SD card not recognized? Showing "needs to be formatted"? Physically broken after being forced into a slot?
We recover data from full-size SD cards used in DSLRs, mirrorless cameras, camcorders, and audio recorders. PCB repair, controller bypass, and direct NAND chip reading when needed.
Full-size SD cards contain a separate controller chip and NAND memory chip on a PCB. When the controller fails, the NAND can be desoldered and read directly using PC-3000 Flash. MicroSD cards are monolithic, with both components sealed in a single package, requiring spider-board adapters or precision micro-soldering to access the memory.
Unlike hard drive data recovery, which involves replacing physical read/write heads inside a 0.02µm ULPA-filtered clean bench, SD card recovery addresses electronic faults at the controller and NAND chip level. No moving parts means no clean bench requirement, but the recovery still demands precision soldering and specialized flash reading hardware.
Most full-size SD cards use a PCB-based design with a separate controller chip and NAND flash memory. UHS-II cards require a second row of pins using low-voltage differential signaling (LVDS), which typically requires a multi-layer PCB to route those traces.
All MicroSD cards are monolithic. Whether a full-size SD card is PCB-based or monolithic depends on the card's age, capacity, speed class, and manufacturer.
On older PCB-based cards, the NAND chip is a separate component that can be desoldered and read directly using PC-3000 Flash. This is standard chip-off recovery, and it works even when the controller is completely dead. On modern monolithic cards, recovery requires precision epoxy sanding and microscopic wiring to exposed test points, identical to the process used for microSD cards.
Monolithic recovery requires either precision spider-board adapters (using needle-like pins pressed against exposed test points) or manual micro-soldering to tap into the sealed package. We handle both microSD recovery and monolithic full-size SD recovery.
SD vs MicroSD Architecture
Feature
SD Card
MicroSD
Internal design
Often PCB + separate chips; some monolithic
Monolithic
NAND removable
On PCB designs (desolder)
No (sealed)
Recovery method
Chip-off or PCB repair
Spider-board soldering
Common use
Cameras, camcorders
Phones, drones, dashcams
What Is SD Express Data Recovery?
SD Express cards use the PCIe bus and NVMe protocol instead of the legacy SD interface. Recovery of a failed SD Express card follows NVMe and SSD workflows rather than the flash-card chip-off workflows used on ordinary SD cards.
The SD 7.0 specification introduced SD Express, which replaces the legacy SD bus with PCI Express lanes and the NVMe protocol. These are the same interfaces used in modern laptop and desktop SSDs.
SD 7.0 uses a single PCIe Gen 3 lane. SD 8.0 added PCIe Gen 4 x2 support.
From a recovery standpoint, an SD Express card is functionally a miniature NVMe SSD. The traditional SD pinout is retained for backward compatibility, but when operating in Express mode, the card communicates over PCIe. A dead SD Express card cannot be recovered using standard SD card readers or legacy chip-off workflows.
The diagnostic and imaging process mirrors NVMe SSD recovery rather than traditional flash card recovery.
SD Express cards are still uncommon in consumer cameras as of 2026, but CFexpress Type B (which also uses PCIe/NVMe) is already standard in professional cinema cameras and flagship mirrorless bodies. As SD Express adoption grows, expect recovery costs and procedures to align with SSD-class work rather than traditional flash card pricing.
SD Express Controller Architecture
SD Express controllers on the market include the Silicon Motion SM2708 (PCIe Gen 3 x2, SD 8.0) and the Phison PS5017 (PCIe Gen 3 x1), both using NVMe. The SM2708 pairs with 3D TLC NAND and handles wear leveling, ECC, and NVMe command queuing internally. The PS5017 supports similar configurations on a single PCIe lane with Phison's own firmware stack.
The SD Express specification requires 1.8V on the VDD2 power pin to enter PCIe Express mode. If the host device doesn't supply VDD2 (common with older card readers), the card falls back to the legacy SD interface, limiting speeds to ~104 MB/s.
A dead SD Express card can't be imaged through standard SD card readers at all. Legacy TSOP-48 flash readers can't reach the NVMe command set these controllers use.
SD Card Failures We Recover
What Types of SD Card Failures Can Be Recovered?
Recoverable SD card failures include physical PCB damage, controller failure, electrical damage, and file system corruption. SD cards have no moving parts, but the PCB, controller, and NAND flash are vulnerable to physical stress, electrical faults, and wear. Recovery depends on whether the NAND remains intact.
Physical PCB Damage
SD cards are thin and fragile. Forcing a card into a slot at an angle, stepping on it, or bending it can snap the internal PCB or sever traces between the controller and NAND chip.
