Chip-Off NAND Data Recovery
What is chip-off NAND recovery?
Chip-off NAND recovery is a last-resort physical extraction that accesses a dead SSD's data without its controller: a technician desolders the NAND flash chips and reads their raw hex pages directly. It works only when the controller is unrecoverable & the drive has no active hardware encryption, such as legacy SATA controllers with encryption disabled, USB flash drives, SD & microSD cards, or unencrypted monolithic eMMC chips.
It cannot decrypt a hardware-encrypted drive, because the AES-256 key is bound to the original controller silicon. On Apple T2 and M-series, chip-off returns only ciphertext, so board-level microsoldering to revive the original controller is the only recovery path.
Chip-off recovery physically desolders the NAND flash memory chips from an SSD's circuit board using BGA rework equipment, then reads raw hex data directly from each chip. This bypasses the failed controller entirely. It is the last-resort method used when the controller is physically destroyed and firmware tools like the PC-3000 cannot establish communication. For non-encrypted drives, the raw NAND data must then be reconstructed by reverse-engineering the controller's data interleaving pattern, ECC algorithms, and block mapping. There is a critical limitation: modern drives with hardware encryption store the encryption key in the controller's secure enclave. Apple T2/M-series and Samsung 980/990 Pro implement AES-256 encryption with keys bound to the specific controller silicon. If the controller is destroyed, the keys are gone and chip-off returns only encrypted ciphertext. For these drives, recovery requires restoring the original controller's functionality through board-level repair or firmware intervention, not transplanting NAND to a different controller. We use Hakko microsoldering stations and BGA rework for the physical extraction process.
Methodology Fit
When chip-off NAND recovery works, and when AES-256 makes it pointless
Chip-off is the correct recovery method only when the controller is physically destroyed and the drive does not use controller-bound AES-256 hardware encryption. On modern hardware-encrypted SSDs the Media Encryption Key lives in the original controller silicon, so removing the NAND yields ciphertext and the only recovery path is board-level repair of the original PCB.
Chip-off is the right method
  • Legacy SATA controllers with no hardware encryption (Phison PS3111-S11).
  • USB flash drives, SD and microSD cards, and budget thumb drives where the storage class never implemented hardware encryption.
  • Monolithic eMMC packages on phones, drones, dashcams, and IoT devices where the application processor did not bind a storage key to its secure enclave.
  • Controller silicon cracked, burned, or otherwise unable to power on, with no encryption to defeat once raw NAND is read.
Chip-off cannot recover the data
  • Samsung 980 Pro and 990 Pro NVMe with always-on AES-256 wrapped by the controller's hardware-unique root.
  • Apple T2 and M-series logic boards where the SSD class key is wrapped by a Unique ID fused into the Secure Enclave.
On unencrypted legacy drives and on monolithic packages, the physical workflow is the same regardless of whether the NAND sits in a discrete BGA-152 footprint on a SATA PCB or inside a single-package eMMC ball-grid. The package is reflowed on a Zhuo Mao BGA rework station with a die-safe thermal profile, and Hakko FM-2032 handpieces on FM-203 or FX-951 base stations handle adjacent component work without disturbing neighboring silicon. An Atten 862 hot air station is used for lower-mass passives and rework cleanup. Once the dies are clean, raw reads come off a PC-3000 Flash rig and the Flash Translation Layer, XOR scramblers, and ECC are reconstructed in software. For the deeper procedural breakdown on single-package devices, see monolithic NAND recovery.
On a hardware-encrypted SSD the same chip-off workflow produces only AES-256 ciphertext, because the Key Encryption Key derived from the controller's silicon-unique fuses never leaves that die. Transplanting NAND to a donor controller of the same model fails for the same reason: a different silicon root key cannot unwrap the original Media Encryption Key. The only viable path is repairing the original PCB so the original controller boots and decrypts the NAND through its own AES engine. That is why a modern SSD data recovery service is a board-repair discipline first and a chip-off discipline second: PMIC and voltage-regulator replacement, cold-joint controller reflow on the Zhuo Mao station, and microsoldered passive rework with the Hakko FM-2032 to restore the controller power circuit without disturbing the silicon-bound root key that wraps the MEK.
