RAID 1 Data Recovery Services
RAID 1 stores identical data on two or more mirrored drives. When the array fails, a single healthy mirror often contains everything you need.
Our RAID data recovery service handles the less straightforward cases: split-brain divergence after controller failures, resync errors that overwrote newer data with older data, and mechanical failures on both mirrors simultaneously. We image each drive through write-blocked channels, compare both mirrors at the sector level, and extract the most complete and current version of your data.
How Does RAID 1 Mirroring Affect Data Recovery?
- Every write operation in a RAID 1 array is duplicated to all mirrors. On a standard 2-drive RAID 1, both drives hold byte-identical data at all times during normal operation. This means a single healthy drive can be imaged and mounted independently to recover every file.
- Because there is no striping, there are no block size, rotation, or member order parameters to detect. Recovery tools do not need to virtually reconstruct an array layout the way they do for RAID 0, 5, or 6. The imaging and extraction workflow matches a standard single-drive case.
- Enterprise and NAS configurations sometimes use 3-way or 4-way mirrors for additional redundancy. Database transaction log volumes and boot/OS partitions are common candidates for multi-mirror RAID 1 because the write penalty is acceptable for small, critical datasets.
- Common RAID 1 use cases include OS and boot volumes, database transaction logs, 2-bay home NAS enclosures (Synology DS220+, QNAP TS-230), and small business file servers where simplicity and redundancy outweigh raw storage capacity.
- The trade-off is storage efficiency: a 2-drive RAID 1 provides only 50% usable capacity. Users often choose RAID 1 specifically because recovery is straightforward, though this advantage disappears when both mirrors develop faults simultaneously or when the controller introduces split-brain conditions.
How Does RAID 1 Compare to RAID 10 and RAID 5 for Recovery?
| Property | RAID 1 (Mirror) | RAID 10 (Striped Mirror) | RAID 5 (Single Parity) |
| Data protection method | Exact 1:1 drive mirroring | Striping across mirrored pairs | Distributed block-level parity |
| Minimum drives | 2 | 4 | 3 |
| Storage efficiency | 50% (capacity of one drive) | 50% (total capacity divided by 2) | (N-1) of N drives |
| Fault tolerance | 1 drive | 1 drive per mirrored pair | 1 drive total |
| Rebuild stress | Low; linear 1:1 sector read from the surviving mirror | Low; linear read from the surviving member of the pair | High; requires reading every sector of all surviving drives, so a URE during a degraded rebuild aborts the operation on legacy controllers, while modern Dell PERC and LSI/Broadcom MegaRAID puncture the affected stripe and finish |
| Recovery complexity | Low to moderate; watch for split-brain divergence | Moderate; requires destriping across pairs | High; requires correct parity rotation and disk order |
The practical takeaway: RAID 1 is the easiest level to recover when one mirror is intact, but it shares the limitation common to every RAID level. RAID is hardware availability, not a backup.
A deletion, a ransomware payload, or a controller that writes garbage is mirrored to both members at the moment it happens. Discrete offline copies are the only protection against that class of loss.
What Does It Mean When a RAID 1 Array Reports Degraded?
The word reaches you from whichever layer owns the array, and every one of those layers is reporting the same physical condition: one member in, one member out.
- Linux md software mirror
- The md array is running with one member present and the other missing or flagged failed.
/proc/mdstatandmdadm --detailare where that member state is read on a running host. - Dell PERC and LSI/Broadcom MegaRAID virtual disk
- PERC cards are rebadged LSI/Broadcom silicon, and both families write the array geometry to the member drives as a SNIA DDF variant in the trailing sectors. A virtual disk marked degraded has lost one member out of that on-disk configuration. The configuration travels with the drives, so a degraded virtual disk is not tied to the card staying alive.
