Enterprise Storage Array Recovery
NetApp FAS & ONTAP Data Recovery
We recover data from failed NetApp FAS, AFF, and E-Series arrays by reconstructing WAFL aggregates from RAID-DP or RAID-TEC parity data. FAS2750, FAS8700, FAS9500, AFF A-Series. Free evaluation. No data = no charge.
15 min read
Overview
How NetApp Arrays Fail and How We Recover Them
NetApp FAS and AFF systems run ONTAP on WAFL, which uses copy-on-write semantics with atomic Consistency Points committed every 10 seconds. We rebuild the aggregate from RAID-DP or RAID-TEC parity. The NetApp controller is not needed; WAFL metadata and parity data reside entirely on the member drives.
NetApp FAS and AFF systems run ONTAP, a proprietary operating system built on the Write Anywhere File Layout (WAFL). WAFL does not store data in fixed locations like NTFS or ext4. Instead, it uses copy-on-write semantics with atomic Consistency Points committed every 10 seconds.
Data and parity are distributed across RAID-DP (double parity) or RAID-TEC (triple parity) groups. When enough drives degrade, the HA controller pair fails, or NVRAM battery depletion causes a dirty shutdown, the aggregate goes offline and all connected hosts lose access.
We rebuild the WAFL on-disk structures from the raw drive images. The NetApp controller is not needed for recovery; WAFL metadata and parity data reside entirely on the member drives.
NetApp Platforms We Recover
We recover FAS hybrid flash/HDD systems, AFF all-flash SSD and NVMe arrays, and E-Series SANtricity block storage. FAS and AFF run ONTAP on WAFL with RAID-DP or RAID-TEC parity; E-Series uses conventional RAID and DDP pools. The recovery path differs by platform, but every family stores its metadata and parity on the member drives.
NetApp has shipped several distinct hardware families. The recovery approach depends on the platform.
FAS Series (Hybrid Flash/HDD)
The FAS2750, FAS8700, and FAS9500 are hybrid storage systems that combine SSD caching with NL-SAS or SAS spinning drives. In a Flash Pool aggregate, ONTAP caches the working data set on the SSDs & uses the HDDs for data that's accessed less often. FAS9500 systems scale across multiple expansion shelves (DS460C, DS224C, DS212C) supporting hundreds of drives per HA pair.
  • RAID-DP default: RAID-DP (one horizontal parity drive and one diagonal parity drive per RAID group) is ONTAP's default for Flash Pool and performance HDD tiers. Capacity HDD tiers built from 6TB and larger drives default to RAID-TEC instead. The group size is set per aggregate, so read it from the array rather than assuming a count.
  • Recovery approach: Parse RAID-DP parity, reconstruct the aggregate, and extract FlexVol volumes or LUNs.
AFF A-Series (All-Flash FAS)
The AFF A250, A400, A700, and A800 are all-flash systems running ONTAP on SSD or NVMe drives. They use the same WAFL filesystem and RAID-DP/RAID-TEC protection. Because these are solid-state systems, physical recovery does not involve clean bench head swaps. Failure modes center on controller failures, firmware corruption, and encryption key loss.
  • NVMe shelves: An AFF A800 runs on NVMe SSDs. We image those drives over NVMe-compatible interfaces, not SAS HBAs.
  • No clean bench needed: SSD and NVMe drive recovery does not require a laminar flow bench. There are no read/write heads or spinning platters. Failure modes are electronic (controller death, firmware corruption, NAND wear) or logical (WAFL metadata corruption).
E-Series (SANtricity, Non-ONTAP)
The E-Series (E2800, E5700, EF600) runs SANtricity OS, not ONTAP. These are block-level SAN storage systems that store volumes in RAID volume groups or disk pools rather than WAFL. Recovery here is conventional RAID reconstruction. We pull the drives, image them, parse SANtricity's on-disk metadata, and rebuild the array.
  • DDP (Dynamic Disk Pools): E-Series DDP distributes data and parity across all pool members, similar in concept to Dell ADAPT. DDP reconstruction requires parsing NetApp's pool metadata format rather than standard RAID stripe maps.
WAFL Architecture
How WAFL Writes Data to Disk
WAFL operates on copy-on-write: modified data is written to free space rather than overwriting existing blocks, and inode pointers are updated to the new location. That scatters data non-sequentially across the RAID group.
WAFL operates on copy-on-write principles. When data is modified, ONTAP writes the new blocks to free space on the drives rather than overwriting existing blocks. Metadata pointers in the inode file are updated to reference the new location. This architecture enables instant snapshots (since old blocks are preserved) but makes recovery more complex because data is scattered non-sequentially across the RAID group.
