RAID 5 Data Recovery Services
RAID 5 distributes single-parity data across three or more member drives. When one member fails, the array operates in degraded mode; when a second fails, the volume goes offline. We recover RAID 5 arrays by imaging each member through write-blocked channels, capturing RAID superblock metadata, and reconstructing the stripe layout offline using virtual RAID reconstruction software. This page covers RAID 5 specifically; for other levels, see our RAID data recovery service overview. Free evaluation. No data recovered means no charge.
Repair Warning
How Do You Repair a Degraded RAID 5 Array?
You do not run in-place filesystem repair on a degraded RAID 5. Image every member read-only first, then rebuild the array virtually from the clones. Running fsck, chkdsk, or mdadm --create against a live degraded array overwrites the exact on-disk state recovery depends on.
The repair tools that work on a healthy single disk are destructive on a degraded array. fsck, e2fsck, xfs_repair, and Windows chkdsk issue writes to the filesystem that overwrite the exact on-disk state a recovery engineer needs to reassemble the volume. Once a repair pass has rewritten the filesystem, later hex-level reconstruction is no longer possible. The kernel.org Linux RAID wiki states the rule: don't issue any commands that will write to the disks (like mdadm -C, fsck or even mount etc).
Two mdadm operations are the most common way a recoverable array gets destroyed before any imaging happens. Never run mdadm --assemble --force or mdadm --create on a degraded array before each member has been imaged through a hardware write-blocker.
mdadm --assemble --force overrides mismatched event counts to force assembly, and if a RAID 5 array is both dirty and degraded, forcing it online can lead to undetectable data corruption. mdadm --create erases and overwrites the RAID array information area of every involved member, destroying the original array geometry that virtual reconstruction depends on.
The correct repair path is read-only. Image each member through write-blocked PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager, then reconstruct the array virtually from the clones with Data Extractor Express RAID Edition. Parity is recomputed against stable images, never against degrading drives under a live rebuild. The full step-by-step sequence is in the sysadmin decision flow below, and the math on why a live rebuild of a large degraded array is so likely to fail is in the URE probability section.
Once writes are stopped and slot order is documented, the next step is the lab's free mail-in evaluation. Label each member with its slot number, ship the drives in, and the array is reconstructed offline from the clones at the Austin, TX lab.
Hard rule: stop all writes and image every member read-only before any repair, assemble, or create command touches the array. Contact us for a free evaluation first.
Updated June 2026
18 min read
Parity
What Is Parity in a RAID 5 Array?
Parity in RAID 5 is a distributed block, computed with bitwise XOR across each stripe, that reconstructs a missing member from the surviving data and parity blocks. It tolerates one failed drive only; a degraded rebuild reads every surviving member end to end and can hit a URE.
The parity block is the XOR of all data blocks in the stripe; any one missing block is the XOR of the remaining blocks including parity. Parity rotates across all members rather than sitting on a dedicated drive, which is what distinguishes RAID 5 from RAID 4. That single distributed parity buys availability and one-member fault tolerance, not a backup: it does nothing against a second concurrent drop, soft corruption, user deletion, or malware.
For how this fits the other levels, see our RAID data recovery service overview, the on-page detail on how XOR parity and de-striping work, and the URE probability that makes a degraded rebuild risky.
Distributing parity is what separates RAID 5 from the older dedicated-parity levels. RAID 3 and RAID 4 park every parity block on a single dedicated drive, which turns that drive into a write bottleneck because every write in the array has to update it. RAID 5 rotates the parity block across all members stripe by stripe, spreading the write load and the wear evenly.
The cost of that rotation shows up at reconstruction: the parity rotation scheme (left-symmetric, left-asymmetric, right-symmetric, or right-asymmetric) has to be identified before de-striping, because the wrong scheme reassembles the blocks in the wrong order and produces garbled output.
Parity Terms That Decide Recovery
Write penalty (read-modify-write)
Updating one data block in RAID 5 takes four I/O operations: read the old data block, read the old parity block, recompute parity by XORing out the old data and XORing in the new, then write the new data block and the new parity block. That four-I/O cost per small write is why RAID 5 trails RAID 0 (one write) and RAID 10 (two writes) on random-write workloads such as databases and virtual machine stores.
Distributed parity vs. dedicated parity
RAID 3 and RAID 4 store parity on one dedicated drive; RAID 5 rotates parity across every member. Distribution removes the single-parity-drive write bottleneck and spreads wear evenly. It also means the parity rotation pattern is part of the array geometry that virtual reconstruction has to recover from the on-disk metadata or from manual hex analysis before the volume can be de-striped.
Parity is availability, not a backup
Parity covers exactly one member failure so the array stays online. It does nothing against a second concurrent drop, a torn stripe from an unclean shutdown, filesystem corruption, accidental deletion, ransomware, or a stale drive resynced during a botched rebuild. A degraded rebuild also reads every surviving member end to end and can hit an unrecoverable read error on a marginal drive, with no second parity to fall back on. RAID is uptime; a backup is a separate copy on separate media.
Failure Modes
What Causes a RAID 5 Array to Fail?
RAID 5 fails when more than one member drive becomes unreadable at the same time, or when metadata corruption makes the controller unable to locate parity and data stripes across surviving members.
