What Happens During a NAS Crash
A NAS (Network Attached Storage) crash can involve failure at multiple layers: individual drives, the RAID array, the filesystem, or the NAS controller board itself. Consumer and small-business NAS devices from Synology, QNAP, Buffalo, TerraMaster, and Asustor run Linux-based operating systems (DSM, QTS, TerraMaster OS), and they handle RAID in software with mdadm. When a NAS becomes inaccessible, the specific failure mode determines what data is recoverable and how.
What Are the Three Categories of NAS Failure?
| Failure Type | What Happened | NAS Behavior | Data Status |
| Single disk failure (with redundancy) | One drive died in a RAID 1/5/6/SHR array | Degraded mode; beeping; warning in management UI | All data accessible |
| Multi-disk failure or RAID collapse | Two+ drives failed (RAID 5/SHR-1), or any failure in RAID 0/JBOD | Volume inaccessible; NAS may boot but shows no storage pool | Data present on drives but array cannot be assembled |
| NAS controller/board failure | NAS hardware (CPU, RAM, flash module, power supply) failed | NAS does not power on, or boot loops | Drives are fine; data recoverable by assembling RAID externally |
How Does Filesystem Corruption Happen on Multi-Disk NAS Arrays?
Consumer NAS devices use ext4 or Btrfs on top of the RAID volume. Both filesystems use journaling (ext4) or copy-on-write (Btrfs) to maintain consistency during writes, but these protections have limits. Power loss during active writes can corrupt the filesystem if the NAS lacks a UPS and the drives lack reliable power-loss data protection.
The drives' own write cache may report writes as complete before they are physically committed to the platters, creating a window where data can be lost.
Synology SHR (Synology Hybrid RAID) and QNAP QTS both build their RAID on Linux mdadm. The RAID superblock metadata (drive order, chunk size, parity layout, array UUID) is stored on each member drive. If a drive gets disconnected and plugged back in after the array has changed, its superblock no longer matches the others. mdadm then either leaves the stale drive out or refuses to assemble the array.
What Is RAID Metadata and How Does It Get Damaged?
NAS RAID metadata is stored in the mdadm superblock on each member drive. It records the array UUID, drive positions, RAID level, chunk size, and event counter. Mismatched event counters cause mdadm to exclude drives it considers stale, even when those drives hold valid data and the array could otherwise assemble.
NAS RAID metadata is stored in the mdadm superblock (version 1.0, 1.1, or 1.2, depending on NAS vendor and firmware version). The version determines where the superblock sits on the member: v1.2 is written 4 KiB from the start of the device, v1.1 at the start, and v1.0 (like the legacy v0.90) near the end. This superblock records:
- Array UUID (unique identifier for the array)
- Member drive positions and UUIDs
- RAID level, chunk size, and layout algorithm
- Array state
- Event counter
- Bitmap location (for write-intent bitmaps)
mdadm uses the event counter to determine which drives have the most recent data. Mismatched counters can cause mdadm to exclude a drive it considers stale, even if that drive has valid data.
Some NAS firmware updates modify the RAID configuration or partition layout. If a firmware update is interrupted (power loss, network failure), the RAID metadata may be left in a transitional state that the NAS cannot resolve on its own.
What Happens When Both Halves of a Mirror Keep Writing?
A two-drive mirror is meant to hold the same blocks on both disks. If the halves lose track of each other & both keep taking writes, each disk ends up with its own version of the most recent work. People call that a split-brain mirror.
Which layer keeps track of it depends on who built the mirror. Synology DSM & QNAP QTS mirrors are mdadm arrays. TrueNAS & QuTS hero pools are OpenZFS. Btrfs can also mirror on its own, inside the filesystem.
- mdadm, in the array metadata
- The md(4) man page describes an optional write-intent bitmap that records which blocks of the array may be out of sync. The mdadm(8) man page says a re-added member may need only the bitmap-flagged sections recovered, or nothing at all, depending on its event count. The --force option assembles the array even when some members' metadata looks out of date.
