Lab Operational Since: 17 Years, 9 Months, 9 DaysFacility Status: Fully Operational & Accepting New Cases
Data recovery prices range from $100–$2,000 depending on the type of failure. This guide explains exactly what you will pay and why, with transparent pricing from a lab that does not hide behind "contact us for quote" tactics.
Hard drive recovery cost, hard disk recovery cost, and hard drive recovery service cost all describe the same 5-tier pricing scale below; only the terminology differs. Hard drive repair price is a narrower subset covering PCB or ROM-level board work on drives that still have healthy heads and undamaged platters.
Hard drive data recovery costs $100–$2,000 across 5 published tiers: $100 for a simple copy, From $250 for file system recovery, $600–$900 for firmware repair on PC-3000, $1,200–$1,500 for a donor-matched head stack swap, and $2,000 for platter surface damage. Helium-sealed enterprise drives (Exos, Ultrastar, MG08) run $200–$5,000+ with helium refill billed separately on opened-chamber tiers. Evaluation is free, there is no diagnostic fee, and a failed recovery costs nothing under the No Data, No Charge policy.
Hard drive recovery price by failure tier
The hard drive recovery price at our Austin lab is set by what failed, not by drive capacity or manufacturer. Five published tiers cover every recoverable mechanical or firmware failure: $100, From $250, $600–$900, $1,200–$1,500, and $2,000. There is no diagnostic fee gating the evaluation.
Hard drive data recovery prices, same scale as hard disk pricing
Our hard drive data recovery prices and our hard disk data recovery cost are one and the same 5-tier scale; the terms are interchangeable because a hard disk drive is a hard drive. Searchers asking how much does data recovery cost for a mechanical drive land on the same published tiers above. Helium-sealed enterprise drives are tracked separately at $200–$5,000+ with helium refill billed on opened-chamber tiers.
Author01/15
Updated June 24, 2026
14 min read
Featured Snippet Optimization - Quick Answer02/15
Data Recovery Cost: Quick Answer
  • Logical Recovery: $100 simple copy or From $250 file system recovery (deleted files, formatted drive, partition issues)
  • Firmware Issues: $600–$900 (drive not detected, wrong capacity, translator errors)
  • Head Swap: $1,200–$1,500 (clicking, beeping, donor parts required)
  • RAID/Complex: quoted after evaluation (RAID arrays, multi-drive systems)
These are Rossmann Repair Group prices. Large corporate labs (DriveSavers, Ontrack) charge 2-3x more for the same work.
Recovery cost range03/15
Hard drive data recovery costs $100–$2,000 depending on the failure type. A data copy from a functioning drive costs $100. File system recovery starts at From $250. Firmware repair using PC-3000 costs $600–$900. A head swap requiring matched donor parts costs $1,200–$1,500. Platter surface damage recovery starts at $2,000. Diagnostic evaluation is free. If the data is not recoverable, there is no charge.
Which Tier Is My Drive?03b/15
Which Hard Drive Recovery Cost Tier Does My Drive Fall Into?
Hard drive recovery cost runs $100–$2,000, starting at $100 for a working drive, and the tier is set by the symptom you can observe, not by the drive's capacity. Match what your drive is doing to the price in the table below. Evaluation carries no diagnostic fee, and a failed recovery costs nothing under No Data, No Charge.
The ladder below maps what the drive is doing right now, your own observation before you ship it, to the published price for that failure class. Find the row that matches your symptom and read the cost straight across. All work is performed in-house at our Austin, TX lab.
What your drive is doingRecovery tierCostDeposit
Your drive works, you just need the data moved off itSimple Copy$100No deposit
Your drive isn't recognized by your computer, but it's not making unusual soundsFile System RecoveryFrom $250No deposit
Your drive is completely inaccessible. It may be detected but shows the wrong size or won't respondFirmware Repair$600–$900No deposit
Your drive is clicking, beeping, or won't spin. The internal read/write heads have failedHead Swap$1,200–$1,50050% deposit
Your drive was dropped, has visible damage, or a head crash scraped the plattersSurface / Platter Damage$2,00050% deposit
Rush is optional: +$100 rush fee to move to the front of the queue. Helium-sealed enterprise drives (Exos, Ultrastar, MG08) run on a separate list, $200–$5,000+, with the refill performed in-house after the sealed chamber is opened. Once you have spotted your row, the full in-house hard drive recovery walkthrough covers what happens on the bench after the drive lands in Austin.
Cost comparison04/15
How Do Data Recovery Costs Compare Between Labs?
Rossmann publishes five fixed hard drive tiers before you ship: $100, From $250, $600–$900, $1,200–$1,500, and $2,000. Large corporate labs quote a broad range up front and bill at or near the ceiling. Labs that require a call for a quote control the information asymmetry.
ProviderPrice RangePricing ModelNo Data, No Fee
Rossmann Group$100 simple copy or From $250 file system recovery
$600–$900 (Firmware)
$1,200–$1,500 (Head Swap)
Published tiers, firm quote after free evaluationYes
National Lab
Industry Estimate
$2,000 - $7,000+Call for quoteVaries
Corporate Lab
Industry Estimate
$800 - $3,000+Call for quoteVaries
Competitor prices are industry estimates based on published customer reports and competitor pricing pages (2024-2025). Actual quotes vary by case.
Wide-Range Quotes vs. Flat-Rate Tiers
Large corporate labs quote a broad range up front, then bill at or near the ceiling once the work is done. By the time the final invoice arrives, you have already shipped your drive, waited weeks, and have no realistic alternative. The incentive structure rewards quoting high and delivering a number that matches.
We publish our rates on this page before you ship anything. After a free hands-on evaluation, you get a firm number locked to the specific failure type. If the quote does not work for you, we return your drive for a flat return shipping fee. For a full breakdown of how large-lab pricing operates, read our DriveSavers pricing analysis.
Detailed Pricing Table05/15
What Does Data Recovery Cost by Failure Type?
Hard drive data recovery cost is set by what broke. Logical issues (deleted files, corrupted partitions) run $100 to From $250. Firmware repair using PC-3000 costs $600–$900. A head swap with donor parts costs $1,200–$1,500. Platter surface damage starts at $2,000.
The cost of data recovery depends primarily on what is wrong with your drive. A simple file deletion is cheap to fix; a mechanical head crash requires expensive donor parts and hours of clean bench work. If you are unsure whether your drive needs repair or recovery, that distinction affects pricing.
  • Logical Recovery
    $500-$1,500
    ~3.0x more
    Software imaging and file system repair. Drive reads normally.
  • $100 simple copy or From $250 file system recovery
    $500-$1,500
    ~3.0x more
    Partition table repair, MBR/GPT rebuild, RAW file system recovery.
  • $600–$900
    $1,000-$2,500
    ~2.8x more
    ROM transfer, translator repair, Service Area patching via PC-3000.
  • From $250 to $600–$900
    $800-$1,500
    ~1.7x more
    TVS diode replacement, ROM chip transfer, motor driver repair.
  • $1,200–$1,500
    $2,000-$7,000+
    ~5x more
    Clean bench head transplant from donor drive, careful imaging.
  • $1,200–$1,500
    $2,000-$7,000+
    ~5x more
    Head unstick procedure, often followed by head swap.
  • $200–$1,500
    $1,000-$7,000+
    ~5x more
    5 tiers: simple copy, file system, PCB repair, firmware, advanced board rebuild.
  • Quoted after evaluation
    $3,000-$10,000+
    ~2.0x more
    Multiple drive imaging, array reconstruction, per-member recovery.
  • Evaluation Fee
    FREE
    Free (but check)
    We diagnose and quote for free. Some shops charge $50-$150.
Hard Drive Recovery Cost by Failure Tier
Hard drive recovery cost is set by what broke, not by brand, capacity, or how full the drive is. Rebuilding a translator module in PC-3000 takes the same reverse-engineering work on a 500GB drive as on an 8TB one, so the tiers below are priced by the failure class the drive falls into at intake. Every number is pulled from the same published hard drive recovery price list the lab works off.
Failure TierHard Drive Recovery CostWhat the Tier CoversTypical ETA
Simple Copy$100Functional drive; data transfer to new media3-5 business days
File System RecoveryFrom $250File system corruption. Accessible with professional recovery software but not by the OS2-4 weeks
Firmware Repair$600–$900Firmware corruption: ROM, modules, or translator tables corrupted; requires PC-3000 terminal access3-6 weeks
Head Swap$1,200–$1,500Head stack assembly failure. Transplanting heads from a matching donor drive on a clean bench4-8 weeks
Surface / Platter Damage$2,000Platter scoring or contamination. Requires platter cleaning and head swap4-8 weeks
CMR vs SMR pricing:
SMR (Shingled Magnetic Recording) drives require more work at the firmware and head-swap tiers due to their overlapping track architecture.
