We recover failed server arrays from Dell PowerEdge, HP ProLiant, and IBM Power Series hardware. SAS and NVMe drive imaging, RAID controller reconstruction, and VM extraction from VMware ESXi and Hyper-V environments.
Rossmann Repair Group recovers Dell PowerEdge, HP ProLiant, and IBM Power Series server arrays with RAID 5, 6, and 10 reconstruction, VMware VMFS extraction, Hyper-V VHDX recovery, and Windows Storage Spaces repair. Degraded arrays typically complete virtual destriping 3 to 5 calendar days after intake; catastrophic cases run 7 to 14 days.
Supported hardware
Which Server Hardware and RAID Controllers Do We Support?
We recover data from Dell PowerEdge, HP ProLiant, and IBM Power Series servers, including arrays managed by PERC, Smart Array, and SAS HBA controllers. Both SAS and SATA member drives are supported. Enterprise arrays use proprietary RAID controller firmware that standard recovery software cannot interpret; we reconstruct arrays offline using Data Extractor Express RAID Edition without relying on the original controller hardware.
Hardware
Controller or interface
Recovery handling
Dell PowerEdge
PERC H730, H740, and H755 controllers
PERC cards store RAID metadata in proprietary formats on each member drive. When the controller fails or metadata becomes corrupted, we image each SAS or SATA member and reconstruct the array configuration offline using Data Extractor Express RAID Edition.
Smart Array P-series and E-series controllers (Gen8 to Gen10) store proprietary metadata in the RAID Information Sector, written to raw reserved physical sectors at the start of each member drive, independent of any OS partitioning scheme. Newer MR-series controllers (Gen10/Gen11) are rebranded Broadcom and use SNIA DDF-based metadata written to the trailing sectors of each drive instead. We capture both metadata formats during imaging and use them to determine stripe size, parity rotation, and member ordering without requiring the original controller hardware.
IBM Power Series
Hardware-managed RAID on POWER hardware
IBM servers running AIX or Linux use JFS2, ext4, or XFS filesystems over hardware-managed RAID. We image member drives on PC-3000 and reconstruct the array layout from captured controller metadata.
SAS and SATA arrays
SAS drives, SATA drives, and SAS HBAs
Enterprise servers commonly use SAS drives, which require different interface hardware than consumer SATA drives. Our lab images these drives while preserving access to non-standard sector sizes (520/528 bytes) often used in enterprise arrays.
PCIe NVMe servers
Intel P5510, Samsung PM9A3, and Micron 7450 drives
PCIe NVMe enterprise drives are common in modern server deployments. These drives connect over PCIe rather than SAS or SATA and require NVMe-aware imaging procedures.
Enterprise arrays use proprietary RAID controller firmware that standard recovery software cannot interpret.
We reverse-engineer controller configurations and reconstruct arrays offline using Data Extractor Express RAID Edition without relying on the original controller hardware.
Supported RAID levels include RAID 6 with dual parity, RAID 10 striped mirrors, and every other common enterprise RAID level.
Enterprise Helium Drive Recovery in Server Arrays
High-capacity enterprise servers commonly use hermetically sealed helium drives from Seagate Exos, WD Ultrastar HC, and Toshiba MG series. These drives cannot be serviced like standard air-breather drives. Breaking the hermetic seal exposes platters to atmospheric pressure and particulate contamination. All open-drive work is performed on our ULPA-filtered clean bench.
High-capacity enterprise servers (Dell PowerEdge R740xd, HP ProLiant DL380 Gen10 Plus) increasingly ship with hermetically sealed helium drives from Seagate Exos, WD Ultrastar HC, and Toshiba MG series.
Helium-filled drives are sealed and require different mechanical handling than air-filled drives.
When a helium drive fails mechanically, it cannot be serviced like a standard air-breather drive.
Breaking the hermetic seal exposes the platters to atmospheric pressure and particulate contamination.
Donor parts must come from the same helium-sealed model family with matching head counts and firmware revisions.
Helium drive recovery pricing starts at $200 for simple data copies and can reach $4,000–$5,000 for mechanical failures.
What Do PERC, MegaRAID, Smart Array, DDF, and RAID-on-Chip Mean?
PERC, MegaRAID, Smart Array, DDF, Foreign Configuration, and RAID-on-Chip are the six controller terms that appear across Dell PowerEdge, HP ProLiant, and server array recovery cases. Each names a distinct layer of how enterprise controllers store metadata, route parity, or fail. Misunderstanding any of them on a degraded array can destroy recoverable data.
PERC
Dell PowerEdge RAID Controller. PERC cards store RAID metadata in proprietary formats on each member drive. Dell PERC H730, H740, and H755 controllers write Disk Data Format metadata to member drives, recording stripe size, parity rotation, and member ordering.
MegaRAID
The LSI and Broadcom hardware RAID controller line. Newer MR-series controllers (for example, MR416i-p) use Broadcom MegaRAID DDF-based metadata written to the final sectors of each drive.
Smart Array
The HP and HPE hardware RAID controller line (P408i, P440ar, E208i). P-series and E-series controllers (Gen8 to Gen10) store proprietary metadata in the RAID Information Sector, written to raw reserved physical sectors at the start of each member drive independent of any partitioning scheme, rather than the SNIA DDF format used by PERC and MegaRAID. Newer MR-series controllers (Gen10/Gen11) are rebranded Broadcom and use DDF on the trailing sectors instead.
DDF (Disk Data Format)
The SNIA-standardized on-disk metadata format used by PERC and MegaRAID controllers. DDF blocks record stripe size, parity rotation sequence, and member ordering, which is the information required to virtually reconstruct an array offline using Data Extractor Express RAID Edition without the original controller.
The controller BIOS prompt that appears when the DDF metadata on the drives no longer matches the controller's NVRAM. On a physically degraded array, importing the foreign configuration can trigger a Background Initialization or parity rebuild that pins every surviving member at full read load and finishes off a marginal same-batch survivor; if a URE lands, a modern PERC or MegaRAID punctures that stripe and loses its data while a legacy controller aborts, and either way you lose the clean clones you would have imaged first. Do not import.
RAID-on-Chip (ROC)
The dedicated silicon on a hardware RAID controller that handles parity calculation and member I/O.
What Causes Dell PERC and LSI MegaRAID DDF Metadata Corruption?
Dell PERC H730, H740, and H755 controllers write Disk Data Format metadata to member drives, recording stripe size, parity rotation, and member ordering. When the controller NVRAM cache fails or a rebuild crashes mid-operation, the array presents as a Foreign Configuration. We image each member on PC-3000 and parse the surviving DDF blocks offline.