- Btrfs RAID1, in the filesystem
- The Btrfs administration docs say that during a degraded mount, a new chunk that the remaining devices can't lay out in the current profile falls back to another profile such as SINGLE. The same docs tell you to check for chunks with unwanted profiles & balance them after a read-write degraded mount.
- ZFS mirror vdev, in the pool
- The zpool-scrub man page says a resilver examines only data ZFS knows to be out of date, such as after attaching or replacing a mirror device. A scrub examines all data.
Each of these scrubs checks something different & fixes something different.
| Layer | What the scrub checks | What a repair does |
| mdadm check or repair | Reads every block on every device & checks that the data is consistent | On RAID1, md takes one copy of the block & writes it over all the other copies. The mismatch count lands in md/mismatch_cnt. |
| Btrfs scrub | Data checksum errors, basic super block errors, basic metadata block header errors & disk read errors | On a replicated profile like RAID1, a read-write scrub fixes damage by copying verified good data from another replica. Scrub isn't a filesystem checker. On NOCOW files it still checks & fixes the metadata, but not the file data. |
| ZFS scrub | Each block's checksum, across all data in the pool | On a mirror, ZFS automatically repairs any damage the scrub finds. |
md compares the copies with each other. Btrfs & ZFS compare each block with its checksum. A checksum tells the scrub whether a block is damaged. It doesn't tell it which of two versions of your files you wanted to keep.
When md runs a repair on a RAID1 mirror & the two halves differ, it keeps one version & overwrites the other.
A mirror covers you for one dead drive. It won't settle an argument between two drives that disagree. If your halves were written separately, image both members before anything resyncs, re-adds, or repairs. We image every member at the Austin lab first. See RAID data recovery for what we charge for that work.
How Does the RAID Parity Rebuild Cascade Increase URE Probability?
Consumer SATA drives carry a worst-case specification of one unrecoverable read error per 10^14 bits read (roughly 12.5 TB), a warranty floor that raises the worst-case probability of a latent unreadable sector as array size grows.
If a URE does land, mdadm records the bad LBA in its Bad Block Log and continues; the more common cause of a failed rebuild is mechanical exhaustion of a marginal same-batch survivor under the sustained read load.
Consumer SATA drives are specified by their manufacturers at an unrecoverable read error (URE) rate of one sector per 10^14 bits read, which works out to roughly one URE per 12.5 TB of sequential reads. Enterprise SATA and nearline SAS drives are typically rated at 10^15 bits per URE.
If a read error does land during rebuild, mdadm records the unreadable LBA in its Bad Block Log and finishes the resync; only the data in those blocks is lost. A doubly-degraded collapse comes from a second drive actually dropping out, a marginal survivor failing mechanically under the sustained read or a non-TLER drive stalling past the controller timeout and being ejected, not from a single logged bad sector.
The cascade compounds with drive age. Drives purchased together from the same batch share manufacturing lot characteristics and wear together.
The practical consequence for IT administrators managing RAID arrays with irreplaceable data: when the data is irreplaceable and unbacked and the drives are degrading, image every surviving member read-only before any rebuild rather than rebuilding on degrading hardware.
Why Does a Healthy SMR Drive Get Ejected as Dead During a Rebuild?
An SMR drive gets ejected during a rebuild because its firmware stalls host I/O long enough for the Linux md layer to give up on it, not because anything mechanical broke.
A RAID rebuild throws heavy, sustained sequential writes at an SMR (Shingled Magnetic Recording) drive. The drive firmware then stalls host I/O while it performs background reshingling, and it does not answer new commands until the shuffle finishes.
The md (mdadm) layer reads the non-responsive drive as dead, ejects it from the array, and the NAS operating system degrades or crashes the volume in response.
This is a software-timeout false crash, not a head, platter, or other mechanical failure. The ejected SMR drive is physically healthy; it was simply too slow to answer while it reorganized its own tracks. The correct response is to power the unit down, image the ejected SMR drive through a hardware write-blocker with a PC-3000 before touching the array, and never force a rebuild onto a member that stalls under sustained writes. See why a RAID 5 rebuild aborts partway through and our RAID recovery workflow for the imaging-first path.
