What a Hard Drive Head Swap Involves
A head swap is the process of replacing a hard drive's failed read/write head stack assembly (HSA) with a compatible HSA from a matched donor drive. It is performed when the original heads are physically damaged or fed by a failed preamp. The swap happens inside a ULPA-filtered laminar flow bench so the exposed platters never see room air. Head swap recovery falls inside our broader hard drive data recovery service at $1,200–$1,500 plus donor drive cost.
When Is a Head Swap Needed?
Common scenarios that require a head swap:
- The drive clicks repetitively because the heads cannot read servo wedges (head failure or preamp failure)
- The drive makes grinding or scraping sounds (head crash with platter contact)
- The drive initializes but large regions of the platter are unreadable due to a degraded or failed individual head
Before committing to a head swap, a technician verifies the diagnosis. Firmware issues can mimic head failure. A drive that clicks because of corrupted Service Area structures can sometimes be repaired through firmware access alone, with the enclosure never opened.
What Are the Six Causes of Repetitive Actuator Clicking?
- 1. Head Stack Assembly (HSA) Physical Failure
- The read/write heads are damaged, the preamplifier on the head stack flex has failed, or the flex itself is open. This is the only scenario on this list that requires a physical head swap. The drive spins, sweeps, and never resolves servo well enough to report a valid identity.
- 2. Service Area (SA) Firmware Corruption
- The physical heads are healthy, but the firmware structures stored on the reserved cylinders are corrupted. The drive cannot load its own operating code and enters a retry loop. PC-3000 can rebuild the translator and restore Service Area structures with the drive still sealed.
- 3. PCB Component Failure
- A shorted TVS diode, a burnt regulator, or a failed combo motor driver prevents stable power delivery. The driver retries startup and the actuator rehomes each time. A TVS that has done its job fails as a dead short to ground, tripping upstream protection, which is how it shields the driver behind it. Board repair fixes this without a head swap.
- 4. Bad Sector Accumulation in the Firmware Zone
- The G-list has overflowed, or media damage inside the Service Area blocks the initialization data the firmware needs. The drive throws itself into a continuous retry loop. PC-3000 can clear the overflow & regenerate the translator.
- 5. Power Supply Instability
- Insufficient amperage from the host power supply causes brownouts to the drive's logic board. The 12V rail sags during spindle spin-up, the motor controller resets, and the actuator rehomes. Testing on a known-good power supply or bench power supply confirms this cause.
- 6. Fluid Dynamic Bearing (FDB) Seizure
- The platters never reach operating speed, so the heads never fly and never read servo. That is a motor failure, and the recovery path is a platter transplant rather than a head swap.
At our Austin lab we diagnose every clicking drive with PC-3000, FLIR thermal imaging of the exposed board, and multimeter checks before choosing between firmware repair, board rework, and a head swap. Acoustics narrow nothing on their own: several of the six causes above sound alike through a drive lid. Misdiagnosing firmware corruption as head failure wastes donor money and puts an intact drive on the bench for no reason. All head-swap work happens at this single Austin, TX lab, and drives ship in from anywhere in the country through our mail-in hard drive recovery intake.
What Are the Donor Drive Matching Criteria?
The matching criteria are:
- Firmware Family
- A model number identifies a product; a firmware family identifies the Service Area layout and head map format the drive was built around. Two drives with the same model number on different firmware families can carry different structures, so the donor has to come from inside the patient's family.
- Head Count and Head Map
- A donor can have more heads than the patient drive. Beyond count, the head map (which physical head reads which platter surface) must match.
- Preamp Compatibility
- The preamplifier is an analog IC on the head stack flex, not a part on the external board, so its compatibility rides along with the whole assembly. Manufacturers change preamp suppliers and revisions between production runs, which is what the vendor identifier codes are read for.
- Manufacturing Date and Site
- Drives built at different factories or in different date ranges can use different internal components behind one model number. Seagate encodes this through the Part Number, Site Code, and Date Code. Western Digital encodes it through the Drive Configuration Matrix, the DCM string printed on the label.
Where Is the Preamp Located and Why Is Preamp Rework Not Performed?
The preamp amplifies microvolt-level signals from the tunneling magnetoresistive read sensors into millivolt waveforms the read channel can work with. It is mounted on the HSA flex so those high-impedance signals travel the shortest possible path before amplification. Moving it to the board would add dozens of traces through the flex and connector, and the noise picked up along the way would swamp the signal.
The large chips people point at on the outside of the board are not preamps. A part like the ST L6260 is a combo driver for the spindle and voice coil, and preamps in this class come from TI or LSI/Agere and live inside on the flex. Forum posts occasionally suggest transferring a healthy preamp onto a patient's flex with BGA or LGA rework. The fix for a preamp fault is a donor head stack.
How Is Donor Compatibility Checked Before the Donor Is Opened?
Seagate donor matching aligns the Part Number, the Site Code, and the Date Code. Site codes name the factory that built the drive. Seagate has no DCM: the Drive Configuration Matrix is a Western Digital identifier, and mixing the two vocabularies is how donors get bought that were never going to work.
On Western Digital drives the DCM string is the field that tracks preamplifier and head stack compatibility. Technicians align the J or 2 anchor character near the end of that string, plus the character immediately before it. Decoding the DCM by digit position is the common mistake, and published position rules contradict each other across sources, so the anchor is what gets matched.
Firmware gives the rest. On WD ROYL drives, Module 0A holds the active head map and Module 47 holds the servo adaptives, including the per-head microjog offsets between each slider's read and write elements. Both are read from the patient before any mechanical work, so the technician knows what the donor has to satisfy & has a backup if the drive degrades during the transplant.
Sourcing takes time because of this. One model number can span several internal builds across its production life, and a candidate that disagrees on head count or firmware family is rejected on the label alone. Labs keep cataloged donor inventory sorted by model, firmware family, and date code so candidates can be checked against the patient without waiting on shipments.