Dell PERC H730, H740, and H755 controllers write Disk Data Format metadata to member drives.
Those metadata blocks are used to describe the virtual disk layout.
The DDF blocks record stripe size, parity rotation sequence, and member ordering.
When the controller's NVRAM cache fails or a forced rebuild crashes mid-operation, the DDF metadata on the drives desynchronizes with the controller's internal state, and the array presents as a Foreign Configuration.
We do not import foreign configurations through the PERC BIOS.
We image each SAS member drive on the PC-3000 SAS card and use Data Extractor Express RAID Edition to parse the surviving DDF blocks from the end of each drive image.
The tool extracts the original parity rotation, stripe size, and member ordering to reconstruct the virtual disk offline.
If individual SAS drives require physical repair before imaging (burned TVS diodes, seized spindle motors), that work happens first on our ULPA-filtered clean bench.
For arrays containing NVMe enterprise SSDs alongside SAS spinners, the NVMe members are imaged through separate PCIe adapters using PC-3000 SSD.
How Do We Recover Dell PERC H710 Arrays?
We image each member on PC-3000 and rebuild Dell PERC H710 arrays offline from DDF metadata without flashing firmware against degraded drives. A common failure mode on older PowerEdge R720, R720xd, and R820 servers is the controller hanging at boot, preventing the virtual disk from coming online.
The PERC H710 and H710P are 12th-generation PowerEdge RAID controllers.
They store the same Disk Data Format metadata as the newer H730, H740, and H755.
When the card hangs during initialization it never finishes enumerating virtual disks, the server stalls at the PERC banner, and any attached BMC console shows the controller as unresponsive.
IT forums often suggest reflashing the controller with a recovery ROM image or Dell firmware update package to clear the hang.
On a healthy array that may be reasonable maintenance.
On an array where physical drives are already degrading, a firmware reflash forces the controller to re-enumerate every drive, re-read DDF metadata, and in some firmware revisions attempt a Background Initialization.
Any of those events can push a weak SAS drive into hard failure and convert a recoverable array into a parity-loss case.
Bypass the H710 controller entirely. Our workflow for H710 cases does not attempt to clear the hang or reflash firmware. The original H710 card never touches the drives during recovery.
Image each SAS member in read-only mode. Each SAS member is imaged on the PC-3000 SAS card.
Stabilize mechanically unstable drives first. Any drive with mechanical instability is stabilized on the ULPA-filtered clean bench before imaging.
Parse DDF blocks and reconstruct the virtual disk. Once every member has a working image, the DDF blocks are parsed from the tail of each image to recover stripe size, parity rotation, and member ordering, and the virtual disk is reconstructed offline.
How Does a Failed RAID Controller Write-Back Cache Module Trigger a RAID 5 Write-Hole?
When the controller's flash-backed cache module or write-cache battery fails, the controller drops from write-back to write-through mode, and any writes still buffered in cache at that instant may never flush cleanly to the members. If power is lost or the controller crashes after the cache drops, an in-flight partial-stripe write leaves the parity of those stripes inconsistent across the member drives. This is a controller-cache failure, separate from the drive-level power-loss-protection capacitor covered below.
The write-back cache module (on Dell PERC H730, H740P, and H755 controllers this is a lithium-ion battery-backed Non-Volatile Cache that flushes DRAM to onboard NAND on power loss; Broadcom brands its own supercapacitor-backed module CacheVault, and older controllers used a battery-backed write cache, or BBWC) exists so the controller can acknowledge writes before they reach the platters. When that module's flash or battery fails, the controller drops from write-back to write-through mode.
Any writes buffered in the write-back cache at the instant the module fails may not flush cleanly to the member drives. The controller can no longer guarantee that a full stripe, its data blocks plus its recalculated parity, lands atomically.
On a power loss or controller crash after the cache has dropped, the parity block for an in-flight partial-stripe write no longer matches its data blocks. That is the RAID 5 write-hole: it leaves the parity of any in-flight stripes inconsistent across the member drives. Committed stripes retain consistent parity; the inconsistency is local to the stripes that were dirty in cache at the instant of failure, not the whole array.
The inconsistent stripes surface later as file or block corruption, or the controller flags the set as a foreign configuration on the next reinitiation.
Our recovery path never rebuilds against the live members. Each SAS member is imaged in read-only mode on the PC-3000 SAS card, then the stripe geometry, chunk size, parity rotation, and member order are reconstructed virtually in software with Data Extractor Express RAID Edition against the image files. The on-disk controller metadata carries that geometry, so the original card is not required. From the reconstructed virtual array we identify and skip the inconsistent parity stripes. If your controller logged a cache failure alongside a degraded set, treat it the same way as any other RAID 5 recovery case and image every member before touching the array. There are no diagnostic fees, and under the no data, no recovery fee policy the imaging and virtual reconstruction happen in-house at the Austin, TX lab.
What Causes Enterprise NVMe Firmware Failures in Server Arrays?
Modern servers use PCIe NVMe drives as high-speed caching tiers or primary storage. These drives suffer from controller firmware bugs under sustained write loads. Enterprise NVMe drives can enter controller diagnostic states where the drive reports the wrong capacity. When the Flash Translation Layer cannot initialize normally, the host OS cannot access the user data area.
These drives suffer from controller firmware bugs under sustained write loads that SAS spinners don't experience.
Enterprise NVMe drives can enter controller diagnostic states where the drive reports the wrong capacity instead of its actual size.
When the controller's Flash Translation Layer (FTL) cannot initialize normally, the host OS cannot access the user data area.
Software cannot scan a drive that reports the wrong capacity to the host operating system.
Standard commercial recovery tools do not support many modern enterprise NVMe controllers.
Because these drives use hardware-bound encryption, direct NAND extraction yields ciphertext.
The original controller must be brought back to a state where it can decrypt and serve the data.
For consumer-grade PCIe Gen4 NVMe drives (such as those using the Phison PS5016-E16 controller) occasionally repurposed in entry-level server caches, PCIe link training failures can prevent the drive from enumerating on the bus entirely.
NVMe enterprise SSDs in server arrays follow our firmware corruption recovery workflow, with firmware recovery priced at $900–$1,200.
How Does a Failed Power-Loss-Protection Capacitor Corrupt Enterprise NVMe Data?