Why Does a Desktop Drive Get Dropped From a NAS Array Over One Bad Sector?
A desktop drive with no short error-recovery limit keeps retrying a marginal sector. On a plain kernel the host per-command timer expires at 30 seconds, so a long retry outlives it. The SCSI layer resets the device, marks it offline, and the md layer drops a physically healthy member out of the array.
The feature that caps that retry loop is Error Recovery Control, part of the ATA SCT (SMART Command Transport) command family and configured through the scterc parameter. Drive vendors ship the same ATA feature under three different trade names.
- Time Limited Error Recovery (TLER)
- Western Digital's trade name for the feature. RAID-labelled WD drives carry a short configured ceiling on how long the drive sits on a sector before it gives up and reports the error.
- Error Recovery Control (ERC)
- Seagate's trade name, and also the ATA standard name for the underlying feature. Because these are three labels for one ATA feature,
smartctladdresses all of them through the samesctercparameter. - Command Completion Time Limit (CCTL)
- Samsung and Hitachi call it this.
A drive that gives up fast is worth more to a redundant array than a drive that keeps trying. When the drive returns a read error promptly, that failed I/O travels up the stack, the RAID layer reconstructs the block from parity or a mirror copy, and the array keeps running. When the drive answers nothing at all, there is no error for the RAID layer to act on, only a command that never completes.
The other limit belongs to the host. The Linux SCSI layer puts a timer on every command.
When that timer runs out, the SCSI error handler schedules an abort of the command. Then it works up through a device reset, a target reset, a bus reset and a host reset. If the device's commands still haven't recovered after all that, it's taken offline. The md layer sees those failed commands and ejects the member.
The roughly 7-second figure quoted for RAID-labelled drives is the drive's own ceiling on its internal retry loop, held in drive firmware.
RAID and NAS-labelled drives carry the short ceiling so the drive reports the error, and lets redundancy supply the block instead of hanging the bus. Whether it is set short from the factory varies by model, so read it before you build the array rather than assuming it. On Linux the setting is read and written with smartctl, in deciseconds, which is why a 7.0-second limit is passed as 70.
smartctl -l scterc /dev/sdX # read the current limit
smartctl -l scterc,70,70 /dev/sdX # 7.0 s read and write limitA rebuild puts continuous read load on the surviving members, and a scheduled scrub does the same. If a second drive without a short limit meets its own marginal sector under that sustained read load, the same sequence runs again on that drive, and a second ejection turns a redundant array into a crashed one. Neither drive has failed.
This is a read-path stall rather than the write-path reshingling stall that ejects shingled drives. Which of the two stalls you are looking at follows from whether the member uses shingled or conventional recording.
Documented remedies run in both directions: shorten the drive-side limit with smartctl, or lengthen the host-side timer by writing a larger value into the sysfs timeout file. Neither is a repair you run on an array that has already crashed.
Once a volume is down, the open question is whether a member was ejected on a timeout or failed mechanically, and that answer comes from imaging the drives and reading their SMART data, not from pressing repair. We handle that as mail-in NAS extraction at the Austin lab, and the same imaging-first path covers multi-member array reconstruction. Diagnosis is free and there is no recovery fee if there is no data.
Can a Failed NVMe Cache SSD Crash the Whole Volume?
Yes. On a NAS pool accelerated by an M.2 NVMe write cache, losing that single SSD can crash the entire volume even when every mechanical HDD in the array is healthy. The NVMe device holds uncommitted (dirty) writes destined for the underlying HDD array, so its data is not a throwaway copy.
That covers Synology's prosumer DS920+, DS1520+ and DS1621+ when they run an M.2 NVMe read/write cache.
If the NVMe drops off the PCIe bus, those uncommitted writes are permanently lost. The underlying mechanical HDD array is left holding an incomplete, inconsistent Btrfs filesystem, and DSM (or the equivalent NAS operating system) immediately reports a Volume Crashed error.
The point to hold onto: the HDD array members are not mechanically failed. The cache namespace is stranded, and the filesystem on the healthy disks is inconsistent because the writes that would have completed it never arrived.
