How Donor Drives Are Matched for Head Swaps
Published March 8, 2026
Updated August 27, 2026
A head swap requires transplanting the entire Head Stack Assembly (HSA) from a compatible donor drive into the patient drive (the drive with failed heads). The donor heads must be mechanically compatible with the patient's platters and electronically compatible with the patient's firmware and preamp circuitry. Matching by model number alone is not sufficient. Hard drive manufacturers produce the same model number across multiple hardware revisions, with different head components, preamp chips, and firmware variations within a single model line. Donor matching is a prerequisite for head-swap cases in our hard drive data recovery workflow.
What Is Matched Between the Donor and the Patient Drive?
Donor selection at the PC-3000 bench turns on preamp gain matching, channel coefficients, microjog offsets, HSA family and firmware revision compatibility, and HGA generation for multi-platter helium drives.
1. Preamp gain matching
The preamp on the HSA flex cable amplifies head signals at a calibrated gain stage. When donor and patient preamp revisions differ, the read-back signal arrives at the controller channel at the wrong amplitude.
2. Channel coefficients (FIR equalizer and gain)
The equalizer tap coefficients and their associated gain and target settings are head-specific adaptive values stored in the System Area. The Viterbi detector downstream reads whatever the equalizer hands it; it holds no per-head calibration of its own. The patient's coefficients were trained against the patient's heads; loading them against donor heads produces equalization residuals that the Viterbi detector mis-decodes as bit errors. PC-3000 reads the donor's channel coefficients from the donor SA before the swap and writes them into the patient firmware as part of adaptive transfer, so the equalizer is targeted at the heads that will actually be installed.
3. Microjog offsets
Per-head radial position deltas stored in adaptive tables. Detailed mechanics are documented in the SA Adaptives and Microjog Calibration section below.
4. HSA family and firmware revision compatibility
A donor labeled with the same model number routinely fails because the HSA family or firmware sub-revision differs. WD Marvell drives split on the DCM J or 2 anchor character and the character preceding it, which encode the head stack supplier and preamp. Firmware revision is matched as a precondition, but firmware-revision match alone is not sufficient when the HSA family within the revision has changed. This is why same-model donors fail more often than the model number alone suggests.
5. HGA generation on multi-platter helium drives
The donor window tightens from months to weeks. Helium head swap pricing uses $3,000–$4,500 per the helium HDD pricing tiers.
How Does the Donor Selection Decision Cascade Work?
The decision cascade runs five phases: patient label analytics, candidate donor lookup, external label cross-check, ROM dump and shadow module verification, and internal preamp and adaptive verification. Each phase eliminates donors that fail earlier checks before any clean-bench work begins.
  1. Phase A. Patient Label Analytics. Transcribe the metadata that determines candidate filtering. For Western Digital units, record the MDL string (16-digit or 17-digit format) and the Drive Configuration Matrix (DCM), which encodes head stack vendor and preamp tuning in specific character positions. For Seagate units, record Model Number, Part Number prefix, Site Code (WU, SU, TK), and Date Code. Seagate Date Codes use a proprietary fiscal-year format and must be converted to a standard calendar date before the 12-week donor window can be evaluated.
  2. Phase B. Candidate Donor Lookup. Candidate donors are filtered against the patient identifying fields recorded in Phase A before they are physically acquired.
  3. Phase C. External Label Cross-Check. When a candidate donor arrives, the WD model string is re-verified against the patient. DCM alignment uses the J or 2 anchor character near the end of the DCM string. The anchor and the single character immediately preceding it encode the HSA supplier and preamp tuning, and must match exactly between patient and donor.
  4. Phase D. ROM Dump and Shadow Module Verification. Before the donor seal is broken, PC-3000 reads the donor ROM through vendor-specific commands. The Service Area shadow copies are read in a separate step: WD Marvell drives have an LDR loader uploaded to controller RAM, which permits reading Module 102 and Module 103, the platter-resident shadows of the ROM head map and the SA adaptives. Seagate F3 drives are accessed via the serial diagnostic COM port. The SPI flash ROM is first extracted in Boot Code mode. PC-3000 then generates a Technological Mode unlock patch from that image, which is loaded into RAM to bypass the Diagnostic Port Lock for subsequent terminal access.
  5. Phase E. Internal Preamp and Adaptive Verification. If the ROM dump confirms compatibility, the donor is staged for internal inspection.
What Disqualifies a Donor Before the Clean Bench?
Four conditions remove a donor from consideration before any HSA extraction: mismatched physical head count or geometry, visible platter damage or crash-rings, a Date of Manufacture beyond the 12-week window, and DCM anchor character deviation on WD drives. Each is observable from the label, the ROM dump, or a platter inspection.
Donor drives cost from hundreds to thousands of dollars, and a misjudged candidate destroys both the donor heads and the patient platters on first spin-up. The following conditions remove a donor from consideration before any HSA extraction begins. Each is observable from the label, the ROM dump, or a microscopic platter inspection performed with the patient cover off but the donor still sealed.
Mismatched physical head count or geometry
A donor with fewer heads, or with an active head map that does not align geometrically with the patient chassis, is rejected.
