SSD Power Loss Recovery
A sudden power outage, power surge, or UPS failure can corrupt the Flash Translation Layer (FTL) stored in your SSD's volatile DRAM cache. The NAND flash chips still hold your data, but the controller has lost the map it needs to find it. We reconstruct the translation layer using the PC-3000 SSD and repair blown power management ICs via board-level microsoldering at our Austin, TX lab. SSDs have no moving parts.
Updated 2026-05-14
SSD data recovery after power loss usually starts with FTL reconstruction, not file recovery software. The NAND flash chips can still hold the data, but the controller may show 0 bytes, SATAFIRM S11, Safe Mode, or no device until PC-3000 SSD rebuilds the translation layer.
Every additional power cycle risks the controller executing TRIM or garbage collection on corrupted metadata, permanently erasing recoverable NAND pages. Do not attempt to format the drive or run recovery software. Power-loss cases are one of the highest-survival arrival conditions our SSD data recovery service sees because the controller never had time to complete its erase cycle. Call (512) 212-9111 for a free evaluation.
Free evaluation, no diagnostic fees
Can Data Be Recovered from an SSD After Power Loss?
Yes. Power loss corrupts the SSD's internal mapping table (the Flash Translation Layer), but the actual files remain stored on the NAND flash memory chips. The controller has lost its map, not the data itself. Professional recovery rebuilds that map using specialized hardware that communicates directly with the controller chip, bypassing the corrupted firmware.
Recovery software cannot help because it operates through the operating system's storage driver. When the controller is in safe mode or electrically dead, the OS sees 0 bytes or no device at all. Software requires a functioning controller to translate logical addresses to physical NAND locations. The PC-3000 SSD bypasses that requirement by injecting a working firmware loader directly into the controller's RAM.
What Happens To An SSD During
What Happens to an SSD During a Power Outage?
SSDs store the active copy of their Flash Translation Layer in volatile DRAM cache for speed. During a graceful shutdown, the controller flushes this DRAM cache to non-volatile NAND. A sudden power loss interrupts that flush. The mapping table is lost or partially written, leaving the controller unable to locate your files on the NAND.
  • Drive reports 0 bytes total capacity or shows incorrect capacity (e.g., 2TB drive reads as 8MB)
  • Drive shows as "SATAFIRM S11" or an unfamiliar model name in BIOS
  • Drive not detected in BIOS or Device Manager
  • Drive is detected but hangs, causing the system to freeze when accessed
  • Drive enters read-only mode or reports "write protect" errors
  • Computer refuses to boot from a previously functional SSD after a power event
Power Event SymptomLikely FailureSSD Data Recovery Path
Power outage during write or garbage collectionCorrupted Flash Translation LayerPC-3000 SSD reads surviving NAND metadata and rebuilds a virtual translator.
Power surge or failing PSUPMIC, voltage regulator, or TVS diode failureFLIR thermal imaging locates the short; Hakko FM-2032 and Atten 862 repair the power path.
Drive reports 0 bytes or incorrect capacityController safe mode after FTL corruptionPC-3000 enters diagnostic mode and bypasses the corrupted firmware.
SATAFIRM S11 or unfamiliar BIOS model nameRaw controller panic stateThe matching PC-3000 controller utility loads a working microcode loader.
Drive is not detected after the surgeBroken power delivery to controller or NANDBoard-level microsoldering restores the original controller so encryption stays intact.
A power surge adds a second failure mode: the surge overwhelms the Power Management IC (PMIC) and TVS diodes on the SSD circuit board. The PMIC burns out, cutting power delivery to the controller. The NAND flash retains its electrical charge and data. Board-level repair restores the power path.
Recovery Process
How We Recover Data from Power-Damaged SSDs
Recovery follows two paths depending on whether the damage is electrical (blown PMIC from a surge) or logical (corrupted FTL from an outage). Both paths happen at our Austin lab using the PC-3000 SSD and board-level microsoldering equipment.
  1. 01
    Electrical Fault Diagnosis
    FLIR thermal imaging identifies shorted or blown components on the PCB. We measure voltage rails with a multimeter to confirm which power delivery components failed. If the PMIC, voltage regulators, or TVS diodes are damaged, the drive needs board repair before any firmware work begins.
  2. 02
    Board-Level PMIC Repair (If Needed)
    Using Hakko FM-2032 microsoldering irons and Atten 862 hot air rework, we remove the burned PMIC and reflow a healthy donor component onto the PCB. This restores the correct 1.8V, 1.2V, and 0.9V rails so the controller and NAND receive clean power. The native controller boots and decrypts data through its own hardware encryption pipeline.
  3. 03
    Controller Identification and Technological Mode
    We identify the controller manufacturer (Phison, Silicon Motion, Samsung, Marvell) and select the matching PC-3000 loader module. The PC-3000 SSD issues vendor-specific commands to place the controller into diagnostic mode, bypassing the corrupted firmware. A working microcode loader is injected into the controller's RAM.
  4. 04
    FTL Reconstruction (Virtual Translator)
    The PC-3000 reads surviving NAND page headers, block sequence numbers, and wear-level counters to reconstruct the corrupted Flash Translation Layer. This rebuilt map is held in RAM on the drive itself as a virtual translator, restoring the logical-to-physical address mapping without writing to the user data area.
  5. 05
    Sector-by-Sector Imaging and Verification
    With the virtual translator active, the drive presents its real capacity and file system. We image the entire drive sector-by-sector to a known-good destination drive. Files are verified against the original directory structure and transferred to your return media.
How Much Does SSD Power Loss Recovery Cost?
SSD power loss recovery costs $200–$1,500 for SATA drives and $200–$2,500 for NVMe drives. The final price depends on whether the failure is purely firmware (FTL corruption) or also electrical (blown PMIC from a surge). Every case starts with a free evaluation and a firm quote. If we recover nothing, you pay nothing.
Failure TypeSATA SSDNVMe SSDTypical Cause
File system corruption onlyFrom $250From $250Minor power flicker; journaling partially recovered
PMIC / voltage regulator repair$450–$600$900–$1,200Power surge destroyed power delivery components
Firmware / FTL reconstruction$600–$1,200$900–$1,200Power outage during write or garbage collection
NAND swap (severe board damage)$1,200–$1,500$1,200–$2,500Surge destroyed controller beyond repair; NAND transplant to donor board
A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. Rush service available: +$100 rush fee to move to the front of the queue.
Published SSD Power Loss Recovery Pricing
SSD power loss recovery uses the same published pricing tables as every Rossmann SSD case. SATA SSD firmware reconstruction uses $600–$1,200; NVMe firmware reconstruction uses $900–$1,200. Board repair is priced separately because replacing a PMIC or regulator is component-level microsoldering, not software recovery.
SATA SSD Pricing
NVMe SSD Pricing
Mail-In
Nationwide Mail-In SSD Recovery
We recover SSDs from all 50 states through mail-in service. Ship your drive to our Austin, TX lab. All work is performed in-house; we do not outsource to third-party labs. Walk-in service is available in Austin at 2410 San Antonio Street.
Call (512) 212-9111 for a free evaluation before shipping. We will confirm whether your case matches the symptoms above and provide packaging guidance to prevent further damage during transit.
FTL Corruption Mechanics
How Power Loss Corrupts the Flash Translation Layer
The Flash Translation Layer maps logical block addresses (LBAs) from the operating system to physical page addresses on the NAND flash. Because NAND cannot be overwritten in place, this mapping changes with every write operation as the controller redistributes data across cells for wear leveling and garbage collection.
For performance, the active FTL lives in the SSD's DRAM cache. During a graceful shutdown, the host sends a Standby Immediate command and the controller flushes the DRAM contents to a reserved section of NAND called the service area. An unexpected power loss (also called asynchronous power loss or surprise power loss) terminates this sequence mid-flush. The service area receives a partial or inconsistent copy of the mapping table. On the next boot attempt, the controller reads the corrupted service area, cannot parse the FTL, and enters a safe mode or hangs in an initialization loop.
The user data on the NAND flash cells is not erased by this event. NAND cells retain their electrical charge for months to years without power (JEDEC rates consumer SSDs for 52 weeks of unpowered retention at 30C). The data is stranded because the map to find it is broken, not because the data itself is gone. PC-3000 recovery reads the raw NAND pages, extracts surviving page headers and block sequence numbers, and assembles a virtual translator in RAM on the drive itself to restore logical file access.
Partial Page Programming
Partial Page Programming in MLC, TLC, and QLC NAND
Modern SSDs use multi-level NAND cells that store 2 bits (MLC), 3 bits (TLC), or 4 bits (QLC) per cell by programming precise voltage thresholds into each cell. Lower pages are programmed first; upper pages are programmed later. Power loss during an upper-page program operation leaves the cell at an indeterminate voltage.