All chip-off and board-level work on these targets is performed at the Austin, TX lab, with no diagnostic fee and no data, no recovery fee.
18 min read
How to Ship Your SSD for Chip-Off Evaluation
Don't power on the drive. Every power cycle on a failing SSD risks a firmware panic state, TRIM execution on corrupted mapping tables, or further controller degradation. Remove it from the computer & ship it unpowered.
  1. Wrap the bare drive in an anti-static bag. M.2 NVMe drives fit in a small USPS flat-rate box or a padded FedEx envelope.
  2. Surround the drive with foam or bubble wrap. Avoid loose packing peanuts; they shift during transit & leave the drive unprotected against impact.
  3. Ship to our Austin, TX lab. Call (512) 212-9111 if you need the mailing address or have questions about packaging.
  4. Evaluation is free. We call you with a firm quote before any work begins. If chip-off isn't viable (encrypted controller, cracked NAND), we tell you that instead of charging for work that can't succeed.
Contact us for shipping labels & drop-off instructions.
What Is Chip-Off Data Recovery and When Is It Necessary?
Chip-off data recovery physically removes NAND flash memory chips from the SSD circuit board and reads them on a dedicated chip reader, bypassing the controller. It is the last resort when the controller is destroyed beyond repair and cannot respond to any diagnostic commands.
This is not the first option. Firmware corruption recovery using the PC-3000 and board-level controller repair via Hakko microsoldering are always attempted before chip-off. These methods preserve the original controller and, critically, any encryption keys stored inside it. Chip-off is only used when the controller silicon is cracked, burned, or otherwise unable to power on.
Chip-off is destructive. The NAND chips are permanently removed from the board. The drive cannot be reassembled or returned to service afterward. Once the chips are desoldered, there is no going back to controller-based recovery. This is why we exhaust all other options first.
How Does The BGA Rework Process
How Does the BGA Rework Process Work?
BGA rework uses controlled heat profiles to desolder NAND packages from the PCB without thermal damage to the silicon die. Each chip is then read individually, and the raw data is reconstructed by decoding the controller's interleaving and error correction algorithms.
  1. 01
    NAND Identification
    NAND flash chips are identified and cataloged on the PCB. Manufacturer, part number, die configuration, and number of chips are recorded. This determines the correct reader adapter and decoding parameters.
  2. 02
    Controlled Desoldering
    The Zhuo Mao BGA rework station heats each NAND package at precise temperature profiles to melt the solder balls without exceeding the thermal limits of the silicon die. Overheating destroys the NAND.
  3. 03
    Raw NAND Reading
    Cleaned chips are placed in a chip reader (PC-3000 Flash reader or equivalent). Raw hex data is dumped from each chip. This data is scrambled; it is not a readable file system.
  4. 04
    Interleaving and ECC Reconstruction
    The controller's specific data interleaving pattern (how it striped data across multiple chips) must be reverse-engineered. ECC (Error Correction Code) algorithms are applied to correct corrupted pages. The Flash Translation Layer and block mapping are reconstructed manually.
  5. 05
    File System Extraction
    Once the logical data layout is rebuilt, the file system is extracted and verified against expected directory structures. Files are delivered on your choice of return media.
Why Chip-Off Fails On Modern Encrypted
Why Chip-Off Fails on Modern Encrypted Drives
Hardware encryption renders chip-off useless when the controller holding the decryption key is destroyed. The NAND contents are AES-256 ciphertext. Without the key from the controller's secure enclave, brute-forcing the encryption is computationally infeasible with any current or foreseeable technology.
