Enterprise Virtualization Recovery
Microsoft Hyper-V Data Recovery
We recover VHD/VHDX virtual disks from failed RAID arrays, repair broken checkpoint chains, reconstruct Cluster Shared Volumes, and extract VMs from corrupted Hyper-V hosts. Free evaluation. No data = no charge.
14 min read
Overview
How Hyper-V Environments Fail and How We Recover Them
Microsoft Hyper-V stores virtual machines as VHD or VHDX files on NTFS or ReFS volumes, often backed by RAID arrays or SAN LUNs. When the underlying storage fails, the Hyper-V host loses access to the virtual disks and all VMs on that volume go offline. Recovery requires imaging the physical drives, reconstructing the RAID array offline, parsing the host filesystem, and extracting each .vhdx file individually.
VHDX replaced VHD in Windows Server 2012 as the default virtual disk format. It supports up to 64TB per file, carries a log region for crash consistency, and can be either fixed-size or dynamically expanding.
Checkpoints (formerly "snapshots") create .avhdx differencing disks that track block-level changes relative to a parent. Cluster Shared Volumes (CSV) extend the storage model to failover clusters, allowing multiple Hyper-V hosts to access the same LUN simultaneously.
VHDX On-Disk Structure
VHDX On-Disk Structure and Failure Points
VHDX begins with the 8-byte "vhdxfile" file type identifier at offset 0, followed by two header copies at 64KB and 128KB, a region table at 192KB, a log region the header points to, the BAT (Block Allocation Table), and a metadata region with parent locators. Storage-layer corruption of any of these renders the file unmountable, and recovery parses each structure directly from the raw image.
Understanding the VHDX binary layout is required for targeted recovery. The format was designed for resilience, but storage-layer failures can still render files unreadable.
VHDX Header and Metadata
  • The 8-byte "vhdxfile" file type identifier sits at offset 0; two header copies live at offsets 64KB and 128KB for redundancy
  • Region table at offset 192KB describes the location of the BAT (Block Allocation Table) and metadata regions within the file
  • BAT maps each virtual disk block to its physical offset in the VHDX file; for dynamic disks, unallocated blocks have a BAT entry state of PAYLOAD_BLOCK_NOT_PRESENT
  • Log region is MB-aligned and can sit anywhere after the header section, so its position is read from the header rather than assumed; it records pending metadata updates, and Hyper-V replays it on mount to ensure consistency
  • Metadata region stores virtual disk size, logical/physical sector size, payload block size (configurable 1MB to 256MB, 32MB default), and parent locator for differencing disks
Differencing Disks
  • Each checkpoint creates an .avhdx file that becomes the active write target; the parent .vhdx becomes read-only
  • .avhdx files use the same VHDX format but with a parent locator in the metadata region pointing to the parent file by path and unique ID
  • Block-level change tracking: only modified blocks have BAT entries; reads for unmodified blocks are passed through to the parent
  • Merge operation (checkpoint deletion) copies changed blocks from the .avhdx into the parent; power loss during merge can leave both files in an inconsistent state
  • Deep checkpoint chains (5+ levels) increase fragmentation and I/O latency; failed merges at any level can strand the entire chain
The BAT holds two entry types for dynamic and differencing disks: payload BAT entries and sector bitmap BAT entries. Each payload entry carries one of three states. PAYLOAD_BLOCK_NOT_PRESENT means the block was never written and reads pass through to the parent (or return zeros for a base disk).
PAYLOAD_BLOCK_FULLY_PRESENT means every sector in the block lives in this file. PAYLOAD_BLOCK_PARTIALLY_PRESENT means only some sectors are present, and the associated sector bitmap block decides which sectors come from this file versus the parent. Misreading these states during extraction silently returns stale parent data, so we resolve every partially present block against its bitmap before writing output.
When a RAID failure corrupts the NTFS volume hosting the VHDX files, the Hyper-V host cannot read the VHDX headers, BAT, or log region. Standard Hyper-V tools (Inspect-VHD, Merge-VHD) require a mounted volume and operate strictly offline against an unattached disk chain. Running them against a live degraded array, or while the underlying storage is still failing, causes large-scale logical damage.
Our approach bypasses the host entirely: we parse VHDX structures from the raw RAID image and extract virtual disks by resolving BAT entries against their sector bitmaps.
