Windows Server Recovery
ReFS File System Data Recovery
We recover data from corrupted ReFS volumes on Windows Server 2012 R2 through Server 2025. B+ tree metadata reconstruction, Storage Spaces Direct cluster failures, Hyper-V VHDX extraction, and deduplication-aware recovery. ReFS recovery is one part of our enterprise server data recovery work: when the volume sits on a failed Storage Spaces pool, we reconstruct the pool geometry from each drive's metadata partition first, then parse the ReFS metadata. Free evaluation. No data = no charge.
How ReFS Volumes Fail and How We Recover Them
ReFS (Resilient File System) is Microsoft's B+ tree-based filesystem designed for Windows Server environments. Unlike NTFS, which uses a flat Master File Table (MFT) for metadata, ReFS stores all metadata in B+ trees and uses an allocate-on-write model: metadata updates are written to new disk locations rather than overwriting existing data.
When the root B+ tree node corrupts or the checkpoint area (superblock) becomes unreadable, Windows cannot mount the volume and displays it as RAW. Recovery requires parsing the B+ tree structures offline, locating historical metadata checkpoints preserved by the allocate-on-write design, and reconstructing the directory hierarchy from surviving tree nodes.
ReFS was introduced in Windows Server 2012 and its on-disk format has changed across Windows Server releases. Microsoft added block cloning with Server 2016 and continued changing the format afterward, and a volume formatted by a newer release is not readable by an older one. That is why the version a volume was formatted under is one of the first things we record.
ReFS On-Disk Architecture
Understanding the ReFS on-disk format is necessary for targeted recovery. ReFS differs from NTFS in every structural dimension.
B+ Trees and the Object Table
- ReFS organizes all metadata into B+ trees. The root of the filesystem is the object table, a B+ tree whose keys are object IDs and whose values are table descriptors pointing to other B+ trees
- Each directory is a B+ tree. Each file's extent map is a B+ tree. The entire metadata hierarchy is trees pointing to trees
- If the root object table node is damaged, the entire volume is unmountable. Recovery requires locating a previous version of the root node from the checkpoint area or scanning for orphaned B+ tree nodes on disk
Allocate-on-Write Model
- When ReFS updates metadata, it writes the new version to a different location on disk and then atomically updates the parent pointer. The old version remains at its original location until the space is reclaimed
- This means metadata updates do not overwrite prior versions immediately. After a corruption event, historical metadata snapshots often survive on disk
- Recovery exploits this: we scan for B+ tree pages at historical offsets, compare page sequence numbers, and reconstruct the directory tree from the most recent consistent set of pages
Checkpoint Area (Superblock)
- The checkpoint records where the current root of the object table lives, which is what Windows reads to mount the volume
- Because ReFS allocates on write, an older root node is often still on disk after a newer one is damaged
- When the checkpoint cannot be read, we locate the object table root by scanning for B+ tree page signatures across the volume surface
Container Table and Extents
- ReFS tracks free space and allocated extents through a container table (also a B+ tree). A container is a band of allocated space much larger than the cluster size; do not confuse the two
- File data extents are referenced through the file's extent B+ tree, which maps logical file offsets to physical container numbers
- For recovery, we parse the container table to resolve file extent references. If the container table is corrupted, we reconstruct extent maps from individual file B+ tree nodes
Common ReFS Failure Scenarios
ReFS does not use NTFS-style chkdsk to repair these conditions. It handles corruption online by salvaging: when no alternate Storage Spaces copy exists, ReFS removes the corrupt data from the namespace to keep the volume mounted, which is permanent loss.
The ReFS scrubber only auto-repairs latent corruption when an alternate copy exists on a Storage Spaces mirror or parity space. With no alternate copy, the salvage path discards the affected references and the data has to be parsed back out offline.
Volume Shows as RAW
The most common ReFS failure. Windows cannot parse the checkpoint area or root object table, so it presents the volume as RAW in Disk Management. Causes include power loss during a metadata flush, firmware bugs in the storage controller, or bad sectors at the checkpoint offsets.
Storage Spaces Pool Failure
Storage Spaces (non-Direct) pools lose redundancy when more disks fail than the resiliency type allows (one for single parity or two-way mirror, two for dual parity). When the pool goes offline, all ReFS volumes on it become inaccessible. Recovery requires reconstructing the Storage Spaces virtual disk layout from the pool metadata database before parsing ReFS.