A failed power-loss-protection capacitor lets a server NVMe drive lose its in-flight DRAM write cache on a power event, so the filesystem journal is torn mid-transaction while the drive still enumerates at its correct capacity and mounts. The NAND holds the data and the drive reports healthy, but the on-disk metadata is inconsistent.
Datacenter and enterprise NVMe drives carry onboard power-loss-protection (PLP/PLI) capacitors, such as tantalum polymer capacitors, whose job is to flush the volatile DRAM write cache to NAND when external power drops. Consumer drives generally omit this circuitry and depend on the host OS to sync writes.
When those capacitors degrade and lose charge, a sudden power loss drops the backup rail before the in-flight DRAM cache reaches NAND. The drive reports no error: it enumerates normally at its correct capacity and the NAND remains intact.
Because the final cache contents never landed, the filesystem journal or log, whether VMFS, NTFS, ReFS, XFS, or ext4, is torn mid-transaction. The volume still mounts, so the array looks healthy while the metadata is internally inconsistent.
Recovery requires read-only imaging to capture the dirty NAND state before any journal replay, fsck, chkdsk, or filesystem repair runs. Replaying a torn journal or letting a repair tool prune orphaned inodes and roll back incomplete transactions on the dirty state destroys otherwise recoverable data.
Each affected drive is imaged behind a write blocker using PC-3000 first, and the torn filesystem is reconstructed offline from that image, never by repairing the live drive.
What Causes SATA SSD Controller Failures in Legacy Server Arrays?
Silicon Motion SM2259XT controllers can enter a safe mode where corrupted wear-leveling tables cause the drive to report 0 bytes capacity. Marvell 88SS1074 controllers lock into a BSY state.
Silicon Motion SM2259XT controllers can enter a safe mode where corrupted wear-leveling tables cause the drive to report 0 bytes capacity to the host.
Marvell 88SS1074 controllers that fail to load firmware from NAND lock into a BSY state.
Both failure modes block any software-level recovery tool.
For Marvell 88SS1074 drives (ACE Lab family Venus, Marvell codename Dean), PC-3000 SSD's Marvell utility handles the BSY state.
SATA SSD recovery in server arrays starts at $200 for drives that read normally.
Vm san recovery
How Do We Recover Virtual Machines and SAN Storage?
We extract .vmdk and .vhdx virtual disk files from failed RAID arrays running VMware ESXi and Microsoft Hyper-V. When a SAN controller or firmware fails, the data still resides on the physical drives. We image them on PC-3000 and reconstruct the LUN layout and filesystem from raw images.
VMware ESXi and VMFS recovery. VMFS (VMware Virtual Machine File System) is a clustered filesystem designed for virtualization. When a VMFS volume becomes corrupted or the underlying RAID array degrades, we reconstruct the array from member drive images and parse the VMFS metadata to locate and extract individual .vmdk files for each virtual machine.
Hyper-V and .vhdx recovery. Microsoft Hyper-V stores virtual machines as .vhdx files on NTFS or ReFS volumes. When the host server's RAID array fails, we image the members, rebuild the array, and extract the .vhdx files intact. Individual files within the virtual disk can then be recovered as needed.
Traditional SANs. Dell EMC Unity, NetApp FAS, and HPE Nimble storage arrays present LUNs over iSCSI or Fibre Channel to host servers. When the SAN controller or firmware fails, the data still resides on the physical drives. We remove drives from the SAN chassis, image them on PC-3000, and reconstruct the LUN layout and filesystem from the raw images.
Virtual SANs (VMware vSAN). vSAN distributes VM storage objects across local disks in an ESXi cluster. A multi-node failure or metadata corruption can make the entire vSAN datastore inaccessible. We image the member drives from each affected node and reconstruct the distributed object layout to recover the underlying .vmdk files.
Software-Defined Storage (SDS). When the software layer (ZFS, Ceph, GlusterFS, or similar) fails but the underlying drives are physically intact, recovery focuses on imaging the drives and reconstructing the storage pool metadata. The physical drives contain all the data; the software layer is the map. We rebuild that map from the raw images. For ZFS-specific failures, our ZFS pool recovery guide covers pool states, TXG rollbacks, and safe diagnostic steps.
VM datastore on a degraded RAID array. When a VMFS datastore or a Hyper-V Cluster Shared Volume sits on a RAID 5 or RAID 6 array that has already lost a member, the recovery is a nesting-doll problem. The physical array is imaged member by member with PC-3000 first, because a URE during a live rebuild of a degraded array can collapse the set, and only then is the geometry reconstructed virtually in software so the .vmdk or .vhdx can be carved out and the guest filesystem mounted. Our VMware and Hyper-V recovery from a corrupted RAID array page walks through this two-layer reconstruction in detail.
Microsoft SQL Server and database extraction. After reconstructing the RAID array and parsing the host filesystem, we extract Microsoft SQL Server .mdf and .ldf files directly from the recovered volume. PostgreSQL, MySQL, and Oracle tablespace files follow the same extraction workflow. Our database recovery service covers application-layer corruption in detail.
ERP and accounting system databases. When a RAID controller cache fails during active writes, enterprise databases supporting ERPs (Microsoft Dynamics, SAP) or accounting systems often suffer from torn pages: 8KB SQL Server page boundaries interrupted mid-write. After array reconstruction, we extract the damaged .mdf and .ldf files using PC-3000 Data Extractor. Our SQL Server recovery service covers application-layer database corruption in detail.
Windows Server Storage Spaces (S2D). When a Windows Server "Virtual Disk" goes Offline or Detached in Storage Spaces due to stale metadata or dropped members, running the Repair-VirtualDisk PowerShell cmdlet on degraded pools can cause irreversible data loss by forcing parity recalculation across surviving members. We image the physical pool members and reconstruct the Storage Spaces metadata using Data Extractor Express RAID Edition, treating the pool as a software-defined RAID without relying on the original Windows Server host.
Enterprise difference
What Makes Enterprise RAID Recovery Different?
Enterprise server recovery differs from consumer NAS recovery in four ways: proprietary RAID controller metadata, SAS drive interfaces, multi-layer storage architectures that stack RAID, virtualization, and SAN protocols on top of one another, and the member count that has to be imaged drive by drive before reconstruction starts. Data Extractor Express RAID Edition is designed to interpret these proprietary formats and reconstruct arrays without the original controller.
Proprietary controller metadata. Enterprise RAID controllers from Dell (PERC), HP (Smart Array), and LSI/Broadcom write proprietary on-disk metadata that generic recovery tools cannot parse. Consumer NAS devices from Synology or QNAP use Linux mdadm or Btrfs RAID, which stores metadata in well-documented formats. Data Extractor Express RAID Edition is designed to interpret these formats and reconstruct arrays without the original controller.