  • Second member failure during degraded operation. RAID 5 tolerates exactly one failed member by reconstructing its data from the remaining drives via XOR parity. While the array runs degraded, every read operation stresses all surviving members. If any of them has latent bad sectors or weak heads, it will fail under this increased load. Enterprise drives with an unrecoverable read error rate of 1 in 10^15 bits have a non-trivial probability of encountering an error during a full-array rebuild on large-capacity members.
  • Parity corruption from unclean shutdowns. When a RAID 5 array loses power mid-write, partial stripe writes can leave parity blocks inconsistent with their corresponding data blocks. The controller may not detect this inconsistency until the array needs to reconstruct a missing member, at which point the corrupted parity produces wrong data. Battery-backed write caches mitigate this, but consumer NAS devices (Synology, QNAP, Buffalo) rarely include them.
  • Firmware bugs in the RAID controller. Both hardware RAID cards and software RAID implementations (mdadm, ZFS, Btrfs) have shipped bugs that corrupt parity under specific write patterns. Linux kernel commit logs document multiple mdadm parity calculation fixes over the years.
  • Stale drive reintroduction. When a failed member is replaced and the array rebuilds onto a spare, the old drive contains data from before the failure. If someone reconnects that original drive, the controller may attempt to resync from stale data, overwriting current blocks with outdated content across the entire array.
  • Accidental volume reinitialization. NAS management interfaces sometimes present a "Repair" or "Create" option when a volume is degraded. Accepting that prompt can overwrite RAID superblocks and member metadata, destroying the parameters needed for reconstruction.
Controller vs Drive
What Is the Difference Between a RAID Controller Failure and a Member Drive Failure?
A RAID 5 array goes offline for two distinct reasons: one or more member drives failed, or the RAID controller itself failed. The recovery approach differs for each, and misdiagnosing the cause leads to destructive actions that overwrite surviving data.
When a member drive fails mechanically, the array loses one source of data blocks. The remaining members still hold valid data & parity. Recovery means imaging the surviving drives, performing a head swap on the failed member if it has physical damage, and reconstructing the volume offline from all member images.
Controller failure is different. Dell PERC and LSI/Broadcom MegaRAID store DDF variants on the trailing sectors of member drives. HP Smart Array stores RIS metadata near the start of each member drive, not DDF. The controller keeps a cached copy in NVRAM, but the array geometry travels with the disks.
We don't rely on the original controller at all. Each member is imaged through write-blocked channels on PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager. Virtual RAID reconstruction software parses the on-disk metadata structures from the cloned images to identify stripe size, parity rotation, & member ordering. The logical volume is assembled virtually, independent of any server hardware.
Controller Metadata
RAID Controller Metadata Architecture: DDF vs. RIS
Enterprise RAID controllers store array geometry in different on-disk locations. Dell PERC and LSI/Broadcom MegaRAID write SNIA DDF into trailing sectors of each member. HP Smart Array writes proprietary RIS near the start. Knowing which format is present determines where recovery engineers parse stripe size, parity rotation, and member order when the controller is bypassed.
Enterprise RAID controllers do not all store array configuration the same way. Dell PERC (PowerEdge RAID Controller) and LSI/Broadcom MegaRAID share a common ancestry and write SNIA Disk Data Format (DDF) metadata into a reserved area at the trailing sectors of each physical member. HP ProLiant Smart Array uses a proprietary RAID Information Sector (RIS) written near the start of each member.
Knowing which controller wrote the on-disk metadata determines where the recovery engineer parses array geometry from when the controller itself is bypassed.
In our process, the controller is not part of the recovery path. Member images are cloned through write-blocked PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager workflows. Virtual RAID reconstruction software then parses DDF, RIS, or mdadm superblock structures directly from the clones to recover stripe size, parity rotation, and member order without touching original disks.
Enterprise Storage Terminology
SNIA DDF (Disk Data Format)
Standardized on-disk metadata format used by LSI/Broadcom MegaRAID and Dell PERC controllers. Stored at the trailing sectors of each member drive so that the array geometry survives a controller swap. Parsing DDF from cloned member images is how we reconstruct the array when the original controller is dead, foreign, or unavailable.
RIS (RAID Information Sector)
HP ProLiant Smart Array proprietary metadata stored near the start of each physical member rather than the end. Like DDF, RIS allows the array to be reconstructed from the disks themselves. The location difference matters: an imaging workflow that reads only DDF offsets and not the head of the disk will miss RIS entirely on HP Smart Array members.
NVRAM Cache and BBU (Battery Backup Unit)
Hardware RAID controllers buffer writes in NVRAM backed by a battery or supercapacitor to survive power loss. When the BBU degrades or fails, the controller disables write-back caching. Writes that were held in NVRAM during an unclean shutdown can land on members as torn stripes, producing parity that does not match the corresponding data blocks.
Foreign Configuration
A state where the controller's NVRAM does not recognize the on-disk DDF (LSI/PERC) or RIS (HP) metadata as one of its own arrays. Common after a controller swap, an aborted rebuild, or moving disks between chassis. On Dell PERC, the BIOS prompts to Import the foreign configuration into NVRAM or Clear the DDF from the disks. Clear erases on-disk metadata; choosing it on a degraded RAID 5 destroys the geometry needed to reconstruct the array. See our Dell PERC foreign configuration recovery guide.