What Does the Head Swap Procedure Involve Step by Step?
- Environment preparation. The laminar flow bench is powered on. ULPA filtration establishes a particle-free airstream across the work surface. Tools are cleaned and placed within reach.
- Drive disassembly. The patient drive's top cover is removed by extracting the Torx screws. Any internal recirculation filter is noted. The actuator latch, magnetic or screw-based, is released.
- HSA removal. The comb or ramp fixture goes in first, then the head stack assembly comes off the pivot in one motion. The sliders never touch the platter data surface and never touch each other.
- Platter inspection. The exposed platter surfaces are examined under magnification for scoring, debris, or contamination. If a platter surface carries concentric scoring from a head crash, that whole surface is skipped during imaging.
- Donor HSA installation. The matched donor assembly goes in along the mirror image of the removal path, seated on the pivot with the flex reconnected and the latch secured. The fixture is withdrawn once the assembly is seated, and it does not stay inside the drive.
- Reassembly. The cover is reseated and screwed down so the enclosure and its recirculation filtration work as designed. Helium drives are repressurized with helium after the donor assembly is installed; we perform the mechanical work, the helium refill, and platter cleaning in-house at our Austin lab. Helium is roughly one-seventh the density of air, about 0.18 kg/m³ against 1.22 kg/m³, and the air-bearing surface was cut for the lighter gas. Spin that stack in air and the slider flies outside the clearance window it was calibrated for, which is what puts it into the platter.
Does the Drive Need a Head Comb or a Ramp Tool?
Contact start/stop drives rest their heads on a textured landing zone on the platter when power is off. To move that head stack, a thin separator comb slides between the sliders so they cannot touch each other or the data tracks as the assembly lifts off the pivot. Combs are sized to a specific platter spacing and platter count.
Ramp-parked drives park the heads on a plastic ramp outside the outer diameter of the platter stack. Lifting straight up tears the suspension tongues, because the sliders are perched on the ramp lips. Extraction needs a ramp tool that constrains the sliders against the ramp profile, holds the actuator at the right rotational position, and lets the whole assembly clear in one smooth vertical motion. Parking type follows generation: Seagate U Series and Barracuda drives through the 7200.12 generation use landing-zone parking, while later Barracuda generations and Western Digital and Toshiba drives from roughly 2008 use ramps. Inspection settles it when the label does not.
Sequence matters as much as tool choice. On ramp-parked families the actuator is rotated off the magnet so the voice coil clears the upper pole, and a magnetic latch or locking pin is released before the tool can slide in. The donor assembly is loaded onto the fixture outside the drive cavity, lowered in, seated on the pivot, and only then is the fixture withdrawn so the heads settle onto the ramp lips in their factory orientation. Pulling the tool before the pivot is seated is how sliders snap off.
A comb is an insertion and extraction fixture and nothing more. It leaves the drive before the lid goes back on, so no fixture is holding, lifting, or steering heads while the platters spin.
Why Does ROM Transfer Matter for Modern Drives?
The standard approach keeps the original board, with its original ROM, attached to the drive that now has donor heads. PC-3000 then reads the existing adaptive parameters and adjusts them for the installed hardware, and edits the head map where the firmware needs to be told which physical head is which logical head.
On boards that carry a discrete ROM, that part is an 8-pin SPI NOR flash. Moving it to a donor board means reading it with a programmer and writing it to the donor. Nothing is being "re-fused," since fusing describes one-time-programmable eFuses inside a SoC. The defect tables are not in there either. The P-List and G-List live in the Service Area on the platters, which is why a board swap alone never delivers them and why damaged heads block a translator rebuild.
A PCB swap alone does not fix head failure.
Swapping the PCB replaces the electronics, not the read/write heads. The heads are inside the sealed drive enclosure, attached to the actuator assembly. If the heads are damaged, a PCB swap changes nothing about the mechanical failure inside the drive.
Which Firmware Modules Should Be Backed Up Before a Head Swap?
These are the Western Digital modules backed up before a head swap at our Austin lab. Each one serves a distinct function, and losing one without a backup turns a recoverable mechanical failure into a firmware reconstruction job.
- Module 0A
- The active head map: which logical head corresponds to which physical head and surface. It is ROM-resident with a shadow copy on the platters in Module 102.
- Module 47
- Servo calibration and the per-head microjog tuning. ROM-resident with a shadow copy in Module 103. This is the module that has to describe the heads actually installed, which is why it is read before the swap and worked on after it.
- Module 02
- Configuration: model, serial number, capacity, and lock state. It is identity data, not calibration data, and it belongs to the patient drive.
- Module 11
- The Loader, or permanent overlay, uploaded into the Marvell controller's volatile memory at power-up. When a drive is stuck in BSY, this is what PC-3000 can load into RAM to simulate a successful Service Area boot.
- Module 30
- The Service Area defect translator. It is among the structures most often damaged during a failed head initialization, and losing it forces translation to be rebuilt from the surviving defect data.
- Module 32
- The G-list relocation tracker. Overfill here produces the familiar "slow responding" behaviour, with the firmware stuck parsing a list it cannot finish.
Seagate F3 drives use different vocabulary for the same idea. Firmware components there are System Files in the Service Area, reached through the F3 diagnostic terminal rather than through WD Module numbers, and the two naming systems never mix on one drive. On modern Seagate families the diagnostic terminal ships locked, so a silent terminal is not evidence that the board is dead.
Getting into that terminal is its own step. PC-3000 dumps the SPI ROM and applies a boot code patch that lives in RAM, which re-enables the diagnostic port for Service Area work and disappears at the next power cycle. What that patch does is bounded: it restores terminal access, and it does not decrypt user data or bypass an SED or ATA password lock. A drive locked with those still needs the original credentials, and no firmware tool substitutes for them.
