iSCSI LUN Recovery
What an iSCSI LUN is and how it is actually stored
@iSCSI directory on Btrfs or ext4; on QNAP QTS it is an LVM logical volume carved from the storage pool.iSCSI exposes a block device to a remote server over a standard TCP/IP network. The server, called the initiator, sees the LUN as a local hard drive and formats it with its own filesystem. The NAS, called the target, receives SCSI commands over IP and translates them into reads and writes against its internal storage pool.
The critical detail most competitors miss is what happens on the NAS side. On Synology DSM, an Advanced LUN is a file inside the hidden @iSCSI directory, which Synology documents as holding LUNs and their snapshots, on the Btrfs or ext4 volume. The file appears to be the full provisioned size, but Btrfs only allocates extents on demand. On QNAP QTS, a Block-Based LUN bypasses the host filesystem entirely and is carved from the LVM storage pool as a logical volume.
This means recovery is never a single-layer operation. Engineers must reconstruct the RAID, parse the host filesystem or LVM metadata, extract the LUN container, and then parse the initiator filesystem inside it. A VMware ESXi host writes VMFS; a Windows server writes NTFS. Both of those filesystems live inside the LUN file or LVM volume on the NAS.
Because the container sits on top of the storage pool, the underlying array reconstruction has to succeed before the @iSCSI namespace is even addressable; a degraded or accidentally rebuilt RAID is the first failure we image and reassemble read-only. When the target is a packaged appliance, the same job overlaps with NAS data recovery, since the Synology or QNAP unit that presents the LUN is a Linux host managing those drives with mdadm, LVM, or ZFS rather than dedicated SAN hardware.
Why did my Synology iSCSI LUN disappear after a reboot?
@iSCSI directory. The data extents survive on the RAID; only the metadata pointer is severed.The LUN disappeared because the link between the iSCSI Target daemon and the underlying LUN file was severed. The most common causes are host filesystem corruption, a failed DSM update that reset the target configuration database, or an accidental deletion in SAN Manager.
When Btrfs on the host volume crashes, the directory tree that points to the LUN file under @iSCSI may become unreachable. The extents that hold the actual VMFS or NTFS data are still intact on the physical drives, but the metadata that maps logical LUN addresses to physical RAID stripes is damaged. Without that map, the iSCSI Target daemon cannot respond to SCSI READ commands from the initiator, and the datastore appears empty or offline.
A less common but equally destructive cause is snapshot rollback inconsistency. Synology Advanced LUN snapshots are built on Btrfs copy-on-write.
If a rollback is interrupted by power loss or insufficient free space, the metadata linking the active LUN to its snapshot base shatters. The LUN either fails to mount or mounts as corrupted raw space.
What is inside the hidden @iSCSI directory on a Synology volume?
Synology documents the hidden @iSCSI directory at the volume root as holding LUNs and their snapshots. A file-level LUN's data payload is stored there as a file on the Btrfs or ext4 host volume.
- LUN data file
- The file containing the block-level data written by the initiator. It holds the nested VMFS, NTFS, or ext4 filesystem.
Other internal files sit in that directory alongside it. Synology does not publish what each one holds, so we read them off the image rather than assign them roles from the file name. What the recovery actually depends on is the LUN data file and the Btrfs records that describe its block layout, and those are recovered with Btrfs forensic tools that locate the older inode or extent records from before the crash.
How are QNAP Block-Based and File-Based LUNs different?
QNAP offers two architectures, and the recovery path depends entirely on which one was configured.
| Feature | Block-Based LUN | File-Based LUN |
| Parent storage | LVM storage pool (or ZVOL on QuTS hero) | Standard ext4 or ZFS volume |
| Underlying layer | Direct LVM logical volume or ZFS ZVOL | Image file on the host filesystem |
| Thin provisioning | Supported | Supported |
| VAAI support | Full Copy, Block Zeroing, Hardware Assisted Locking, plus Thin Provisioning and Space Reclaim | Full Copy, Block Zeroing, and Hardware Assisted Locking; no Thin Provisioning and Space Reclaim |
| Recovery path | Reconstruct LVM metadata, parse thin-pool extents | Parse host filesystem, extract image file |
QNAP strongly recommends Block-Based LUNs for performance. The tradeoff is that recovery from a deleted Block-Based LUN requires deep LVM knowledge, because the logical volume metadata must be reconstructed from the LVM header backups stored on the member drives.