Recovery approach: Desolder the NAND chip from the damaged board and read it directly with PC-3000 Flash. If the PCB crack is minor, we bridge the broken traces with jumper wires.
Controller Failure
The controller chip manages communication between your camera and the NAND flash. When it fails, the card may not be detected, show 0 bytes, or prompt "needs to be formatted."
Recovery approach: Bypass the controller entirely. Desolder the NAND chip, read the raw data, and reconstruct the file system from the dump.
Common SD card controllers: Full-size SD cards typically use controllers from SanDisk, Phison, or Silicon Motion. The controller scrambles stored data with an XOR pattern specific to that controller.
During chip-off recovery, the raw NAND dump appears as scrambled noise until that pattern is reversed. PC-3000 Flash carries a maintained database of controller XOR patterns, page formats, and FTL behavior. Controllers the database does not cover are handled by working backwards from the dump itself, searching it for FAT32 or exFAT boot records and directory structures until the transform falls out.
SanDisk 30.6MB capacity drop
A common SanDisk symptom is a 32GB, 64GB, or 128GB card that suddenly mounts as an unformatted ~30.6MB or 32MB RAW volume. This is not your data shrinking. A card that mounts at a tiny fraction of its rated capacity is reporting a controller or firmware fault, not the real contents of the NAND.
Running chkdsk or recovery software against that 30.6MB partition reads empty default sectors, not the NAND, so it returns nothing while stressing an already failing board. Recovery here means bypassing the controller: monolithic cards go to Spider Board probing on PC-3000 Flash, and PCB cards have the NAND desoldered and read directly.
Electrical Damage
Faulty card readers, USB hubs with poor voltage regulation, or static discharge can fry the controller or damage the NAND interface. The card may work intermittently or stop responding entirely.
Recovery approach: Test for short circuits on the PCB. If the controller is dead but NAND is intact, proceed with chip-off recovery.
When the controller cannot be revived, PCB-based cards have the NAND desoldered and read on PC-3000 Flash, while monolithic cards are reached through Spider Board probing of the exposed test pads, and the logical image is rebuilt from the raw dump either way.
File System Corruption
Pulling a card from a camera mid-write, power loss during file transfer, or a camera firmware bug can corrupt the FAT or exFAT file system. The card may appear empty, show as RAW, or produce read errors.
Recovery approach: Create a forensic sector-level image of the card. Rebuild the file system from the image or carve files using header signatures.
Software Problem or Hardware Failure?
Is It a Software Problem or a Hardware Failure?
SD card recovery software fixes logical problems on a physically healthy card: files you deleted, a card you accidentally formatted, or a partition that no longer mounts. A card that reports 0 bytes, demands a format, or fails to appear in the operating system at all is showing a controller or NAND hardware failure that software cannot reach, because the data path between the host and the memory is broken.
Tools such as Recuva, PhotoRec, R-Studio, and the EaseUS and CleverFiles products read the card the same way your camera does: they ask the card's controller for sectors and scan what comes back. That works only while the controller still answers and the NAND still returns its contents.
When the symptom is a dead controller, a snapped PCB trace, or degraded NAND, the card never presents readable sectors to scan, so a software pass returns nothing or stalls. The same reasons that data recovery software fails on degraded flash memory apply to SD cards: the failure is below the layer the software can address.
Software can handle these
You deleted photos or video and have not written new files since
You ran a quick format and the card still mounts at its full capacity
The card mounts and reads, but a partition or folder is missing or shows the wrong name
The card is detected at the correct size and reads without errors or hangs
Hardware failure: stop and send it in
The card reports 0 bytes, or a fraction of its rated capacity
The operating system or camera demands a format before it will mount the card
The card does not appear in the operating system in any reader
The card detects intermittently, gets warm in a reader, or hangs the scan partway
Do not format a RAW card to fix it
When a card reads as RAW or prompts "needs to be formatted," the directory and file allocation tables that point to your photos have become unreadable, not the photos themselves. Accepting the format prompt writes a fresh FAT32 or exFAT structure over those same metadata sectors.
That overwrites the metadata a technician would otherwise rebuild from. The safe move is to power the card down, leave it untouched, and send it for a free evaluation so we can image the card before anything writes to it.
SD Card Recovery Process
How Is Data Recovered from a Failed SD Card?
SD card recovery starts with a forensic image of the NAND memory, then progresses through controller bypass, XOR descrambling, and file system reconstruction. The approach is always image-first: we secure a copy of the raw data before attempting any repair. The steps vary depending on failure type.
Unlike hard drive recovery where the primary challenge is mechanical head failure, SD card recovery addresses electronic and firmware-level faults at the controller and NAND chip level. If the controller is dead or the PCB is damaged, we either bridge broken traces or desolder the NAND chip for direct access.
