This is technical documentation written by the engineers at Rossmann Repair Group. Each article explains how a specific storage technology works, how it fails, and what professional recovery involves at the hardware and firmware level. These are reference materials, not marketing pages. No pricing, no intake forms, no sales pitches.
HDD Mechanics
How the mechanical and electronic components inside a hard drive work, fail, and get repaired.
How Hard Drive Read/Write Heads Work
Technical explanation of HDD read/write head design, voice coil motors, slider aerodynamics, preamp chips, and common failure modes.
How Hard Drive Platters Store Data
How magnetic domains on HDD platters encode binary data. Tracks, sectors, servo wedges, and what platter damage means for recovery.
How Hard Drive Firmware Works
What hard drive firmware does, where it lives on the platters, and how translator modules and adaptive parameters affect data recovery.
What a Hard Drive Head Swap Involves
Step-by-step explanation of HDD head swap procedures: donor matching, preamp compatibility, ROM transfer, and head map alignment.
Hard Drive PCB Components Explained
What each component on a hard drive PCB does: MCU, preamp connector, motor controller, TVS diodes, and the ROM chip.
What Happens During a Hard Drive Head Crash
The physics of a head crash: how sliders lose fly height, the debris contamination cascade, and why continued operation destroys data.
CMR vs SMR: How Recording Technology Affects Recovery
How Conventional and Shingled Magnetic Recording differ in track layout, write performance, and data recovery complexity.
SMR Secondary Translator: Why a Drive Reports 0 Capacity
How SMR secondary translator corruption makes a hard drive mount at full capacity while every sector reads 0x00, and how the lab recovers it.
SSD Architecture
How NAND flash storage works at the cell level, and why SSD failures differ from hard drive failures.
How NAND Flash Cells Store Data
How floating gate and charge trap NAND cells store bits. SLC, MLC, TLC, QLC endurance, read disturb, and what cell wear means for recovery.
What TRIM Does and Why Deleted SSD Data Disappears
How the TRIM command tells SSD controllers which blocks are free, how garbage collection erases them, and why erased data is unrecoverable.
How SSD Wear Leveling Works
Static vs dynamic wear leveling, write amplification, block wear tracking, and what happens when NAND cells reach endurance limits.
What the Flash Translation Layer Does
How the FTL maps logical addresses to physical NAND locations, manages garbage collection, and what FTL corruption means for recovery.
How SSD Controller Encryption Works
How AES hardware encryption operates inside SSD controllers, key storage mechanisms, and why chip-off reads yield ciphertext.
Why an SSD Reports 0 Bytes
Three causes of SSDs showing 0 bytes: controller failure, FTL corruption, and NAND degradation. How lab diagnosis distinguishes them.
RAID & Storage Systems
Parity math, rebuild risks, and filesystem-level failure modes in multi-disk storage arrays.
How RAID Parity Actually Works
XOR parity math in RAID 5, distributed vs dedicated parity, RAID 6 dual parity, and how stripe layout affects rebuild and recovery.
Why Rebuilding a Degraded RAID Destroys Data
URE probability during rebuild, stress-induced failures in remaining drives, and why forcing a RAID rebuild risks total data loss.
How ZFS Differs from Hardware RAID
Copy-on-write vs in-place update, checksumming, self-healing reads, and what happens when ZFS pools fail compared to hardware RAID.
What Happens During a NAS Crash
Filesystem corruption on multi-disk NAS arrays, RAID metadata damage, and why pulling drives to scan with consumer tools makes recovery harder.
Recovery Science
The tools, environments, and procedures used in professional data recovery.
HDDSuperClone vs ddrescue
Lab comparison of HDDSuperClone vs GNU ddrescue. When each tool works, when both fail, and when a drive needs PC-3000.
Cleanrooms vs Laminar Flow Benches for Data Recovery
ISO 14644-1 classification, HEPA vs ULPA filtration, particle counts, and why HDD work needs a clean bench but not a full cleanroom.
What PC-3000 Actually Does
How the PC-3000 hardware-software platform provides vendor-specific firmware access for data recovery. Capabilities, limitations, and variants.
How Donor Drives Are Matched for Head Swaps
Firmware revision matching, head map compatibility, adaptive parameters, and physical generation criteria for selecting donor drives.
HDD PRML Read Channel Tuning
What PRML, EPRML, and NPML do in the read channel, which read-channel settings a recovery lab can change, and how adaptive parameters are handled after a head swap.
Chain of Custody for Shipped Drives
Packaging requirements, intake documentation, secure storage, and what happens to the original drive after data recovery is complete.