Consistency Points and NVRAM
Incoming NFS, CIFS, iSCSI, and FC writes are cached in system memory and logged to non-volatile RAM (NVRAM or NVMEM). ONTAP commits those cached writes to disk at a Consistency Point (CP). A CP fires at least every 10 seconds, & sooner if the write log fills up. Between CPs, the on-disk state is always consistent at the previous CP, and the NVRAM log contains the uncommitted delta.
This design provides strong crash consistency: if power drops cleanly, ONTAP replays the NVRAM log on boot and commits the pending CP. The problem arises when the NVMEM battery fails during a power event.
If the battery cannot preserve the log through the outage, the uncommitted writes (up to 10 seconds of data) are permanently lost. The aggregate itself remains consistent at the last committed CP.
Keep this bounded CP loss distinct from aggregate-level corruption. A lost CP costs at most the last 10-second delta and leaves the aggregate consistent, whereas unrecoverable metadata discrepancies inside WAFL are a structural problem in the aggregate itself. We work through that distinction, along with SVM namespace and cluster volume-location metadata, in the SVM failover and cluster metadata triage section.
NetApp Terminology
WAFL (Write Anywhere File Layout)
NetApp's copy-on-write filesystem. Modified data is written to free space rather than overwritten in place, and inode pointers are updated to the new location.
ONTAP
The proprietary operating system that runs NetApp FAS and AFF storage arrays and manages WAFL, aggregates, FlexVol volumes, and RAID-DP/RAID-TEC parity.
RAID-DP
Double-parity RAID using one row parity drive and one diagonal parity drive per RAID group. It reconstructs from two simultaneous drive failures within the group.
RAID-TEC
Triple-parity RAID that adds a third anti-diagonal parity drive, surviving three concurrent failures. ONTAP defaults to it for capacity HDD tiers built from 6TB and larger drives.
An atomic commit of cached writes from NVRAM to disk, firing at least every 10 seconds, or sooner when the write log is full. The on-disk aggregate is always consistent at the last CP.
FlexVol
A flexible logical volume carved out of an aggregate. FlexVol volumes hold the exported NFS/CIFS data and SAN LUNs, and they are extracted from the reassembled aggregate during recovery.
Aggregate
The pool of physical disks grouped into one or more RAID-DP or RAID-TEC RAID groups. FlexVol volumes are provisioned on top of the aggregate.
NVRAM / NVMEM
Battery-backed non-volatile memory that logs incoming writes between Consistency Points. A depleted battery during a power event loses up to 10 seconds of uncommitted writes while the aggregate stays consistent at the last CP.
NSE / OKM
NetApp Storage Encryption uses Self-Encrypting Drives whose media keys are wrapped by the Onboard Key Manager or an external KMIP server. Losing that key material leaves the drives unrecoverable ciphertext.
Flash Pool
A hybrid aggregate that uses SSDs as a cache for the working data set and HDDs for less frequently accessed data.
RAID-DP & RAID-TEC
RAID-DP and RAID-TEC Reconstruction
RAID-DP uses two dedicated parity drives per RAID group, one for horizontal row parity and one for diagonal parity, and reconstructs data from two simultaneous drive failures within the same RAID group. RAID-TEC adds a third anti-diagonal parity drive and survives three concurrent failures. Do not force a rebuild on degraded drives with media defects; power down and image the members first.
RAID-DP uses two dedicated parity drives per RAID group: one for horizontal (row) parity and one for diagonal parity. The diagonal parity calculation deliberately skips one data disk per stripe, creating mathematical independence between the two parity sets. This allows the system to reconstruct data from two simultaneous drive failures within the same RAID group.
RAID-TEC adds a third parity drive with anti-diagonal parity, surviving three concurrent failures. On capacity HDD tiers built from 6TB and larger drives, ONTAP defaults to RAID-TEC. NetApp's reasoning is that bigger disks raise the odds of concurrent failures.
RAID-DP and RAID-TEC are proprietary NetApp parity implementations, not generic RAID-6. RAID-DP combines row parity with a mathematically derived diagonal parity, and RAID-TEC adds an anti-diagonal parity. The raidgroup geometry, the disk roles, group layout, and parity rotation, is encoded in the on-disk RAID-label and aggregate metadata on the member drives.
That is exactly why the aggregate reconstructs without the original controller: like every enterprise controller, NetApp writes its structural metadata to the disks rather than to the controller hardware, so the geometry survives a dead controller pair.