# Merge-VHD is an OFFLINE operation. The chain must be unattached,
# and it must run against verified copies, never the live array.
# Inspect the chain first, then merge a checkpoint into its parent:
Inspect-VHD -Path D:\copies\vm01\disk0.avhdx
Merge-VHD -Path D:\copies\vm01\disk0.avhdx -DestinationPath D:\copies\vm01\disk0.vhdx
Generation 1 vs Generation 2
How Does Hyper-V VM Generation (Gen 1 vs Gen 2) Affect VHDX Recovery?
The generation changes only how the guest reaches its disk. Gen 1 boots an emulated legacy IDE controller under BIOS firmware; Gen 2 uses synthetic SCSI exclusively under UEFI. The VHDX container is unchanged: the BAT and sector bitmap are byte-for-byte identical, so raw-image VHDX extraction is generation-independent.
Administrators often assume a Gen 2 VM stores its disk differently from a Gen 1 VM. It does not.
Generation is a property of the virtual machine platform, not of the VHDX file. It selects the guest firmware and the boot controller the guest sees at runtime, and it has no effect on the on-disk container that holds the data.
GenerationFirmwareBoot controllerVirtual disk formatHow the guest reaches the boot disk
Generation 1BIOSEmulated legacy IDE for the boot diskVHD or VHDXThe guest sees an emulated legacy IDE controller for its boot disk; non-boot data disks can be presented over synthetic SCSI.
Generation 2UEFI (adds an EFI System Partition)Synthetic SCSI only; no IDE emulationVHDX onlyThe guest reaches every disk through the synthetic SCSI VMBus path, with the VSP in the parent partition and the VSC in the guest.
Generation 1 (BIOS, IDE boot)
  • BIOS firmware with an emulated legacy IDE controller for the boot disk; Gen 1 can also attach non-boot data disks over synthetic SCSI
  • Supports both the older fixed VHD format and VHDX, so a Gen 1 VM may hold a legacy .vhd we still parse header and BAT for
  • IDE emulation is a presentation layer for the guest; it does not fix or simplify where the VHDX BAT allocates host blocks, which stays dynamic
Generation 2 (UEFI, synthetic SCSI)
  • UEFI firmware adds an EFI System Partition (ESP) inside the boot VHDX that holds the boot loader; there is no IDE emulation at all
  • VHDX format exclusively; a Gen 2 VM cannot use the older fixed VHD container
  • A damaged ESP stops the VM from booting but is separate from the data VHDX payload, which stays fully recoverable through offline extraction
Recovery never boots the guest, so the synthetic-SCSI-versus-IDE distinction does not gate extraction. We parse the VHDX header, walk the region table to the BAT, and resolve every block against its sector bitmap directly from the raw image. That sequence is identical for a Gen 1 and a Gen 2 disk because the container is identical.
For read-only inspection of an extracted copy we mount it with Mount-VHD -ReadOnly, which attaches the file without exposing it to guest firmware at all.
A Gen 2 VM that will not power on because its EFI System Partition is damaged still has a fully readable data VHDX; the boot failure and the data payload are separate problems. When the disk lives on a hardware controller, the same on-disk metadata parse we use for any failed parity array reconstructs the geometry before the VHDX is touched. The broader intake path for a dead hypervisor host is covered on our enterprise server recovery overview.
A guest-side storage-path fault is a host problem to chase, not a reason to touch the VHDX: the container on disk is unaffected by what the running guest can or cannot see. When the underlying pool is a Windows software stack we handle it through Storage Spaces pool reconstruction, and the container extraction itself follows the same steps as any virtual disk image recovery job regardless of generation.
ReFS-Hosted VHDX and S2D
Why Does ReFS Metadata Corruption Make a VHDX File Unreadable When the Data Survives?
ReFS stores every VHDX as a file referenced through B+ tree metadata, so a damaged object table or a failed metadata checksum drops the VHDX out of the namespace even though its data extents physically survive on the storage media. The checksum tells you which blocks are valid; it does not repair anything once the volume is unmountable. Recovery parses the ReFS metadata offline rather than trusting the host to mount it.
