Professional hard drive data recovery for clicking, beeping, and not detected drives. Our Austin lab processes HDD and SSD recoveries daily via local drop-off and nationwide mail-in. We extract files in-house with PC-3000 tools and validated clean-bench procedures. No data = no charge. Same equipment as enterprise labs at a fraction of the price.
NDA on Request
Confidentiality Guaranteed
Chain of Custody
Legal Documentation
ISO 14644-1 Class 4 Equivalent
0.02µm Validated
100% Confidential
NDA Standard
Drives We Recover From
What Hard Drive Recovery Customers Say
Hard drive data recovery costs $100–$2,000, depending on the failure type. Simple data copies from a functional drive cost $100. File system recovery for corrupted partitions, formatted drives, or volumes the operating system no longer recognizes starts at $250. Firmware repair, where the drive's internal software is corrupted and requires PC-3000 terminal access to rebuild translator tables, ROM data, and adaptive parameters, costs $600–$900. Mechanical failures that require a donor head swap on our laminar-flow clean bench, validated to 0.02 µm particle count, run $1,200–$1,500 and require a 50% deposit because donor parts are consumed in the procedure. The most severe tier covers platter surface damage from head crashes and starts at $2,000. Every recovery begins with a free evaluation and a firm quote before any work begins. If we cannot recover your data, you pay nothing.
Hard drive data recovery is the process of retrieving inaccessible data from failed, corrupted, or damaged hard disk drives (HDDs) and solid-state drives (SSDs). Also called hard disk recovery or HDD data recovery, the goal is the same: get your files back from a drive that will not cooperate. Professional data retrieval services use specialized hardware such as the PC-3000 by ACE Lab and DeepSpar Disk Imager to recover data from hard drives when standard software solutions fail. According to Backblaze's Drive Stats data covering over 340,000 drives, the average annualized failure rate across all models is approximately 1.5–1.6%, meaning millions of drives fail each year and require professional recovery.
Recovery methods include:
- Logical repair: Recovering corrupted partitions, formatted filesystems, and deleted files using sector-level imaging and advanced file carving. On modern SMR (Shingled Magnetic Recording) hard drives, deleted files may be permanently unrecoverable due to background UNMAP commands that function identically to solid-state TRIM, instantly returning zeroes to recovery software. Formatted SSDs also self-erase via TRIM, requiring controller-level intervention if supported.
- Firmware repair: Restoring access to drives not detected by the system; includes ROM extraction, translator module rebuilding, and adaptive parameter correction using PC-3000-class tools
- Mechanical repair: Clean bench head swaps and platter work for clicking or beeping drives with physical head damage, performed under ULPA-filtered laminar flow validated to 0.02 µm particle count
Last updated: February 2026
What's Happening to Your Drive?
Select your symptom for a free diagnosis
PC-3000 Recovery Platform
Every Recovery on Camera
At a Glance
- $Cost: From $100 for simple copies, $250–$2,000 for recovery (firm quote after free evaluation)
- ✓Equipment: PC-3000 Portable III + ULPA-filtered clean bench (ISO 14644-1 Class 4 equivalent) for mechanical failures
- 🛡Guarantee: No data recovered = no charge (evaluation always free)
Estimate Your Recovery Cost
Select the symptoms your hard drive is showing to get an estimated cost range and recovery outlook. This is a starting point; we provide a firm quote after evaluating your drive for free.
Select all symptoms that apply. This tool gives a rough estimate; your actual quote comes after our free evaluation.
Select symptoms above to see your estimated cost range and recovery likelihood.
Why Choose Our Austin Lab
We are not a middleman. We do not ship your drive to a mystery warehouse. Our certified techniciansrecover your data on-site in Austin using the same class of equipment as national labs: PC-3000, DeepSpar, laminar-flow clean benches, donor inventory, and microscopes. Learn about our Austin lab. You speak directly with the technician handling your case. No scripts. No sales team.
Local and Nationwide
All data recovery performed in our Austin lab. Mail-in accepted from all 50 states.
No Data, No Charge
If we cannot recover your data, you pay $0 (optional return shipping only).
Same Equipment, Lower Price
PC-3000 imaging, validated clean bench; without ad budgets or affiliate kickbacks.
Transparent Pricing
Clear ranges up-front; final quote after free evaluation; no surprise fees.
Direct Communication
Talk to your engineer, not a salesperson. Get straight answers.
Real Proof
2.49M+ YouTube subscribers and hundreds of hour-long recoveries on camera.