Transport Metadata
The slot order, enclosure ID, and SES (SCSI Enclosure Services) backplane data that identifies where each member physically lived. Recorded before drives are removed from a server because slot assignment is part of the recovery geometry on most hardware RAID controllers.
Rebuild Dangers
Why Does Forcing a RAID 5 Rebuild Risk Data Loss?
Forcing a rebuild on a degraded RAID 5 writes to every sector of the replacement drive and reads every sector of every surviving member. If any surviving member has latent errors, the rebuild fails partway through and leaves the array in a worse state than before the rebuild started.
Adding a replacement drive doesn't make RAID 5 safer or faster after a member has failed. It starts writes. The controller reads every surviving member, calculates each missing block from XOR parity, and writes reconstructed data to the replacement drive while the array has zero remaining redundancy.
  • A RAID 5 rebuild computes each stripe of the replacement drive by XORing the corresponding blocks from all surviving members. This requires a complete sequential read of every surviving drive. For a four-member array with 8 TB drives, that is 24 TB of reads under sustained load.
  • URE (unrecoverable read error) encounters during rebuild can fault a degraded RAID 5, though the outcome is controller-specific. Legacy and low-end controllers halt and drop the volume; modern PERC and LSI/Broadcom MegaRAID puncture the stripe and continue, losing only that stripe; mdadm logs the bad LBA and continues. The data in the affected stripe is lost in every case.
  • Repeated rebuild attempts compound the problem. Each cycle adds thermal stress and additional head wear to drives that are already under strain. Drives with marginal heads can progress from occasional read errors to complete head failure across multiple rebuild cycles.
  • Online expansion or RAID level migration (e.g., converting RAID 5 to RAID 6) during a degraded state is particularly destructive. These operations rewrite stripe geometry across all members. If the process fails midway, the array exists in a hybrid state that no standard tool can interpret without manual analysis.
For a full walkthrough of what happens when a rebuild fails mid-process and how to respond safely, see our guide on what to do when a RAID 5 rebuild fails.
If your array is degraded: Power down. Do not rebuild, repair, or reinitialize. Read our guide on recovering from a degraded RAID before doing anything else. Label each drive with its slot number and contact us for a free evaluation.
URE Probability
URE Probability: Why Large RAID 5 Arrays Fail During Rebuild
Large degraded RAID 5 arrays fail during rebuild mostly because the rebuild pins aging same-batch survivors at sustained read for the length of the pass and a marginal member fails under that load. Consumer drives are rated at a worst-case 1 URE per 10^14 bits read (about 12.5 TB), so a long rebuild also raises the chance of a latent unreadable sector.
A four-member RAID 5 rebuild on 8 TB drives forces the controller to read 24 TB sequentially across three surviving members. Applying the worst-case consumer URE floor as an upper bound puts the probability of encountering at least one URE during that 24 TB read near 85%, and around 18% on enterprise drives.
These are worst-case bounds: field studies (USENIX FAST; Backblaze) show most drives read far past their rated 12.5 TB without a single URE, and errors cluster on aging or marginal drives rather than arriving on an independent per-byte basis.
Drive ClassExample ModelsURE RateURE per Sequential ReadURE probability on 24 TB rebuild
Consumer SATASeagate Barracuda, WD Blue1 in 10^14 bits~1 sector per 12.5 TB~85%
Enterprise SATA/SASSeagate Exos, WD Ultrastar1 in 10^15 bits~1 sector per 125 TB~18%
A four-member RAID 5 made from 16 TB drives forces the rebuild to read 48 TB from the surviving members.
Against the worst-case 1 URE per 12.5 TB floor that read pass would encounter a handful of unreadable sectors, but the bigger problem is what hours of sustained full-surface read do to aging same-batch survivors: a marginal head, preamp, or bearing crosses its failure threshold mid-rebuild, and RAID 5 has no second parity block to cover a second drive going down.
What a single URE does when it lands depends on the controller. Legacy block-level hardware RAID and low-end consumer controllers (for example Intel RST) hard-abort the rebuild and drop the volume offline. Modern Dell PERC and LSI/Broadcom MegaRAID puncture the stripe: they write a bad-block placeholder, finish the rebuild, and keep the volume online, losing only the punctured stripe.
Linux mdadm records the bad LBA in its Bad Block Log and continues. The data inside that stripe is gone for good, but on a modern stack one URE does not take the whole array down.
This is why we don't attempt live rebuilds. We image every member offline using PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager with write-blocked member imaging workflows. Sectors that remain unreadable are flagged in the image map.
Parity is recalculated later against stable images, not against original drives while a controller is timing out commands.
Two observable states mean the rebuild is lost rather than still in progress: it halts at a fixed percentage and stops advancing, or the array flips from Degraded to Failed or Offline because a survivor timed out or returned fatal media errors. Repeated controller-side retries on a mechanically failing member accelerate physical degradation and subtract from what a lab can reconstruct. Forcing a member that dropped days or weeks earlier back online makes the controller recalculate parity from blocks that never received the writes taken while that member was absent, and each additional pass puts more full-surface sequential read load on the aging survivor that stopped the rebuild. If the array is sitting in one of those states, read what to do after a RAID rebuild has already failed before you restart anything.