Visual Inspection and Damage Assessment
Inspect the card under magnification for cracked housing, bent contacts, broken PCB traces, or signs of electrical damage (burn marks, discoloration). Test with a known-good reader to confirm whether the controller responds.
PCB Repair or Controller Bypass
If the controller still functions, we image the card directly. If the controller is dead or the PCB is damaged, we either bridge broken traces or desolder the NAND chip for direct access. SD cards use standard NAND packages (TSOP-48, BGA, or LGA/TLGA) that can be cleanly removed with a hot-air rework station.
NAND Imaging with PC-3000 Flash
The desoldered NAND chip is placed in a reader adapter and connected to PC-3000 Flash. We read the raw memory contents page by page, applying multiple passes to produce a clean dump. This raw dump includes all data currently stored on the NAND.
Note: a format that overwrites the data areas, as opposed to a quick format that rewrites only the metadata, destroys recoverable data regardless of card condition.
Monolith Bus Line Autodetection
Monolithic SD cards (and all microSD cards) seal the controller & NAND in one package with no published pinout diagram. We use the PC-3000 Flash Spider Board Adapter, which presses needle-like pins against exposed bus line test points on the chip surface. PC-3000 Flash's automatic pin sequence detection (introduced in software update 7.5.11) resolves the correct bus line order without destructive trial-and-error soldering.
The technician sets the spider board needles, selects "Read Chip ID" for the current configuration, and the software autodetects the Chip ID, confirming the pin order is right. This removes guesswork on undocumented monoliths.
Overcoming Read-Disturb and Charge Bleed
NAND cells store data as trapped electron charge, and that charge drifts over time (retention loss) or shifts under repeated reads of neighboring cells (read-disturb, common on dashcam and drone cards that loop-record for months). A consumer card reader has one fixed sensing threshold, so once a cell's voltage has drifted past it the reader simply returns CRC errors and gives up on the block.
PC-3000 Flash uses the NAND's own Read Retry commands to step the reference voltage across a range of levels, taking multiple read passes of the marginal page to resolve bits that a single-threshold read could not. That is how the bench recovers data from degraded cells that a card reader marks as unreadable.
4
Data Reconstruction
Apply ECC correction to fix bit errors, decode any XOR scrambling used by the controller, and reassemble the logical block layout. Once the logical image is reconstructed, we mount the file system (FAT32 or exFAT) and extract files. If the file system is too damaged, we carve files using header and footer signatures.
FAT32 Reconstruction for Legacy Controllers
Older SD cards using AU, SSS, or FC controllers store data without standard translator or block number metadata in the NAND firmware. On these controllers, PC-3000 Flash can't use the usual block-mapping approach to rebuild a logical image. Instead, we use the "Image based on data analysis (FAT32)" assembling method.
This bypasses the need to manually align blocks based on file system allocation tables.
5
Verification and Delivery
Spot-check recovered files: open sample photos, scrub through video clips, verify file counts against directory metadata. Deliver recovered data on a new USB drive or external hard drive. We provide a file listing before delivery so you can confirm we recovered what you need.
Recovery for Photographers and Videographers
How Does SD Card Recovery Work for Photographers and Videographers?
SD cards are the primary storage medium for professional camera systems. A card failure during a wedding shoot, commercial production, or documentary project means lost revenue and work that cannot be re-created. We recover RAW photos, 4K/8K video, and professional audio from all SD card formats used in DSLR, mirrorless, and cinema cameras.
We recover all professional file formats written by camera systems:
Audio: WAV, BWF, AIFF from field recorders (Zoom, Sound Devices, Tascam)
RAW and high-bitrate video files are large files written sequentially by the camera. On a freshly formatted card, they tend to be stored contiguously, which aids carving from a raw NAND dump. After cycles of deleting and reshooting, fragmentation increases as the filesystem reuses freed clusters.
Formatting the card before each shoot minimizes this effect.
Time-Sensitive Recovery
Wedding photographers and production crews often face delivery deadlines. Turnaround tracks the tier the job lands in: 3-5 business days for a copy off functional media, 2-4 weeks for file system recovery, 3-6 weeks for PCB repair, and 4-8 weeks for chip-off.
Rush is a queue position, not a shorter reconstruction: +$100 rush fee to move to the front of the queue. Contact us to discuss your timeline.
What NOT to Do
Do not format the card when prompted by your camera or computer
Do not write new photos or video to the card
Do not run consumer recovery software on a physically damaged card
Remove the card, store it safely, and send it for professional evaluation
Drone and Action Camera SD Card Recovery
How Is Drone and Action Camera Footage Recovered from SD Cards?