How Does Post-Swap Imaging Work?
Imaging after a head swap runs conservatively. Read quality is marginal by definition, so the imager takes the easy sectors first on a fast pass, then returns for the failures with slower passes and longer retry budgets. Parking the heads between passes lets the donor set cool.
If the donor heads degrade during imaging, with read errors climbing or clicking starting, a second swap with a fresh donor set is the next move. That is why labs stock more than one compatible donor for common families, and why imaging is the part of the job that consumes the schedule.
How Does Manufacturer-Specific Donor Matching Work?
| Family | Identifier fields that are matched | Firmware structures read first |
| Seagate F3 | Part Number, Site Code, and Date Code from the label. Seagate does not use a DCM. | System Files in the Service Area, read through the F3 diagnostic terminal |
| Western Digital ROYL | DCM string, aligned on the J or 2 anchor character near the end plus the character before it | Module 0A (head map) and Module 47 (servo adaptives and microjogs) |
Vendor vocabulary is not interchangeable, and treating it as though it were is a real source of destroyed drives. DCM belongs to Western Digital. Site codes belong to Seagate. The Media Cache Management Table and the Non-Resident G-List are Seagate F3 structures, and the T2 translator in Module 190 is a Western Digital structure. A workflow that mixes them up is reading the wrong thing on the wrong architecture.
Toshiba and HGST each print their own identifier sets, and the fields that decide compatibility are not the same between the two vendors. A donor bought on an unsourced decode rule is a donor bought twice, so the label fields get compared directly against the patient rather than run through a rule of thumb.
How Are CCB-Generation WD and HGST Helium Drives Accessed?
Which PC-3000 hardware a lab owns decides how it reaches these families. A PC-3000 Portable III or Portable PRO needs ACE Lab's separate HGST CCB adapter for CCB drives. The PC-3000 Express does not: CCB support is built into the software itself, and that is the path we use here.
Without CCB-capable access, a technician can spin a helium drive up and get nothing useful out of it. Service Area structures stay unreadable, background firmware activity cannot be halted while modules are being worked on, and the head map cannot be edited after a transplant. These are WD-architecture drives, so the structures in question are numbered Modules; System File numbering belongs to Seagate F3 and does not apply here.
Helium adds a physical constraint on top of the firmware one. The factory seal is laser-welded and no lab re-creates it, so a refill buys a working window rather than a repair, and the patient drive is retired after the data is cloned rather than returned as a usable device. Helium head swaps at Rossmann Repair Group run $3,000–$4,500, plus helium and donor cost. Helium cost: $400-$800 additional for head swap and surface damage tiers. This covers the helium refill required after opening the sealed chamber. We do this work in-house, including the refill and platter cleaning.
How Is Donor HSA Compatibility Determined?
| Step | Filter | Rejection criteria | Source |
| 1 | Model and form factor | Different base model, or 3.5-inch against 2.5-inch | Drive label |
| 2 | Firmware family | Firmware revision from outside the patient's family | Drive label or PC-3000 |
| 3 | Vendor build identifiers | Seagate Part Number, Site Code, or Date Code disagree; WD DCM anchor character and its preceding character disagree | Drive label |
| 4 | Head count and head map | Different head count, or a head map that does not correspond | PC-3000 (WD Module 0A) |
| 5 | Adaptives readable | Patient adaptives cannot be read, so there is nothing to align the donor against | PC-3000 (WD Module 47) |
Order is what makes the sequence cheap. A label comparison takes half a minute and eliminates most candidates, so model, firmware family, and vendor build identifiers go first. Firmware reads take longer and run only on survivors. Working the sequence backwards means burning bench time on drives that were disqualified by their own labels.
This is why a head-swap tier recovery at our Austin lab runs $1,200–$1,500 for head-swap recovery plus the donor drive itself. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. +$100 rush fee to move to the front of the queue. There is no diagnostic fee, and our no data, no recovery fee policy covers the tier.
How Is the Head Map Configured and the Translator Rebuilt Using PC-3000?
Adaptive Alignment to the Installed Heads
Every drive carries calibration data unique to its own head and media combination, split between the serial flash ROM on the board and the Service Area on the platters. That data tunes the read channel and the servo loop for particular heads. On supported families PC-3000 reads those parameters and writes them so the channel is targeting the heads actually installed rather than the ones that failed.
On Western Digital ROYL drives this is concrete: Module 47 holds the servo adaptives and per-head microjog offsets, and Module 0A holds the head map they apply to. Drive donor heads with the patient's original microjog data, or the reverse, and the read element sits off the track center the write element used. The drive clicks, fails to read, and can scrape the platter.
Logical Head Map Editing
On multi-platter drives one donor head is often weaker than the rest, or one surface carries thermal asperities from a prior head crash. PC-3000 can build a selective head map that disables the problem head so the healthy surfaces clone first. Once that data is safe, the weak head is re-enabled for a targeted slow pass with tight timeouts.
Translator Module Verification
The translator maps logical block addresses to physical sectors. A head crash often damages it, because failing heads generate read errors that overflow the defect lists. The symptom is a drive that spins up normally and then reports zero capacity or the wrong identity. PC-3000 can start the drive in factory mode, work around the damaged structures, and reconstruct translation from the defect data in the Service Area.
What Are the Common Head Swap Failure Modes?
- Donor Electrical Mismatch
- The drive spins up and the heads load, but the read channel never resolves servo, so the actuator sweeps and clicks instead of settling. Nothing on the board fixes this, because the preamp is part of the assembly that was just installed. The donor is pulled and a different candidate is sourced.