SAS drive handling. Enterprise servers use SAS drives with dual-port connectivity and controller behaviors that do not present cleanly through a standard SATA port. We image these drives at their native protocol, preserving access to all addressable sectors including those outside the standard SATA command set.
Multi-layer storage stacks. A typical enterprise failure might involve a RAID array presenting a LUN over iSCSI to an ESXi host running VMFS with multiple VMs, each containing its own filesystem. Recovery requires reassembling every layer of that stack. The array must be recovered from raw disk images up through the guest filesystem.
Scale. Enterprise arrays routinely contain 8, 12, or 24 drives. Each member must be imaged individually before array reconstruction can begin. The imaging phase alone can take days for large arrays with degraded members, and the reconstruction phase must correctly handle the metadata from every drive in the set.
Controller Reconstruction. PERC, Smart Array, and LSI controller metadata is parsed from drive images and used to reconstruct stripe maps, parity rotation, and member ordering offline.
VM Extraction. After array reconstruction, VMFS and ReFS/NTFS volumes are parsed to locate .vmdk and .vhdx files. Individual VMs can be delivered separately.
Board-Level Repair. SAS drives with burned PCB components or TVS diode failures are repaired at the component level to restore readability before imaging begins.
RAID rebuild dangers
Why Do Forced RAID Rebuilds Fail on Enterprise Arrays?
The rebuild read load is highest on large arrays because every surviving member is stressed at the same time.
What actually kills a degraded array on the bench is mechanical, not a clean per-byte dice roll. A full-surface parity rebuild pins every surviving member at close to 100% sustained read for the length of the pass, and that load pushes an already-marginal head, preamp, or spindle bearing past its failure threshold mid-rebuild. A desktop or drive-managed SMR member without configurable TLER/ERC stalls during band rewrites past the controller command timeout, so the controller ejects a physically healthy drive and aborts. Members share a manufacturing batch, age, and thermal environment, so a second failure inside the rebuild window is correlated, not independent.
The URE math is a worst-case bound, not a schedule. Consumer-class drives carry a worst-case spec of roughly one URE per 10^14 bits read (~12.5 TB), and enterprise drives at 10^15 bits (~125 TB), but that number is a warranty floor: most drives read far past it without a single URE. Rebuilding a multi-TB array raises the probability of hitting a latent unreadable sector.
What happens when a URE does land is controller-specific. Legacy block-level hardware RAID and low-end controllers abort the rebuild and drop the volume offline; HP/HPE Smart Array P-series and E-series also abort and flag POST Error 1784/1786. Modern Dell PERC and LSI/Broadcom MegaRAID puncture the stripe instead, write a bad-block placeholder, finish the rebuild, and keep the volume online with only that stripe lost; Linux mdadm records the bad LBA in its Bad Block Log and continues. The data inside that stripe is gone for good, but one URE does not universally take the whole array down.
This is why we do not rely on the original controller hardware to recover data.
We image each member drive individually in read-only mode, then reconstruct the array offline with Data Extractor Express RAID Edition on the PC-3000.
This approach reads each sector exactly once, maps bad sectors without triggering a parity recalculation, and preserves the original data layout.
Do not force-import a foreign configuration. If your Dell server shows a PERC foreign configuration prompt after a controller swap or firmware update, importing the configuration can overwrite the on-disk metadata that maps drive order, stripe size, and parity rotation. Power off the server and contact a recovery lab before pressing any buttons.
How Much Does Enterprise Server Recovery Cost?
Enterprise server recovery follows the same transparent pricing model as every other service we offer: per-drive imaging based on each drive's condition, plus an array reconstruction fee for the virtual destripe. The fee depends on RAID level, member count, filesystem type, and whether stripe parameters must be detected from raw data or captured from surviving controller metadata.
Helium SAS and SATA Spinner Per-Drive Imaging Cost
Enterprise Exos, Ultrastar HC, WD Gold, Toshiba MG, and similar sealed 12TB+ members use helium HDD pricing when firmware complexity or mechanical work requires helium-specific handling.
01
02
From $600
03
$4,000–$5,000
Helium cost
NVMe Enterprise SSD Per-Drive Imaging Cost
01
02
03
04
05
Array Reconstruction Fee
Quoted per array on top of per-drive imaging costs. The fee depends on RAID level, member count, filesystem type, and whether stripe parameters must be detected from raw data or captured from surviving controller metadata. A 4-drive array where all members read normally costs less than a 12-drive array with two mechanically failed members.
Rush fee available: +$100 rush fee to move to the front of the queue. For a 6-drive array, the rush fee applies per drive ($100 x 6 =$600). Rush cases are moved to the front of the imaging queue.
No Data = No Charge: If we recover nothing from your server array, you owe nothing. Free evaluation, no obligation.
Published pricing: We publish our per-drive pricing because the work is based on the condition of each drive and the array reconstruction required.
We sign NDAs for corporate data recovery. All drives remain in our Austin lab under chain-of-custody documentation. We do not sign BAAs, but we are willing to discuss your specific data-handling requirements before work begins.
Enterprise intake
How Should Businesses Ship Server Arrays for Recovery?
Multi-drive server arrays require careful disassembly and packaging before shipping. Remove each drive from its hot-swap bay, label it with its slot position (bay 0, bay 1, etc.), and ship each drive individually in an anti-static bag with at least 2 inches of closed-cell foam.
Label slot positions before removal. Photograph the front panel with drives seated, then mark each drive caddy with its bay number using a label or marker on the caddy handle. Slot order determines stripe mapping in PERC, Smart Array, and LSI controllers.
Package drives in anti-static bags with foam padding. Each drive ships in its own anti-static bag, wrapped in at least 2 inches of closed-cell foam on all sides. Standard bubble wrap transmits shock; closed-cell foam absorbs it.
Ship via FedEx or UPS with tracking and insurance. We accept standard parcel carriers for most server arrays. For full-rack shipments exceeding parcel weight limits, freight carriers work. Declare the shipment value for insurance purposes. See our mail-in data recovery page for packaging details and our shipping address.
Include array configuration notes. Write down the RAID level, stripe size (if known), filesystem type (VMFS, NTFS, ReFS, XFS, ext4), and any recent events (power loss, rebuild attempt, firmware update) that preceded the failure. This context saves diagnostic time and reduces your total cost.
