Enterprise Storage Array Recovery
Dell EMC PowerVault Data Recovery
We recover data from failed Dell EMC PowerVault arrays. ME4, ME5, MD-series, NX appliances. Free evaluation. No data = no charge.
18 min read
Overview
How PowerVault Arrays Fail and How We Recover Them
A failed PowerVault or PERC array is recoverable because the controller's structural metadata (Dell's DDF variant on PERC-attached members, the ADAPT page-allocation map on ME4/ME5) lives on the member drives, not only in controller NVRAM. The original controller is not required.
Dell EMC PowerVault arrays (ME4, ME5, MD, NX series) store data across multiple SAS drives managed by dual active-active controllers. When controllers fail, firmware corrupts, or enough drives degrade to exceed parity tolerance, the virtual disk groups go offline and all connected hosts lose access.
The critical distinction for ME4 and ME5 arrays is ADAPT (Autonomic Distributed Allocation Protection Technology). ADAPT replaces traditional RAID with an erasure coding scheme that distributes data and parity across chunk stripes. Standard RAID destriping software designed for PERC-managed arrays or Linux mdadm cannot parse ADAPT's distributed page layout.
Older MD-series arrays use traditional RAID with Dell-proprietary on-disk metadata, which requires vendor-specific metadata parsing but follows conventional RAID reconstruction methodology.
Powervault Product Lines
PowerVault Product Lines and Recovery Approaches
ME4 and ME5 use ADAPT erasure coding (8+2 on ME4, up to 16+2 on ME5); MD-series use traditional RAID with Dell on-disk metadata; NX appliances use PERC plus Windows Storage. The original controller is not required.
Dell EMC has shipped several distinct PowerVault generations. Each has a different storage architecture, and the recovery methodology differs accordingly.
PowerVault ME4 and ME5 (ADAPT Erasure Coding)
The ME4 (2018) and ME5 (2022) series are Dell's current midrange storage platforms. Both use dual active-active controllers with Intel Xeon processors (ME4: dual-core; ME5: upgraded with 2x the cores) and large controller memory (8GB per controller on ME4; 16GB on ME5). They support SAS SSD, 10K SAS, and 7.2K NL-SAS drives in 2U (12-bay or 24-bay) and 5U (84-bay, ME484/ME584) enclosures.
  • ADAPT configuration: ME4 uses 8+2 chunk stripes (8 data chunks, 2 parity); ME5 supports up to 16+2 for larger disk groups. Spare capacity is distributed across all members instead of dedicating entire drives as hot spares.
  • Multi-tier storage: ME5 supports automatic tiering across hot (SSD), warm (10K SAS), and cold (7.2K NL-SAS) tiers. The controller migrates pages between tiers based on access patterns. During recovery, all tiers must be imaged and the page allocation table reconstructed to reassemble data that spans tiers.
  • Recovery approach: Reconstruct the ADAPT page layout by parsing Dell's on-disk metadata. Map virtual disk group extents and extract the presented LUNs or virtual disks.
PowerVault MD Series (Traditional RAID)
The MD series (MD3060e, MD3260, MD3460, MD3660f, MD3860f) are Dell's legacy DAS/SAN storage arrays. They use traditional RAID levels (0, 1, 5, 6, 10) managed by dual redundant controllers. Unlike ME4/ME5, MD arrays do not use ADAPT.
  • RAID metadata: MD controllers write proprietary on-disk metadata to reserved sectors on each member drive. This metadata includes RAID level, stripe size, member ordering, and rebuild state.
  • 12Gb SAS backplane: MD3460 and later models use 12Gb SAS, which requires matching interface hardware for imaging.
  • Recovery approach: Same as conventional RAID recovery.
PowerVault NX Series (Windows Storage Server)
The NX series (NX3230, NX3330, NX430) are Dell-branded Windows Storage Server appliances. They combine a PowerEdge server chassis with internal RAID managed by PERC controllers and Windows Storage Spaces or standard NTFS/ReFS volumes.
  • PERC controllers: NX appliances use the same PERC H730/H740/H755 controllers as PowerEdge servers. The recovery process is identical: image members, parse PERC metadata, reconstruct offline.
  • Windows Storage Spaces: If the NX uses Storage Spaces instead of hardware RAID, the storage pool metadata is managed by Windows. Reconstruction requires parsing the Storage Spaces metadata database from the member drive images.