Visible platter damage and crash-rings
Before HSA extraction, the patient platters are inspected under the ULPA clean bench. A concentric crash-ring scored through the CoCrPt magnetic coating means the failed head has lifted particulate matter into the HDA. Installing a pristine donor HSA into a contaminated HDA destroys the donor heads on the first spindle rotation. Recovery on a crash-ring patient requires platter burnishing and media cleaning under the bench before the donor HSA is committed.
The industry baseline is a 12-week DOM window between patient and donor.
DCM anchor character deviation (WD)
The Western Digital DCM is not arbitrary. The J or 2 anchor character near the end of the DCM string, and the single character immediately preceding it, encode the HSA vendor and preamp tuning configuration. A donor whose anchor pair does not match the patient anchor pair is disqualified, even when the model number, firmware revision, and Date of Manufacture all match.
How Is the Head Map Verified on the PC-3000?
The logical head map tells the controller which physical read/write elements to route I/O through. PC-3000 reads Module 0A on WD Marvell drives to confirm the donor head map matches the patient. A donor must support the patient configuration exactly or a superset of it before the swap is committed.
The logical head map tells the controller which physical read/write elements to route I/O through. Verifying the donor head map against the patient head map before committing the swap, and selectively disabling weak heads on the donor after the swap, are both performed through the PC-3000 utility against specific firmware modules. Procedural context for the swap itself is documented in what a head swap involves.
Verification sequence
  1. Navigate Tools, Utility extensions, Modules directory to inspect Service Area integrity.
  2. Read Module 0A as the head map of physical head positions active in the patient configuration.
  3. Compare the patient head map against the donor ROM head map extracted in Phase D. The donor must support the patient configuration exactly, or a superset of it.
Selective head disablement after the swap
If a transplanted donor HSA presents one marginal head, PC-3000 can logically retire that element from the active translation pool. On Seagate F3 the path is Zones and Heads Inactivation through the P-List menu.
Why Does Firmware Revision Matching Matter?
The firmware revision is the primary matching criterion because the firmware controls how the drive communicates with the heads: signal timing, read channel calibration, servo decoding parameters, and write current profiles. Heads from a donor with a different firmware revision may not work because the patient firmware expects specific electrical characteristics the donor heads do not provide.
The drive's firmware revision is the primary matching criterion. The firmware controls how the drive communicates with the heads: signal timing, read channel calibration, servo decoding parameters, and write current profiles. Heads from a donor with a different firmware revision may not work because the patient drive's firmware expects specific electrical characteristics from the heads that the donor heads do not provide.
Firmware revisions are printed on the drive label. For Seagate drives, this is a four-character code (e.g., CC26, SDM1, 0001). For Western Digital, the firmware revision is part of the extended model number. The firmware revision indicates the generation of controller code and, by extension, the generation of head technology the firmware is calibrated for.
Within a firmware revision, there can be sub-revisions that affect compatibility. Two Grenada drives with firmware "CC26" manufactured six months apart may have different micro-code patches. In most cases, same firmware revision is sufficient. In some Seagate Rosewood drives, even drives with the same firmware revision but from different manufacturing sites (identifiable by the Site Code on the label) have different head compatibility.
How Does the Head Map Affect Donor Compatibility?
A drive's head map specifies which heads are installed and active. A 3-head donor HSA cannot be used in a 4-head patient drive, because the donor carries no head for the fourth surface.
A drive's head map specifies which heads are installed and active. The head map is stored in the drive's firmware and defines which physical head positions are active and how the firmware addresses them. A 3-head donor HSA cannot be used in a 4-head patient drive, because the donor carries no head for the fourth surface.
Matching CriterionWhere to Find ItWhy It Matters
Firmware revisionDrive label, IDENTIFY DEVICE responseFirmware calibrates read channel and write current for specific head characteristics
Head count / head mapFirmware SA modules, capacity variantHSA must have the same active head positions
Preamp chip modelVisible on HSA flex cable PCBSignal path between heads and controller must be electrically compatible
Platter countDrive label (capacity + model), physical inspectionHSA arm count must match platter count
Why Must the Preamp Chip Match?
The preamp is a small IC mounted on the HSA flex cable inside the sealed drive cavity. It amplifies microvolt signals from the read heads and drives write current to the write heads. The preamp model must match because the controller's read channel is calibrated for the specific signal characteristics of that preamp, and gain mismatches produce uncorrectable read errors.
The preamp is a small IC mounted on the HSA flex cable, inside the sealed drive cavity. It amplifies the microvolt signals from the read heads and drives the write current to the write heads. The preamp model must match between donor and patient because the controller's read channel is calibrated for the specific signal characteristics of that preamp.
Preamp models can be identified by the marking on the chip, visible when the drive is opened. Common preamp manufacturers include Texas Instruments, STMicroelectronics, Broadcom (Avago), and Renesas.
What Happens to Adaptive Parameters After a Head Swap?
Every hard drive generates a unique set of adaptive parameters during factory self-scan, recording calibration data for the drive's individual heads. After a head swap, the patient drive's adaptive parameters no longer match the installed donor heads. PC-3000 can load the donor drive's adaptive parameters into the patient firmware to restore read stability.
