Consumer Education
Why Data Recovery Costs So Much
Data recovery pricing changes when the job changes. A simple copy, firmware repair, head swap, helium refill, SSD controller failure, and NAND recovery all use different tools, donor parts, and labor. Rossmann Group publishes pricing before paid work begins, with no diagnostic fee and no data, no recovery fee.
Updated May 20, 2026
8 min read
Short Answer
Why does data recovery cost so much?
Data recovery costs more when the failed device needs specialized hardware work. A healthy drive copy is the lowest tier. Firmware repair needs PC-3000 access. A clicking HDD whose heads have failed needs donor heads & clean bench work. Helium HDDs add sealed-chamber handling and refill cost. SSD and flash recoveries move the problem to controllers, firmware, NAND chips, and board repair.
The quote should map to the failure. If the lab cannot explain the failed part, the tool used, the donor requirement, and the no-data policy, the price is not auditable.
Rossmann Group's published ranges are $100–$2,000 for hard drive recovery and $200–$5,000+ for helium hard drive recovery. Cost is set by failure tier, not by drive capacity.
Published Pricing
Rossmann Data Recovery Pricing
These are the published service ranges from the pricing source files. A final quote is given after evaluation because the same device model can fail logically, electrically, mechanically, or at the firmware level.
Hard Drive Recovery
Helium Hard Drive Recovery
    From $600
    $3,000–$4,500
    $4,000–$5,000
Helium cost
SSD Recovery
Cost Drivers
What Changes the Price
Data recovery price is set by failure type, not drive capacity. A working drive copy sits at the lowest tier; firmware repair, head swaps, and helium refill each step the price higher. Donor parts, clean bench work, and imager labor account for the cost difference between tiers.
Failure Type
A working drive that needs a copy is not the same job as firmware repair, a head swap, surface damage, SSD controller failure, or NAND chip work.
Donor Parts
Physical recoveries can consume donor hardware. For HDD head swaps, Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
Clean Bench Work
Mechanical HDD work requires a controlled work surface. We use a 0.02 micron ULPA-filtered clean bench for head swaps, platter cleaning, and contamination-sensitive work.
Helium Refill
Helium drives add sealed-chamber handling and refill steps. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
Firmware Tools
Firmware repair uses PC-3000 hardware to access service-area modules, ROM data, translators, defect lists, and vendor-specific recovery utilities.
Time on the Imager
Weak drives are copied slowly with head maps, resets, selective reads, and verification. The labor is in getting a stable image without making the patient drive worse.
Failure Table
Why One Drive Costs More Than Another
FailureWhat the Lab DoesRossmann Tier
Working driveCopy data to a target drive and verify the transfer.$100
File system damageImage the media, rebuild partitions, and extract files.From $250
Firmware faultUse PC-3000 to access service-area modules, ROM data, and translator records.$600–$900
Clicking HDD with failed headsSource donor heads, open the drive on a clean bench, replace the head stack, then image the drive safely.$1,200–$1,500
Helium HDDHandle sealed-chamber mechanics, donor matching, helium refill, and imaging.$200–$5,000+
SSD or flash failureDiagnose power rails, controller firmware, NAND access, BGA work, and raw dump reconstruction. NVMe SSDs run over PCIe, & their range ($200–$2,500) tops out higher than the SATA SSD range.$200–$1,500
Clean Bench
Clean Bench Work Is for Mechanical Drives
Hard drive heads float above spinning platters. When the heads fail, the drive must be opened where airborne particles are controlled at the work surface. Rossmann Group uses a 0.02 micron ULPA-filtered clean bench for head swaps, platter cleaning, and mechanical HDD work.
A clean bench does not recover data by itself. It provides the environment needed for a technician to replace heads, inspect platter condition, clean contamination, and get the patient drive ready for imaging. SSDs, USB flash drives, SD cards, and iPhones do not expose spinning platters, so their recovery cost comes from electronics and firmware work instead.
