FREE ESTIMATE
SMR Hard Drive Data Recovery
At Rossmann Repair Group, we specialize in the recovery of data from Shingled Magnetic Recording (SMR) hard drives, which is new tech. SMR drives are widely used in consumer and enterprise environments since they provide higher storage capacity for less money. Their unique structure makes them very difficult to recover when they fail.
If your SMR hard drive is not working, we have all the tools necessary to get your data back!
Why Rossmann Repair?
What Makes SMR Drives Unique and Challenging for Recovery?
SMR hard drives write data in overlapping tracks, like shingles on a roof. This allows for higher storage density. While this technology maximizes capacity, it makes recovery more difficult due to the following reasons:
  • Overlapping Data Tracks: Modifying or recovering one track risks overwriting or corrupting adjacent tracks.
  • Second-Level Translators (SLT): These firmware components map logical block addresses (LBA) to physical block addresses (PBA). If the translator is damaged, the drive can return empty or corrupted data.
  • Trim-like UNMAP Commands: SMR drives used in host-managed or host-aware configurations can process UNMAP commands (similar to TRIM for SSDs) in some systems. These commands tell the drive to mark certain data blocks as no longer in use, which can sometimes erase important mapping information in the Second-Level Translator (SLT) that connects logical addresses to physical storage locations. Deleted translator metadata or zone mappings can prevent reconstruction of the overlapping data tracks unique to SMR drives.
  • Firmware Dependence: SMR drives heavily rely on firmware for managing data zones, and corruption here can make recovery extremely complex.
Who Uses SMR Hard Drives?
SMR drives are commonly found in:
  1. Consumer Electronics: External hard drives like the WD My Passport and Seagate Backup Plus.
  2. Network Attached Storage (NAS): Models like the WD Red series often use SMR drives for storage solutions.
  3. Surveillance Systems: High-capacity drives for storing security camera footage, such as some of Seagate’s SMR-based surveillance models.
Common Issues with SMR Drives
  1. Quick Formatting:
  • If you format a drive and unplug it, old-style CMR drives (CMR referring to Conventional Magnetic Recording) are trivial to recover with standard software like R-Studio or UFS. Sometimes a pain, but mostly doable.
  • With SMR drives like some WD My Passport models, you have to deal with second translators, translator dependencies, and you may not even get all the data from it.
  • Basic software like UFS Explorer and R-Studio will show only empty sectors with zeroes in a case like this where the drive was formatted.
  • Recovery often requires advanced tools to bypass damaged SLTs and restore fragmented data, like the Acelab PC3000.
  1. Firmware Corruption:
  • SMR-specific firmware handling is more complicated compared to older CMR drives.
  • If the second translator has an issue, the drive may click even if the heads are good, which can confuse new technicians into believing the heads are a problem.
  • Sometimes this means blocking access to the service area or special modules.
  • Software like UFS Explorer and R-Studio will not handle this. In this case, UFS stands for "u find shit" - only zeroes :'(
Our SMR Data Recovery Process
We use advanced technology and methods to deal with the challenges specific to SMR recovery:
  1. Translator Repair:
    • We rebuild or bypass the damaged second-level translator to recover fragmented data.
  2. Firmware Restoration:
    • Our tools safely repair corrupted firmware modules to get the drive back to working condition so we can recover all of its data.
  3. Zone Recovery:
    • By carefully handling overlapping zones, we ensure adjacent data tracks remain intact during recovery.
  4. Physical Repairs:
    • For drives with mechanical issues, our Purair VLF-48 laminar flow bench provides the controlled environment necessary for repairs. The Purair VLF-48 Laminar Flow Bench allows an ultra-clean workspace with ULPA filtration capturing 99.999% of particles down to 0.1 microns. Its vertical airflow design minimizes turbulence, making it perfect for handling delicate media during data recovery. We are NOT opening your drive in any old office!
Start Estimate
Watch a Real Data Recovery Service below!
Why SMR Data Recovery Requires Experienced Technicians
Recovering data from SMR hard drives is a highly specialized task that requires lots of technical expertise & precision. New technicians working with tools like the PC3000 or performing cleanroom repairs on a laminar flow bench are on their way to success if they are committed to learning, but newer technicians often make mistakes that lead to permanent data loss. Here’s why choosing an experienced technician matters!
Common Mistakes Made by Inexperienced Technicians
  1. Mishandling Second-Level Translators (SLT):
    • SMR drives rely on SLTs to map logical data to physical locations. A newbie may overwrite or improperly rebuild this translator, causing irreversible data loss.