ADAPT Erasure Coding: Why Standard RAID Tools Fail
ADAPT is erasure coding, not RAID 6. It distributes data and parity across chunk stripes (8+2 on ME4, up to 16+2 on ME5) with spare capacity spread across all members instead of dedicated hot-spare drives. Standard RAID 5/6 destriping tools cannot reconstruct it; only software that parses the ADAPT on-disk page map can.
ADAPT is not RAID. Treating a failed ME4 or ME5 like a RAID 5/6 array and running standard destriping software will produce garbage output.
Traditional RAID maps data stripes sequentially across a fixed set of member drives in a predictable pattern. ADAPT allocates data in pages, distributing data chunks and parity chunks across all available drives in the virtual disk group. The allocation is not sequential; the controller places pages wherever free capacity exists, including capacity previously reserved for hot spares.
SpecificationPowerVault ME4PowerVault ME5
Controller ProcessorDual-core Intel XeonUpgraded Intel Xeon (2x cores)
Controller Memory8GB per controller16GB per controller
ADAPT Chunk Stripes8+2 (8 data, 2 parity)Up to 16+2 (16 data, 2 parity)
Auto-TieringManual tier assignmentAutomatic hot/warm/cold tiering
Max ExpansionME484: 84 drives (5U)ME584: 84 drives (5U)
Drive TypesSAS SSD, 10K SAS, 7.2K NL-SASSAS SSD, 10K SAS, 7.2K NL-SAS
For recovery, the practical consequence is that we cannot feed ME4/ME5 drive images into a standard RAID reconstruction tool and get usable output. The page layout, distributed spare capacity, and non-sequential allocation mean the page map must be reconstructed from Dell's on-disk metadata structures before data extraction can begin.
PowerVault Quarantine
Dell PowerVault Quarantine States Explained
QTDN, QTCR, and QTOF are controller policy locks, not proof of physical drive failure. QTOF means the inaccessible-drive count exceeded fault tolerance and the controller took the group offline to protect data. The quarantined drives are often physically healthy; recovery images every member and rebuilds the layout from raw images.
When the PowerVault controller detects drive failures or data integrity errors, it places the affected virtual disk group into a quarantine state. Understanding these states helps IT administrators avoid making the situation worse before contacting a recovery lab.
QTDN (Quarantined with Down Disk)
A fault-tolerant virtual disk group is degraded because one or more member drives are inaccessible. ADAPT or RAID parity can still reconstruct the missing data. The group remains online in degraded mode. The controller may automatically rebuild onto distributed spare capacity (ADAPT) or a dedicated hot spare (RAID).
QTCR (Quarantined Critical)
The virtual disk group is critical: the number of inaccessible drives equals the fault tolerance. For ADAPT with 2 parity chunks, this means 2 drives are down. One more failure means data loss. The controller keeps the group online but read performance degrades as parity calculations require reading every surviving member for each I/O.
QTOF (Quarantined Offline)
The number of inaccessible drives exceeds fault tolerance. User data is incomplete and the controller takes the virtual disk group offline. No host I/O is possible. This is the most common state when customers contact us. Recovery requires extracting all drives and reconstructing the layout from raw images.
Do not use the Dell CLI "trust" command on a quarantined group with degraded drives. The trust command forces a drive out of quarantine and triggers an automatic ADAPT self-healing rebuild. Dell's own documentation warns that misusing trust and dequarantine can cause data corruption or loss. If the drive has media defects or mechanical degradation, the rebuild also puts hours of sustained load on the surviving members. Power down the array and ship it to a recovery lab.
Firmware-Induced QToF
Firmware-Induced QTOF: The Samsung DSA3/DWA3 Bug
The DSA3 to DWA3 firmware update corrupts the logical block mapping on Samsung MZILT800HBHQ0D3 and MZILT1T6HBJR0D3 SAS SSDs. The controller logs SCSI sense 0x5,0x21,0x0 (LBA out of range) and quarantines the disk group. Dell documents it in KB 000199115. Do not rebuild or trust the group.
A documented firmware compatibility issue affects specific Samsung SAS SSDs in PowerVault ME4 arrays. Samsung models MZILT800HBHQ0D3 (800GB) and MZILT1T6HBJR0D3 (1.6TB) can fail after a firmware update from DSA3 to DWA3.
After the update, the affected drives report SCSI sense data 0x5,0x21,0x0,0x2100 (Illegal Request, logical block address out of range). The ME4 controller interprets this as a drive failure and quarantines the virtual disk group. If enough SSDs in the group received the same update, the group enters QTOF.