This partial page program does not just corrupt the data being written at the moment of failure. Because upper and lower pages share the same physical cell, the scrambled voltage threshold destroys the lower page data that was successfully written days or weeks earlier. Academic research on TLC and QLC NAND refers to this as retroactive data corruption: power loss actively destroys archived data, not just in-flight data.
QLC NAND (4 bits per cell) is the most vulnerable because it requires 16 discrete voltage levels per cell, leaving the narrowest margins between states. Consumer drives using QLC NAND (Intel 670p, Solidigm P41 Plus, Samsung 870 QVO, Crucial P3) are at elevated risk from power interruption during write or garbage collection operations. PC-3000 can adjust read voltage thresholds during recovery to resolve ambiguous cell states on partially programmed pages.
PLP
Power Loss Protection: Enterprise vs. Consumer SSDs
Enterprise SSDs and consumer SSDs use different strategies to handle sudden power loss. Enterprise drives include hardware capacitors; consumer drives rely on firmware. The protection level determines how much data survives an outage.
FeatureEnterprise SSD (Hardware PLP)Consumer SSD (Firmware PLP)
Protection mechanismOnboard tantalum polymer capacitorsFirmware journaling and safe-boundary algorithms
DRAM cache flushHardware hold-up power (10 to 50ms)Best-effort; relies on residual controller power
FTL vulnerabilityLow (capacitors flush the full DRAM to NAND)High (DRAM contents lost if power drops during flush)
Aging riskCapacitor degradation in high-temperature server racks reduces hold-up time over yearsNo hardware component to degrade, but firmware logs cannot save volatile DRAM data
Common examplesIntel D3-S4510/S4610, Samsung PM9A3, Micron 7450Samsung 870 EVO, Crucial BX500, WD Blue SN580
Enterprise drives with aging PLP capacitors can still suffer FTL corruption if the capacitors no longer provide sufficient hold-up time. Sustained high operating temperatures in dense server racks accelerate capacitor degradation. A drive rated for 20ms of hold-up power at manufacture may deliver only 5ms after several years, which is insufficient to flush a full DRAM cache.
Power Loss During Writes Vs GC
When Power Loss Is Most Dangerous
The severity of power-loss corruption depends on which operation the SSD controller was executing at the exact moment of the outage. A power loss during garbage collection is more destructive than a loss during a simple file save.
Power loss during a host write
The specific file being written is truncated or corrupted. If the OS uses a journaling file system (NTFS, APFS, ext4), it can often repair the file system metadata on the next boot. This is the least severe scenario. The FTL may survive intact if the controller was not simultaneously updating its mapping tables.
Power loss during garbage collection
Garbage collection moves valid pages from partially empty blocks to new blocks so the old blocks can be erased. The controller tracks these page movements in the FTL. If power fails mid-transfer, the FTL metadata tracking the physical relocation of pages is corrupted. The drive loses track of where valid data resides across the entire NAND, causing drive-wide corruption rather than single-file damage. This is the most common trigger for controller safe-mode lockouts.
Power loss during TRIM execution
TRIM unmaps logical blocks that the OS has marked as deleted and queues the physical pages for erasure. If power drops during an active TRIM operation, the unmapping tables can corrupt. The controller may enter a fault state where it cannot allocate new blocks or resolve the boundary between mapped and unmapped addresses.
SLC Cache Folding Vulnerability
Why Does SLC Cache Folding Make Power Loss Worse?
Consumer SSDs write incoming data to a fast pseudo-SLC (pSLC) cache where the controller programs just 1 bit per cell. During idle periods, the controller "folds" this cached data into denser TLC or QLC blocks. Power loss during a fold operation corrupts the FTL journal's block sequence counters, causing the controller to enter panic mode on the next boot.
Folding compresses roughly 3 SLC blocks into 1 TLC block (or 4 SLC blocks into 1 QLC block), creating write amplification as the controller rewrites data across NAND dies. The FTL tracks which SLC pages have been migrated & which remain valid through a bitmap in the service area. If power cuts mid-fold, the bitmap goes out of sync with the actual NAND state. Some pages exist in both the SLC cache & the partially written TLC block; others exist in neither. The controller detects this inconsistency at boot, can't resolve it, & drops off the PCIe bus or reports 0 bytes.
Drives above 80% capacity are most vulnerable. A full drive shrinks the dynamic SLC pool, forcing the controller to fold more frequently with less reserve space. PC-3000 SSD recovery reads the surviving SLC cache metadata alongside the partially folded TLC/QLC blocks, then reconstructs the mapping by reconciling both sources. Firmware recovery costs $600–$1,200 (SATA) or $900–$1,200 (NVMe).
DRAM-Less And HMB SSD Vulnerability
Why Are DRAM-less SSDs More Vulnerable to Power Loss?
DRAM-less NVMe drives using Host Memory Buffer (HMB) cache their FTL in the computer's system RAM via DMA over PCIe. A system-wide power loss severs the PCIe link & obliterates the HMB data instantly. The controller has no opportunity to flush the active FTL cache back to NAND, leaving it without a valid mapping table on the next boot.
Controllers in this category include the Maxio MAP1602 (Kingston NV2, Acer FA200) & Realtek RTS5772DL (ADATA Legend 800). After power loss, these drives enter a BSY firmware state or drop to protective ROM mode. Even minor bit flips in the HMB translation data can trigger a controller lockup that ignores standard NVMe reset commands, because the controller can't distinguish between stale cache entries & valid ones.
DRAM-less drives are the fastest-growing category in consumer NVMe SSDs, making this failure pattern increasingly common. Recovery requires PC-3000 Portable III with a controller-specific utility to bypass the panicked firmware & reconstruct the FTL from raw NAND metadata. Tool support varies by controller; Maxio, Realtek, and InnoGrit NVMe architectures currently lack dedicated FTL reconstruction support, so recovery on those families falls back to board-level repair. NVMe firmware recovery costs $900–$1,200. Rush service: +$100 rush fee to move to the front of the queue.
Controller-Specific Behaviors
Controller-Specific Power Loss Responses
Each SSD controller family implements different error-handling routines when it detects unrecoverable FTL corruption after a power event. The controller architecture determines both the error state the drive enters and the PC-3000 module required for recovery.
Phison SATA (PS3111-S11) and Phison NVMe (PS5012-E12)
Phison SATA controllers enter ROM MODE when the service area metadata is corrupted beyond self-repair. The PS3111 reports its model name as SATAFIRM S11 and shows 0 bytes capacity. The Phison E12 NVMe variant drops off the PCIe bus or locks up if power is cut during an SLC cache flush. PC-3000 injects the Phison-specific loader to access these panic states and rebuild the FTL from surviving page metadata.
Affected drives: Kingston A400, Patriot Burst, Inland Professional (SATA); Sabrent Rocket, Corsair MP510 (NVMe E12).
Silicon Motion (SM2258, SM2259, SM2262EN)
Silicon Motion controllers enter a BSY (Busy) state or drop to a generic 1GB ROM mode when the system tables are corrupted. The controller hangs on a specific initialization step and never completes SATA or NVMe enumeration. PC-3000 forces the controller past the stalled boot sequence using vendor-specific ATA commands and reconstructs the FTL from dedicated system blocks.
Affected drives: ADATA SU800, HP S700, Team Group SSDs, Crucial BX500.
Samsung In-House NVMe (Elpis)
Samsung NVMe controllers implement hardware AES-256 encryption with the media encryption key bound to the controller silicon. Samsung's modern in-house controllers, Elpis among them, are not on ACE Lab's PC-3000 SSD supported-controller list, and those drives are taken case by case. If a power surge damages the PMIC or voltage regulators, board-level microsoldering to restore the power delivery circuit is the only viable recovery path. The original controller must boot and decrypt the NAND itself.
Affected drives: Samsung 980 Pro, 990 Pro, 970 EVO Plus.
Maxio MAP1602 / MAP1602A (Gen4 NVMe, DRAM-less)
DRAM-less Gen4 controller that depends on HMB for FTL caching. After power loss, the drive reports its raw controller name "MAP1602" with 0 bytes or 2MB capacity. Hardware AES-256 encryption makes chip-off impossible; the data is ciphertext without the original controller's key material. Professional firmware recovery tools currently lack automated FTL reconstruction support for the MAP1602; recovery relies on board-level repair to restore power delivery so the native controller can boot and decrypt the NAND itself. Rossmann does not currently offer in-lab firmware recovery for Maxio MAP1602.
Affected drives: Kingston NV2 (some SKUs), Acer FA200, Netac NV7000-T.
InnoGrit IG5236 Gen4 NVMe
8-channel Gen4 controller with onboard DRAM. After firmware panic, the drive reports "MN-5236" with 2MB capacity instead of its real size. Hardware AES-256 encryption binds the media key to the controller die. Professional firmware recovery tools currently lack dedicated FTL reconstruction support for InnoGrit controllers. If the controller enters the MN-5236 panic state, board-level repair to restore power delivery is the primary recovery path; the original controller must boot & decrypt the NAND itself. Rossmann does not currently offer in-lab firmware recovery for InnoGrit controllers.