This is not the same failure class as a ZFS SLOG loss, and treating it as one leads to the wrong recovery decision. A SLOG is a separate log device. Lose it and you lose only the in-flight synchronous writes it held, and the ZFS pool still imports. A Synology-style NVMe write-cache dropout strands general dirty writes rather than a bounded synchronous log, and it leaves the copy-on-write filesystem inconsistent, which is a different and worse failure class. The NVMe here is a dirty write cache holding uncommitted blocks, not a Btrfs journal.
Lab extraction images the NVMe cache device and every HDD member first through a hardware write-blocker, then performs virtual array reconstruction with Data Extractor Express RAID Edition. The Btrfs filesystem is recovered read-only with btrfs-find-root and btrfs restore, never btrfs check --repair, because in-place repair overwrites the copy-on-write generation tree roots that recovery depends on. See Btrfs filesystem corruption recovery for the read-only extraction path.
How Does Filesystem Metadata Corruption Propagate?
On Btrfs, a corrupted chunk tree leaves the filesystem unmountable, and btrfs-restore has to pull the files out without mounting it.
ext4 writes metadata changes to its journal before it writes them to their final spot on disk. After a crash, the journal can be replayed up to its latest commit record.
ext4 doesn't checksum file data blocks, so silent corruption of file contents goes undetected. Its metadata_csum feature checksums the superblock, group descriptor blocks, inode and block bitmaps, directories & extent tree blocks. That covers the metadata, not the file data itself.
XFS is the usual data-volume filesystem on Buffalo TeraStation and LinkStation units, and its version of the journal is the XFS log. The Linux kernel replays the XFS log automatically on mount to bring the filesystem into a consistent state. xfs_repair is an offline utility that aborts if it detects a dirty log on an unmounted filesystem and instructs the operator to mount and cleanly unmount first.
If an XFS filesystem was created with metadata CRCs turned on, every metadata object carries a checksum. Corruption there gets caught instead of slipping by silently. An XFS log so damaged that neither the kernel nor a clean mount cycle can replay it leaves the filesystem in a state xfs_repair refuses to clear without -L, which destructively zeroes the log and risks data loss.
On Btrfs, the equivalent structures are the chunk tree, root tree, extent tree, and checksum tree. Btrfs writes new metadata to new locations (copy-on-write) and updates the superblock to point at the new tree roots atomically.
If every superblock copy points at a chunk tree that references a missing device ID, the filesystem won't mount, and btrfs-restore has to walk the raw metadata blocks to pull files out without mounting it.
Why Does Pulling the Drives and Plugging Them Into a PC Make It Worse?
Pulling NAS drives and connecting them to a PC destroys the RAID context the array depends on. Windows cannot read ext4, Btrfs, or XFS filesystems and may prompt to initialize the disk, overwriting RAID metadata.
When a NAS dies, a lot of people pull the drives and plug them into a PC. That causes two problems:
- Windows cannot read the filesystem. NAS volumes use ext4, Btrfs, or XFS. Windows does not natively mount these. Windows Disk Management may prompt to "initialize" the disk, which would overwrite the partition table and RAID metadata.
- Mixed-up drive order complicates manual reconstruction. Linux software RAID (mdadm) records each member's role in an on-disk superblock and UUID rather than deriving it from the physical bay, so an array normally reassembles even when the disks are returned to different slots. Labeling positions before removal is still worthwhile, because manual reconstruction and some layered NAS configurations depend on knowing the original order, and drives pulled from more than one array are easy to mix up.
Do not initialize, format, or resync when the NAS prompts you to.
When a NAS detects a problem with its storage pool, it may offer to "repair," "resync," or "reinitialize" the volume. Reinitialization creates a new empty RAID array, overwriting the existing metadata and making recovery far more difficult. If the data matters, power off the NAS and consult a recovery service before accepting any repair prompts from the NAS management interface.
What Happens When the NAS Controller Board Fails?
