What TRIM Does and Why Deleted SSD Data Disappears
Published March 8, 2026
Updated March 8, 2026
TRIM is an ATA command (DATA SET MANAGEMENT) that the operating system sends to an SSD controller to identify logical block addresses that are no longer in use. When you delete a file, the OS marks those blocks as free in its filesystem table and sends a TRIM command to the SSD. The controller unmaps those addresses. If the drive advertises RZAT, reading them returns zeros.
What TRIM Tells the Controller to Do
On a hard drive, deleting a file only removes the directory entry that points to the file's data. The actual data remains on the platters until another file overwrites those sectors. This is why hard drive data recovery software can scan for deleted files and often find them intact.
SSDs work differently because of how NAND flash writes. NAND can be written at the page level (typically 4-16 KB) but can only be erased at the block level (typically 256-512 pages per block).
TRIM reduces write amplification by informing the controller which pages contain deleted data. The controller can then skip those pages during block consolidation, and the garbage collector can erase blocks that contain only invalidated pages without needing to copy any valid data out first.
Canonical TRIM Terminology
Data recovery work on flash storage runs into the same acronyms across SATA, NVMe, and SCSI stacks.
ATA DATA SET MANAGEMENT (DSM), opcode 0x06
The SATA command that carries TRIM. The DSM feature field selects the sub-function; bit 0 enables the TRIM sub-function, which delivers a list of LBA ranges the host no longer uses. The controller is free to queue the work, reorder it, or ignore it.
NVMe DEALLOCATE (Dataset Management, opcode 0x09)
The NVMe equivalent of ATA DSM TRIM. The Dataset Management command with the Deallocate (AD) bit set tells the controller that the listed LBA ranges can be released. Read behavior after deallocate is governed by the DLFEAT field in IDENTIFY NAMESPACE.
SCSI UNMAP (opcode 0x42)
The SCSI command used for the same purpose on SAS drives and on USB Attached SCSI (UAS) enclosures. When a USB-to-NVMe bridge chip claims to pass TRIM, what it is actually doing is translating UNMAP into NVMe DEALLOCATE on the back side of the bridge.
DRAT (Deterministic Read After Trim)
Reported in IDENTIFY DEVICE Word 69 bit 14. Guarantees that every read of a TRIMmed LBA returns the same value, but that value can be any constant, including stale data the controller chose to pin. Useful to recovery tools only when combined with knowledge of what value the firmware returns.
RZAT (Deterministic Read Zero after TRIM)
Reported in IDENTIFY DEVICE Word 69 bit 5. Guarantees that reads of TRIMmed LBAs return all zeroes.
Queued TRIM (SATA FPDMA Queued)
An optional extension that lets TRIM commands ride inside the Native Command Queuing (NCQ) pipeline instead of draining the queue first. Several early SATA SSDs implemented this incorrectly at the firmware level, and the Linux kernel maintains a blacklist that disables queued TRIM on known-bad drives.
Overprovisioning (OP)
Raw NAND capacity the controller reserves and never exposes as user LBAs. Works alongside TRIM: the larger the OP pool, the more free erase blocks the garbage collector can consume without having to relocate valid data.
Garbage Collection: Deterministic vs Non-Deterministic
Garbage collection is the controller's background process of reclaiming blocks that contain a mix of valid and invalid (TRIMmed or overwritten) pages. The controller reads valid pages from partially used blocks, writes them to a new block, and erases the old block to make it available for new writes.
How the controller handles reads of TRIMmed blocks before garbage collection completes determines whether the TRIM implementation is deterministic or non-deterministic:
TRIM TypeRead After TRIMRecovery Window
Deterministic Read After TRIM (DRAT)Returns the same value every time a TRIMmed LBA is read (may be zeroes or stale data, but consistent)Minimal. Data returned is deterministic but may not reflect actual NAND contents.
Deterministic Read Zero after TRIM (RZAT)Returns all zeroesNone for recovery software. Zeroes returned deterministically for all TRIMmed ranges.
Non-deterministic TRIMMay return old data or zeroes, unpredictablyTheoretical window exists, but unreliable.
Most modern consumer SSDs implement deterministic TRIM. On a drive that advertises RZAT, once the OS sends the TRIM command, recovery software reading those LBAs will get zeroes, regardless of whether the physical NAND erase has completed yet.
Why Erased NAND Blocks Are Unrecoverable
When garbage collection erases a NAND block, it applies an erase voltage that pulls all trapped electrons out of the floating gates (or charge trap layers) in every cell in the block. Every cell returns to its erased state: all 1s in binary.
This differs from hard drive deletion in a critical way. On an HDD, deleted data remains as magnetic polarity patterns until overwritten. On an SSD, TRIM-triggered garbage collection physically resets the cells. Chip-off NAND extraction (desoldering the NAND chips and reading them directly) will show erased blocks where the data used to be.
TRIM is why SSD data recovery differs from HDD recovery.
