How Hard Drive Read/Write Heads Work
A hard drive read/write head is a thin-film electromagnetic transducer mounted on a slider that keeps a baseline aerodynamic clearance of a few nanometers above a spinning platter, with the transducers thermally protruded to an active magnetic spacing of about 1 to 2 nanometers. It reads data by detecting changes in magnetic polarity on the platter surface and writes data by applying a focused magnetic field to flip the polarity of individual magnetic domains. Each platter surface has its own dedicated head, and all heads are connected to a single actuator arm assembly driven by a voice coil motor. Head stack replacement is one stage of our complete hard drive data recovery workflow.
How Does the Voice Coil Motor Position the Heads?
The actuator assembly is the mechanical structure that positions the read/write heads over the correct track on the platter. It pivots on a bearing located near the center of the drive. The voice coil motor (VCM) drives this pivot by passing current through a coil suspended between two permanent magnets. Reversing the current direction moves the actuator in the opposite direction.
Modern drives abandoned stepper motors for head positioning in the early 1990s. Stepper motors move in fixed increments, which limits track density. Voice coil motors provide continuous, proportional positioning with sub-micron accuracy. A servo feedback loop reads positioning data from servo wedges embedded on the platters and adjusts coil current thousands of times per second to keep the heads centered on the target track.
When external power is lost, the spindle motor acts as a generator. The rotational momentum of the still-spinning platters produces back-EMF, which is routed to the VCM coil to actively sweep the heads off the platters before the air bearing collapses. Most modern drives retract the heads to a parking ramp at the outer edge of the platter stack; older drives used a landing zone near the inner diameter. Once the heads reach the park position, a magnetic latch holds them in place.
How Do Hard Drive Heads Fly Above the Platter?
The read/write element is not a standalone component. It is fabricated onto a ceramic slider, typically made of alumina-titanium carbide (AlTiC). The bottom surface of the slider is the air bearing surface (ABS), which is etched with a pattern of rails and channels designed to generate aerodynamic lift from the thin layer of air dragged by the spinning platter.
At 7,200 RPM, the platter surface moves at roughly 80 to 120 km/h depending on the radial position. This airflow creates a pressurized air cushion that lifts the slider to a baseline aerodynamic clearance of a few nanometers, while thermal fly-height control drives the read/write transducers to an active magnetic spacing of about 1 to 2 nanometers. For context, a smoke particle is roughly 250 nanometers in diameter, which is why opening a drive outside a particulate-controlled environment risks contamination.
These dimensional disparities dictate strict cleanroom controls during any drive opening. Corneocytes (skin flakes) are typically around 1,000 nanometers thick. A bacterium is 1,000 to 5,000 nanometers long. Any of these particles caught between the slider and the platter acts like a wedge forced through a bearing at surface speeds of 80 to 120 km/h. The slider ramps over the obstruction, scores the magnetic coating, and sprays fresh debris across the remaining surfaces. Our ULPA-filtered clean bench keeps airborne particulates out of the head-disk interface during head stack work.
The fly height must remain constant across the entire platter radius despite variations in air velocity. The ABS geometry is engineered to compensate: negative pressure regions at the leading edge balance positive pressure at the trailing edge where the read/write element sits. Some modern drives use thermal fly-height control (TFC), where a small heater embedded in the slider expands the tip by a few nanometers to fine-tune the gap during operation.
What Slider Form Factors Do Modern Drives Use?
Modern HDD sliders are standardized at the Femto form factor: 0.85 mm long, 0.7 mm wide, and 0.23 mm thick. The previous-generation Pico slider (1.25 mm by 1.0 mm by 0.3 mm) is still found on older platters but has been phased out of new-build drives. The Femto footprint is roughly half the Pico footprint, which reduces slider mass and improves shock tolerance during seeks.
The air bearing surface is not a flat pad. It is etched into multiple step levels that together hold the slider in a stable equilibrium of pitch, roll, and altitude. A typical Femto ABS uses three depth levels: a no-etch primary rail surface, a shallow step recess of approximately 300 nm at the leading edge that generates a high positive pressure ramp, and a deeper cavity of up to 2.5 µm that generates sub-ambient suction across the central body of the slider. The combined positive and negative pressures produce a high-stiffness air bearing that resists changes in fly height during track-to-track seeks and rotational vibration. The trailing pad carries the read and write elements and sits closest to the platter; the pitch angle is set so that the read/write transducers are the lowest point on the slider profile.