Hyper-V on Windows Server 2016 and later commonly hosts VHDX files on ReFS rather than NTFS, and on hyper-converged clusters that ReFS volume sits on top of a Storage Spaces Direct (S2D) pool. The VHDX recovery problem becomes layered: the VHDX is a file inside a ReFS namespace, and that ReFS namespace is a virtual disk carved out of a pool that spans drives across multiple nodes.
A failure at any layer hides the VHDX, and the recovery order has to run from the lowest layer up. The deeper ReFS internals are documented on our ReFS metadata reconstruction page; this section covers how those internals gate VHDX extraction.
Integrity Streams and Checksums
  • ReFS metadata pages are always checksummed; data blocks carry CRC-64 checksums only when integrity streams are enabled on the file or directory
  • On a mirrored Storage Spaces volume, ReFS auto-repairs a bad block from the redundant copy during normal operation; a checksum mismatch with no surviving copy isolates the block instead of repairing it
  • A metadata checksum failure on a structure that maps a VHDX renders the whole VHDX unreadable to the host even when the underlying data extents are physically intact on the media
  • Once the volume is unmountable, integrity stream checksums only let us confirm which recovered blocks are valid; they perform no repair on their own
Object Table Corruption
  • The ReFS object table is the root B+ tree of the volume, the ReFS equivalent of the NTFS Master File Table; every file reference resolves through it
  • A damaged object table drops file references, including multi-terabyte VHDX files, out of the namespace while the data extents themselves survive on disk
  • Because ReFS is allocate-on-write, historical object-table checkpoints often survive in unallocated space and give us a rollback path to rebuild the namespace
  • Recovery parses the B+ trees offline and can fall back to those earlier object-table versions to re-expose the VHDX entries the live root no longer indexes
ReFS does not use NTFS-style chkdsk. It relies on allocate-on-write metadata and an online salvage and integrity scanner that removes corrupt references to keep a volume mounted, which is permanent loss of those references. Running chkdsk against a ReFS volume is inappropriate and can make recovery harder; it is an NTFS repair tool with no valid role on ReFS.
If you are unsure, image the drives and parse the metadata offline before any host-side repair runs. The same chkdsk myth that damages failing NTFS drives applies with even less margin on ReFS.
How Does Storage Spaces Direct Sit Under the ReFS Volume?
Storage Spaces Direct aggregates the local drives across cluster nodes into a single storage pool, layers virtual disks with mirror or parity resiliency on top of that pool, and formats those virtual disks with ReFS for the Cluster Shared Volumes that host the VHDX files. The pool metadata lives on the drives themselves, on a subset of drives per node that the pool selects to host it, not in any single controller.
Quorum loss, a majority-node failure, or a breach of the resiliency floor takes the pool offline, which removes the virtual disks and the ReFS CSVs hosting the VHDX files from the namespace. The drives still hold the data; the pool layer simply refuses to expose it. S2D is an availability design, not a backup; it replicates a logical corruption or a deletion the same way a RAID set does.
VHDX recovery from an S2D pool runs bottom-up. The pool and virtual-disk layer is reconstructed first, then the ReFS volume is parsed, then the VHDX BAT is resolved. The imaging hardware reads the member drives; the pool assembly, ReFS parse, and VHDX resolution are software steps performed against the images, never against the live members.
  1. Reassemble the S2D pool geometry. Parse the pool metadata off the drive images that carry it to rebuild the slab-to-node mapping and virtual-disk layout in software.
  2. Reconstruct the virtual disks. Assemble each mirror or parity virtual disk from the raw drive images using the parsed pool metadata.
  3. Parse the ReFS object table and B+ trees. Read the checkpoint areas, walk the object table, and fall back to historical checkpoints in unallocated space if the live root is damaged.
  4. Resolve the VHDX BAT. Locate each .vhdx and .avhdx on the reconstructed ReFS volume and resolve its Block Allocation Table against the sector bitmaps to extract the virtual disk.
Cluster Shared Volume Recovery
How Is Data Recovered from a Failed Cluster Shared Volume?
Cluster Shared Volumes let multiple Hyper-V hosts in a Windows failover cluster access the same volume simultaneously. One node at a time, the coordinator node, owns the physical disk resource behind the LUN and handles metadata changes. When the underlying storage fails, the CSV coordination layer is irrelevant; recovery targets the NTFS or ReFS filesystem and the VHDX files directly from the raw array image.