Storage Spaces Direct S2D Quorum Loss
S2D requires a majority of cluster nodes to maintain quorum. If two of three nodes fail simultaneously, the cluster loses quorum and all cluster shared volumes go offline. The data remains on the physical drives in each node. Recovery involves imaging drives from all nodes and reassembling the S2D pool geometry from each node's metadata partition.
Chkdsk Damage
Running chkdsk /f or chkdsk /r on a corrupted ReFS volume can make recovery harder. Chkdskis an NTFS repair tool, and ReFS does not use NTFS-style chkdsk. Nothing good comes of pointing repair tooling at a ReFS volume you still need data from; it writes to a volume whose historical metadata is the thing we would be reading. Contact us before running chkdsk on any ReFS volume that contains data you need.
Hyper-V Host Crash
When a Hyper-V host crashes with VMs running, the ReFS volume may have uncommitted metadata for in-flight VHDX writes. The volume itself usually recovers on reboot (ReFS is designed for this), but if the crash was caused by a hardware failure (dead controller, failing drive), the combination of ReFS metadata damage and partial VHDX writes creates a two-layer recovery problem.
Deduplication Corruption
Windows Server deduplication on ReFS (introduced in Server version 1709, included in the LTSC track starting with Server 2019) creates chunk stores that replace inline file data with references. If the chunk store B+ tree or the reparse point data is corrupted, deduplicated files become unreadable even though the raw chunks exist on disk. Recovery requires reconstructing the dedup mapping table.
ReFS vs NTFS: Why Recovery Requires Different Tools
| Attribute | NTFS | ReFS |
| Metadata structure | Master File Table (MFT): flat record array at a fixed offset | B+ trees: hierarchical, self-balancing, rooted in the object table |
| Update model | In-place updates with journaling ($LogFile) | Allocate-on-write for metadata; old pages preserved until space reclaimed |
| Checksums | None (relies on hardware or Storage Spaces for integrity) | CRC-64 on metadata pages; optional CRC-64 on data blocks (integrity streams) |
| Recovery advantage | MFT backup ($MFTMirr) provides a partial copy of the first MFT records | Historical checkpoints from AoW; dual checkpoint areas; B+ tree page scanning |
| Max volume size | 256 TB (practical) | 35 PB (practical, Windows-supported); designed for hyper-converged multi-petabyte storage |
Most data recovery software and even many professional recovery labs do not support ReFS parsing. The tools that handle NTFS MFT reconstruction cannot parse ReFS B+ trees. This is why ReFS recovery is a specialized service.
Storage Spaces Direct S2D Recovery
Image every surviving member write-blocked before allowing any S2D rebuild to start. Reading parity slabs across the remaining members during a rebuild exposes the array to an unrecoverable read error: consumer-class drives are rated near one URE per 10^14 bits read, roughly 12.5 TB, so a degraded multi-terabyte pool is likely to hit one mid-rebuild and drop the operation.
SMR drives in the capacity tier add a second hazard; they stall during the sustained sequential writes a rebuild generates, the controller reads the 30-to-60 second pause as a dead drive, and the member gets ejected, which can cascade into pool collapse. We image the members first so the rebuild runs against copies, never the originals.
Storage Spaces Direct is Microsoft's hyper-converged infrastructure (HCI) solution. It pools local storage from multiple cluster nodes into a single software-defined storage layer. ReFS is the recommended filesystem for S2D cluster shared volumes (CSVs) in production configurations.
S2D Pool Geometry
S2D creates a storage pool from all eligible drives across cluster nodes. The pool is divided into slabs, and data is distributed across nodes according to the resiliency type (mirror, parity, or mirror-accelerated parity).
The pool selects a subset of drives per node to host the pool metadata database. Recovery starts by reading this metadata from each node's drives to reconstruct the virtual disk geometry.
Cluster Quorum Failure
A three-node S2D cluster requires at least two nodes to maintain quorum. If two nodes fail simultaneously (power event, network partition, cascading hardware failure), the cluster loses quorum and all CSVs go offline.
The cluster refuses to bring the storage online without quorum. We bypass the cluster layer entirely: image all drives from all nodes, reconstruct the pool metadata, assemble the virtual disks from the raw images, and parse the ReFS volumes directly.