The ABS pattern is also the reason that even a microscopic blob of lubricant or a single corneocyte under the slider does more than just block the head. It alters the local pressure profile. The slider responds by either lifting off track or pitching forward into harder contact, depending on where the contaminant sits relative to the rails. This is the mechanism behind several of the fly-height degradation modes described later on this page.
What Read Sensor Technologies Do Hard Drive Heads Use?
The read element and the write element on a modern head are two different structures stacked on the same slider. The write element is a tiny electromagnet; current through a copper coil drives a focused field through a write pole to flip magnetic domains on the platter. The read element is a passive sensor whose electrical resistance changes in response to the magnetic field coming off the platter surface. The sensor technology has gone through three generations.
- MR (magnetoresistive)
- First introduced by IBM in the early 1990s. An MR sensor is a thin strip of nickel-iron alloy whose resistance changes by a few percent when a magnetic field crosses it. MR heads enabled the jump past 1 Gb per square inch. They were replaced once areal density outpaced what the anisotropic magnetoresistive effect could resolve.
- GMR (giant magnetoresistive)
- Dominant from the late 1990s through the mid-2000s. A GMR sensor is a sandwich of two ferromagnetic layers separated by a non-magnetic conductive spacer. When the field polarity on the platter aligns the two layers, resistance drops sharply. The effect is large enough to resolve smaller magnetic domains, which is what carried drives from single-digit Gb per square inch into the hundreds.
- TMR (tunneling magnetoresistive)
- Standard on current drives. The conductive spacer of a GMR stack is replaced with a thin insulating barrier, typically magnesium oxide. Electrons tunnel through the barrier in quantities that depend on the relative alignment of the two ferromagnetic layers. The resistance swing is larger than GMR, which is why TMR heads were required to push areal density past the roughly 100 to 150 Gb per square inch ceiling that GMR could not exceed.
From a recovery standpoint, the sensor generation affects donor matching. A TMR read element is more sensitive to electrostatic damage during handling and more intolerant of fly-height excursions than the MR sensors on older drives. The parameters the drive firmware uses to bias the sensor, calibrate write current, and interpret the read channel output are stored in adaptive tables in the System Area. Those adaptives are tied to the specific head stack that was calibrated against them at the factory. A donor head stack with a different sensor variant or a different preamp will not read the platters correctly until the adaptives are either re-used from the original PCB or translated through PC-3000 utilities.
GMR vs TMR Comparison
| Property | GMR | TMR |
| Current geometry | Current-in-plane (CIP), some late CPP variants | Current-perpendicular-to-plane (CPP) |
| Spacer between magnetic layers | Conductive metal (typically copper) | Thin insulating barrier (typically magnesium oxide) |
| Physical mechanism | Spin-dependent electron scattering at the spacer interface | Quantum-mechanical electron tunneling through the MgO barrier |
| Signal amplitude per bit | Moderate | Several times higher than GMR at the same dimensions |
| ESD damage threshold | Tolerates higher transient currents | Order-of-magnitude lower; published research cites damage currents as low as about 4 mA and sub-nanosecond transients under 1 V as sufficient to break down the MgO barrier |
| Practical areal density ceiling | Up to roughly 100 Gb per square inch | Above 1 Tb per square inch with modern stack designs |
Bias-Current Sensitivity and Recovery Implications
A TMR sensor is biased by a small DC read current supplied by the preamp chip on the HSA. The factory calibrates an initial bias current per head and stores it in the System Area adaptives alongside the preamp gain and channel parameters. When the sensor degrades from thermal asperity events or partial head-disk contact, the read signal amplitude drops, and the obvious response is to raise the bias current to recover signal margin.