Action cameras and drones write MP4 and MOV video in two separate components: the raw video data and the index that maps timestamps to byte positions. When a drone crashes or a GoPro loses power mid-recording, the index is never finalized. Professional recovery reconstructs the container index from the raw video stream to restore playable footage.
Action cameras (GoPro Hero series, DJI Action, Insta360) and drone-mounted cameras (DJI Mavic, Air, Mini series) write video data differently from traditional cameras.
MP4 and MOV files use a container format with two critical components: the mdat atom (the raw video and audio binary data) and the moov atom (the index that maps timestamps to byte offsets within the mdat). The moov atom is typically written last, when recording stops. If a drone crashes, a GoPro loses battery, or the card is ejected mid-recording, the moov atom is never finalized.
The raw video data exists on the card, but no index tells a media player how to read it.
Consumer recovery software cannot handle this scenario because it relies on intact file system metadata and container headers. Professional recovery rebuilds the moov atom index from the sample structure in the raw mdat stream, reassembling playable video from what appears to be unstructured binary data.
Action Camera Recovery Considerations
High write endurance demands: Action cameras writing continuous 4K/5.3K video push SD cards toward their rated write cycles faster than typical photo use. Cards rated for lower endurance (standard TLC) may develop bad blocks and read errors sooner.
SD Card Firmware Failures
What SD Card Firmware Failures Are Distinct from Physical Damage?
SD card firmware failures happen inside the controller, not on the physical board. When the controller panics on an exhausted wear-leveling pool or its flash translation layer corrupts, the card's host interface goes offline while the NAND stays intact. Recovery reads the raw NAND and rebuilds the translator in software.
A wedged controller isn't a broken board. The NAND still holds every byte you wrote; the fault sits in the firmware layer that translates your files into physical flash addresses. Controllers panic from exhausted wear-leveling pools, latch-up, or thermal stress, & when they do the card's SD or USB host interface goes offline while the memory underneath stays intact.
Symptoms you can see
The card mounts at the wrong capacity or reports a fraction of its rated size.
The card demands a format or shows as a RAW volume, even though nothing physically broke.
The card detects at 0 bytes or disappears from the operating system after a firmware panic.
Detection comes & goes, degrading over successive insertions as the controller keeps retrying a corrupt translator.
File-system-visible symptoms often trace to a corrupt flash translation layer. The logical-to-physical (L2P) map that tells the controller where each block lives is held in controller memory & firmware; when it corrupts, the card can mount at the wrong capacity, report a fraction of its rated size, or present a RAW volume that prompts you to format it.
A card can also report a capacity it never had because it was built that way. If your files came back empty rather than damaged, read how a counterfeit SD card reports storage it does not have before paying for a recovery attempt, because data the controller discarded at the real capacity boundary was never written to flash & cannot be read back.
A third failure is spare-pool exhaustion. Every flash controller reserves a percentage of the NAND as a spare-block pool & remaps failing blocks into it; once that reserve is spent, the controller can no longer retire a bad block & endurance is finished. Rebuilding that lost mapping from the raw dump is its own reconstruction step, handled during chip-off.
Chip-off recovery reaches data a wedged controller can't. We read the raw NAND directly on PC-3000 Flash, then rebuild the translator in software from the spare-area (OOB) metadata, so a dead host interface no longer stands between you & the files. Chip-off recovery runs $1,200–$1,500.
Speed Class Recovery Differences
How Does Recovery Differ Across UHS-I, UHS-II, and V90 Cards?
UHS-I cards use a single row of bus pins; UHS-II adds a second row of low-voltage differential pins routed through a multi-layer PCB; V90 is a sustained-write video rating with a guaranteed 90 MB/s floor. Recovery difficulty follows the pin rows and PCB layers a card carries, not its headline speed.
Speed Class
Physical Interface
Recovery Implication
UHS-I
Single-row bus, up to ~104 MB/s
Standard PCB chip-off or direct controller imaging; the NAND desolders & reads on PC-3000 Flash
UHS-II
Second-row LVDS pins on a multi-layer PCB
Severed second-row traces need multi-layer PCB repair before imaging; the NAND itself still reads via chip-off
V90 (Video Speed Class 90)
90 MB/s guaranteed sustained write
Heavy sustained 4K/8K writes wear the NAND faster; more read-retry & bad-block work at reconstruction
UHS-II adds its speed with a second row of pins carrying low-voltage differential signaling (LVDS). Routing those pairs takes a multi-layer PCB, so a crack that severs an inner-layer trace can't be jumpered on the surface the way a single-layer UHS-I break can.