  • NTFS underneath (direct I/O): CSV on NTFS uses standard NTFS on the SAN LUN or RAID volume. Each node communicates directly with the storage for data I/O, while the coordinator node that owns the disk resource handles metadata-changing operations. The actual file storage is plain NTFS, so once we have the raw RAID image we parse NTFS normally and follow each VHDX run list.
  • ReFS on Server 2016+ (redirected I/O): Windows Server 2016 and later support ReFS for CSV volumes, but ReFS on CSV runs in file-system redirected I/O mode, routing data through the coordinator node rather than direct SAN access. ReFS uses checksummed B+ tree metadata and allocator-based data placement, and ReFS block cloning accelerates checkpoint merges. Storage Spaces Direct (S2D) builds on this same ReFS block cloning. Our tooling parses both NTFS and ReFS volumes from raw images.
  • Redirected I/O fallback: When a CSV owner node loses direct SAN access, other nodes fall back to redirected I/O over the cluster network. If multiple nodes lose storage access simultaneously, all VMs on the CSV go offline. The data is still on the physical drives; the CSV coordination failure is a software problem, not a storage problem. A CSV failure does not mean the data is gone. Where the CSV is backed by an iSCSI LUN published from network-attached storage, the recovery starts at that backing storage: rebuild it first, and the VHDX files come back with it.
Hyper-V Replica Failure Scenarios
Hyper-V Replica asynchronously copies VM changes to a secondary host on a replication cycle you choose when you enable it. Replica is availability, not a backup: it tracks the primary and replays the same corruption or deletion, and it can diverge if replication falls behind. When both sites suffer storage failures, we recover from whichever site holds the most recent consistent data.
Hyper-V Replica asynchronously replicates VM changes to a secondary host. Replica is not a backup; it creates a point-in-time copy that can diverge from the primary if replication falls behind, and it will faithfully replicate a logical corruption or an accidental deletion to the secondary. When both the primary and replica sites experience storage failures, we recover from whichever site has the most recent consistent data.
Primary Site Failure
Primary host RAID fails. The replica site has a copy that is current as of the last replication cycle. We recover from the replica VHDX files, which are missing whatever was written after that cycle.
Both Sites Failed
Both primary and replica storage failed (ransomware, site-wide power event, or cascading RAID failures). We image drives from both sites and compare the VHDX timestamps to determine which copy has the most recent consistent data. Partial recovery from both copies may yield a more complete dataset.
Controller Cache and AVHDX Chain
How Does Lost RAID Controller Write-Back Cache Corrupt a VHDX That Still Mounts?
Lost write-back cache corrupts a mountable VHDX when acknowledged writes never reach the member drives. A controller acknowledges a host write once it lands in DRAM cache; if that dirty cache is discarded before destaging, the VHDX still parses while specific LBA ranges read back stale.
A hardware RAID controller acknowledges a host write the moment it lands in its write-back DRAM cache, before the data is destaged to the member drives. Enterprise cache protection prevents loss from that window by design.
HP Smart Array Flash-Backed Write Cache (FBWC) flushes the volatile DRAM cache into an onboard non-volatile NAND flash module on power loss, then replays it on restore, drawing on a backup power source for the duration of that flush. Dell PERC Non-Volatile Cache performs the same flush powered by a lithium-ion battery.
These are backup-power and NAND modules, not NVMe devices. A healthy module loses nothing on a routine power event.
Loss occurs only when that protection is degraded, bypassed, or thrown away. Three vectors account for the acknowledged-but-lost writes that sit beneath a Hyper-V volume.
  • Degraded or failed cache backup unit: when the supercapacitor or battery degrades and fails, the controller disables write caching and keeps read acceleration enabled, which is the safe default rather than a loss event on its own.
  • Forced write-back without protection: if an operator forces write-back caching with no functional capacitor, or enables physical-drive write cache, acknowledged writes are exposed to permanent loss on a power failure.
  • Discarded preserved cache: when a Dell PERC or Broadcom MegaRAID virtual disk goes offline or member disks go missing, the controller retains the dirty acknowledged-but-not-destaged cache as preserved or pinned cache. On reboot and import it normally auto-flushes to the members, but if an operator manually discards the preserved cache through the controller interface, those writes are permanently lost and never reach the disks.
