Why Rebuilding a Degraded RAID Destroys Data
When a drive fails in a RAID 5 array, the controller enters degraded mode: it can still serve data by calculating the missing drive's contribution from parity on every read. The standard response is to replace the failed drive and initiate a rebuild.
This process is one of the most dangerous operations in storage management.
Rebuilding a degraded RAID 5 pins every surviving member at close to 100% sustained read until it finishes, and that load, not a clean per-byte coin flip, is what most often finishes off a marginal same-batch survivor mid-rebuild. The consumer URE spec of 1 error per 12.5 TB is a worst-case warranty floor that raises the probability of hitting a latent unreadable sector as array size and drive age climb, never a deterministic schedule.
If the data is irreplaceable and you have no verified backup, image the drives first and attempt recovery against the images; our RAID data recovery service handles this workflow in-lab.
What Is URE Probability During RAID Rebuild?
Consumer hard drives carry a worst-case manufacturer specification of 1 Unrecoverable Read Error (URE) per 10^14 bits read, roughly 12.5 TB. That number is a warranty floor, not a schedule: most drives read far past 12.5 TB without a single URE, and errors cluster on aging or marginal drives rather than arriving on an independent per-byte basis.
A four-drive RAID 5 rebuild on 16 TB drives reads 48 TB across surviving members, which raises the probability of hitting a latent unreadable sector as a worst-case upper bound. If a URE does land during a degraded RAID 5 rebuild, the affected stripe cannot be reconstructed and its data is permanently lost.
Every hard drive has a specified URE rate. Consumer drives (WD Blue, Seagate Barracuda, Toshiba P300) are typically rated at 1 URE per 10^14 bits read, which equals approximately 12.5 TB. Enterprise drives (WD Ultrastar, Seagate Exos) are rated at 1 URE per 10^15 bits read (125 TB).
If a URE does land on a surviving drive during the rebuild, the controller cannot reconstruct that stripe and its data is permanently lost. What happens to the rest of the array then depends on the controller (see the controller behavior below); the binomial arithmetic also overstates random bit-rot while understating the correlated mechanical risk that is the more common real-world cause of a failed rebuild.
| Drive Size | Array (4-drive RAID 5) | Rebuild Read Volume | Worst-Case URE Bound (Consumer) | Worst-Case URE Bound (Enterprise) |
| 4 TB | 12 TB usable | 12 TB | ~1.0 | ~0.1 |
| 8 TB | 24 TB usable | 24 TB | ~1.9 | ~0.2 |
| 16 TB | 48 TB usable | 48 TB | ~3.8 | ~0.4 |
| 20 TB | 60 TB usable | 60 TB | ~4.8 | ~0.5 |
The URE rate is a statistical specification, not a guaranteed threshold. A drive may encounter UREs well before reaching 12.5 TB of reads, or it may never encounter one. The rates above represent the manufacturer's warranty specification: the point at which encountering a read error is within expected behavior, not a defect.
How Rebuild Stress Causes Surviving Drive Failures
The URE math only accounts for read errors. RAID arrays are frequently built from drives purchased together, with matching model, firmware revision, and manufacturing batch. When one drive fails, the survivors share the same wear profile; the rebuild's sustained sequential full-surface reads push marginal drives past their failure threshold, causing a second failure and total data loss.
Surviving drives face sustained sequential reads across their entire capacity for hours or days, depending on drive size and rebuild priority settings. This is a workload pattern that most drives rarely experience during normal operation.
Drives in the same RAID array are often purchased together, installed at the same time, and exposed to identical thermal and vibration conditions. They are the same model, same firmware revision, and similar manufacturing batch. This shared history means their wear profiles are correlated. If one drive has worn to the point of failure, the others in the array are at a similar wear state. The sustained stress of a rebuild can push a marginal drive over the edge.
Common failure modes triggered by rebuild stress include:
- Head degradation. Read/write heads that are near end-of-life may fail under continuous full-surface reads.
- Firmware timeout. If a drive encounters a difficult sector and its internal error recovery loop takes too long, the RAID controller may declare the drive failed (timeout). Hardware controllers hold a command timeout on physical disk queries; a consumer drive has no cap on its internal recovery loop on a damaged sector and can sit in it well past that window, while NAS-rated drives cap the drive-side retry near 7 seconds with TLER/ERC to stay under it.
How Does TLER Decide Whether a Rebuild Survives?
Desktop SATA drives ship without time-limited error recovery, so a weak sector triggers an uncapped internal retry loop that can run longer than the controller command timeout.