TLER, ERC, and the Timeout Cascade
URE math explains why a sector cannot be read. Time-Limited Error Recovery explains why the rest of the array goes offline when that sector is hit. Enterprise drives implement TLER (Western Digital and HGST naming), ERC (Seagate naming), or CCTL (under the SCT command set) to cap internal retry attempts at around 7 seconds.
After that cap, the drive returns an error to the controller so the controller can recover from parity. Consumer drives have no such cap; they keep retrying a marginal sector, and Western Digital's own TLER documentation notes that recovery can easily run past the window a RAID card allows.
Hardware RAID controllers expect a command response inside an 8 to 10 second window. A consumer drive locked in extended internal error recovery looks dead to the controller. The controller drops the drive from the array.
On a degraded RAID 5 already running with zero remaining fault tolerance, that drop turns a single-member failure into a double-fault collapse before any sector was actually unrecoverable in the physical sense. Reseating the drive in another chassis often shows it is still readable; the failure was a protocol timeout, not a media defect.
This is why pulling consumer SATA drives into enterprise RAID at scale produces failure events that present as multi-drive failures but are actually TLER-induced dropouts stacking on top of URE probability. Imaging each member offline through PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager bypasses the controller's timeout window entirely. The imager tolerates whatever recovery latency a marginal drive needs without interpreting it as a failure event.
Decision Flow
Sysadmin Decision Flow for a Degraded RAID 5
When a RAID 5 enters a degraded state, the correct sequence is to halt further writes, preserve drive identity and slot order, image every member through a write blocker, and only then attempt array assembly from cloned images. The destructive moves are forcing a rebuild, importing a foreign configuration on a partially rebuilt array, and clearing on-disk metadata to suppress controller errors.
  1. Stop writes immediately. Power down the host through a graceful shutdown if the operating system is still responsive. If the array is already offline at the controller level, power down via the chassis. Continued writes during a degraded state increase the chance of a stripe write landing without a corresponding parity update.
  2. Document the array state before removing drives. Capture the controller event log, the RAID BIOS configuration screen, and any SMART data the controller exposes. Note which member is flagged failed and which were ever marked predictive failure or missing. Photograph the chassis front and back so the slot order is preserved on paper and not just in memory.
  3. Label every drive with its slot number and serial. Hardware RAID controllers care about slot assignment even when on-disk DDF or RIS metadata is intact. Software RAID stacks (mdadm, ZFS, Btrfs) care about device identity. Mismatched slot reinsertion is a common cause of post-recovery confusion.
  4. Do not click Import, Clear, or Foreign Config Import. On a degraded array, Import can pull a stale or mixed-rebuild DDF into NVRAM and force the controller to expose corrupted parity online. Clear erases the on-disk metadata that virtual reconstruction depends on. Neither option is safe until every member has been imaged.
  5. Do not force the array online or restart a rebuild. Force-online and Make-Online operations cause the controller to honor the current member states even when one of them is dropping commands. Restarting a stalled rebuild reissues the same sustained sequential reads that triggered the URE in the first place.
  6. Image every member through a write blocker. Connect each drive in turn to PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager with the hardware write-block path engaged. A member that turns out to have mechanical damage receives a donor head transplant on a 0.02 micron ULPA-filtered clean bench before imaging.
  7. Extract controller metadata from the clones. Parse DDF from the trailing sectors of LSI/PERC member clones, RIS from the leading sectors of HP Smart Array clones, or mdadm/ZFS superblocks for software RAID. Stripe size, parity rotation, and member ordering come out of this step rather than out of guesswork.
  8. Reconstruct the array offline against the clones. Virtual RAID reconstruction software assembles the logical volume from member images. Parity is recalculated against stable images, not against drives that may be one read away from additional sector loss. A failed rebuild is recoverable from this state because the original members are untouched.
Hard stops for degraded arrays: never run the controller's Force Online, Make Online, Repair, or Initialize options on a RAID 5 that has lost a member. Never accept Foreign Config Clear. Never run dd, ddrescue, or any imaging tool against a drive without a hardware write-blocker between the drive and the imager.
Process
How Does RAID 5 Data Recovery Work?
We recover RAID 5 arrays by imaging each member independently, capturing RAID metadata from superblocks or controller metadata, and assembling the array virtually from cloned images. No data is written to your original drives at any point.
  1. Evaluation and documentation. Record the NAS or controller model, RAID level, member count, filesystem type (EXT4, XFS, Btrfs, ZFS, NTFS), and any prior rebuild or repair attempts. This step is free.
  2. RAID metadata capture. Before imaging begins, we read RAID superblocks from each member to extract stripe size, parity rotation direction (left-symmetric, left-asymmetric, right-symmetric, or right-asymmetric), member ordering, and data offset. These parameters define how blocks are distributed across members. Capturing them from the original superblocks avoids guesswork during reconstruction.
  3. Write-blocked forensic imaging. Each member is connected through hardware write-blockers to PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager. A member that turns out to have mechanical damage receives a donor head transplant on a 0.02 micron ULPA-filtered clean bench before imaging. Imaging uses adaptive retry settings and head-maps to maximize data capture from weak sectors.