Affected drives: HP FX900 Pro.
Phison PS5021-E21T (Gen4 NVMe, DRAM-less)
The E21T is a DRAM-less Gen4 controller vulnerable to SLC cache folding interruption. Power loss during a fold desynchronizes the block sequence counters, causing the controller to drop off the PCIe bus or enter a BSY lockup. PC-3000 SSD supports the PS5021-E21T, so once power delivery is stable the controller can be driven into its diagnostic mode to rebuild the translation layer. When power-loss damage drops the controller off the bus, board-level repair to restore power delivery comes first so the controller can boot.
Affected drives: Kingston NV2 (E21T, some SKUs).
Phison PS5018-E18 (Gen4 NVMe, premium 8-channel)
The E18 is a premium 8-channel PCIe 4.0 controller with onboard DRAM. If a power surge damages the PMIC or voltage regulators, board-level microsoldering to restore the power delivery circuit comes first so the controller can boot.
Affected drives: Sabrent Rocket 4 Plus, Corsair MP600 Pro XT, Seagate FireCuda 530.
Realtek RTS5772DL (Gen4 NVMe, DRAM-less + QLC)
Worst-case power loss combination: volatile HMB caching with QLC NAND that requires 16 discrete voltage states per cell. A system power loss obliterates the HMB FTL cache while leaving the QLC cells vulnerable to partial page programming corruption. Realtek DRAM-less controllers currently lack dedicated support in professional firmware recovery tools for automated FTL reconstruction. If the controller drops to ROM mode after power loss, board-level repair to restore the power path is the primary recovery approach; firmware-level reconstruction options remain limited for this architecture. Rossmann does not currently offer in-lab firmware recovery for Realtek controllers.
Affected drives: ADATA Legend 800.
Page Program Suspend And L2P Divergence
Page Program Suspend States and L2P-to-Journal Divergence
Two failure modes inside the controller account for most of the "drive disappeared," "0-byte capacity," and BSY-hang complaints we receive after a power outage. Both originate below the file system layer, which is why ordinary recovery software cannot address them: the controller never reaches a state where it can present logical sectors to the host.
1. NAND page program suspended mid-cycle
A NAND page program is a multi-pulse ISPP (Incremental Step Pulse Programming) operation. The controller issues the program command, the NAND die raises the wordline voltage in steps, and verify reads confirm each cell crossed its target threshold. If the rail collapses between the first program pulse and the final verify, the cells in that page sit at an intermediate Vt distribution: not erased, not fully programmed, and not readable through the normal sense margins. On the next power-on, the controller attempts to read the block to advance its FTL state, encounters uncorrectable ECC, and either retries forever (BSY hang) or marks the block bad and refuses to publish a capacity (0-byte report).
2. L2P table in DRAM diverged from the on-NAND journal
The active Logical-to-Physical map lives in DRAM (or HMB) for performance. The controller periodically flushes deltas to a journal in NAND service blocks so the L2P can be rebuilt at next boot. Between flushes, the in-RAM L2P is ahead of the on-NAND journal by some number of pending writes. When power drops, the RAM contents evaporate, but the host has already received acknowledgements for some of those writes. On boot, the controller replays the journal and finds physical pages it never recorded a mapping for. Some firmwares enter a safe mode (SATAFIRM S11, ROM mode, or write-protect) rather than publish an inconsistent translator.
Underlying stateSymptom on next power-onWhy software cannot fix it
Page program suspended; cells at intermediate VtDrive enumerates then hangs BSY on the first read of the affected LBA rangeECC fails at the physical layer; the OS never sees the sector
L2P RAM divergence; journal entries missingDrive reports 0 GB or SATAFIRM S11; some controllers report the model name but no LBA capacityNo translator is published, so logical sectors do not exist for the host
Journal points to a block whose erase was interruptedDrive disappears from BIOS, or appears and disappears every few secondsController resets itself on every read attempt; the host driver never completes IDENTIFY
Recovery software runs above the storage stack and depends on the controller already presenting a working translator. None of the three states above expose a translator; installing another recovery tool, running chkdsk, or reinitializing the disk in Disk Management only adds new writes that the controller misroutes, deepening the divergence. The fix has to happen inside the FTL, not on top of it.
Forensic power-up workflow at intake
When a power-loss SSD arrives, the host power path is treated as untrusted. The drive is not plugged into a motherboard until the board has been cleared. The intake sequence:
  1. PMIC isolation. Host VCC pins (5V SATA or 3.3V M.2) are lifted from the rest of the board by removing or bridging the upstream fuse, fusible resistor, or input inductor. This decouples the controller and NAND from any surge-damaged downstream component before any current is applied.
  2. Controlled VCC ramp from a bench supply. A current-limited lab-bench supply is connected to the isolated input rail and ramped from 0V to nominal. The current draw is logged at each step. A healthy SATA SSD draws roughly tens of milliamps at idle on the 5V rail; a board with a shorted PMIC output pulls the supply into its current limit immediately.
  3. FLIR thermal monitoring during ramp. A FLIR thermal camera watches the PCB while the rail comes up. A failed PMIC, TVS diode, or output capacitor heats within seconds, identifying the failed component before the controller is powered.
  4. PC-3000 SSD imaging only after the board is cleared. Once the power tree is confirmed healthy (or repaired with Hakko FM-2032 microsoldering and Atten 862 hot air rework), the drive is connected to PC-3000 SSD in the vendor technological mode. The original controller is held in a loader state while PC-3000 reads the service-area journal and rebuilds the L2P map from the surviving on-NAND entries.
SATA SSD recovery in this state is priced at $600–$1,200. NVMe SSD recovery is priced at $900–$1,200. If the PMIC or output capacitors are damaged and require microsoldering before imaging, board repair is priced separately at $450–$600 (SATA) or $900–$1,200 (NVMe). Free evaluation, firm quote before any paid work, no data no fee.
PMIC Damage From Surges
Power Surge Damage: PMIC and Voltage Regulator Failures
A power surge from a failing PSU, motherboard VRM spike, or lightning event sends excess voltage through the SATA power connector (5V rail) or M.2 slot (3.3V rail). The Power Management IC and transient voltage suppression diodes absorb the overvoltage, burning out to protect the controller and NAND packages behind them.
A dead PMIC means the drive draws no operating current and does not enumerate in BIOS. FLIR thermal imaging reveals the short-circuit heat signature on the failed component. Using Hakko FM-2032 microsoldering stations and Atten 862 hot air rework, we remove the destroyed PMIC and install a healthy donor component. Once the correct voltage rails are restored (typically 1.8V, 1.2V, and 0.9V for modern controllers), the original controller powers up and decrypts the NAND through its own hardware encryption pipeline.
Board-level repair is the correct approach for surge-damaged SSDs. Chip-off (desoldering NAND chips) is the wrong response for encrypted drives because many modern SSDs implement hardware AES-256 encryption bound to the controller. Desoldered NAND from an encrypted drive yields only ciphertext with no key. Repairing the original board preserves the encryption chain. For unencrypted drives where the controller is destroyed beyond repair, chip-off NAND extraction remains a viable escalation path.
SATA Vs NVMe
SATA vs. NVMe: How Interface Affects Power Loss Vulnerability
The drive interface protocol affects both the vulnerability window for FTL corruption and the complexity of recovery after a power event.
FactorSATA SSDNVMe SSD
Power rails5V from SATA power connector3.3V from motherboard M.2 slot
Cache architectureOnboard DRAM cache (typically 256MB to 1GB)Onboard DRAM or Host Memory Buffer (HMB) using system RAM
Power loss FTL vulnerabilityModerate; lower throughput means smaller FTL delta in DRAMHigher; PCIe link severs instantly, HMB data is lost with system RAM
Common firmware panicsSATAFIRM S11, BSY state, 0GB capacityNon-detection, SLC cache flush lockup, write-protect lock
Recovery toolPC-3000 SSD (SATA interface)PC-3000 Portable III (PCIe-native)
NVMe drives using Host Memory Buffer (HMB) technology are especially vulnerable. These DRAM-less drives use the computer's system RAM as their FTL cache. A system-wide power loss obliterates the HMB data along with all other system RAM contents, leaving the NVMe controller heavily reliant on firmware journaling for recovery.
Board-Level PMIC Diagnostics
Board-Level PMIC Diagnostics for Power-Damaged SSDs
When a power-damaged SSD arrives dead, the diagnostic workflow starts at the power delivery circuit, not the controller firmware. The PMIC converts the host input voltage (5V SATA or 3.3V M.2) into four or more regulated rails that feed the controller ASIC, NAND flash, DRAM cache, and PHY interface. A single shorted component on any rail kills the entire drive.
PMIC Voltage Rail Architecture
SSD PMICs from vendors like Qorvo/Active-Semi (ACT series), Richtek (RT series), and SGMicro (SGM series) step the host input down to multiple output rails. Each rail powers a different subsystem on the PCB.