Cache Tier and Capacity Tier
S2D uses a tiered storage model: NVMe or SSD drives serve as a cache tier, and HDDs serve as the capacity tier. Data is destaged from cache to capacity asynchronously. If a node fails during destaging, some data exists only in the cache tier on that node's SSDs. Recovery must account for both tiers: we image cache-tier SSDs and capacity-tier HDDs from every node, then reconstruct the complete virtual disk including data that had not yet been destaged.
Recovery Methodology
- Image every drive write-blocked. Every drive in the server or S2D cluster is imaged through PC-3000 with write-blocking. SAS drives (standard in Dell PowerEdge and HP ProLiant servers) are imaged on the PC-3000 SAS card. NVMe cache-tier drives are imaged through NVMe-to-PCIe adapters. For drives with bad sectors, we capture healthy sectors first using head maps, then retry damaged areas with aggressive read parameters. This stage produces a sector image of each member and touches no original drive after the copy.
- Reconstruct the storage pool in software. For Storage Spaces or S2D configurations, array-aware forensic software parses the Storage Spaces metadata database off the drive images that carry it. This database describes the virtual disk layout: which slabs on which physical drives compose each virtual disk, and what resiliency type (mirror, parity) protects each virtual disk. We reassemble the virtual disks virtually from the raw drive images using the parsed metadata, never against the live members.
- Parse the ReFS B+ trees. With the virtual disk (or raw volume for non-pooled configurations) assembled from the images, we parse the ReFS metadata. First, read the checkpoint region. If a valid checkpoint exists, follow the root pointer to the object table B+ tree. If no readable checkpoint remains, scan the volume for B+ tree page signatures (magic number + page header structure) and rebuild the object table from discovered pages, sorted by page sequence number to select the most recent consistent set.
- Extract files and verify checksums. Directory entries are resolved from the directory B+ trees. File data extents are mapped from the file extent B+ trees through the container table. Files are extracted to target media with full path preservation. For volumes with integrity streams, we verify each block's CRC-64 checksum during extraction and flag any blocks with checksum mismatches.
Does ReFS Recovery Differ Across Windows Server 2016, 2019, and 2022?
Microsoft documents that ReFS detects corruption through integrity streams that checksum metadata, and that allocate-on-write writes updated metadata to new disk locations rather than overwriting the old pages. Those two properties hold on Server 2016, 2019, and 2022, and they are what make offline ReFS recovery possible at all: the historical metadata pages are still on the platter until the container space is reclaimed.
The integrity-stream and allocate-on-write behavior is documented; the ability to roll back to a prior consistent set of those pages is our lab's independent forensic work parsing the raw image, not a native ReFS rollback command.
Server 2016
Shipped ReFS 3.x with block cloning and integrity streams. No in-box ReFS deduplication. Recovery parses the object table, checkpoint areas, and container table the same way; we read the checkpoint region, follow the root pointer, and fall back to B+ tree page scanning by sequence number when no readable checkpoint remains.
Server 2019 LTSC
First LTSC build to include ReFS Data Deduplication and tighter Storage Spaces Direct tiering integration. A 2019 volume can carry a chunk store under System Volume Information, so recovery is two-pass: parse the ReFS B+ trees, then resolve reparse points into the chunk store containers. A 2016-only ReFS parser misses the dedup layer.
Server 2022 / 2025
Newer 3.x on-disk format revisions and broader mirror-accelerated parity use on S2D. A parser built only for an older ReFS revision cannot walk these trees; the page header and container layout changed across versions. We detect the format version from the volume superblock structures before selecting the parse path.
The practical recovery consequence is the parse path, not the principle. We identify the on-disk format revision from the volume structures, then walk the object table and container table for that revision. Allocate-on-write and metadata checksums give us the same historical-page recovery surface on every build; the dedup chunk store and the resiliency layout are what we add or drop depending on which Server version wrote the volume.
How Do You Reconstruct S2D Virtual Disks When the Storage Pool Metadata Is Partially Corrupt?
Image every surviving member write-blocked before any rebuild. A degraded parity space has to read parity slabs across the remaining members, and consumer-class drives are rated near one unrecoverable read error per 10^14 bits read, roughly 12.5 TB. On a multi-terabyte pool a degraded rebuild is likely to hit a URE mid-pass and abort, so we image first and let the reconstruction run against the copies.