- HP and HPE Smart Array logical drive
- The traditional Smart Array controllers, the P-series, E-series, and SR-series, do not use DDF. They write a proprietary RAID Information Sector to a reserved area at the start of each member, so a logical drive marked degraded is a member missing from that start-of-disk sequence. Swapping the controller does not move the metadata, because the metadata was never held on the controller. HPE's newer MR-series cards are Broadcom MegaRAID silicon and use the trailing-sector DDF layout instead.
- Consumer 2-bay NAS storage pool
- Synology DSM standard volumes and QNAP QTS both run Linux md beneath their storage managers, so a pool the web interface calls degraded is the md state above wearing a friendlier label. A degraded 2-bay NAS pool and a degraded Linux mirror are the same recovery problem.
A degraded mirror answers every read from one physical drive. No partner is left to supply a sector the survivor cannot return, so a latent media defect stops being an event the array quietly services from the other copy and surfaces as a read error at the volume.
The volume stays online and the files stay readable. Every request now lands on one set of heads with no second copy behind them, which is the exposure the degraded label is reporting.
What Happens When You Drop a Replacement Drive Into the Empty Bay?
The reflex is to fill the bay and let the array resync, and that resync is a blind block-for-block copy across the full capacity of the surviving member. It reads regions ordinary file access has never touched, and untouched regions are exactly where latent unreadable sectors sit undetected until something reads the drive end to end.
Consumer drives carry a worst-case manufacturer rating of one unrecoverable read error per 10^14 bits read, roughly 12.5 TB; enterprise drives are typically rated at one per 10^15. That rating is a worst-case ceiling on the error rate, not a countdown and not a fixed allocation. Reading a multi-TB survivor from end to end raises the probability of surfacing a latent unreadable sector, and plenty of full resyncs finish without hitting one.
The exposure on a mirror is smaller than on parity. A mirror resync reads one surviving member linearly, while a degraded RAID 5 rebuild has to read every sector of every surviving member to recompute the missing parity block.
Smaller exposure is not zero exposure, and the consequences differ: on RAID 5 an unreadable sector denies the controller the parity block it needs, while on a mirror the resync source is the only copy of that sector still in the chassis.
The quieter outcome is a resync that completes. mdadm has no checksum to consult while it copies, so any region the survivor returns as a good read is written verbatim onto the replacement whether or not it still matches what was written there. The array goes back to reporting itself redundant while both members now carry the same defect.
What Do You Image First on a Degraded Mirror?
Image the survivor first, before a replacement ever enters the bay. Only one member holds current data in a degraded array, which fixes the imaging order.
- Clone the surviving member write-blocked. The resync is the risk event and the survivor is the only complete current copy, so it gets imaged before anything else is asked of it. We use the PC-3000 Express or the PC-3000 Portable III on conservative read-retry settings, and ddrescue where the member reads without intervention. A survivor with a mechanical fault of its own is a single-drive hard drive recovery before it is an array job.
- Image the dropped member as a second source. It went stale at every offset written after it left the array, but it is a physically complete copy of everything up to that point, so it can supply LBAs the survivor can no longer read. The superblock Events delta and Update Time delta between the two members, described in the sections below, are what bound how far that staleness reaches.
- Reassemble from the image files. The imagers read sectors; the array itself goes back together in software, with
mdadm --assemble --readonlyrun against the clones, or with Data Extractor Express RAID Edition on the PC-3000 Express when the on-disk metadata is too damaged to parse. No reconstruction step ever touches a live member.
Degraded and split-brain call for different work. Degraded means one member is gone and there is nothing to adjudicate; split-brain means both members are present and have diverged, which the Events counter and Update Time comparison in the sections that follow resolve. All member imaging and virtual reassembly is performed in-house at our Austin, TX lab.
Split-Brain Scenarios and Mirror Divergence
- During normal operation, the RAID controller ensures both mirrors receive every write in lockstep. When the controller crashes mid-write, one mirror may have committed a transaction that the other mirror never received. The result: two drives with identical data everywhere except for the sectors that were in-flight at the moment of failure.