    • Using generic PC3000 scripts without understanding SMR-specific firmware quirks can result in fragmented or missing data.
  2. Damage to Overlapping Data Tracks:
    • SMR drives write data in overlapping tracks, meaning a mistake in one area can overwrite or corrupt adjacent tracks.
    • Inexperienced techs often use cloning methods meant for standard old CMR drives which can destroy the integrity of overlapping zones.
  3. Improper Use of Cleanroom Tools:
    • Handling delicate internal components like heads or platters in a laminar flow bench requires experience. Common errors include:
      • Scratching platters while removing heads.
      • Misaligning replacement components, rendering the drive unreadable.
  4. Not addressing UNMAP Issues:
    • New techs sometimes overlook the impact of Trim commands, which can prematurely delete data necessary for a data recovery from SMR drives. Misconfiguring recovery software can make things worse.
  5. Inadequate Firmware Handling:
    • SMR drives depend heavily on proprietary firmware for managing shingled zones. Without training a technician might apply firmware fixes meant for CMR drives, bricking the device.
Why Choose Rossmann Repair Group?
  • Certified Expertise: Our technicians are extensively trained and certified by ACE Lab, the developers of PC3000. We understand the nuances of SMR drives and their unique recovery challenges. While "Apple certification" is useless & often means the technician is not allowed to do real repairs, acelab's actually matter!
  • Industry-Leading Tools: We
  • Experience You Can Trust: With years of expertise in data recovery, we handle cases other labs cannot.
  • Top Rated: No, really. Check google maps - we have the highest(and most) ratings of any data recovery company.
  • No paid advertising: No banner ads, no yelp promotions, no google adwords. We rely on word of mouth and videos demonstrating our abilities. The lack of paid advertising means the savings are passed onto you.
Contact Us Today
If your SMR hard drive has failed, don’t lose hope. Contact Rossmann Repair Group for professional data recovery services!
We Can Extract Information From These Types of Media at Our Lab
Laptop Hard Drives
Liquid damaged iPhones
Physically damaged USB flash drives
SD & microSD cards
WD MyPassport
Desktop Hard Drives
External Hard Drives
USB Hard Drives
RAID configurations
SATA, IDE, SCSI, SAS, SSD Hard Drives
Our Rates?
Giving a price without seeing the device, assessing its condition is impossible. Everyone feels better having some basic idea of what things may cost, so for a basic idea, see below. Do realize the + means price can go up! Please do note that drives that have been opened before are rarely if ever recoverable by us: mention this prior to sending it in as we rarely work on pre-worked on drives.
hard drives
Hard Drives
$100 for basic data retrieval, $250-$650 for firmware repair, $900-$2000 for heads swap.
Get Started
SD cards and micro sd cards
SDcards/microSD cards
$200 for basic data recovery, $900 for breakout board data recovery
Get Started
cellphone data recovery
CellPhones
$300-$650 for drop or liquid damage, $1200+ for difficult cases(board swap). $400+ for any damage inflicted by inept repair technicians(long screw) that is above and beyond terrible.
Get Started
ssd card data recovery
SSDs
$300-$2000 depending on extent of damage
Get Started
Love From Our Customers
Hear from our satisfied customers who trust us for their data recovery needs in Austin. We didn't become the top rated repair shop on Google maps by accident - this was a 15 year effort of providing best-in-class service, with no gimmicks.
5 star ratingFive weeks ago, my 10 year old daughter's 5th gen iPad stopped charging. My husband and I suspected a loose connection, but when we took it to Apple, they ran some test and concluded the logic board died. Since the iPad was set up under me when she got it (at the age of 6), I had disconnected her from *my* iCloud. Apple basically couldn't sell me a new iPad because we had no data backup. Based on Apple's recommendation, we sent it to their data recovery partner, DriveSavers, who quoted me $2800 for data recovery due to "widespread corruption" on her logic board. We declined. Enter the Rossmann Repair Group. Earlier this week, I got a call asking me what specifically was wrong with the iPad because they were able to turn it on, and had access to all the data. To say I was floored is a complete understatement - but 100% explains why the Find Me app showed my daughter's iPad location as CA, when it had a "corrupted" logic board… *eye roll* Rossmann Repair Group gave me a copy of my daughter's data for $100, on a storage device I did not have to pay for, AND fixed her home button and cracked screen for another $100. They shipped it back to me for free. $200 and it was done. I would tipped if there was a virtual tip jar... so happy!! ;) I feel completely misled by Apple, and we were flat out lied to by DriveSavers. But Rossmann Repair Group was honest, kind, and reasonable. I feel like they completely came to our rescue. I wish you could have seen the smile on my daughter's face when she got her iPad back. My heart swelled. To David, the tech who fixed it, thank you so much. Because of you, we are Rossmann Repair Group customers for life.