Every hard drive generates a unique set of adaptive parameters during factory self-scan. These parameters record the specific calibration data for the drive's individual heads: optimal read channel settings, write current values, fly height compensation, and servo tracking offsets.
After a head swap, the patient drive's adaptive parameters no longer match the installed heads. The parameters were calibrated for the original heads, not the donor heads. In some cases, the drive can still read with minor degradation. In other cases, the mismatch prevents the drive from reading its own System Area, causing it to fail initialization.
PC-3000 can modify adaptive parameters after a head swap. The technician can load the donor drive's adaptive parameters into the patient drive's firmware, aligning the calibration with the installed heads. This is not always necessary (some drive families tolerate mismatched adaptives well enough for imaging), but it improves read stability and reduces errors on drives where the mismatch causes issues.
Why Do Manufacturing Date and Factory Site Affect Donor Matching?
The closer the donor is to the patient in manufacturing date and production site, the higher the compatibility probability. Two drives with matching model and firmware but different DCM codes or Site Codes may have incompatible heads.
Western Digital encodes manufacturing information in the DCM (Drive Configuration Matrix) printed on the label. Two drives with the same model number and firmware revision but different DCM codes may have incompatible heads.
Seagate uses a combination of the Part Number (PN), Site Code, and Date of Manufacture printed on the label. The Site Code identifies the factory (e.g., WU for Wuxi, SU for Suzhou, TK for Thailand). Two Seagate drives with matching model numbers and firmware revisions but different Site Codes or Part Numbers may have incompatible head assemblies.
Same model number does not mean compatible donor.
A Seagate ST2000LM007 with firmware SBK2 from early 2017 and an ST2000LM007 with firmware SDM1 from 2020 are different hardware generations despite sharing a model number. The heads, preamp, and firmware are different. Using the SDM1 drive as a donor for the SBK2 patient will not work. Matching requires firmware revision, head map, and manufacturing proximity.
How Labs Maintain Donor Inventory
Professional recovery labs maintain an inventory of donor drives organized by manufacturer, model family, firmware revision, head map, and manufacturing date range. Common drive families that fail frequently are stocked in higher quantities. If the lab has a matching donor in stock, the head swap can proceed immediately; otherwise, sourcing takes 1 to 5 days depending on the drive's rarity.
Professional recovery labs maintain an inventory of donor drives organized by manufacturer, model family, firmware revision, head map, and manufacturing date range. Common drive families that fail frequently (Seagate Rosewood, WD Blue/Green 2.5", Samsung Spinpoint M8) are stocked in higher quantities.
When a patient drive arrives, the technician identifies the required donor specifications from the drive label and firmware. If the lab has a matching donor in stock, the head swap can proceed immediately. If not, the lab sources one from supplier networks, which may take 1-5 days depending on the drive's rarity.
Donor inventory depth is one reason the size of a lab's parts library matters when comparing data recovery labs; a lab that already stocks your drive family can begin the head swap without waiting on a supplier order.
Donor drives are purchased specifically as parts inventory. They are functional drives that have been verified to read and write normally. Using a donor from a failed drive (e.g., a drive that had bad sectors but working heads) is possible but risky: the heads may be degraded even if they currently function.
How Do Firmware Families Differ by Manufacturer?
Hard drive manufacturers iterate on base firmware architectures across multiple product generations. Cross-family donors are incompatible even when the model number prefix looks similar, because each family uses a distinct read channel configuration, SA module layout, and head addressing scheme.
Hard drive manufacturers iterate on base firmware architectures across multiple product generations. Recognizing which firmware family a drive belongs to is the first step in donor matching, because cross-family donors are incompatible even when the model number prefix looks similar. Each family uses a distinct read channel configuration, SA module layout, & head addressing scheme.
Seagate F3 Architecture: Grenada and Rosewood
Seagate's F3 architecture covers drives where the firmware revision is a short alphanumeric code without a period (e.g., CC49, SBK2, SDM1). Within F3, these sub-families have distinct matching requirements:
Grenada (7200.14 desktop)
Desktop 3.5" drives including the Barracuda ST1000DM003 & ST2000DM001. Grenada matching depends on firmware revision, head map, & preamp chip. The preamp revision is visible on the HSA flex cable when the drive is opened.
Rosewood (2.5" mobile)
The Rosewood family includes the ST1000LM035, ST2000LM007, & ST500LM030. These are among the most common drives in recovery labs. Rosewood matching is complicated because the preamp revision is not printed on the drive label, and the serial terminal is locked on most units. The preamp must be identified by opening the drive or estimated from the Date of Manufacture.
Western Digital Marvell-Based Architecture
Western Digital transitioned from older Caviar IDE/SATA controllers to Marvell-based MCU architectures. Modern WD drives are categorized into Marvell Version 1 & Version 2, distinguished by the family code in the model number.
WD donor matching requires aligning the full model number, the physical head map, & specific characters within the DCM (Drive Configuration Matrix). The J or 2 anchor character near the end of the DCM, with the character immediately preceding it, encodes the head stack supplier & preamp. Two drives with identical model numbers & firmware but different DCM anchor characters have physically different head assemblies from different component vendors.