RAID-rated drives ship with TLER (Western Digital), ERC (Seagate), or CCTL (Hitachi, Samsung) that caps the drive-side retry near 7 seconds, so the drive surrenders quickly and lets the controller fall back to parity instead of waiting on the head to finish reseeking.
Dell PERC and LSI MegaRAID controllers enforce a command timeout for physical disk queries. A consumer drive that stalls past that window during a rebuild read will be issued a bus reset, marked as a second failure, and dropped from the array.
The underlying media is often still recoverable in a lab; the controller has already booted the drive out of the configuration. This is why mixing consumer drives into a hardware RAID 5 is a common cause of degraded-to-failed transitions during rebuild.
SCT-ERC support and value can be inspected with:
smartctl -l scterc /dev/sdXreads the current TLER value in deciseconds.smartctl -l scterc,70,70 /dev/sdXsets a 7-second read and write recovery limit on drives that accept the command.echo 180 > /sys/block/sdX/device/timeoutextends the Linux block-layer timeout to 180 seconds so the kernel waits for the drive's deep recovery cycle to complete instead of issuing a bus reset and ejecting the drive. This is the mdadm workaround for consumer drives with no TLER support.
Drive-Managed Shingled Magnetic Recording (DM-SMR) drives introduce a second timeout failure mode. Under the sustained writes of a rebuild, the drive pauses host I/O while it rewrites data into shingled zones. That pause routinely exceeds controller timeouts and causes the drive to be ejected mid-rebuild. The 2020 WD Red SMR incident documented this failure pattern in Synology and mdadm arrays, and ZFS resilver on SMR drives is known to abort for the same reason.
What Is the I/O Load During a RAID Rebuild?
During rebuild, the controller reads all surviving drives, computes XOR parity, and writes to the replacement drive simultaneously. Write performance drops sharply on arrays without battery-backed write cache. Rebuild times for a 16 TB drive in a busy production array can exceed 48 hours. Neither high nor low rebuild priority reduces URE risk or stress on surviving drives.
During rebuild, the array must continue serving production I/O while simultaneously reading all surviving drives and writing to the replacement drive. The controller is performing three tasks: reading source data from surviving drives, computing parity (recalculating the missing drive's contribution), and writing the rebuilt data to the new drive.
This creates a sustained I/O load across every drive in the array. On arrays without battery-backed write cache, write performance drops sharply during rebuild. Rebuild times for a 16 TB drive in a busy production array can exceed 48 hours.
Every hour the array operates in degraded mode during rebuild is an hour where a single additional failure means complete data loss. Many RAID controllers allow setting rebuild priority (low, medium, high). High priority completes the rebuild faster but further degrades production performance. Low priority preserves performance but extends the vulnerability window. Neither option reduces the URE risk or the stress on surviving drives.
A forced rebuild on a degraded RAID 5 with large consumer drives is a gamble with your data.
RAID 5 was designed in an era of drives measured in gigabytes. RAID 6 or mirrored configurations (RAID 10) are the appropriate choices for large-capacity arrays. If a RAID 5 array with large drives has lost a drive and the data is irreplaceable, a lab recovery is safer than a forced rebuild.
How Does Parity Recalculation Stress Marginal Drives?
For each stripe, the controller reads blocks from every surviving member, XORs them, and writes the result to the replacement drive. On a 16 TB replacement with a 64 KB chunk size, that is roughly 244 million chunk reconstructions. Every surviving drive runs at 100% sequential read throughout, pushing drives with weak heads or marginal preamps through their failure threshold.
The XOR parity math behind a RAID 5 rebuild is computationally cheap per stripe, but the volume of operations is substantial. For each stripe on the replacement drive, the controller must read the corresponding block from every surviving member, XOR them together, and write the result.
On a 16 TB replacement drive with a 64 KB chunk size, that is roughly 244 million chunk reconstructions across the rebuild. Hardware RAID controllers (Dell PERC, LSI MegaRAID, Adaptec) offload this to a dedicated ASIC; software RAID (mdadm, ZFS, Storage Spaces) consumes host CPU for every parity computation.
The stress on surviving drives compounds the URE risk. During normal array operation, each member sees a random mix of reads, writes, and idle time. During rebuild, every surviving drive is pinned to 100% sequential read utilization for the full duration.
A drive with a pending sector reallocation, a weak head, or a marginal preamp will be pushed through its failure threshold by this workload. The controller then interprets that failure as a second drive loss, and the array transitions from degraded to failed mid-rebuild.