Because the guest OS already received write acknowledgment, lost or discarded dirty cache leaves stale or inconsistent on-disk LBA ranges beneath the VHDX. The VHDX header, region table, and BAT can all parse cleanly while the payload at specific offsets reads back a previous generation, so the file appears mountable while individual blocks are stale.
Why Does a Hyper-V Checkpoint Show Read Errors for Blocks It Never Wrote?
A checkpoint returns read errors for blocks it never wrote because an AVHDX differencing disk inherits unmodified blocks from its parent VHDX. As described in the VHDX on-disk structure section above, the AVHDX BAT marks every block it did not change PAYLOAD_BLOCK_NOT_PRESENT and reads it through to the parent. If an underlying RAID partial-sector failure corrupts specific parent VHDX payload block offsets, the checkpoint cannot return data it never stored, and the read fails at an address the differencing disk never wrote itself.
The corrupted offsets map back to physical stripes. HP Smart Array arrays default to a 256KB stripe, and Dell PERC defaults range from 64KB on PERC 9 and earlier to 256KB on PERC 10 and later, so a single damaged stripe can span a contiguous run of inherited payload blocks across the parent. Recovery traces each corrupted LBA range through every AVHDX BAT in the checkpoint chain and classifies each block as inherited from the parent, which requires parent VHDX repair, or overridden in the differencing disk's own BAT, which is recoverable directly from the AVHDX.
The PC-3000 Express reads the member drives; Data Extractor Express RAID Edition destripes those images and resolves the checkpoint chain in software, never against the live members. This keeps the corrupted parent stripes isolated to the blocks that actually depend on them rather than failing the entire chain.
What Does a VSS Hardware Provider Timeout Tell You About the RAID Array Underneath?
A VSS hardware provider timeout tells you the storage path under the Hyper-V host is unstable, not that a file is corrupt. The Volume Shadow Copy Service coordinates three roles for every snapshot: the requestor is the backup application that asks for the shadow copy, the writer is the application component such as the Hyper-V VSS writer that quiesces its data so the copy is consistent, and the provider is what actually creates and holds the shadow copy.
The default Windows system software provider does volume-level copy-on-write in the host. A hardware provider is different: it is a storage-array or controller-integrated plug-in that offloads snapshot creation down to the storage layer itself.
When a hardware provider times out or crashes partway through creating a snapshot, the guest VHDX or AVHDX can be left in an uncommitted, inconsistent state. That inconsistency lives beneath the file layer, in the same acknowledged-but-not-reconciled storage state as the discarded write-back cache described above: the members hold bytes that do not match what the host was told is committed.
In-place tools run at the wrong layer for this. A guest-side chkdsk and a host-side DISM operate on the filesystem and the VHDX as a file, and neither can reconcile a stripe that the array never destaged.
The provider that failed tells you where to look. Read the VSS-source log first: open Windows Event Viewer, then Windows Logs, then Application, and filter for the Volume Shadow Copy Service source. The VSS-source errors logged there record failures in the snapshot path and identify which provider was in play. Event ID 8193 and Event ID 12289 both land in that log as VSS-source errors, and the body of each one names the writer it came from.
  • Hardware provider failure: a timeout or fault reported from the storage layer. It implicates the RAID controller and the I/O path to the members, because the snapshot work was pushed down to that storage layer and did not return in time.
  • Software provider or writer failure: a host-side crash in the system software provider or an application VSS writer. It runs in the host, is independent of the storage path, and does not implicate the array on its own.
A hardware-provider error during a routine backup job, on a host whose VMs live on a RAID array, is an early warning that a member has path instability. It is a reason to image the array offline, member by member, rather than trust an in-place controller rebuild. A rebuild started against a member that is dropping off the I/O path can read a stale stripe as good and propagate it into parity, which converts a recoverable inconsistency into a spread one.
We image each member with the PC-3000 Express, which holds slow or unstable drives on the imaging path instead of ejecting them, then reassemble the array from those images with Data Extractor Express RAID Edition. The geometry is rebuilt in software against the images, so a member with path instability is never asked to serve a live rebuild.