3.3V or 2.5V rail (NAND VCC)
Core power for the NAND flash packages. This rail supplies the charge pump circuits inside each NAND die that program and erase cells. A shorted MLCC bypass capacitor on this rail prevents the NAND from receiving operating voltage, but the stored charge in the NAND cells is unaffected.
1.8V rail (NAND I/O VCCQ and controller PHY)
Powers the NAND I/O bus and the controller's physical layer interface (SATA PHY or PCIe PHY). Without this rail, the controller cannot communicate with the host or read from the NAND. This is the most commonly damaged rail in surge events because it sits closest to the host interface on many PCB layouts.
1.2V rail (DRAM cache and interface PHY)
Feeds the DDR3/DDR4 DRAM cache IC and the PCIe or SATA transceiver. On NVMe drives, this rail also powers the PCIe gen3/gen4 serializer-deserializer. Damage here typically manifests as the drive appearing in the BIOS device list but hanging on any data access attempt.
0.9V to 1.0V rail (controller ASIC core logic)
The lowest voltage rail powers the controller's internal logic gates, FTL engine, and AES encryption pipeline. This rail draws the highest current (often 1A or more under load) and naturally measures low resistance to ground. Novice technicians frequently misread this as a short circuit. The correct test is injecting a known voltage from a bench supply and measuring current draw, not relying on resistance readings alone.
TVS Diode First-Line Defense
TVS (transient voltage suppression) diodes are the first protection layer on an SSD PCB. During a surge, the TVS clamps the voltage spike by shorting to ground, blowing the upstream fuse or fusible resistor to cut power before the surge reaches the PMIC. Diagnosis starts here with a multimeter in diode test mode.
Healthy TVS reading
A working TVS diode shows 0.5V to 0.8V forward drop in diode mode, and OL (open line) in reverse. This confirms the protection component is intact and the surge passed through to downstream components.
Blown TVS reading (shorted)
A TVS that reads near 0.00V in both directions has shorted. It absorbed the surge and sacrificed itself. Removing the shorted TVS and checking whether the downstream PMIC input rail returns to normal resistance confirms whether the damage stopped at the TVS or propagated further.
Open TVS reading
A TVS that reads OL in both directions has blown open. The protection failed completely, and the full surge voltage reached the PMIC. In this scenario, expect cascading damage to the PMIC, output capacitors, and potentially the controller IC itself.
Thermal Imaging Fault Localization
When the TVS check passes but the drive still draws abnormal current, the short circuit is deeper in the power delivery path. Voltage injection through a bench power supply isolates the shorted component using heat as the signal.
  1. Set a lab bench supply to the rail's nominal voltage (1.0V to 3.3V depending on the suspected rail) with a current limit of 2A. Connect it to the shorted rail's input pad on the PCB.
  2. If the board draws over 1A at low voltage, a component has internally shorted. The shorted component converts electrical energy into heat.
  3. FLIR thermal camera reveals the fault. A shorted MLCC ceramic capacitor acts as a resistive heater, reaching over 150 degrees Fahrenheit within seconds. A PMIC with internal dielectric punch-through shows a distinct thermal hotspot, often with visible epoxy discoloration.
  4. Hakko FM-2032 on an FM-203 base station removes the identified component. If removing a bypass capacitor clears the short, the capacitor was the sole failure point and the drive boots after replacement. If the short persists, the PMIC itself has failed internally.
  5. For a failed PMIC, Atten 862 hot air rework removes the damaged IC. A donor PMIC (harvested from an identical model SSD) is reflowed onto the pads to restore all output rails.
Post-Repair Rail Verification
After PMIC replacement, every output rail is verified before applying host power to the drive. This prevents a cascading failure from destroying the donor PMIC.
Inductor-side resistance check
Measure resistance to ground at each output inductor. Compare readings against a known-good board of the same model. Resistance within 10% of the reference confirms the downstream path is intact. Zero ohms on both sides of a bypass capacitor confirms a dead short has cascaded past the PMIC to downstream components.
Isolated input-side short
If shorts exist only on the PMIC input side (between the host connector and the PMIC input pins), the PMIC replacement alone restores the drive. The downstream controller, NAND, and DRAM are undamaged. This is the best-case surge scenario and falls in the $450–$600 (SATA) or $900–$1,200 (NVMe) circuit board repair tier.
Cascading damage confirmation
If multiple output rails still show dead shorts after PMIC replacement, the surge propagated through to the controller or NAND packages. At that point, the PCB is beyond component-level repair, and the case escalates to NAND chip transplant onto a donor board ($1,200–$1,500 SATA, $1,200–$2,500 NVMe, 50% deposit required, plus donor drive cost).
Board repair IS data recovery for encrypted SSDs. The controller's AES-256 encryption key is generated on and bound to the original controller, so it never leaves that silicon. Reviving the original controller through PMIC replacement preserves that key relationship. Most data recovery labs outsource board-level failures or declare them unrecoverable. We locate the failed component with FLIR thermal imaging and replace it with a Hakko FM-2032 at our Austin lab. Single location, no outsourcing.
Dead SSD Rail Short Detection
Diagnosing a Dead SSD: Rail Short Detection & PMIC Verification
A dead SSD that draws no current, or trips the host's 3.3V over-current protection on plug-in, is diagnosed at the bench with a multimeter, an oscilloscope, & a current-limited supply before any firmware work begins. This section extends our ssd data recovery workflow with the exact resistance thresholds, the PCIe CEM power-up handshake the scope should capture, the tantalum-polymer failure mode that hides behind a passing short test, & the controlled power-cycle protocol used to image controllers that hang mid-read.
Resistance-to-Ground Triage Table
The first measurement on a dead drive is resistance from each rail's decoupling capacitor to ground, with the host disconnected. Healthy boards present rail-dependent baselines that look low to anyone used to HDD PCBs. The 0.85V to 1.0V core rail supports high-density CMOS logic; a dormant rail-to-ground reading near 10 to 50 ohms is a normal baseline for the parallel quiescent leakage paths, ESD diodes, & parasitic junction capacitances inside the controller, not a short.
RailHealthy resistanceShorted readingMost likely failure
3.3V host input (SATA pins 1-3 / M.2 pins 70, 72, 74)Hundreds of ohms to kilo-ohms (typically >300 Ω)Under 2 ΩCracked 10-22 µF MLCC input bypass or catastrophic PMIC input stage
1.2V DRAM & PCIe SerDes PHY50 Ω to 200 ΩUnder 2 ΩFailed controller PHY layer; drive often link-trains then drops
0.85V to 1.0V controller core10 Ω to 50 Ω (normal baseline)0.00 Ω on both sides of the bypass capDielectric punch-through inside the controller, or a shorted bypass MLCC
Diode-mode confirms what resistance suggests. A healthy 3.3V rail reads 0.300V to 0.500V forward drop. A core rail reads 11 to 37 mV; that is the silicon's intrinsic drop, not a fault. A true short reads 0.000V on both sides of the same decoupling capacitor.
M.2 NVMe Power-Up Handshake on the Oscilloscope
Once the rails pass resistance triage, the next question is whether the controller boots when power is applied. The PCIe CEM specification fixes the timing the host & the SSD must satisfy. Probing five signals captures the entire handshake & localizes the fault to power delivery, host clocking, or controller firmware.
  1. 3.3V_AUX & 3.3V main rail ramp. The host's M.2 supply must ramp monotonically & stabilize. A sagging or oscillating 3.3V on plug-in points to a downstream short the PMIC is reflecting back to the regulator. Stop here if the rail will not hold.
  2. PMIC PWR_EN assert. Once the 3.3V input is stable, the PMIC's internal sequencer (or a dedicated enable from the controller's housekeeping domain) drives its PWR_EN logic high & sequences 1.8V, 1.2V, & the core rail. Missing PWR_EN, with 3.3V present, points to the PMIC IC itself.
  3. 100 MHz REFCLK presence. The host's differential reference clock must be stable for at least 100 µs before PERST# is released (PCIe parameter TPERST#-CLK). No REFCLK means the upstream root complex is not ready, not the SSD.
  4. PERST# de-assertion on M.2 pin 50. PERST# is an active-low fundamental reset driven by the host. PCIe TPVPERL requires the host to hold PERST# asserted for a minimum of 100 ms after power & clocks are valid. When PERST# goes high, the controller's power-on reset releases & the boot ROM runs.
  5. Link training start. After PERST# de-asserts, the controller has 20 ms to begin LTSSM link training. If link training never starts, the controller boot ROM hung; if it starts & then collapses, the firmware loaded but panicked. The NVMe layer above will never set CSTS.RDY=1, & the device disappears from BIOS enumeration.
The widely-repeated "NVMe drives have 100 ms to boot" rule is a misreading of the spec. TPVPERL is the host-side hold time on PERST#, not an endpoint boot budget. The endpoint's actual window is the 20 ms link-training start after reset is released.