read more
Christina M Avatar
Christina M
12/17/2021
I just got my Macbook Pro back from RRG. I have to say I was overjoyed and honestly getting my Macbook Pro back was the one time I felt pure joy in a while. I caught Louis on the phone a couple of the times that I called and he is super nice, incredibly nice to customers. I called in to tell him I wanted rush service and he noted that I approved $45 rush service. I called the beginning of the next week to see what the status was because it had been delivered on Thursday. Louis said they were in the middle of replacing the battery now, and then within the hour I got an email saying it was done. They did not charge me the rush service charge, which I didn't realize until after I paid and it shipped, but the was a duplicated repair charge on the invoice that I called and noted to them, which they promptly fixed. This leads me to believe that they waived the rush charge. These guys are awesome and made a daunting experience of being without my Macbook Pro for a week super easy. In contrast-- Geek Squad (Best Buy) said they needed to send it off to Apple for a month, and Microcenter, while I'm very impressed that they were able to do it in store, wanted $500 for the repair, which $300 of that was Apple's charge for the battery, that they're forced to use because they are an AASP. My understanding is they replace the whole backing and not just the battery. But here's the thing-- regardless of both places and even though all my data is backed up on the cloud, I simply did not trust to leave my Macbook Pro with either Microcenter (because they are an AASP only, because they're an awesome store with very capable people) or *shudder* Best Buy. Thank you so much Louis for being awesome, and all the rest of the guys. I don't know who the other guys were I spoke with but everyone was incredibly kind.
read more
Alexander Rose Avatar
Alexander Rose
12/17/2020
Went in to ask if they could retrieve my SSD from my Surface Pro 4 for me and they gave me a good rate, but was still a bit too expensive for me. So, they let me use their equipment for about an hour until I was able to fish it out myself and recover my data.
read more
Aravind Udayakumar Avatar
Aravind Udayakumar
7/24/2024
Louis Rossmann is as real as it gets man. The sheep may not be of your average sheep's color, but he's the real deal. He knows exactly what he is doing and he's the full sheep. Not half the sheep, but the full legit sheep. You can't go wrong with Louis Rossmann. Don't delay, ship your Mackbook to Rossmann Repair Group today. Get your data recovery needs, your PP3SHEEP HOT repaired, liquid damaged keyboards (including those beautiful butterfly....wait a second... I wouldn't classify those as keyboards...) screens, and all sorts of... fuses....missing a screw? Perhaps a short screw for those short holes? Rossmann Repair Group has everything you need. But seriously, this place will fix all your sheep related needs!
read more
Just R. Avatar
Just R.
6/19/2019
5 star ratingI traveled two and a half hours each way to take my laptop in to Rossmann Repair Group because I was so impressed with the skill and expertise displayed in Louis Rossmann's YouTube channel (in addition to its hilariousness and occasionally brilliant wit and wisdom). It was important to me to go to a repair store that I had trust and confidence in.
Louis and his colleagues were extraordinarily diligent, professional, thorough, transparent and went far above and beyond what was necessary and greatly exceeded my expectations. This was literally the best customer service experience I can remember by far. I would recommend Rossmann Repair Group to anyone without reservations. Louis and his colleagues are also among the most uncompromisingly ethical professionals I've ever met - as another reviewer pointed out, they literally invest huge amounts of uncompensated time to educate customers on how systematically faulty MacBooks are despite having a business model reliant on people continuing to buy them.
Seriously, if you care about your computer, time, money, data, etc., I wouldn't risk going anywhere else for MacBook repair.
read more
Samantha G. Avatar
Samantha G.