How We Compare to National Labs
All four companies listed below use PC-3000 hardware for firmware-level recovery. The difference between us and the national labs is overhead, not capability. Our pricing reflects engineering time and donor parts; theirs reflects advertising budgets, cleanroom real estate, and certification fees.
| Feature | Rossmann Group | DriveSavers | Ontrack | Geek Squad |
| Average Cost | $100–$2,000 | $2,000-$7,000 | $800-$3,000+ | $600-$2,500 (outsourced) |
| Work Location | In-house Austin lab | Novato, CA facility | Multiple global labs | Outsourced to partner labs |
| Equipment | PC-3000, DeepSpar, ULPA-filtered bench | PC-3000, proprietary tools | PC-3000, proprietary tools | Varies by partner |
| No Data = No Charge | Yes, always | Diagnostic fee may apply | Yes | Varies |
| Direct Technician Contact | Yes, talk to your engineer | Through account manager | Through account manager | Store staff only |
| Free Evaluation | Yes | Yes | Yes | $50+ diagnostic fee |
| Proof of Work | 2.49M+ YouTube subscribers, hundreds of filmed recoveries | Client testimonials | 35+ year track record | Best Buy brand reputation |
Data compiled from publicly available pricing and service information as of January 2026. Read our full comparison guide.
Drive Repair vs. Data Recovery
Many clients ask: "Can you repair my hard drive so I can use it again?"
Hard Drive Data Recovery Standards & Verification
Serving clients nationwide via mail-in service since 2008.
See our clean bench validation data and particle test videoFailure Types We Handle
Clicking hard drive →
Beeping drive →
Drive not detected →
Drive not spinning →
Logical and Mixed Failures
File system corruption →
Accidentally deleted files or formatted a conventional hard drive? If SMART is clean and reads are fast, DIY tools work. (Note: DIY software cannot recover deleted files on modern SSDs due to the TRIM command permanently wiping unmapped blocks). If reads slow or drop, stop and let us image with pro hardware before it degrades.
Bad sectors / SMART errors →
If SMART reports reallocated or pending sectors, the drive is physically degrading. We fast-pass good regions, then revisit weak areas with head-maps and conservative retries (DeepSpar/PC-3000). Goal: maximum image with minimum stress on the heads.
RAID and NAS recovery →
Time-Critical Data Emergency?
Supported Models & Systems
Operating Systems
- • Windows (NTFS, FAT32, exFAT)
- • MacOS (APFS, HFS+)
- • Linux (EXT4, XFS, Btrfs, ZFS)
- • Server / VMware (VMFS)
Computers
- • Laptop hard drives (Dell, HP, Lenovo, ASUS)
- • Apple MacBooks (Pro, Air)
- • Desktop PCs & Workstations
- • All-in-One PCs
External Drives
- • WD Passport / Elements
- • Seagate Backup Plus
- • LaCie Rugged
- • G-Technology / SanDisk Professional
Storage Types
- • 3.5" Desktop HDD
- • 2.5" Laptop HDD
- • NAS Units (Synology, QNAP)
- • USB Flash & SD Cards
Recovery Services By Symptom
The sound your drive makes tells us what has failed. If your hard disk is clicking, beeping, corrupted, or not detected, our engineers can help. Click the symptom that matches yours for detailed information.
Clicking or Ticking
Platters spin but heads cannot find data. Head failure or preamp damage.
Learn more →Beeping or Buzzing
Motor cannot spin. Heads stuck to platters (stiction) or seized spindle.
Learn more →Not Detected
Computer does not see the drive. PCB failure, firmware corruption, or weak heads.
Learn more →Hard Drive Corrupted
File system damaged. Shows as RAW, asks to format, or files inaccessible. Data is often still intact on the platters.
Learn more →Listen to Your Drive
The sound a failing hard drive makes reveals the failure type. Play each clip below and compare it to what your drive sounds like. If yours matches a mechanical failure (clicking, beeping, grinding), power it off immediately and contact us for a free evaluation.
Common Problems We Solve
Dropped Hard Drive
External drive fell? Laptop dropped? Head damage is likely, but data is usually recoverable.
Get help →Water Damaged Drive
Flood, spill, or moisture damage? Don't dry it out. We explain what actually works.
Get help →Power Surge Damage
Lightning strike or power surge? PCB damage is fixable. Data is often 100% intact.
Get help →Making Strange Noises
Clicking, beeping, grinding? Each sound tells us exactly what's wrong. Stop using it.