Parity recalculation also amplifies the cost of a single read error. In a healthy RAID 5, a URE on one drive is recoverable because parity plus the other members reconstruct the missing block. During a degraded rebuild, there is no redundancy left; the array is already down one drive.
Any URE on a surviving member during rebuild is a direct, unrecoverable data loss for the affected stripe. What it does to the rest of the array is controller-specific: a legacy block-level or low-end consumer controller (and HP/HPE Smart Array P-series and E-series, which flag POST Error 1784 or 1786) aborts the rebuild and drops the volume, while modern Dell PERC and LSI/Broadcom MegaRAID puncture the stripe and finish the rebuild and Linux mdadm logs the bad LBA in its Bad Block Log and continues.
On the controllers that abort, that is the mechanism behind a RAID rebuild that fails partway through: the rebuild stops wherever the URE lands.
What Is the RAID 5 Write Hole and How Does It Compound a Rebuild?
The RAID 5 write hole is the gap that opens because a parity update is not atomic. Writing the changed data block and writing the recalculated parity block for that stripe are two separate disk operations. If power is lost between them, the parity on disk no longer matches the data in that stripe, and nothing on the array records which of the two writes was interrupted. The controller cannot detect or repair the inconsistency on its own, because parity alone cannot identify which member holds the stale value.
A rebuild turns that latent inconsistency into permanent data loss. To reconstruct a failed drive, the controller XORs all surviving members one stripe at a time and writes the result to the replacement. If a stripe's parity was already inconsistent before the drive failed, the XOR produces wrong bytes on the replacement rather than the original data. The rebuild still reports success, so the corruption is silent; it surfaces later as an unreadable file or a filesystem error, with no obvious link back to the power event that caused it.
The mdadm write-intent bitmap is often described as a fix for this, and that description is wrong. The bitmap records which stripe regions were in flight so that after an unclean shutdown mdadm re-syncs only those regions instead of resyncing the whole array. It narrows the resync window and reduces exposure, but it does not guarantee that a stripe's data and parity landed together, so it does not close the write hole. The features that actually close it are a dedicated md write-journal device and the Partial Parity Log, added for RAID 5 in kernel 4.12. Each records enough state to recover a consistent stripe after a crash rather than leaving parity in an unknown condition.
Btrfs carries the same hazard in its own parity code. The Btrfs project has long warned that its RAID 5/6 implementation has a non-atomic write hole and explicitly recommends against using Btrfs RAID 5/6 for data you cannot afford to lose. That warning shapes how Btrfs write-hole damage is treated during recovery. NAS units that run Btrfs as a single-device filesystem on top of mdadm RAID 5, including Synology SHR with Btrfs, Asustor, and TerraMaster, carry the write-hole exposure at the mdadm parity layer; the Btrfs layer there is not configured in its own RAID 5/6 parity profile, so a second parity-layer write hole applies only when Btrfs itself is placed in RAID 5/6 mode.
How Does RAID 6 Reduce Rebuild Risk Compared to RAID 5?
RAID 6 adds a second independent parity block (P and Q, computed via Reed-Solomon rather than pure XOR) to every stripe, allowing the array to survive two concurrent drive failures. A URE on a surviving drive during a RAID 6 rebuild is recoverable from the second parity block, so the rebuild continues rather than aborting. For arrays using drives of 8 TB or larger, RAID 6 is the appropriate parity configuration.
The cost is additional write overhead during normal operation and one less usable drive of capacity. A four-drive RAID 6 array provides 50% usable capacity versus 75% for RAID 5.
| Attribute | RAID 5 | RAID 6 |
| Parity blocks per stripe | 1 (XOR) | 2 (P via XOR, Q via Reed-Solomon) |
| Drive failures tolerable | 1 | 2 |
| URE during rebuild | Stripe permanently lost | Recovered from second parity block |
| Usable capacity (4 drives) | 3 drives (75%) | 2 drives (50%) |
| Random write penalty | 4 I/O per write (read-modify-write) | 6 I/O per write (dual parity update) |
The random write penalty is the reason RAID 5 persisted so long on small arrays: write amplification of 4 is already painful, and 6 is worse. On modern NVMe and SSD arrays the overhead is masked by device bandwidth. On spinning disks, RAID 6 is measurably slower for small random writes, which is why transaction-heavy workloads often use RAID 10 instead.
Why Are RAID 10 Rebuild Reads Smaller Than RAID 5 Rebuild Reads?