  4. Offline virtual assembly. Virtual RAID reconstruction software loads the cloned images and assembles the virtual array using the captured metadata. De-striping reconstructs the logical volume by reading blocks in the correct interleaved order across member images. The tool validates parity consistency stripe by stripe: for each stripe, XORing all data blocks and the parity block should produce zero. Stripes that fail this check are flagged for manual analysis.
  5. Parity reconstruction for failed members. For each stripe where one member's data is missing (due to bad sectors or an unreadable member), the recovery tool XORs the remaining blocks to reconstruct the missing data. This is the same operation the RAID controller performs during normal degraded reads, but executed offline against stable images rather than against drives under stress.
  6. Filesystem extraction and verification. After array reconstruction, we mount the virtual volume read-only and extract files. R-Studio and UFS Explorer handle filesystem-level recovery for cases where the filesystem itself sustained damage. Priority data (databases, virtual machines, shared folders) is verified first.
  7. Delivery and secure purge. Recovered data is copied to your target media. After you confirm receipt, all working copies are securely purged on request.
Handling stale drives: If a stale member was reintroduced and a partial resync occurred, we compare block-level timestamps and parity consistency across all member images to identify which sectors contain current data versus overwritten content. This analysis happens on the cloned images, preserving the originals.
How Much Does RAID 5 Recovery Cost?
RAID 5 recovery is priced per member drive based on the failure type of each drive, with array reconstruction reviewed after member imaging. Published HDD pricing applies per member; modern helium drives use the helium HDD tiers. No diagnostic fees apply.
Published HDD Tiers, Applied Per Member
Each conventional member drive is imaged and billed from the same published HDD tiers below, based on that drive's failure type. A five-drive array with one head-swap member and four clean members is quoted as four logical-tier images plus one head-swap image, not as a single flat array fee.
Per-Member Imaging
  • Logical or firmware-level issues: From $250 to $600–$900 per conventional HDD member. Covers filesystem corruption, firmware module damage requiring PC-3000 terminal access, and SMART threshold failures that prevent normal reads.
  • Mechanical failures (head swap, motor seizure): $1,200–$1,500 per conventional HDD member with the listed deposit policy. Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Head swaps are performed on a 0.02 micron ULPA-filtered clean bench before write-blocked cloning.
  • Helium HDD members: $200–$5,000+ per member depending on the failure tier. Helium donor drives must be an exact match. Typical donor cost: $200–$600 depending on model and availability, plus helium refill cost ($400–$800) required after opening the sealed chamber.
Array Reconstruction
  • Reconstruction is reviewed after member imaging because member count, filesystem type (ZFS, Btrfs, mdadm, EXT4, XFS, NTFS), missing-sector overlap, and metadata damage determine the labor.
  • Virtual RAID reconstruction software performs parameter detection and assembly from cloned member images. R-Studio and UFS Explorer handle filesystem-level extraction after reconstruction.
No Data = No Charge: If we recover nothing from your RAID 5 array, you owe nothing. Free evaluation, no obligation.
Pricing basis: Each member is imaged and priced individually from the published HDD or helium HDD tiers. Array reconstruction is quoted after we know how many members image cleanly and whether parity metadata is intact.
Parity De-striping
How XOR Parity and De-Striping Work in RAID 5 Recovery
RAID 5 recovery depends on two operations: XOR parity reconstruction to regenerate missing blocks, and de-striping to reassemble data in the correct logical order from interleaved member images. XOR is a bitwise operation; the reconstruction is exact as long as all remaining blocks are intact and the parity rotation scheme is correctly identified.
  • XOR parity basics. For any stripe of N blocks (N-1 data blocks plus 1 parity block), the parity block equals the XOR of all data blocks. If block D2 is missing, XORing D1, D3, and P produces D2. This is a bitwise operation; no approximation or estimation is involved. The reconstruction is exact as long as all remaining blocks are intact.
  • Parity rotation. RAID 5 does not place parity on a single dedicated drive. Instead, parity rotates across members in a defined pattern. Identifying the correct rotation scheme is required before reconstruction; the wrong pattern produces garbled output.
  • Stripe size detection. The stripe size (commonly 64 KB, 128 KB, 256 KB, or 512 KB) defines how much contiguous data is written to one member before moving to the next. RAID superblocks store this value. When superblocks are damaged, we detect stripe size by analyzing entropy patterns across member images: boundaries between stripes from different files show measurable entropy transitions.
  • Member order verification. The physical slot order recorded by the controller must match the logical member order used during reconstruction. If drives were removed and reinserted in different slots, or if slot labels are missing, we verify order by cross-referencing data continuity across member boundaries. A correctly ordered array produces coherent file headers at known filesystem offsets; an incorrectly ordered one does not.
  • Parity inconsistency detection. After virtual assembly, we run a full parity check across every stripe. Stripes where the XOR of all blocks does not equal zero indicate prior write inconsistencies (from unclean shutdowns or firmware bugs). These stripes are individually analyzed to determine which block is incorrect, and the filesystem-level context is used to select the most plausible correction.
All-Flash RAID 5
How Do Member Identity and Capacity Errors Affect RAID 5?
A RAID 5 member reporting 0 bytes, a wrong capacity, or a wrong model string is a member preservation problem before it is an array reconstruction problem. That drive should not be placed back into a live rebuild because the controller will treat unreliable identity data as a normal failed member replacement event.