WD firmware stores the head map in ROM Module 0A. Module 47 holds the SA Adaptives (servo parameters & head-specific calibration).
SA Adaptives & Microjog Calibration
Service Area (SA) adaptive parameters are head-specific calibration values generated during factory testing. After a head swap, these parameters no longer match the installed donor heads. PC-3000 can transfer the donor's adaptives into the patient firmware to restore read stability. On WD Marvell drives, SA adaptives are stored in Module 47.
Service Area (SA) adaptive parameters are head-specific calibration values generated during factory testing. After a head swap, these parameters no longer match the installed donor heads. PC-3000 can transfer the donor's adaptives into the patient drive's firmware to restore read stability, but the process varies by manufacturer & firmware family.
On Western Digital Marvell-based drives, SA Adaptives are stored in Module 47. This module contains voltage settings, read channel gain profiles, & servo calibration values specific to each head position. If the donor heads deviate from the patient's Module 47 values, the drive may fail to read its own Service Area on power-up, resulting in a clicking loop or immediate head park. The technician uses PC-3000 to replace the patient's Module 47 with the donor's version, allowing the firmware to calibrate for the installed heads.
Microjog values are a subset of the adaptive data. During factory calibration, the drive measures microscopic alignment offsets for each head on the actuator arm & records compensation values. These values correct for physical variation in head placement that is unavoidable during HSA manufacturing. When a donor HSA has microjog values close to the patient's original values, the swap is more likely to produce stable reads without additional intervention. Large deviations in microjog values indicate the donor heads are physically misaligned relative to what the patient firmware expects, which causes read errors & sector instability during imaging.
Why Does the Patient's ROM Transfer to the Donor PCB, Not the Reverse?
The ROM contents follow the patient's heads and platters, not the donor's. The ROM holds adaptive data burned during factory calibration against the original HDA, and the firmware expects that data to match the physical media it is reading. Transplanting a donor ROM onto a patient HDA produces controller errors that look identical to head failure but are actually firmware misconfiguration.
A common question from customers is whether a head swap is accompanied by a ROM swap in the same direction. It is not. The ROM contents follow the patient's heads and platters; never the donor's. This is because the ROM holds adaptive data that was burned during factory calibration against the original HDA, and the firmware expects that data to match the physical media it is reading. Transplanting a donor ROM wholesale onto a patient HDA produces controller errors that look identical to head failure but are actually firmware misconfiguration.
On Seagate F3 drives, the ROM chip holds the bootstrap code and the baseline adaptive parameters (RAP, CAP, SAP); the primary translator (SysFile 28) lives in the Service Area on the platters, not in the ROM. The patient's heads were calibrated against the patient's platters, so the patient ROM must move onto the donor PCB (or equivalently, the donor ROM is replaced with the patient's ROM contents via a programmer). A wholesale donor ROM swap commonly produces the LED 000000CC code on the F3 diagnostic port, or a Diag Err state where the controller cannot locate its own SA.
On Western Digital Marvell-based drives, Module 0A holds the head map and Module 47 holds the SA adaptives. Both pin adaptive data to the physical controller and its factory-calibrated HDA. Using a donor ROM wholesale causes the controller to apply donor servo parameters to the patient HDA, which produces a hardware retry loop (repeated read-channel calibration attempts that never converge) or a slow-responding error where the drive takes several seconds to answer IDENTIFY DEVICE and then fails to initialize the user area.
The practical workflow at our Austin data recovery lab is to read the patient ROM with a programmer clip before the HSA swap is attempted, store the dump, and write the patient ROM contents onto the donor PCB. If the donor PCB is incompatible at the motor-driver level, the donor's electrical components are populated onto the patient's PCB instead, preserving the patient's ROM in its original socket.
How Are Date-Code Window and Site-Code Used for Donor Matching?
Industry practice is to match donors within approximately 3 months (12 weeks) of the patient's Date of Manufacture. The full fingerprint combines three fields: Seagate Part Number prefix, Site Code identifying the factory, and Date of Manufacture. Together, Part Number prefix plus Site Code plus DOM act as an HSA lot fingerprint. Helium drive donor windows tighten to weeks rather than months.
Date of Manufacture is one of the most load-bearing external matching criteria. Industry practice is to match donors within approximately 3 months (12 weeks) of the patient's Date of Manufacture. Some labs stretch this window to 6 months when rare drive families leave no tighter option. A donor from outside the window often looks electrically similar on paper and still produces unstable reads in the patient drive.
The full fingerprint is a combination of three fields. The Site Code (WU for Wuxi, SU for Suzhou, TK for Thailand) identifies the factory. Together, Part Number prefix + Site Code + DOM act as an HSA lot fingerprint.
Helium drive donor windows are tighter. A helium donor window measured in weeks rather than months is standard practice.
What Is Verified at the Clean Bench Before a Head Swap?