The practical question is not whether a company advertises a room. The practical question is whether the work surface, tools, and technician process match the failed device.
Donor Parts
Why Donor Parts Add Cost
A head swap is not a generic parts swap. The donor drive must match the failed drive closely enough for the replacement heads to read the patient platters. Model family, head map, firmware family, manufacturing details, and condition all matter.
The original drive's PCB and ROM data usually stay with the patient because they contain adaptive parameters calibrated for that drive. After the mechanical work, the drive is imaged with controlled retries and head maps instead of being mounted like a normal USB drive.
Donor hardware is a real consumed cost on physical recoveries. The quote should tell you whether donor parts are required and how they are billed.
Helium Drives
Why Helium Hard Drives Cost More
Helium-sealed enterprise drives use a sealed chamber and tight tolerances. When we open one up for mechanical work, it adds steps an air-filled desktop drive doesn't have: we open the welded casing in a controlled way & refill the helium.
Rossmann Group performs helium HDD recovery in-house, including mechanical work, helium refill, and platter cleaning. The published helium range is $200–$5,000+. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
SSD and Flash
Why SSD and Flash Recovery Is Different
SSDs do not have heads or platters. They fail through power faults, controller faults, firmware corruption, failed NAND, damaged PCBs, encryption locks, and wear-leveling problems. That work uses PC-3000 SSD, microscope diagnostics, hot air, BGA rework, and controller-specific reconstruction.
NVMe SSDs are a distinct, higher-ceiling class. They run over the PCIe interface. SATA SSD recovery is $200–$1,500; NVMe SSD recovery runs to $200–$2,500.
USB flash drives and SD cards add more variation. Some cases are a simple file-system recovery. Others require PCB repair or chip-off NAND reading. Rossmann Group publishes flash media pricing at $200–$1,500.
Deleted files on modern SSDs are a separate issue. TRIM and garbage collection can erase the mapping needed to reconstruct deleted data. Professional recovery is strongest when the problem is hardware, firmware, or access to an intact file system.
Donor Scarcity
Donor Scarcity Dimensions
Donor matching for hard drive data recovery is not "same model number." On Seagate F3 families such as Barracuda 7200.14, the firmware family, site code (such as WU or SU), date code window, head map, & preamp revision all have to line up.
Seagate Rosewood drives ship with a locked diagnostic terminal. PC-3000 gets terminal access back with an unlock patch. That is bench time spent before the donor question can even be settled, and it pushes the sourcing cost up.
Western Digital ROYL drives add another axis. The DCM encodes the head stack supplier and preamp configuration, and both must match.
Sourcing a donor screened against that much metadata is the slow, expensive half of a head swap, and it is billed as a disclosed donor cost rather than folded into the tier.
More detail on the procedure lives in how donor drives are matched and what a head swap involves.
PC-3000 Imaging
PC-3000 Imaging Labor
A weak HDD is not copied with a USB adapter. PC-3000 issues vendor specific commands that bypass the operating system ATA stack, so a stalled drive cannot freeze the host. Data Extractor builds a head map in RAM from ROM and service area data, isolates reads to individual heads, enforces millisecond timeout thresholds on each sector, and triggers a hardware power-cycle when the drive hangs instead of waiting on the kernel.
DeepSpar Disk Imager pairs with the PC-3000 workflow for SATA-layer instability. It runs custom PCIe firmware that schedules multi-pass directional reads, isolates read errors from bus errors, and supports head-by-head imaging on drives that lose heads partway through a session. The labor is in shepherding a failing drive through hours of conditional reads without losing the image.
See what PC-3000 actually does for the toolchain detail.
Translator Rebuild
Translator Rebuild Labor
Firmware repair on Seagate F3 drives touches service area SysFiles, specifically SysFile 1B (P-list), SysFile 35 (Non-Resident G-list), and SysFile 28 (primary translator). Work happens through the F3 terminal at the F3 T> prompt.
