WD Passport Not Detected?
We Fix "Spyglass" Drives.
My Passport drives in this family are self-encrypting. We do the firmware work first, and we image the drive after that.
Updated February 2026
8 min read
What is a Spyglass Drive?
What is a "Spyglass" Drive?
"SpyGlass" is one of Western Digital's names for a 2.5-inch drive family. ACE Lab's PC-3000 support list puts SpyGlass, Spyglass 2, Spyglass 2 Ultra and Spyglass 3 under its WD Marvell 2.5-inch heading, and drive records show the WD40NMZW as a SpyGlass on a native USB board. We get them inside WD My Passport and WD Elements enclosures.
These aren't built like a standard hard drive. They use Shingled Magnetic Recording (SMR), and the portable models sit on a native USB circuit board that has no SATA connector on it. That combination is what makes them harder to work on when they fail.
SMR Drive Complexity
SMR drives write tracks that overlap like roof shingles. Writes that land outside those shingled bands get tracked by a second-level translator (T2). On a Western Digital SMR drive, that translator lives in Service Area Module 190. ACE Lab says a damaged T2 leaves the drive reading back zeros in every sector.
Key Technical Challenges
  • 1
    Native USB InterfaceThere is no SATA connector. The USB port is built into the main board. We micro-solder SATA test-point leads to talk to the firmware through PC-3000.
  • 2
    Monolithic Native USB BoardThe USB interface, the main controller and the encryption processor all sit on the one board. Dropping in a donor board on its own won't give you a readable drive.
Common Spyglass Models
Model NumberWD Engineering FamilyPCB Seen In Drive Records
WD40NMZWSpyGlass2060-800041
WD40NDZWSpyGlass 2 and SpyGlass 2 Ultra2060-800041, 2060-810035
WD50NDZWSpyGlass 2 Ultra2060-810035
WD20NMVWShrek and Shrek LT, not SpyGlass2060-771801, 2060-771961
WD10JMVWFirebird and FBLite, not SpyGlass2060-771801, 2060-771961
Common WD Spyglass Failure Modes
"Slow Responding" Bug
The drive is detected, but opening a folder takes forever.
Not Detected / Blinking
The light blinks, the motor spins, but the computer sees nothing.
Our Fix: USB-to-SATA conversion plus Service Area diagnosis in PC-3000.
Translator Corruption
When the SMR map (T2) is damaged, every sector reads as "00".
Our Fix: Write the original Module 190 back and build the imaging map from the second-level translator data in PC-3000. This procedure is part of our standard PC-3000 WD data recovery workflow.
Hearing noises? See our guide on clicking hard drive recovery for mechanical failures.
Actions That Cause Permanent Data Loss
Do NOT run CHKDSK
CHKDSK works on the file system over standard ATA commands, and it can't repair firmware. On a drive that's failing physically it fires thousands of read retries at bad sectors, and that wears out heads that are already weak.
Do NOT "Initialize" Disk
If Windows asks to initialize, say NO. That writes to a drive you still need to read.
If you need professional data recovery, stop powering the drive on.
Our Recovery Process
Before we image a SpyGlass drive we solder on SATA test-point leads and do the firmware work in PC-3000.
  1. USB-to-SATA Conversion: We micro-solder SATA data leads to test points on the board so PC-3000 can talk to the drive's firmware directly.
  2. Work On The Drive's Own Board: The USB interface, the controller and the encryption processor are all on that one native USB PCB, so that's where the firmware work happens.
  3. Stabilize Firmware: We block background SMR operations and rebuild the translator if necessary.
  4. Sector-by-Sector Image: We clone the data to a healthy drive, handling read errors with precision timing.
How Do We Recover Data From WD Spyglass Hard Drives?
WD Spyglass hard drive data recovery starts with firmware stabilization, not file browsing. PC-3000 Portable III and PC-3000 Express let us work with the original ROM, Service Area modules, and SMR translator before DeepSpar or PC-3000 imaging touches user sectors.
Firmware Work Before Imaging
T2 translator
The second-level T2 translator lives in Service Area Module 190 and tracks the writes staged outside the shingled bands. ACE Lab says that when it's damaged, the drive reads back zeros in every sector. We repair the translator first, and the file system after that.
Original ROM and adaptives
The original PCB state matters on native USB SpyGlass drives. We keep the ROM and the adaptive data so firmware access and imaging stay tied to the drive that wrote your files.
Mechanical Work When Heads Are Weak
A WD Passport that clicks persistently is no longer a firmware-only job. We inspect the head stack assembly, check the voice coil actuator movement, and use FLIR thermal cameras to look for PCB heat faults before opening the drive.
  1. Match donor head stacks by model family, head map, preamp compatibility, and firmware behavior.
  2. Open the drive only inside a 0.02 micron ULPA-filtered clean bench for head replacement or platter contamination inspection.
  3. Build an imaging map in PC-3000 or DeepSpar Disk Imager that reads stable heads first and skips damaged zones.
  4. Tune retries and timeouts when weak tracks need controlled passes instead of brute-force reads.
PCB Fault Or Head Fault: How We Tell Them Apart On A WD Spyglass
If your WD Spyglass won't spin up or it clicks, the problem can be on the board (USB bridge, MCU, power regulation) or in the head stack. Treating the wrong layer first wastes head life and can contaminate platters.