What Should IT Do in the First 30 Minutes After a Server Outage?
Power the server down, refuse rebuild or repair commands, photograph bay order, and preserve controller error screens before the chassis is touched. Those four artifacts cut hours or days off Dell PERC, Smart Array, VMware VMFS, and Storage Spaces recovery because they preserve the original stripe map and failure context.
Failure pattern
First action
Why it matters
Foreign Configuration or Missing Disks prompt
Power the server off, photograph the controller screen, label every bay, and do not import the configuration.
That preserves the original metadata path for Dell PERC foreign configuration and other RAID recovery cases.
Storage Spaces or ReFS virtual disk goes Offline
Do not run Repair-VirtualDisk or chkdsk /f. Export the error text and record every pool member serial number before removal.
We rebuild the virtual disk from member images, then parse ReFS metadata and any attached .vhdx files from clones instead of the live host.
VMware datastore disappears after power loss
Stop rescans, note the datastore names, and list which VMs matter first before the drives leave the rack.
VMFS recovery moves faster when the target datastore and VM names are known up front. See our VMware ESXi recovery page for the filesystem-specific workflow.
SQL Server goes into suspect state after a cache event
If the volume is still stable in read-only mode, save the SQL error log and list the affected .mdf and .ldf names. If storage is unstable, power the box off instead of attaching the database again.
We recover the array first, then extract the database files for database recovery work on cloned media.
Tell us which datastore, LUN, or database matters first. Once the stripe map is confirmed, we can prioritize a VMware VMFS volume, a ReFS volume, or a SQL file set before lower-priority shares.
Package the drives using our mail-in instructions and include that priority list in the box so the lab knows the recovery order before imaging begins.
What Happens After the Drives Reach the Austin Lab?
Once the drives arrive in Austin, we verify bay order, clone each member in read-only mode on PC-3000, capture controller metadata, and build the array virtually before file extraction starts. That keeps writes off the evidence and lets us target the highest-value VM, LUN, or database first.
Intake photos and slot-map verification. We compare the drive labels, intake photos, and your notes before a member is removed from its recorded bay order. That preserves the stripe map when a PERC or Smart Array controller wrote stale metadata to one member but not the rest.
Read-only imaging of every member. SAS disks are cloned on the PC-3000 SAS card. SATA members are cloned with PC-3000. We log weak heads, unreadable LBAs, and dropped links during the image instead of learning about them after a rebuild has already started.
Controller and pool metadata capture. We pull DDF blocks, HP Smart Array metadata, Storage Spaces headers, GPT maps, and filesystem superblocks from the images before any destriping attempt. Those structures tell us stripe size, parity rotation, member order, and where the live volume begins.
Virtual destriping and filesystem parsing. Once the map is confirmed, we reconstruct the virtual disk in software and parse VMFS, ReFS, NTFS, XFS, ext4, or ZFS from the working copies. That is where a server recovery case separates into VM extraction, database extraction, or raw file export.
Priority extraction and engineer update. If you told us one VM, one LUN, or one SQL database matters most, that target moves first. The same engineer doing the imaging and RAID reconstruction gives the update, not a sales relay.
If you want the broader chain from intake through return shipment, our recovery process page shows how the lab documents each step around diagnostics, imaging, and data return.
How Do We Prioritize Production Downtime Cases?
A failed database server or virtualization host halts access to production applications, internal tools, and customer-facing services. Enterprise server cases with active production outages are prioritized in our intake queue. SAS drives are imaged on the PC-3000 SAS card. Enterprise media is not bottlenecked through consumer SATA adapters.
The financial impact compounds by the hour.
We prioritize enterprise server cases that involve active production outages and can begin imaging within hours of receiving drives.
SAS drives are imaged on the PC-3000 SAS card. We do not bottleneck enterprise media through consumer SATA adapters.
How Do We Handle Confidentiality, NDAs, and Chain of Custody?
We execute bilateral NDAs for enterprise clients, law firms, and financial institutions before any drive is opened or powered on. Every case maintains chain-of-custody documentation from intake through return shipment. Drives remain in our Austin lab on isolated diagnostic networks throughout the recovery process. Certificates of media destruction are available upon request after data is delivered.
Enterprise IT teams can request our standard NDA before the array ships.
We return a signed copy the same business day so legal review does not delay intake or the imaging queue.
We offer certificates of media destruction upon request after data is delivered.
We do not sign Business Associate Agreements (BAAs). If your organization requires BAA coverage, we are happy to discuss the specifics of your data-handling requirements before work begins.
Recovery Time and Recovery Point Objectives
Refuse writes to the source array. RPO protection starts by refusing to write to the source array.
Image every surviving member. Every surviving member is imaged sector by sector on PC-3000 before any reconstruction is attempted.
Avoid controller-led rebuilds on degrading hardware. If a survivor hits an Unrecoverable Read Error, a modern PERC or MegaRAID controller punctures the stripe and the data in it is permanently lost, while legacy controllers abort and drop the volume.
Work from clones. Imaging first freezes the pre-failure state on working copies so all subsequent analysis happens on clones, never on the evidence.
RTO ranges depend on the failure mode, not on a marketing tier.
Failure mode
RTO range
Timeline driver
Degraded-but-accessible RAID 5 or RAID 6 array
Every member still reads, and members are imaged in parallel before virtual destriping begins.
Two or more failed members, Dell PERC NVRAM mismatch, or helium drive mechanical failure
7 to 14 days
Mechanical work on helium enterprise drives extends the timeline by donor head-stack sourcing for the exact Seagate Exos or WD Ultrastar HC model and firmware revision.
PCB-level repairs on controller boards use a Hakko FM-2032 on an FM-203 base for TVS diode and ROM chip replacement when the board shorts the 12V rail. A $100 rush fee is available to move the array to the front of the imaging queue.
How Does Forensic Chain of Custody Work for Litigation Cases?
Law firm, internal-investigation, and e-discovery cases receive a numbered custody log from intake photo through return shipment. Source drives are imaged behind a hardware write-blocker so physical evidence cannot be mutated, and SHA-256 hashes of the working image are recorded and re-verified after each analysis pass. Custody artifacts are delivered alongside the recovered data.
Source drives are imaged behind a hardware write-blocker so the physical evidence cannot be mutated by the host OS or by the imaging tool itself.
SHA-256 hashes of the working image are recorded at clone completion and re-verified after each analysis pass.
Custody artifacts are delivered alongside the recovered data so counsel can match image hashes against intake hashes in deposition.