Diagnose →Other situations: emergency recovery | SSD recovery | cost breakdown | how to choose a service | water damage recovery | fire damage recovery
Recovery by Manufacturer
Different manufacturers have different failure patterns. We track real reliability data from Backblaze's fleet of 340,000+ drives to understand model-specific issues and tailor our approach for each brand.
Seagate Recovery
Higher AFRF3 terminal access, ROM extraction, and model-specific diagnostics. Rosewood slim drives and Barracuda models are our most frequent cases.
View Seagate reliability data →Western Digital Recovery
Low AFRIndustry-leading failure rates. The PC-3000 WD module handles ROM/module repair and Ultrastar enterprise drives. My Passport and Elements external drives are frequent mail-in cases, often requiring specialized firmware patching.
View WD reliability data →Toshiba Recovery
Canvio external drives and MQ/MG internal series. Toshiba drives use a unique head parking mechanism that frequently fails after drops. PC-3000 Toshiba module for firmware and translator repair.
View Toshiba recovery details →Hitachi / HGST Recovery
Samsung Recovery
Maxtor / LaCie Recovery
Maxtor drives (acquired by Seagate in 2006) and LaCie external enclosures remain common in older systems and backup arrays. Recovery from these units typically involves PCB swaps and ROM transfers.
Find Your Drive Family
Recovery approach varies by drive family. Match the model number on your drive label to find specific failure modes and repair procedures.
Seagate Rosewood
ST1000LM035, ST2000LM007
2.5" · 500GB–2TBWD Spyglass / My Passport
WD40NMZW, WD50NMZW
2.5" · 3TB–5TBSeagate Barracuda
ST1000DM003, ST3000DM001
3.5" · 500GB–3TBWD Red / Red Plus
WD20EFRX, WD40EFRX
3.5" · 2TB–6TBToshiba DT01/DT02
DT01ACA100, DT02ABA400
3.5" · 500GB–6TBSeagate Barracuda 7200.11
ST3500320AS, ST31000340AS
3.5" · 500GB–1.5TBView all drive families → | WD Green recovery walkthrough (Part 1) and Part 2
Start Your Free Estimate
Professional Recovery
Get a Free EstimateSecure Mail-In from Anywhere in the US
1 Business Day
- New York City 1 Business Day
- Los Angeles 1 Business Day
- Chicago 1 Business Day
- Seattle 1 Business Day
- Denver 1 Business Day
- ✓Use the box-in-box method: float a small box inside a larger box with 2 inches of bubble wrap.
- ✓Wrap the bare drive in an anti-static bag to prevent electrical damage.
- ✗Do not use packing peanuts. They compress during transit and allow heavy drives to strike the edge of the box.
Our Recovery Process
- 1
Evaluate & Protect
- 2
Stabilize Access
- 3
Clean-Bench Mechanics
For clicking, beeping, or stuck heads: exact-match donor head swap on a validated laminar-flow bench.
- 4
Image First, Always
- 5
Recover from Image
- 6
Deliver & Purge
Typical timing: Healthy 1 TB images in a few hours; light bad sectors add days; "not detected"/firmware about a week; head swaps with donor parts 1-3 weeks. Severe platter damage may be unrecoverable; we will tell you when to save your money.
Hard Drive Data Recovery Pricing
Hard drive data recovery costs $100–$2,000, depending on the failure type. Simple copies start at $100. File system recovery starts at $250. Firmware repair is $600–$900. Head swaps are $1,200–$1,500. Surface damage is $2,000. We provide a firm quote after a free evaluation.
Honest ranges so you can budget without a sales call. See our detailed pricing breakdown. After a free evaluation we give you a firm quote and honest assessment. If it turns out easier than expected, you pay less; not a flat "worst-case" tier. If we cannot get your data, you pay $0 (optional return shipping only). See all service pricing.