The constraint is that the MgO barrier breaks down at very low current levels. Pushing the bias above the calibrated tolerance band exceeds the dielectric strength of the tunnel barrier and causes either an immediate hard short or a slow drift of the head's transfer curve that ends in dead silence on subsequent reads. PC-3000 Express exposes the per-head bias and preamp gain registers so that bias adjustments can be made in small steps with the channel parameters re-tuned between passes. The same control surface allows the technician to clamp the bias at the calibrated value while raising channel gain or retuning the equalizer first, which is the safer recovery order on a weakening TMR head.
ESD discipline at the bench follows from the same physics. A single ungrounded touch on the preamp side of the flex can drop a transient through the MgO barrier of any head in the stack and silently degrade the read curve without producing a visible failure until the imaging pass starts.
What Does the Preamp Chip Do?
The signals produced by the read element are measured in microvolts. Sending these tiny signals down a flex cable to the PCB would introduce noise that overwhelms the signal. To solve this, every modern hard drive has a preamplifier (preamp) chip mounted directly on the head stack assembly (HSA), millimeters from the read/write elements.
- Preamp
- Amplifies the microvolt read signal to millivolt levels before sending it to the read channel chip on the PCB. Also drives the write current to the write element. Each head pair (read + write) has its own preamp channel.
- Flex Cable
- A thin polyimide ribbon connects the preamp to the PCB connector. It carries amplified read signals out and write signals in. Damage to the flex cable produces symptoms identical to head failure.
- Read Channel Chip
- Located on the PCB, the read channel chip converts the analog signal from the preamp into digital data. It applies signal processing algorithms to extract data from noisy signals.
The preamp chip is the single most common point of failure in the signal path. Electrical surges, flexing of the HSA during impact, and thermal stress can all damage preamp channels. A preamp failure on one channel disables the corresponding head. If the failed head is needed to read data, a head swap is the only path forward.
What Are the Common Head Failure Modes and Symptoms?
Head failures are the most common mechanical failure in modern hard drives. The symptoms vary depending on how the heads failed and how many heads are affected.
| Failure Mode | Symptoms | Mechanism |
| Head crash | Grinding or scraping sound, then drive stops responding | Slider contacts platter surface, scoring the magnetic coating and generating debris |
| Stiction | Drive does not spin up, or beeps on power-on | Heads stick to platter surface due to surface tension. Common after drops or prolonged storage |
| Preamp failure | Clicking, intermittent detection, partial reads with bad sectors | One or more preamp channels damaged by surge or thermal stress. Drive clicks as it retries with failed channels |
| Head degradation | Increasing bad sectors, slow reads, SMART warnings (reallocated sectors) | Read element sensitivity degrades over time. Read signal drops below threshold on weak sectors first |
| Partial head failure | Drive detected but files on certain platters are inaccessible | One head in a multi-head drive fails. Data on that platter surface becomes unreadable while other surfaces work normally |
How Does a Dual-Stage Microactuator Keep the Head On Track?
A dual-stage servo combines a voice coil motor for coarse positioning with a piezoelectric (PZT) microactuator near the slider for fine positioning. The VCM moves the entire actuator arm to the approximate track; the PZT element flexes the suspension tip by a few hundred nanometers to land the read element exactly on track. Modern drives need this two-stage system because track widths have shrunk well below what the VCM alone can resolve within the bandwidth budget of the servo loop.
The PZT elements are bonded to the base of the suspension between the E-block and the gimbal. Applying a control voltage causes one element to expand while the other contracts, rotating the slider through a few hundred nanometers of cross-track travel. Because the moving mass is just the slider and the suspension tip rather than the entire E-block, the microactuator loop runs at a much higher bandwidth than the VCM loop. This bandwidth is what allows the servo to reject rotational vibration picked up by the chassis RV sensors and to settle on a narrow track without overshoot.
For recovery, the PZT stage adds failure surfaces. PZT ceramic is brittle, and bending the suspension during HSA extraction or insertion can crack the element. A cracked PZT loses its fine-positioning authority, so the drive either fails to lock onto the servo wedges or locks with elevated position-error signal that drives sector retries. A donor HSA installed without re-using or translating the System Area adaptives has a PZT that responds to the same control voltage with a different physical deflection, so the heads land off-track even when the VCM positions correctly. A drive that spins up, identifies, and then sweeps back and forth without locking, ending with the actuator striking the parking ramp at rhythm, is one of the classic signatures of a PZT or micro-jog mismatch after a swap. The same surface acoustic signature shows up on a drive whose original heads are alive but whose servo data on the platters has been damaged, which is why we cross-reference the symptom against the clicking hard drive symptom guide before deciding whether a head swap is on the recovery path.