A RAID 10 rebuild reads only from the surviving mirror partner of the failed drive, not from every member. Replacing one failed 16 TB drive in an eight-drive RAID 10 produces 16 TB of rebuild reads against a single drive. Replacing one failed 16 TB drive in an eight-drive RAID 5 produces 112 TB of rebuild reads across seven surviving members.
The trade-off is 50% usable capacity. For arrays of 8 TB or larger drives where rebuild time and second-failure exposure matter more than raw capacity per spindle, RAID 10 is the parity-free choice with the smallest exposure window.
Why Do Synology, QNAP, and Buffalo NAS Rebuilds Destroy Data the Same Way?
Consumer and prosumer NAS boxes run standard Linux mdadm software RAID, so their rebuilds hit the identical URE risk this page already describes for hardware RAID 5. There is no proprietary silicon interpreting the parity: a degraded rebuild reads every surviving member end to end, faces the same URE-during-rebuild math, and carries the same second-drive-ejection risk documented above.
The array reassembles on a vanilla Linux workstation with the same tools an engineer would use on any mdadm set, because that is exactly what it is.
The specific stacks differ only in the layers above mdadm:
- Synology SHR (Synology Hybrid RAID) is standard Linux
mdadmaggregating mismatched-size partitions into RAID 1 or RAID 5 sets, governed by LVM, formatted Btrfs or ext4. It is not proprietary hardware RAID. Pulled from a dead DiskStation, the member drives reassemble on a Linux workstation withmdadm --assemble --readonlyand LVM activation. - QNAP QTS is
mdadmplus LVM plus ext4. The QuTS hero variant runs ZFS instead, but the mdadm rebuild risk is the QTS line, and QTS is the volume most QNAP units ship with. - Buffalo TeraStation layers XFS over standard Linux
mdadm. - Asustor and TerraMaster run
mdadmwith Btrfs or ext4. TerraMaster TRAID is a management layer functionally identical to Synology SHR, not proprietary silicon.
Because each of these is mdadm software RAID underneath, forcing a degraded rebuild through the vendor UI runs the same read storm across the same aging same-batch members and can eject a second drive the same way, on top of the SMR ejection risk already described.
If the data matters and there is no verified backup, image the members first and reconstruct against the images, the same imaging-first path used for any array. This is the workflow behind our NAS data recovery service, and the common outcomes of pushing rebuild instead are documented on our NAS RAID rebuild data loss page.
Prosumer NAS models add one rebuild trigger that hardware RAID servers do not have. On units such as the DS920+, DS1520+, and DS1621+, an M.2 NVMe drive used as a read/write cache can drop off the PCIe bus under heavy sustained write load when the consumer controller firmware panics, while it still holds uncommitted dirty writes.
Those writes are lost, and the underlying mechanical Btrfs or ext4 array is left incomplete and inconsistent, which DSM reports as "Volume Crashed." This happens before any rebuild starts, so a rebuild attempt then runs on an already-inconsistent array, stacking NVMe-cache-loss corruption on top of the URE rebuild risk. It is an additional NAS-specific trigger, not a guarantee, and it is one more reason to image before rebuilding rather than after.
What Should You Do Before Importing a Stale Member?
A drive that drops offline mid-array becomes a stale member: its data blocks are frozen at the timestamp of its failure, while the array continues to serve writes to the surviving drives. Image every member before that stale drive is reinserted and the controller is told to "Import Foreign Configuration."
A foreign configuration prompt shows up after a reboot where drive sled order is disturbed, a controller swap that reads the wrong metadata generation, or a hot-plug reseat of a previously failed drive performed in the hope that it will rejoin cleanly.
Block-level imaging of every drive in the array (including the stale one) and offline reconstruction against the images preserves the writes the survivors took while the array ran degraded. The reconstruction must use the original parity sequence, which is why a lab RAID recovery with Data Extractor Express RAID Edition or UFS Explorer is the recommended workflow once a foreign configuration import has been initiated.
What Are the Safer Alternatives to Rebuilding a Degraded RAID?
Before initiating any rebuild, create sector-level images of every surviving drive. Rebuild attempts can then be performed against the copies using a virtual RAID tool such as Data Extractor Express RAID Edition, R-Studio, or UFS Explorer. If a second drive fails during imaging, the sectors already read remain available. Touching production hardware before imaging is a common cause of unrecoverable RAID data loss. If the array is still running in degraded mode and nothing has been rebuilt yet, the safe troubleshooting sequence for a degraded RAID array covers reading the controller logs & counting the fault tolerance that's left before anyone authorizes a rebuild.