Donor drive cost:
Rush option:
Large-capacity drives:
For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra.
Hard Drive Data Recovery Cost at a Glance
Hard drive data recovery cost at Rossmann Repair Group runs $100–$2,000 across 5 published failure tiers. Simple copy off a working drive is $100. File system recovery on a drive that spins fine but is not recognized starts at From $250. Firmware repair using PC-3000 terminal access is $600–$900. A head swap with donor parts on a clean bench is $1,200–$1,500. Platter surface damage with combined head swap and platter cleaning starts at $2,000.
The same numbers apply whether the search phrase is hard drive data recovery cost, hard disk recovery cost, or hard drive recovery price. Every tier above is the published rate the lab works off for in-house hard drive data recovery in Austin, TX. There is no diagnostic fee and no recovery fee if data cannot be returned.
Three things move the final hard drive data recovery cost inside a given tier: donor drive availability, capacity, and rush. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Capacity surcharge: For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra. Rush option: +$100 rush fee to move to the front of the queue. Sealed helium drives (Exos, Ultrastar, MG08) are quoted from a separate helium price list because the recovery procedure requires a helium refill step.
If the quoted hard drive data recovery cost feels high relative to other services, this breakdown of where the money goes explains the equipment, donor inventory, and clean bench time priced into each tier.
Per-Service Pricing Breakdown06/15
What Does Data Recovery Cost by Device Type?
Hard drive recovery runs $100–$2,000 across the 5 tiers above. SATA SSD recovery runs $200–$1,500. NVMe SSD recovery runs $200–$2,500. iPhone board-level recovery is a flat $500 for pre-X models and a flat $750 for iPhone X and newer. RAID array recovery is quoted after evaluation based on member count and failure type.
All prices below are published Rossmann Repair Group rates.
SATA SSD Data Recovery Cost
SSD works; data transfer to new media
SSD not recognized but no physical damage
Failed voltage regulators, dead PMICs, shorted capacitors
ROM or module corruption; PC-3000 terminal work
Advanced Board Rebuild
Micro-soldering to revive logic board (50% deposit)
Five published tiers. No data, no charge.
iPhone Data Recovery Cost
iPhone Pre-X Models
Older models with single-layer logic boards
$500
iPhone X and Newer
Board-level work on complex dual-layer (sandwiched) logic boards
$750
Board-level recovery. No data, no charge.
RAID & NAS Recovery Cost
Member Imaging (per drive)
Logical or firmware issues on individual array members
Array Reconstruction
Offline rebuild of RAID layout and parity
Mechanical Member (per drive)
Head swap or platter work on individual members
HDD tier per failed member
Per-drive pricing plus reconstruction fee.
See also: NAS recovery details
USB & Flash Media Recovery Cost
USB Flash Drive (Logical)
Simple copy or file system corruption
$200 to $300–$600
USB Flash Drive (Controller/PCB)
Controller failure requiring chip-level work
USB/SD NAND Chip-Off
Physical NAND extraction for monolith drives (50% deposit)
SD / microSD Recovery
Simple copy to chip-off extraction
$200–$1,500
Helium Hard Drive Recovery Cost
Sealed helium drives (Seagate Exos, WD Ultrastar HC, Toshiba MG08) cost more to recover than standard air-breather HDDs. Opening the sealed chamber requires a controlled environment, and head swaps need helium refill (+ helium cost ($400-$800) + donor drive + tax + target drive). The donor drive must match the exact model, firmware revision, and head map. These enterprise drives use higher platter counts and tighter tolerances, making mechanical recovery more labor-intensive than a standard 2- or 3-platter consumer drive.
    From $600
    Helium drive firmware recovery is more complex due to sealed chamber architecture
    Your helium drive is clicking, beeping, or won't spin. The internal read/write heads have failed
    50% deposit required (usually $1,100 non-refundable deposit). Helium cost ($400-$800) and donor drive cost additional.
    $3,000–$4,500
    $4,000–$5,000
Helium cost
NVMe SSD Recovery Cost
NVMe SSDs use a different bus protocol and controller architecture than SATA SSDs. Recovery requires PC-3000 SSD with NVMe-specific adapters. NVMe controllers (Phison E12, E18; Samsung Elpis; WD/SanDisk in-house) implement AES hardware encryption bound to the controller silicon, so chip-off NAND extraction yields ciphertext that cannot be decrypted without the original controller. Recovery focuses on coaxing the original controller back into a readable state via firmware repair, not desoldering the NAND.
The destination drive we copy recovered data onto. You can supply your own or we provide one at cost plus a small markup. All prices are plus applicable tax.
USB Flash Drive and SD Card Recovery Cost
Flash media recovery ranges from simple file system repair to full chip-off NAND extraction. Monolithic flash drives (where the controller and NAND are fused into a single package) require direct pin-out identification and raw data reconstruction. Standard USB flash drives with discrete NAND chips are less expensive to recover than monolithic devices.
    $300–$600
    PCB Repair
    Chip-off Data Recovery
Controller-Specific Firmware Failures and Recovery Prices
The $600–$900 firmware recovery price applies across SSD controller families because the engineering labor is similar: connect the drive to PC-3000 in technological mode, bypass the corrupted boot sequence, and reconstruct the Flash Translation Layer from surviving NAND page data. The specific controller determines which mode and command set the technician uses, not the price tier.
Silicon Motion SM2259 and SM2258
These controllers enter a context-table checksum failure when firmware panics during a write operation or when NAND degradation corrupts the boot area. The drive appears in Disk Management showing exactly 0 bytes of capacity. Consumer SSD recovery software requires a valid block device capacity to scan and will not detect the drive. PC-3000 SSD uses Vendor Specific Commands to bypass the stalled boot sequence, read surviving NAND pages directly, and rebuild the FTL mapping tables. Price: $600–$900.
Phison PS3111-S11
When this controller loses access to the FTL after an unclean shutdown or excessive NAND wear, the drive resets its identity string to "SATAFIRM S11" in BIOS. The drive appears to be a different device entirely. Recovery requires connecting via PC-3000, entering Phison Technological Mode, and rebuilding the translator from the NAND directly. Price: $600–$900.
Phison PS5012-E12
When this PCIe NVMe controller suffers a firmware panic from sudden power loss or NAND wear, it drops off the PCIe bus entirely or reports 0 bytes. Unlike the SATA S11 lockout, there is no altered identity string; the drive simply disappears from BIOS or appears as an unallocated volume. Recovery requires PC-3000 Portable III to force the controller into diagnostic mode and rebuild the FTL mapping tables from surviving NAND data. Price: $900–$1,200.
Both failure types fall under the drive not detected symptom category. If your SSD shows 0 bytes, displays "SATAFIRM S11," or is invisible to the operating system, the firmware recovery price tier applies.
Laptop Data Recovery Cost07/15
What Does Laptop Data Recovery Cost?
Laptop data recovery costs depend on the drive type, not the laptop brand. Older laptops with 2.5-inch mechanical drives follow HDD pricing: $100 for a data copy, $600–$900 for firmware repair, and $1,200–$1,500 for a head swap. Modern laptops with NVMe SSDs follow SSD pricing: $200–$2,500.
Laptop recovery cost depends on the drive inside the machine, not the laptop brand. Older laptops (pre-2018) typically contain 2.5-inch mechanical drives. These follow standard HDD pricing: $100 for a data copy, $600–$900 for firmware repair, and $1,200–$1,500 for a head swap. Dropped laptops frequently cause stiction in 2.5-inch drives (heads stuck to platters), which falls in the $1,200–$1,500 tier.
Modern laptops (2019+) use soldered NVMe SSDs. Recovery follows SSD pricing: $200–$2,500.
One critical difference: recovering deleted files from a modern laptop SSD is typically impossible. Operating systems issue TRIM commands on file deletion, instructing the SSD controller to discard the data blocks. Software recovery tools cannot retrieve data the controller has already discarded. If the SSD has a controller or firmware failure (not a deletion), recovery through laptop drive recovery follows standard SSD pricing tiers.
Seagate Data Recovery Cost08/15
What Does Seagate Hard Drive Recovery Cost?
Seagate hard drive data recovery costs $100 for a data copy, $600–$900 for firmware corruption requiring PC-3000 terminal access, and $1,200–$1,500 for a head swap on clicking drives. The price is set by the failure mechanism, not by capacity or Seagate model number.
Seagate drive recovery is priced by the failure mechanism, not by capacity or model number. A functioning Seagate Barracuda needing a data copy costs $100. Firmware corruption costs $600–$900 and requires PC-3000 terminal access to repair translator modules or Service Area data. The Seagate Rosewood family (ST1000LM035, ST2000LM007) is one of the most common drives we see for head swaps at $1,200–$1,500; these 2.5-inch slim drives have lower motor torque, making them prone to stiction after drops.