Recovery software cannot find data that has been physically erased from the NAND cells. This is the single most important fact that distinguishes SSD recovery from hard drive recovery.
TRIM Behavior Across Operating Systems
OSTRIM Enabled by DefaultNotes
Windows 7+Yes (NTFS)TRIM sent on delete.
macOSYes (Apple SSDs)TRIM for third-party SSDs requires manual enablement via trimforce command.
Linux (ext4, Btrfs, XFS)Depends on mount optionsContinuous TRIM via "discard" mount option or periodic batch TRIM via fstrim.
Why Hardware RAID Controllers Disable TRIM
Enterprise hardware RAID controllers in RAID mode typically refuse to forward TRIM commands to member SSDs. The reason is parity integrity. If a drive advertising RZAT receives a TRIM command and zeroes the referenced LBAs, the parity block the controller already computed across the stripe no longer matches the data blocks on disk. Subsequent reads will pass, but any rebuild or consistency check reads the zeroed blocks and either flags parity errors or overwrites valid data with parity-reconstructed zeroes.
The controller flashed to IT mode (HBA passthrough) does forward TRIM, because in that mode the host owns the array layout (usually ZFS, mdadm, or Storage Spaces) and the firmware is not computing parity. Software RAID stacks that are TRIM-aware (Linux mdraid with RAID 1/10, ZFS, Btrfs RAID 1) propagate TRIM to the underlying devices once the array geometry and block offsets are understood.
This pattern is relevant during RAID recovery: a hardware-RAID SSD array presented to a recovery workstation usually still contains every user LBA on the NAND because the controller never issued TRIM. You have to reconstruct the controller's own metadata (DDF) first, but the underlying data hasn't been erased.
Samsung 860 and 870 EVO Queued TRIM Firmware Bug
The Samsung 860 EVO and 870 EVO SATA SSDs shipped with queued TRIM (FPDMA Queued) firmware that interacts badly with several AMD and Intel SATA controllers. The visible symptom in the Linux kernel log is a cascade of WRITE FPDMA QUEUED and SEND FPDMA QUEUED timeouts, followed by the drive being reset and remounted read-only. Left alone, this corrupts filesystems.
The kernel maintains a blacklist in libata-core.c that disables queued TRIM on Samsung 8xx-series SSDs. Administrators who hit the issue on older kernels can force the behavior with the boot parameter libata.force=noncqtrim, which allows NCQ for reads and writes while serializing TRIM.
Can deleted files be recovered from an SSD with TRIM enabled?
In almost all cases, no. When a file is deleted, the OS sends a TRIM command identifying the freed blocks. The controller unmaps them. If the drive advertises RZAT, reading those addresses returns zeros. Then garbage collection physically erases the NAND cells. Unlike HDDs where deleting only removes the directory entry, TRIM puts the data out of reach at once and garbage collection destroys it afterward.
Does TRIM happen instantly?
Not always. Deterministic Read After TRIM (DRAT) guarantees the same value on every read of a TRIMmed LBA, but that value is not necessarily zeroes. RZAT guarantees zeroes. Non-deterministic TRIM may return different values on each read. Most modern SSDs apply the unmap immediately and start returning the deterministic value at once; the physical erase is what gets deferred to garbage collection.
Does TRIM compromise full-disk encryption security?
TRIM can leak metadata about which blocks are free and which hold encrypted data, which weakens plausible deniability on hidden volumes. VeraCrypt blocks TRIM by default on non-system volumes on Windows for this reason. Linux LUKS doesn't pass TRIM through unless the administrator adds the discard option to /etc/crypttab. By default, an encrypted LUKS container doesn't emit TRIM. BitLocker and FileVault both pass TRIM through to the SSD.
What is the difference between TRIM, ATA Secure Erase, and NVMe Sanitize?
TRIM only deallocates LBAs in the flash translation layer and lets background garbage collection eventually erase the NAND. ATA Secure Erase (SECURITY ERASE UNIT) resets the mapping table and typically issues a block-erase across the NAND, but its exact behavior varies per firmware. NVMe Format with Crypto Erase destroys the media encryption key so every block decrypts to garbage instantly, without touching the NAND itself. NVMe Sanitize (Block Erase, Overwrite, or Crypto Erase modes) is a controller-enforced, blocking operation that the drive advertises as complete only after every physical block has been handled.
Why do hardware RAID controllers disable TRIM on SSD arrays?
Enterprise hardware RAID controllers running in RAID/IR mode generally refuse to forward TRIM to member drives. If a deterministic zero-after-TRIM drive were to zero a block on a RAID 5 or RAID 6 member, the stored parity would no longer match the data stripes and would be corrupt for any subsequent recovery or rebuild. The controller in IT mode (HBA passthrough) does forward TRIM, because the host owns the array semantics and the firmware is not tracking parity.
If you are experiencing this issue, learn about our SSD recovery service.