The NAND still reads through chip-off, but the board repair ahead of it is the harder, slower part. A UHS-II card also keeps its first pin row & falls back to UHS-I mode in a legacy reader, which helps us confirm whether the fault sits in the second-row interface or deeper in the controller.
V90 targets sustained write, not peak burst. The Video Speed Class floor of 90 MB/s exists so 4K & 8K cameras never drop frames, & holding that floor for hours pushes program/erase cycles harder than photo use. Cards that shot heavy video arrive with more worn cells, so the reconstruction stage leans on read-retry at stepped reference voltages to pull bits back from charge-degraded pages.
Write Patterns by Device
How Do Camera, Drone, and Dashcam Write Patterns Change SD Card Failures?
Write pattern decides how an SD card fails. Cameras write in bursts and reformat per shoot, so they fail from file-system corruption and snapped PCBs. Drones add crash power-loss. Dashcams loop-record around the clock and lose power at ignition-off, driving endurance wear and spare-pool exhaustion.
Cameras (DSLR, mirrorless, cinema)
These bodies write large RAW frames & high-bitrate video in bursts, then reformat the card before the next shoot. Their dominant failures are file-system corruption from a card pulled mid-write & a snapped PCB from forcing the card into a slot at an angle. Because each clip lands in a mostly contiguous run, files carve cleanly from a NAND dump. File-system repair on a healthy board starts at $300–$600.
Drones (DJI Mavic, Air, Mini)
A crash cuts power mid-write, leaving the MP4/MOV index (the moov atom) unwritten & the flash translation layer mid-update, so the footage needs container-index reconstruction rather than a plain file copy. Continuous flight recording also runs the card's endurance budget down faster than photo use.
Dashcams (24/7 loop record)
Dashcams loop-record around the clock & take an ignition power-cut at the end of every drive, so they push read-disturb & endurance wear faster than any camera card. Those cards wear their spare-block pool down until the controller can no longer remap. Our dashcam & body-cam recovery workflow covers the microSD wear-out & video reconstruction path in detail.
Chip-off Workflow
NAND Chip-off Workflow on the PC-3000 Flash Bench
Once a full-size SD card is classified as a chip-off candidate (dead controller, shorted PCB, or broken traces between controller and NAND), the card moves to the soldering bench. A $1,200–$1,500 chip-off recovery involves four sequential stages: NAND package identification, controller family routing, multi-die merging, and bad block map reconstruction.
NAND Package Identification
SD card NAND is packaged in one of a few standard form factors, and the package dictates the desolder method. Legacy and industrial cards use TSOP-48, which comes off with a conventional hot-air station under a polyimide protective film. Modern high-density discrete NAND uses BGA-132 or TLGA-52, which require a Zhuo Mao or equivalent precision BGA rework station with bottom heat and a thermal ramp profile matching the original reflow.
Monolithic SD cards are a different problem entirely: the controller die and NAND die share a single epoxy-sealed package with no exposed NAND chip to desolder. Monoliths require epoxy sanding to expose the NAND die test points, followed by spider-board probing rather than chip removal.
Controller Family Routing
Every chip-off job begins with controller identification before desolder, because the controller model determines which PC-3000 Flash translator building algorithm handles the reconstruction. Identifying the controller selects the controller-specific reconstruction support in PC-3000 Flash, whose maintained database holds known XOR patterns, page formats, and FTL behavior.
SanDisk-branded cards using in-house controllers have their own modules with controller-specific bad block reservation patterns. Skipping this identification step and applying a generic XOR mask produces a dump that never descrambles into valid file-system structures or readable files.
Multi-Die and Multi-Plane NAND
Higher-capacity SD cards stack multiple NAND dies inside a single package using wire-bonded chip-enable (CE) lines. Each die must be read independently through its own CE pin, then merged into a single logical image in the correct interleave order.
Dual-plane NAND (where each die contains two independent planes that can read in parallel) adds a second layer of interleaving within each die dump. Misaligning the interleave pattern by even one page shifts the entire logical image out of alignment and turns recoverable files into noise.
Bad Block Map Reconstruction
Every flash controller reserves a percentage of NAND capacity for bad block replacement. When a block is marked bad during the controller's lifetime, a replacement block from the reserve area takes over its logical address. That mapping lives in the controller's own firmware area and is lost the moment the controller dies.
On chip-off recovery, the reserved blocks appear as fragments of in-order data surrounded by discontinuous offsets. PC-3000 Flash rebuilds a virtual image by searching the descrambled dump for FAT32 and exFAT boot records and directory structures; stubborn cases require manual bad block map rebuilding using a hex editor and knowledge of the specific controller's reservation policy.