PropertyRAID-DPRAID-TEC
Parity Drives per Group2 (row + diagonal)3 (row + diagonal + anti-diagonal)
Simultaneous Failures Tolerated2 per RAID group3 per RAID group
ONTAP Default ForAll-flash, Flash Pool, and performance HDD tiersCapacity HDD tiers with 6TB+ drives
Do not force a RAID-DP rebuild on degraded drives. If a RAID group is degraded and the remaining members have media defects or unstable read performance, a forced rebuild requires reading every sector of every surviving drive. Weak drives that fail mid-rebuild cause the array to lose more data than the original failure. Power down the system and contact a recovery lab.
The Two-Drive Problem in RAID-DP
RAID-DP survives two complete drive failures. If a third drive has bad sectors (not a complete failure, but unreadable regions), the array collapses.
Here we physically stabilize one of the two failed drives. That's a head swap on the clean bench for a mechanical failure, or firmware intervention for an electronic one. The goal is to bring one failed drive back to a partial read state, converting a dual-degraded array into a single-degraded array. Once reduced to single-drive degradation, diagonal parity can reconstruct the remaining gaps.
Failure Modes
Common NetApp Failure Scenarios
The most common NetApp failures, NVRAM battery depletion during power loss, HA controller takeover failures that send an aggregate offline, cascading drive failures during rebuild, and SAS disk shelf or backplane faults, leave the WAFL aggregate consistent at the last Consistency Point and recoverable. The correct response is to power down and image the drives, never force the aggregate online.
NVRAM Battery Depletion During Power Loss
If a facility-wide power outage occurs and the NVMEM battery is already degraded, uncommitted transactions in the NVRAM log are lost. The WAFL aggregate remains consistent at the last Consistency Point, but writes issued in the preceding 10-second window are permanently lost. The aggregate itself is fully recoverable.
HA Controller Takeover Failures
In an HA pair, if Controller A fails and Controller B attempts takeover but encounters WAFL metadata inconsistency on the shared disk shelf, the aggregate goes offline. Split-brain scenarios occur when both controllers believe they own the same aggregate. IT administrators often panic and attempt to force the aggregate online, which can irreversibly damage the WAFL layout. The correct response is to power down both controllers and ship the disk shelf for recovery.
Cascading Drive Failures During Rebuild
During rebuild, every sector of every surviving member must be read. Drives that have been running 24/7 for years may have weak sectors that were never read during normal I/O. The rebuild exposes these latent defects. Additional drive failures during rebuild push the RAID group past its parity tolerance.
SAS Disk Shelf and Backplane Faults
NetApp disk shelves (DS460C, DS224C, DS212C) connect to controllers via SAS cabling. Backplane faults, IOM (I/O Module) failures, or SAS cable degradation can make multiple drives appear failed simultaneously, even when the drives themselves are healthy. This triggers multi-drive RAID-DP degradation. Extracting the drives and imaging them outside the shelf typically reveals they are fully readable. Recovery in this case is straightforward: image all members and reconstruct the aggregate.
SVM Failover & Cluster Metadata
SVM Failover and Cluster Metadata Triage
An unplanned HA failover hands the down node's aggregates to its partner. If the takeover completes only partially, or the SVM root volume sits on an aggregate that never came online, the entire junction-path namespace is severed and clients lose every volume even when the data blocks themselves stay intact.
In an HA pair, an unplanned failover hands the down node's aggregates to its partner through storage failover (takeover). If the partner is itself unreachable, or the takeover finishes only partially, the aggregates the down node owned cannot come online. The Storage Virtual Machine (SVM) root volume is the entry point that anchors the junction-path namespace. When the root volume lives on an aggregate that did not come online, the entire SVM namespace is severed and clients lose access to every junctioned volume even when the data volumes' own aggregates are intact. This is why the namespace, not the data, is usually the casualty. If a cluster has two or more HA pairs, NetApp recommends load-sharing mirrors of the SVM root volumes so the namespace stays reachable if both nodes of one HA pair go down.
Two Corruption Classes, Not One
Consistency Point loss and aggregate-level corruption are different in kind, and conflating them leads to the wrong recovery decision. Consistency Point (CP) loss is bounded: it can only cost the in-flight writes cached in NVRAM/NV-LOG at the instant of the crash, at most one CP interval of roughly 10 seconds, and the on-disk aggregate stays consistent at the last committed CP. WAFL needs no fsck on boot in that case.
Aggregate-level corruption is different. When WAFL holds unrecoverable discrepancies in its metadata, block maps, or the inode file, the aggregate has a metadata problem rather than a bounded write-loss problem, and it gets worked from images of the members instead of on the live system.