Apple T2 and M-Series Macs
All NAND data is hardware-encrypted with a key stored in the Secure Enclave on the T2 chip or M-series SoC. The SSD storage is soldered to the logic board. If the controller (or the entire SoC) is destroyed, the encryption key is gone. Chip-off returns only encrypted garbage. For details on recovery options that preserve the controller, see our Apple T2 chip data recovery and M-series soldered NAND recovery pages.
Samsung NVMe (980 Pro, 990 Pro)
Samsung's Elpis (980 Pro) and 990 Pro controllers implement AES-256 hardware encryption by default, even without a user-set password. The Media Encryption Key lives in the controller's secure enclave. If the controller is destroyed, the key is gone and the NAND contents are unreadable ciphertext.
Where Chip-Off Works
Older SATA SSDs without hardware encryption, USB flash drives, SD cards, microSD cards, and some budget NVMe drives that do not implement hardware encryption. On these devices, chip-off produces unencrypted raw data that can be reconstructed into a usable file system.
If your drive uses controller-bound encryption (Apple T2/M-Series, Samsung 980 Pro and 990 Pro) and the controller is destroyed, the data is unrecoverable. The encryption key dies with the controller. The only path is restoring the original controller through board-level electrical repair or firmware intervention. For a deeper breakdown of how Media Encryption Keys are bound to controller silicon and why donor-board swaps fail, see our SSD hardware encryption reference.
AES-256 / MEK Silicon Barrier
AES-256 Media Encryption Key Silicon Barrier
On SSDs that implement hardware encryption, the NAND is encrypted at the controller, not at the operating system. A 256-bit Media Encryption Key (MEK) generated on-die at factory init drives an inline AES-XTS engine that sits between the host interface & the NAND.
Pull the chips off the board & you get high-entropy ciphertext with no MBR, no GPT, no NTFS or APFS headers. There is no key to recover off the NAND because the key was never on the NAND. Reviving the original controller is the only path to plaintext.
The MEK is produced inside the controller die by an on-die hardware True Random Number Generator the first time the drive powers on at the factory. That 256-bit value is then wrapped by a Key Encryption Key derived from a Hardware Unique Key fused into the controller silicon. The plaintext MEK never crosses the SATA or PCIe bus, never appears in NVMe admin traffic, & never lands on the NAND in cleartext form. It exists only in the controller's on-die SRAM at runtime & in wrapped form in the system area.
Every page-write traverses a dedicated AES-XTS hardware block inside the controller before the data reaches the NAND. This encryption is always-on regardless of whether the user ever set an ATA password or an Opal PIN; TCG Opal SSC 2.01 & IEEE 1667 define how the host enrolls a passphrase to gate access to the already-encrypted volume. Always-on encryption is also why Instant Secure Erase & cryptographic erase complete in milliseconds: the controller throws away the wrapped MEK & every prior write becomes unreadable noise without touching a single NAND cell.
Apple T2 & M-series SoCs, Samsung 980 Pro (Elpis) & 990 Pro, & most current NVMe controllers implement this architecture. Rossmann does not currently offer in-lab recovery for Apple T2. Rossmann does not currently offer in-lab recovery for Apple M-series. Rossmann does not currently offer in-lab recovery for Realtek RTS5762. Samsung in-house controllers are not on ACELab's PC-3000 SSD supported-controller list, and the lab takes those drives case by case. The architectural point holds across the category: if the silicon holding the MEK is dead, the wrapped key cannot be unwrapped & the NAND remains ciphertext.
A clean BGA extraction with the Atten 862 hot air station & reflow on the Zhuo Mao rework setup will return raw NAND pages, but those pages are AES-256 output. Statistical analysis shows uniform byte distribution with no recognisable file system signatures, no journal records, no recoverable directory entries. Brute force against AES-256 is not a budget question; it is computationally infeasible against current & foreseeable hardware. Swapping the desoldered NAND onto a donor PCB of the same model also fails: the donor controller's Hardware Unique Key differs from the patient's, so its Key Encryption Key cannot unwrap the patient MEK stored in the patient's system area. The donor produces its own ciphertext from its own keys; it cannot read the patient's.
