Data Recovery Training & Certifications
We believe in showing our work. Here is the verifiable training our lead technician has completed; here is what it means for your recovery.
Why Skills Matter More Than Facilities
Many competitors justify $2,000+ prices by marketing their "ISO 14644-1 Class 5 Cleanrooms." While a clean environment is important for open drives, most modern data recovery is a firmware engineering challenge, not a dust challenge.
If your drive has a corrupted Media Cache or a "Slow Responding" bug, no amount of air filtration will fix it. You need an engineer who understands the code that runs the drive.
We list the certifications below to prove we have the Utility to fix the actual problems drives face today, rather than just the Facilities to market them.
Meet Chris
Chris (Bogumił) Piskorz is our lead hard drive data recovery technician. He runs the PC-3000 systems in our Austin lab and handles the recoveries that come through our doors and our nationwide mail-in service.
We sent him to get trained directly by the people who make the tools we use. ACELab makes the PC-3000; HEX Akademia in Poland specializes in diagnostics and foundational skills for drive repair. The courses below represent hands-on training with engineers who work on this full-time.
We list these certifications so you can see what he's trained on. If your drive has a problem covered by one of these courses, we've dealt with it before.
Training Completed
What each course covered and how it applies to your hard drive data recovery.
PC-3000 Seagate HDD Data Recovery Advanced Training
ACE Lab Europe S.R.O. • July 5-6, 2024
Two-day advanced program on Seagate hard drive architecture and firmware-level data recovery. Covers modern Seagate drive families (F3 and Rosewood) and critical firmware failures.
- Seagate microcode structure and terminal diagnostics
- ROM modification and firmware unlocking
- Translator repair for F3 architecture
- Rosewood recovery and Media Cache management
- Data Extractor optimization with head map editing
Applies to: Seagate drives that spin but show 0 capacity or won't mount. Firmware repair without opening the drive.
PC-3000 WD HDD Data Recovery Advanced Training
ACE Lab Europe S.R.O. • July 8-9, 2024
Two-day advanced seminar on Western Digital hard drive data recovery. Covers firmware architecture, hardware encryption, and logical recovery using PC-3000.
- ROM patching and non-original ROM handling
- Service Area diagnostics and passport module recovery
- T2 translator corruption repair
- USB-to-SATA conversion and encryption handling
- Self-Encrypting Drive (SED) unlocking (strictly on supported legacy bridge-IC architectures)
Applies to: WD drives with hardware encryption, Slow Responding issues, and corrupted firmware or Service Areas.
Basic Data Recovery Training: HDD/SSHD
HEX Akademia, Poland • April 16-19, 2025
Four-day foundational course on hard drive data recovery from HDDs and solid-state hybrid drives. Combines theory with hands-on lab work using professional data recovery tools.
- HDD/SSHD malfunction diagnostics and advanced SMART parameter monitoring
- PC-3000 Utility, Data Extractor, and UFS Recovery Professional operation
- FAT, exFAT, and NTFS file system analysis and repair
- Imaging drives with degraded magnetic surfaces
- Service Area (firmware) repairs and HSA replacement preparation
Applies to: Proper diagnosis before repair. Identifies what's wrong with a drive before committing to a recovery approach.
Advanced Data Recovery Specialist: HDD/SSHD
HEX Akademia, Poland • April 21-26, 2025
Six-day advanced certification program specializing in complex hard drive data recovery. Focuses on firmware repair, advanced mechanical procedures, and recovery from physically damaged magnetic surfaces.
- Advanced file system engineering and manual repair of complex structures
- Custom tool and script development for unique recovery cases
- CMR and SMR firmware recovery: Media Cache issues and T2 Translator corruption
- Partial head removal and specialized platter cleaning procedures
- Custom imaging strategies for severely damaged CMR and SMR drives
Applies to: Drives with physical damage, scratched platters, failed heads, or complex mechanical failures requiring clean bench intervention.
Cleanroom Myth vs. Data
Competitors use the term "Class 5 Cleanroom" to justify high prices. An ISO 14644-1 Class 5 cleanroom allows up to 3,520 particles (at 0.5 µm) per cubic meter.
We don't rely on room standards; we rely on bench standards. We open drives under a 0.02 micron ULPA-filtered clean bench for mechanical work.
Room Standard vs. Bench Approach
*We open drives under a 0.02 micron ULPA-filtered clean bench, which filters localized airflow directly over the exposed platters rather than conditioning an entire room. See our full validation process.
Administrative Compliance vs. Engineering Capability
Some data recovery companies advertise SOC 2, SAS70, or ISO 27001 certifications as evidence of technical capability. These frameworks audit corporate accounting controls, internal IT security policies, and data handling procedures. They verify that a company encrypts its network and locks its server room.
None of these frameworks evaluate whether an engineer can execute a head stack assembly replacement, rebuild a corrupted Western Digital Spyglass translator, or inject firmware into a Phison controller's RAM. The distinction matters: a SOC 2 audit confirms a company follows its own security policies, not that its technicians can recover data from a failed drive.
