clean bench.
What is a ROM region transplant and when is it needed?
A ROM region transplant is required when the patient PCB ROM is partially corrupt but the head-specific calibration blocks remain intact. Three PCB-level operations are sometimes called ROM work but are not interchangeable. A full ROM swap copies the entire patient ROM to a donor PCB. On older Rosewood drives this works when the patient ROM data is healthy but the PCB hardware is dead. On newer Rosewood models an MCU swap is necessary. A Technological Mode unlock patch opens F3 terminal access on a locked diagnostic port. A ROM region transplant is different. It keeps the patient's head-specific calibration and replaces the corrupted boot overlays.
What happens if a Rosewood donor drive has a mismatched preamp?
Rosewood head stack assemblies contain a preamp chip. The preamp vendor code is identified via the Ctrl+L terminal command or by reading the ROM hex data. Installing heads with a mismatched preamp produces a FAIL Servo Op=0100 Resp=0003 error in the PC-3000 terminal, meaning the servo system cannot lock onto the tracks.
Cross-link
Not a Rosewood? Browse all drive families for Barracuda, IronWolf, Exos, WD, Toshiba, HGST, and Samsung.
All HDD Recovery
Rosewood drive beeping?
Stop powering it on. Mail it to our Austin lab for evaluation. No data, no charge.