Do not run a rebuild or a trust command against a group that failed this way.
Dell Knowledge Base article KB 000199115 documents this issue and the affected firmware versions. If your ME4 experienced sudden multi-drive failure immediately after a firmware update, this is the most likely cause.
Helium Drive Handling
Helium Drive Handling in Dense Enclosures
The ME484 and ME584 84-bay 5U enclosures populate their capacity tier with helium-sealed NL-SAS drives. A failed helium member must be opened on a ULPA-filtered laminar flow bench so the sealed internal atmosphere can be breached without contaminating the platters. Imaging an 84-drive array can span days when degraded members need mechanical repair first.
The ME484 (ME4) and ME584 (ME5) 5U 84-drive expansion enclosures populate their NL-SAS capacity tier with 12TB+ 3.5" drives. At these capacities, the drives are helium-sealed with laser-welded chassis.
Helium drives do not go back together the same way as standard air-breathing drives. The internal atmosphere is sealed at manufacture. Breaking the seal without the right environment contaminates the platters immediately, and the chassis has to be resealed and refilled with helium before the platters spin again. We open helium drives on a ULPA-filtered laminar flow bench that maintains a clean particle environment during head swaps.
For PowerVault arrays with 84 drives, the imaging phase alone can span multiple days, longer still if degraded members require mechanical repair before imaging.
Methodology
Recovery Methodology for PowerVault Arrays
1. Evaluation and Documentation
We document the PowerVault model, controller firmware version, virtual disk group configuration (ADAPT or RAID level), current quarantine state, and the event log entries leading up to the failure. If the management interface is accessible, we export the configuration before extracting drives. If both controllers are dead, we extract the configuration from the on-disk metadata after imaging.
2. SAS Member Imaging
Drives with media defects are imaged with adaptive retry parameters and head maps. Mechanically failed drives receive head swaps on the clean bench before imaging.
3. ADAPT or RAID Reconstruction
For ADAPT arrays, we parse Dell's on-disk metadata to reconstruct the page allocation table, map chunk stripes to their physical locations across member drives, and assemble the virtual disk group. For RAID arrays, Data Extractor Express RAID Edition reads the proprietary metadata to determine stripe size, parity rotation, and member ordering. In both cases, parity data is used to reconstruct any unreadable sectors from failed members.
4. Filesystem Extraction and Delivery
The reconstructed virtual disk is mounted read-only. Common filesystems on PowerVault LUNs include VMFS (for VMware ESXi datastores), NTFS/ReFS (for Windows servers), and ext4/XFS (for Linux hosts). We extract the target data, verify file integrity against the customer's priority list, and deliver on encrypted media.
Controller Cache & NVRAM
Controller Cache and NVRAM Considerations
Write-back cache holds host-acknowledged writes in volatile memory backed by a supercapacitor that flushes to a flash vault on power loss. If the controller died mid-flush, the vault holds partial writes, which we extract through board-level access. This work is independent of array reconstruction.
ME5 controllers allocate 16GB of memory per controller for read/write caching. When write-back caching is enabled, the controller acknowledges writes to the host before committing them to disk. This uncommitted data sits in volatile cache backed by supercapacitors or battery.
If a controller sustains electrical damage during a power event, data trapped in volatile cache is at risk. The supercapacitor provides enough charge to flush cache to a dedicated flash module (vault area) during orderly shutdown. If the controller failed before the flush completed, the vault area may contain partial writes.
We extract the vault contents through board-level access when the controller cannot be powered on normally.
Dell PERC Controller Families
Dell PERC Controller Families and Recovery
H330 has no cache, H730/H730P carry 1GB/2GB flash-backed cache, H740P carries 8GB, and H755/PERC 11 carries 8GB with optional SED. All write DDF metadata to the drives, so recovery bypasses the controller and reconstructs from raw images. Foreign Configuration means an NVRAM-versus-DDF mismatch, and choosing Clear destroys the routing.
Dell PowerEdge servers use PERC (PowerEdge RAID Controller) hardware to manage virtual disks across SAS and SATA drives. When a PERC controller fails or its NVRAM desynchronizes from the on-disk DDF metadata, the virtual disk goes offline. Recovery bypasses the controller entirely and reconstructs the array from raw drive images.
PERC H330 (Entry-Level)
No onboard cache memory. Supports RAID 0, 1, 5, 10, and 50. Because H330 has no battery-backed cache, write-back caching is unavailable and no cache vault recovery is needed. Found in PowerEdge R230, R330, T130, and T330 servers.