Do not run wafliron / aggr wafliron, storage disk unfail, or force aggr online on a degraded aggregate. NetApp says storage disk unfail can't be reversed once it's invoked. Power the system down and image the members first.
NetApp's RAID-DP and RAID-TEC parity geometry is proprietary, so we rebuild the aggregate from the on-disk RAID labels rather than the tooling that handles a conventional RAID array. The same principle that governs the rest of our enterprise server recovery work applies here: the array geometry lives on the member drives, so a dead controller pair does not put the aggregate out of reach.
Disk Ownership & Zeroing
ONTAP Disk Ownership and Disk Zeroing
If the owner ID in an aggregate's RAID tree doesn't match the system the disks are plugged into, ONTAP declares the aggregate foreign & marks it offline. If you still need that data, leave ownership alone & don't zero any disk until every member has been imaged.
ONTAP won't let anyone reassign ownership of a disk that's in use in an aggregate. NetApp's own docs tell admins to remove ownership information before pulling a spare disk or its shelf, so another node can take it in.
That instruction is written for spares. On a shelf you're sending us for recovery, leave ownership alone.
What Makes ONTAP Call an Aggregate Foreign?
NetApp says it happens when a RAID tree object carries an ownership identifier that's different from the local system. ONTAP then declares the aggregate foreign & marks it offline.
We don't need ONTAP to accept that owner ID. We image each member & run the parity reconstruction against the images, the same way we handle a dead controller pair.
When Does NetApp Require Zeroing?
NetApp requires zeroing before a disk gets reused in another aggregate.
NetApp's reference page for storage disk zerospares says the ONTAP release it covers uses fast zeroing. That converts a spare from non-zeroed to zeroed without the long wait of physically zeroing it. Just because it's quick doesn't mean you should run it. If the data matters, stop, pull the members, & send them to us for imaging first.
NetApp Storage Encryption (nse)
NetApp Storage Encryption (NSE) Constraints
NSE uses Self-Encrypting Drives that hold a media key wrapped by the Onboard Key Manager inside ONTAP or an external KMIP server. If that key material is lost, the drives stay ciphertext and no parity reconstruction recovers them. Confirm NSE status and key backups before shipping; we can image the members but cannot decrypt without the keys.
NetApp supports hardware-level encryption via Self-Encrypting Drives (SEDs) that encrypt at the drive firmware layer. Keys are managed by either the Onboard Key Manager (OKM) built into ONTAP or an external KMIP (Key Management Interoperability Protocol) server.
If the encryption keys are lost (OKM corrupted, KMIP server destroyed, key backup missing), the data on the SEDs is cryptographically erased and unrecoverable. We can image the physical drives and reconstruct the RAID-DP/RAID-TEC parity, but the resulting data is encrypted and unusable without the original authentication keys.
Before sending drives for recovery, verify whether NSE was enabled on the failed system and whether key backups exist. Recovery of encrypted volumes requires the exact key material used at the time of encryption.
Methodology
Recovery Methodology for NetApp Systems
We document the model and aggregate layout, label every drive by shelf and slot, then image each member through SAS or NVMe interfaces. RAID-DP or RAID-TEC parity is reconstructed against the images, never the live drives, and the WAFL aggregate is reassembled offline so FlexVol volumes and LUNs extract read-only.
1. Evaluation and Documentation
We document the NetApp model, ONTAP version, aggregate configuration (RAID-DP or RAID-TEC, RAID group sizes, number of data/parity drives), FlexVol/LUN layout, and the event log entries leading to failure. If the management console (System Manager or CLI) is accessible, we export the configuration. If both controllers are dead, we extract configuration from on-disk metadata after imaging.
2. Drive Extraction and Slot Mapping
Every drive is labeled by disk shelf ID and slot number before removal. ONTAP writes disk ownership information to the disk, so membership travels with the member rather than with the bay. The labels give us a second, physical record to check against the on-disk RAID labels during reassembly.
3. SAS/NVMe Imaging
Drives with media defects are imaged with adaptive retry parameters and head maps. Mechanically failed drives receive head swaps on the ULPA-filtered clean bench before imaging.
4. RAID-DP/TEC Parity Reconstruction
We calculate horizontal and diagonal parity (RAID-DP) or add anti-diagonal parity (RAID-TEC) across the RAID group images. Missing sectors from failed members are reconstructed using parity data from surviving members. The parity math runs against the drive images, never against the live members. For dual-degraded RAID-DP arrays, we first physically stabilize one failed drive to reduce degradation to single-drive level, then use diagonal parity to fill the remaining gaps.