How do you reconstruct a deleted QNAP Block-Based LUN from the LVM thin pool?
vgcfgrestore, then carving the thin-pool extent map so each surviving virtual offset maps back to its physical RAID extent.A deleted QNAP Block-Based LUN is reconstructed by restoring the LVM logical-volume metadata offline from the header backups on the member drives, then carving the thin-pool allocation map and mapping the virtual offsets back to physical RAID space. Deletion unlinks the logical-volume metadata, but the thin-pool extents that held the LUN payload often survive until QTS overwrites them.
QNAP QTS stores a Block-Based LUN as an LVM logical volume carved from a thin pool, not as a file on a host filesystem. That distinction sets the recovery path.
On QTS the work targets the LVM layer; on QuTS hero a Block-Based LUN is a ZFS ZVOL, a separate block device inside the pool with its own copy-on-write semantics, and the reconstruction follows ZFS dataset logic rather than LVM extent logic. Identifying which platform wrote the array is the first decision, because a thin-LVM carve and a ZVOL reconstruction share no tooling.
The QTS reconstruction runs against forensic images, never the live array. The sequence is offline throughout:
- Reassemble the members read-only. Every member drive is imaged first, then
mdadm --assemble --readonlyrebuilds the array from the image files so the original mdadm superblock state is preserved and no write reaches a member. - Restore the LVM metadata. LVM writes a textual backup of the volume-group layout to a header area on the physical volumes.
vgcfgrestoreagainst that on-disk header backup rebuilds the volume-group and logical-volume definitions that the deletion unlinked, re-establishing the thin pool and the deleted volume's identity. - Carve the thin-pool extent map. Thin volumes do not occupy contiguous space; the thin pool tracks which physical extents back which virtual addresses through its own B-tree metadata. The allocation map is parsed so each surviving virtual offset of the LUN is tied back to the physical extent on the RAID that holds it.
- Export the reconstructed volume. Once the virtual-to-physical extent map is rebuilt, array-aware forensic software exports the logical volume as a raw image. That image is the LUN container, ready for the nested initiator filesystem to be parsed.
When the thin-pool B-tree metadata is itself damaged, the map is rebuilt bottom-up by gathering surviving leaf nodes rather than trusting the unlinked top-level pointers. This is why a deleted Block-Based LUN is not a file-undelete problem. There is no host filesystem directory entry to restore; the entire logical-volume and thin-pool addressing stack has to be reassembled before a single byte of the initiator's data is readable.
The thin pool itself is a thin logical volume in a QTS volume group, so the carve depends on the broader LVM metadata recovery work that restores the volume-group descriptor area before any extent map is parsed. That volume group rarely sits on a bare disk; it lives on the mdadm block layer beneath the LUN, which is why the array superblocks are examined and the members reassembled read-only before LVM is even activated.
What happens if a Synology iSCSI LUN snapshot rollback is interrupted?
btrfs restore.An interrupted Synology Advanced LUN snapshot rollback shatters the metadata linking the active LUN to its snapshot base, so the LUN fails to mount or mounts as corrupted raw space. Synology Advanced LUN snapshots are built on Btrfs copy-on-write, and a rollback rewrites the references that bind the live LUN to the snapshot generation it is being reverted to.
Power loss or insufficient free space partway through that rewrite leaves the LUN metadata describing a state that no longer matches the on-disk Btrfs generation. The LUN's logical-to-physical map is now inconsistent: the active LUN-file extents and the snapshot extents disagree about which blocks are current, and the iSCSI Target daemon either refuses to bring the LUN online or presents raw space the initiator reads as a corrupt VMFS or NTFS volume.
Forensic recovery is read-only. The goal is to locate the historical Btrfs generation tree root that still describes the pre-rollback block layout of the LUN file, then extract that file with btrfs restore against the image, which reads the older tree without writing anything back to the filesystem.