Tantalum Polymer Failure: The Short Test That Passes
Enterprise & high-end consumer SSDs carry tantalum polymer bulk capacitors on the Power Loss Protection circuit. Their failure mode is different from the MLCC ceramics elsewhere on the board, & that difference defeats a naive short hunt.
Why tantalum polymer caps do not always short
Traditional MnO2 tantalums short violently under overvoltage; the manganese dioxide cathode supplies oxygen & the part can ignite. Tantalum polymer caps replace MnO2 with a conductive polymer cathode (ESR around 6 to 150 mΩ). When a dielectric defect punches through, Joule heating breaks the polymer chain locally & transforms the conductive polymer into a non-conductive barrier. That self-healing isolates the short. The part typically fails open or high-resistance rather than dead-short.
Diagnostic signature
Resistance & diode-mode short tests pass. The drive still fails its internal Power-Loss Protection BIST on boot, the controller refuses to leave its housekeeping state, & the bus drops within a few seconds of enumeration. Capacitance & ESR meters reveal the missing bulk capacitance; visual inspection rarely shows damage because the polymer self-heals internally.
Contrast with surge-failed MLCCs
Cracked MLCCs from PCB flex or surge events bridge their internal electrode layers & read as a dead short across the bypass node. The fault is loud on a multimeter. The tantalum polymer fault is silent on a multimeter & loud only on a capacitance bridge or a controller PLP self-test log.
Lifting a Shorted Tantalum with the Hakko FM-2032
When a tantalum does short (the self-healing capacity was overwhelmed), the part is lifted before any further injection testing. Leaving a shorted bulk cap on the rail guarantees the donor PMIC or replacement regulator dies the moment power is applied.
  1. Pre-heat the PCB underside to roughly 150°C on a hot plate. This narrows the temperature gradient across the lifted joint & protects nearby MLCCs from cracking on cool-down.
  2. Tin one Hakko FM-2032 tip with fresh leaded solder, then bridge the cap's anode & cathode terminations. Apply a second tip from the opposite side so both terminations reflow within a couple of seconds & the part lifts cleanly without pulling pads.
  3. Wick the pads, inspect for any remaining tombstoned solder under the microscope, & re-measure rail-to-ground resistance & diode drop. A short that lifts with the cap confirms the part was the fault. A short that persists means the next upstream or downstream component on the rail is also damaged.
  4. Replace with a tantalum polymer of the same case size, rated voltage, & ESR class. Reflow on Atten 862 hot air with shield foil over adjacent NAND packages. Repeat the diode-mode reading; the healthy rail returns to the values listed in the triage table.
Controlled Power-Cycle Imaging for Intermittent Boot
Some controllers enumerate, deliver a few thousand sectors, & then hang on a degraded NAND read. The Low-Density Parity-Check engine exhausts its read-retry budget; on SATA SSDs the firmware hangs with the ATA BSY bit asserted, while NVMe controllers either fail to assert CSTS.RDY or raise Controller Fatal Status (CSTS.CFS). Either way the host sees the bus disappear. Conventional OS drivers respond by issuing a bus reset that the panicked controller ignores, or by dropping the link entirely. Imaging continues only when power, not software, drives the recovery loop.
PC-3000 SSD's power-glitch & controlled power-cycle feature drives the rail relay on the recovery adapter, not the host OS. The sequence on a hung controller is deterministic.
  1. The imaging session times out a sector range that has stalled (millisecond-level threshold, not the multi-second OS default).
  2. PC-3000 cuts 3.3V on the adapter, waits for residual rail voltage to drain below the controller's power-on-reset threshold (a few hundred milliseconds, depending on bulk capacitance), then re-applies power.
  3. The controller cold-boots. PC-3000 re-injects its microcode loader into controller RAM via the vendor technological mode, restoring the virtual translator without relying on the panicked native firmware.
  4. Strict per-sector timeouts prevent the controller from re-entering the same LDPC cascade on retry.
This is what "power cycling" means at the lab bench, & it is not the consumer-forum advice to leave a drive in the BIOS for 30 minutes. That idle trick only allows a healthy controller to run garbage collection. It does nothing for a firmware panic, a BSY lockup, or an LDPC read-retry collapse, because the controller is halted the entire time.
A board that survives rail repair, passes the PCIe handshake on the scope, & completes a power-cycled image lands in the $450–$600 (SATA) or $900–$1,200 (NVMe) circuit board repair tier. Rush service: +$100 rush fee to move to the front of the queue. Diagnosis is free; no recovered data means no recovery fee.
PC-3000 FTL Reconstruction
PC-3000 FTL Reconstruction After Power Loss
FTL reconstruction is the process of rebuilding a corrupted Flash Translation Layer using the PC-3000 SSD's controller-specific utilities. The procedure bypasses the panicked controller firmware, injects a working microcode loader into the controller's RAM, and algorithmically rebuilds the logical-to-physical address map from surviving NAND metadata. On encrypted drives, the hardware AES decryption pipeline stays active throughout.
Five-Phase Recovery Workflow
  1. 1.
    Technological Mode Entry
    PC-3000 manipulates the SATA or PCIe interface to halt the corrupted firmware boot cycle. Depending on the controller family, this involves bridging specific PCB test points (ROM pin shorting on Phison), issuing proprietary Vendor Specific Commands (Samsung SATA controllers), or forcing past a stalled initialization via vendor ATA commands (Silicon Motion BSY state). The controller stops trying to boot from its corrupted service area.
  2. 2.
    RAM Microcode Injection
    A working microcode loader is pushed into the controller's volatile RAM. This temporarily boots the controller into a known-good diagnostic state, providing raw NAND access without touching the corrupted firmware in the service area. On drives with hardware AES-256 encryption, the injected loader preserves the decryption pipeline so extracted data is plaintext, not ciphertext.
  3. 3.
    NAND Page Header Scan
    The PC-3000 utility scans physical NAND pages across all dies, reading service area metadata, page headers, wear-level counters, and block sequence numbers from surviving blocks. This raw scan can take 2 to 12 hours depending on NAND capacity and cell degradation level. Blocks with uncorrectable ECC errors are flagged for read-retry in Phase 5.
  4. 4.
    Virtual Translator Construction
    The PC-3000 software uses the extracted metadata to emulate the controller's FTL logic in RAM on the drive itself. Block sequence numbers and page timestamps establish the correct write order. Wear-level counters resolve conflicts where multiple physical pages claim the same logical address. The result is a rebuilt logical-to-physical address map that the recovery workstation presents as a virtual drive with the original capacity and file system structure.
  5. 5.
    Data Extraction with Read-Retry
    With the virtual translator active, the drive presents its real capacity. PC-3000 images sector-by-sector to a target drive, applying hardware read-retry sequences and adjusted read voltage thresholds for cells degraded by partial page programming or wear. TLC and QLC NAND cells with ambiguous voltage states get multiple read passes at shifted threshold levels to maximize data yield.
SATA SSD firmware recovery after power loss costs $600–$1,200. NVMe firmware recovery costs $900–$1,200. If the board also needs PMIC repair before FTL work can begin, the circuit board tier applies first: $450–$600 (SATA) or $900–$1,200 (NVMe). Rush service: +$100 rush fee to move to the front of the queue.
Controller-Specific FTL Workflow Differences
Each controller family stores FTL metadata in different structures and enters different panic states after power loss. The PC-3000 loads a controller-specific module for each.
Phison (PS3111-S11 SATA, PS5012-E12 NVMe)
SATA variants enter ROM MODE via the SATAFIRM S11 panic state; NVMe variants (E12) drop off the PCIe bus or report a generic ROM state. The Phison-specific loader accesses panic registers and reads the service block area where FTL snapshots are stored. The virtual translator is rebuilt from surviving page metadata in these service blocks. Phison's FTL uses a log-structured merge approach; recovery depends on how much of the merge log survived the power event.
Silicon Motion (SM2258, SM2259XT, SM2262EN)
BSY state or generic 1GB ROM mode. PC-3000 forces the controller past stalled initialization using vendor ATA commands unique to the SM22xx family. FTL reconstruction reads dedicated system blocks where Silicon Motion controllers store mapping table checkpoints. The SM2259XT (used in DRAM-less budget SATA SSDs like the Crucial BX500) is prone to power-loss FTL corruption because it relies on a small internal SRAM cache instead of dedicated DRAM for FTL metadata.
Samsung SATA (MKX) and Samsung NVMe (Elpis)
Samsung SATA (MKX) and NVMe (Elpis) controllers are unsupported by the PC-3000 firmware utilities; firmware-level FTL reconstruction is not currently available for these chips. Hardware AES-256 encryption binds the media encryption key to the controller die. If the controller is electrically dead, board repair to restore the power delivery circuit is the only viable recovery path so the original controller can boot and decrypt the NAND.