The certifications listed on this page verify hard drive data recovery and SSD recovery engineering skills: firmware manipulation, mechanical intervention, and controller diagnostics using the PC-3000.
More Than a Job
Data recovery is something Chris is interested in outside of work. He attends industry conferences because he wants to stay current with new drive technologies and recovery techniques, not because someone told him to.
ACE Lab Tech Week: Data Recovery & Digital Forensics Conference
ACE Lab Europe S.R.O. • October 8-11, 2025
Tech Week is ACELab's annual gathering for data recovery professionals. Engineers, lab owners, and technicians from around the world attend four days of workshops and presentations on the latest storage technology and forensic recovery methods.
Why it matters: Drive technology changes every year. New firmware architectures, encryption schemes, and storage formats appear constantly. Attending events like this means Chris sees what's coming before those drives show up at our lab with problems.
Where This Training Comes From
ACELab
ACELab makes the PC-3000, which is the main tool we use for hard drive data recovery. It lets us communicate with drives at the firmware level, which is necessary for most of the problems we see.
Their training courses are taught by the engineers who develop the software. When Seagate or WD releases a new drive family, ACELab figures out how to support it and teaches that in their courses.
HEX Akademia
HEX Serwis is a data recovery lab in Poland that also runs training courses. Their curriculum spans from foundational diagnostics to advanced mechanical interventions, including hands-on work with head stack assemblies and platter cleaning.
Training happens at their facility in Kobysewo, working on actual drives under supervision. Chris completed both their basic and advanced certifications back-to-back over 10 days in April 2025.
How This Applies to Your Drive
Seagate drive that spins but won't mount
Usually a firmware problem: Media Cache corruption or translator failure. Shows up as 0 capacity or a stuck busy state. The Seagate training covers firmware repair without opening the drive. See our Rosewood recovery page for specifics.
WD MyPassport or external that's not detected
WD drives have hardware encryption and complex firmware. Common failures: Slow Responding bug, T2 translator corruption, and damaged passport modules. The WD training covers ROM patching, SED unlocking on supported legacy bridge-IC architectures, and USB-to-SATA conversion.
Drive with bad sectors or degraded surface
The HEX training covers imaging strategies for drives with damaged magnetic surfaces, including SMART parameter analysis and custom imaging configurations for both CMR and SMR architectures.
Clicking, grinding, or physically damaged drive
Drives with failed heads or contaminated platters need mechanical intervention in a clean environment. The HEX advanced training covers partial head removal, platter cleaning, and imaging strategies for severely damaged media.
SSD Firmware Failures: Where Certifications Fall Short
The certifications above focus on HDD firmware and mechanical recovery. SSD failures operate differently: there are no moving parts, but the firmware is more complex. When a Phison PS3111-S11 controller suffers flash translation layer corruption from a power loss mid-write, it enters a hardcoded fallback mode. The drive reports itself to the BIOS as "SATAFIRM S11" with 0 bytes capacity. The drive is electrically alive but has no working firmware to load.
The PC-3000 SSD utility issues Phison vendor-specific commands to inject a working firmware loader directly into the controller's RAM, bypassing the corrupted NAND. From there, the technician rebuilds the translator tables from surviving metadata. This is the same controller used in Kingston A400 and Patriot Burst drives.
Silicon Motion SM2258XT controllers (common in Crucial BX500 and ADATA SU650 SSDs) present a different failure pattern: the drive may appear connected but shows 100% Active Time in Task Manager with zero read/write activity. The controller's firmware has stalled, blocking all host commands. The PC-3000 SSD utility issues vendor-specific commands to bypass the stall and access user data directly through the controller's diagnostic interface.
The Tools Behind the Training
We use PC-3000 systems for our hard drive data recovery work. The ACELab courses teach how to get the most out of this equipment.
We also maintain a clean bench environment for mechanical work and keep donor drives on hand for head swaps. The HEX advanced training covers the mechanical procedures that make those interventions possible.
Questions About Our Training
Why do these certifications matter more than a cleanroom?
What is PC-3000?
Why did you send your technician to Poland for training?
Do you handle all drive brands or just Seagate and WD?
How clean is your bench compared to an ISO Cleanroom?
Is the work done in-house or sent out?
What if my drive problem is not covered by this training?
Why do your engineers hold ACE Lab and HEX Akademia certifications instead of the CDRP?
Can a technician with a CDRP certification fix a SATAFIRM S11 SSD error?
Related Services
Full HDD recovery service overview
SSD firmware and controller recovery
Multi-disk array reconstruction
Synology, QNAP, and custom NAS recovery
The hardware we use for recovery
Clean bench vs cleanroom reality
See the particle counter test at the benchQuestions about your drive?
Send it in for a free evaluation. We'll tell you what's wrong, what it would take to fix it, and what it would cost. No obligation.