SMR capacity-tier members add the second hazard: under the sustained sequential writes of a rebuild, the reshingling pause of tens of seconds reads as a dead drive, and the member is ejected, which can cascade the pool offline.
The pool metadata database describes the slab-to-virtual-disk mapping, the resiliency type per virtual disk, and the column and interleave layout. Because more than one drive holds a copy of that database, partial corruption on one member rarely destroys the geometry: the same descriptors usually survive on the others. We image each drive with PC-3000 hardware, then parse the metadata partitions from the images.
- Read every surviving metadata copy. Parse the hidden pool-metadata partition from each drive image and cross-check the slab maps, virtual-disk records, and resiliency descriptors across members to identify which copies are internally consistent.
- Rebuild the slab-to-virtual-disk geometry. Reconstruct which slabs on which physical drives compose each virtual disk, the column count, interleave size, and parity layout, using the consistent metadata copies to fill gaps left by the corrupt copy.
- Assemble the virtual disks in software. We reassemble the virtual disks with Data Extractor Express RAID Edition (the ACE Lab RAID/array tool that runs on the PC-3000 Express) from the raw drive images, never the live members. The original Storage Spaces controller or HBA is not needed; the geometry lives on the disks, not in the card.
- Parse ReFS from the assembled virtual disk. With the virtual disk assembled from images, parse the ReFS checkpoint areas and object table B+ tree as for any ReFS volume, falling back to B+ tree page scanning by sequence number when the checkpoints are damaged.
What Happens When an NVMe S2D Cache Drive Drops Off the Bus Mid-Destage?
The cache tier absorbs incoming writes and destages them to the capacity HDDs in the background. When an NVMe cache member disappears from the PCIe bus during a destage, the writes that were still in flight, including ReFS metadata updates, never reach the capacity tier.
The result on the capacity HDDs is a partial set of B+ tree writes: some metadata pages reflect the newest transaction, others stop one or more transactions behind. This is exactly the situation allocate-on-write is built to survive, because the prior consistent pages were not overwritten.
- Image the NVMe cache member. We image the NVMe SSD with PC-3000 SSD in sector-imaging mode through an NVMe-to-PCIe adapter, capturing whatever the device still returns. This is a read-only sector copy, not a controller-level repair.
- Image the capacity HDDs. Capacity-tier HDDs are imaged with PC-3000 hardware.
- Reassemble the virtual disk in software. We reconstruct the S2D virtual disk from the raw images with Data Extractor Express RAID Edition, applying any cache-tier writes that did complete before the drop, then hand the assembled volume to the ReFS parser.
- Select the consistent metadata generation. We parse the ReFS object table and container table, compare B+ tree page sequence numbers, and select the most recent consistent set of metadata pages, discarding the half-written pages from the interrupted destage rather than trusting a torn newest write.
Imaging and reconstruction are separate stages here. PC-3000 hardware reads sectors off the members; the virtual-disk reassembly and the ReFS B+ tree parse are software steps run against the image files, never against the live drives. That separation is what lets us choose the last consistent metadata generation instead of inheriting the torn state the live cluster was left in.
Hyper-V VHDX and SQL Database Extraction
VHDX Recovery
Hyper-V stores virtual machine disks as VHDX files on the host ReFS volume. Microsoft recommends ReFS for Hyper-V storage because ReFS block cloning enables instant VM checkpoint creation. After extracting VHDX files from the reconstructed ReFS directory tree, we verify the VHDX header, BAT (block allocation table), and metadata region. If the VHDX is intact, we mount the virtual disk and confirm the guest filesystem (NTFS, ext4, XFS) is accessible. For dynamic VHDX files, we also verify the parent locator chain for differencing disks used by VM checkpoints.
SQL Server Database Extraction
SQL Server databases on ReFS volumes consist of .mdf (primary data) and .ldf (transaction log) files. After extracting these files from the reconstructed ReFS tree, we verify the database header page (page 0) for consistency, check the boot page (page 9) for database metadata, and attempt to bring the database online in a recovery instance. For databases with torn pages (common after a crash), we run DBCC CHECKDB to assess damage scope before attempting repair.