5. WAFL Aggregate Reassembly
After RAID reconstruction, we parse the WAFL on-disk structures: inode files, indirect block trees, volume metadata, and snapshot checkpoint records. Then we extract the FlexVol volumes and LUNs from the reassembled aggregate. Common host-side filesystems include VMFS (for VMware ESXi datastores), NTFS/ReFS (Windows), ext4/XFS (Linux), and NFS exports. We mount extracted volumes read-only and verify priority files against the customer's recovery list.
Helium Drive Handling
Helium Drive Handling for High-Density Shelves
DS460C shelves hold up to 60 drives. When a helium-sealed member needs a head swap, we do it under a controlled breach on the ULPA-filtered clean bench, then refill the drive with helium before the platters spin again. At 60 drives the imaging phase alone can span multiple days before any aggregate reconstruction begins.
NetApp DS460C shelves hold up to 60 NL-SAS drives.
Helium drives do not go back together like standard air-breathing drives. The drive's internal atmosphere is sealed at the factory. Once we breach that seal, we have to repressurize the drive with helium before the platters spin again. We open helium drives on a ULPA-filtered laminar flow bench using a controlled breach procedure that maintains a clean particle environment during head swaps.
For NetApp systems with 60+ NL-SAS drives, the imaging phase alone can span multiple days. If degraded members require mechanical repair, add head swap and donor sourcing time per drive.
How Much Does NetApp Recovery Cost?
NetApp recovery follows the same transparent pricing model as every other service: per-drive imaging based on each drive's condition, plus a reconstruction fee per aggregate. No data recovered means no charge.
Service TierPrice Range (Per Drive)Description
Logical / Firmware Imaging$250-$900Firmware corruption, SMART threshold failures, or drives that are healthy but removed from a failed shelf/controller.
Mechanical (Head Swap / Motor)$1,200–$1,500 air-filled / $3,000–$4,500 helium50% depositDonor SAS heads matched by model, firmware revision, head count, and preamp version. DS460C helium NL-SAS members use helium HDD pricing, plus helium and donor costs.
Aggregate ReconstructionCustom Quoteper aggregateRAID-DP/RAID-TEC parity reconstruction, WAFL aggregate reassembly, FlexVol/LUN extraction, and filesystem recovery. One fee per aggregate.
No Data = No Charge: If we recover nothing from your NetApp system, you owe $0. Free evaluation, no obligation.
We sign NDAs for corporate data recovery. All drives remain in our Austin lab under chain-of-custody documentation. We are not HIPAA certified and do not sign BAAs, but we are willing to discuss your specific compliance requirements before work begins.
NetApp FAS and ONTAP Recovery; Common Questions
Can you recover data from a NetApp FAS system where the controller pair failed?
Yes. The WAFL filesystem structures and RAID-DP parity data are stored on the member drives, not in the controller. We reconstruct the aggregate from the raw drive images without needing the original controllers.
What is the difference between RAID-DP and RAID-TEC recovery?
RAID-DP uses two parity calculations (horizontal and diagonal) and can survive two concurrent drive failures per RAID group. RAID-TEC adds a third parity calculation (anti-diagonal) and survives three failures. Recovery methodology is the same for both: image all members, calculate parity to fill gaps from failed drives, and reassemble the aggregate. RAID-TEC is more resilient but uses more disk capacity for parity.
Is WAFL recovery possible if the NVRAM battery died during a power loss?
The WAFL aggregate itself remains consistent at the last Consistency Point (CP). ONTAP commits data to disk every 10 seconds via CPs, so the maximum data at risk is the uncommitted writes cached in NVRAM during that window. If the NVMEM battery died during the outage, the in-flight writes are permanently lost. The aggregate and all previously committed data are recoverable.
Can you recover encrypted NetApp volumes using NSE (NetApp Storage Encryption)?
Only if you have the encryption keys. NSE uses Self-Encrypting Drives (SEDs). If the Onboard Key Manager (OKM) or external KMIP server is destroyed and no key backup exists, the data is cryptographically erased and unrecoverable regardless of the physical condition of the drives. We can image the drives, but the data cannot be decrypted without the original keys.
Should I attempt to force an offline aggregate back online?
No. Forcing an aggregate online when member drives have media defects or mechanical degradation triggers a RAID-DP rebuild across the remaining drives. If those drives are weak, the rebuild stress can cause additional failures, permanently destroying parity data. Power down the system and ship the drives to a recovery lab.
How is NetApp FAS/AFF recovery priced?
Same transparent model as all our services: per-drive imaging fee based on each drive's condition, plus an aggregate reconstruction fee. No data recovered means no charge.
Ready to recover your NetApp array?