Methodology
Recovery Methodology for IT Administrators
Every member drive and every CSV or SAN LUN is cloned through a write-blocked imager before anything is parsed. The array geometry is then reconstructed virtually in software against the image files, the host filesystem is parsed, and each VHDX is extracted by resolving its BAT. No vendor repair tool ever touches the live degraded array.
Step-by-step procedures for Hyper-V environment recovery. If you are evaluating our technical capability, this is how the work gets done.
  1. Image first, against copies only. Clone every member drive and every CSV or SAN LUN through a hardware write-blocker (ddrescue, PC-3000 Portable III, or PC-3000 Express) before any parse. Never run vendor repair (Merge-VHD, chkdsk, or a controller "rebuild") against the live degraded array. A rebuild pins every surviving member at close to 100% sustained read for as long as it runs, and a marginal same-batch survivor can fail mechanically in that window; a survivor can also surface a latent unrecoverable read error, which a legacy controller treats as a second failure while modern PERC and MegaRAID puncture the stripe and continue. For irreplaceable, unbacked data on a degraded RAID 5 above 24TB we do not gamble on a live rebuild: each member is imaged member-by-member through a write-blocked interface first.
  2. Reconstruct the array virtually. Parse the on-disk controller metadata from the image files and reconstruct stripe size, member order, and parity rotation in software, never against the live members.
  3. Parse the host filesystem. Read the NTFS or ReFS volume from the reconstructed image and locate every .vhdx, .avhdx, .vmcx, and .vmrs file.
  4. Extract and consolidate. Resolve each VHDX BAT against its sector bitmaps, walk the .avhdx parent locators in creation order, and consolidate the chain into a flat VHDX at the most recent consistent state.
1. Storage Layer Imaging
A drive with a failed head goes to the clean bench for mechanical work before any imaging.
2. RAID Reconstruction
If the Hyper-V host uses a hardware RAID controller (Dell PERC, HP Smart Array, LSI MegaRAID), the structural metadata lives on the member drives, not in the controller NVRAM.
We parse that on-disk metadata from the drive images with array-aware forensic software and reconstruct stripe size, member ordering, parity rotation, and RAID level virtually, without needing the original controller hardware. For Storage Spaces Direct (S2D) or software RAID, we parse the Windows Storage Spaces metadata from the drive images.
3. NTFS/ReFS Parsing and VHDX Extraction
With the RAID image reconstructed, we parse the NTFS or ReFS volume to locate .vhdx, .avhdx, .vmcx (VM configuration), and .vmrs (runtime state) files. Each VHDX is extracted by reading its BAT and following the block offsets to their physical locations in the volume. For dynamically expanding disks, only allocated blocks are present in the file.
4. Checkpoint Consolidation
If the VM has checkpoints, we reconstruct the .avhdx chain by reading each differencing disk's parent locator metadata. Changed blocks from each .avhdx are applied in sequence to the base .vhdx.
If a merge was in progress when the failure occurred, we determine the merge progress from the BAT state and complete the consolidation manually. The output is a single flat VHDX representing the VM at its most recent consistent state.
Hyper-V Terminology
Hyper-V and VHDX Terminology
These terms describe the on-disk structures and operations that determine whether a failed Hyper-V environment is recoverable and how the work is scoped.
VHDX (Virtual Hard Disk v2)
The default Hyper-V virtual disk format since Windows Server 2012. The BAT (Block Allocation Table) maps virtual blocks to physical offsets, the payload block size is configurable from 1MB to 256MB (32MB default), the log region is MB-aligned and located through the header, and the region table at 192KB locates the BAT and metadata.
AVHDX (differencing / checkpoint disk)
A differencing disk created when a checkpoint is taken. The .avhdx becomes the active write target and uses a parent locator in its metadata region to point at the parent .vhdx by path and unique ID. Only changed blocks carry payload BAT entries; everything else reads through to the parent.
Broken checkpoint merge chain
A merge consolidates an .avhdx into its parent. Merge-VHD is strictly an offline operation that requires the disk chain to be unattached, run against verified copies. A power loss mid-merge, or running Merge-VHD against a live degraded array, leaves both files inconsistent and can cause large-scale logical damage.
Cluster Shared Volume (CSV)
A volume that multiple failover-cluster nodes access at once. CSV on NTFS uses direct I/O to the SAN for data, with the coordinator node that owns the disk resource handling metadata changes. CSV on ReFS runs in redirected I/O mode, routing data through the coordinator node.