Marvell (88SS1074)
PC-3000 SSD supports the Marvell 88SS1074, so firmware-level FTL reconstruction is available for this controller; the controller's LDPC error correction is why recovery runs through the original controller rather than raw NAND reads. Board-level repair to restore power delivery comes first when the failure is strictly electrical, after which the controller can boot. The 88SS1074 is found in drives like the WD Blue 3D SATA and SanDisk Ultra 3D.
Journal Replay vs. Full NAND Scan
PC-3000 uses two methods to reconstruct the FTL after power loss. The choice depends on whether the controller's journal entries survived the outage.
Journal Replay (primary method)
PC-3000 targets the SSD's reserved service area, scanning for surviving FTL journal logs. These logs record recent delta changes to the mapping table. The utility replays these transactions sequentially, rolling back corrupted state to assemble a virtual translator. Journal replay is faster & produces higher data yield when journal entries survive intact.
Full NAND Scan (fallback method)
If the journal itself is destroyed, PC-3000 falls back to reading raw page-level metadata across all physical pages: spare area bytes, page headers, & logical block sequence numbers. The map is reconstructed from scratch. This process takes 2 to 12 hours per TB depending on NAND condition & cell degradation, but it is resilient against severe journal corruption where replay isn't possible.
Orphan Log Entries & the Crash Recovery State Machine
The FTL journal is the small, append-only log a controller writes to NAND every time the logical-to-physical mapping changes. Journal entries get coalesced into the full L2P table during scheduled checkpoints. Power loss between those checkpoints leaves the journal in one of three desynchronized states, each with a different recovery profile.
On power-up, the controller's crash recovery routine runs a sanity check against the last good checkpoint, walks the journal forward, and tries to replay every entry into the in-DRAM L2P table. Orphan entries are entries whose preconditions (the prior mapping state) no longer match what the journal expects. The bootloader must decide whether each orphan is safe to ignore, safe to replay, or fatal.
Three classes of orphan log entry
Class A: journal entry written, page program never completed
The controller logged a mapping update for LBA N to physical page P, then lost power before page P was finished. The journal points at a half-programmed cell. On replay, the controller reads page P, hits ECC failure, and flags the entry as a fatal corruption. PC-3000 handles this by ignoring the orphaned mapping and falling back to the prior valid mapping recovered from page metadata.
Class B: page program completed, journal entry never written
The new data made it to NAND but the journal still references the old physical address. On reboot, the controller serves stale data from the old page. The newly written data is still on NAND with a valid logical block address in its spare-area metadata stamp. PC-3000 full NAND scan finds the newer page by comparing block sequence numbers and timestamp counters across all surviving pages, then replaces the stale journal pointer in the rebuilt virtual L2P.
Class C: journal block itself hit by lower-page disturb
Power loss during an upper-page program on the same word line that holds journal entries destroys the journal's lower-page contents through paired-page disturb. The controller's ECC engine cannot recover the journal blocks at all, and the bootloader fails its sanity check. The drive halts boot and enters ROM mode (Phison) or stalls BSY (Silicon Motion). Journal replay is not an option; recovery requires the full NAND scan path.
Crash recovery is not magic. It is a state machine with finite branches, and every branch leaves a different fingerprint on the NAND. PC-3000 inspects the surviving journal pages, identifies which class of orphan dominates, and chooses between forward journal replay, journal rollback, or full NAND metadata reassembly. The choice is driven by what survived, not by what the customer asks for.
PLP Built-In Self-Test & Why Aged Enterprise SSDs Fail
Enterprise SSDs with hardware Power Loss Protection do not trust their own capacitors. The controller runs a periodic Built-In Self-Test (BIST) against the tantalum polymer cap bank, measures the energy it can deliver, and reacts when the bank degrades below the threshold required to flush the DRAM cache.
Tantalum polymer caps degrade slowly under thermal stress. Equivalent series resistance (ESR) climbs, capacitance drops, and the energy budget for a controlled shutdown shrinks. A new enterprise SSD might hold 35 millijoules across its cap bank at rated voltage; the same drive after five years in a hot server chassis might deliver under 12 millijoules. Twelve millijoules is enough to write a few hundred bytes of journal but not enough to flush an 8 GB DRAM cache.
What the BIST measures
  • Capacitance: the controller charges the bank, disconnects the host rail momentarily during idle, measures the voltage decay slope across a known load, and back-calculates total stored energy.
  • ESR: a small AC perturbation is applied to the bank and the resulting voltage ripple is measured against the expected impedance. Rising ESR is the early warning sign of polymer degradation.
  • Hold-up time: a synthetic shutdown sequence is timed end-to-end against the worst-case DRAM flush size. If the bank can't sustain the rail long enough, the test flags the drive.
What the controller does when BIST fails
The firmware disables the write-back cache and forces all writes into synchronous write-through mode. Latency climbs, IOPS drops, but the drive can no longer lose in-flight data to a power event because there is no in-flight data sitting in DRAM. The drive also flips a SMART attribute (SMART 175, "Power Loss Protection Failure," on Intel and Micron enterprise drives) so the host can alarm on it.
Drives that lose data during a power outage despite carrying enterprise PLP almost always show prior BIST failures in their SMART logs or have aged caps that nobody monitored. Intake on a power-loss enterprise SSD includes pulling vendor-specific SMART pages and bench-testing the cap bank against original specification before any firmware work begins. Cap replacement happens before FTL reconstruction so the drive is not rebuilt only to fail the same way on the next outage. Circuit board repair tier applies: $450–$600 (SATA) or $900–$1,200 (NVMe).
Post-Power-Loss SSD Symptom Matrix
Power-loss SSD failures follow predictable patterns. The visible symptom narrows down the controller state, which narrows down the recovery path. The table below maps the most common symptoms to root cause and the corresponding lab procedure.
Symptom at hostController stateRoot causeRecovery path
BIOS no-detect, no linkDead or unpoweredBlown PMIC, failed voltage regulator, shorted output cap from surgeElectrical triage, FLIR localization, PMIC microsolder replacement
BSY (busy), hangs POSTInfinite init loopSilicon Motion controller looping read-retry on degraded FTL blocksPC-3000 vendor ATA command, force past stalled init, microcode injection
Reports "SATAFIRM S11" at 8MB / 2MB / 0ROM Mode fallbackPhison PS3111-S11 hit fatal ECC in FTL service blocksROM-pin short for technological mode, Phison loader, journal replay
Enumerates at 0 capacitySafe mode, default identityFTL unreadable, controller dropped programmed IDENTIFY valuesTechnological mode entry, full NAND scan, virtual L2P rebuild
Correct capacity, OS freezes on file accessPartial FTL, retry stormPaired-page disturb damaged specific logical regions, ECC retries time outImage immediately, adjust read voltage thresholds for retry-degraded cells
Drive forced into read-onlySelf-protective lockFirmware detected systemic FTL inconsistency, blocked further writes & TRIMImage now through write blocker, no chkdsk, no fsck, no repair tools
Drops off bus mid-IO, returns after power cycleBrown-out recurrenceAged PLP caps failing BIST, write-through forced, host timing outTantalum cap replacement, then FTL consistency check & imaging
Reports raw controller name (MN-5236, SM2258XT, MAP1602)ROM identity, no firmware loadedMain firmware refused to load from corrupted service areaController-specific PC-3000 module; some controllers fall outside supported coverage (see note below)
Symptoms can stack. A drive that survived a surge with a damaged PMIC will look BIOS-no-detect until the board is repaired, then reveal a SATAFIRM S11 or BSY state once power is restored to the controller. Intake works the symptoms in physical order: power delivery first, then controller state, then FTL reconstruction. SATA firmware recovery costs $600–$1,200; NVMe firmware recovery costs $900–$1,200. Board repair tier applies separately when both layers fail.
Some raw controller names that appear after a power-loss panic correspond to controllers that fall outside PC-3000 SSD's supported coverage list. The Maxio MAP1602 (used in budget NVMe drives) is one example. Rossmann does not currently offer in-lab recovery for Maxio MAP1602. For modern Samsung in-house controllers (Polaris, Elpis, MGX), firmware-level FTL reconstruction is not currently supported either; those controllers are not on ACE Lab's PC-3000 SSD supported-controller list, and those drives are taken case by case.
PC-3000 Vendor Commands & Service Area Structure
The five-phase workflow describes the recovery arc at a high level. The detail below is what each phase looks like at the wire protocol layer: which vendor-specific commands the PC-3000 issues, what the service area actually holds, and how the L2P translator gets rebuilt page by page.
Technological mode entry: vendor command paths
Standard ATA and NVMe command sets cannot reach a controller in panic. PC-3000 SSD ships controller-family modules that issue undocumented vendor-specific commands outside the public spec. The entry method varies by family.