We handle identity and capacity errors at the array layer first. Slot order, controller metadata, and the last known member role are documented before any parity calculation is attempted. If the failing member can be stabilized, it is imaged through PC-3000 Express, PC-3000 Portable III, PC-3000 SSD, or DeepSpar Disk Imager depending on the device type.
Once every member image exists, the RAID controller is no longer part of the recovery path. Virtual RAID reconstruction software works from cloned images, validates parity stripe by stripe, and flags identity mismatches without writing a byte to the original members.
NVMe Tri-Mode
How Do You Recover an NVMe RAID 5 Array on a Broadcom Tri-Mode Controller?
You image each member on the transport it actually speaks, then reconstruct offline. On a Broadcom Tri-Mode MegaRAID, an NVMe U.2/U.3 member uses native PCIe and cannot be imaged through a SAS HBA in IT mode; it is cloned on a native PCIe path with PC-3000 SSD. The SNIA DDF geometry is identical to a SAS/SATA RAID 5, so the original controller is not required.
Broadcom Tri-Mode MegaRAID controllers (9560-16i, 9670-24i, 9580-8i8e) run SAS, SATA, and NVMe drives in the same drive bay via Tri-Mode SerDes over PCIe Gen4. The MegaRAID 9500 series is the first PCIe Gen4 RAID adapter family, and the 9560-16i is based on the SAS3916 RAID-on-Chip. The bays follow the SFF-TA-1001 (U.3) connector spec with Universal Backplane Management (UBM), so a single slot can hold a SAS, SATA, or NVMe member. For the full controller-level walkthrough of these cards, see our Broadcom Tri-Mode MegaRAID controllers recovery page.
The transport is the only thing that changes for recovery. An NVMe member speaks native PCIe, not SAS, so it cannot be imaged through a SAS HBA in IT mode the way a SAS or SATA member can. It is cloned on a native PCIe attach path with an NVMe-capable forensic imager. On this bench that tool is PC-3000 SSD, which covers NVMe and SATA SSD members; PC-3000 Express and DeepSpar Disk Imager handle conventional HDD members, and SAS members are imaged through a SAS HBA in IT mode behind a hardware write-blocker. This matches how flash members are already imaged elsewhere on this page.
Member typeTransportImaging path
SAS / SATA memberSAS or SATA over the controller backplaneRemoved from the chassis and imaged sector by sector through a host bus adapter in IT mode behind a hardware write-blocker.
NVMe member (U.2 / U.3)Native PCIeCannot be read through a SAS HBA in IT mode. Imaged on a native PCIe attach path with PC-3000 SSD, then treated as one more clone in the offline reconstruction.
A mixed-transport array (some NVMe members alongside SAS or SATA members) therefore requires two separate imaging workflows: the native-PCIe path for the NVMe members and the IT-mode HBA path for the SAS/SATA members. Both are completed before any virtual reconstruction begins. The image-before-reconstruct rule does not change; only the forensic hardware for the NVMe half changes.
Once every member is cloned, the array geometry is read the same way it is on any SAS/SATA RAID 5. The SNIA DDF metadata (stripe size, member and drive order, parity rotation, and epoch history) lives on the member disks, not in controller NVRAM, so controller death is not data loss and the original Tri-Mode controller is convenient but not required. Virtual reconstruction is performed offline from the clones with Data Extractor Express RAID Edition.
Parity Rotation
Engineering Insight: Manual Parity Rotation Detection
When the RAID controller is damaged or metadata is wiped, we determine stripe size and parity rotation by direct hex analysis of the raw member images. This is not a scan; it is a manual reconstruction of the array geometry from data patterns.
Identifying the Parity Rotation Scheme
RAID 5 controllers use one of four standard rotation patterns: left-symmetric, left-asymmetric, right-symmetric, and right-asymmetric. The difference is which member holds the parity block for each stripe and in which direction the assignment rotates. Left-symmetric (the most common default for mdadm and many hardware controllers) places parity on the last member for stripe 0, then shifts backward by one for each subsequent stripe.
To identify the scheme when metadata is missing, we open the first several hundred stripes in a hex editor across all member images simultaneously. Parity blocks have a distinct entropy signature compared to data blocks containing filesystem structures (EXT4 superblock copies, XFS allocation group headers, NTFS MFT entries). By mapping which member holds the high-entropy parity block at each stripe offset, the rotation pattern becomes visible within the first 8 to 16 stripes.
Stripe Size from Entropy Transitions
Stripe size defines the boundary at which data switches from one member to the next. Common values are 64 KB, 128 KB, 256 KB, and 512 KB. When superblocks are intact, we read the stripe size directly.
When they are not, we look for entropy transitions at regular intervals on each member image. A file stored sequentially produces low-entropy (structured) data that abruptly shifts to high-entropy (compressed or random) data at the stripe boundary where a different file or parity block begins. The interval between these transitions is the stripe size.
Virtual RAID reconstruction software automates much of this detection, but ambiguous cases (arrays with uniform compressed data, encrypted volumes, or mixed stripe sizes from online expansion) require manual verification against known filesystem anchor points. We cross-reference detected parameters against the filesystem superblock offset to confirm correctness before proceeding with full reconstruction.