8/10/2019
AMAZING. I talked to a few other places before coming here. The final price I paid here was half of what I was quoted at the other place, insanely FAST (a few days vs. 6-8 days) AND SO MUCH MORE CLEAR in their diagnosis and process! The Rossmann Group is the best. First, I went to Dr. Brendan's on St.Marks. My computer sat there for a while- even though they mention a 24hr diagnosis period and I called them to ask about what happened. Super poor communication at Dr.Brendan from my experience. Also their quote was around $800 and timing was 6-8 days. This all felt super wrong, and I decided I might should take the laptop somewhere else. My work depends on it! SO I had read all the awesome reviews on google and saw how involved the people at The Rossmann Group were in helping their customers. Went over there on a Sunday. As soon as I showed up the technician opened my computer and told me exactly what was wrong, immediately diagnosed and understood. No smoke and mirrors, no questions unanswered. So amazing! Even though it was a holiday weekend (ie: NYE) the problem was solved by Tuesday night and I picked up my computer Wednesday! Highly recommend this shop! It seriously has taken a huge burden off my back as I launch my new biz in 2019. Computer problem was.... Display went out on my mac book pro after I dropped coffee near it. Other place said I would need a LCD screen replacement and a new logic board. But Rossmann Group opened the computer and showed me that part of the cable that connects the logic board and screen was burned out. So they replaced that for around 460$. Computer works great now!
read more
Alexandria Jarvis Avatar
Alexandria Jarvis
1/21/2019
5 star ratingI'm very satisfied with the data recovery performed by Rossmann Repair. The turnaround time was fast, their cost estimate was fair, and the final amount was well within their estimated amount. Every step of the process was painless and the customer service is excellent. I dealt with exactly *zero* B.S. the entire time. Highly recommended.
read more
Kevin M. Avatar
Kevin M.
5/20/2021
5 star ratingAbsolute miracle workers. I dropped off an 8tb hard drive that had fallen into a BUCKET OF BLEACH and they did the impossible. Look no further than this place
read more
Robert Avatar
Robert
7/17/2022
5 star ratingSimply the email "request a quote" feature was enough for me to come here and make my first ever review. They couldn't even fix my problem due to it being a severe legacy hardware failure, but were quick, upfront and honest about it, even linking me to a work around that will allow me to recover my files and transfer them to a new device or hard drive. There is really something to be said about this quality of service, I would have stuck my logic board back in the oven like an idiot (again) potentially bricking the entire thing forever. Louis, you really know how to run a no nonsense quality business. Thank you From a former Apple fanboy.
read more
Sam S.
9/22/2019
My 2017 Macbook Pro's hard drive got bricked after updating to Apple's Catalina OS (no hard drive was detected). *Yes, Apple's software update physically corrupted my hard drive. I went to my local Apple store and was quoted over $800 to get my Macbook in working order, despite the issue happening because of a known Apple bug. I've been watching Louis's videos on YouTube for some time and decided to ship my Macbook from Hawaii to his shop in New York. His team was very straight forward and repaired my laptop at a fraction of the cost (considering new hard drive + installation)! I can't thank Louis and his team enough! Much mahalo! #supportrighttorepair
read more
Daniel P. Avatar
Daniel P.
9/14/2020
Louis and his staff are great. Honest and professional, they are the only board level repair and drive recovery service I recommend.
read more
Holger Kuester Avatar
Holger Kuester
12/17/2020
By far the best company I have ever used for data recovery. They keep m informed every step of the way and did it quickly. Thanks again cant wait to use them again.
read more
John Bort Avatar
John Bort
12/17/2020
5 star ratingI had the pleasure of visiting the Rossmann Repair Group in NYC one day almost two years ago as friends of mine needed an evaluation of a broken Macbook Pro, a bad hard drive and possible data transfer. Louis Rossmann greeted us immediately and was very friendly and patient. He told us exactly what the problem was and said that the Macbook Pro was beyond repair due to bad GPU connections. In fact he saw this as soon as he turned it on, he could detect very faint lines on the screen which indicated this issue. He was very honest about this, he said that some places would get it to work for a while by heating it up and charging a few hundred dollars, but that the repair would not last long and it would certainly fail again.My friend asked him if he could transfer the data from the Macbook to a Mac Mini so it would work like the Macbook. He said he could and it would take a couple of days. We returned a few days later to pick everything up. The cost was very reasonable and my friends were very satisfied with the service. He gave the bad HD back to us, said it would require sending to a recovery center. Just honest. No ripoffs.In this tech repair industry, dishonesty is very common since tech people know the average person has no clue about any of this technology and there is almost no chance they would know if they are being fooled or how much the repair is really worth. I know this well since I also do computer and electronics repair and support myself and I know how easy it would be to fool customers left and right! I don't do this and I highly appreciate other tech experts who aren't tempted to profit from people's trust and innocence!So in summary, if you don't want to get ripped of and lied to, and are looking for a highly competent reliable technician, make sure you go here with your Mac equipment. If you like, you can stop by an Apple Genius bar first for a good laugh, while they give you the wrong diagnosis, quote you an insanely high repair price, and try to convince you to buy a whole new unit.Finally, if you want to be amazed, look for Louis Rossmann on YouTube and watch some of his videos where he shows exactly how he repairs the "unrepairable" and inspires many others to do their own repairs, start their own repair businesses and with his tireless entrepreneurial positive attitude even motivates disillusioned young students to not give up on school and go to college! (In fact one student said he was about to give up on education but after watching Louis on YouTube he made the decision to enter Med school! Now that's remarkable!)Louis is such a great guy, that in some cases where the issue is very minor, like a bad cable, he even does the repair for no charge! Try to find anybody who is willing to do anything for no charge these days! (The Genius bar would certainly tell you that your unit has been water damaged, when it wasn't, (maybe was in a humid room which would turn the water indicators red!) and quote you $1000 for a repair that would cost them $7 for the cable)Louis Rossmann is a hero, one of those rare individuals who make positive contributions to individuals and society every single day. I am pretty sure that anybody who gives him a bad review probably either is part of Apple, or considers Apple to be some kind of religious deity.