Phison (PS3111-S11, PS5012-E12)
Two methods. First, a ROM-mode test point on the PCB is bridged while power is applied; this forces the Mask ROM to skip the corrupted service-area boot and accept a loader over the host interface. Second, when the test point is not accessible, PC-3000 sends a Phison-specific vendor command sequence that triggers the ROM's diagnostic entry without the physical short. The PS5012-E12 (NVMe) accepts a similar sequence over the PCIe admin queue using a vendor opcode in the 0xC0 range.
Silicon Motion controllers stalled in BSY are unblocked with an SM-family vendor ATA command that interrupts the read-retry loop and drops the controller into a diagnostic state where it accepts microcode upload. The exact command byte differs between SATA and NVMe variants and between firmware generations, which is why PC-3000 modules are released per controller revision. No PCB bridging is required for most SM SATA variants.
Marvell (88SS1074)
Marvell controllers expose a UART debug interface on PCB test pads that is used at the factory for production debug. PC-3000 SSD supports the 88SS1074, so firmware-level FTL reconstruction is available for this controller through that diagnostic path. Board-level repair to restore the power delivery circuit comes first when the failure is strictly electrical.
Service area module map
Once the loader is running, the service area becomes addressable. The service area is not a single file; it is a partitioned region of NAND that holds dozens of numbered modules, each storing a different piece of the controller's state. The exact map is controller-specific, but the categories are consistent.
  • Bootloader and main firmware images, with two or three redundant copies. Power loss usually leaves at least one copy intact.
  • FTL journal modules, the append-only log of recent mapping changes. The most recent journal segments are the ones at risk after a power event.
  • L2P checkpoint modules, the periodic full snapshots of the mapping table. Checkpoints are written infrequently, so they are usually older than the journal tip but more likely to be intact.
  • Bad block tables, P/E cycle counters, and read-voltage offset tables per die. These are critical for reading NAND back accurately during imaging.
  • Encryption key descriptors. The key material itself is bound to controller hardware fuses, but the descriptor selects which key slot decrypts which LBA range. On encrypted drives, this descriptor is what makes board repair the only viable recovery path when the controller silicon dies.
L2P rebuild from surviving metadata
With the SA modules dumped to the workstation, PC-3000's utility walks the extracted state in this order: ECC and geometry first, then bad block tables, then the last good L2P checkpoint, then journal forward-replay up to the first orphan entry. When the journal tip is corrupted, the utility switches to the full NAND scan path: every physical page is read, its spare-area metadata is parsed for the logical block address & the block sequence number, and the highest-sequence valid mapping wins. The rebuilt L2P lives in RAM on the drive itself. The customer SSD is never written back to.
Once the virtual translator is consistent, Data Extractor presents the rebuilt drive as a sector-addressable image. File system reconstruction happens against this image, not against the original SSD. SATA SSD firmware recovery after power loss costs $600–$1,200. NVMe firmware recovery costs $900–$1,200. Rush service: +$100 rush fee to move to the front of the queue.
Why Does Running chkdsk or fsck on a Power-Loss SSD Destroy Data?
The reflex after a sudden shutdown is to boot the machine, watch Windows offer to repair the volume, and click Yes. On a hard drive, that habit is harmless. On an SSD with a damaged FTL, every chkdsk or fsck pass destroys recoverable data before any imaging tool can read it.
An SSD never overwrites pages in place. Every metadata write the file system issues forces the controller to allocate fresh NAND pages, update the FTL mapping, and queue the previous physical location for garbage collection. When the controller is already in a degraded state because its journal is half-written, those new writes advance the FTL state past the point where PC-3000 can replay the surviving journal entries. Recovery downgrades from journal replay to full NAND scan, then from full NAND scan to chip-off, with each escalation losing yield.
chkdsk /f rewrites the NTFS Master File Table
The /f flag instructs Windows to repair file system errors by rewriting MFT records and journal entries. On a power-loss SSD, every MFT write forces a controller-side wear-level operation. The controller picks a fresh erase block, programs the new MFT data, and updates the FTL to point the logical MFT address at the new physical block. The previous physical page, which may still contain the only intact copy of the pre-power-loss MFT, gets queued for erasure.
TRIM amplification during repair operations
When chkdsk flags large extents as orphaned and marks the corresponding clusters free in the NTFS $Bitmap, the Windows storage stack issues TRIM (DSM Deallocate on NVMe) for every flagged LBA. The controller marks those physical pages for immediate erasure. Pages that held recoverable user data before chkdsk ran are zeroed at the controller level, with no recovery path through firmware tools.
fsck.ext4 journal replay collides with the FTL journal
ext4 maintains its own metadata journal at the file system layer. The kernel ext4 driver replays uncommitted transactions during mount when the superblock is flagged dirty; fsck.ext4 (e2fsck) replays them in userspace before mount when invoked manually. Either path writes new data into block groups across the volume, and each write triggers a separate FTL update. Journal replay is correct from the OS perspective; it is destructive from the recovery perspective because the controller's pre-existing FTL journal still contained the original write order needed to reconstruct logical addresses.
Repair-Volume on a panicked controller hangs the system
When the controller has dropped to ROM mode and reports an anomalous capacity (SATAFIRM S11 enumerates as 0 bytes; MN-5236 enumerates as roughly 2 MB or 2 GB; MAP1602 enumerates with a generic placeholder capacity), Repair-Volume cannot issue valid IO. The cmdlet stalls the storage stack, often forcing another hard reboot. The repeated power cycles compound the original power-loss event, advancing the controller through more failed initialization attempts and consuming additional NAND program-erase cycles on its panicked write-retry logic.
The correct procedure after a power-loss SSD failure is to power the drive down, disconnect it from the host, and ship it for imaging. PC-3000 SSD reads NAND through the controller's vendor command interface without ever mounting the file system, so the FTL state at intake is preserved through the reconstruction phase. Imaging completes against the static state of the NAND at the moment recovery begins.
How Do Recovery Labs Detect Failed PLP Capacitors on Enterprise SSDs?
Enterprise drives like the Intel D3-S4510, Samsung PM9A3, and Micron 7450 carry tantalum polymer capacitors that hold the controller and DRAM up for 10 to 50 milliseconds after the host rail collapses. After several years in a hot rack, those capacitors lose capacitance and equivalent series resistance climbs. The drive still passes power-on self-test but no longer survives a real power event. Detecting the degraded capacitor before recommending firmware reconstruction is part of intake diagnostics.
Visual inspection under stereo microscope
Tantalum polymer capacitors near the PMIC are inspected for thermal damage, package cracking, scorching around the anode lead, and discoloration of the marking band. Solid polymer caps do not contain liquid electrolyte and do not outgas; failure manifests as charring from a short-circuit event or off-axis warpage where solder pads have softened under sustained heat. Flagged caps are removed and tested off-board.
ESR and capacitance off-board
An ESR meter checks each removed cap against its rated capacitance. A drop of more than 20 to 30 percent from rated value, or an ESR reading several times the manufacturer spec, confirms wear-out. Tantalum polymer capacitors degrade with operating hours and temperature; the typical failure mode is gradual capacitance loss and rising ESR, with sudden short-circuit events possible under thermal stress.
FLIR thermal scan during write load
A degraded PLP cap with elevated ESR dissipates more heat under sustained write load than its neighbors. FLIR thermal imaging during a controlled write workload highlights individual caps running 5 to 10 degrees Celsius hotter than peers, which confirms the degradation visually before off-board testing.
Hold-up time test on a bench supply
The drive is powered from a bench supply with the rail switched off mid-write while a logic analyzer captures the controller's shutdown handshake. A healthy enterprise drive completes its FTL flush within the rated hold-up window; a drive with degraded caps drops the rail before the flush completes, which is exactly the failure mode that produced the original power-loss corruption.
When intake confirms degraded PLP caps, replacement happens before any FTL work begins. Hakko FM-2032 microsoldering removes the failed tantalum polymer caps; donor parts of the same capacitance, voltage rating, and ESR class are reflowed into place. Without this step, a successful FTL reconstruction would still leave the drive vulnerable to the same failure on the next power event after it leaves the lab. Circuit board repair on enterprise SSDs falls in the $450–$600 (SATA) or $900–$1,200 (NVMe) tier; firmware reconstruction afterward applies the $600–$1,200 (SATA) or $900–$1,200 (NVMe) tier. Rush service: +$100 rush fee to move to the front of the queue.
Short answers for power outage, surge, 0-byte, SATAFIRM S11, and software recovery questions.
Can data be recovered from an SSD after a power outage?
Yes, in most cases. Power loss corrupts the Flash Translation Layer (FTL) mapping in volatile DRAM, but the actual data remains on the NAND flash chips. The PC-3000 SSD bypasses the panicked controller, reads surviving NAND metadata, and reconstructs a virtual translator to image the data. SATA SSD recovery costs $600–$1,200. NVMe SSD recovery costs $900–$1,200. Free evaluation, firm quote, no data no fee.
Why did my SSD stop working after a power surge?