PERC H730 / H730P (Mid-Range)
1GB (H730) or 2GB (H730P) of non-volatile flash-backed cache. Supports RAID 0, 1, 5, 6, 10, 50, and 60. The flash-backed write cache preserves uncommitted writes during power loss. Found in PowerEdge R430, R530, R630, R730, and R730xd servers. Recovery from H730 arrays follows standard RAID reconstruction methodology.
PERC H740P (High-End, 14th Gen)
8GB flash-backed cache with hardware XOR/RAID 6 offload engine. Supports the same RAID levels as H730 with faster parity calculation. Found in PowerEdge R640, R740, R740xd, and R940 servers. The 8GB cache vault stores more uncommitted data during power loss, which means more data is at risk if the controller board itself is damaged.
PERC H755 / PERC 11 (15th Gen and Later)
8GB flash-backed cache, NVMe passthrough support, and optional hardware encryption via Self-Encrypting Drives (SEDs). The H755 writes DDF metadata in the same format as earlier PERC generations, so the recovery process for SAS arrays remains identical. If SED encryption is enabled with a PERC-managed key, the encryption key must be available before drive data can be decrypted; without the key, the SED hardware blocks all read access at the drive firmware level.
PERC Foreign Configuration errors are the most common reason IT administrators contact us about PowerEdge servers. Choosing "Clear" instead of "Import" at the PERC BIOS prompt destroys the DDF metadata mapping and makes the virtual disk inaccessible. If your PERC shows Foreign Configuration, power down the server and contact a recovery lab before selecting either option.
Where Dell PERC Writes Its Metadata, and Why HP Arrays Differ
PERC and LSI/Broadcom MegaRAID write their DDF metadata to the trailing sectors at the end of every member drive; HP Smart Array instead writes a proprietary RAID Information Sector (RIS) to a reserved area at the start of each drive. A recovery engineer has to identify which vendor wrote the array before choosing where to read the geometry, because assuming a DDF end-of-drive layout on an HP RIS start-of-drive array reads filesystem data where the metadata should be.
Controller FamilyMetadata FormatOn-Disk Location
Dell PERC / LSI / Broadcom MegaRAIDSNIA DDF variantTrailing sectors, end of drive
HP Smart ArrayProprietary RISReserved area, start of drive
Because the DDF header records member count, stripe element (chunk) size, parity rotation, and the virtual-disk GUID on the drives themselves, the original PERC card is not required.
The common belief that you need the original controller to recover a hardware RAID is false, because the geometry lives on the member drives, not in the dead card. For controller family details across the PERC line, see our Dell PERC controller recovery reference.
A degraded PERC array has to be imaged member-by-member before any rebuild, and a controller should never be replaced or foreign-imported during an active rebuild. On nested RAID 50/60 spans this matters more, because the safest recovery path is always offline imaging first.
Virtual Disk Failure
What Causes a Virtual Disk to Go Offline on Dell Servers?
A Dell virtual disk goes offline when the PERC loses contact with more members than the RAID level tolerates, or when controller NVRAM desyncs from the on-disk DDF metadata (Foreign Configuration). In both cases the member data is intact; choosing Clear instead of Import, or forcing a rebuild on marginal drives, is what destroys it.
A Dell PowerEdge virtual disk goes offline when the PERC controller loses communication with enough array members to exceed the RAID level's fault tolerance, or when NVRAM metadata desynchronizes from the physical disk DDF headers. The causes split into two categories: logical controller issues and physical drive failures.
Logical / Controller Issues
  • Foreign Configuration: NVRAM and on-disk DDF metadata mismatch after controller replacement or drive migration between servers
  • Firmware update interruption: Lifecycle Controller or PERC firmware updates that fail mid-write can reset NVRAM state and orphan the virtual disk
  • Cache backup unit failure: When the PERC battery-backed Non-Volatile Cache module fails, the controller switches from write-back to write-through caching, reducing write performance but not taking the virtual disk offline
  • Accidental Clear instead of Import: Selecting Clear at the PERC BIOS prompt erases DDF metadata from physical disks, destroying the virtual disk routing
Physical Drive Failures
  • Multiple drive failure beyond parity: RAID 5 tolerates one drive loss; RAID 6 tolerates two. A third failure on RAID 6 drops the virtual disk offline
  • Read/write head degradation: Aging SAS drives develop bad sectors faster than the PERC patrol read can detect them, causing cascading failures during rebuild operations
  • Backplane or SAS expander fault: A failed SAS expander or backplane connection makes all drives behind it invisible to the PERC, simulating multi-drive failure
  • Power event damage: Electrical surges can damage the PERC PCB, drive electronics, or both simultaneously
In every case, the first step is to power down the server and avoid running any rebuild, initialization, or diagnostic commands through the PERC BIOS or Dell OpenManage. Running chkdsk or consumer recovery software on a server with physically failing drives causes further damage. Our no-fix-no-fee guarantee applies to all Dell PowerEdge and PowerVault recovery cases.