This step is why some chip-off jobs push past the 4 to 8 week baseline window. Rush service (+100) moves a card to the front of the bench queue, but chip-off turnaround is bounded by the reconstruction steps above, not by queue position alone.
SD card data recovery starts at $200 for logical file system repair and reaches $1,200–$1,500 for chip-off recovery on monolithic cards. Final pricing depends on the failure type, card architecture (PCB-based vs. monolithic), and the complexity of the NAND reconstruction.
Your flash drive or SD card works, you just need the data moved off it. Rush available: +$100
$300–$600
Your flash drive or SD card isn't showing up, but it's not physically damaged. Starting price; final depends on complexity
PCB Repair
Your flash drive or SD card has shorted components or won't power on. May require a donor drive (additional cost)
Chip-off Data Recovery
Your flash drive or SD card needs physical NAND chip extraction to recover the data. 50% deposit required
Detailed Pricing Breakdown
01
02
$300–$600
03
PCB Repair
04
MicroSD and SD card recovery share the same NAND chip-off and spider-board techniques. This video shows the process on a monolithic flash card using PC-3000 Flash and ACELAB adapters. The same NAND recovery process applies to full-size SD cards with monolithic construction where the controller and NAND are sealed in a single package.
SD Card Recovery Terminology
SD card recovery involves controller bypass, XOR descrambling, and NAND chip-off. Understanding these terms helps you follow what we find during evaluation and why each step matters. The six terms below cover the PCB, controller, NAND flash, ECC, and XOR scrambling concepts referenced throughout this page.
These are the parts and procedures that determine whether the card can be imaged through the controller or read directly with PC-3000 Flash.
Chip-off
Desoldering the NAND flash chip from the card's PCB and reading it directly with a flash reader (PC-3000 Flash or similar). Used when the controller is dead or the board is physically destroyed.
PCB (Printed Circuit Board)
The thin fiberglass board inside a full-size SD card that connects the controller chip, NAND chip, and contact pads. Cracked PCBs sever electrical traces between components.
Controller
The IC that manages read/write operations, wear leveling, ECC, and communication between the host device and the NAND flash. When it fails, the card is not detected even though data remains on the NAND.
NAND Flash
The non-volatile memory chip that stores your data. SD cards typically use MLC or TLC NAND. The data persists on NAND even after the controller fails or the PCB is damaged.
ECC (Error Correction Code)
An algorithm applied by the controller to detect and correct bit errors in NAND pages. During chip-off recovery, the correct ECC parameters must be identified and applied to produce a clean data dump.
XOR Scrambling
A data transformation applied by nearly all modern SD card and flash memory controllers. XOR scrambling converts stored data into noise-like patterns with a roughly even distribution of ones and zeros. The scrambling key is specific to the controller model and must be identified and reversed during chip-off recovery before the file system becomes readable.
SD Card Recovery: Common Questions
Can data be recovered from a broken SD card?
In most cases, yes. Full-size SD cards contain a small PCB with separate NAND flash and controller chips. If the plastic housing is cracked or the PCB has snapped traces, we can often repair the board or desolder the NAND chip and read it directly using PC-3000 Flash.
How much does SD card recovery cost?
SD card recovery is $200–$1,500. Simple data transfers start at $200. Chip-off NAND extraction is $1,200–$1,500. File system recovery (corruption, accidental format) is $300–$600. PCB repair for shorted components or broken traces is $600–$900. We provide a firm quote after a free evaluation; no data, no charge.
Can you recover RAW photos from a corrupted SD card?
Yes. RAW image files (CR2, NEF, ARW) are large files that cameras write sequentially. We image the NAND and reconstruct the flash translation layer to rebuild a logical filesystem image. If the filesystem metadata is too damaged, we fall back to file carving using known file-type signatures. On a freshly formatted card, RAW files tend to be stored contiguously, which aids both approaches. Fragmentation increases after repeated delete/shoot cycles.
What is the difference between SD card and MicroSD recovery?
Full-size SD cards use a PCB with separate NAND and controller chips. MicroSD cards are monolithic (controller and NAND sealed together in a single inseparable package). SD card recovery often involves standard chip-off. MicroSD recovery requires spider-board adapters or micro-soldering, which is more labor-intensive and typically costs more.
Do you offer rush turnaround for wedding photo recovery?
Rush moves your card to the front of the queue (+$100 rush fee to move to the front of the queue). It does not shorten the reconstruction work, so turnaround still tracks the tier: 3-5 business days for a copy off functional media, 2-4 weeks for file system recovery, 3-6 weeks for PCB repair, and 4-8 weeks for chip-off.