| Service Tier | Price | Description |
| Simple CopyLow complexity | $100 | Your drive works, you just need the data moved off it Functional drive; data transfer to new media Rush available: +$100 |
| File System RecoveryLow complexity | From $250 | Your drive isn't recognized by your computer, but it's not making unusual sounds File system corruption. Accessible with professional recovery software but not by the OS Starting price; final depends on complexity |
| Firmware RepairMedium complexity – PC-3000 required | $600–$900 | Your drive is completely inaccessible. It may be detected but shows the wrong size or won't respond Firmware corruption: ROM, modules, or translator tables corrupted; requires PC-3000 terminal access Standard drives at lower end; high-density drives at higher end |
| Head SwapHigh complexity – clean bench surgery50% deposit | $1,200–$1,500 | Your drive is clicking, beeping, or won't spin. The internal read/write heads have failed Head stack assembly failure. Transplanting heads from a matching donor drive on a clean bench 50% deposit required. Donor parts are consumed in the repair |
| Surface / Platter DamageHigh complexity – clean bench surgery50% deposit | $2,000 | Your drive was dropped, has visible damage, or a head crash scraped the platters Platter scoring or contamination. Requires platter cleaning and head swap 50% deposit required. Donor parts are consumed in the repair. Most difficult recovery type. |
All tiers: Free evaluation and firm quote before any paid work. No data, no fee on simple copy, file system, and firmware tiers. Head swap and surface damage require a 50% deposit because donor parts are consumed in the attempt.
Target drive: The destination drive we copy recovered data onto. You can supply your own or we provide one at cost. For ultra-high-capacity drives (20TB and above), the target drive costs approximately $400+ due to the large media required. All prices are plus applicable tax.
Pricing Comparison
| Scenario | Rossmann | DriveSavers / Big Labs |
| "Not detected" firmware issue | $600-$900 | $1,000-$2,500 |
| Head swap (exact donor, clean bench) | $1,200-$1,500 | $2,000-$7,000+ |
| Logical recovery (fast reads) | $100-$500 | $500-$1,500 |
| Evaluation fee | None | Free eval, but fees common elsewhere |
| Marketing Overhead | $0 (Word of Mouth) | Thousands [Read Analysis] |
Why the difference? We do not bankroll PPC ads, affiliate kickbacks, or vanity certificates. Your invoice reflects engineering time, donor parts, and imaging hours; not marketing overhead. Read our analysis of DriveSavers pricing.
Clean Rooms vs. Clean Benches
Competitors advertise multi-million-dollar “ISO Class 5 certified clean rooms” populated by technicians in full spacesuits. Clean room classifications are defined by ISO 14644-1, which specifies maximum allowable airborne particle concentrations. For data recovery, that level of whole-room infrastructure is marketing theater, not a technical requirement. What actually protects your platters is a validated laminar-flow clean bench with proper ULPA particle filtration and an image-first workflow.
| Standard | Max Particles ≥0.5µm per ft³ | Filtration Level | Required For HDD Work? |
| ISO 14644-1 Class 5 (Class 100) | 100 particles | 0.3µm HEPA | Industry marketing standard |
| ISO 14644-1 Class 4 (Class 10) | 10 particles | 0.1µm ULPA | Semiconductor manufacturing |
| Our Laminar Bench | Near-zero particles (validated) | 0.02 µm particle count | ✓ Localized ISO 14644-1 Class 4 equivalent |
Our ULPA-filtered laminar-flow clean bench achieves zero particle count at 0.02 µm during validation. ULPA filters are rated 99.999% efficient at the most-penetrating particle size (0.1-0.3 µm); the 0.02 µm reading comes from our TSI P-Trak 8525 particle counter. We validate our bench before every open-drive procedure and publish the results. The reading: localized ISO 14644-1 Class 4 equivalent conditions.
Why You Don't Need a $1M Cleanroom
Competitors charge $3,000+ and justify it with photos of technicians in full cleanroom suits. In this video, Louis demonstrates our laminar flow bench particle test side-by-side with a competitor's marketed cleanroom. The bench validates to localized ISO 14644-1 Class 4 equivalent conditions at 0.02 µm sensitivity. The cleanroom is designed for semiconductor fabs, not 30-minute head swaps. The difference in your invoice is real estate and marketing, not science.
Full article: Do You Really Need a Clean Room for Hard Drive Data Recovery?
Real Recovery Cases
Recovery outcomes depend on the condition of the drive when it arrives. If you stopped using it immediately, success rates remain high. If someone ran software on it, tried to open it, or kept powering it on, odds drop. Watch our documented recovery cases and judge for yourself.
Seagate ST2000LM007
Beeping after drop
Heads parked on platters. Unstick in clean bench, PC-3000 image with head map. 847GB Lightroom catalog recovered.
$400
Watch similar case →WD Blue 1TB
Clicking on startup
Firmware translator corrupt. Rebuilt with PC-3000, selective head imaging. QuickBooks DB verified, zero corruption.