ReFS Deduplication Recovery
Windows Server version 1709 introduced deduplication support on ReFS volumes, included in the LTSC track starting with Server 2019. Deduplication on ReFS uses a post-process model: files are initially written normally, and the deduplication service runs in the background to identify duplicate chunks, store them in a chunk store, and replace the original file data with reparse points referencing the chunk store.
- Chunk store corruption: The chunk store is a set of container files stored in a hidden System Volume Information directory. Each chunk is identified by a hash. If the chunk store containers or the chunk store index are corrupted, deduplicated files become unreadable because the reparse points cannot resolve to valid chunk data.
- Reparse point damage: Deduplicated files use NTFS reparse points (even on ReFS) to redirect reads to the chunk store. If the reparse point metadata in a file's B+ tree node is damaged, the file appears as zero-length or fails to open with an I/O error. We reconstruct the reparse point data from the chunk store index by matching file chunk hashes.
- Recovery approach: We parse the chunk store containers, rebuild the chunk index, and resolve reparse points for each deduplicated file. Files that were not yet processed by the dedup service retain their original inline data and are recovered normally through the ReFS B+ tree.
The dedup chunk store is its own on-disk subsystem, separate from the ReFS metadata trees. Windows Data Deduplication stores the unique chunks as an organized series of container files inside the hidden System Volume Information folder, and the optimized files on the volume become reparse points that index into those containers.
That separation drives the recovery order: we reconstruct the ReFS volume first, locate the chunk store containers under System Volume Information, then rebuild the chunk-to-reparse-point mapping and resolve each deduplicated file back to its full content.
Files the dedup service had not yet optimized still carry their inline data on the ReFS volume and come back normally through the B+ tree parse, so a partially optimized volume splits into two recovery paths: inline files resolved directly, optimized files resolved through the chunk store. We do not run the dedup chunk store through the ReFS checkpoint logic; it is a Data Deduplication structure, parsed on its own terms.
- Chunk store
- The on-disk repository that holds the unique data chunks produced by Windows Data Deduplication. It lives as container files in the System Volume Information folder and is a separate subsystem from the ReFS metadata B+ trees.
- Reparse point
- The pointer the dedup service writes in place of an optimized file's data. Reading the file follows the reparse point into the chunk store; if the reparse data is damaged, the file opens as zero-length or returns an I/O error until the mapping is rebuilt.
- Chunk store container
- One of the container files that physically stores the deduplicated chunks under System Volume Information. Recovery parses these containers directly from the reconstructed ReFS tree to resolve every chunk a reparse point references.
ReFS Recovery Pricing
Same transparent model: per-drive imaging based on each drive's condition, plus a volume reconstruction fee covering ReFS metadata parsing, B+ tree reconstruction, and file extraction. No data recovered means no charge.
| Service Tier | Price Range (Per Drive) | Description |
| Logical / Firmware Imaging | $250-$900 | Firmware faults, SMART threshold failures, or filesystem corruption on individual pool members. |
| Mechanical (Head Swap / Motor) | $1,200-$1,50050% deposit | Donor parts required. SAS drives in enterprise servers require SAS-specific donors. |
| ReFS Volume Reconstruction | Custom Quoteper volume | ReFS metadata parsing, B+ tree reconstruction, file extraction. Includes Storage Spaces pool assembly if applicable. |
No Data = No Charge: If we recover nothing from your ReFS volume, you owe $0. Free evaluation, no obligation.
Before sending drives: do not run chkdsk on the ReFS volume. ReFS does not use NTFS-style chkdsk; running chkdsk can trigger online salvage that discards corrupted data references instead of preserving the historical metadata that allocate-on-write had left on disk.
ReFS Recovery; Common Questions
My Windows Server shows a ReFS volume as RAW. Can you recover the data?
Can you recover data from a failed Storage Spaces Direct (S2D) cluster?
Is ReFS recovery different from NTFS recovery?
My ReFS volume had integrity streams enabled. Does that help recovery?
Can you extract Hyper-V virtual machines from a corrupted ReFS volume?
How is ReFS recovery priced?
See the particle counter test at the benchRelated services
Dell, HP, IBM enterprise servers
VHDX and VM extraction
RAID 0, 1, 5, 6, 10 arrays
VMFS and VMDK recovery
Storage Spaces pool metadata and slab reconstruction
All HDD brands and models
Complete service catalog
Ready to recover your ReFS volume?