Some competitors price Seagate recovery by capacity (e.g., flat rates for "up to 2TB" or "over 12TB"). That pricing model ignores the actual work involved. A 1TB Seagate with firmware corruption requiring PC-3000 module reconstruction costs $600–$900 regardless of how much data is on the platters. A 4TB Seagate with a simple deletion costs $100. The failure determines the price; the label on the drive does not.
External Hard Drive Recovery Cost08b/15
What Does External Hard Drive Recovery Cost?
External hard drive recovery costs the same as internal drive recovery, $100–$2,000, because the price is set by the internal mechanism's failure, not the plastic enclosure. A simple copy is $100; firmware corruption is $600–$900; a head swap on a clicking drive is $1,200–$1,500. A USB bridge board that died on its own is a separate, lower-cost board repair, not a recovery.
We remove the 2.5-inch internal mechanism from its USB shell and connect it directly; the enclosure brand does not change the failure tier. A Seagate Backup Plus, Seagate Expansion, or Toshiba Canvio is an ordinary hard drive mechanism sitting inside a USB enclosure with a removable bridge board, so it follows the same hard drive recovery tiers.
A simple data copy is $100; firmware corruption is $600–$900; a head swap on a clicking drive is $1,200–$1,500.
The same logic drives our external hard drive recovery service: price the mechanism, not the box around it.
One genuine external-specific wrinkle shows up on modern WD portables like the My Passport. These are native-USB drives: the USB controller is built onto the drive's own circuit board rather than a removable bridge, and WD's hardware encryption is keyed by a wrapped Data Encryption Key stored in the drive's Service Area, which the PC-3000 WD utility reads from the platters.
A physically broken USB port is a board-level repair, not a data loss event, because the key material lives on the drive, not in the port.
The one true dead end is a user-set WD Security password, which we do not promise to defeat. Running chkdsk or Windows "Scan and Fix" on an external drive that keeps dropping offline can overwrite the file table and turn a $600–$900 firmware or bad-sector recovery into a harder logical case; bad sectors are a physical failure of the heads or media, never a logical one.
dd for AIO extraction09/15
What Determines Data Recovery Cost?
Four factors determine the final price: the type of failure, donor parts required, drive capacity, and the lab's overhead structure. Logical issues cost $100 to From $250. Firmware repairs cost $600–$900. Mechanical head swaps requiring exact-match donor drives cost $1,200–$1,500. Labs with marketing overhead charge 2 to 3x more for identical work.
Type of Failure
The single biggest factor. Logical issues cost $100 for a simple copy or From $250 for file system corruption. Firmware corruption requiring PC-3000 terminal access costs $600–$900. Mechanical failures requiring donor heads and clean bench work cost $1,200–$1,500. Each tier reflects the complexity, parts, and time required.
Donor Parts
Head swaps require exact-match donor drives. The donor must share the same model number, firmware revision, and head configuration. Rare or newer models cost more because the donor parts cost more to source. Rossmann maintains a donor inventory to reduce delays and parts costs.
Drive Capacity
Larger drives take longer to image. A 500GB drive might image in hours; an 8TB drive can take days. Imaging time affects labor cost. High-capacity drives (8TB+) also require a larger target drive (~$400+).
Severity of Damage
A clicking drive caught early has better odds than one that was powered on repeatedly or opened at home. More damage means more donor attempts, longer imaging passes, and higher cost. A head crash that scores the platters pushes the case into the $2,000 tier.
Urgency
Simple copies take 3–5 business days. Firmware and complex tiers take 2–8 weeks depending on failure type and donor availability. Rush service is available on any tier: +$100 rush fee to move to the front of the queue.
Lab Overhead
Corporate labs spend on marketing, referral commissions, and walk-in cleanroom facilities. These costs are built into every customer's invoice. Rossmann operates without marketing overhead or referral programs. You pay for engineering work, not advertising budgets.
Referral fee in your quote10/15
Why Do Large Data Recovery Labs Cost More?
A $1,200–$1,500 head swap at Rossmann is the same procedure billed at $2,000 to $7,000 by referral-driven labs because 15%+ commission to the local shop and marketing overhead are baked into the quote. Most people assume the shop accepting their drive is recovering the data. Often it is not. The shop ships your drive to a national lab and collects a percentage of whatever you pay.
Rossmann runs no partner program. There is no middleman cut in your bill.
How the Referral Chain Works
  1. 1You bring your clicking hard drive to a local repair shop.
  2. 2The shop accepts it. They tell you they'll "send it to the lab."
  3. 3Your drive ships to a national data recovery lab: DriveSavers, Ontrack, SalvageData, Gillware, or similar.
  4. 4The lab performs the recovery and charges $3,000 or more.
  5. 5The referring shop collects 15%+ commission. On a $3,000 job, that is $450.
  6. 6You pay the full amount. The shop's contribution was mailing a package.
These are real businesses with real storefronts and real employees. They are not scam operations. They do not do data recovery. The local shop uses language like "our lab" or "our partners," and there is no standard requirement to disclose that your drive is shipping to a third party or that a referral fee is included in your bill.
These Referral Programs Are Public
The labs themselves advertise these programs in their own marketing materials, pitched directly at repair shops looking for additional revenue:
  • National labs run "Reseller Referral Partner Programs" with thousands of business partners. Their pitch to shops: "earn passive income" with "no equipment needed" and no signup fees. Each partner gets a unique Partner ID to track referrals and earns commission on every successful recovery with no monthly cap.
  • Corporate labs offer Partner Programs starting at 15% commission on successful recoveries, scaling with volume. Partners receive custom ID-coded brochures and co-branded marketing materials designed to create the impression the customer is getting a "special discount" through the local shop.
  • Other competitors run "Authorised Partner Programs" that pay a percentage of total fees from signed customer agreements. Partners receive training materials and "Authorised Partner status" branding.
  • Legacy labs claim to be "approved and preferred by 5,000+ providers" and offer discounted reseller rates or direct referral commissions.
Best Buy and Geek Squad: The Model Everyone Recognizes
Geek Squad is the most visible version of this outsourcing model. They handle simple logical recoveries (deleted files, basic corruption) in-store. Firmware failures and mechanical problems get shipped to "Geek Squad City" or outsourced to partners. Ontrack has historically served as their exclusive recovery provider for complex cases.
Big-box retail Level 3 data recovery pricing typically starts around $1,450 in labor plus diagnostic fees. The destination drive for your recovered data is often not included. Compare that to our head swap published head swap tier of $1,200–$1,500, which covers the full recovery.
The difference: we own the lab, the equipment, and the process. There is no middleman. The technician who diagnoses your drive is the one who performs the recovery.
Hidden Fees That Inflate the Bill
Beyond referral commissions, some labs build in fees that guarantee revenue even when the recovery fails or you change your mind. Documented examples of bait-and-switch pricing in data recovery show discounts of 30-90% after customers decline initial quotes.
National labs:
Cancellation fee of $200 or 20% of the quoted price, whichever is greater, if you cancel after approving a quote.
Various labs:
Non-refundable "attempt fees" or "parts deposits" on difficult cases. Revenue is guaranteed even when the recovery fails.
Big-box retailers:
Diagnostic fees charged before any work begins.
What Rossmann Charges
Evaluation fee:
$0. We diagnose your drive and provide a firm quote at no cost.
Diagnostic fee:
$0. Included in the free evaluation.
Cancellation fee:
$0. Decline the quote, we return your drive.
Return shipping on failed recovery:
$0 on qualifying jobs under our No Data, No Charge policy.
Referral commission baked into price:
$0. We do not run a partner program. There is no middleman cut in your bill.
Related: Virtual Offices & Cleanroom Overhead11/15
Virtual Offices Are a Separate Problem
The referral shops above are real businesses at real addresses. A different pattern: some data recovery companies list dozens of "locations" on Google Maps that are virtual offices, Regus suites, or UPS Store mailboxes. There is no lab, no staff, no equipment at the address. Your drive ships to a centralized facility elsewhere.
We investigated this pattern and documented which companies do it. In Austin, a Google Local Guide visited two listed data recovery addresses and found no lab at either location.
Cleanroom Overhead Added to Your Bill
National labs cite Class 5 walk-in cleanrooms to justify $2,000–$5,000+ quotes. For the vast majority of mechanical recoveries, a validated laminar-flow bench achieves the same contamination control at the drive surface. The bench costs under $5,000. The walk-in cleanroom costs six figures. The recovery outcome is the same.
Read our full analysis of cleanroom requirements vs. laminar-flow benches.