iDRAC Diagnostics
iDRAC Out-of-Band Diagnostics Before Recovery
iDRAC stores hardware and Lifecycle Controller event logs independently of the host OS, so they persist through crashes. Exporting them through the web UI or the Redfish API before shipping lets us triage logical versus physical failure without booting the host or mounting anything.
Dell PowerEdge servers with iDRAC (integrated Dell Remote Access Controller) store hardware event logs independently of the host operating system. These logs persist through OS crashes and remain accessible even when the server cannot boot, making them the safest source of pre-recovery diagnostic data.
Before shipping a failed PowerEdge server, IT administrators can extract these logs through iDRAC's web interface or its Redfish RESTful API without booting the host OS or mounting any file system. The Lifecycle Controller log records every drive insertion, removal, SMART alert, firmware update, and virtual disk state change with timestamps. This timeline helps us determine whether the failure is logical (controller metadata issue) or physical (drive hardware failure) before we open a single drive.
  1. Connect to the iDRAC management IP through a browser or SSH
  2. Navigate to Maintenance > Lifecycle Log (web UI) or query the Redfish API system log endpoint
  3. Export the full lifecycle log as CSV or JSON and send it to your recovery lab along with the server
  4. Do not run any Lifecycle Controller firmware updates, virtual disk initialization, or PERC configuration changes
Providing iDRAC logs saves diagnostic time and reduces the total recovery cost. When we know the exact sequence of events that led to the failure, we skip exploratory imaging of drives that were not involved in the virtual disk group, and we can prioritize the drives most likely to contain recoverable data.
The CLI utilities below read controller and slot state out-of-band, without mounting, rebuilding, or modifying the array. These are read-only query commands. Do not run any rebuild, import, or trust command against degraded drives.
# read controller summary, model, cache, firmware
storcli64 /c0 show
# list virtual disks and their state
storcli64 /c0/vall show
# enumerate every enclosure slot and physical drive
storcli64 /c0/eall/sall show
# on Dell PowerEdge the same binary ships as perccli
perccli64 /c0 show
iDRAC
Integrated Dell Remote Access Controller. An out-of-band service processor on Dell PowerEdge boards that logs hardware and Lifecycle Controller events independently of the host OS and exposes them through a web UI and the Redfish RESTful API.
storcli64
Broadcom/LSI MegaRAID command-line tool for querying controller, virtual disk, and physical drive state. Dell ships a PERC-branded rebrand of the same binary as perccli. The query forms shown above are read-only and do not alter array metadata.
QTOF
The quarantine-offline state a PowerVault controller enters when the number of inaccessible drives exceeds the virtual disk group's fault tolerance. Host I/O stops. The quarantined drives are often physically healthy; recovery images every member and rebuilds the layout from raw images.
ADAPT
Autonomic Distributed Allocation Protection Technology. Dell's erasure coding scheme on ME4 and ME5 that distributes data and parity across chunk stripes (8+2 on ME4, up to 16+2 on ME5) with spare capacity spread across all members rather than dedicated hot-spare drives.
DDF
Disk Data Format. The SNIA on-disk RAID metadata variant that Dell PERC and LSI/Broadcom MegaRAID write to the trailing sectors of each member drive. Because the geometry lives on the disks, recovery reconstructs the array from raw images and does not require the original controller.
RIS
RAID Information Sector. The proprietary on-disk metadata that HP Smart Array controllers write to a reserved area at the start of each member drive, in contrast to the DDF format Dell PERC and LSI/Broadcom MegaRAID write to the trailing sectors.
PowerVault Recovery Pricing
PowerVault recovery follows the same transparent pricing model as every other service: per-drive imaging based on each drive's condition, plus a reconstruction fee per virtual disk group. No data recovered means no charge.