Default Stripe Sizes by Enterprise Controller
When superblocks are damaged and entropy detection is ambiguous, vendor defaults narrow the search. Most administrators leave the controller's factory chunk size untouched at array creation time, so the default is what we test first during virtual reconstruction. A stripe size mismatch produces a scrambled mosaic: small files contained inside one chunk appear intact and may even open, while any file crossing a chunk boundary corrupts the moment the reader hits the wrong member.
Linux mdadm
512 KB default on modern kernels. Older kernels (pre-3.x era) defaulted to 64 KB, so arrays built on legacy distributions may carry the older value.
Dell PERC 8 and 9 (H330, H730)
64 KB default stripe element.
Dell PERC 10, 11, and 12 (H740, H755, H965)
Configurable from 64 KB to 1 MB. Dell documents the supported range for these generations, but the factory default varies by platform and build, so the stripe element must be parsed from the DDF metadata on the cloned member rather than assumed.
LSI / Broadcom MegaRAID
64 KB is the native WebBIOS and StorCLI factory default across most MegaRAID generations, including 9240-class SAS cards and 9361 firmware. OEMs that rebrand the hardware (for example Lenovo and some HPE configurations) frequently ship 256 KB stripes, so the value on the cloned member must be confirmed rather than assumed.
HP Smart Array (P400, P410, P420, P440)
The legacy P400 defaulted parity RAID levels such as RAID 5 to 16 KB, while modern Smart Array generations commonly default to 256 KB. The value parsed from the RIS metadata on the cloned member is authoritative.
Synology and QNAP (mdadm-backed)
Inherit the underlying Linux mdadm default of 64 KB on DSM and QTS releases that predate the kernel default change, and 512 KB on current releases. SHR arrays are mdadm plus LVM plus Btrfs or ext4, so the chunk size lives in the mdadm superblock and can be read directly from a cloned member.
RAID 5 Recovery Questions
How many drives can fail in a RAID 5 before data is lost?
RAID 5 tolerates exactly one member failure. The array continues operating in degraded mode using XOR parity to reconstruct the missing drive's data on the fly. A second simultaneous failure makes the array inaccessible through normal means, though partial recovery from the surviving members is sometimes possible depending on failure timing and overlap.
What is parity in a RAID 5 array?
Parity is a calculated value stored alongside data stripes that allows the array to reconstruct the contents of any single missing member. RAID 5 computes parity using XOR across each stripe: if you XOR all the data blocks in a stripe together, you get the parity block. If any one block is missing, XORing the remaining blocks (including parity) reproduces it. Parity blocks are distributed across all members rather than stored on a dedicated drive, which spreads the write load evenly.
Can a RAID 5 be recovered after two drives fail?
Sometimes. If the two failures occurred at different times, the drive that failed first may contain data that was still current at the time it dropped out of the array. We image both failed members and analyze the overlap window. In cases where one member has only minor degradation (weak heads, a small number of bad sectors), a full image can often be obtained after mechanical repair, which restores the array to single-fault tolerance and allows reconstruction.
What happens if a replaced drive is reintroduced to a RAID 5 array?
If the original failed drive is reconnected after a spare has already been resynced into the array, the controller may treat the stale drive as current and attempt to resync from it. This overwrites good data with outdated blocks. We capture metadata from all members and identify which blocks contain current data versus stale data during offline reconstruction.
How long does RAID 5 data recovery take?
A three-to-five member array where all surviving drives image cleanly takes three to five business days. Arrays with mechanically failed members that need head swaps or donor sourcing add four to eight weeks depending on part availability. The reconstruction phase itself (de-striping, parity validation, filesystem extraction) typically takes one to two days once all member images are complete. A +$100 rush fee to move to the front of the queue is available to move to the front of the queue.
Can you recover an HP Smart Array or Dell PERC RAID 5 without the original controller?
Yes. Dell PERC and LSI/Broadcom MegaRAID store DDF variants on the trailing sectors of member drives, while HP Smart Array stores RIS metadata near the start of each member drive. We image each member through write-blocked PC-3000 Express or DeepSpar Disk Imager workflows, then parse the on-disk metadata from cloned images for virtual RAID reconstruction.
Why does a RAID 5 member show 0 bytes or the wrong capacity?
A RAID 5 member that reports 0 bytes, a wrong model string, or the wrong capacity cannot be trusted in a live rebuild. The correct recovery path is array-layer preservation first: document slot order, image every readable member, stabilize the member that is dropping offline, then reconstruct parity from cloned images instead of letting the controller write to a replacement drive.
Why do large RAID 5 arrays fail during rebuild even when only one drive died?
Two things stack up during a rebuild. First, the rebuild reads every surviving member end to end (24 TB on a four-member array of 8 TB drives) under sustained load for the whole pass, which pushes aging same-batch survivors toward a mechanical failure mid-rebuild, and a single-parity array has no second parity to cover a second drive going down. Second, consumer drives carry a worst-case unrecoverable read error (URE) spec of 1 in 10^14 bits (about one unreadable sector per 12.5 TB), so a long read pass raises the chance of a latent bad sector. That URE figure is a warranty floor, not a schedule; field studies show most drives read far past it clean. Enterprise drives with a 10^15 spec lower the per-byte risk but not the correlated mechanical exposure. This is why we image each member offline through PC-3000 or DeepSpar rather than letting the controller attempt a live rebuild on degrading hardware.