Why Data Recovery Costs What It Does12/15
Why Does Professional Data Recovery Cost So Much?
A $1,200–$1,500 head swap covers a PC-3000 system, a 0.02 micron ULPA-filtered clean bench, exact-match donor inventory, and hours of multi-pass imaging on DeepSpar Disk Imager. A $600–$900 firmware repair pays for PC-3000 Service Area access and translator reconstruction. The price tracks the tools, parts, and engineering time each tier consumes.
Data recovery is not like replacing a phone screen. It requires specialized equipment, years of training, and significant time investment per case.
Equipment Costs
  • PC-3000: professional firmware and imaging systems (Portable III, Express, or SSD)
  • DeepSpar DDI: dedicated hardware imaging system
  • Clean bench: ULPA filtration for open-drive work
  • Microscopes: precision optics for head and board work
  • Donor inventory: spare drives stocked across model families
  • Software licenses: Annual fees for forensic tools
Time Investment
  • Diagnosis: 30 minutes to 2 hours per drive
  • Imaging: Hours to days depending on capacity and damage
  • Mechanical work: 1-4 hours of clean bench time
  • Recovery: Hours of file system analysis
  • Verification: Checking recovered files open correctly
  • Some cases span weeks with multiple recovery attempts
Recovery Engineering at Each HDD Price Tier13/15
What Recovery Engineering Happens at Each Price Tier?
Each pricing tier reflects a different category of engineering work. Tier 1 ($100) is a hardware-level data copy using DeepSpar. Tier 2 (From $250) rebuilds corrupted file system metadata. Tier 3 ($600–$900) requires PC-3000 Service Area access. Tier 4 ($1,200–$1,500) is a clean bench head transplant with donor matching. Tier 5 ($2,000) adds platter cleaning before imaging.
Tier 1: Simple Copy ($100)
The drive is functional but the owner can't access or transfer data normally. We connect it to a DeepSpar Disk Imager or PC-3000 Data Extractor, bypassing the operating system entirely. The hardware imager controls the SATA link directly, setting custom read timeouts at the millisecond level so a single bad sector doesn't stall the entire transfer.
Consumer software relies on the OS storage stack, which forces the drive into aggressive retry loops on failing sectors. Each retry drags degraded heads across the same magnetic tracks, generating debris & accelerating damage. The DeepSpar skips unstable sectors on the first pass, images all stable data, then returns to problem areas with progressively shorter timeout windows. A $100 copy using professional hardware is not the same operation as dragging files in Windows Explorer.
Tier 2: File System Recovery (From $250)
The drive spins & is detected, but the partition table, MBR/GPT, or file system metadata is corrupted. This happens after accidental formatting, abrupt power loss during a write, or a failed OS update that damaged the volume header. The platters & heads are fine; the problem is in the logical structure that maps file names to physical sectors.
We image the drive first (protecting the original), then reconstruct the file system from the clone. For NTFS volumes, this means rebuilding the Master File Table. For HFS+/APFS, it means reconstructing the Catalog File or Object Map. For ext4, we parse the journal & inode tables.
The price starts at From $250 because the physical drive is healthy; the engineering work is in metadata reconstruction, not mechanical intervention.
Tier 3: Firmware Repair ($600–$900)
The drive powers on, may spin normally, but is not detected by the BIOS or reports 0 bytes. The problem is in the drive's firmware: a hidden set of modules stored in a reserved area of the platters called the Service Area (SA). The SA contains the translator tables, defect lists, adaptive parameters, & ROM data the drive needs to function. When any of these corrupt, the drive becomes a brick.
Recovery requires PC-3000 Portable III or PC-3000 Express to force the drive into factory/technological mode, bypassing standard SATA communication. The technician reads the corrupted SA modules, identifies which ones failed, and patches or rebuilds them. Common repairs include clearing an overflowed defect reallocation list (Module 32 on Western Digital drives), rebuilding the translator table that maps logical addresses to physical sectors, and regenerating corrupted ROM data.
SMR drives cost more ($900) because they add a second translation layer, such as the Media Cache Management Table (MCMT) or T2 translator. When firmware corruption hits an SMR drive, the technician must reconstruct both the primary translator and the Media Cache mapping tables that manage the overlapping track geometry. CMR drives have a simpler translator structure and cost $600.
Tier 4: Head Swap ($1,200–$1,500)
A clicking or beeping drive has failed read/write heads. The head stack assembly must be replaced with parts from a compatible donor drive, performed in a 0.02 micron ULPA-filtered clean bench. The high cost reflects donor sourcing, the precision of the transplant, & the imaging time afterward.
Donor matching is the bottleneck. A donor drive must share the same model, firmware revision, head count, & compatible preamplifier circuitry.
For Western Digital Marvell-architecture drives, the microjog values (radial alignment offsets between the read and write elements, stored in ROM) must fall within a narrow tolerance range. For Seagate, the firmware family & site code must align exactly. Incompatible donors crash within seconds of spin-up, destroying themselves & potentially the patient platters.
After transplant, the PC-3000 reads the original adaptive parameters from ROM & adjusts them for the donor head tolerances. The drive is then imaged immediately using DeepSpar or PC-3000 Data Extractor in multi-pass mode, prioritizing stable sectors before approaching any weak areas. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Tier 5: Platter Surface Damage ($2,000)
A head crash physically gouges the ferromagnetic coating off the platter surface, generating microscopic debris. This debris embeds into undamaged tracks & acts as an abrasive that destroys any newly installed donor heads within minutes. Recovery at this tier combines platter cleaning, head swap, & targeted multi-pass imaging.
Before installing donor heads, the platters are inspected under magnification & cleaned to remove loose particulate. If the drive arrived with stiction (heads seized to the platter surface), model-specific head combs separate the sliders without shearing the mechanisms or scratching additional media.
On multi-platter drives where one surface is deeply scored, the technician physically removes the corresponding head from the donor stack and uses the PC-3000 to electronically disable it in RAM. This lets the remaining platter surfaces be imaged without the donor stack crashing into the scored zone.
The Data Extractor builds a media scan map, skips the physically damaged LBA ranges on the first pass, then returns with reverse imaging & modified timeout parameters to extract residual data from the periphery of the scratch rings.
Board Failure vs Head Swap13b/15
Does a Failed Circuit Board Cost the Same as a Head Swap?
No. A failed circuit board with intact heads & platters routes to the $600–$900 board-repair and ROM-transplant tier, while a clicking drive that needs a clean-bench head swap routes to the $1,200–$1,500 tier. The free evaluation tells the two apart before any quote, and a board-only fault never gets clean-bench head work.
The free evaluation routes the quote before the lid ever comes off. A board fault & a head fault look identical from the outside (a drive that simply won't mount), but they read as two different faults on the bench. We watch current draw on a lab supply, sweep a FLIR thermal camera across the printed circuit board to find any component pulling current it shouldn't, and listen to spin-up against click acoustics. A shorted board usually shows a dead short on a power rail & a component heating under the FLIR lens; a failed head shows normal current draw with a clicking actuator that never settles into a read.
A drive that took a power surge often shows a shorted transient-voltage-suppression diode. That diode is a protective crowbar: it is designed to fail as a dead short and clamp the rail to ground so the surge never reaches the motor-controller IC behind it. If instead the diode fails open, the surge passes straight through & can take out the voltage regulator it was meant to guard. Either way, the heads & platters are usually untouched, which is what moves the case onto the electronics path rather than the mechanical one.
Dropping a bare donor board onto the drive almost never works, & that is the single most common way a DIY board swap finishes off a recoverable drive. The original board carries a small serial-flash ROM holding adaptive data unique to your drive, the calibration the heads & preamp were tuned to at the factory. A donor board runs its own, wrong, adaptives. A real board repair migrates that ROM and adaptive content onto the matched donor board on the PC-3000 Portable III, or replaces the shorted protective component on your original board so the rest of the electronics power back up. We describe these by function because the exact part changes from model to model, & guessing a part number off a forum is how a recoverable board becomes an unrecoverable one.
Here is where each one lands on the published scale. A board repair with a ROM and adaptive transplant sits at the $600–$900 firmware-repair tier, because the work is electronic & firmware-level rather than mechanical. A clean-bench head transplant sits at the $1,200–$1,500 head-swap tier, since it consumes a matched donor head stack inside the 0.02 micron ULPA-filtered clean bench. A board whose data was never at risk, where the platters & heads are healthy and the electronics just need the drive talking again, can drop to the $100 simple-copy tier once it images cleanly. The principle holds across the whole scale: the further a failure pushes us toward consumable donor parts & clean-bench mechanical work, the higher the tier, and a pure electronics fault stays at the low end.