For TCG Opal drives, Samsung self-encrypting SATA, & modern NVMe, the only valid path is board-level repair of the original controller. We restore the power rails the controller needs to boot: the PMIC, the buck converters, & the voltage regulators that feed the I/O ring. FLIR thermal cameras localise shorted caps & failed regulators by their thermal signature under bench power. The Hakko FM-2032 handles component-level replacement. Once the rails are clean & the controller boots, the PC-3000 Portable III talks to it over the SATA or NVMe bus, the inline AES engine decrypts the NAND natively, & the data comes off as plaintext. Board repair is SSD data recovery for any drive with a silicon-bound MEK.
Chip-off still has a narrow legitimate window. Older SATA controllers with no hardware AES engine, such as the Phison PS3111-S11 with XOR scrambling only, produce raw scrambled but unencrypted NAND. Monolithic eMMC packages, USB flash drives, & SD/microSD cards generally have no silicon-bound MEK at all, & remain valid chip-off targets when the controller is physically destroyed. Anything newer than that, & the answer is the controller comes back to life or the data does not.
Chip-Off Vs. Controller Repair
Chip-Off vs. Controller Repair: Which Do We Try First?
Controller repair is always attempted first. PC-3000 firmware recovery and board-level microsoldering preserve the original controller and its encryption keys. Chip-off is destructive, requires more labor, and cannot recover data from encrypted drives at all. We escalate to chip-off only after confirming the controller cannot be revived.
The escalation path for every SSD that arrives at our lab follows a strict order. First, we attempt firmware corruption recovery using the PC-3000 to communicate with the controller in technological mode. If the controller responds, we recover data without touching the hardware.
If the controller does not respond, we move to board-level repair: Hakko microsoldering to replace burned voltage regulators, rework cold solder joints on the controller BGA, or replace passive components. The goal is to restore enough controller functionality for PC-3000 access. If the controller silicon itself is cracked or burned through, and the drive does not use hardware encryption, chip-off is the final option.
We will tell you before starting chip-off if the drive uses hardware encryption. If it does, and the controller is beyond repair, we will tell you the data is unrecoverable rather than charge you for work that cannot succeed.
When Is Chip-Off The Only Recovery
When Is Chip-Off the Only Recovery Option?
Chip-off becomes the only recovery option when an unencrypted SSD's controller is physically destroyed beyond any firmware or board-level repair. Four specific failure modes push a case past PC-3000 Technological Mode & Hakko microsoldering into chip-off territory: dead controller silicon, catastrophic PCB fracture, advanced liquid corrosion, & fire damage.
On encrypted drives, none of these scenarios lead to chip-off. If the controller holding the AES-256 key is beyond repair, the data is unrecoverable by any method. Chip-off on an encrypted SSD produces ciphertext with no key to decrypt it.
Dead Controller Silicon (Cracked, Burned, or Electrically Destroyed)
The controller IC is physically destroyed. A cracked BGA die, a burned-through package from voltage surge, or an electrical overstress event that fused internal traces. No loader, no firmware tool, & no Hakko microsoldering fix can communicate with dead silicon. If the drive used an unencrypted controller (Phison PS3111), chip-off extracts raw NAND data directly.
Catastrophic PCB Fracture from Impact
Drop damage, crush force, or vehicular impact that severed copper traces between the controller & NAND across the multi-layer PCB. If the NAND BGA packages aren't physically cracked (NAND silicon is more resilient to blunt impact than the thin FR-4 substrate), they can be desoldered & read. PCB trace repair isn't feasible when fractures span multiple internal copper layers. See our physical damage recovery page for the full triage process.
Advanced Galvanic Corrosion from Liquid Exposure
Prolonged liquid contact (saltwater is the worst case) corrodes BGA solder joints under the controller. Ultrasonic cleaning can restore mild corrosion, but advanced galvanic damage eats through the copper pad stack beneath the controller BGA. When cleaning & board repair fail to restore continuity between the controller & its NAND bus, chip-off extracts the memory packages before corrosion reaches them.
