A Clicking Hard Drive Does Not Always Have Dead Heads
Clicking in a hard drive has at least six distinct causes, and head failure is only one of them. PCB component failures, firmware corruption, bad sector accumulation, power supply issues, and motor bearing problems all produce clicking or ticking sounds that get misdiagnosed as head failure. The correct diagnosis requires connecting the drive to professional hardware and reading its firmware state before opening anything.
Updated March 29, 2026
The claim
What Gets Repeated About Clicking Drives
“If your hard drive is clicking, the read/write heads are dead and you need a cleanroom head swap.” This is the default diagnosis from most data recovery companies and the first result on every tech forum. It is wrong more often than people realize.
Six causes of clicking
Six Causes of Hard Drive Clicking
A clicking hard drive requires proper diagnosis because the sound alone does not identify the failure. Each of these six causes produces clicking or ticking, and each has a different repair path and cost.
1. Read/Write Head Failure
The head stack assembly has physically failed. One or more heads cannot maintain flight height or read data. This is the cause most labs assume by default, and the most expensive to fix. Requires a head swap with matched donor heads on a ULPA-filtered clean bench.
2. PCB Component Failure
A shorted TVS diode, failed motor controller IC, or burnt power regulation component on the circuit board prevents the drive from initializing. The drive clicks as the motor controller attempts startup repeatedly. Fix: replace or bypass the failed component. Cost: a fraction of a head swap.
3. Service Area Firmware Corruption
The firmware stored on the platter surfaces (translator tables, defect lists, SMART logs) has become corrupted. The drive initializes partially, then the heads fail to locate readable firmware modules and start recalibrating. Fix: terminal connection to repair firmware via PC-3000. The drive never needs to be opened.
4. Bad Sector Accumulation
Clusters of unreadable sectors trigger aggressive retry loops in the drive firmware. The heads reposition repeatedly over the same failing area, producing a rhythmic clicking pattern. The heads themselves may be functional but the media surface is degraded in specific zones.
5. Power Supply Instability
Insufficient or unstable 12V/5V power delivery from the PSU, USB-to-SATA adapter, or enclosure causes the motor to stall and restart repeatedly. Common with laptop drives connected through unpowered USB adapters. The drive works normally on a powered SATA connection.
6. Motor Bearing Problems
Degraded fluid dynamic bearings cause spindle speed variations. The heads lose track synchronization and recalibrate repeatedly. Less common than head or firmware failure, but produces similar sounds.
Head failure
Documented Cases Where Clicking Was Not Head Failure
Two of the most widely documented drive families illustrate why “clicking = head failure” is an unreliable assumption. In both cases, the correct fix cost a fraction of what labs were quoting for head replacement.
Seagate Barracuda 7200.11 CC1H Firmware
Drives with the CC1H firmware version entered a BSY (busy) state due to corrupted S.M.A.R.T. log entries in the Service Area. The data on the platters was intact. The fix required a TTL serial adapter connected to the drive's diagnostic port, issuing terminal commands to clear the corrupted log and reinitialize the motor. No head swap. No cleanroom. The repair cost a fraction of what labs were quoting for “head replacement.”
Sources: Overclock.net fix documentation, Hackaday coverage (2012), HDDParts firmware fix kit documentation.
Western Digital WD2500JS / WD2500AAJS
PCB boards 2060-701335-005 and 2060-701537-002 fail due to burnt or shorted power regulation components. The drive clicks rhythmically as the motor controller tries to initialize but cannot get stable voltage. An inexperienced technician hears clicking and quotes a head swap. A technician who actually diagnoses the drive sees a PCB fault and fixes it for a fraction of the cost.
Sources: HDDZone PCB repair guides, Outsource Data Recovery case documentation.
Firmware corruption
Why This Myth Persists
Head swaps are the most expensive standard procedure in hard drive data recovery. The financial incentive to default to a head failure diagnosis is straightforward.
  • A firmware repair or PCB fix falls under Tier 3 ($600–$900). A head swap starts at $1,200–$1,500 at an independent lab and $2,000-$7,000+ at large cleanroom-marketed labs. If every clicking drive gets classified as head failure, the minimum quote doubles or triples.