Every one of these starts with the same free evaluation, carries no diagnostic fee, and runs under No Data, No Charge, all in-house at our Austin, TX lab. See how the board path and the mechanical path fit into the full failure-tier breakdown on the hard drive data recovery overview.
Cost Drivers By Tier13c/15
What Drives the Cost Difference Between Recovery Tiers?
The tier itself is set by two drivers: where the labor happens (PC-3000 terminal time versus open-chamber clean-bench occupancy versus a board-repair bench) and whether a consumable donor is harvested. Two more factors move the timeline but not the price: how long a donor takes to source and how many imaging hours the capacity adds. A firmware repair stays at $600–$900 because it spends terminal time and burns no parts; a head swap reaches $1,200–$1,500 because it consumes a matched donor stack.
Failure TierHard Drive Recovery CostWhere the Labor HappensDonor Parts + SourcingClean-Bench Time
Simple copy$100Host imaging bench. DeepSpar Disk Imager streams a working drive to fresh media.None. No part is harvested.None. The sealed chamber is never opened.
File system recoveryFrom $250Host imaging bench, then metadata reconstruction off the clone in PC-3000 Data Extractor.None. The platters and heads read normally.None. Work runs on the image, not inside the drive.
Firmware repair$600–$900PC-3000 Portable III terminal. Service Area module and translator repair over the diagnostic port.None for a pure firmware fault. Terminal time, not parts.None. The lid stays on; the repair is electronic.
Head swap$1,200–$1,5000.02 micron ULPA-filtered clean bench. Head-stack transplant, then selective imaging.Matched donor head stack consumed. Days to weeks to source a firmware-and-head-map match.Hours of open-chamber bench time per swap, plus imaging.
Surface / platter damage$2,000Clean bench. Platter cleaning, head swap, and reverse multi-pass imaging.Multiple donor head sets often consumed reading scored platters.Longest open-chamber occupancy of any tier.
The table reads the same top to bottom: the further a failure pushes toward consumable donor parts & open-chamber clean-bench work, the higher the tier. A pure firmware or terminal fault stays low because it spends terminal time, not parts or bench-open hours, & capacity only moves imaging hours inside a tier, never the tier itself. See how these drivers sit inside the full failure-tier breakdown on the hard drive data recovery overview, or read what actually gets repaired over the diagnostic port in how hard drive firmware works.
No Data No Charge14/15
No Data, No Charge Guarantee
At Rossmann Repair Group, if we cannot recover your files, you pay nothing for the recovery attempt. Evaluation is always free. You only pay return shipping if you want the original drive back. This no data, no charge policy applies to all cases, regardless of complexity, including head swaps and firmware repairs.
Learn more about our guarantee →
50% Donor Deposit14b/15
How the 50% Donor Deposit Works
Two failure tiers take a 50% deposit before bench work starts: a head swap ($1,200–$1,500) and platter surface damage ($2,000). Both consume donor parts that are physically destroyed during the repair and cannot be returned or resold. The deposit is half of the quoted tier price you already agreed to, not an extra line item on top of it.
A head swap pulls the read/write head stack out of a matched donor drive and transplants it into your drive in a 0.02 micron ULPA-filtered clean bench. Once those heads are harvested, the donor is scrap. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The same logic applies to a platter surface damage recovery at $2,000, where several sets of donor heads are often consumed reading scored platters after the surfaces are cleaned in the ULPA bench.
That is why these two tiers collect 50% up front while the $100 simple copy and $600–$900 firmware repair tiers do not. A simple copy reads a working drive. A firmware repair patches the Service Area through PC-3000 Portable III without opening the drive or burning a donor. No consumable part leaves inventory, so no deposit is needed against parts the lab can never recover.
The deposit does not weaken the No Data, No Charge guarantee. The recovery fee stays contingent on results: if we open your drive, swap the heads, and still cannot pull your files, you pay nothing for the attempt and we return the device at no cost.
The deposit exists because donor parts are physically consumed to even attempt the repair, not as a charge against a failed outcome. Read the exact terms on the No Data, No Charge guarantee page, and see how the deposit sits inside the published hard drive recovery tiers above.
Total Out-of-Pocket14c/15
What Is the Total Out-of-Pocket Cost Beyond the Recovery Tier?
The recovery fee, the published tier matched to your failure, is the bulk of the bill, and it is the only line item the No Data, No Charge guarantee makes contingent on success. A few non-contingent ancillary costs can sit on top depending on the case: a target drive, donor parts on the mechanical tiers, optional rush, tax, and return shipping if you want the original mailed back.
The recovery fee is whatever tier your drive falls into: $100 for a simple copy, From $250 for file system work, $600–$900 for a Service Area firmware repair, $1,200–$1,500 for a head swap, or $2,000 for platter surface damage. That single number is the only part of the invoice the outcome-based guarantee zeroes out if we cannot pull your files.
The other lines below are never charged against a failed attempt either; each one applies only on a job that succeeds and that you accept.
Recovered data has to land somewhere, so a target drive is its own line item separate from the recovery fee. A standard target drive is a small add-on, but capacity drives the cost. For larger capacities (8TB, 10TB, 16TB and above), target drives cost $400+ extra. You can also supply your own blank drive and skip this charge entirely.
Donor parts are billed at cost, and only on the two mechanical tiers: the $1,200–$1,500 head swap and the $2,000 surface damage recovery. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The $100 copy, From $250 file system, and $600–$900 firmware tiers consume no donor at all, because none of them open the drive or harvest a head stack, so no parts cost ever attaches to them.
Rush is optional. +$100 rush fee to move to the front of the queue, so an urgent case adds the flat $100 on top of the tier price. Sales tax applies to the total as it does on any Austin invoice, and return shipping is a real cost only if you ask us to mail the original drive back after the recovery; declining the quote outright still costs nothing toward the recovery itself.
There is no separate diagnostic, attempt, or evaluation fee anywhere in this list.
Helium-sealed enterprise drives run on a separate price list at $200–$5,000+ because opening the sealed chamber adds an in-house helium refill on top of the donor and head work; that work is performed at our Austin bench and never outsourced. The split between a fee that the guarantee can refund by outcome and ancillaries that are real costs on a successful, accepted job is the same across both lists; see how each fee sits inside the five published recovery tiers.
Prior Attempt14d/15
Does a Prior Failed Recovery Attempt Cost More?
Sometimes, yes. A prior attempt can push a drive into a higher published tier, because the tier is set by failure type & a failed attempt can change the failure type itself. Recovery software, a donor-board swap, or opening the drive outside a clean bench can turn a $600–$900 firmware case into a $1,200–$1,500 head swap or a $2,000 surface-damage job.
The published tier is set by what failed, not by how the drive arrived. A working-drive copy is $100, file system work From $250, firmware repair $600–$900, a donor-matched head swap $1,200–$1,500, & platter surface damage $2,000. A prior attempt can move a case up that ladder when it changes the failure type underneath. We never bill you for an attempt that failed somewhere else; we quote the state the drive is in when it lands on our Austin bench.
Recovery software run on a degrading drive is the most common escalator. A drive with reallocated or pending sectors, or one that reads unstably, is a physical failure: the media surface or the read/write heads are giving out, not the file system. Software that keeps hammering a weak head across marginal sectors can finish those heads off, turning a case that might have imaged near the From $250 file-system or $600–$900 firmware level into a $1,200–$1,500 head swap once the heads degrade. Bad sectors & clicking are physical from the first power-on. The software doesn't rewrite a Service Area it can't reach; it runs over standard ATA & stresses the heads.
A DIY donor-board swap can do the same thing for a different reason. The original PCB carries a small serial-flash ROM holding that drive's unique adaptive parameters, & bolting on a bare donor board runs the wrong adaptives. That can leave the original ROM content the only path back. If the original board held the only copy of those adaptives & it gets damaged in the swap, a board-only fault that could have been a $600–$900 ROM & adaptive migration on the PC-3000 Portable III escalates toward firmware & mechanical work.
Opening a drive outside a 0.02 micron ULPA-filtered clean bench is the costliest of these mistakes. Particulate that lands on the platters scores the surface the moment the drive spins back up. That pushes a clean head swap ($1,200–$1,500) toward platter cleaning & surface-damage handling ($2,000), the most consumable-heavy tier we run.
None of this changes the price unless it changed the drive. The free evaluation still tells us the current failure state before any quote, there's still no diagnostic fee, & No Data, No Charge still governs the outcome. We quote the tier the drive is in when it arrives, & we'll tell you honestly if an earlier attempt moved it. See how each tier sits inside the hard drive recovery overview, & read the exact terms on the No Data, No Charge guarantee page.
Donor Drive Cost14e/15
What Affects the Donor Drive Cost on a Mechanical Recovery?