What you never do is the opposite: btrfs check --repair, btrfsck --repair, and mount -o recovery,ro all write updated pointers into the live Btrfs and overwrite the very copy-on-write generation roots that describe the pre-rollback layout. On a shattered snapshot rollback, those in-place operations convert a recoverable inconsistency into permanent loss of the prior generation.
Why can't I just run fsck or btrfsck --repair on the NAS?
btrfsck --repair and mount -o recovery,ro rewrite metadata in place and overwrite the historical copy-on-write generation roots that locate the LUN extents. Live repair is the most common cause of permanent iSCSI data loss.Running btrfsck --repair or fsck.ext4 on a live, degraded NAS is the single most common cause of permanent iSCSI data loss. These tools attempt to rebuild broken metadata trees in place.
On a CoW filesystem like Btrfs, that means allocating new blocks and updating pointers. The old tree roots are not erased, but the generation pointers that lead to them are overwritten.
If the repair logic guesses wrong, and it often does on a damaged chunk tree, the tool orphans the @iSCSI subvolume from the root tree. The LUN files inside it become unreachable by any standard mount.
Even worse, btrfsck --repair may decide that the unallocated extents holding the LUN data are free space and update the block group accounting to mark them as empty. The next write to the NAS will overwrite your VMFS or NTFS payload.
The same risk applies to mount -o recovery,ro. The recovery option replays the Btrfs log tree, which writes updated pointers to disk even when paired with ro.
If the log references corrupted blocks, the replay writes bad pointers into the live filesystem. What started as a mountable degraded volume becomes completely unmountable.
How do professional engineers recover a crashed iSCSI LUN?
Our workflow is strictly offline and non-destructive. We run every step on forensic clones, never the original drives.
- Write-blocked imaging: Every NAS member drive is cloned sector-by-sector with ddrescue or the PC-3000 Portable III. Write-blocking prevents the host OS from triggering Btrfs CoW or SCSI UNMAP space reclamation.
- Offline RAID assembly: We virtually reconstruct mdadm parity geometry, LVM volume groups, or ZFS pools from the cloned images on a forensic Linux workstation.
mdadm --assemble --readonlypreserves the original superblock state. - Host filesystem parsing: For Synology Btrfs volumes, we run
btrfs inspect-internal dump-superto inspect superblock copies, thenbtrfs-find-rootto locate historical tree roots with intact@iSCSInamespaces. For ext4, we use inode carving to locate the extent tree mapping the LUN file. - LUN file extraction: Once a valid root is found, we use
btrfs restore -t <bytenr>to extract the LUN file read-only. For QNAP Block-Based LUNs, we reconstruct the LVM thin-pool extent map and export the logical volume as a raw image. - Initiator filesystem mount: The extracted LUN file is exposed as a loopback block device with
losetup -f. We then parse the encapsulated VMFS, NTFS, ReFS, or ext4 filesystem and export the virtual machines, databases, or files to a separate storage array.
All work is performed in-house at 2410 San Antonio Street, Austin, TX 78705. We use named equipment: PC-3000 Portable III, PC-3000 Express, and a ULPA-filtered clean bench. Founded in 2008.
How is a VMFS datastore on an iSCSI LUN actually recovered?
A VMFS datastore on an iSCSI LUN is recovered through four nested extraction stages, because the VMFS lives inside the LUN container, the container lives inside the NAS host filesystem or LVM, and that layer lives on the reconstructed RAID. Each layer has to be peeled before the one inside it is even addressable, which is why this is not a single VMFS scan.