Hyper-V Replica
Asynchronous VM replication to a secondary host on a configured replication cycle. It is an availability feature, not a backup: it replays the same corruption or deletion to the replica and can diverge from the primary when replication falls behind.
Fixed vs dynamic vs differencing disks
A fixed VHDX preallocates its full size on creation. A dynamic VHDX grows on demand and marks unwritten blocks PAYLOAD_BLOCK_NOT_PRESENT. A differencing VHDX (.avhdx) stores only deltas relative to a parent and depends on the parent locator chain to read unchanged data.
ReFS object table
The root B+ tree of a ReFS volume, the ReFS equivalent of the NTFS Master File Table. Every file reference, including each VHDX, resolves through it. A damaged object table drops those references out of the namespace while the data extents survive on disk; allocate-on-write leaves historical object-table checkpoints in unallocated space that recovery can roll back to.
ReFS integrity stream
The optional per-block CRC-64 checksum mode on ReFS data. Metadata is always checksummed; data blocks are checksummed only when integrity streams are enabled. On a mirrored Storage Spaces volume ReFS auto-repairs a bad block from the redundant copy, but once the volume is unmountable the checksum only marks which blocks are valid and repairs nothing on its own.
A pool that aggregates local drives across cluster nodes, layers mirror or parity virtual disks on top, and formats them with ReFS for Cluster Shared Volumes. Pool metadata lives on a subset of drives per node that the pool selects to host it. Quorum loss, majority-node failure, or a resiliency-floor breach takes the pool offline and removes the ReFS CSVs hosting the VHDX files from the namespace.
How Much Does Hyper-V Recovery Cost?
Hyper-V recovery follows the same transparent pricing model as every other service: per-drive imaging based on each drive's condition, plus a $400-$800 reconstruction fee that includes RAID rebuild, NTFS/ReFS parsing, and VHDX extraction. No data recovered means no charge.
Service TierPrice Range (Per Drive)Description
Logical / Firmware Imaging$250-$900Firmware module damage, SMART threshold failures, or filesystem corruption on individual array members.
Mechanical (Head Swap / Motor)$1,200-$1,50050% depositDonor parts consumed during transplant. SAS drives require SAS-specific donors matched by model, firmware revision, and head count.
Reconstruction + VHDX Extraction$400-$800per arrayRAID reconstruction, NTFS/ReFS parsing, VHDX extraction, and checkpoint chain consolidation if applicable.
No Data = No Charge: If we recover nothing from your Hyper-V environment, you owe $0. Free evaluation, no obligation.
Our pricing is published up front. The tiers above are the whole quote: no diagnostic fee, and no separate charge for an attempt that recovers nothing.
Hyper-V Recovery; Common Questions
What causes VHDX file corruption and can it be recovered?
VHDX files carry a dedicated log region for crash consistency, MB-aligned and located by a pointer in the file header rather than at a fixed offset. Power loss during a metadata commit can leave an incomplete log entry. If the log replay fails on Hyper-V startup, the VHDX becomes unmountable. Recovery involves parsing the VHDX header, BAT (Block Allocation Table), and log entries from the raw disk image, then reconstructing a consistent virtual disk from the committed log entries.
How do you recover data from a failed Cluster Shared Volume?
Cluster Shared Volumes (CSV) use NTFS on the underlying storage with a coordination layer across Windows failover cluster nodes. When the underlying RAID array or SAN LUN fails, the CSV goes offline and all VMs on that volume are stopped. Recovery does not depend on the cluster coordination metadata. We image the underlying physical drives, reconstruct the RAID array, parse the NTFS filesystem, and extract the .vhdx files for each VM.
Can you fix a broken Hyper-V checkpoint chain?
Yes. Hyper-V checkpoints create .avhdx (Auto VHDX) differencing disks. Each .avhdx contains a BAT (Block Allocation Table) mapping changed blocks relative to its parent. When a checkpoint merge fails or the chain references are corrupted, the VM cannot start. We read the BAT from each .avhdx, determine correct parent-child ordering, and manually consolidate the differencing blocks back into the base .vhdx.
My Hyper-V failed to merge a differencing disk. Can you complete the merge?