$350
Watch process →LaCie Mobile 4TB
Not detected after surge
PCB damage. ROM/adaptives transfer to donor board. Full image, 3.2TB video files delivered.
$500
Watch similar case →Recovered After Failed Attempt
Seagate Barracuda 2TB
Returned "unrecoverable" by another lab
Previous shop opened the drive in an uncontrolled environment and contaminated the platters. We cleaned the platters, swapped heads from an exact-match donor, and recovered 1.8TB of family photos spanning 15 years.
$1,200
Watch difficult case →WD Ultrastar 8TB
Head swap recovery
Failed read/write heads on a WD enterprise drive. Donor heads sourced from matching firmware revision, swapped in clean bench, full 8TB image completed.
$1,200
Watch head swap case →Seagate Barracuda 1TB
Green light, no detection
Drive powers on with green LED but not recognized by any system. Firmware module corruption diagnosed via PC-3000 terminal. Modules rebuilt, full image extracted.
$600
Watch this case →Evidence Locker
Verified recovery cases from our lab. Filter by device type or failure mode.
129 verified recovery cases · Verify on Google Maps
Watch Our Engineers Work
We believe in total transparency. That is why we film our work. Watch Louis Rossmann and the team perform real data recovery procedures, from head swaps to firmware rebuilds, so you know exactly what happens to your drive.
Got an SSD instead? NVMe, M.2, SATA; different tech, same lab. We do controller repair, firmware fixes, and chip-off on unencrypted drives.
Safe to Try at Home
- ✓Try a different cable or port. USB cables fail more often than drives. Test with a known-good SATA or USB cable before assuming the drive is dead.
- ✓Check Disk Management (Windows) or Disk Utility (Mac). If the drive appears but has no letter, it often just needs a drive letter assigned, not recovery.
- ✓Use ddrescue to clone a readable drive. If the drive spins normally and reads (even slowly), you can safely image it with our free ddrescue guide before attempting file recovery.
Do NOT Do This
- ✗Do not open the hard drive. Exposing platters to unfiltered air introduces particles that cause permanent scratches. This is the #1 way people destroy their own data.
- ✗Do not put it in the freezer. The freezer trick is a myth that causes condensation damage and corrodes electronics.
- ✗Do not run CHKDSK or Disk Utility on a clicking/beeping drive. These tools attempt writes that can destroy weakened heads and turn a $400 recovery into a $1,500+ job or total loss.
- ✗Do not keep power-cycling a failing drive. Each spin-up attempt on a mechanically damaged drive worsens the damage. If it clicks, beeps, or grinds, power it off immediately.
When to Call a Professional
Do you have HIPAA or SOC 2 certification?
Can HDD be repaired?
Can you recover data from a dead hard drive?
What causes hard drive failure?
What is the difference between HDD and SSD data recovery?
Can data be recovered from an SSD after TRIM?
Guides & Resources
Research your options before making a decision. These guides help you understand when to DIY, when to hire a pro, and how to choose the right service.
Complete guide: DIY methods, when to use software, when to call a pro
Decision guide: Which approach is right for your situation?
How to Choose a Recovery Service
What to look for, red flags to avoid, questions to ask
Hard Drive Recovery Near Me
Nationwide mail-in service: Local vs. specialized labs
Emergency Recovery Service
Rush service for time-critical situations
Step-by-step ddrescue guide for drives that still read
Locations We Serve
Sources & References
- Backblaze Hard Drive Stats: Annualized failure rate data from a fleet of 340,000+ drives. Model-level reliability observations referenced for general manufacturer trends.
- ACE Lab PC-3000 Portable III: Industry-standard data recovery hardware and software used by professional labs worldwide. Manufacturer specifications referenced for tool capabilities.
- DeepSpar Disk Imager: Professional sector-level imaging tool with controlled retry and timeout features. Used in conjunction with PC-3000 for forensic imaging.
- Magnuson-Moss Warranty Act (15 U.S.C. 2302): Federal law referenced regarding independent repair and warranty rights. Manufacturers cannot void warranty for using an independent service provider.
- ISO 14644-1:2015: Classification of air cleanliness for cleanrooms and clean zones. ISO 14644-1 Class 5 (formerly Fed Std 209E Class 100) and ISO 14644-1 Class 4 (formerly Class 10) standards referenced in the clean bench comparison table.
- Pricing comparisons are based on publicly available information from competitor websites, verified as of January 2026. DriveSavers, Ontrack, and Geek Squad pricing ranges reflect published quotes and customer-reported data.