The original source drives are returned untouched or held in bonded storage at the case owner's instruction.
Direct-Engineer Communication for IT Teams
The technician imaging your drives on PC-3000, parsing the DDF or HP Smart Array metadata, and virtually destriping with Data Extractor Express RAID Edition is the same person answering your phone calls and email threads.
Status updates cite the actual work performed (members imaged, bad-sector maps generated, parity rotation detected, stripe size confirmed), not a generic ticket state a sales rep is relaying from a back office. If the array cannot be recovered, our no data, no charge guarantee applies.
Intake
Every package is opened on camera. Your drive gets a serial number tied to your ticket before we touch anything else.
Diagnosis
Chris figures out what's actually wrong: firmware corruption, failed heads, seized motor, or something else. You get a quote based on the problem, not the "value" of your data.
Recovery
Firmware work happens on the PC-3000. Head swaps and platter surgery happen in our ULPA-filtered bench. Nothing gets outsourced.
4
Return
Original drive plus recovered data on new media. FedEx insured, signature required.
What Specialized Enterprise Recovery Services Are Available?
Detailed technical documentation on specific enterprise recovery scenarios covers VMFS datastore recovery, .vmdk extraction, snapshot chain repair, VHD/VHDX file recovery, ZFS pool failures, and Ceph OSD recovery. It also covers WAFL filesystem parsing, RAID-DP diagonal parity reconstruction, ReFS B+ tree metadata reconstruction, SAN LUN reconstruction, and enterprise SAS drive imaging on a PC-3000 SAS card.
VMware ESXi VMFS datastore recovery and .vmdk extraction.
Hyper-V VHD/VHDX file recovery and snapshot chain repair.
ZFS pool failures, Ceph OSD recovery, and WAFL filesystem parsing.
RAID-DP diagonal parity reconstruction and ReFS B+ tree metadata reconstruction.
SAN LUN reconstruction and enterprise SAS drive imaging on a PC-3000 SAS card.
Which Recovery Page Matches Your Stack?
The overview page covers the decision tree. If your outage centers on one storage layer such as VMFS, ReFS, SAN LUN mapping, ZFS, or a failing SAS member, the deeper subpages carry the filesystem, controller, and extraction detail that does not fit on a single overview.
VMware ESXi or vSAN datastore failure. What we reconstruct first: VMFS metadata, datastore layout, snapshot chains, and the target .vmdk set. Best next page: VMware ESXi recovery.
Hyper-V, Cluster Shared Volume, or ReFS outage. What we reconstruct first: ReFS metadata trees, CSV layout, and the affected .vhdx chain. Best next page: Hyper-V recovery and ReFS recovery.
Proxmox VE, Ceph, or ZFS-backed virtualization. What we reconstruct first: ZFS pool metadata, Ceph object placement, and qcow2 or raw guest disks. Best next page: Proxmox VE recovery.
TrueNAS pool import failure or degraded vdev. What we reconstruct first: ZFS labels, uberblocks, MOS metadata, and the dataset tree behind the failed pool. Best next page: TrueNAS recovery.
SAN controller failure or offline LUN. What we reconstruct first: LUN maps, 520-byte sector members, and the host filesystem sitting on top of the virtual disk. Best next page: SAN storage recovery.
SQL Server or ERP data after an array crash. What we reconstruct first: the RAID first, then the .mdf and .ldf files that need database-level repair. Best next page: SQL Server recovery.
Physical SAS drive failure inside the array. What we reconstruct first: member imaging, firmware access, and any board-level or clean-bench work needed before the array can be rebuilt safely. Best next page: SAS hard drive recovery.
Can you recover data from a Dell PowerEdge with a failed PERC controller?
Yes. We reverse-engineer PERC controller metadata and reconstruct the array offline from member drive images using Data Extractor Express RAID Edition, without needing the original controller.
Do you recover VMware VMFS volumes?
Yes. We reconstruct VMFS volumes from the underlying RAID array images and extract individual .vmdk virtual disk files for each VM. Hyper-V .vhdx recovery follows the same imaging-first approach.
Can you image SAS drives, or only SATA?
We image both. SAS (Serial Attached SCSI) drives require different interface hardware than SATA. Our lab uses a PC-3000 SAS card to image enterprise drives through the native SAS protocol.
How does the recovery workflow differ between SAS and SATA server drives?
Enterprise SAS drives are often formatted with 520-byte or 528-byte sectors under the T10 Protection Information (T10 PI / DIF) standard, where each 512-byte logical block carries an 8-byte Protection Information tuple (a 2-byte guard CRC, 2-byte application tag, and 4-byte reference tag tied to the LBA) for end-to-end integrity. Failing SAS drives report SCSI sense data (such as Sense Key 03h MEDIUM ERROR or 04h HARDWARE ERROR). SATA drives use 512-byte or 4K logical sectors, SMART attributes, and a single ATA interface, so the imager treats command timeouts and UNC errors differently. We image SAS members on the PC-3000 SAS card.
Why did our server array crash during an automatic hot spare rebuild?
A hot spare rebuild forces every surviving member into a continuous, full-surface read at the same time. Members in the same array were usually bought together and have nearly identical wear, head-load counts, and bad-sector growth, so the stress of resilvering routinely surfaces a latent Unrecoverable Read Error on a second drive. When that happens the controller cannot recompute parity for the affected stripe. A global or dedicated hot spare that auto-activates is therefore not a recovery feature; it is the moment when a degraded array often becomes a parity-loss case. Our workflow images every member on PC-3000 before any reconstruction, then destripes virtually with Data Extractor Express RAID Edition so no parity is ever written back to the source drives.
How do we verify our server backups are actually restorable before shipping the array?
A green status line in Veeam, Commvault, or Veritas means the last backup job completed without reporting an error. It does not prove the resulting backup chain restores. Before assuming a server array is non-critical because backups exist, mount the most recent full and incremental backup, restore at least one large database and one filesystem share to an isolated target, and run application-level integrity checks (DBCC CHECKDB for SQL Server, eseutil for Exchange, an actual file open for shares). Verify the backup chain reaches the point-in-time you need, not just the most recent job. If the test restore fails, treat the production array as the only copy and stop touching it. Power the server down, label the drives, and ship for read-only imaging.
Should our MSP attempt on-site server data recovery or ship the drives to your lab?