Can data be recovered from an SD card dropped in water or saltwater?
In most cases, yes. The NAND flash chip inside an SD card is sealed in an epoxy or plastic package that resists short-term water exposure. Our process involves ultrasonic cleaning, isopropyl alcohol displacement, and mechanical cleaning of oxidized contacts. If the controller is damaged by corrosion, we proceed with chip-off NAND recovery.
Can you recover video from a crashed drone or GoPro?
Yes. When recording stops unexpectedly, the MP4/MOV container index (moov atom) is never written. We rebuild that index from the sample structure in the raw mdat stream. If the card is physically damaged from impact, we combine chip-off NAND recovery with video container reconstruction.
Can deleted files be recovered from an SD card?
In most cases, yes. Standard SD cards and cameras do not use the TRIM command that modern SSDs use to erase data blocks immediately after deletion. When you delete a photo or video, the file system marks those clusters as available but the NAND cells retain the data until new files overwrite them. Recovery via file carving is effective as long as the sectors have not been rewritten.
Should I run chkdsk or recovery software on a failing SD card?
Not if the card has physical symptoms: not detected, wrong capacity, or freezing during reads. chkdsk and file system repair utilities force aggressive read/write cycles across the entire card. On degraded NAND, those extra cycles push failing memory cells past the point of recovery. Software tools are safe only when the card is physically healthy and the data loss is purely logical (accidental deletion, quick format). If the card shows intermittent detection or gets hot during use, stop powering it and send it for professional chip-off evaluation with PC-3000 Flash.
Why don't SD card recoveries require a cleanroom?
SD cards contain solid-state NAND flash chips and a controller IC. No moving read/write heads, no magnetic platters, no spinning disks. Airborne particulate control (cleanrooms, clean benches) protects exposed platters during hard drive head swaps. SD card recovery is entirely electronic: micro-soldering, NAND chip desoldering with hot-air rework, and firmware-level imaging with PC-3000 Flash. A cleanroom has no bearing on the outcome of an SD card recovery.
Why do monolithic SD cards take longer to recover than PCB-based cards?
PCB cards have separate NAND and controller packages. We desolder the NAND with hot-air rework, then rebuild the flash translation layer. Monolithic cards fuse the controller, NAND die, and wire bonds into a single epoxy package. We abrade the package to expose internal test points, then land it on a spider-board adapter whose precision needles make contact under mechanical pressure. Working out the pinout on an undocumented card family is the slow part. PCB repair runs 3-6 weeks; chip-off runs 4-8 weeks.
Do you recover data from SD Express cards that use NVMe and PCIe?
Yes. SD Express adds a second row of pins carrying a PCIe Gen3 x1 or Gen4 x1 lane running NVMe, on top of the legacy UHS-I bus on the first row. When an SD Express card fails, we first test the legacy SD bus; if the card still enumerates over UHS-I, standard controller imaging often works. When the PCIe side is dead, chip-off is a last resort. The NAND inside SD Express cards uses the same 3D TLC as consumer NVMe SSDs and relies on LDPC error correction with soft-decision decoding that the original controller performs by issuing retry reads at shifted voltage thresholds. Raw chip-off cannot reproduce the soft-decision data, so LDPC-protected dumps often cannot be corrected offline.
My UHS-II card works in a USB 3.0 reader but not in my camera. What failed?
A card that works in UHS-I readers but fails in a UHS-II host points at the second row of pins. UHS-II adds 8 recessed contacts carrying sub-LVDS (low-voltage differential signaling) lanes: a transmit differential pair, a receive differential pair, and a reference clock pair, rated up to 312 MB/s half duplex and 156 MB/s full duplex. The second row is the first thing to wear: bent pins, corrosion, or damaged pads from repeated card swaps. Many cheap USB readers only wire the UHS-I row, so a card with a dead UHS-II row appears healthy to the reader but fails in a camera that negotiates UHS-II first. We inspect the second row under a stereo microscope, clean oxidation, and rebuild individual pads with UV-curable solder mask and a copper patch. If the LVDS transceiver inside the controller has failed, we move to chip-off.
How does recovery differ for Canon CR3, Sony ARW, and Nikon NEF files?
Each manufacturer uses a distinct container structure. Canon CR3 uses the ISO Base Media File Format (the same box-and-atom container family as MP4 and HEIF) with custom Canon boxes (CMT1, CMT2, CRAW) for metadata and RAW sensor data; we rebuild the container by parsing the static Canon metadata boxes and relinking the image data blocks. Sony ARW is a TIFF/EP variant. We detect the camera model during carving via EXIF MakerNote and apply manufacturer-specific container rebuild rules.