The donor drive is a separate line billed at cost, & it appears only on the two mechanical tiers: the $1,200–$1,500 head swap & the $2,000 surface-damage job. Donor cost tracks scarcity, not your drive's capacity. A donor has to match firmware revision, head count, & preamplifier circuitry, so rare or high-capacity models cost more to source.
The donor is never marked up. We bill it as its own line at the price we paid, kept separate from the $1,200–$1,500 head-swap fee & the $2,000 surface-damage fee. The recovery tier covers the bench work: opening the drive in a 0.02 micron ULPA-filtered clean bench, transplanting the head stack, & migrating the original adaptive parameters. The donor is the physical hardware that work consumes, quoted on top of the tier.
What moves the donor cost is availability, not how much data sits on your platters. A donor has to match the patient drive on firmware revision, head count, & preamplifier circuitry before its heads will track your surfaces, so a common consumer model with millions of units shipped has cheap, plentiful donors, while a rare or high-capacity model has far fewer compatible candidates on the market.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. The exact criteria we check before a part qualifies are laid out in how we match a donor to your drive.
The other three tiers carry no donor cost at all. A $100 simple copy, From $250 file system recovery, & $600–$900 firmware repair never open the drive or harvest a head stack, so there is no part to source & no donor line on the invoice. Firmware work runs entirely through the PC-3000 Portable III against the drive's own Service Area; it spends terminal time, not hardware.
Helium-sealed enterprise drives sit on their own, pricier donor list. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber. Those donors are scarcer than air-drive parts, & the sealed chamber has to be refilled with helium once it's opened, which is part of why the helium recovery range runs $200–$5,000+. We perform that head swap & refill in-house at the Austin bench; the helium mechanical work is never outsourced.
In every case we source the cheapest compatible donor available that still matches; you don't pay for the first part we pull off the shelf. The free evaluation identifies the failure tier & whether a donor is even needed before any quote lands, there's no diagnostic fee, & the No Data, No Charge policy still governs the outcome. See how the donor cost sits beside each tier on the hard drive recovery overview, or read the exact terms on the No Data, No Charge guarantee page.
Faq15/15
Data Recovery Cost: Common Questions
What is the average hard drive recovery cost?
The average hard drive recovery cost at Rossmann Repair Group ranges from $100 for a simple copy off a healthy drive to $2,000 for severe platter surface damage. File system corruption falls at From $250. Firmware corruption requiring PC-3000 Portable III access to the Service Area for translator rebuilds, as well as PCB ROM transplants, falls at $600–$900. A donor-matched head stack swap performed in a 0.02 micron ULPA-filtered clean bench falls at $1,200–$1,500. Helium-sealed enterprise drives carry their own range ($200–$5,000+) with helium refill billed separately on opened-chamber tiers.
Why does physical hard drive recovery cost more than logical?
Physical hard drive recovery cost is higher than logical recovery because mechanical work consumes parts and bench labor that software work does not. A logical recovery on a drive that still reads, priced at From $250, runs through DeepSpar Disk Imager or PC-3000 Data Extractor and consumes no donor parts. A mechanical recovery at $1,200–$1,500 requires sourcing a donor drive matched on firmware revision, head count, and preamplifier circuitry, transplanting the head stack in a 0.02 micron ULPA-filtered clean bench, then reading the original adaptive parameters from ROM. Helium-sealed enterprise drives (Exos, Ultrastar, MG08) require a helium refill after the chamber is opened, which is why the helium HDD recovery cost range runs $200–$5,000+ with refill billed separately on opened-chamber tiers.
Is hard drive recovery cost determined by capacity or by failure type?
Hard drive recovery cost is determined by failure type, not by capacity or by the volume of data on the drive. A 500GB drive and a 10TB drive both fall into the $1,200–$1,500 tier if both need a donor-matched head stack swap. Rebuilding a corrupted translator in the Service Area on the PC-3000 Portable III is the same firmware repair tier ($600–$900) whether the drive holds 1TB or 8TB. Capacity affects imaging time once the drive is stabilized, but it does not change the published tier. The only structural exception is helium-sealed enterprise drives, which carry their own pricing range ($200–$5,000+) because of the sealed-chamber handling overhead.
How much does data recovery cost?
Data recovery pricing depends entirely on the device type and failure mode. Mechanical hard drives at Rossmann Repair Group fall into 5 published tiers spanning $100–$2,000: $100 for a working-drive copy, From $250 for file system corruption, $600–$900 for firmware repair via PC-3000 Portable III, $1,200–$1,500 for a head stack transplant in our 0.02 micron ULPA-filtered clean bench, and $2,000 for platter surface damage. Helium-sealed enterprise drives run $200–$5,000+ with an additional helium refill cost on opened-chamber tiers. SATA SSD work runs $200–$1,500 and NVMe SSD work runs $200–$2,500. Evaluation is free. There is no diagnostic fee, and the No Data, No Charge policy means a failed recovery costs nothing.
How much do data recovery services cost?
Honest data recovery services publish their pricing by failure category instead of quoting per gigabyte or hiding behind a non-refundable diagnostic fee. Our published rates: hard drive recovery $100–$2,000, helium HDD recovery $200–$5,000+ (helium refill billed separately on opened-chamber tiers), SATA SSD $200–$1,500, NVMe SSD $200–$2,500, and flash media $200–$1,500. Marketing-heavy labs typically charge two to three times these amounts for the same PC-3000 and DeepSpar Disk Imager work because their prices fund advertising spend and referral commissions. Rossmann Repair Group operates one Austin lab with no franchises, no outsourcing, no diagnostic fees, and no charge if the recovery fails.
Hard drive data recovery costs $100–$2,000 at Rossmann Repair Group across 5 published tiers: $100 simple copy, From $250 file system recovery, $600–$900 firmware repair on PC-3000 Portable III, $1,200–$1,500 donor-matched head stack swap, and $2,000 platter surface damage. The hard drive recovery cost is set by the failure type, not by capacity or data volume, and the starting point of From $100 applies to a working drive that simply needs its data moved off. Helium-sealed enterprise drives (Exos, Ultrastar, MG08) run $200–$5,000+ with helium refill billed separately on opened-chamber tiers. Evaluation is free, there is no diagnostic fee, and the No Data, No Charge policy means a failed recovery costs nothing. You can compare data recovery prices across all our device tiers on the central pricing page, or read the full hard drive data recovery service page for the recovery methodology behind each tier.
How much does hard disk data recovery cost?
Hard disk data recovery costs $100–$2,000 across 5 published tiers. "Hard disk" and "hard drive" refer to the same mechanical storage device, so the pricing is identical: $100 for a simple copy from a healthy hard disk, From $250 for file system corruption, $600–$900 for firmware repair via PC-3000 Portable III, $1,200–$1,500 for a head stack swap with matched donor parts, and $2,000 for platter surface damage recovered on a 0.02 micron ULPA-filtered clean bench. Evaluation is free; no charge if the hard disk cannot be recovered.
What is the hard drive recovery price for each failure type?
The hard drive recovery price ranges from $100 to $2,000 across 5 fixed tiers. A simple copy from a healthy drive costs $100. File system recovery costs From $250. Firmware repair via PC-3000 Portable III access to the Service Area costs $600–$900. A donor-matched head stack swap performed in a 0.02 micron ULPA-filtered clean bench costs $1,200–$1,500. Platter surface damage starts at $2,000. Evaluation is free, and a failed recovery costs nothing under the No Data, No Charge policy.
What are hard drive data recovery prices at this lab?
Hard drive data recovery prices at Rossmann Repair Group are $100 for a simple copy, From $250 for file system recovery, $600–$900 for firmware repair on PC-3000, $1,200–$1,500 for a head stack swap with matched donor parts, and $2,000 for platter surface damage. These 5 hard disk data recovery cost tiers are published before you ship; there is no diagnostic fee and no charge if recovery fails. +$100 rush fee to move to the front of the queue.
Is the donor drive included in the head swap price, or is it a separate cost?
The donor drive is a separate line billed at cost, not folded into the head swap fee. It appears only on the two mechanical tiers, the $1,200–$1,500 head stack swap and the $2,000 surface-damage recovery, because those are the only jobs that open the drive and harvest parts. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Donor cost tracks scarcity rather than your drive's capacity: a donor must match firmware revision, head count, and preamplifier circuitry, so a rare or high-capacity model has fewer compatible donors and costs more to source. The $100 copy, From $250 file system, and $600–$900 firmware tiers consume no donor and carry no donor line at all. Helium-sealed enterprise drives use a separate, pricier donor list with an in-house helium refill, which is reflected in their $200–$5,000+ range.
Why is professional data recovery so expensive?