Before the patient drive is opened, the ULPA-filtered vertical laminar flow bench is validated with a particle counter and the donor HSA is staged. Visual platter inspection checks for rotational scoring, crash rings, and embedded debris. Slider count verification confirms the physical head count matches the logical head map reported by firmware.
Before the patient drive is opened, the vertical laminar flow bench is validated and the donor HSA is staged. The ULPA-filtered bench provides a particle-controlled localized environment at the open drive. The lab uses a particle counter to verify the bench before opening the drive.
Visual platter inspection runs under high-magnification illumination and checks for three primary defects. Rotational scoring appears as concentric rings around the platter, indicating a head has touched the surface during prior operation. Crash rings are darker zones where the head has scraped the CoCrPt magnetic coating off the substrate; crash rings mean the donor HSA will be sacrificed if installed. Embedded debris is any foreign particle adhered to the platter surface; a single particle requires cleaning with a platter-safe procedure before the donor HSA is brought into contact with the disk.
Slider count verification compares the physical head count on the patient HSA to the logical head map reported by firmware. A 6-head drive must show 6 intact sliders on the HSA arm comb. A missing or damaged slider indicates the head map and the physical assembly are out of sync, and the donor selection must be revisited against the actual physical configuration rather than the label-reported head count.
HSA Extraction and Transplant Procedure
The physical transfer of a Head Stack Assembly from donor to patient is a bench procedure, not a single motion. Every step is performed inside the ULPA vertical laminar flow bench. The procedure runs six stages: head comb staging, actuator pivot release, platter rotation lock, donor HSA preparation, transplant and comb withdrawal, and first power cycle under PC-3000 control.
The physical transfer of a Head Stack Assembly from donor to patient is a bench procedure, not a single motion. Every step is performed inside the ULPA vertical laminar flow bench with the drive cavity open. The tooling is model-family-specific, and the risk at each step is contact between slider and platter surface. Once a slider lands on a spinning or stopped platter with any lateral force, the CoCrPt magnetic coating is scored and the platter track is lost for that revolution; repeated contact creates the crash ring pattern described in the clean-bench verification section above.
  1. Head comb staging. A head comb is a set of thin polymer or shim-steel fingers sized to the exact inter-platter gap of the target drive family. The comb slides between the platters and separates the read/write heads before the HSA is lifted off the pivot. Comb dimensions are specific to drive family: a 3.5" enterprise comb will not fit a 2.5" Rosewood, and a Rosewood comb will bind in an Ultrastar helium cavity. The correct comb is selected by drive family before the patient cover is removed and kept under the laminar flow until installation.
  2. Actuator pivot release. The HSA is held to the baseplate by a pivot screw or magnetic latch (depending on family). The head stack is parked on the ramp load/unload structure or on the inner crash stop, and the comb is inserted between the platters to capture the sliders. Only after the comb is seated can the pivot be released.
  3. Platter rotation lock. On drives with free-spinning spindles (some 3.5" desktop families), a spindle lock pin is inserted through the motor hub to prevent platter rotation during HSA removal. Any rotation while the comb is between the platters drags the sliders against the comb surface and abrades the air-bearing face. On sealed helium drives, the cover reseal procedure after a head swap requires helium refill from a calibrated line per our helium-HDD recovery workflow.
  4. Donor HSA preparation. The donor drive is opened in parallel under the same bench. The donor HSA is combed and lifted identically. The donor ROM is not transferred; only the physical head stack is moved. The patient ROM contents have already been programmed onto the donor PCB (or the donor PCB has been swapped onto the patient body) before this step, per the ROM binding procedure in the section above.
  5. Transplant and comb withdrawal. The donor HSA is seated onto the patient pivot with the comb still holding the sliders apart. The pivot screw or latch is reattached. The comb is withdrawn in a single smooth motion parallel to the platter surface; a tilted withdrawal brings a slider into momentary contact with the platter and can score the landing zone. The cover is replaced before power is applied to prevent airflow contamination of the newly transplanted heads.
  6. First power cycle under PC-3000 control. The drive is connected to the PC-3000 Portable III or Express terminal, not to a normal SATA port. First power is issued with the terminal recording the boot sequence so that any SA read failure, adaptive mismatch, or preamp error is captured in the log before the firmware commits a write. If the drive fails to spin up, the procedure aborts and the donor selection is revisited before a second attempt is staged.
Extraction procedure varies across families. WD 2.5" Marvell drives (WD10SPZX, WD20SPZX) use a magnetic latch instead of a screw on some sub-revisions, which the technician identifies visually before lifting. Helium drives (Ultrastar DC HC series, Exos X) require the additional step of breaking the cover hermetic seal under the bench and refilling the cavity with helium from a calibrated line before the cover is re-bonded. Helium head swaps use $3,000–$4,500; surface damage cases use $4,000–$5,000, plus helium and donor costs.
PC-3000 Head Testing Workflow
After installing a donor HSA, PC-3000 runs a structured diagnostic sequence to evaluate whether the donor heads can read the patient drive's data. The workflow runs four steps: SA module read test, head stability evaluation, conditional adaptive transfer, and selective head map configuration. The workflow determines head compatibility, identifies weak heads, and guides the imaging strategy.