- Platter Contamination
- Crashed heads shave magnetic material and slider debris off the surfaces, and that debris settles across the platters and inside the cavity. Install donor heads over uncleaned platters and the debris works like sandpaper on the new sliders, wrecking them within seconds of power-on.
- Donor Wear During Imaging
- Donor heads were calibrated for a different set of platters. Over a long imaging session the air bearing degrades and read margins fall, which shows up as rising error counts and slower throughput. Rest periods between passes and a second donor set on standby are how that gets managed.
- Adaptives Left Unaligned
- A physically perfect transplant still returns garbage if the firmware is driving the new heads with the old calibration. Alignment is not a one-time step either: as the donor set wears, the technician pauses imaging, re-runs adaptive alignment through PC-3000, and resumes.
When Is a Head Swap Disqualified?
| Platter condition | What it looks like under magnification | Recovery outlook |
| Scoring confined to a band | A grooved circular band at one radius, with coated surface on either side of it. | The band is lost, the rest is not. Donor heads image the intact surface, and the affected range is mapped as permanent defects. |
| Full-radius stripped media | Grooves covering the radius of one or more surfaces, often visible as a change in sheen where the magnetic layer is gone down to the substrate. | Disqualified. The data carrier is gone, so the case closes at inspection and no donor work is attempted. |
Full-radius damage is why a drive that clicks repeatedly has to be powered down at the first sign of a head crash. One failing head produces abrasive debris, a mixture of stripped magnetic media, overcoat fragments, and slider material, and the airflow inside a spinning drive carries it to every surface. Each new crash adds debris, which shortens the survival of the next head, which adds more debris. A drive that arrives after hours of retries often shows scoring on surfaces that were healthy when the first head let go. The guidance on every clicking-drive page is the same for that reason: stop powering it on.
How Are Scratched Platters Handled in Recovery?
Firmware lives on reserved cylinders outside the user area, and if the damage reaches those tracks the drive cannot load its own operating code even with a healthy donor assembly installed. That case is a firmware problem stacked on a mechanical one: the transplant restores flying heads, and the Service Area work still has to succeed afterward before any user data is reachable.
Platter cleaning in the ULPA-filtered bench comes before donor heads go in. The technician cleans the surfaces with lint-free wipes and filtered isopropyl alcohol and inspects under magnification. Debris left behind destroys the donor set within seconds of power-on. If the magnetic layer is stripped to the substrate across the radius, the case is disqualified, because no head reads what is no longer there.
Cleaning and helium refill are both in-house work at the Austin lab, which has been the only Rossmann Repair Group location since the company was founded in 2008. Nothing on a head swap is subcontracted to a franchise or a partner lab.
Macro Cleanroom vs Localized Laminar Flow Bench
A drive opened inside an active ULPA bench, with the lid removed in the downstream airflow, sits in cleaner air than a drive opened in a filtered room where somebody just walked past the bench and broke up the flow. The governing variable is laminar airflow integrity over the platter window while the drive is open, and that is a property of how the work is done rather than of the square footage around it.
A HEPA filter's 0.3 micron rating is often misread. That figure is its most penetrating particle size, the point of minimum efficiency, not the smallest particle it stops. Smaller particles are captured at higher efficiency through Brownian diffusion. The Austin lab runs a ULPA-filtered laminar flow bench for all mechanical work, including head swaps, helium refills, and platter cleaning. The full comparison of filtration architectures is on the cleanrooms vs laminar flow benches reference page.
How Does Read Channel Tuning Work After a Head Swap?
Modern drives read with maximum-likelihood detection: the channel does not hunt for isolated peaks, it equalizes the sampled waveform and lets the detector pick the most probable bit sequence out of it. Adaptive parameters are what shape the signal reaching that detector, and they were measured against particular heads at the factory.
What changes during retuning is equalization ahead of the detector, gain, target response, and how the firmware schedules retries. The detector itself is fixed logic with no accept-or-reject threshold to loosen, so the recovery margin sits in what reaches it. That margin is real: adaptives tuned for degraded heads or scored surfaces pull data off sectors that stock parameters return as errors.
The trade is throughput. A marginal donor match images slowly, and a job that would have cloned overnight can run for days. That is one of the reasons labs stock several compatible donors per common family: when a set falls below usable read margins, a fresh set goes in and imaging resumes where it stopped.
How Does the Voice Coil Actuator Control Head Positioning?
Two motors sit inside a hard drive and they are not alike. The spindle is a three-phase brushless DC motor, typically 1.5 to 4 ohms phase-to-phase. The voice coil is a single coil, measured across its own pins at a value specific to the drive family rather than the spindle's phase-to-phase range. What restricts the actuator is pivot-bearing friction and the spring tension of the flex cable.
Power loss shows the actuator working at its most decisive. The motor controller harvests back-EMF from the still-spinning spindle and uses it to sweep the head stack to the outer diameter, where the suspension lift tabs ride up a plastic ramp and pull the sliders off the media before aerodynamic flight is lost. That is why "landing zone" is obsolete vocabulary for modern drives, and it is the same geometry a technician has to respect with a ramp tool during a swap.
Head positioning during normal operation is closed-loop against servo information written on the platters at the factory. A donor assembly whose heads cannot resolve that information never gets to the data, which is why servo behaviour is the first thing checked after a transplant and read tests come second.
What Actuator Diagnostics Run Before a Donor Is Opened?
Thermal imaging is a board-side test and only a board-side test. Aluminum is opaque in the infrared, so a FLIR camera cannot see a hot preamp through the drive lid; what it finds is a shorted combo driver, a failed regulator, or a rail pulling current it should not. No thermal camera reads an internal preamp through a sealed head disk assembly, so preamp faults are inferred from behaviour rather than seen.
Resistance measurements come next. The spindle reads roughly 1.5 to 4 ohms phase-to-phase, and the voice coil is measured across its own pins. An open or shorted coil, or a spindle that will not turn, points at the actuator or the motor rather than at the heads, and that changes the whole recovery path.