- Reconstruct the underlying array. The member drives are imaged, then the RAID or mdadm array is reassembled virtually from those images with
mdadm --assemble --readonlyon a forensic workstation. Nothing is parsed against the live members. - Parse the host filesystem or LVM metadata. On a Synology target the host Btrfs or ext4 filesystem is parsed to reach the
@iSCSInamespace; on a QNAP Block-Based target the LVM volume-group and thin-pool metadata is restored instead. This stage yields the location and addressing of the LUN container. - Extract the LUN container. The container itself is pulled out: the Synology LUN file under
@iSCSIextracted withbtrfs restore, or the QNAP logical volume exported as a raw image from the rebuilt thin-pool extent map. The output is a single block image representing exactly what the initiator saw as its disk. - Parse the initiator filesystem inside the container. The container is exposed as a loopback block device, and the initiator's own filesystem is parsed. For a VMware ESXi host that means navigating the VMFS heartbeat region, the VMFS metadata, and the VMDK descriptor and flat extents to rebuild each virtual disk. For a Windows initiator it means parsing NTFS. Only then are the VMs, databases, or files exported to a separate destination array.
This stack is why iSCSI recovery is not "just like recovering a VMDK." A flat VMDK sits directly on a host VMFS volume you can scan in one pass. A VMFS-over-iSCSI datastore is encapsulated: the VMFS bytes are interleaved through the LUN container's sparse or thin-provisioned addressing, which is itself interleaved through the host filesystem or LVM, which is itself striped across the RAID.
Raw block extraction skips every one of those translation layers, so it returns discontinuous fragments that no VMFS parser can mount. The extent maps at each layer have to be honored in order, or the VMFS heartbeat region and VMDK descriptors never line up with their flat extents.
The same nested-extent discipline scales up to dedicated enterprise SAN recovery, where the iSCSI or Fibre Channel targets are presented by a rack controller instead of a NAS appliance but still expose LUNs as thin-provisioned block devices. On a controller-based filer the LUN virtualization is even deeper, which is the case with NetApp FAS and ONTAP arrays that wrap each LUN inside a WAFL flexible volume before it ever reaches the initiator.
How is a TrueNAS iSCSI LUN different from a Synology LUN file?
A TrueNAS zvol is a block device carved directly from the zpool; it appears on the host at /dev/zvol/<pool>/<zvol>. It is not a Btrfs or ext4 file, and there is no @iSCSI directory to walk. The zvol has its own block size, set at creation and readable with zfs get volblocksize, which the recovery has to honor so the nested filesystem's blocks line up with the zvol's addressing.
The SCSI target daemon lineage differs by edition: TrueNAS CORE uses ctld, the FreeBSD CAM Target Layer daemon, and TrueNAS SCALE uses scst on Linux. The daemon is not the recovery layer, though. It only advertises the target and maps it to a backstore. The data lives in the zpool and the zvol, so recovery targets those, not the target daemon's configuration.
The recovery sequence is read-only from the first step. The pool is imported read-only and unmounted with zpool import -o readonly=on -N against forensic clones, never a plain zpool import on a degraded pool, which can hang and can commit writes. Then the zvol block device is read, and only then is the nested initiator filesystem inside the zvol, whether VMFS, NTFS, or a VHDX container, parsed and exported.
If the pool used ZFS deduplication, holding the Deduplication Table in ARC takes roughly 1 to 5 GB of RAM per 1 TB of deduplicated data. The table is stored on disk and read on demand, so the pool still imports on an undersized host, but iXsystems documents that loading it on demand can take days after an import or reboot. That is why the import is attempted read-only on a workstation with adequate RAM, never forced back on the original NAS that crashed in that state.
- Image every member drive. Each pool member is cloned first so the pool is only ever touched through the images, never the originals.
- Import the pool read-only and unmounted.
zpool import -o readonly=on -Nbrings the pool up against the clones without mounting datasets or committing any write. - Locate and read the zvol. The LUN is the zvol block device at
/dev/zvol/<pool>/<zvol>, which is read as the container image the initiator saw as its disk. - Parse and export the nested filesystem. The VMFS, NTFS, or VHDX inside the zvol is parsed and the virtual machines, databases, or files are exported to a separate destination.
Because the LUN is a zvol on a live ZFS pool, the recovery overlaps with the wider TrueNAS pool recovery work that reconstructs the zpool before any zvol is addressable. An all-flash TrueNAS pool's NVMe members are imaged with the PC-3000 SSD; SATA members are imaged with PC-3000, and SAS members through a SAS HBA with a hardware write-blocker. When the array geometry itself has to be reconstructed before extraction, that is done with Data Extractor Express RAID Edition against the member images.