- A worse scenario arises when a failed controller is replaced and the new controller forces a resync in the wrong direction. If the controller selects the stale mirror as the source and overwrites the current mirror, recent data is replaced with older data. This is not a hardware failure; it is a configuration error that destroys valid data through a legitimate resync operation.
- Unclean disconnection of a single mirror (cable fault, backplane failure, hot-swap during active writes) also causes divergence. The disconnected drive retains whatever state it had at the moment of removal, while the surviving mirror continues to accept new writes. When the disconnected drive is reinserted, the controller must decide which direction to resync.
- Silent corruption adds another layer. Even during normal operation, bit-rot or media defects on one mirror can go undetected if the controller does not perform periodic scrub operations. Over months or years, sectors on one mirror may accumulate uncorrectable read errors that only surface when both mirrors are needed.
Do not force a resync. If your RAID controller is prompting you to rebuild or resync a RAID 1 mirror after a failure, power down both drives. A resync in the wrong direction permanently overwrites the newer copy with older data.
Where Does a RAID 1 Mirror Store Its Metadata?
- Linux software mirrors (mdadm). Most 2-bay NAS units run mdadm under their GUI. The mdadm superblock records the array UUID, level, device role, and sync epoch. Its position depends on the metadata version: version 1.2, the modern default, sits 4 KiB from the start of the member; versions 0.90 and 1.0 sit at the end of the device with the filesystem starting at offset 0.
- That offset-0 layout is a trap. A host OS can auto-mount one member as a standalone disk, and any background write (journaling, indexing) desyncs that member from its partner and creates split-brain divergence.
- Dell PERC and LSI MegaRAID. PERC cards are rebadged LSI/Broadcom controllers. They write a variant of the SNIA Disk Data Format (DDF) to the trailing sectors of each member, with an anchor header at the last logical block pointing to records that define level, chunk size, drive order, and epoch. The controller NVRAM only caches this; the authoritative copy is on the disks.
- HP Smart Array. HP and HPE P-series and E-series controllers do not use DDF. They write a proprietary RAID Information Sector (RIS) to a reserved area at the start of each drive, inside a hidden partition. Pointing DDF-based tooling at an HP array fails outright, which is a common reason a self-attempted recovery stalls before it starts.
- No original controller required. Because the geometry lives on the platters, a failed PERC, MegaRAID, or Smart Array card is not data loss. We connect each member through a write-blocked channel using an HBA in IT (Initiator Target) mode, read the DDF or RIS headers, and virtually assemble the mirror without the original card.
Which Mirror Do We Image First?
When two members have diverged, the imaging order matters. We read the metadata epoch timestamps to find the member that was current at the point of failure, then weigh that against each drive's physical SMART health. The goal is to clone the most up-to-date, mechanically sound member first using PC-3000 Express with conservative read-retry settings.
Cloning happens before any logical operation, because a consumer mirror drive without time-limited error recovery will stall on latent unrecoverable read errors and can drop offline mid-rebuild, taking the array with it. Only once both members are imaged do we reconcile the filesystem and decide which sectors are authoritative.
Reading the mdadm Superblock with --examine
On a Linux software mirror, mdadm --examine /dev/sdX reads the on-disk superblock from a single member and prints the array metadata without modifying anything. Run it against each member in turn and the fields below tell you which mirror diverged and which one was authoritative at the point of failure. Reassembling a divergent mdadm mirror from its superblocks is the focus of our Linux mdadm software RAID recovery service.
- Array UUID
- Both members must report the same UUID. A mismatch means the two drives belong to different arrays, or that one member was re-created with
mdadm --create, which writes a fresh superblock and destroys the original membership record. A UUID mismatch rules out a clean reassembly of those two drives as a single mirror. - Device Role / Array Slot
- The Device Role field records which mirror position the member held, slot 0 versus slot 1. A member reporting a spare role rather than an active slot, or a role marked as failed, identifies a drive that was demoted out of the active mirror before the array stopped.
- Update Time
- The Update Time is the wall-clock timestamp of the last superblock write. The member with the more recent Update Time was still active when the array failed; the member with the older timestamp dropped out earlier and holds a stale view of the data.