After installing a donor HSA, the technician uses PC-3000 to evaluate whether the donor heads can read the patient drive's data. This is a structured diagnostic sequence, not a single pass/fail test. The workflow determines head compatibility, identifies weak heads, & guides the imaging strategy.
  1. SA Module Read Test. Power on the patient drive with the donor HSA installed. PC-3000 attempts to read the Service Area modules (the firmware stored on reserved platter tracks). If the drive reads its SA successfully, the donor heads are electrically compatible with the patient's controller & preamp circuit. If the SA read fails, the heads are incompatible or the adaptives need transfer.
  2. Head Stability Evaluation. PC-3000 reads sample sectors from each head position & reports the error rate per head. Donor heads are never perfectly calibrated for the patient's platters; some read degradation is expected. The technician evaluates whether each head reads well enough for sustained imaging or if specific heads need to be disabled in the head map to prevent platter damage from a weak head dragging.
  3. Conditional Adaptive Transfer. If the SA read succeeded but the error rate is high, the technician transfers the donor's adaptive parameters into the patient firmware. On WD drives, this means replacing Module 47. On Seagate F3 drives, this means editing the SA adaptive tables. The drive is then power-cycled & the head stability test is repeated.
  4. Selective Head Map Configuration. If one or more heads are unstable after adaptive transfer, PC-3000 can disable specific heads in the firmware head map. The imaging proceeds using only the stable heads, recovering data from the platter surfaces those heads can reach. Data on surfaces served by the disabled heads may require a second donor attempt with a better-matched HSA.
How Does Donor Matching Work on Modern 20TB+ Enterprise Drives?
Enterprise HDDs released from 2024 onward introduce recording-layer technologies that tighten donor matching beyond PMR and helium-PMR rules.
Enterprise HDDs released from 2024 onward introduce recording-layer technologies that tighten donor matching beyond the rules that apply to PMR and helium-PMR families. Donor windows shrink, cross-family substitution is ruled out, and additional verification steps run on the PC-3000 Portable III before any head-comb work begins. The procedures referenced here run inside our in-house mechanical recovery lab under the same ULPA clean bench used for consumer drive head swaps.
WD Ultrastar DC HC560 and HC580 TSA HelioSeal
The Ultrastar DC HC560 (20 TB) and HC580 (24 TB CMR) families add a Triple-Stage Actuator (TSA) on top of the primary VCM and the secondary milli-actuator.
The practical effect on donor selection is a donor window measured in weeks. The full DCM string on the label becomes a hard match criterion.
Toshiba MG10 and MG11 FC-MAMR
The Toshiba MG10 (20 TB) and MG11 (24 TB) families use Flux Control Microwave-Assisted Magnetic Recording (FC-MAMR). Each write head carries a spin-torque oscillator that emits a microwave field at the gap, lowering the effective switching field of the recording layer so smaller bit cells can be written reliably. Donor matching uses the HDD Code printed on the drive label.
Modern HDD Family Quick Reference
FamilyRecording TechDonor-Matching Criticals
WD Ultrastar DC HC560 / HC580CMR with Triple-Stage Actuator, HelioSealFull DCM, donor window in weeks
Toshiba MG10 / MG11FC-MAMR with spin-torque oscillatorHDD Code on label
Why Do OptiNAND Drives Require iNAND Migration During a Head Swap?
Western Digital OptiNAND drives move metadata from the platter Service Area onto an iNAND UFS chip soldered to the PCB, including RRO tables, ATI refresh accounting, and ArmorCache emergency-power-off cache. A standard SPI ROM transplant is insufficient because the head positioning servo loop depends on data that no longer lives on the platters. The iNAND must be migrated to the donor PCB as a separately handled component.
Western Digital OptiNAND drives move metadata that older designs kept inside the platter Service Area onto an iNAND UFS chip soldered to the PCB. The metadata includes the Repeatable Run-Out (RRO) tables, the Adjacent Track Interference (ATI) refresh accounting, and the ArmorCache emergency-power-off cache. A standard SPI ROM transplant procedure is not sufficient on these drives, because the head positioning servo loop depends on data that no longer lives on the platters. Donor PCB swaps and ROM transfers on OptiNAND drives require treating the iNAND as a separately migrated component.
The correct PCB transplant on an OptiNAND drive moves the iNAND UFS chip onto the donor PCB so the donor controller reads patient-specific RRO and ATI metadata, or moves the SoC and the iNAND together as a paired unit. The iNAND footprint on the PCB is a discrete UFS package next to the controller, and it is reworked under the same Atten 862 hot air station used for SPI ROM transplants, with FLIR thermal monitoring to keep the package within the manufacturer reflow profile. After the migration, the controller reads RRO and ATI from the patient iNAND and the original head positioning model is restored.
An iNAND failure that is independent of the heads is a distinct failure mode from a classic head crash. The patient HSA can be mechanically healthy, but with the iNAND unreadable the ATI and RRO indices are lost and the heads cannot stabilize tracking against recorded data.
What Are the Donor Matching Constraints for Mozaic HAMR Drives?