What is the difference between chip-off and spider-board recovery in turnaround time?
Chip-off applies to PCB cards: setup, preheat, and controlled reflow on an Atten 862 hot-air station lift the NAND cleanly. Translation layer reconstruction follows. Spider-board applies to monolithic cards: we expose internal test points by abrading the epoxy, then land a Spider Board adapter whose precision needles contact those points without solder for routine cases, or solder a custom fanout board when a card family has no working needle pinout. Working out the pinout on a card family with no known needle order is the slow part, which is why monolith work is more labor-intensive than chip-off.
My camera says the SD card 'needs to be formatted.' Should I let it?
No. The 'card needs to be formatted' or 'memory card error' prompt means the host device can power the card and reach the controller, but the file system metadata (FAT boot sector, FAT tables, root directory) is unreadable or fails a checksum. Your photos and video are almost always still present on the NAND. If you accept the format prompt, the camera writes a fresh FAT32 or exFAT structure over the existing metadata sectors. Pull the card, power it down, and send it for a free evaluation. We image the card and rebuild the file system from the intact data rather than overwriting it.
How do you keep a failing SD card from being written to during imaging?
The workflow is image-first: the card is imaged before anything else, and every later step runs against that image rather than the card. This matters because Windows and macOS both probe newly inserted media with metadata writes (System Volume Information, .Spotlight-V100, .Trashes, journal updates) the instant the card mounts, and a failing controller can answer a write attempt by erasing the wrong block. Your card is never handed to a desktop operating system to poke at. If the controller is too unstable to complete a clean read, we move to chip-off, where the NAND is read directly with PC-3000 Flash.
Is my SD card problem a software issue or a hardware failure?
It depends on whether the card still presents readable sectors. Recovery software (Recuva, PhotoRec, R-Studio, EaseUS, CleverFiles) only works when the card is physically healthy and the loss is logical: deleted files, a quick format, or a missing partition on a card that still mounts at full capacity. If the card reports 0 bytes or a fraction of its rated size, demands a format, fails to appear in the operating system, or detects intermittently and gets warm, that is a controller or NAND hardware failure. Software cannot reach the data because the path between the host and the memory is broken. In that case, stop powering the card and send it for a free evaluation, where we image the NAND directly with PC-3000 Flash.
Will reformatting a RAW SD card fix it?
No. When a card reads as RAW or prompts 'needs to be formatted,' the directory and file allocation tables that point to your files have become unreadable, not the files themselves. Accepting the format writes a fresh FAT32 or exFAT structure over those same metadata sectors. That overwrites the structures a technician would otherwise rebuild from and lowers the odds of a clean recovery. Leave the card unwritten, power it down, and send it in. We image the NAND and rebuild the filesystem from the intact data rather than overwriting it.
Can a bad card reader physically damage my SD card?
Yes. Poorly made readers can kill a card electrically, and damaged contact pins inside a reader can drag across the card's gold pads and scrape them down to the underlying FR-4 substrate, breaking the electrical contact even on a functional card. If a card was readable in one device but stopped responding after a session in a different reader, suspect the reader first.
Logistics
Shipping
Shipping
Mail-in
✓Use the box-in-box method: float a small box inside a larger box with 2 inches of bubble wrap.
✓Wrap the bare drive in an anti-static bag to prevent electrical damage.
✗Do not use packing peanuts. They compress during transit and allow heavy drives to strike the edge of the box.
MicroSD cards use monolithic architecture requiring specialized chip-off techniques via solderless spider-board adapters or manual micro-soldering. CompactFlash uses a 50-pin PATA interface common in industrial equipment. See our MicroSD recovery or CompactFlash recovery pages.
“All I can say is.. WOW. I spilled water on my laptop and couldn't find anywhere that would fix it, I kept thinking I would have to pay $1000+ for data recovery (always backup your files, kids) and thankfully I found Rossmann! I mailed it in right away!
They do water damage, no problem. Patrick was great and super helpful through the process and made everything smooth sailing. They also fixed my Mac within 48 hours and shipped it right back out to me. It was like all I did was shutdown the computer!”
“They are the best! My daughter spilled water on her keyboard. Apple store would charge $750 even though we still are in warranty saying they don't cover water damage. Rossmann group fixed it would Q-tips and didn't charge me anything! just told me "next time bring in something really broken". Will tell all my friends to go here for tech need!”
“These guys are awesome! Called a bunch of shops around San Antonio and they all said the whole motherboard would need to be replaced after I spilled water on mine and it would cost me around 1000$ to fix it, not only that, all my data would be lost (might as well buy a new laptop).”