Draw the line at logical versus physical. Logical failures (filesystem corruption, accidental LUN deletion, ransomware on a healthy array) can sometimes be handled on-site by an MSP with verified backups and a tested restore process. Physical failures cannot. If a drive is clicking, has burned TVS diodes, has a seized spindle, has dropped offline with SCSI hardware-error sense codes, or if the controller is hanging at boot, on-site recovery is not a real option. We operate a single lab at 2410 San Antonio Street, Austin, TX with a ULPA-filtered clean bench; portable clean rooms do not exist for credible data recovery work. Power the server down, label each drive bay, and ship the drives. Per-drive imaging fees are based on drive condition, and there is no charge if no data is recovered.
How is enterprise server recovery priced?
Same transparent model as all our services: per-drive imaging fee based on drive condition, plus an array reconstruction fee. No data recovered means no charge. We do not add opaque emergency surcharges.
Can you handle sensitive corporate data?
We sign NDAs and maintain chain-of-custody documentation for every case. Drives remain in our Austin lab throughout the process. We do not sign BAAs, but we are happy to discuss your data-handling requirements on a case-by-case basis.
Why shouldn't our IT department force a RAID rebuild on the degraded array?
A rebuild pins every surviving drive at close to 100% sustained read until it finishes, and same-batch survivors at the end of their service life are most likely to fail mechanically in exactly that window. A latent Unrecoverable Read Error (URE) can also surface on a survivor during the pass. The outcome of a URE depends on the controller: legacy hardware RAID and HP Smart Array P/E-series abort the rebuild and drop the volume, while modern Dell PERC and MegaRAID puncture the stripe and continue. For irreplaceable, unbacked data on degrading hardware we do not gamble on a live rebuild: we image each member in read-only mode on PC-3000, then reconstruct the array in software without triggering destructive parity writes.
How do we ship a multi-drive server array for recovery?
Remove each drive from its hot-swap bay, label it with its slot position (bay 0, bay 1, etc.), and ship each drive individually in an anti-static bag with closed-cell foam padding. Include notes on the RAID level, stripe size, and filesystem type. Ship via FedEx or UPS with tracking and insurance.
What should our IT team do in the first 30 minutes after a server outage?
Power the server down, refuse rebuild or repair commands, and photograph every drive bay and controller error screen before anything is moved. Label each member by slot position and record the RAID level, filesystem, hypervisor, and last event before failure. That context lets us map the array faster once the drives reach our Austin lab.
Can you extract individual virtual machines from a failed server?
Yes. After imaging the physical drives and reconstructing the RAID array, we parse the host filesystem (VMFS for VMware ESXi, ReFS or NTFS for Hyper-V, ZFS for Proxmox) to locate .vmdk, .vhdx, or qcow2 virtual disk files. Each VM can be delivered separately. Guest OS files within the virtual disk can also be extracted individually.
Do you prioritize cases involving active production outages?
Yes. Enterprise server cases with active production downtime are prioritized in our intake queue. SAS drives are imaged on the PC-3000 SAS card, and array reconstruction begins as soon as all member images are complete. Contact us with your array configuration details so we can provide a timeline estimate before you ship.
My Dell PowerEdge shows 'The following virtual disks have missing disks' and asks to press C. What should I do?
Do not press 'C' to load the configuration utility and do not force-import the foreign configuration. The controller has detected that the DDF RAID metadata on the drives does not match the controller's NVRAM. Importing the configuration on physically degraded drives can trigger an automated rebuild that destroys the parity stripe when it hits an Unrecoverable Read Error on a surviving member.
How do you recover data from an HP ProLiant server showing POST Error 1785?
Error 1785 ('Drive Array Not Configured') indicates the Smart Array controller cannot detect a valid RAID configuration, often because multiple members dropped offline or the array metadata was corrupted. We do not use the HP Smart Array controller to recover the data. We image each SAS or SATA member drive on PC-3000 and use Data Extractor Express RAID Edition to parse the proprietary HP Smart Array metadata directly from the drives.
Should I run chkdsk or force an array rebuild if multiple drives show errors?
No. Running chkdsk /f on a physically degrading array forces Windows to aggressively truncate the Master File Table (MFT) and orphan critical file indexes when it encounters read errors on failing sectors. On a server with database files, this destroys .mdf headers and transaction log chains. Forcing a rebuild on degrading hardware is also reckless: the rebuild pins every survivor at sustained read for the length of the pass, and a marginal same-batch member can fail mechanically mid-rebuild. A surviving member can also hit an Unrecoverable Read Error; on legacy hardware RAID and HP Smart Array P/E-series that aborts the rebuild and drops the volume, while modern PERC and MegaRAID puncture the stripe and continue. Power down the server, label each drive bay, and ship the drives for read-only imaging with PC-3000.
Can you recover a Windows Storage Spaces or Storage Spaces Direct cluster after the virtual disk goes Offline?
Yes. We image each pool member, capture the Storage Spaces metadata from the disks, and rebuild the virtual disk layout without running Repair-VirtualDisk on the source members. ReFS, NTFS, and .vhdx extraction all happen from those images, not from the live cluster.
Do enterprise helium drives require different recovery procedures?
Yes. Helium-filled enterprise drives (Seagate Exos, WD Ultrastar HC, Toshiba MG series) use hermetically sealed chambers to reduce air turbulence, allowing tighter platter spacing and higher capacity. Opening a helium drive vents the helium, so the chamber has to be resealed and refilled before the platters spin again. These drives require donor parts from the same helium-sealed model family, and all open-drive work is performed on our ULPA-filtered clean bench. Helium drive recovery pricing starts at $200 for simple copies and reaches $4,000+ for surface damage cases.
Why shouldn't I use 'Import Foreign Configuration' on a degraded Dell PERC array?
When a Dell PowerEdge halts with a Foreign Configuration error, the DDF metadata stored on the physical drives no longer matches the controller's NVRAM. Importing the foreign configuration forces degraded drives online and can immediately trigger a Background Initialization or parity rebuild. If a surviving member hits an Unrecoverable Read Error during that forced parity write, the array transitions from recoverable to destroyed. Power off the server, label each drive bay, and ship the drives for read-only imaging via PC-3000.
Can you recover data if the RAID 5 array failed during a rebuild?
Yes. A failed RAID 5 rebuild usually means a surviving member hit an Unrecoverable Read Error (URE) during parity recalculation, dropping the array offline. We don't resume the rebuild. We write-block and image all member drives on PC-3000, map every bad sector, then virtually destripe the array using Data Extractor Express RAID Edition. The tool uses the XOR parity blocks from the original pre-rebuild state to reconstruct data across the failed sectors without triggering additional destructive writes.