Yes. A failed merge leaves orphaned .avhdx files that Hyper-V no longer tracks in the VM configuration (.vmcx). We parse each differencing disk's Block Allocation Table to identify which sectors it owns, then merge them in creation-time sequence into the base VHDX. The result is a single consolidated virtual disk at the VM's most recent consistent state.
My VHDX is on a ReFS volume and is unreadable. Is the data gone?
Usually not. ReFS references each VHDX through B+ tree metadata, so a damaged object table or a failed metadata checksum drops the VHDX out of the namespace even though its data extents physically survive on the storage media. Once the volume is unmountable, the integrity-stream checksum only tells us which blocks are valid; it does not repair anything. We image the drives, parse the ReFS object table offline, and fall back to historical object-table checkpoints that allocate-on-write left in unallocated space to re-expose the VHDX entries. Do not run chkdsk on a ReFS volume; it is an NTFS repair tool with no valid role on ReFS.
Can you recover VHDX files from a Storage Spaces Direct (S2D) cluster that lost quorum?
Yes. S2D aggregates local drives across cluster nodes into a pool, layers mirror or parity virtual disks on top, and formats those virtual disks with ReFS for the Cluster Shared Volumes that host the VHDX files. Quorum loss, a majority-node failure, or a resiliency-floor breach takes the pool offline and removes the virtual disks and ReFS CSVs from the namespace, but the data stays on the physical drives. Recovery runs bottom-up: image the physical drives from every node, reassemble the S2D pool geometry from the pool metadata the drives carry, reconstruct the virtual disks in software, parse the ReFS object table and B+ trees, then resolve the VHDX BAT. The imaging hardware reads the drives; the pool assembly, ReFS parse, and VHDX resolution run against the images.
What happens if I discard preserved cache on a Dell PERC controller?
Discarding preserved cache tells the controller to throw away the dirty write-back data it pinned when the virtual disk went offline. Those writes were already acknowledged to the guest OS but were never destaged to the member drives, so discarding them permanently loses the most recent changes and leaves stale LBA ranges beneath any VHDX on that virtual disk. On reboot and array import the controller normally auto-flushes preserved cache to the disks; the loss happens only when an operator manually discards it through the controller interface. If the data matters, image the members before re-initializing the controller.
Why does a Hyper-V checkpoint show read errors for blocks it never wrote?
An AVHDX checkpoint stores only changed blocks and marks everything else PAYLOAD_BLOCK_NOT_PRESENT, reading those addresses through to the parent VHDX. If an underlying RAID partial-sector failure corrupts the parent's payload at one of those offsets, the checkpoint returns a read error for a block it never wrote, because the data it depends on lives in the corrupted parent layer. Recovery traces each failed LBA range through the BAT of every disk in the chain to separate blocks that need parent VHDX repair from blocks the differencing disk owns outright.
Does Hyper-V VM generation (Gen 1 vs Gen 2) change how a VHDX is recovered?
No. Generation selects the guest firmware and boot controller, not the disk container. Gen 1 uses BIOS firmware and an emulated legacy IDE controller for its boot disk (it can also present non-boot data disks over synthetic SCSI), while Gen 2 uses UEFI firmware and the synthetic SCSI VMBus path exclusively with no IDE emulation, and Gen 2 can only use the VHDX format. The VHDX BAT and sector bitmap are byte-for-byte identical across both generations, so offline extraction (parse the header, walk the region table to the BAT, resolve each block against its sector bitmap) is the same for either one. We never boot the guest, so the IDE-versus-synthetic-SCSI distinction does not affect extraction. A Gen 2 VM that will not boot because its EFI System Partition is damaged still has a fully readable data VHDX; the boot failure and the data payload are separate problems. For read-only inspection of an extracted copy we attach it with Mount-VHD -ReadOnly.
What Server Recovery Customers Say
Christopolis
“HIGHLIGHT & CONCLUSION ******Overall I'm having a good experience with this store because they have great customer services, best third party replacement parts, justify price for those replacement parts, short estimate waiting time to fix the device, 1 year warranty, and good prediction of pricing and the device life conditions whether it can fix it or not.”
Yuong Huao Ng Liang
iPhone
Mac Hancock
Rudy Gonzalez
MacBook Air
Ready to recover your Hyper-V environment?