- Events counter
- The Events field is a monotonic counter incremented on every array state change. The member with the higher Events count is authoritative. The size of the gap between the two members quantifies how far the stale member drifted before it dropped out, a small gap means it left moments before failure, a large gap means it was running detached for a long time.
- State (clean / active / FAULTY)
- A member flagged
FAULTYorremovednames exactly which mirror diverged and rules that stale member out, whereas a State ofactivewith an unflushed write-intent bitmap identifies the surviving member that was still writing at the point of failure, which makes it the imaging-priority drive.
We read --examine from a write-blocked clone produced with PC-3000 Express or ddrescue, never from the live member, so the superblock is never updated during diagnosis.
What If the mdadm Write-Intent Bitmap Is Inconsistent After an Interrupted Resync?
The write-intent bitmap exists to track which blocks changed so a resync after an unclean shutdown only touches dirty regions instead of the whole device.
When an mdadm resync is interrupted mid-way and the bitmap is missing or in an inconsistent state, letting the kernel resync against a live member is the failure mode that destroys recoverable data: the kernel forces the array consistent by overwriting one member with the other, with no way to undo it. We resolve this read-only against the clones rather than the live disks.
- Image all members write-blocked with the PC-3000 Express before any resync runs. Reconstruction happens in software against the image files, never against the live members.
- Hash the corresponding sector ranges across the images and build a divergence map. The regions that match across both members are uncontested; only the dirty regions the bitmap was tracking need adjudication.
- For each divergent region, the authoritative copy is the member whose superblock reports the higher Events counter and the more recent Update Time, the same event-counter parity described above. Once the authoritative member is identified, the composite image is assembled from the clones with no write ever reaching the originals.
Why SMR Drives Drop Out of a RAID 1 Rebuild
A rebuild or resync of a 2-bay RAID 1 mirror is a sustained sequential write across the entire replacement member. Shingled Magnetic Recording (SMR) drives cannot absorb that write pattern, and the way they fail looks like a dead drive to the controller.
- An SMR drive absorbs incoming writes into a small Conventional Magnetic Recording (CMR) media cache, then must pause to fold that cache into the overlapping shingled zones. Under the sustained write load of a rebuild, the CMR cache overflows and the drive stalls with no command completion while it reshingles.
- The WD Red WDx0EFAX series shipped SMR media and was widely deployed in consumer 2-bay NAS mirrors.
- The correct intervention is to image each member, member by member, through a write-blocked interface with ddrescue or PC-3000 Express before attempting any rebuild, because the rebuild itself is what triggers the SMR stall. We reconstruct the mirror virtually from the clones rather than letting the controller resync against a live SMR member.
Which mdadm Commands Destroy a Still-Active Mirror?
mdadm --create or mdadm --assemble --force on a degraded RAID 1, and do not --add the current disk back into an array running on the stale one. Image every member write-blocked, compare the Events counters read-only, then assemble the clones. The highest Events count is the authoritative member.The most common way a recoverable RAID 1 mirror becomes an unrecoverable one is an operator running a well-meaning repair command against the live members. Forum threads routinely recommend re-creating or force-assembling a degraded array to bring it back online.
Each of those commands writes to the disks, and each one can overwrite the exact metadata and payload a clean reassembly depends on. The three below are the ones that turn a straightforward mirror job into permanent loss.
Stop before running any of these on the original members.
mdadm --createandmdadm --create --assume-cleanwrite a fresh superblock to every member, destroying the original device order, metadata version, and chunk size. If the recreated metadata version differs from the original, for example recreating as 1.2 when the array was 1.0, thedata_offsetshifts and the filesystem payload is misaligned into garbage. If LVM sits on top, the new superblock overwrites the LVM PV header and severs the volume group.mdadm --addof the wrong member is silent and irreversible. If the current, up-to-date disk is added as a new member into an array still running on the stale disk, mdadm syncs the stale data onto the current disk, overwriting newer data with older.mdadm --assemble --forceoverrides the event-counter safety check and can bring the array online on a stale member that dropped out days or weeks ago, silently rolling the filesystem back to that older state.