How do you recover a Proxmox VE iSCSI LUN with LVM on top?
Proxmox drives the target with targetcli on the Linux LIO framework. The backing store beneath the LUN can be a ZFS zvol, an LVM thin logical volume, or a raw block device. Proxmox does not store LUNs in an @iSCSI directory, so the recovery path follows the backstore, not a hidden filesystem folder.
Adding an iSCSI target directly in Proxmox maps the whole raw LUN to a single VM disk. To run many VM disks with thin provisioning, Proxmox instead puts an LVM volume group on top of the iSCSI block device. That means recovery has to reconstruct the LVM volume-group header on the recovered target before any thin logical volume, each holding one VM disk, can be carved back out.
A common LIO failure mode is a lost mapping. targetcli reloads its configuration from /etc/rtslib-fb-target/saveconfig.json at boot. If the backing devices are not online when the service starts, the target-to-backstore mapping fails to restore and the LUN vanishes from the initiator. The extents usually survive; only the mapping is lost, which is a metadata problem, not a data-destruction event.
- Image the underlying disks. Every member or backing disk is cloned so all reconstruction runs against images.
- Recover the storage layer first. Import the ZFS pool read-only, or restore the LVM volume-group header with
vgcfgrestorefrom the on-disk backup, depending on which backstore Proxmox used. - Reconstruct the LVM-on-iSCSI volume group. The volume group Proxmox layered on the iSCSI block device is rebuilt so its thin volumes become addressable again.
- Carve the thin LV and export the guest. The thin logical volume holding each VM disk is carved, then the nested guest filesystem inside it is parsed and exported.
When the backstore is a ZFS pool, this recovery shares its first stage with Proxmox VE recovery, and the LVM-on-iSCSI reconstruction depends on the same LVM metadata recovery work that restores the volume-group descriptor area before any thin volume can be carved.
iSCSI LUN recovery is priced per member drive, multiplied by the number of drives requiring imaging and analysis. Standard consumer NAS drives use our HDD pricing tiers:
| Failure type | Price range |
| File system recovery (logical) | From $250 |
| Firmware repair (unrecognized / wrong size) | $600–$900 |
| Head swap (clicking / beeping) | $1,200–$1,500 |
Helium-filled enterprise drives (8TB and larger Toshiba MG, WD Ultrastar, Seagate Exos series) use helium-specific pricing: From $200 through $3,000–$4,500. A 5-bay NAS with four standard drives and one helium drive would be priced as the sum of the applicable per-drive tiers.
Rush service adds 100. +$100 rush fee to move to the front of the queue Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available.
No diagnostic fees. No data, no recovery fee.
How long does iSCSI LUN recovery take?
Imaging takes 6 to 10 hours per 4TB drive. A 4-drive NAS with a crashed Btrfs host filesystem typically takes 2 to 4 business days for RAID assembly, host filesystem parsing, LUN file extraction, and initiator filesystem export. If member drives have bad sectors or head degradation, bitwise imaging with PC-3000 adds time.
Thin-provisioned LUNs with heavy fragmentation or SCSI UNMAP history take longer because the extent map must be reconstructed from Btrfs chunk trees or LVM thin-pool metadata rather than simply copied sequentially.
Frequently asked questions
The LUN likely disappeared due to corruption in the underlying Btrfs or ext4 filesystem, severing the metadata link to the @iSCSI directory, or due to a failure in the Synology iSCSI Target daemon after a DSM update. The data extents usually remain intact on the RAID.
Synology documents the hidden @iSCSI directory as holding LUNs and their snapshots. A file-level LUN's payload is stored there as a file on the host Btrfs or ext4 volume, and it contains the nested filesystem (VMFS, NTFS, etc.) written by the connected server.
Can I recover an accidentally deleted QNAP block-based LUN?
Yes, if the storage pool has not been overwritten. Recovery requires extracting the drives, imaging them, and reconstructing the LVM thin-pool extent map offline to reassemble the deleted logical volume.
Should I run a filesystem check to fix a crashed LUN?