- Image all drives first. Before touching the array, create sector-level images of every surviving drive using a hardware imager (PC-3000 Portable III) or GNU ddrescue with a mapfile. For ddrescue on a weak member, run the bulk pass with
ddrescue -d -n -r0 /dev/sdX image.bin map.logfirst ( -d bypasses kernel cache via O_DIRECT, -n skips the scraping phase that pounds damaged surfaces, and the mapfile records the state of every sector). Run scraping passes ( -r3 ) only after the bulk image is secured. If the drive dies during imaging, the mapfile preserves every sector that was already read, so the next attempt resumes against the same image instead of starting from zero. - Virtual RAID assembly. Import the drive images into a RAID recovery tool (Data Extractor Express RAID Edition, R-Studio, UFS Explorer) and reconstruct the array virtually. This avoids any physical stress on the original drives and allows multiple reconstruction attempts with different parameters.
- Do not initialize or resync. If the RAID controller prompts to "initialize" or "resync" the array after detecting a problem, do not proceed without understanding what the operation will do. Some controllers will overwrite RAID metadata or parity data during initialization, making the original data unrecoverable.
What is a URE and why does it matter during RAID rebuild?
A URE (Unrecoverable Read Error) is a sector the drive's error correction cannot read. Consumer drives carry a worst-case spec of 1 URE per 12.5 TB of reads, a warranty floor rather than a schedule. During rebuild the controller reads every surviving drive, and on large drives that sustained read raises the worst-case probability of hitting a latent unreadable sector.
If a URE does land during a RAID 5 rebuild, the corresponding stripe cannot be reconstructed and its data is lost; whether the rest of the array survives depends on the controller (puncture, Bad Block Log, or abort).
Should I rebuild a degraded RAID array myself?
If you have verified backups, rebuilding is reasonable. If the data is irreplaceable, rebuilding a degraded RAID 5 is risky: the surviving drives share the same age and wear profile as the failed drive, and the rebuild subjects them to sustained stress. The safer approach is to image all drives individually first, then attempt a virtual rebuild from the images.
If a rebuild has already failed, review the failure modes documented on our RAID rebuild failed page before making the next move.
What should I do if my Dell PERC or LSI MegaRAID controller shows a foreign configuration after a reboot?
Do not click Import Foreign Configuration or Force Online without first imaging every member drive. Dell PERC and LSI MegaRAID controllers write new metadata when a foreign config is imported or an offline physical disk is forced online.
Power the server off, pull the drives in labeled order, image each one, then test the import on the images with a virtual RAID tool such as Data Extractor Express RAID Edition or UFS Explorer before touching production hardware.
Why does using consumer drives in a hardware RAID array make rebuilds fail?
Hardware RAID controllers (Dell PERC, LSI MegaRAID, HPE Smart Array, Adaptec) enforce a command timeout for physical disk queries. Desktop SATA drives ship without time-limited error recovery, so a weak sector triggers an uncapped internal retry loop that can run past the controller window. The controller interprets that stall as a drive failure, issues a bus reset, and drops the drive from the array. On a degraded RAID 5, the second drop ends the array.
RAID-rated drives (WD Red Pro, WD Gold, Seagate IronWolf Pro, Toshiba N300) ship with TLER, ERC, or CCTL that caps the drive-side retry near 7 seconds, which fits inside the controller window. Drives that support SCT-ERC can be inspected and reprogrammed with smartctl -l scterc /dev/sdX.
Does ZFS resilver or mdadm rebuild face the same URE risk as a hardware RAID 5?
Partially. ZFS resilver traverses the block pointer tree instead of reading entire drives sector by sector, so it touches only allocated blocks. A URE on a surviving drive during resilver is detected and repaired from the second copy of metadata (ditto blocks) or from the redundancy tier (raidz2 or raidz3).
ZFS on raidz1 is still vulnerable to a second drive failure during resilver, and ZFS on Drive-Managed SMR drives experiences the same write-stall ejections that abort hardware-controller rebuilds. Linux mdadm RAID 5 has the same URE failure mode as hardware RAID 5, but the write-intent bitmap shortens the resync window when a drive drops out transiently and is re-added without having been replaced. For drive sizes above 8 TB the safer parity choices on Linux are raidz2 or mdadm RAID 6.
What should I do the moment one drive fails in a degraded RAID array?