Donor heads from any PMR or helium-PMR family are strictly incompatible with a Mozaic HAMR chassis. The Mozaic HSA carries an integrated nanophotonic laser and a plasmonic writer. PMR heads carry neither.
The Seagate Mozaic HAMR HSA carries an integrated nanophotonic laser and a plasmonic writer, which together perform the thermal writing that the superlattice platinum-alloy media requires.
Donor heads from any PMR or helium-PMR family are strictly incompatible with a Mozaic HAMR chassis. PMR heads carry no laser and no plasmonic writer, and the recording layer on PMR platters does not require heat-assisted writing. A PMR HSA installed on a HAMR chassis cannot write the recording layer at all.
Can a Larger-Capacity Donor Be Used for a Down-Binned Drive?
Manufacturers ship multi-platter HDAs with one or more heads disabled in firmware to fill lower-capacity SKUs. A larger-capacity donor in the same family can be used for a down-binned patient when the active-head positions align with the donor's physical-head positions. On WD Marvell, the active-head map in Module 0A is edited; on Seagate F3, the Zones and Heads Inactivation P-List path marks unused heads inactive.
Manufacturers ship multi-platter HDAs with one or more heads disabled in firmware so a single mechanical platform can fill multiple lower-capacity SKUs. A 4-head HDA may ship as a 3-head or 2-head SKU with the surplus heads marked inactive in the head map. The HDA, the preamp, and the HSA generation are physically identical across the binned SKUs. This opens a procedural option in donor matching: a larger-capacity donor in the same family can be used for a down-binned patient when the active-head positions on the patient align with the physical-head positions on the donor.
On WD Marvell platforms, the active-head map is stored in Module 0A. The map is edited on the PC-3000 so the patient's active positions match the physical heads being installed from the donor HSA, and the surplus donor heads are masked inactive before the first power-up.
On Seagate F3 platforms, the Zones and Heads Inactivation P-List path is used to mark unused heads inactive on the donor side before the swap, or to retire a marginal head after the swap when a single donor head proves unstable on the patient's platter surface. The Heads Inactivation entries persist in the SA and survive subsequent power cycles, so the controller stops attempting to read tracks on the masked heads during imaging.
The standard disqualifiers still apply. A larger-capacity donor from a different HSA generation cannot be used regardless of capacity, because the preamp, head attachment geometry, and adaptive parameter set differ. A larger-capacity donor from a different preamp revision cannot be used either, even when the HSA generation matches, for the reasons documented in the preamp compatibility section. Down-bin substitution is a procedural option that expands the donor pool, not a way around the PC-3000 matching criteria.
What Are the Common Drive Family Matching Pitfalls?
Each drive family has compatibility traps that general matching rules do not cover. These pitfalls come from undocumented component changes, manufacturing site differences, and firmware sub-revisions not reflected on the drive label. The most common pitfalls are the Rosewood preamp revision, the WD DCM anchor-character head stack supplier, and Samsung-internals Seagate-branded drives.
Each drive family has specific compatibility traps that general matching rules do not cover. These pitfalls come from undocumented component changes, manufacturing site differences, & firmware sub-revisions that are not reflected on the drive label. The following notes apply to the drive families most commonly seen in recovery labs.
Seagate Rosewood Pitfalls
The Rosewood 2.5" family (ST1000LM035, ST2000LM007) accounts for a large share of consumer head-swap cases. The primary matching hazard is the preamp revision. At least two distinct preamp generations are in circulation, and neither the preamp part nor its revision is printed on the label. The Date of Manufacture printed on the label provides the best external estimate.
Verification is by opening the drive & reading the preamp marking on the HSA flex cable, or by reading the preamp identifier through PC-3000 after a successful SA initialization.
WD Blue & Green Marvell Platform
Modern WD 2.5" drives (WD10SPZX, WD20SPZX, WD10SPCX) use the Marvell controller platform. The DCM is the critical external matching reference. The J or 2 anchor character near the end of the string, with the character immediately preceding it, identifies the head stack supplier; donors that differ on those characters will have a physically different HSA even when the model number & firmware match.
Samsung / Seagate Momentus Hybrid Drives
After Seagate acquired Samsung's HDD division, several drive models carry Seagate branding but use Samsung-designed internals. The ST1000LM024 is a Samsung Spinpoint M8 with a Seagate label. Donor matching for these drives must follow Samsung logic (full model number & PCB part number), not Seagate F3 logic. Using a Seagate F3 donor for a Seagate-branded Samsung drive will fail because the SA module layout, head addressing, & preamp circuitry are Samsung architecture.
Head swap on Samsung/Seagate hybrid drives follows standard head swap pricing at $1,200–$1,500. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. +$100 rush fee to move to the front of the queue
For complex donor-sourcing cases, customers can track progress through our in-house mechanical recovery lab, where the donor, adaptive transfer, and imaging steps are all performed under a single PC-3000 workstation without subcontracting.
Why can't I just buy the same model hard drive for parts?
Matching by model number alone is insufficient. Manufacturers produce the same model across multiple hardware revisions with different head components, preamp chips, and firmware. The firmware revision, head map, preamp compatibility, and manufacturing batch all affect whether donor heads work with the patient drive's platters and firmware.