How Are Heads Handled During a Head Swap?
A modern HSA cannot be lifted off the platters by hand. The suspension spring tension will snap the sliders together the moment they leave the parking ramp, shearing the TMR sensors and the trailing-edge pad against each other. The procedure uses a family-specific head comb that holds the sliders at the correct vertical spacing, a parking ramp as the transfer surface, and ESD-grounded tooling at every step. The ordered sequence below is the bench protocol we follow inside the ULPA-filtered clean bench. The full procedure, donor preparation, and post-swap firmware alignment are documented separately in what a head swap involves.
- Open the drive on the laminar flow bench, lid facing into the downward airflow, with the spindle motor unpowered. The ULPA filtration keeps the head-disk interface clear of the 0.12 µm and larger particles that would otherwise drift onto the platter during the open-lid window.
- Confirm the patient heads are seated on the parking ramp at the outer diameter. If the heads stuck to the platter surface (stiction) during a power loss or drop, a head unstick tool is used to lift and guide them horizontally back onto the ramp before anything else is touched. Dragging stuck heads across the data zone destroys the magnetic surface.
- Insert the family-specific head comb between the suspension arms while the heads sit on the ramp. The comb (for example, an ST3-4 tool for Seagate 3.5-inch four-platter stacks, or a Western Digital W-series comb for WD families) locks the vertical spacing of the sliders to the donor platter pitch.
- With the comb in place, pivot the HSA off the ramp and unbolt the actuator pivot. The comb prevents the sliders from collapsing onto each other during extraction.
- Transfer the patient platter stack and the donor HSA into the working drive body. The donor HSA, already combed and stored in its anti-static carrier, is fitted to the pivot and walked back onto the parking ramp before the comb is removed. The comb is only released once the sliders are riding the ramp.
- Re-align the patient PCB or transfer the patient ROM and adaptives onto the commissioned drive's PCB using PC-3000 Portable III or PC-3000 Express. A donor HSA driven by its own original adaptives instead of the patient's will not read the patient platters even when the mechanical install is perfect.
- Spin up under PC-3000 control, verify per-head signal amplitude and PES distribution before opening any imaging session, and only then start the controlled imaging pass on PC-3000.
What Causes Fly Height to Degrade Over Time?
Fly height degrades through several distinct mechanisms, each of which leaves a different signature on the imaging pass. The four most common are contact-start-stop wear on legacy drives, lubricant migration onto the slider, thermal asperity events, and head-disk interference. Each one narrows the air gap or damages the read element in a way that shows up as a per-head bad-sector pattern long before the drive stops responding entirely. The mechanical end state of any of these modes is described in more detail on what happens during a head crash.
- Contact-Start-Stop (CSS) Wear
- Older drives parked heads in a textured landing zone on the inner diameter of the platter rather than retracting to a load/unload ramp. Every spin-up and spin-down cycle dragged the slider across the landing zone before the air bearing built up, wearing both the platter texture and the DLC (diamond-like carbon) coating on the slider. Drives still in service from the CSS era show progressive read amplitude loss on the inner tracks. Modern load/unload drives retract heads to an outer-edge ramp and avoid this wear path entirely.
- Lubricant Migration
- Platters carry a molecularly thin lubricant overcoat that lets the slider survive occasional low-altitude excursions without immediate damage. Over thousands of hours, especially under elevated drive temperatures, the lubricant migrates and accumulates on the ABS rails of the slider. The added mass and altered surface chemistry disturb the air bearing, destabilize the fly height, and eventually drag the slider into contact. The signature is a gradual rise in channel retry rates across all heads in a long-running drive.