Synology DSM and QNAP QTS units use mdadm software RAID, so the RAID metadata lives on the data drives, not on the controller. Any Linux system running mdadm can assemble those drives, given the correct parameters.
Recovery from a NAS controller failure involves:
- Removing all drives and labeling their slot positions
- Imaging each drive individually using a hardware imager or ddrescue
- Scanning images for mdadm superblocks to determine array parameters
- Assembling the RAID array from images (not original drives)
- Mounting the filesystem read-only and copying data
What Are the Btrfs-Specific Failure Modes on NAS Devices?
Btrfs RAID 5/6 has a documented write hole: power loss during a write spanning a parity stripe leaves parity inconsistent with data. Corruption of the chunk tree makes the filesystem unmountable, requiring btrfs-restore to parse raw metadata blocks to extract files.
Btrfs provides checksumming and copy-on-write at the filesystem level (similar to ZFS). Btrfs RAID 5/6 has a known "write hole" issue that the Btrfs developers have documented: if power is lost during a write that spans a parity stripe, the parity may become inconsistent with the data.
Synology runs mdadm for the RAID layer underneath Btrfs. On an SHR volume that means mdadm RAID with a Btrfs filesystem on top. QNAP avoids Btrfs entirely: QTS layers ext4 over LVM2 and mdadm, while QuTS hero uses ZFS native RAID.
Btrfs maintains extensive internal metadata: the chunk tree, extent tree, device tree, and checksum tree. Corruption of the chunk tree (which maps logical addresses to physical device locations) can make the entire filesystem unmountable. Recovery from chunk tree corruption requires parsing raw Btrfs structures on the disk images to reconstruct the mapping.
What Happens to a ZFS Pool During a Crash?
ZFS is copy-on-write and commits pool state atomically in transaction groups, so an unexpected shutdown leaves the in-flight transaction group incomplete while every previously committed block stays intact. Import selects the last valid uberblock rather than repairing in place, which is why the ext4 or Btrfs fsck mental model does not apply. TrueNAS and QNAP QuTS hero both run this OpenZFS stack, so a crashed ZFS pool behaves nothing like a crashed mdadm array.
- Uberblock
- The root pointer of the ZFS metadata tree. It records the transaction group number, a timestamp, the Meta Object Set root, and a checksum. Each vdev label holds a rotating ring of uberblocks, so ZFS can fall back to an earlier consistent state when the most recent block fails validation.
- Transaction group (TXG)
- A batch of data and metadata writes held in memory and flushed to disk atomically. The pool advances only when a TXG commits, so an interrupted commit is discarded rather than half-applied.
- ZFS Intent Log (ZIL) and Separate Log (SLOG)
- The ZIL records synchronous writes so they survive a crash before the next TXG commit. An optional SLOG device holds that log on faster media. A dead SLOG doesn't destroy the pool. You lose only the in-flight synchronous writes the log held.
- Deduplication Table (DDT)
- The inline hash table ZFS uses to track duplicate blocks. It is stored on disk and read on demand; holding it in ARC takes roughly 1 to 5 GB of RAM for every 1 TB of deduplicated data.
TXG atomicity and the uberblock ring
ZFS batches writes into transaction groups and flushes them to disk on a timed interval, or sooner when the write buffer fills. A committed TXG writes a new uberblock into the next slot in the ring, cycling back to overwrite the oldest, and stamps it with its own checksum. When a crash interrupts a commit, the newest uberblock fails its checksum and ZFS falls back to the last valid one. This is a rollback to the last consistent state, not an overwrite of live data. There is no fsck pass that rewrites metadata in place, so a normal import reads and validates rather than repairs.
A missing SLOG does not kill the pool
The claim that a dead SLOG means a dead pool is false. Synchronous writes are logged to the ZIL, optionally on a Separate Log device, and only the writes still in flight at the moment of the crash live there. Everything already committed sits on the main vdevs. When the SLOG is missing or dead, zpool import -m brings the pool online, and the only thing you lose is those in-flight synchronous writes.
What happens to a deduplicated pool on an under-provisioned host?