How Do You Verify Which Mirror Is Current Before Assembly?
Verify member order before any assembly command touches the array. The Events counter, not the UUID, tells you which member is authoritative. Read it from a write-blocked clone, in this order.
- Run
mdadm --examine --scanandmdadm --examine /dev/sdXread-only against each member. Run these from a write-blocked clone, never the live disk, so no superblock is updated during diagnosis. - Compare the Events counter across members. The member with the highest Events count is the authoritative, active member. The lower-Events member is stale and must never be the device-order source for a
--createor the overwrite target for an--add. - When both members report the same array UUID while degraded, the UUID does not tell you which member is current. The Events count does. The event count overrides the UUID match.
- Image every member write-blocked with ddrescue or PC-3000 Express first, run
mdadm --examineread-only on the clones, then assemble the clones withmdadm --assemble --readonly. If the metadata is too damaged to parse, reconstruct the geometry virtually in Data Extractor Express RAID Edition on the PC-3000 Express. Nothing is ever rebuilt against a live member.
If the array is already in this state, or you are not certain which member is authoritative, stop and send the drives in. All imaging and reconstruction is performed in-house at our Austin, TX lab under the no-fix-no-fee guarantee, and we accept mail-in drives from anywhere in the U.S. See the mail-in instructions or start a case before running any command that writes to the members.
What Happens If Both RAID 1 Mirrors Fail at the Same Time?
A mirror only protects you if the second member outlives the first. That margin is thinner than most administrators assume. The two drives in a 2-bay mirror are usually pulled from the same purchase order, so they share a manufacturing batch, a firmware revision, and a shelf date.
Once installed, they see the same power events and absorb the same lockstep write stream, which means near-identical head-flight-hours and duty cycle. Two drives built days apart and worked identically tend to reach the same media-defect or bearing-wear threshold inside a narrow window, so a single bad power event or a shared firmware bug can knock both members down before the array ever reports a degraded state.
This is a different problem from split-brain, and the distinction decides the entire procedure.
- Split-brain divergence
- Both members are mechanically healthy and readable; they hold different but valid writes because the controller let them drift apart. The question is logical: which mirror holds the authoritative, most recent committed data. That adjudication is covered in the split-brain & superblock sections above.
- Correlated dual physical failure
- Both members are physically degraded at once, with overlapping head, media, or motor faults rather than divergent writes. The question is physical: which member can still read each individual LBA. No journal or Events counter resolves this; only the per-drive bad-sector maps do.
When both members are physically degraded, we treat each as an independent single-drive recovery and then merge the results. The procedure runs in five stages.
- Image each member independently, write-blocked. We clone both drives separately with the PC-3000 Express on conservative read-retry, with mechanical work (head swap, motor repair) done on the ULPA-filtered clean bench first if a drive is clicking or stalled. No resync ever runs; a resync against a degraded live member is what turns a recoverable two-drive event into total loss.
- Build a per-member sector map. Each imaging pass records which LBAs returned good reads and which came back bad, producing a separate readable-sector and bad-sector map for each drive.
- Composite by sector union. For every LBA, we take the readable copy from whichever member can still read it. Because each drive's defect regions usually fall in different LBA ranges, the union of the two readable maps is far more complete than either member on its own.
- Isolate the true loss as the intersection. The only genuinely unrecoverable region is the set of LBAs that read bad on both drives, the intersection of the two bad-sector maps, not the union. Quantifying loss as that intersection is what separates a near-complete composite from a panicked total-loss call.
- Reconcile the filesystem on the composite. Once the union image is assembled, we mount it read-only and run journal replay, directory reconstruction, and file carving against the single merged image rather than against either damaged member.