- Thermal Asperity
- A thermal asperity is a brief, localized contact between the TMR read element and a microscopic bump or particle on the platter surface. The friction spike heats the sensor, the resistance shifts well outside its normal swing, and the read channel sees a transient that looks like a giant magnetic event. The drive firmware filters these out where it can, but repeated asperity events at the same radial location degrade the sensor and corrupt the sectors at that location.
- Head-Disk Interference (HDI)
- HDI is sustained physical contact between the slider and the platter. Even a short HDI event shears DLC off the slider or the platter, generates debris that the air stream pushes under adjacent heads, and starts a cascade that ends in a full head crash. The recovery decision after suspected HDI is whether to attempt an imaging pass at all; once debris is loose in the chassis, every additional spin-up risks contaminating surfaces that are still readable.
On the imaging bench, the order in which these modes are addressed matters. A drive showing the slow-drift pattern of lubricant migration can be imaged on its original heads with PC-3000 under capped retry budgets and per-head pass ordering. A drive showing thermal asperity spikes localized to one head benefits from PC-3000 per-head channel tuning before imaging. A drive showing the rising-noise signature of HDI is opened in the clean bench and evaluated for a head swap before any further spin-up, because every additional rotation against debris reduces the surface area still recoverable from the donor pass.
How Many Heads Does a Hard Drive Have?
The number of heads in a drive depends on the number of platters and whether data is written on one or both surfaces. Manufacturers configure the head count to hit a target capacity at a given areal density.
Head configuration matters for recovery because a head swap donor drive is matched on head count, head map, and preamp compatibility. Capacity variants inside one family are not donors for each other.
What Makes a Donor Head Stack Compatible?
A donor head stack assembly is not interchangeable by model number alone. Two drives with identical part numbers on the label can carry incompatible head stacks if they were built in different production runs. Before a donor is pulled from the shelf, its head stack must match the patient drive across several dimensions.
- Preamp Revision and Family
- The preamp chip mounted on the HSA carries a revision code that the manufacturer uses to track silicon generations. A donor HSA with a different preamp revision drives the read and write channels with different bias currents, different write compensation curves, and different channel gain. The patient firmware's adaptive tables expect the original preamp's response curve; swapping in a mismatched preamp causes the drive to clock in but read garbage or fail calibration during the initial ID read.
- Head Stack Assembly Family
- HSA families are tracked by the manufacturer with internal part numbers distinct from the drive model number. Within a model family, the HSA generation changes as the head wafer changes. A Seagate Barracuda built in week 32 of a given year may carry a different HSA generation than the same model built in week 38, with different magnetic properties on the read element. Donor identification requires cross-referencing the patient label codes (site code, firmware revision, factory date code) against documented HSA family maps.
- Micro-Jog Tolerance
- Micro-jog is the small radial offset between the read element and the write element on each head, calibrated at the factory. Each head carries its own micro-jog value stored in the System Area. A donor head with a different micro-jog will write to one location and read from a different location, producing track misregistration. On drives where micro-jog values can be read from the patient adaptives, PC-3000 utilities can apply the patient's micro-jog profile to the donor heads. On drives where micro-jog is tied to the HSA ROM, the donor must already carry compatible values.
- Firmware Adaptives and ROM Data
- Adaptives are the per-head calibration tables the firmware uses to bias the read element, set write current, and tune the read channel. They are generated on the factory test track and stored in the System Area and sometimes the PCB ROM. After a head swap, the original adaptives must be preserved; either by retaining the patient PCB or by reading the patient adaptives out through a PC-3000 terminal session and writing them back into the assembled drive before the first spin-up with the donor heads.
- Head Map and Surface Pairing
- Multi-platter drives assign each logical head to a specific platter surface (upper or lower). The patient head map defines which physical heads are enabled and how they translate to logical head numbers. Donor HSAs pulled from drives with a different head map (for example, a 4-head donor for a 3-head patient built on the same model number) cannot be installed directly; the surface alignment will not match the patient adaptives.
