You Do Not Need a Cleanroom for Data Recovery
A cleanroom is an entire room built to maintain a specific particle count per cubic meter. What hard drive recovery actually requires is particle control at the point where the drive is open and platters are exposed. A ULPA-filtered laminar flow bench achieves this at 2-5% of the cost.
Updated August 28, 2026
The claim
What the Cleanroom Marketing Claims
“Data recovery must be performed in an ISO Class 5 certified cleanroom to prevent contamination.” This is the centerpiece of marketing for large data recovery operations. Their websites feature photos of technicians in bunny suits, airlocks, and white-walled cleanroom chambers.
ISO cleanroom specs
ULPA Clean Bench vs. Full Cleanroom
An ISO Class 5 (formerly Class 100) cleanroom allows no more than 3,520 particles of 0.5 microns or larger per cubic meter. A ULPA-filtered laminar flow bench puts its filtered air at the work surface where the drive is open.
FactorISO Class 5 CleanroomULPA Clean Bench
Build costDedicated room construction, HVAC, and certificationSingle bench-top unit
Annual maintenanceHVAC, gowning supplies, recertificationFilter replacement
Area filteredEntire room (floor, ceiling, walls)Work surface where drive is open
Head swap pricing impactFacility overhead built into every quote$1,200–$1,500
Filtration thresholds per ISO 14644-1 and ULPA filter specifications.
Clean bench physics
Most Data Recovery Work Does Not Require Opening the Drive
Firmware repairs, logical recovery, PCB diagnosis, and many electronics-level fixes are performed with the drive sealed. A cleanroom adds zero value to these cases, but cleanroom-equipped labs apply the same overhead to all invoices.
Why the myth persists
Why This Myth Persists
A cleanroom photographs well. It signals institutional seriousness. For a panicking customer comparing labs, “ISO Class 5 Certified Cleanroom” sounds more trustworthy than “laminar flow bench in a normal room,” even though the bench provides equal or better filtration where it matters.
Certification Theater
Cleanroom certification (ISO 14644-1) is a legitimate standard. But the marketing implies it certifies recovery competence when it only certifies air quality. A company can have a certified cleanroom and no PC-3000. Certification does not indicate whether the technicians know how to rebuild firmware, swap heads, or read a failed ROM chip. The certification measures how clean the room is, not how good the lab is.
Overhead Justification
Once a lab has paid for a walk-in cleanroom build, every invoice needs to recoup that investment. The cleanroom becomes the justification for premium pricing, not the technical skill of the technician doing the work. Labs with unpublished head-swap pricing point to their cleanroom as the reason. Labs that charge $1,200–$1,500 for the same procedure using a ULPA bench cannot match the marketing, but they can match the results.
SSD Misapplication
SSDs have no platters, no heads, and no exposed magnetic surfaces. They are sealed silicon packages. Opening an SSD case does not expose anything that contamination could damage. A cleanroom is irrelevant to SSD recovery. Yet cleanroom-equipped labs apply the same cleanroom overhead to SSD cases.
When filtration matters
What Head Swaps Actually Require
Hard drive head swaps require particle control because the head keeps a baseline aerodynamic clearance of a few nanometers above the platter surface. A particle larger than the flight height causes a head crash. This is a real engineering constraint that demands filtration.
A ULPA-filtered laminar flow bench creates a curtain of filtered air flowing across the work surface. Any particle generated during the procedure (from tools, gloves, or the drive itself) gets swept away from the platter surface and out the front of the bench.
The cleanroom approach filters the entire room, including the floor, ceiling, walls, and the empty space above the technician's head. This is necessary in semiconductor manufacturing, where wafers are exposed for hours across an entire production line. In data recovery, the drive is open for 15-30 minutes on a 2-foot by 3-foot work surface. Filtering the entire room to protect a 3-inch platter is engineering overkill that serves the marketing budget, not the recovery outcome.
Our setup
Our Approach to Contamination Control
We use a ULPA-filtered clean bench. The bench costs a fraction of a cleanroom, and that savings goes directly to lower pricing.
  • Head swaps: $1,200–$1,500, published before you ship
  • SSD recoveries: from $200 with zero cleanroom surcharge, because SSDs do not need particle control. SSD recovery details.
  • No diagnostic fee. No data, no recovery fee. See our HDD pricing.
Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. +$100 rush fee to move to the front of the queue.
Is a cleanroom required for hard drive data recovery?
No. What data recovery requires is particle control at the point where the drive is open and platters are exposed. A ULPA-filtered laminar flow bench pushes clean air through a ULPA filter. Air Science rates the ULPA filter in our Purair VLF-48 at 99.999% efficiency for particles between 0.1 and 0.3 micron. A cleanroom filters the entire room, including empty space above the technician's head, which adds cost without improving the outcome.
How much does a cleanroom cost to build and maintain?
A walk-in ISO Class 5 cleanroom is a major capital build with ongoing costs for HVAC, filter replacement, gowning supplies, and periodic recertification. That overhead gets built into every invoice, including jobs where the drive was never opened. A ULPA-filtered clean bench is a single piece of equipment with routine filter maintenance, a fraction of the facility cost.
Do SSDs need a cleanroom for recovery?
No. SSDs have no platters, no heads, and no exposed magnetic surfaces. They are sealed silicon packages. Opening an SSD case does not expose anything that contamination could damage. A cleanroom is irrelevant to SSD recovery, yet cleanroom-equipped labs apply the same overhead to SSD cases.
What does ISO cleanroom certification actually certify?
ISO 14644-1 certifies air quality: the maximum allowable particle count per cubic meter of air at various particle sizes. An ISO Class 5 room allows no more than 3,520 particles of 0.5 microns or larger per cubic meter. The certification measures how clean the room is, not how competent the technicians are. A company can have a certified cleanroom and no PC-3000.
What is a ULPA-filtered clean bench?
A ULPA (Ultra Low Penetration Air) filtered laminar flow bench is a workstation that pushes filtered air across the work surface. Air Science rates the ULPA filter in our Purair VLF-48 at 99.999% efficiency for particles between 0.1 and 0.3 micron. Any particle generated during a head swap procedure is swept away from the platter surface and out the front of the bench.
Same Filtration. Lower Price.
Call (512) 212-9111 or ship your drive to our Austin lab. No diagnostic fee. No data, no recovery fee.