The imaging hardware and the merge step are separate stages, and keeping them separate is what makes the union work. The PC-3000 Express reads sectors and emits each member's image plus its mapfile; it does not reconcile anything between two drives.
Merging two partial images into one rescue map is a software step done with ddrescue mapfiles. ddrescue records which regions it rescued and which are still unread, so a later pass can be confined to the regions still missing, and two members' mapfiles can be combined so the composite only retries the LBAs that remain unread on both. The imager images; the mapfile merge reconciles.
Cost on a dual physical failure follows the same per-member math used everywhere on this page: each drive is imaged and priced individually from the published HDD tiers, mechanical members at the head-swap tier of $1,200 to $1,500 per drive plus donor cost, with one array reconstruction fee on top.
How Is RAID 1E Recovery Different From Classic RAID 1?
- RAID 1E, also documented as Integrated Adjacent Stripe Mirroring or Integrated Offset Stripe Mirroring, is a mirror topology spread across three or more drives. Each data block is duplicated to a drive at an offset within a striped layout rather than copied to a single dedicated partner. That staggered placement lets a mirror run on an odd number of drives, where a classic 2-drive mirror or a hardware RAID 10 striped mirror does not fit because hardware RAID 10 requires an even drive count.
- The recovery consequence is that RAID 1E is not the straight image-and-extract job a 2-drive mirror is. There is a stripe rotation and a set of mirror-pair offset assignments to recover before any sector means anything, so the destriping depends on reading the layout correctly first.
- Geometry comes from DDF, not mdadm. RAID 1E layouts deployed by hardware controllers store level, stripe size, and the offset mirror-pair assignments in the SNIA Common RAID Disk Data Format on the member drives. That on-disk DDF is authoritative; the controller NVRAM only caches it. The geometry is parsed from the DDF records, never inferred from an mdadm superblock, because a hardware RAID 1E volume has no mdadm superblock to read.
- Which controllers deploy it. RAID 1E is a topology for odd-drive-count arrays, and support for it is specific to the card. Adaptec publishes RAID 1E among its supported levels. Read the level off the controller in front of you rather than assuming a vendor family supports it, then follow the on-disk metadata rather than a model name.
- A dead PERC or MegaRAID card is not data loss. Because the offset-mirror geometry lives on the platters in DDF, the original controller is convenient, not required. We image each member write-blocked through an HBA in IT mode with the PC-3000 Portable III, then reconstruct the RAID 1E volume virtually in Data Extractor Express RAID Edition by parsing the DDF and applying the offset-mirror layout to the image files. The imager reads the drives; the software reassembles the array from those images, so nothing is ever rebuilt against a live member.
- RAID 1E is one branch of our broader RAID array reconstruction work, and it shows up most often inside enterprise server arrays where an odd backplane drive count made a 2-drive mirror or RAID 10 impractical.
Our RAID 1 Recovery Process
- Free evaluation: Document the RAID controller model, NAS make and model, number of mirrors, failure history, and whether any rebuild or resync was attempted. Label each drive with its original slot position.
- Write-blocked imaging: Clone each mirror using PC-3000 imaging hardware with conservative retry settings. If a mirror has mechanical damage (clicking, not spinning), we perform head transplants or motor repair on a laminar-flow bench before imaging. Each mirror is imaged to a separate target; originals are never modified.
- Sector-level comparison: Diff both mirror images to map every divergent sector. On a healthy RAID 1, the images should be identical. Any mismatches indicate split-brain writes, silent corruption, or bad sectors that one drive accumulated before failure.
- Journal and timestamp analysis: For divergent regions, we examine the filesystem journal (ext4 journal, NTFS $LogFile, XFS log) on both mirrors to determine which received the most recent committed transactions. File modification timestamps and directory entry metadata are compared to build a timeline of which mirror was current at the point of failure.
- Composite image assembly: Construct a single authoritative image by selecting the correct sectors from each mirror based on the journal analysis. For databases and virtual machines, we verify internal transaction logs (PostgreSQL WAL, MySQL redo logs, VMDK change tracking) against the filesystem-level findings.