Before we run any translator regeneration command, we back up SysFile 28 & SysFile 35. Only then does the regeneration run.
WD DM-SMR drives in the Palmer family need a different procedure. They run a secondary translator at Module 190, accessed through the PC-3000 T2 translator workflow.
When Module 190 is corrupt, the drive reports its full capacity and returns 0x00 for every sector. On a drive like that, we lock its own writing through PC-3000, because a drive that's free to write will update what's left of the second-level translator.
The full procedure for that family is documented in WD SMR translator failure. This labor is why a firmware tier costs what it does relative to a working-drive copy.
Helium Refill
Helium Refill Workflow
Helium drives ship in a hermetically welded casing. Opening the casing requires specialized cutting inside the 0.02 micron ULPA-filtered clean bench so no metal shavings reach the platters. The donor head stack has to use the helium-compatible ramp set.
After the helium refill, we close the cavity with a temporary hermetic seal. Imaging on PC-3000 starts right away, because that temporary seal degrades with time.
That full workflow is why the published helium drive data recovery range is $200–$5,000+. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
Chain of Custody
Chain of Custody Cost
We wrote up our exact intake & handling procedure for mail-in drives on our page about chain of custody for shipped drives.
Rush Handling
Does Paying More Make Data Recovery Faster?
A rush fee buys queue position, not a different recovery process. Rossmann Group charges a flat $100 to move a case to the front of the evaluation & bench queue. The published tier price stays the same, & the physical work on a damaged drive takes as long as the drive allows.
The amount doesn't scale with the tier. The hard drive price list publishes +$100 rush fee to move to the front of the queue, & the SATA SSD, NVMe SSD, helium HDD, & flash lists all publish the identical $100.
Some labs sell expedited service as a percentage premium on the recovery total, so the urgency charge grows with the difficulty of the repair. A flat queue fee & a percentage premium are two different products: priority handling on a time-critical case changes when a technician looks at the drive, not what the repair costs.
Donor sourcing, clean bench time, & imaging passes have a floor money can't compress. Firmware repair on a failed hard drive publishes an ETA of 3-6 weeks, and a head swap publishes 4-8 weeks, whether or not the fee is paid.
A donor has to be located and matched before the drive is opened, and the imaging pace is set by how well the patient drive reads. The fee compresses the waiting, not the work.
One tier genuinely moves. Simple copy ($100) publishes 3-5 business days; with the rush fee that job finishes in 1-2 days or less, because a healthy drive needs no donor, no clean bench, and no retry strategy. The Austin lab runs Monday through Friday, so the fee moves a case up the weekday queue rather than adding weekend labor.
HDD TierPublished ETAWhat the Rush Fee Changes
Simple copy ($100)3-5 business daysDrops the job to 1-2 days or less.
File system recovery (From $250)2-4 weeksEarlier evaluation slot. The published ETA is unchanged.
Firmware repair ($600–$900)3-6 weeksEarlier bench slot. Service-area work still runs its full course.
Head swap ($1,200–$1,500)4-8 weeksDonor sourcing sets this calendar, so the fee only moves the queue.
Surface damage ($2,000)4-8 weeksQueue position only. Platter cleaning and imaging set the pace.
Every tier and ETA above comes from the same source as the published price list. If a lab quotes a faster calendar for a head swap than for a copy job, ask which step it plans to skip.
Quote Audit
How to Audit a Data Recovery Quote
A good quote is specific. It should tell you what failed, which tier applies, what parts are required, and what happens if recovery fails. Ask these questions before approving paid work.
  1. 01
    What failure did you diagnose?
  2. 02
    Was the drive opened, and if so, under what contamination control?
  3. 03
    Does this case require donor parts, helium refill, or chip work?
  4. 04
    Is the quoted price tied to a published tier?
  5. 05
    What happens if no data is recovered?