No. Running btrfsck --repair or fsck.ext4 on a live NAS overwrites Copy-on-Write metadata blocks that forensic tools need to locate previous valid states of the LUN. Live repair is the most common cause of permanent iSCSI data loss.
What is the difference between QNAP File-Based and Block-Based LUNs?
File-Based LUNs are image files on a standard volume (ext4), similar to a VMDK. Block-Based LUNs are carved directly from the LVM storage pool as block devices, bypassing the host filesystem for better performance and native thin provisioning.
Imaging takes 6 to 10 hours per 4TB drive. A typical 4-drive NAS takes 2 to 4 business days for full RAID assembly, host filesystem parsing, and LUN extraction. Drives with bad sectors require additional time for bitwise imaging with PC-3000.
Are iSCSI LUNs physical partitions on the NAS drives?
No. On Synology, an iSCSI LUN is a file inside the hidden @iSCSI directory on Btrfs or ext4. On QNAP Block-Based configurations, it is an LVM logical volume inside a storage pool. It is never a physical partition.
Can I just extract raw blocks from the NAS drives to get the LUN back?
No. Modern iSCSI LUNs are thin-provisioned and fragmented across the RAID. Without parsing the extent map (Btrfs chunk trees or LVM thin B-trees), raw blocks cannot be reassembled into a coherent initiator filesystem.
How do you recover a deleted QNAP Block-Based LUN?
We image the member drives, reassemble the array with mdadm --assemble --readonly, restore the unlinked LVM logical-volume metadata from the on-disk header backup with vgcfgrestore, then carve the thin-pool allocation map so each surviving virtual offset is tied back to its physical RAID extent. Deletion unlinks the volume metadata, but the thin-pool extents usually survive until QTS overwrites them. A QuTS hero Block-Based LUN is a ZFS ZVOL instead and follows ZFS dataset logic rather than LVM carving.
What happens if a Synology LUN snapshot rollback is interrupted?
An interrupted rollback shatters the metadata that links the active LUN to its snapshot base, so the LUN fails to mount or mounts as corrupted raw space. Recovery is read-only: we locate the historical Btrfs generation tree root that still describes the pre-rollback block layout of the LUN file and extract that file with btrfs restore. We never run btrfs check --repair or mount -o recovery,ro, because both overwrite the copy-on-write generation roots that describe the prior layout.
Can a VMFS datastore on an iSCSI LUN be recovered?
Yes, through four nested stages: reconstruct the RAID from member images, parse the host Btrfs/ext4 or LVM metadata, extract the LUN container (the Synology LUN file under @iSCSI or the QNAP logical volume), then parse the VMFS inside it by navigating the heartbeat region, VMFS metadata, and VMDK descriptor and flat extents before exporting the VMs. It is not the same as recovering a flat VMDK, and raw block extraction fails because it skips every encapsulation layer's extent map.
Is a TrueNAS iSCSI LUN a file like on Synology?
No. TrueNAS presents an iSCSI LUN as a ZFS zvol, a block device carved from the zpool at /dev/zvol/<pool>/<zvol>, not a file in an @iSCSI directory. Recovery imports the pool read-only and unmounted with zpool import -o readonly=on -N against clones, then reads the zvol and parses the nested VMFS or NTFS. A degraded pool is never imported without the read-only flag. On a deduplicated pool, holding the DDT in ARC takes roughly 1 to 5 GB of RAM per 1 TB of deduplicated data; the pool still imports when the table does not fit, but loading it on demand can take days.
How is Proxmox VE iSCSI recovery different?
Proxmox drives the target with targetcli on the Linux LIO stack and usually layers an LVM volume group on the iSCSI block device so several VM disks share one LUN. Recovery is storage-layer first: recover the ZFS pool or reconstruct the LVM volume-group header, then carve the thin logical volume holding each VM disk. Proxmox does not store LUNs in an @iSCSI directory, and a lost saveconfig.json mapping is a metadata problem, not data destruction.
See the particle counter test at the benchRelated services
Ship us your NAS drives. We'll extract the LUNs.
iSCSI LUN recovery with offline forensic tools. No data, no recovery fee. Free diagnosis. Austin, TX lab.