We tell these two apart at intake, before we open any drive. We follow the same steps whether the drive came in as a standard hard drive data recovery job or as a sealed external My Passport unit.
Differential Diagnostics At Intake
  1. Visual inspection of the PCB for burn marks, blown TVS diodes and missing capacitors around the USB bridge. Burned components point to a board-level fault before heads are suspected. See hard drive PCB components for the rail map we walk.
  2. FLIR thermal sweep under power with the drive on a current-limited supply. The camera only sees the exposed PCB, because the preamp sits inside the sealed drive body and aluminium is opaque in the infrared. A hot spot on the board points at a board fault. A board that stays cool still isn't in the clear, though, so we check it on the terminal.
  3. Service Area probe via PC-3000 Portable III through SATA test points we solder onto the board.
Named Lab Workflow For Mechanical Cases
When differential diagnostics confirm a head-side fault, the drive moves to the 0.02 micron ULPA-filtered clean bench.
  1. Clean-bench teardown of the head stack assembly, with voice coil actuator inspection and platter surface check under magnification.
  2. Donor head stack installation following the donor match below. See what a head swap involves for the full procedure.
  3. Set the firmware write lock in PC-3000 before any imaging starts. On a device-managed SMR drive a SATA write blocker only stops writes coming from the host. It doesn't stop the drive's own background work, so that lock has to go in at the firmware level first.
  4. If the translator or other Service Area modules need repair, we do that in PC-3000 Portable III or PC-3000 Express before the imaging pass.
  5. Image on the DeepSpar Disk Imager or in PC-3000, reading the stable heads first and skipping the damaged zones.
Donor Head Matching
Here's what the donor has to match. For the longer version, read how donor drives are matched.
1. Exact model family
Match the full model string, not just the capacity on the box. A WD40NMZW and a WD40NDZW aren't interchangeable.
2. Head map
The donor needs the same head map or a bigger one.
3. Preamp ID
Donor and patient have to carry the same preamp part number.
4. Date code window
The donor has to come off the line inside the same production window as the patient.
USB-to-SATA Conversion: The Solder Points
A native USB WD portable has no SATA connector. The USB interface, the main controller and the encryption processor all live on the one board, so there's no separate bridge to unplug and nowhere to hang an off-the-shelf USB-to-SATA adapter. To reach the firmware with PC-3000 we micro-solder SATA data leads onto test points on the board.
The leads go around capacitors on the native PCB and pick the SATA signals up off the board itself. Where those points sit changes with the board revision, so we confirm them against the board in hand instead of working off a generic diagram.
With the leads on, the board runs off an external supply and goes onto a PC-3000 Portable III. That gets us into the Service Area through the drive's own board and its own ROM state.
Why Generic Adapters Fail
Off-the-shelf USB-to-SATA adapters cannot recover SpyGlass drives. The drive has no SATA port to connect to. The board only exposes USB.
PCB Revisions We Handle
The solder point layout varies by PCB revision. We maintain conversion procedures for:
  • 2060-800041 (SpyGlass and SpyGlass 2, WD40NMZW and WD40NDZW)
  • 2060-810035 (SpyGlass 2 Ultra, WD40NDZW and WD50NDZW)
Transparent Pricing
Transparent Pricing
WD Spyglass recoveries follow our standard published pricing model. Compare to our standard hard drive recovery pricing. For a full tier-by-tier breakdown, see our hard drive data recovery cost guide.
Service TierPrice RangeDescription
Firmware Repair$600–$900Translator fix, or a drive that isn't detected and isn't clicking.
Mechanical / Heads$1,200–$1,500Persistent clicking or grinding. Requires donor parts and clean bench work.
Related Symptoms
See The Work
See The Work
Spyglass Recovery FAQ
Can I just swap the PCB on my WD Passport?
No. On a modern WD Passport it's all one native USB board: the USB interface, the main controller and the self-encrypting-drive processor. There's no SATA connector anywhere on it. Swapping the board on its own won't hand you a readable drive.
What does 'Spyglass' mean for my hard drive?
SpyGlass is one of Western Digital's names for a 2.5-inch drive family. ACE Lab's PC-3000 support list puts SpyGlass, Spyglass 2, Spyglass 2 Ultra and Spyglass 3 under its WD Marvell 2.5-inch heading, and drive records show the WD40NMZW as a SpyGlass.
Is it safe to run CHKDSK on a slow WD drive?
No. CHKDSK works on the file system over standard ATA commands, so it can't reach the firmware, let alone repair it. On a drive that's failing physically it fires thousands of read retries at damaged sectors, and that wears out heads that are already weak.
How much does WD Spyglass recovery cost?
Firmware repair costs $600–$900. Head swaps for mechanical failures such as persistent clicking are $1,200–$1,500. There is no charge if data is not recovered.
Learn more about our general hard drive data recovery services, or browse all WD drive families for model-specific recovery guides. Out of state? See how we serve customers looking for hard drive recovery near you via nationwide mail-in to our Austin lab, or read how to choose a hard drive recovery service.
Recover Your WD Passport Today
We recover Spyglass drives at the hardware level in our Austin, TX lab.