Does RAID 5 recovery cost more than RAID 6 recovery?
Per-member imaging costs use the same HDD pricing tiers for RAID 5 and RAID 6. The difference is reconstruction risk. RAID 5 single-parity arrays require every surviving member to be readable for complete reconstruction, while RAID 6 dual-parity arrays can tolerate two missing members. Array reconstruction is reviewed after member imaging because member count, filesystem type, and missing-sector overlap change the workload.
Dell PERC asks to Import or Clear a Foreign Configuration. Which is safe on a degraded RAID 5?
Neither is safe before every member has been imaged. Import reads the SNIA DDF metadata from the disks into the controller's NVRAM and brings the array online using whatever state the disks currently report; on a partially rebuilt or degraded RAID 5 that can force corrupted, mixed-parity stripes online. Clear erases the DDF metadata from the disks, destroying the geometry needed for virtual reconstruction. The correct path is to power down, image every member through a write blocker, and parse DDF from the clones offline. The controller never has to make this decision once the recovery happens against cloned images.
What is HP Smart Array Error 1783 and is data still recoverable?
POST Error 1783 is an HP Smart Array Controller Failure: the controller has entered a hardware lock-up state during Power-On Self-Test and cannot initialize. The most common causes are a physically loose, failed, or missing Flash-Backed Write Cache (FBWC) or Battery-Backed Write Cache (BBWC) module, an I2C or flash ROM fault on the controller board, or outright controller silicon failure. Because the controller hardware has failed to initialize, it cannot access the array at all. The data on the member drives is usually intact and undisturbed precisely because the dead controller cannot interface with them. We image each member through write-blocked channels, parse RIS from the leading sectors of every clone, and reconstruct the array offline; the failed controller is not part of the recovery path.
Can SMR drives in a RAID 5 array cause the rebuild to fail?
Yes. SMR (Shingled Magnetic Recording) drives use a small CMR cache zone for incoming writes, then reorganize data onto shingled tracks during idle periods. A RAID rebuild is not an idle period; it forces sustained sequential reads across the surviving members and continuous sequential writes to the replacement drive. If the replacement drive is SMR, its CMR cache overflows under that sustained write load and the drive pauses to reorganize shingles, introducing multi-second latency spikes. The RAID controller interprets these pauses as drive timeouts and drops the SMR member from the array, turning a single-fault rebuild into a double-fault failure. We image SMR members offline at their own pace using DeepSpar Disk Imager, which tolerates the latency without marking the drive as failed.
Why is RAID 5 slower on writes than RAID 0 or RAID 10?
RAID 5 carries a write penalty from read-modify-write. To update one data block, the controller reads the old data block and the old parity block, recomputes the new parity by XORing out the old data and XORing in the new data, then writes both the new data block and the new parity block. That is four I/O operations for a single small write, against one for RAID 0 and two for RAID 10. This overhead is why parity arrays lag mirrored arrays on random-write workloads such as databases and virtual machine stores.
Why does RAID 5 distribute parity across all drives instead of using one parity drive?
RAID 5 rotates the parity block across every member, stripe by stripe, instead of pinning it to one dedicated drive the way RAID 3 and RAID 4 do. A dedicated parity drive becomes a write bottleneck because every write in the array has to update that single drive, and it concentrates wear on one spindle. Distributing parity spreads both the write load and the wear evenly across all members. This rotation is also why reconstruction has to identify the parity rotation scheme (left-symmetric, left-asymmetric, right-symmetric, or right-asymmetric) before de-striping; the wrong scheme produces garbled output.
Is RAID 5 parity the same as a backup?
No. RAID 5 parity is fault tolerance for availability, not data protection. It lets the array keep serving data through exactly one member failure, and nothing more. Parity does nothing against a second concurrent drive drop, an unclean-shutdown torn stripe, filesystem corruption, accidental deletion, ransomware, or a controller writing stale data during a botched rebuild. A degraded rebuild also reads every surviving member end to end and can hit an unrecoverable read error on a marginal drive, so the single-parity array offers no second copy to fall back on. RAID is uptime; a backup is a separate copy on separate media.
Can you recover an NVMe RAID 5 array from a Broadcom Tri-Mode controller?
Yes. Broadcom Tri-Mode MegaRAID controllers (9560-16i, 9670-24i, 9580-8i8e) run SAS, SATA, and NVMe members in the same bay over PCIe Gen4. An NVMe U.2/U.3 member uses native PCIe and cannot be imaged through a SAS HBA in IT mode the way a SAS or SATA member can, so it is cloned on a native PCIe path with PC-3000 SSD while SAS/SATA members are imaged through HBAs in IT mode. A mixed-transport array needs both imaging workflows completed before any virtual reconstruction begins. The SNIA DDF geometry (stripe size, member order, parity rotation, epoch history) lives on the member disks and is identical to a SAS/SATA RAID 5, so the original Tri-Mode controller is convenient but not required. We reconstruct the array offline from the clones with Data Extractor Express RAID Edition.
Ready to recover your RAID 5 array?