Can you recover SQL Server or ERP databases from a crashed server array?
Yes. After imaging the member drives and reconstructing the RAID array offline, we extract .mdf and .ldf database files from the recovered NTFS or ReFS volume. If the RAID controller cache failed during active writes, the database often contains torn pages where SQL Server's 8KB page boundaries were interrupted mid-write.
How much does a 6-drive RAID 5 server array recovery cost?
Each drive is priced by its physical condition: $100 for a healthy drive that reads normally, up to $2,000 for surface damage requiring platter work. A 6-drive RAID 5 where all members read normally costs approximately $100 x 6 = $600, plus an array reconstruction fee for the virtual destripe. If two drives need head swaps, the total increases accordingly. No data recovered means no charge.
Is there a rush option for production server outages?
Yes. A +$100 rush fee to move to the front of the queue is available for any drive in the array. For a 6-drive array, the rush fee applies per drive ($100 x 6 = $600). Rush cases are moved to the front of the imaging queue, and SAS drives are imaged on the PC-3000 SAS card. Contact us with the array configuration before shipping so we can stage the appropriate SAS hardware.
How is NVMe enterprise SSD recovery in servers priced?
NVMe enterprise SSDs (Intel P5510, Samsung PM9A3, Micron 7450) follow our NVMe SSD pricing: $200 for a simple data copy, up to $1,200–$2,500 for advanced recovery. Supported Phison-based caching drives may be handled through PC-3000 SSD; proprietary enterprise controllers often require board repair or terminal access to restore controller function before data can be read. Servers that mix SAS spinners with NVMe caching drives are priced per-drive based on each drive's condition and interface type. The array reconstruction fee applies once per array, regardless of how many drives are NVMe vs. SAS.
How does a destructive RAID rebuild destroy our Recovery Point Objective?
If a surviving member hits an Unrecoverable Read Error, a modern Dell PERC or MegaRAID controller punctures the stripe and writes a bad-block placeholder, so the data in that stripe is permanently lost even though the volume stays online, while legacy controllers abort and drop the volume. Either way the pre-failure state is altered. We avoid that path entirely: each member is imaged on PC-3000, then virtually destriped in software so no write ever touches the source drives and the pre-failure state is preserved on our working images.
What is a realistic RTO for a failed multi-drive server array?
Degraded-but-accessible arrays where every member still reads normally typically complete virtual destriping 3-5 calendar days after intake. Catastrophic cases (two or more failed members, Dell PERC NVRAM mismatch, or helium drive mechanical failure) typically run 7-14 days, and the timeline on mechanical cases is driven by donor head-stack availability for the specific Seagate Exos or WD Ultrastar HC revision in the array. +$100 rush fee to move to the front of the queue.
Can you prioritize one VM, LUN, or database before the rest of the array?
Yes. Once the stripe map and filesystem metadata are confirmed, we can target a named VMFS datastore, .vhdx, .vmdk, .mdf, or .ldf set first instead of spending time on lower-priority shares. Tell us the business-critical workload before you ship so the extraction order matches your RTO.
Do you provide forensic chain of custody for litigation and e-discovery cases?
Yes. Law firm, internal-investigation, and e-discovery cases receive a numbered custody log from intake photo through return shipment. Source drives are imaged behind a hardware write-blocker so the physical evidence cannot be mutated by the host OS or by the imaging tool, and SHA-256 hashes of the working image are recorded and re-verified after each analysis pass. Custody artifacts are delivered with the recovered data so counsel can match image hashes against intake hashes in deposition.
Do IT administrators speak to the engineer doing the work, or to a sales rep?
You speak to the engineer. The technician imaging your drives on PC-3000, parsing the DDF or HP Smart Array metadata, and virtually destriping with Data Extractor Express RAID Edition is the same person answering your phone calls and email threads. Status updates cite the actual work performed (members imaged, bad-sector maps, parity rotation detected), not a generic ticket state.
Our VMware ESXi datastore disappeared after the disk was repartitioned or the GPT was damaged. Can you recover the VMFS?
Yes. A VMFS datastore lives inside a disk partition, GPT on current ESXi and MBR on older VMFS3 volumes, but the VMFS volume header and its resource metadata sit at fixed offsets inside the partition rather than in the partition-table entry itself. When an admin repartitions the LUN, runs the Add Storage wizard, or the partition table gets overwritten, ESXi stops mounting the datastore even though the VMFS structures still sit on the platters. We image every RAID member on PC-3000 first, reconstruct the array in software, then scan the flat image for the VMFS volume signature to rebuild the partition boundaries offline. Nothing is written back to the source drives, so a failed re-signature or an accidental mark-as-new-datastore does not cost you the .vmdk files. Tell us the datastore size and VMFS version if you know them, because that narrows the header search.
Can you recover a Windows Server dynamic disk (spanned, striped, or software RAID-5 volume) that shows Foreign or Failed Redundancy?
Yes, and it is a different problem from Storage Spaces. Windows dynamic disks store the volume layout in the Logical Disk Manager database that Windows writes to each member disk, separate from the partition table. When a member drops out, Disk Management flags the set Foreign or Failed Redundancy and offers to reactivate or repair, which can start a resync that writes across the surviving members. We image each member read-only first, then parse the Logical Disk Manager records from the images to rebuild the spanned, striped, or mirrored layout offline. That preserves the last consistent state of a software RAID-5 set while we map any member that also has bad sectors. Do not import the foreign disk or run a repair on the live server before the members are imaged.
We have a tower server or workstation with internally cabled drives instead of hot-swap bays. How do we ship it?
Ship the drives, not the tower. Tower servers and workstations usually mount drives on fixed rails or cages with individual SATA or SAS cables to the motherboard or an add-in HBA, so the slot order is not printed on the chassis the way it is on a hot-swap backplane. Before you unplug anything, photograph the drive cage and the cable runs, then label each drive with the controller port it was connected to and its physical position in the cage. Note whether the array is onboard motherboard RAID, a Windows software volume, or a dedicated HBA card, because the recovery path depends on where the RAID metadata lives. Pack each drive in its own anti-static bag with closed-cell foam and ship with tracking and insurance. If the workstation ran a single drive with no RAID, the labeling is simpler, but a photo of the cabling still helps us confirm the controller.
“HIGHLIGHT & CONCLUSION
******Overall I'm having a good experience with this store because they have great customer services, best third party replacement parts, justify price for those replacement parts, short estimate waiting time to fix the device, 1 year warranty, and good prediction of pricing and the device life conditions whether it can fix it or not.”