A power surge sends excess voltage through the SATA power connector or M.2 slot. The Power Management IC (PMIC) and TVS diodes absorb the overvoltage, often burning out to protect the controller and NAND. The drive stops enumerating in BIOS because the power delivery path is broken. The NAND flash retains its charge and data. Replacing the blown PMIC via microsoldering restores the original power rails so the controller boots and decrypts normally.
Can recovery software fix an SSD after power loss?
No. Recovery software operates through the OS storage driver and requires a functioning controller to translate logical addresses to physical NAND locations. After power loss, the controller is either locked in firmware safe mode (reporting 0 bytes or SATAFIRM S11) or electrically dead from a blown PMIC. Software has no path to the data. The PC-3000 communicates directly with the controller at the vendor command level, bypassing safe mode.
Will formatting fix an SSD that shows 0 bytes after power loss?
No. A drive reporting 0 bytes has lost its firmware translation layer. The controller cannot present valid capacity to the OS, so format commands either fail or target raw NAND addresses directly. Formatting in this state overwrites the fragmented FTL metadata logs that professional recovery tools need to rebuild the virtual translator. Power off the drive and do not attempt formatting.
How much does SSD power loss recovery cost?
SATA SSD firmware recovery after power loss costs $600–$1,200. NVMe SSD firmware recovery costs $900–$1,200. If the PMIC or voltage regulators are blown from a surge, circuit board repair costs $450–$600 (SATA) or $900–$1,200 (NVMe). Free evaluation, firm quote before any paid work. No data recovered means no charge.
What is the difference between power loss on a consumer SSD vs an enterprise SSD?
Enterprise SSDs include hardware Power Loss Protection (PLP) using onboard tantalum capacitors that provide 10 to 50 milliseconds of emergency power to flush the DRAM cache to NAND during an outage. Consumer SSDs rarely include PLP capacitors due to cost and size constraints, relying on firmware journaling instead. Firmware journaling cannot save data that existed only in volatile DRAM at the moment of power loss. Consumer drives are more vulnerable to FTL corruption from sudden power events.
Why does my SSD show the wrong name or 0 bytes after a power outage?
The controller has entered ROM or Safe Mode due to FTL corruption. It drops its programmed identity & reports a raw controller name (SATAFIRM S11, MN-5236, MAP1602, SM2258XT) with 0 bytes or a tiny capacity like 2MB. Consumer recovery software can't communicate with a panicked controller. On the controllers ACE Lab supports, PC-3000 enters diagnostic mode, bypasses the corrupted firmware, & reconstructs the FTL from surviving NAND metadata. InnoGrit IG5236 and Maxio MAP1602 are absent from that list. Rossmann does not currently offer in-lab recovery for InnoGrit IG5236 or Maxio MAP1602. SATA firmware recovery: $600–$1,200. NVMe firmware recovery: $900–$1,200.
Does the 30-minute SSD power cycle trick work after power loss?
The 30-minute power-only idle trick works only when the SSD controller is healthy enough to finish background cleanup. It does not repair a blown PMIC, a 0-byte ROM Mode panic, or SATAFIRM S11 firmware corruption. If the board has a short, leaving power applied can heat the failed component while the controller still has no usable FTL map.
Can a UPS protect my SSD from power loss corruption?
A UPS protects against utility power outages but doesn't prevent all power loss scenarios. A forced hard reboot (holding the power button during a blue screen), an OS crash, or a kernel panic produces the same asynchronous power loss to the SSD. The drive's FTL flush is interrupted regardless of whether the wall outlet has power. Enterprise SSDs with onboard PLP capacitors protect against all sudden power events; consumer SSDs rely on the host system shutting down gracefully.
Is my SSD's data gone after a power surge?
Usually not. A power surge burns out the PMIC & TVS diodes on the circuit board, cutting power delivery to the controller. The NAND flash chips retain their stored charge & data. Board-level microsoldering replaces the destroyed PMIC, restoring the original voltage rails so the native controller boots & decrypts the data through its own hardware encryption pipeline. Circuit board repair costs $450–$600 (SATA) or $900–$1,200 (NVMe).
Why can't recovery software fix my SSD after a power failure?
Recovery software operates through the OS storage driver & requires a functioning controller. After power loss, the controller is locked in firmware safe mode (reporting 0 bytes or SATAFIRM S11), stuck in a BSY initialization loop, or electrically dead from a blown PMIC. Software has no path to the data because the controller won't translate logical addresses to physical NAND locations. PC-3000 communicates at the vendor command level, injecting a working microcode loader directly into the controller's RAM to bypass the corrupted firmware.
My SSD won't boot after a power outage and BIOS can't see it. What happened?
The controller failed its power-on self-test. After power loss, the bootloader reads the service area, hits uncorrectable ECC errors in the FTL journal blocks, and refuses to assert ready on the SATA or PCIe link. The host firmware times out waiting for the drive to enumerate, so the BIOS shows no device. The NAND is intact; the controller can't reach a state where it would present a logical block device. PC-3000 SSD forces the controller past the failed boot sequence using vendor commands, then rebuilds a virtual translator from surviving NAND metadata. SATA firmware recovery: $600–$1,200. NVMe firmware recovery: $900–$1,200.
Why does my SSD show 0 capacity (0 bytes / 0 GB) after a power loss?
A 0-capacity report means the controller booted into a hardware safe mode and dropped its programmed identity. The Flash Translation Layer is unreadable, so the controller can't expose any usable LBA range. Instead of refusing to enumerate, it answers IDENTIFY with default placeholder values: 0 bytes, a raw controller string, and zero serial number. Read & write commands are rejected at the firmware layer. Continued power-on attempts risk triggering background garbage collection that erases recoverable blocks. Pull power, ship the drive in for evaluation. Firmware recovery costs $600–$1,200 (SATA) or $900–$1,200 (NVMe).
Why is my SSD detected as 8MB after power loss?
An 8MB (sometimes 2MB or 1GB) capacity is the factory bootloader's placeholder. The controller couldn't load its main firmware from the NAND service area after the outage corrupted the FTL, so it stayed in ROM mode and reported a hardcoded fallback size. This is common on Phison PS3111-S11 drives (Kingston A400, Patriot Burst) and on some Silicon Motion DRAM-less controllers. The data on the NAND is intact. PC-3000 SSD enters technological mode, injects a working microcode loader into the controller's RAM, and reconstructs the FTL from surviving service-area metadata. Recovery: $600–$1,200 (SATA) or $900–$1,200 (NVMe).
My SSD went read-only after a power loss. Can I still recover data?
Yes, and the read-only state is protective. When the controller detects systemic FTL inconsistencies after a power event, it can lock the drive into a hardware-enforced read-only mode to block garbage collection and TRIM. The mapping that exists at that moment is frozen. Image the drive immediately to a known-good target before doing anything else; the read-only window provides a stable recovery condition. Do not run chkdsk, fsck, or any repair utility. Do not format. Do not reboot repeatedly hoping the drive recovers itself. Imaging through a write blocker preserves the surviving FTL state for full file extraction.
Does a slow brownout damage an SSD differently than a hard power cut?
Yes. A clean hard cut at the wall outlet drops VCC fast enough that the controller's PLP logic (if present) gets a clean interrupt and triggers an emergency flush. A slow brownout, where VCC sags below the regulator's minimum operating voltage gradually, is worse for SSDs without enterprise PLP. The controller keeps issuing NAND program pulses at degraded voltages, producing partial page programs and indeterminate cell voltage states across multiple blocks. The result is wider FTL corruption and more lower-page disturb damage than a clean cut would cause. A UPS that switches to battery on a brownout, rather than waiting for full outage, eliminates most of that exposure.
Trust
Why Trust Rossmann with SSD Power Loss Recovery?
SSD power loss recovery is electronics repair plus firmware reconstruction. We repair shorted PMICs with Hakko FM-2032, locate failed parts with FLIR thermal cameras, and rebuild FTL maps with PC-3000 SSD at our Austin, TX lab. Pricing is published, the evaluation is free, and no recovered data means no recovery fee.
Single Austin lab
All SSD data recovery work is performed in-house at 2410 San Antonio Street in Austin, TX. Mail-in service is nationwide; there are no franchises, satellite benches, or outsourced SSD power-loss recoveries.
Board repair is data recovery
Modern SSDs bind AES-256 encryption to the original controller. PMIC replacement, regulator repair, and Zhuo Mao BGA rework keep that controller alive so the NAND decrypts through its normal hardware path.
Published SSD pricing
SATA SSD pricing starts at $200 and ranges to $200–$1,500. NVMe SSD pricing starts at $200 and ranges to $200–$2,500, with rush service listed in the pricing files.
Founded in 2008
Rossmann Repair Group was founded in 2008. The same repair discipline used for component-level board work applies to SSD recovery: measure rails, identify the failed silicon, repair the board, then image the data before returning media.
SSD dead after a power outage or surge?
Free evaluation. SATA: $600–$1,200. NVMe: $900–$1,200. No data, no fee.