Professional data recovery requires specialized equipment (a PC-3000 system), trained technicians, clean bench facilities, donor drive inventory, and significant time per case. Each case is unique. A head swap requires sourcing an exact-match donor drive, transplanting heads in a particle-free environment, then imaging the drive sector by sector. That process takes hours to days.
Is data recovery worth the cost?
Yes, when the data is irreplaceable. If the files exist nowhere else, professional recovery is the only option for mechanical or firmware failures. Recovery software cannot fix a clicking drive or corrupted firmware. The alternative is permanent data loss. We provide a free evaluation with honest recovery odds before you commit to any cost.
Is there a fee if you cannot recover my data?
No. Our No Data, No Charge policy means you pay nothing if we cannot recover your files. Evaluation is always free. You only pay return shipping if you want your original drive back after an unsuccessful recovery attempt.
Why is Rossmann cheaper than DriveSavers?
DriveSavers spends on marketing, Apple partnerships, and referral commissions to computer repair shops. These costs are built into their prices. We use the same professional equipment but operate without marketing overhead. You pay for engineering work, not advertising budgets.
What does a hard drive head swap involve?
A head swap replaces the failed read/write head stack assembly with parts from a compatible donor drive. The procedure is performed in a 0.02 micron ULPA-filtered clean bench. The donor drive must match the patient's model, firmware revision, head count, & preamplifier circuitry. After transplant, the PC-3000 reads the original adaptive parameters from ROM & adjusts them for the donor head tolerances. The drive is then imaged using DeepSpar or PC-3000 Data Extractor in multi-pass mode. This is why the head swap tier costs $1,200–$1,500.
Why does firmware repair require PC-3000 hardware?
Hard drive firmware lives in a hidden reserved area of the platters called the Service Area. Standard SATA communication cannot access these modules. The PC-3000 Portable III or PC-3000 Express forces the drive into factory/technological mode, bypassing normal communication to read & patch corrupted firmware modules directly. Common repairs include clearing overflowed defect reallocation lists, rebuilding translator tables that map logical addresses to physical sectors, & regenerating corrupted ROM data. No consumer software can perform these operations.
How are donor drives matched for a head swap?
Donor matching requires more than buying the same model number. The donor must share the exact firmware revision, head count, & compatible preamplifier circuitry. For Western Digital Marvell-architecture drives, the microjog values (radial alignment offsets between the read and write elements, stored in ROM) must fall within a narrow tolerance range. For Seagate drives, the firmware family & site code must align exactly. Incompatible donors crash within seconds of spin-up. Sourcing a compatible donor can take days to weeks depending on the drive model & availability. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
How do I get an accurate data recovery quote?
Ship your drive to our Austin lab for a free evaluation. We diagnose the problem, determine exactly what work is needed, and provide a firm quote before any billable work begins. No surprises, no bait-and-switch pricing.
Should I try data recovery software first?
Only if your drive is healthy (no clicking, beeping, or slow reads). If the drive has physical symptoms, running software forces it to work harder and can destroy recoverable data.
How much does it cost to recover data from an external hard drive?
External hard drive recovery costs $100–$2,000 depending on the failure type, identical to internal drive pricing. We remove the drive from its USB enclosure and connect directly via SATA, bypassing the USB controller. The enclosure brand does not change the price. Enclosure electronics failures (USB bridge board) are a separate, lower-cost repair.
Does it cost more to recover a high-capacity hard drive?
No. Recovery pricing is set by the failure type, not by the drive's storage capacity. A 500GB drive and a 10TB drive both cost $1,200–$1,500 if they need a head swap. Repairing a corrupted translator table requires the same PC-3000 session whether the drive holds 1TB or 8TB. Larger drives take longer to image once stabilized, but imaging time does not change the price tier. The only exception is helium-sealed drives (typically 10TB+), which cost more due to the specialized atmosphere and equipment required to open them safely.
Does SSD data recovery cost more than hard drive recovery?
SATA SSD recovery ranges from $200–$1,500, while HDD recovery ranges from $100–$2,000. Simple SSD recoveries cost slightly more because the failure modes differ: SSDs fail at the controller or firmware level, requiring PC-3000 SSD terminal access or NAND chip-off reads. HDDs fail mechanically or at the firmware level. The most expensive HDD cases, platter damage at $2,000, exceed the most expensive standard SATA SSD cases.
What is the average cost of hard drive data recovery?
The average hard drive recovery cost depends on the failure type. A data copy from a functioning drive costs $100. File system recovery starts at From $250. Firmware repair for drives not detected by the computer runs $600–$900. A head swap for clicking or beeping drives costs $1,200–$1,500, with a 50% deposit because donor parts are consumed during the procedure. Platter damage recovery starts at $2,000. We provide a firm quote after a free evaluation; no data recovered means no charge.
How much does it cost to recover a 1TB hard drive?
A 1TB hard drive recovery costs $100 to $1,200–$1,500 for most recoverable failures, depending on the failure type, not the capacity. A 1TB drive with deleted files costs $100. Firmware corruption on a 1TB drive costs $600–$900. A 1TB drive with a head failure costs $1,200–$1,500. Capacity affects imaging time depending on read speed and bad sectors, but the pricing tier is set by the type of failure, not the number of terabytes.
Do you charge per gigabyte for data recovery?
No. Data recovery is priced by failure type and the engineering labor required, not by the amount of data on the drive. Rebuilding a corrupted translator module in PC-3000 takes the same reverse-engineering work whether the drive holds 500GB or 8TB. Labs that quote per-gigabyte are pricing storage transfer, not recovery engineering. Our five published tiers are set by what broke, not by how full the drive is.
How much does it cost to recover deleted files from a modern laptop SSD?
In most cases, deleted files on a modern NVMe or SATA SSD cannot be recovered at any price. Current operating systems issue TRIM commands immediately upon file deletion, instructing the SSD controller to discard the underlying data blocks. Once TRIM executes, the data is gone. Be cautious of labs charging non-refundable diagnostic fees for SSD deleted-file recovery; the physics of NAND flash makes this a losing proposition on any TRIM-enabled drive.
Laptop data recovery costs $100–$2,000 for older 2.5-inch mechanical drives, depending on failure type. HDD laptop work follows $100 for a data copy, $600–$900 for firmware repair, $1,200–$1,500 for a head swap, and $2,000 for platter damage. Modern laptops with NVMe SSDs follow NVMe SSD pricing: $200–$2,500. The drive type matters more than the laptop brand.
Seagate data recovery costs $100–$2,000 depending on the failure mechanism. A functioning Seagate drive needing a data copy costs $100. Firmware corruption on Seagate drives costs $600–$900 and requires PC-3000 terminal access. A head swap on a clicking Seagate costs $1,200–$1,500. The price is set by what failed, not by the Seagate model number or drive capacity.
Why does firmware repair on SMR hard drives cost more than older CMR drives?
SMR (Shingled Magnetic Recording) drives use overlapping data tracks managed by a secondary translation layer, such as the Media Cache Management Table (MCMT) or T2 translator. When firmware corruption hits an SMR drive, rebuilding this translation layer in PC-3000 requires patching both the primary translator and the Media Cache mapping tables. On a conventional CMR drive, the translator is simpler: one track per sector, no overlap. Firmware repair on a CMR drive costs $600. The same category of repair on an SMR drive costs $900 because the engineering time to reconstruct the complex secondary translation tables that map the overlapping zones is roughly 50% longer.
What are non-refundable attempt fees in data recovery?
An attempt fee is a charge some data recovery labs collect before starting work on mechanically failed or complex drives. The fee is non-refundable regardless of whether the recovery succeeds. SalvageData publishes attempt fees up to $1,000 on their pricing page. Other labs fold similar charges into "parts deposits" or "evaluation fees" that are not returned on failure. Rossmann charges zero attempt fees, zero evaluation fees, and zero diagnostic fees. If the recovery fails, you owe nothing under our no data, no charge policy.
What does SSD firmware recovery cost for specific controller failures?
SATA SSD firmware recovery prices are $600–$900. NVMe SSD firmware recovery is $900–$1,200 because the NVMe protocol adds complexity. A Silicon Motion SM2259 controller entering a 0-byte capacity state falls under $600–$900; PC-3000 SSD uses Vendor Specific Commands to access the NAND and rebuild the Flash Translation Layer. A Phison PS3111-S11 displaying "SATAFIRM S11" in BIOS falls under $600–$900. A Phison PS5012-E12 experiencing firmware panic falls under $900–$1,200. All require PC-3000 Portable III with controller-specific diagnostic mode access.
Does turnaround time affect the price of data recovery?
Standard turnaround at Rossmann Repair Group ranges from 3 to 8 weeks depending on failure type and donor parts availability. Simple copy jobs finish in 3 to 5 business days. +$100 rush fee to move to the front of the queue. For mechanical failures requiring a head swap, the timeline depends on sourcing an exact-match donor drive with the correct head map and firmware revision. Rush service prioritizes your job regardless of tier.