- Write-Current and Pre-Compensation Tables
- Each head carries its own factory-calibrated write-current value, along with overshoot, undershoot, and write pre-compensation tables that shape the write waveform at high data rates. These values are stored per-head in the System Area adaptives. A donor head driven by the patient's write-current setting (when that donor head requires a different drive level to produce a clean transition on the platter) writes weak or distorted magnetic transitions. The result is sectors that look written but fail to read back, or that read back correctly cold and fail after a few read passes. Inside PC-3000 Express, the drive family utility exposes the per-head write-current table so a technician can verify the donor tolerates the patient's adaptives before any user data write is attempted, or constrain the commissioned drive to read-only operation if the tables cannot be reconciled.
- Fly-Height and TFC Heater Calibration
- Modern drives use thermal fly-height control (TFC, also called dynamic fly height or DFH). A small resistive heater embedded in each slider expands the tip a few nanometers to fine-tune the read/write gap. The heater resistance and the current-to-deflection curve vary between head wafers, so the firmware stores a per-head TFC calibration table generated on the factory test rig. A donor head with a different TFC heater profile, driven by the patient's stored heater current, will fly too high (loss of read signal amplitude) or too low (risk of head-disk contact). PC-3000 Portable III reads the TFC adaptive table during the SA module pass so the technician can confirm the donor's heater calibration falls inside the patient's tolerance band before commissioning.
- Suspension Resonance and Servo Loop Match
- The slider sits on a stainless-steel suspension whose mechanical resonance modes (typically a few kHz for the sway mode and tens of kHz for the gimbal mode) are characterized at the factory and notched out of the servo controller loop. HSA generations within the same model line sometimes shift these resonance frequencies as the suspension geometry is revised mid-production. A donor HSA with off-band resonance is excited by the same servo input the patient adaptives expect to be safe, which shows up as elevated position-error signal (PES) on the healthy heads after the swap and intermittent off-track writes. The servo parameter tables exposed through the PC-3000 Express drive family utility include the notch filter coefficients; a mechanically mismatched donor is detected by an abnormal PES distribution during the first servo lock.
Mismatches across any of these axes produce distinct symptoms after a swap. A preamp revision mismatch usually shows as a drive that spins up, identifies, and then fails to read the System Area or reads it with heavy retries. A micro-jog mismatch produces track-by-track bad sectors that move when the drive is power cycled. A write-current mismatch on a donor used to image read-only is harmless; if the same drive is later written to, the result is sectors that read clean immediately after write and degrade within hours. A TFC heater mismatch shifts read amplitude with drive temperature, so the imaging pass looks healthy on a cold drive and fails as the chassis warms. A true donor head failure (dead donor, damaged in storage) looks identical to the original head failure. Diagnosing which category a post-swap failure falls into is why donor selection uses multi-axis matching rather than model-number matching, and why our donor sourcing workflow is documented separately in how donor drives are matched.
How does the read channel pull bits off a weak head?
Once the signal path is intact, the read channel still has to turn a noisy analog waveform into bits. When heads are degraded but not dead, the drive's own error recovery procedures (ERP) run a fixed sequence of read retries with altered channel parameters. In production use the ERP is tuned for throughput, not salvage; it gives up quickly on hard sectors to keep the host operating system responsive. For recovery, the ERP is the wrong policy. A drive with weakening heads will burn through the remaining head life running aggressive retries on sectors that a patient, parameter-aware imager could skip and revisit.
On supported drive families, PC-3000 Portable III and PC-3000 Express communicate with the drive through its terminal (TTY) or factory port, below the normal ATA command interpreter. The Viterbi detector is a maximum-likelihood search implemented in fixed logic, with no accept or reject level to loosen; what changes is the signal handed to it. On a weak head with low read signal amplitude, raising the channel gain may recover sectors that the stock firmware rejected. On a head with high noise but adequate amplitude, reshaping the equalizer response can recover sectors the stock configuration dropped.
These adjustments are not universal. Each drive family exposes a different subset of channel parameters through PC-3000, and each patient drive responds differently based on the state of its heads, platter surfaces, and adaptives. The tuning is iterative: image a pass with the stock configuration, review the per-head bad-sector distribution, adjust the channel parameters for the worst-performing head, image another pass. Temperature also enters the picture; FLIR thermal monitoring during long imaging runs catches preamp heating that shifts the read signal amplitude and forces a parameter re-tune. The full tool chain and pricing tiers for this work are documented on our hard drive data recovery service page.