- Fluid Dynamic Bearing Seizure
- The spindle motor rides on a pressurized oil film rather than ball bearings. The platters never reach operating speed, so the heads never fly. That case calls for a platter transplant into a donor chassis, not a head swap.
- Jammed Actuator Latch
- The latch holds the head stack on the parking ramp with power off. Debris or a deformed crash stop can jam it closed, and the servo then pulses current against a lock. Latch freedom is tested by hand at the clean bench before any donor work starts.
- Voice Coil Short
- A shorted coil makes the combo driver on the board deliver current continuously, heating it fast. Resistance outside the healthy range plus a hot driver under FLIR is the signature. This is board and actuator work, and it happens before any head work.
Platter transplants get much harder on modern high-capacity helium drives. Factory-written servo alignment and the clamping force across a stack of platters lock the rotational phase of every surface. That phase is held mechanically during any transplant, with platter exchangers and edge clamping, and no software measures or corrects it afterward. Head-stack transplants into the patient chassis are the path we take on those drives, because they leave the clamped stack undisturbed.
Which Adaptive Parameter Modules Does Each Hard Drive Vendor Use?
The names differ; the job does not. Both hold data that tunes the read channel and the servo loop for the specific heads installed, and both are read with the vendor-specific PC-3000 utility for that architecture.
| WD ROYL module | Residence | Purpose |
| Module 0A | ROM, shadowed on the platters in Module 102 | Active head map: which logical head reads which physical surface |
| Module 47 | ROM, shadowed on the platters in Module 103 | Servo calibration, per-head microjog tuning |
| Module 02 | Service Area | Configuration: model, serial number, capacity, lock state |
| Module 11 | Service Area | Loader microcode, uploaded into controller RAM when the drive cannot boot its own Service Area |
| Modules 30 and 32 | Service Area | Defect translation and G-list relocation tracking |
| Module 31 | Service Area | The translator, restored through the Dir Editor in the PC-3000 WDC Marvell utility when the Service Area is full of BADs |
Residence drives backup strategy. Structures on the platters can be damaged by a failing head during initialization, which is the case for reading them out before the drive is opened. The serial flash ROM on the board is safer from mechanical damage, but it holds boot code and adaptives rather than the defect lists, so a ROM dump alone never yields the P-List or the G-List.
Which Seagate SysFile Numbers Come Up in Head Swap Recovery?
| System File | Structure | Applies to |
| SysFile 1B | Factory primary defect list, the P-List | Seagate F3 |
| SysFile 28 | Primary translator: forward and reverse LBA-to-physical mapping | Seagate F3 |
| SysFile 35 | Non-Resident G-List | Seagate F3 |
| MCMT | Media Cache Management Table, which tracks sectors held in the conventional media cache before migration into shingled bands | Seagate SMR families |
Getting the vendor right is not pedantry, it is the difference between a repair and a wipe. MCMT expands to Media Cache Management Table and it is Seagate-only. Western Digital's second-level structure is the T2 translator in Module 190. On a Seagate SMR drive the media cache mapping has to be preserved before any translator regeneration runs, because a regeneration that discards it orphans everything still sitting in the cache.
Seagate splits its firmware across the board and the platters the same way Western Digital does, with different names. The SPI ROM on the PCB carries the bootstrap code and the adaptive parameter blocks, RAP, CAP, and SAP, tied to that drive's own heads. The defect lists stay on the platters: SysFile 1B and SysFile 35 live in the Service Area, not in the ROM. That split is why a ROM dump on its own never produces the defect lists, and why heads that cannot read the Service Area block a translator rebuild no matter how healthy the board is.
What Is a BSY State and How Does Translator Corruption Affect Recovery?
The translator is the lookup that converts logical block addresses into physical cylinder, head, and sector. A head crash can damage it, because failing heads generate the read errors that overflow the defect lists behind it. The drive spins up, reports zero capacity or hangs busy, and looks dead to the host.
Firmware repair is attempted before any mechanical work, because a drive whose heads can still read the Service Area does not need a donor at all.
- Terminal access check. PC-3000 connects and attempts terminal communication. A responsive terminal returning damaged data points at firmware rather than at the heads.
- Service Area structure read. The utility reads the defect-management structures for that architecture, Module 30 on WD ROYL drives and the corresponding System Files on Seagate F3. A structure that reads but fails its checksum confirms corruption.
- Defect list extraction. PC-3000 pulls the factory P-List and the grown G-List from the Service Area. Those lists hold the physical sector mapping that translation is rebuilt from, and they live on the platters, not in the board ROM.
- Translator rebuild. The utility regenerates the translation table and writes it back. The drive then reports correct capacity and answers ATA commands.
- Head health verification. After the rebuild, the drive is read-tested across each surface. Heads that resolve servo and return data are healthy and no swap is needed. Heads that cannot are mechanical failures, and a donor assembly is sourced.
Translator corruption with healthy heads needs no head swap. Damaged heads need the swap first and the translator rebuild afterward, because the defect lists the rebuild depends on sit on platters that unreadable heads cannot reach.
How Is Seagate F3 Translation Fork Ambiguity Resolved Manually?
The regeneration command is issued at the F3 T> prompt. It rebuilds the mapping from the defect data, adding defects until translation is consistent. Where an unreadable region has data on both sides of it, the utility cannot infer which way the defective run extends, so it halts and asks for a decision.
Manual Resolution Procedure
- Locate the halt point from the log. The terminal log records the address where regeneration stopped.
- Read the boundary in the sector editor. The technician opens the sector editor at that address and works outward to establish which side of the boundary is actually unreadable. That determines which sectors belong on the defect list.
- Record the bad sectors as defects. The identified sectors are added to the defect list and hidden from the active translation path, which takes them out of translation without discarding the mapping structure underneath.