  • Referral commission economics amplify the problem. A company paying referral fees to middlemen generates far more per referral on a high-dollar head swap invoice than on a lower-cost firmware repair.
  • Proper diagnosis requires professional tools. A PC-3000 or MRT system can read the drive's firmware state, test individual heads, and identify whether clicking originates from heads, firmware, PCB, or power delivery. Consumer software cannot do any of this, so “clicking = heads” becomes the default assumption.
Service area faults
How a Professional Lab Diagnoses a Clicking Drive
When a clicking drive arrives at a professional lab, the first step is never opening it. The technician connects the drive to a PC-3000 Express or PC-3000 Portable III and reads the firmware initialization sequence.
The PC-3000 diagnostic reveals:
  1. Whether the Service Area (firmware zone on the platters) loads correctly
  2. Whether specific firmware modules (translator tables, defect lists, SMART logs) are corrupted
  3. Whether individual heads respond to read commands
  4. Whether the PCB delivers correct voltage on the 5V and 12V rails
If the firmware loads but one or more heads fail to read, that confirms a head issue. If the firmware itself won't initialize due to corrupted modules, that's a firmware repair. If the PCB shows component failure on visual inspection or voltage testing, that's a board-level fix.
Partial Head Failure and Head Map Editing
When one head has failed and the others still read, we sometimes cut the failed head from the head stack and hex edit the head map in the ROM. The drive is then imaged on its remaining heads first. We cut heads only if the platters are badly damaged.
A drive with a failed head goes to the clean bench for mechanical work before any imaging. For a head swap, the technician sources a donor drive matched by model, firmware revision, and head map configuration. The swap happens in a ULPA-filtered clean bench with donor heads verified for preamp continuity before installation.
Our procedure
How We Handle Clicking Drives
Every clicking drive gets a full diagnostic on PC-3000 before we quote anything. We do not default to “head swap” because that is the most profitable diagnosis. We identify the actual cause and quote accordingly.
  • Firmware repairs run $600–$900 (Tier 3)
  • Head swaps start at $1,200–$1,500 (Tier 4) plus donor drive cost
  • No diagnostic fee. If we cannot recover your data, you do not pay.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Rush fee: +$100 rush fee to move to the front of the queue.
Does a clicking hard drive always mean the heads are dead?
No. Clicking has at least six distinct causes: head failure, PCB component failure, firmware corruption in the Service Area, bad sector accumulation triggering retry loops, power supply instability, and motor bearing problems. Proper diagnosis requires connecting the drive to a PC-3000 and reading the firmware initialization sequence before opening anything.
How much does it cost to diagnose a clicking hard drive?
Rossmann Repair Group charges no diagnostic fee. Every clicking drive gets a full PC-3000 diagnostic before any quote is issued. If the cause is firmware corruption, the repair runs $600–$900 (Tier 3). If heads are confirmed failed, head swaps start at $1,200–$1,500 (Tier 4). No-fix-no-fee guarantee applies.
Should I run data recovery software on a clicking hard drive?
No. Software sends read commands through the OS, forcing damaged heads to attempt reads across every sector. Each attempt scrapes the platter surface, generating debris that causes cascading damage to previously undamaged tracks. Power off the drive and contact a professional lab.
What was the Seagate 7200.11 BSY bug?
Seagate Barracuda 7200.11 drives with CC1H firmware entered a BSY (busy) state due to corrupted S.M.A.R.T. log entries in the Service Area. The data on the platters was intact. The fix required a TTL serial adapter connected to the drive's diagnostic port to clear the corrupted log and reinitialize the motor. No head swap and no cleanroom required.
Can a data recovery lab recover data from a drive with one failed head?
When one head has failed and the others still read, we sometimes cut the failed head from the head stack on the clean bench and hex edit the head map in the drive's ROM, so the drive can be imaged on its remaining heads first. We cut heads only if the platters are badly damaged.
Clicking Drive? Get a Real Diagnosis.
Call (512) 212-9111 or ship your drive to our Austin lab. No diagnostic fee. No data, no recovery fee.