Stop writing to the array, then stop the array. Do not click rebuild, do not insert a replacement drive, and do not reboot the server to see if the drive comes back. Every host write to a degraded RAID 5 widens the gap between the surviving members and the failed drive, and every reboot risks the controller marking a second member as foreign or pending.
Power the server down cleanly, label each drive with its bay position, pull all members including the failed one, and image each surviving drive sector-by-sector to a separate target disk using a hardware imager such as the PC-3000 Portable III, or GNU ddrescue with a mapfile for software-only workflows. The failed drive is imaged last, and only if it still spins.
Reconstruction is then attempted against the images using Data Extractor Express RAID Edition, R-Studio, or UFS Explorer. Every operation against the original hardware is irreversible, so the imaging step preserves the option to retry with different parameters. Our RAID data recovery service handles this workflow end-to-end for arrays where the data is irreplaceable.
Why does Rossmann image surviving members to clones first and rebuild virtually instead of letting the controller rebuild onto a hot spare?
The rebuild pins the surviving members at 100% sequential read for hours or days on drives that may already be marginal.
By imaging each surviving member to a clone first, the lab freezes the on-disk state at the moment of intake; subsequent reconstruction attempts run against the clones, not the originals. If a clone read fails on a marginal source drive, the imaging tool's mapfile records exactly which sectors were missed, and a second pass with a different head map, slower read speed, or donor-head rework on the source drive can fill the gaps without restarting from zero.
The virtual rebuild itself runs in software (Data Extractor Express RAID Edition, UFS Explorer, R-Studio) where stripe size, parity rotation, block order, and member sequence can be tested against the actual filesystem until directories and file checksums verify. None of that is possible once a controller rebuild has completed and normal writes have resumed against the array. This is the same general principle behind every imaging-first workflow in single-drive hard drive data recovery, applied at the array level.
How long does a RAID 5 rebuild on multi-terabyte drives actually take, and how does that compound URE risk?
On an idle four-drive RAID 5 of 16 TB enterprise SATA drives with a high rebuild priority, the controller reads roughly 48 TB across surviving members and writes 16 TB to the replacement. Controller throttling, foreground I/O, and chunk-size overhead stretch real-world rebuilds on busy production arrays, and a large drive in a fully populated array can take several days.
Every hour the array runs degraded is an hour where one URE on a surviving drive loses a stripe, and one further drive ejection ends the array. Lengthening the rebuild window also lengthens the thermal-stress window on the surviving members; drives that spent years at low duty cycles are pinned to 100% sequential read utilization for days, which is the workload that exposes pending sector reallocations and weak preamps. A second ejection is a different failure state from a single lost stripe: it takes the set past the single-drive tolerance of RAID 5 and leaves you recovering a RAID 5 with two failed drives rather than a degraded one.
The duration alone is one of the reasons RAID 6 or RAID 10 are the appropriate parity choices for arrays of 8 TB or larger drives, independent of the URE probability math. If a rebuild has already aborted partway through, our RAID data recovery workflow recovers from images of the surviving members rather than retrying the controller rebuild. Whether an array absorbs a URE during that reconstruction, punctures the affected stripe, or aborts the rebuild depends on the redundancy level and the controller error-handling policy, and the per-stripe parity math behind it is worked through in how RAID parity works.
Do Synology, QNAP, and Buffalo NAS rebuilds face the same URE risk as hardware RAID 5?
Yes, because consumer and prosumer NAS boxes run standard Linux mdadm software RAID, not proprietary hardware RAID. Synology SHR is mdadm aggregating mismatched-size partitions into RAID 1 or RAID 5 sets, governed by LVM and formatted Btrfs or ext4; QNAP QTS is mdadm plus LVM plus ext4 (QuTS hero uses ZFS instead); Buffalo TeraStation is XFS over mdadm; Asustor and TerraMaster are mdadm with Btrfs or ext4, and TerraMaster TRAID is a management layer functionally identical to SHR.
Because each is mdadm underneath, a degraded rebuild reads every surviving member end to end and hits the same URE-during-rebuild math and second-drive-ejection risk as hardware RAID 5. The member drives reassemble on a vanilla Linux workstation with mdadm --assemble --readonly.
Prosumer models add one extra trigger: an M.2 NVMe read/write cache on units like the DS920+, DS1520+, or DS1621+ can drop off the PCIe bus under heavy write load while holding uncommitted dirty writes, leaving the underlying array inconsistent (DSM reports Volume Crashed) before any rebuild begins. Image the members first and reconstruct against the images rather than forcing a rebuild.
If you are experiencing this issue, learn about our RAID recovery service.