- Clear the G-List with i4,1,22. Stale entries in SysFile 35 shift the calculation and can produce a false reading at the boundary. The
i4,1,22command clears the G-List. - Re-run the regeneration. With the defect list updated and the Non-Resident G-List cleared, regeneration runs again. If the boundary was the only obstacle, it completes and the drive reports correct capacity.
Seagate F3 Diagnostic Codes Seen During Translator Work
| Code | Meaning | Handling |
LED:000000CC | Init SMART Fail / bad translator: the SMART system file or the primary translator is corrupted, commonly after a power loss. The drive halts busy. | Translator regeneration from the defect lists via PC-3000. |
LED:000000BD | Media cache exception: the MCMT has desynchronized, typically after power loss during a cache flush. | Preserve the media cache mapping before any regeneration runs. |
LED:00000047 | Firmware area locked or MCMT corrupt. | Diagnose in firmware before any generic rebuild command is issued. |
Treating any of these codes as "the drive has bad sectors, run the rebuild" is how SMR drives get destroyed in the diagnostic step. A boundary ambiguity is not a hardware failure either; it is a decision the utility cannot make for itself, and running the automatic command again does not resolve it.
How Does an SMR Translator Rebuild Work After a Head Swap?
The second-level translator is what keeps track of where a given block currently lives.
The order of operations is the part people get wrong. A SATA hardware write blocker stops host write commands and nothing else. It has no effect on the drive's own controller, which keeps running garbage collection while powered. Only a firmware-level write lock commanded through PC-3000 halts that internal activity. The firmware step therefore comes first, and imaging comes after it.
- Firmware write lock on the PC-3000 first. Power the drive on PC-3000 and command the firmware-level write lock, which halts background band rewriting. This happens before any imaging pass starts.
- Read the second-level translator. With internal activity stopped, PC-3000 reads the second-level mapping structure for that architecture: Module 190 on Western Digital. Damaged copies are read from whatever surviving copies the Service Area holds.
- Preserve the media cache mapping before any regeneration. On Seagate SMR drives a generic
m0regeneration wipes the MCMT, and on a drive with data still in the cache that is a destructive command. - Image the drive once translation is stable. Only after the write lock is in place and translation is readable is the drive cloned on PC-3000.
Many high-capacity helium drives are also SMR, and those two problems compound. A head crash on one of them means a helium head swap first, then keeping an unsealed, repressurized drive stable through the long multi-pass SMR imaging that follows. That combination is why helium and SMR jobs are quoted differently from a standard head swap.
What Does LED:000000CC Mean on a Seagate F3 Drive?
LED:000000CC is the Init SMART Fail, or bad translator, condition: the SMART system file or the primary translator is corrupted, most often after a power loss. Initialization halts, the drive reports busy, and it looks dead to the host even though the boot code on the board is intact.The code is a genuine diagnostic output, broadcast over the F3 terminal when firmware panics during initialization. It is not a microcode overlay failure, and it is not a generic way of saying the drive has bad sectors. It points at specific firmware structures in the Service Area.
On a Seagate SMR family the media cache mapping has to survive whatever comes next, so a generic regeneration command is the wrong first move: a generic m0 discards the MCMT along with everything the cache was still holding.
Modern Seagate families also ship with the diagnostic terminal locked. A technician who sends terminal commands and hears nothing back has learned that the terminal is locked, not that the board is dead, and treating that silence as a dead PCB is how recoverable drives get written off.
Why can't you just swap the PCB instead of the heads?
The serial flash ROM on a drive's board holds boot code plus adaptive parameters calibrated to that drive's own heads and platters. Move the board without that data and the controller drives the heads with someone else's calibration, so the drive clicks or reads badly. Transferring the ROM still doesn't help when the heads are the failure, because the heads sit inside the sealed enclosure and the board never touched them.
How long does a head swap take?
Published turnaround for the head swap tier is 4-8 weeks. The mechanical transplant is the short part. Donor sourcing and post-swap imaging dominate the schedule, because damaged platters have to be read slowly and in several passes to pull the most data before the donor heads wear out.
Can you swap heads between different hard drive models?
No. Donor heads have to come from a drive matching on model, firmware family, head count, head map, & the vendor identifiers that track the head stack and preamp build. Manufacturers change head suppliers and preamp revisions inside a single model number, so a mismatched stack fails on servo rather than reading.
Why do head swaps sometimes fail?
Four categories cover most of it. The donor is not electrically compatible, so the heads spin but never find servo. Debris from the original crash is still on the platters and sandblasts the new sliders. The donor heads wear out during a long imaging session on unfamiliar platters. Or the firmware was never aligned to the installed heads.
Why can't you use any donor drive of the same model?
Two drives sharing a model number can be built differently inside. Seagate donor matching aligns the Part Number, the Site Code, & the Date Code. Western Digital uses the Drive Configuration Matrix instead: technicians align the J or 2 anchor character near the end of the DCM string plus the character immediately before it, which is what tracks preamplifier and head stack compatibility. On WD drives the head map in Module 0A and the servo adaptives in Module 47 are read before any mechanical work.
What happens if preamp revisions don't match?
The spindle comes up and the heads load, but the read channel never resolves servo, so the drive sweeps and clicks instead of reporting a usable identity. The preamp is on the head stack flex inside the sealed enclosure, so nothing on the board corrects the mismatch. Compatibility gets settled from label and firmware identifiers before spin-up, not diagnosed after it.
How much does a hard drive head swap cost?
Head swap recovery at Rossmann Repair Group costs $1,200–$1,500 plus donor drive cost. If the platters also have surface damage from a head crash, the price moves to $2,000. No diagnostic fee. The no data, no recovery fee policy applies to all tiers. See our hard drive data recovery pricing for the full breakdown.