Does a manufacturer warranty cover hard drive data recovery prices?
No. Manufacturer warranties cover replacement of the defective hardware; they do not cover recovering the data stored on it. Many Seagate drives (IronWolf, BarraCuda Pro) include Rescue Data Recovery Services for two to three years, but standard warranties from Western Digital, Toshiba, and Samsung explicitly exclude data recovery. Using an independent lab does not void the hardware warranty on your replacement drive. For business customers, cyber liability or business continuity insurance policies sometimes reimburse professional data recovery costs when the loss stems from a covered event.
How do I compare data recovery prices between labs?
Ask three questions before shipping your drive. First: does the lab publish fixed pricing tiers, or does it quote a range and bill at the ceiling? Second: are donor parts, transfer media, and return shipping included in the quoted price, or billed separately? Third: what happens if the recovery fails; is the fee refundable, or is it a non-refundable attempt fee? Rossmann publishes five hard drive recovery tiers and five SSD recovery tiers before you ship anything. Labs that require you to call for a quote control the information asymmetry.
What is a reasonable fee for data recovery from a crashed laptop hard drive?
A reasonable data recovery fee depends on the failure type. If the laptop hard drive has a logical issue such as accidental formatting or partition corruption, recovery costs $100 to From $250. Firmware corruption requiring PC-3000 access costs $600–$900. If the drive is clicking due to head failure, a head swap costs $1,200–$1,500 plus a donor drive. Surface damage from heads scoring the platters starts at $2,000. Rossmann publishes 5 fixed pricing tiers. There is no diagnostic fee; if we cannot recover the data, there is no charge.
How much do people pay for hard drive recovery?
Most hard drive recoveries cost between From $250 and $1,200–$1,500. Simple data copies from functioning drives cost $100. The most common failure types are firmware corruption ($600–$900) and head failure requiring donor parts ($1,200–$1,500). Surface damage starts at $2,000. We do not charge diagnostic fees, and our no data, no charge policy means you pay nothing if recovery fails.
What is the typical hard drive recovery cost?
Hard drive recovery cost at our Austin lab ranges from $100 for a simple data copy to $2,000 for platter surface damage. Firmware corruption requiring PC-3000 Portable III access to the Service Area costs $600–$900. A head stack swap using a donor drive matched on firmware revision, head count, and preamplifier circuitry costs $1,200–$1,500, performed in a 0.02 micron ULPA-filtered clean bench. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Evaluation is free, and there is no charge if the data cannot be recovered.
Is hard drive repair price the same as hard drive recovery cost?
No. Hard drive repair price refers to fixing the drive hardware itself, usually a PCB swap with ROM transplant to bring a drive back online when the board has failed but the heads and platters are intact. Hard drive recovery cost refers to extracting the data, which often requires additional work: imaging with DeepSpar Disk Imager or PC-3000 Data Extractor, rebuilding a corrupted translator table in the Service Area, or a full head stack swap. A board-only repair sits at the low end of the $100–$2,000 range. A mechanical recovery sits in the $1,200–$1,500 to $2,000 range.
Why is hard disk recovery cost lower at this lab than at a large advertising-driven lab?
Hard disk recovery cost at a large marketing-driven lab often runs $2,000 to $7,000 or more for a head swap. The same mechanical procedure at this lab costs $1,200–$1,500. The gap is not equipment; PC-3000 Portable III, DeepSpar Disk Imager, FLIR thermal cameras, and 0.02 micron ULPA clean benches are standard across professional labs. The gap is marketing spend, referral commissions paid to computer shops, and layered sales-team compensation. A hard drive recovery service cost that funds those layers is pricing the sales funnel, not the bench work. Rossmann publishes 5 fixed tiers so the customer can see exactly what the work costs before shipping.
How is cost figured when one drive has two failure modes at once?
The drive is priced at the single highest applicable tier, not by adding up a fee for each symptom. If a clicking drive needs a head swap ($1,200–$1,500) and we then find a corrupted translator in the Service Area once it spins, you are not billed the head swap plus a separate $600–$900 firmware repair. One bench session resolves the dominant failure, so the head swap tier absorbs the firmware work that comes with bringing that drive back to a readable state. The only time a number stacks on top is a consumable: a matched donor drive on the head swap and platter tiers, billed at cost (Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.). Surface platter damage ($2,000) is already the ceiling because it bundles platter cleaning, a head swap, and the firmware work to read the result. This is also why a hard drive recovery quote does not balloon after intake the way a per-symptom estimate would.
Do I pay anything if I decline the quote after the free evaluation?
No recovery fee, no diagnostic fee, no evaluation fee. The hands-on evaluation that produces your firm quote is free, so walking away after you see the number costs nothing toward the recovery itself. The only charge on a declined job is return shipping if you want the original drive mailed back; leave it with us and even that is zero. There is no non-refundable attempt fee and no parts deposit on the $100 copy or $600–$900 firmware tiers, since no donor hardware is consumed to quote them. This is the same No Data, No Charge guarantee that applies when a recovery is attempted and fails.
Does it cost more if I already ran recovery software on the drive?
It can, but only if the software changed the failure type. A drive with reallocated or pending sectors, or one that reads unstably, is already a physical failure of the media surface or the read/write heads, not a logical one. Recovery software that keeps hammering a weak head across marginal sectors can finish those heads off, turning a case that might have imaged near the From $250 file-system or $600–$900 firmware level into a $1,200–$1,500 head swap. That software runs over standard ATA & stresses the heads; it does not reach or rewrite the Service Area. The free evaluation tells us the current state, there is no diagnostic fee, & No Data, No Charge still applies to whatever tier the drive is in when it arrives.
Will a prior DIY board swap raise my recovery cost?
Sometimes. The original PCB carries a small serial-flash ROM holding the drive's unique adaptive parameters, & bolting on a bare donor board runs the wrong adaptives. If the original board is damaged during that swap & it held the only copy of those adaptives, a board-only fault that could have been a $600–$900 ROM & adaptive migration on the PC-3000 Portable III can escalate toward firmware & mechanical work, up to the $1,200–$1,500 head-swap tier. We quote the tier the drive is in when it reaches our Austin bench, with no diagnostic fee & No Data, No Charge on the recovery itself.
What am I actually paying for in a data recovery quote?
You pay for where the labor happens & whether a consumable donor part is harvested, not for the gigabytes stored on it. The $100 simple copy & $600–$900 firmware repair buy host-bench or PC-3000 Portable III terminal time and consume no donor hardware. A $1,200–$1,500 head swap buys open-chamber time in the 0.02 micron ULPA-filtered clean bench plus a matched donor head stack that is consumed in the procedure, & $2,000 platter surface damage buys the longest bench occupancy plus several donor head sets. Evaluation is free, there is no diagnostic fee, & you can see how each driver maps to a tier on the hard drive data recovery overview.
Does the donor sourcing time change the price or just the timeline?
Mostly the timeline. The $1,200–$1,500 head swap & $2,000 surface-damage tiers are priced for the clean-bench transplant itself, so waiting days or weeks for a matched donor to arrive does not raise the tier. What the donor adds is a separate part billed at cost: Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. A rare or high-capacity model has fewer compatible donors, so it costs more to source & takes longer to land, but the recovery labor stays at the same published tier. Read how a donor is matched on firmware revision, head count, & head map in how donor drives are matched.
Why the quotes get accepted
Why So Many People Trust DriveSavers
A four-figure quote for a job an independent lab does for a few hundred dollars usually gets paid, and the reason is not that customers fail to notice the price. It is that the name arrives pre-trusted. When your drive dies and you walk into an Apple Store, the person at the Genius Bar often points you to DriveSavers. Coming from Apple, that reads as an official blessing, so the quote that follows feels like the price of doing it right rather than a number to question.
That referral is not new marketing. It goes back to a 1999 Apple support memo in which Apple agreed to accept drives that DriveSavers had opened without voiding the hardware warranty. Apple was careful to say the mention was "neither an endorsement nor a recommendation" and that DriveSavers is not an Apple Authorized Service Provider, but the practical effect over the following decades was a steady stream of Apple Store referrals and a trust halo that no amount of advertising can buy. Apple still lists DriveSavers on its current data-recovery support page today.
Understanding that causality is the point. The trust is real, but it traces to a warranty-logistics arrangement from 1999, not to any finding that the work is better or the pricing is fair. The same recovery, on the same PC-3000 hardware, is performed by independent labs for a fraction of the quote. For the full breakdown of the referral and what it costs you, see is DriveSavers legit.
Get an accurate quote for your drive