How many donor drives does a lab typically try?
Most successful swaps use the first well-matched donor. When matching criteria are tight (rare head configuration, specific firmware sub-revision), a lab may test two or three donors. Each attempt involves installing donor heads, powering on under PC-3000 control, and checking read stability. Labs maintain inventories sorted by firmware revision, head map, and manufacturing date to minimize trial-and-error.
Are hard drive read/write heads interchangeable between models?
No. Read/write heads are not interchangeable between different drive models, and often not interchangeable between different revisions of the same model. The heads must match the patient drive's firmware revision, head map configuration, preamp chip, & ideally the manufacturing batch. A head stack assembly from a Seagate Rosewood drive with one preamp revision will fail in a Rosewood with a different preamp revision, even if the model number is identical.
What is head map down-binning in hard drives?
Down-binning is a manufacturing practice where a drive with multiple platter surfaces has one or more heads disabled in firmware to sell at a lower capacity. The head map stored in firmware defines which specific physical head positions are active (e.g., heads 0 & 1, or heads 0 & 2). Donor matching must account for which specific heads are active, not just the total count.
Can a donor drive from a different factory work for a head swap?
It depends on the manufacturer. Seagate drives manufactured at different sites (identified by the Site Code, such as WU for Wuxi or SU for Suzhou) frequently have different head components even when the model & firmware match. WD drives from different factories may differ in head stack supplier (identifiable by the DCM). Matching the manufacturing site reduces the risk of component-level incompatibility.
Why is a ULPA clean bench required for a head swap?
Read/write head fly-height is in the single-digit nanometer range, so a single airborne dust particle trapped between the head and the platter scores the CoCrPt magnetic coating on spin-up and destroys both donor heads and the patient platter surface. The ULPA bench is validated with a particle counter before the drive is opened.
How close does the date of manufacture need to be on a donor drive?
The industry standard donor window is approximately 3 months (12 weeks) from the patient drive's Date of Manufacture. Some labs stretch to 6 months when a tighter match is unavailable. Helium drives tighten the window to weeks rather than months.
Can you skip adaptive transfer after a head swap?
Sometimes, but not safely on most modern drive families. A small fraction of older drives tolerate a head swap without adaptive transfer because the firmware applies broad default read-channel parameters that fall within the donor head's response range. On modern WD Marvell, Seagate F3 Rosewood and Grenada, and helium families (Ultrastar DC HC, Exos X), skipping adaptive transfer typically produces a clicking loop, a partial spin-up where IDENTIFY DEVICE answers but the user area is unreadable, or a slow imaging rate with high Reallocated Sector Count growth on the first read pass. PC-3000 Portable III transfers the donor's adaptive parameters (Module 47 on WD, SA adaptive tables on Seagate F3) into the patient firmware before the first imaging pass.
Can I swap the ROM chip from a donor drive onto my failed drive?
No. The patient ROM carries adaptive data calibrated against the patient's heads and platters. The correct direction is the reverse: the patient ROM moves onto the donor PCB, or the donor PCB's ROM is re-flashed with the patient ROM contents. A wholesale donor ROM swap produces a hardware retry loop, a slow-responding controller, or diagnostic errors such as Seagate LED 000000CC / Diag Err. On WD Marvell drives, Modules 0A and 47 pin adaptive data to the physical controller. On Seagate F3 drives, the ROM holds the bootstrap code and the baseline adaptive parameters (RAP, CAP, SAP); the translator (SysFile 28) lives in the Service Area on the platters.
Can I use a larger-capacity drive as a donor for a smaller down-binned patient?
Yes, inside the same drive family, when the active-head positions on the patient align with the donor's physical-head positions. On WD Marvell, Module 0A stores the active-head map, and the map is edited so the patient's active positions match the donor heads being installed. On Seagate F3, the Zones and Heads Inactivation P-List path marks unused donor heads inactive, or retires a marginal head after the swap. The standard disqualifiers still apply: a larger-capacity donor from a different HSA generation or a different preamp revision cannot be used regardless of capacity.
Why is a simple ROM swap insufficient on OptiNAND drives?
Western Digital OptiNAND drives store Repeatable Run-Out tables, Adjacent Track Interference refresh accounting, and the ArmorCache emergency-power-off cache on an iNAND UFS chip soldered to the PCB. A bare SPI ROM transplant leaves the iNAND mismatched to the patient HSA, and the servo loop cannot stabilize tracking because the RRO and ATI metadata no longer lives on the platters. The iNAND device must be relocated to the donor PCB, or the SoC and iNAND moved together as a paired unit. An iNAND failure independent of the heads is a distinct failure mode where the heads are mechanically healthy but head positioning collapses.
Are Mozaic HAMR head swaps possible with a non-HAMR donor?
No. The Mozaic HAMR HSA carries an integrated nanophotonic laser and a plasmonic writer, which together heat the superlattice platinum-alloy media at the moment of writing. PMR and helium-PMR heads carry no laser and no plasmonic writer, so they are strictly incompatible with a HAMR chassis.