read more
Jerry D. Avatar
Jerry D.
9/05/2019
5 star ratingI never write reviews, but I feel it's especially important because this store and the service they provide are one of the reasons why New York is a great city. Amid attacks on right-to-repair, on top of all the other struggles businesses in our increasingly corporatized city faces this is the kind of place that makes this city unique. I have a new MacBook Pro M1. It took an accidental bath, and Apple quoted me 2-week turnaround for repair at a number within 20% of the purchase price for the repair. I could have bought a max'd out brand new MacBook Air for less money than the amount Apple was charging for the job. It appears as though Apple doesn't repair discreet components - they junk an entire logic board and transfer the SSD over as opposed to truly trying to make a fix. Rossmann Repair Group took the time to diagnose the issue right in front of me before I dropped it off, gave me a quote that was fair and reasonable, repaired it within 48 hours, and when I went to pick it up the total cost was less than the stated quote. The machine was good as new. They knew I was willing to spend up to the quoted amount to get a repair, yet they billed me less. It's so very rare to find specialists with that sort of honesty. They knew I was willing to pay a certain price and they billed me for the true value of services rendered. While I never hope to be a repeat customer, if any future machine faces the same fate I know where I'll be going before I ever get it looked at by Apple. This place is awesome.
read more
Matt B. Avatar
Matt B.
3/30/2022
These guys are magic workers. Apple quoted me $700 and said my data wasn’t recoverable and these guys were able to recover all my data and fix my computer for $300!!!
read more
Nader Nouwairi Avatar
Nader Nouwairi
11/27/2023
Our Recent Work
Our highly trained technicians have worked on some of the most complex cases with great success. If your hard drive or SDcard is no longer responsive, we’ll get your information back!
failed usb drive during data recovery service
Have a failed external USB drive? We can by-pass the USB on your drive and go straight for your data!
unstick heads - data recovery austin
Stuck heads? No problem! We have the tools and the clean room to un-stick your heads..
on site hard drive data recovery service
We can do clean room data recovery on premises when necessary.
inspecting 6 head stack donor drive
Inspecting a 6 head stack from a donor drive before it goes into the patient.
Bottom Line:
At Rossmann Repair Group, we don’t just recover data; we restore your peace of mind. Contact us today for your hard drive data recovery needs in Austin and experience service that sets the industry standard.
Top Reasons To Have Your Repairs Done By Us
All data recovery done on-site.
Our pricing is fair.
High success rate.
You can meet & speak with the recovery specialist working on your case directly.
Get In Touch with Us
Give us a call or fill out the form below to get a fast price estimate on a fix for your device.  If you are not local, we also offer a very streamlined Mail-In Service which makes it very easy to work with us from anywhere in the country.
Mail-In Repair Service
Call or Visit Us
Monday-Friday – 11 AM to 7 PM
2410 San Antonio Street
Austin, TX 78705
Email, Call or Walk Into Our Store.  We Want to Hear From You!
"*" indicates required fields
Name*
We Can Fix Your Problem
We provide the best unauthorized MacBook, iPad & iPhone Repair in Austin. You can come to our store for a free estimate without an appointment, or mail your device to us from anywhere in the world to receive service.
Made In America
No Outsourcing
Address
Rossmann Repair Group Inc 2410 San Antonio Street,
Austin, TX 78705
(347) 552-2258
OPENING HOURS
SOCIAL MEDIA
© 2025 Rossmann Repair Group, Inc
phone-handsetmap-markerclock