Software Limits
When Software Saves Money and When It Destroys Data
Recovery software is appropriate for logical problems on healthy media: deleted files, a reformatted partition, or a damaged file system on a drive that reads normally. It is not appropriate for a clicking, beeping, overheating, dropped, or intermittently disconnecting drive.
On a mechanically failing HDD, software forces the drive to keep retrying through bad heads and unstable firmware. That can turn a recoverable mechanical case into platter scoring or a partial image. Power off the drive if it makes abnormal sounds or drops offline.
The safe path is image first, repair second, and work from the clone whenever possible. That is why professional labs use hardware imagers instead of mounting the patient drive in an operating system.
How much does data recovery cost?
HDD recovery is $100–$2,000, helium HDD recovery is $200–$5,000+, SATA SSD recovery is $200–$1,500, NVMe SSD recovery is $200–$2,500, and flash or SD card recovery is $200–$1,500. NVMe SSDs run over PCIe, and their published range tops out higher than the SATA SSD range. The final tier depends on the failure found during evaluation.
Do you charge by the gigabyte?
No. Cost is set by the failure tier, not by data volume. If the heads have failed, a 500 GB drive and a 4 TB drive use the same head swap tier ($1,200–$1,500). The price changes when the failure changes, not when the capacity does.
Why does a clicking hard drive cost more?
Clicking means the drive cannot read its platters reliably, and finding out why takes bench time before anything is quoted. Where it is the heads, the job needs donor parts, clean bench work, ROM and firmware handling, and controlled imaging after the repair. That is a different job from copying a working drive.
Do you charge a diagnostic fee?
No. Evaluation is free. If we can't recover your data, there's no recovery fee. That's our no data, no recovery fee policy.
Are donor drives included?
Donor costs are separate when donor parts are needed. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
Why does helium refill matter?
Helium HDDs are sealed. After mechanical work, the drive must be refilled and sealed before imaging can continue. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber.
Can I use software first?
Use software only on healthy media with logical damage. Do not run software on a clicking, beeping, dropped, or unstable drive. Read data recovery software vs professional service before attempting a scan.
Can I pay to get my data back faster?
Partly. A flat $100 rush fee moves a case to the front of the evaluation and bench queue, and it is the same amount on HDD, SSD, NVMe, and flash cases.
A healthy-drive copy drops from 3-5 business days to 1-2 days or less. A head swap still runs 4-8 weeks, because donor matching and clean bench work set that calendar.
See emergency data recovery for how time-critical cases are handled.
What does the free evaluation determine before you get a price?
Which tier applies. The bench establishes the failure class.
The common findings are a healthy-drive copy, a damaged file system, a firmware or service-area fault, a head stack that can no longer read the platters, or an SSD controller that enumerates on the host bus but won't serve reads. That finding maps to a published tier, & the tier sets the base fee; donor parts, tax, & the target drive are itemized on top.
Once we've looked at the drive, you approve or decline the quote. Decline it & you aren't charged for the evaluation, because there's no diagnostic fee. Ship the drive to the Austin lab, then check the quote you get against the published tier list.
Why do two labs quote different prices for the same symptom?
Because the two numbers aren't covering the same scope. One quote can be the tier fee by itself; another can fold donor parts, a helium refill, the target drive your data ships back on, & tax into a single headline figure.
Rossmann Group quotes the published tier & itemizes the rest, so a head swap reads $1,200–$1,500 plus donor cost instead of one blended number.
Ask what a failed attempt costs, who pays return shipping when nothing is recovered, & whether the figure is tied to a published tier. If an attempt fails, we don't bill a recovery fee. That's in our no-recovery-fee terms. We take a 50% deposit up front on head swaps & platter work. Line those components up against the hard drive recovery tiers before comparing totals.
Need a Real Data Recovery Quote?
Send the failed device to our Austin lab for a free evaluation. If we can't recover the data, there's no recovery fee.