Can I swap heads at home with a clean environment?
No. Three things sit outside a home setup: an exact-match donor from the right firmware family and build, PC-3000 firmware alignment after the transplant, and comb or ramp tooling cut for that drive family. A clean bench stops contamination. It doesn't fix a donor mismatch and it doesn't align firmware.
Why does my drive still click after a head swap?
Usually one of four things. The donor isn't electrically compatible with the patient board. Debris left from the original crash has already damaged the new sliders. The firmware adaptives were never aligned to the installed heads. Or the actuator itself has a fault, which is why the voice coil and spindle get checked before a donor is opened rather than after.
Do helium drives need special heads?
Yes. A helium drive's head stack is calibrated for gas roughly one-seventh the density of air, and the air-bearing surface was cut for that lighter gas. An air-drive donor flies at the wrong height in a helium chamber. The chamber matters as much as the parts: the factory seal is laser-welded, a lab refill is temporary, and the patient drive is retired after cloning rather than returned as a working device. We perform helium head swaps in-house at our Austin lab, including helium refill and platter cleaning.
How are helium drives from the CCB generation accessed on PC-3000?
Modern WD and HGST helium-generation drives don't answer the command set PC-3000 uses on older Western Digital families; ACE Lab's designation for that interface is CCB. Our Austin lab runs those drives on a PC-3000 Express, which carries native WD and HGST CCB support. A PC-3000 Portable III or Portable PRO reaches the same families through ACE Lab's separate HGST CCB adapter instead.
Can a preamp chip be replaced instead of swapping the whole head stack?
No. The preamplifier is an analog IC on the head stack flex inside the sealed enclosure, placed close to the heads so microvolt read signals travel as short a path as possible. Reflow deforms the polyimide substrate, changes trace impedance, and sheds particulate onto the platters underneath. A preamp fault is handled as a head stack fault, and the whole donor assembly goes in.
What is a microjog value and why does it affect donor matching?
A microjog is the microscopic offset between the read element and the write element on one head slider, and it varies head to head from manufacturing. On Western Digital ROYL drives those offsets live in Module 47, not in the Module 0A head map.
Drive a head stack with the wrong microjog data and the read element cannot settle on the track center the write element used. The drive clicks, reads fail, and the suspension is at risk of contacting the platter. Aligning that data to the heads actually installed is the whole point of the firmware stage after a swap.
Can firmware repair fix a clicking drive without a head swap?
Only when the fault is firmware rather than mechanical. Corrupted Service Area structures leave a drive sweeping and retrying with healthy heads, and PC-3000 can rebuild the translator and restore modules with the enclosure closed.
Damaged heads can't be repaired that way. We separate the two with PC-3000 diagnostics and FLIR thermal imaging of the exposed board before choosing a path, because acoustics on their own don't identify a root cause.
Why do donor heads degrade during imaging on patient platters?
Donor heads were calibrated for the donor's platters. Patient platters have different surface roughness, different overcoat thickness, and different written magnetization, so the slider rides differently than it was designed to.
Over a long imaging session the air bearing degrades, damaged areas shock the suspension, and read margins fall. Labs manage that with rest periods between passes and by keeping more than one compatible donor set on hand, so a fresh assembly can go in when the first one drops below usable margins.
What causes repetitive actuator clicking?
Repetitive clicking is the actuator sweeping and striking its crash stop or parking ramp because the heads aren't resolving servo information from the platter. A healthy drive reads servo wedges silently on power-up. The cause underneath can be damaged heads, a failed preamp, a board fault, or corrupted firmware, and those get separated with instruments rather than by ear.
Can a single failed head be replaced without swapping the entire stack?
No. The head stack assembly is one mechanical unit: every head sits on a common actuator arm & shares one flex cable to the preamplifier. When heads are replaced, the whole assembly is replaced with a donor, and PC-3000 then disables any donor head that reads poorly in the logical head map so imaging proceeds on the healthy surfaces first. Only when the platters are badly damaged do we sometimes, instead of a swap, cut the failed head from the head stack and hex edit the head map in the ROM. The drive can then be imaged on its remaining heads first.
What is the difference between a head swap and a platter transplant?
A head swap replaces the head stack assembly and leaves the platters in the patient chassis. A platter transplant moves the platters into a donor chassis, which is what a seized spindle motor calls for. Transplants are far more invasive: rotational phase across the stack is held mechanically during the transfer, with platter exchangers and edge clamping, and no software measures or corrects it afterward. On modern high-capacity helium drives, where factory servo phase is locked across a clamped stack of platters, a head-stack transplant is the path we take instead.
Why can't the original heads be repaired instead of replaced?
Read/write heads aren't repairable at the component level. The slider is a ceramic block with thin-film elements deposited at its trailing edge at sub-micron scale, and a crashed head has a damaged air-bearing surface, a burned read element, or an open trace. The suspension, flex, & preamplifier are one factory assembly. When a head fails, the assembly is discarded and a donor assembly goes in.
How do technicians verify donor heads are reading correctly after a swap?
The drive comes up on PC-3000 rather than on a host machine. What has to happen first is basic: the spindle reaches speed, the heads load, and the firmware resolves servo well enough to report a real identity and capacity. From there the technician runs read tests across each surface. A donor head that reads poorly is disabled in the logical head map, and imaging on PC-3000 starts on the surfaces that passed.
Should I use plastic or metal head combs?
Parking architecture decides, not preference. Contact start/stop drives, including Seagate U Series and Barracuda through the 7200.12 generation, rest their heads on a landing zone and accept plastic separator combs. Later Barracuda generations and Western Digital and Toshiba drives from roughly 2008 park on a ramp at the outer diameter and need a metal ramp tool cut for that family. A plastic comb on a ramp-parked drive tears the suspension tongues on the first extraction.