- Extraction and delivery: Mount the composite image, verify file integrity with you, copy recovered data to your target media, and securely purge all working copies on request.
How Much Does RAID 1 Recovery Cost?
Per-Mirror Imaging
- Logical or firmware-level issues: $250 to $900 per drive. Covers filesystem corruption, firmware module damage requiring PC-3000 terminal access, and SMART threshold failures that prevent normal reads.
- Mechanical failures (head swap, motor seizure): $1,200 to $1,500 per drive with a 50% deposit. Head transplants and platter work are performed on a validated laminar-flow bench before write-blocked cloning.
Array Reconstruction
- Array reconstruction is priced by whether split-brain resolution is needed, the number of mirrors, and the filesystem type (NTFS, EXT4, XFS, Btrfs, ZFS). RAID 1 is the least expensive RAID level to reconstruct because there are no stripe or parity parameters to detect. A single intact mirror with no divergence often needs only filesystem-level extraction from the cloned image, with no separate parameter-detection work.
- Split-brain cases with database or virtual machine workloads require transaction log analysis beyond basic filesystem journal comparison, which adds verification time to the reconstruction quote. Each member is still imaged and priced individually from the published HDD or helium HDD tiers, and the reconstruction fee is quoted once we know how many mirrors image cleanly.
No Data = No Charge: Free evaluation, no obligation.
Single-mirror shortcut: If one mirror is healthy and no divergence exists, the reconstruction fee may be waived entirely since the job reduces to a standard single-drive recovery.
Per-Drive Recovery Tiers
Each mirror is imaged and recovered as an individual drive at our standard rates. The tier depends on the condition of that specific member, logical, firmware, or mechanical.
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
Mirror Verification and Silent Corruption
- Consumer-grade RAID controllers and NAS devices often lack background scrub functionality. Without periodic verification reads, a bad sector on one mirror can persist for months. When the healthy mirror then develops its own fault, the backup copy you assumed was intact may already be compromised.
- ZFS and Btrfs mitigate this with built-in checksumming and scrub operations. If your RAID 1 array runs on mdadm with ext4 or XFS, no such automatic verification exists at the filesystem level. The controller may report both mirrors as healthy while sectors silently decay.
- During recovery, we hash each sector range across both mirror images and generate a divergence map. Sectors that differ are analyzed in the context of surrounding filesystem structures to determine which mirror holds the valid copy. For regions where both mirrors contain errors, we apply ECC reconstruction and file carving to salvage partial data.
- Enterprise environments running 3-way or 4-way RAID 1 mirrors have additional redundancy against silent corruption because a majority vote across three or four copies can resolve ambiguous sectors. We handle multi-mirror configurations by comparing all available images and selecting the majority-consistent version for each sector range.
How Is a ZFS Mirror Rebuild Different From an mdadm Resync?
The mdadm resync described earlier on this page copies the surviving member across the device geometry no matter how much of that geometry holds data. A ZFS mirrored vdev does not work that way, and the difference changes how long a degraded mirror stays exposed.
Commercial recovery pages still describe every mirror rebuild in the traditional terms. Gillware's RAID 1 page states that "Replacing the failed disk triggers a rebuild that simply copies the surviving disk's contents to the replacement." That sentence is accurate for an mdadm or hardware-controller mirror and wrong for a ZFS mirror, which is one of the reasons the two stacks belong in separate mental models.
Sequential Resilver
Sequential resilver is a separate operation with separate guarantees. zpool replace -s performs sequential reconstruction to restore redundancy as fast as possible. Checksums are not verified during sequential reconstruction, and a scrub is started automatically when the sequential resilver completes. It is not supported for raidz configurations, so it is available to you on a mirror and not on a parity vdev. The syntax for the replace itself:
zpool replace [-fsw] [-o property=value] pool device [new-device]Omitting new-device replaces a disk in place, which is the form you use after a physical swap where the device path is unchanged.