Why Head Failures Require Lab-Level Recovery
Data recovery software cannot compensate for a physical head failure. The drive firmware needs functioning heads to read the servo wedges, access the System Area (where firmware modules are stored), and read user data tracks. If the heads cannot read, the drive cannot initialize, and no software on the host computer can bypass that. This is one of the decision points covered in our guide to choosing a hard drive recovery service.
Continued operation damages data.
Running a drive with a partial head failure causes the damaged head to score the platter surface, spreading debris to surfaces served by the still-functioning heads. What starts as a recoverable single-head failure can become an unrecoverable multi-surface crash if the drive continues to run.
A head swap involves opening the drive in a particulate-controlled environment (laminar flow bench with ULPA filtration), removing the failed head stack assembly, and installing a matched donor HSA. After the swap, the drive's ROM chip data and adaptive parameters must be transferred from the original PCB to ensure the new heads can initialize with the drive's existing calibration data. PC-3000 handles this firmware alignment step. This work is performed at our Austin, TX recovery lab. The full procedure, tool chain, and donor-match criteria are described in what a head swap involves.
Why does a hard drive click?
Clicking occurs when the read/write heads cannot locate the servo wedges embedded on the platters. The voice coil motor sweeps the actuator arm back and forth searching for positioning data. If the heads are physically damaged, contaminated with debris, or the preamp chip has failed, the drive repeats this seek-and-fail loop, producing a repetitive clicking sound.
Can a clicking hard drive be fixed?
A clicking drive with a head failure requires a head swap in a particulate-controlled environment. A technician removes the head stack assembly and replaces it with compatible donor heads matched by firmware revision, head map, and preamp compatibility. Software cannot fix a physical head failure.
How close do hard drive heads fly to the platters?
Modern PMR hard drive heads keep a baseline aerodynamic clearance of a few nanometers and use thermal fly-height control to push the read/write transducers to an active magnetic spacing of about 1 to 2 nanometers above the platter surface. A human skin flake is roughly 1,000 nanometers thick. This clearance is maintained by an air bearing surface machined into the slider, which uses the air cushion generated by platter rotation to stay airborne.
What makes a donor hard drive compatible for a head swap?
A compatible donor must match the patient across several axes: preamp chip revision, head stack assembly family, micro-jog tolerance, head map and surface pairing, and firmware adaptives. Identical model numbers are not sufficient, because manufacturers ship drives under one part number that carry different head stack generations depending on the production date and factory site code. Donor identification uses the patient label codes cross-referenced against HSA family maps, not just the model number.
What is PRML in a hard drive read channel?
PRML is the signal processing pipeline the read channel chip uses to turn the noisy analog signal from the preamp into bits. In recovery, PC-3000 can retune the channel adaptives, the FIR equalizer taps, channel gain, target response, and retry behavior, to pull readable sectors off weak or degraded heads. The Viterbi detector itself is fixed logic and has no accept or reject level to loosen.
Why does write-current calibration need to match for a donor head swap?
Each head carries factory-calibrated write-current, overshoot, undershoot, and pre-compensation values stored in the System Area adaptives. The patient firmware drives the donor heads with the patient's stored values. If the donor heads need a different drive level to produce clean magnetic transitions, the written bits are distorted; sectors read back correctly immediately after write and degrade within hours. The PC-3000 Express drive family utility exposes the per-head write-current table so a technician can verify donor compatibility or constrain the commissioned drive to read-only operation if the tables cannot be reconciled.
What does PC-3000 verify before commissioning a donor head stack?
Technicians use PC-3000 Portable III and PC-3000 Express to read the System Area adaptive tables for each head, then manually compare those values against the donor's tolerances: preamp gain and bias, micro-jog offset, TFC heater calibration, write-current and pre-compensation values, and suspension resonance notch coefficients. The technician confirms that the donor falls inside the patient's tolerance band on each axis before any imaging pass begins. A donor that fails verification on a write-side parameter can still be used for read-only imaging; a donor that fails on a read-side parameter (preamp gain, TFC) is rejected.