Do head combs stay inside the drive during imaging?
No. A comb or ramp tool is an insertion and extraction fixture. It holds the sliders apart while the head stack is lifted out or lowered in, then comes back out before the lid is reseated. Nothing holds or repositions the heads once the platters spin, so no fixture can carry heads over a scored region of a running drive.
What is a BSY state and how does it affect head swap recovery?
Translator corruption is the cause we diagnose most often at the Austin lab: the firmware can't map logical block addresses to physical sectors, so initialization hangs. With physically healthy heads, PC-3000 rebuilds translation from the defect lists without opening the drive. With damaged heads the rebuild can't run at all, because those defect lists live in the Service Area on the platters.
Can a head swap fix a drive that shows 0 bytes capacity?
A drive reporting zero capacity has either translator corruption or damaged heads, and PC-3000 tells the two apart. Healthy heads with a rebuildable translator need no mechanical work. Damaged heads that can't read the Service Area defect lists need a donor assembly first, with the translator rebuild following. The head swap alone doesn't restore capacity.
What is translation fork ambiguity on Seagate F3 drives?
During translator regeneration on a Seagate F3 drive, the utility stops when readable data sits on both sides of an unreadable boundary and the direction of the defective run is undetermined. A technician resolves it by hand: identify which side is unreadable in the sector editor, add those sectors to the defect list, hide them from the active translation path, clear the G-List with the i4,1,22 command, then re-run the regeneration.
Can I do a head swap in a bathroom with the shower running?
No. Bathroom humidity condenses on cold platter surfaces the moment the lid comes off, and that condensation traps airborne particulate against the magnetic layer. The embedded debris then destroys donor heads on first contact. Open-platter work belongs in a ULPA-filtered laminar flow bench, where filtered air moves across the drive cavity in one direction for the minutes the lid is off.
Will freezing the drive before a head swap help?
Freezing makes the job harder and can end it. A frozen drive condenses water on the platters as it warms, and that water mixes with crash debris into a slurry that scores the magnetic layer. Cold platters also raise the risk of stiction tearing suspension tongues on spin-up. The freezer idea came from forum posts rather than from drive engineering.
Should I run CHKDSK on a clicking drive before sending it in?
No. CHKDSK works through standard ATA commands at the logical block level and can't reach or overwrite the firmware translator, so the damage it does is mechanical rather than logical. Forcing a scan across failing media makes weak heads re-seek over damaged areas thousands of times, which exhausts them and scores the platters. On a clicking drive the right move is to remove power and stop.
Can I reuse donor heads after one swap?
No. Every transplant disturbs suspension alignment and the air-bearing surface, and a set that has already flown over one patient's platters is no longer at factory geometry. Reusing it on a second drive risks an immediate crash. Donor sets are treated as consumed, which is why donor cost is quoted separately from labor.
Why does the drive need PC-3000 after the physical swap is done?
The transplant installs hardware; it changes nothing in firmware. The drive still holds head-specific adaptive parameters, a head map, and translator tables built around the heads that failed. PC-3000 aligns the adaptives to the heads actually installed, edits the logical head map to disable a weak donor head, and rebuilds the translator when the Service Area was corrupted. Skip that and the drive clicks or returns garbage while the donor heads spin.
Is a head swap the same as a PCB swap?
No. A PCB swap replaces the external board and leaves the head stack alone. A head swap replaces the internal assembly and keeps the original board, which carries the drive's own ROM. They address different failures: a board swap is for a failed motor driver, interface, or regulator, while a head swap is for failed heads, a failed preamp, or a damaged flex inside the enclosure. A surge that killed the board and stressed the preamp can call for both.
What is a fluid dynamic bearing seizure?
A fluid dynamic bearing seizure is a motor problem: the platters never reach operating speed and the heads never fly. A seized spindle is platter transplant territory, and it gets diagnosed with resistance and current measurements rather than by sound.
Can a voice coil motor be repaired without replacing the entire actuator?
Only in narrow cases, such as replacing a deformed crash stop. Rewinding a voice coil isn't a data recovery procedure; an open or shorted coil means the actuator assembly is replaced. At our Austin lab we check the voice coil and the spindle with multimeter resistance measurements and inspect the exposed board with FLIR thermal imaging before deciding between repair and replacement.
Why does the VCM driver IC overheat on some clicking drives?
The combo driver on the PCB feeds both the spindle and the voice coil. A shorted coil or a seized pivot makes it hold current it can't dissipate, and it heats fast. FLIR thermal imaging finds that on the exposed board, since the aluminum lid is opaque in the infrared and hides everything inside. A drive with that fault destroys a donor head stack on first spin-up, so the board and actuator get cleared before any donor is opened.
Can a head swap fix bad sectors?
No. Bad sectors are a physical condition of the media or the heads, never a file-system problem, and replacing heads doesn't restore magnetic material that a crash removed. Donor heads read whatever surface is still coated, so a drive with a scored band often images everything outside that band. The scored tracks stay unreadable and get mapped as permanent defects.
Do all heads in a drive fail at the same time?
No. One or two heads usually fail first while the rest keep reading. That still endangers everything, because debris from the first crash circulates and reaches the other surfaces. A drive with a failed head goes to the clean bench for mechanical work before any imaging. Only when the platters are badly damaged do we sometimes cut the failed head from the head stack and hex edit the head map in the ROM, so the drive can be imaged on its remaining heads first.
Why is a hard drive head swap so expensive?
A head swap consumes a matched donor drive, occupies a ULPA-filtered clean bench, and then needs firmware alignment on PC-3000 before a single sector is imaged. Imaging itself runs slow and long, because the donor heads are working on platters they were never calibrated for. At Rossmann Repair Group the labor and tooling are priced at $1,200–$1,500, plus the donor drive. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