Checksum Verification and Error Correction
ZFS computes checksums and writes them along with the data. On a later read it recomputes them, and when they do not match it attempts to correct the error using the mirror copy.
zpool status reports per-device read, write, and checksum error counters and marks a pool whose redundancy is reduced as degraded. That behavior is exactly what the mdadm-with-ext4 or XFS mirror in the section above lacks: nothing at that filesystem layer verifies that the two members still agree on what they hold.
A Pool That Will Not Import
A pool that will not import never gets as far as a resilver. ZFS has no fsck; the pool either imports or it does not.
zpool import -F attempts to return the pool to an importable state by discarding the last few transactions, and the data in those discarded transactions is irretrievably lost. -X used together with -F takes extreme measures to find a valid transaction group and can roll the pool back to a txg that is no longer guaranteed consistent, so the pool that comes back may contain uncorrectable checksum errors. -o readonly=on imports without writing.
Keep the layers straight: a TXG rollback discards recent transactions, it does not overwrite parity. The uberblocks a rollback selects among live inside each vdev label, four labels per disk with a rotating uberblock ring inside each label, which is why an unimportable pool is a metadata problem before it is a media problem.
Three Conditions That Turn a Mirror Into a Lab Job
Three conditions turn a ZFS mirror into a lab job rather than a zpool replace you run yourself:
- Checksum error counters climbing on the surviving side during a resilver.
- A second device faulting partway through a resilver.
- A pool that will not import at all.
In all three, the discipline is the one the rest of this page teaches. Image every member write-blocked with ddrescue or the PC-3000 Express before you run zpool replace, because a healing resilver is a full traversal read aimed at the one device you cannot afford to lose.
Whether a second device throwing checksum errors mid-resilver stalls the operation or carries it to a bad completion is not something to find out on the only copies of the data you have. ZFS pool work runs in-house at the Austin lab like every other case here, with no diagnostic fee and no charge if we recover nothing.
Where Mirrored Vdevs Show Up
Mirrored vdevs show up on TrueNAS CORE on FreeBSD, TrueNAS SCALE on Linux, Proxmox VE rpool mirrors, QNAP QuTS hero, which is native ZFS rather than the md and LVM stack QTS uses, and plain ZFS-on-Linux servers. The recovery-relevant consequence is portability: the on-disk format is standard OpenZFS, so a mirrored pool can be imported on another host running a compatible OpenZFS version regardless of which OS wrote it.
Common RAID 1 Configurations We Recover
2-Bay NAS Enclosures
Synology DS220+/DS223, QNAP TS-230/TS-233, and similar consumer devices default to RAID 1. These typically use Linux mdadm (software RAID) combined with LVM under the hood. Recovery involves imaging both members and reading the mdadm superblock and LVM headers to identify mirror roles.
Server Boot / OS Volumes
Dell PERC, HP Smart Array, and LSI MegaRAID controllers commonly place the OS partition on a RAID 1 pair separate from the data array. These hardware RAID controllers write proprietary metadata to the drives but do not encrypt user data. We detect the controller parameters from on-disk metadata and reconstruct without the original hardware.
Database Transaction Logs
SQL Server, PostgreSQL, and MySQL deployments often place transaction log files on a dedicated RAID 1 volume for write reliability. Recovery of these volumes prioritizes WAL and redo log integrity over raw file extraction, since a consistent log file can replay transactions to bring the main database to a recoverable state.
RAID 1 Recovery Questions
Is RAID 1 recovery easier than other RAID levels?
What happens if both RAID 1 mirrors fail?
Can data be recovered from a single RAID 1 drive?
How do you determine which RAID 1 mirror has the correct data?
My RAID controller died. Are the drives still readable?
I ran mdadm --add or --create on the wrong drive. Is the data gone?
Is a RAID 1 mirror a backup?
My RAID 1 says degraded. Is my data still there?
Need RAID 1 mirror recovery?
Free evaluation. No data = no charge. Mail drives from anywhere in the U.S.