Service TierPrice Range (Per Drive)Description
Logical / Firmware Imaging$250-$900Firmware corruption, SMART threshold failures, or firmware-induced quarantine (e.g., Samsung DSA3/DWA3 bug). Most healthy SAS drives from PowerVault arrays fall in this tier.
Mechanical (Head Swap / Motor)$1,200–$1,500 air-filled / $3,000–$4,500 helium50% depositDonor SAS heads matched by model, firmware revision, head count, and preamp version. ME484/ME584 helium NL-SAS members use helium HDD pricing, plus helium and donor costs.
ADAPT / RAID ReconstructionCalculated feeper virtual disk groupADAPT page reconstruction, RAID metadata parsing, virtual disk group reassembly, and filesystem extraction. One fee per virtual disk group.
No Data = No Charge: If we recover nothing from your PowerVault array, you owe $0. Free evaluation, no obligation.
We sign NDAs for corporate data recovery. All drives remain in our Austin lab under chain-of-custody documentation.
Dell PowerVault and PERC Recovery; Common Questions
Can you recover data from a PowerVault ME4 or ME5 in QTOF (Quarantined Offline) state?
Yes. QTOF means multiple drives in a virtual disk group are inaccessible, and the controller has taken the group offline. The original controller is not needed for recovery.
Is PowerVault ADAPT recovery different from standard RAID recovery?
Yes. ADAPT (Autonomic Distributed Allocation Protection Technology) is an erasure coding scheme, not traditional RAID. It distributes data and parity across chunk stripes (8+2 on ME4, up to 16+2 on ME5) with distributed spare capacity instead of dedicated hot spares. Standard RAID 5/6 destriping tools cannot reconstruct ADAPT arrays.
What does the Samsung DSA3/DWA3 firmware bug do to PowerVault ME4 arrays?
Specific Samsung SAS SSDs (MZILT800HBHQ0D3, MZILT1T6HBJR0D3) can fail after firmware updates from DSA3 to DWA3. The controller logs SCSI sense error 0x5,0x21,0x0 (logical block address out of range) and quarantines the entire virtual disk group. The firmware update corrupted the logical block mapping. We image these drives by bypassing the corrupted firmware layer.
Should I use the Dell CLI 'trust' command to bring drives back online?
No. The 'trust' command forces a drive out of quarantine and triggers an automatic ADAPT rebuild against a drive Dell warns can cause data corruption or loss when it is trusted without cause. If that drive has mechanical degradation or media defects, the rebuild runs hours of sustained load across the surviving members. Power down the array and contact a recovery lab before running any CLI commands.
How is PowerVault recovery priced?
Same transparent model as all our services: per-drive imaging fee based on each drive's condition, plus an array reconstruction fee per virtual disk group. No data recovered means no charge.
Do you recover from PowerVault MD3460 and older MD-series arrays?
Yes. MD-series arrays (MD3060e, MD3260, MD3460, MD3660f, MD3860f) use traditional RAID with Dell's proprietary on-disk metadata format. Recovery follows the same process as other enterprise RAID.
What Dell PERC controller models do you recover data from?
We recover from all PERC generations used in PowerEdge servers: PERC H330 (entry-level, no cache), H730/H730P (1-2GB flash-backed cache), H740P (8GB flash-backed cache), and H755 (PERC 11, 8GB flash-backed cache). Each generation writes RAID metadata in Dell's DDF format.
What is a Dell PERC Foreign Configuration error?
Foreign Configuration means the PERC controller's NVRAM does not match the DDF (Disk Data Format) metadata stored on one or more physical disks. This occurs after moving drives between servers, replacing a failed controller, or an NVRAM reset. The drive data is intact; the controller cannot match its records to the disk metadata. Choosing 'Clear' instead of 'Import' destroys the virtual disk routing and makes data inaccessible.
Can I rebuild a degraded Dell RAID array to recover data?
Rebuilding a degraded array is not a recovery method. If the remaining drives have bad sectors, media defects, or pending mechanical failure, the rebuild forces sustained sequential reads across every surviving member, which can push a marginal survivor into a secondary mechanical failure. On a read failure, modern PERC and LSI/Broadcom MegaRAID firmware punctures the affected stripe and continues, losing only that stripe's data; older or low-end firmware can drop the rebuilding drive and take the volume offline. When the data is irreplaceable and unbacked, power down the server and contact a recovery lab before attempting any rebuild.
Ready to recover your PowerVault array?