If deduplication was enabled, holding the Deduplication Table in ARC takes roughly 1 to 5 GB of RAM for every 1 TB of deduplicated data. Move a heavily deduplicated pool to a recovery machine that does not have that memory and the pool still imports, but the table is then read from disk on demand, which iXsystems documents can take days after an import or reboot. Because the DDT is not needed to read existing data, the extraction runs strictly read-only.
Boot device versus data pool
TrueNAS runs its operating system from a separate boot device, apart from the drives in the data pool. The pool topology lives in the vdev labels on the data drives. So a corrupted or dead boot device takes out the boot environment and leaves the data pool alone. Install a fresh OS and the pool re-imports.
Cross-host and controller independence
ZFS identifies disks by GUID in the vdev labels, not by port or controller, so a QuTS hero or TrueNAS pool re-imports on different hardware in any drive order. If you're dealing with hardware RAID instead, read ZFS versus hardware RAID.
Lab recovery is image-first. Every member drive is cloned through a hardware write-blocker with ddrescue or a PC-3000 before anything touches the pool, then the clones are imported read-only for forensic extraction. See ZFS pool recovery for the full workflow.
zpool import -N -o readonly=on <pool-name>
zpool import -m -N -o readonly=on <pool-name> # missing/dead SLOGThe -N flag skips mounting the datasets, and -o readonly=on imports the pool read-only. Two commands throw away recent transactions: the bounded rewind zpool import -F and the targeted zpool import -T <txg>. That makes both destructive, so we only ever run them against cloned images, never the original drives.
Should I pull the drives from my NAS and connect them to a PC?
No. NAS drives use Linux filesystems (ext4, Btrfs) and software RAID. Windows cannot read them and may prompt to initialize the disk, overwriting metadata. If you must remove drives, label their slot positions and do not connect them to a system that might auto-mount or modify them.
Why does a RAID 5 rebuild often fail partway through after a single disk is replaced?
Manufacturer datasheets for consumer SATA drives give a worst-case unrecoverable read error spec of one sector per 10^14 bits read, about 12.5 TB. That's a warranty floor, not a schedule. A 4x 8 TB RAID 5 rebuild reads roughly 24 TB from the surviving three members, which raises the worst-case probability of a latent unreadable sector. If a URE does land, mdadm records the bad LBA in its Bad Block Log and continues; the more common cause of a failed rebuild is a marginal same-batch survivor failing mechanically under the sustained read load. Enterprise drives at 10^15 bits per URE widen the margin but do not remove the mechanical risk.
What is the difference between ext4 journal corruption and Btrfs chunk tree corruption?
ext4 is a journaled filesystem. It writes metadata to the journal first, then writes it out to its final location later. Btrfs is copy-on-write and maintains independent chunk, root, extent, and checksum trees. The chunk tree maps logical addresses to physical device offsets. If all on-disk copies are corrupted or reference missing device IDs, the filesystem becomes unmountable and btrfs-restore must parse raw metadata blocks to extract files.
If my NAS shows a degraded array, should I start a rebuild immediately or image the drives first?
If the array holds data you can't replace, image every surviving member drive before you let the NAS rebuild. A rebuild reads every surviving drive end to end, all at the same time. A drive that's been quietly piling up reallocated sectors can fail under that load. If a second drive fails during rebuild on RAID 5 or SHR-1, the array collapses and recovery from drives partially overwritten by the rebuild is harder than recovery from clean pre-rebuild images. Power off the NAS, image each drive with a hardware imager or ddrescue, and assemble the RAID from images rather than originals.
My NAS won't boot after a power cut, or it lost its cache SSD. Is the ZFS pool gone?
Usually not. A ZFS pool stores its topology in the vdev labels on the data drives, so a dead boot device only kills the operating system. The pool re-imports on a fresh install. A lost or failed SLOG doesn't destroy the pool either. zpool import -m brings it online, and you lose only the in-flight synchronous writes the log held. The real danger is a live rebuild or resilver, or an in-place rewind on failing original drives, so image every member first and import the clones read-only.
If you are experiencing this issue, learn about our NAS recovery service.