Fire Damage to Controller & Passive Components
Fire destroys the controller IC & passive components (capacitors, resistors, voltage regulators). A charred PCB with intact NAND packages is a candidate for chip-off extraction, provided the drive used an unencrypted controller.
In every scenario above, chip-off is ONLY viable on unencrypted drives. If the destroyed controller held an AES-256 key wrapped by a silicon-unique root key, the data dies with the controller. No lab can change that.
Why DIY Chip-Off Fails
Why Does DIY Chip-Off Fail?
Home chip-off attempts destroy the NAND silicon before any data can be read. The procedure requires a PC-3000 Flash reader, a Zhuo Mao BGA rework station with thermocouple-controlled profiles, BGA stencils matched to the chip's ball pitch, & controller-specific reconstruction software.
A consumer heat gun can't hold the 1.5 to 2.0°C/s ramp rate that SAC305 solder requires. It overshoots the 245°C peak within seconds, cracking the NAND die through thermal shock. One wrong temperature profile, & the only copy of your data is gone permanently.
Even if the chip survives extraction, the raw hex dump isn't readable. The controller's XOR scrambling keys, interleaving pattern, & FTL mapping must be reverse-engineered before a single file appears. PC-3000 Flash includes controller-specific modules for Phison and Silicon Motion reconstruction. Without that software, a raw NAND dump is noise.
Budget NAND Programmers Can't Reconstruct SSD Data
Forum posts recommend budget IC programmers like the XGecu T48 for chip-off attempts. The read step works. The reconstruction step doesn't.
A budget programmer dumps a binary blob with no understanding of the controller's XOR scrambling, interleaving order, or ECC algorithm. PC-3000 Flash includes controller-family-specific reconstruction modules that decode these parameters automatically for supported legacy flash families (older Phison and Silicon Motion controllers). A generic programmer produces a raw hex file that looks like random noise. The read hardware isn't the bottleneck; the reconstruction software is.
How Much Does Chip-Off Recovery Cost
How Much Does Chip-Off Recovery Cost?
Chip-off is the most expensive recovery tier. The range is $1,200–$1,500, depending on the number of NAND chips, the controller's interleaving complexity, and the time required for data reconstruction. 50% deposit required. No data, no charge still applies. You receive a firm quote after a free evaluation.
Chip-off recovery: $1,200–$1,500. 50% deposit required. Free evaluation, firm quote, no data = no charge.
The cost is higher than firmware-level or controller repair recovery because chip-off requires physical desoldering, individual chip reading, interleaving reconstruction, and manual FTL rebuilding. A 4-chip SSD takes less time than a 16-chip enterprise drive with a complex striping pattern.
Chip-Off Pricing in Context
Recovery MethodWhen UsedSATA SSD PriceNVMe Price
Firmware RecoveryController alive but firmware corrupted; PC-3000 Technological Mode$600–$1,200$900–$1,200
Board RepairDead PMIC, shorted capacitor, or failed voltage regulator; Hakko microsoldering$450–$600$900–$1,200
Chip-Off / NAND SwapController destroyed on unencrypted drive; BGA rework & raw NAND reading$1,200–$1,500$1,200–$2,500
A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. +$100 rush fee to move to the front of the queue.
See our full SSD data recovery page for all pricing tiers & process details. Call (512) 212-9111 for a free evaluation.
BGA Thermal Profile For NAND Package
BGA Thermal Profile for NAND Package Extraction
Lead-free BGA NAND packages use SAC305 solder (96.5% tin, 3% silver, 0.5% copper) with a solidus temperature of 217°C and a liquidus of 220°C. Extracting the chip requires a multi-stage thermal profile that raises the PCB temperature gradually to prevent thermal shock, die delamination, and the “popcorn effect” where trapped moisture causes catastrophic package cracking.
Heating a NAND package directly with a hot air gun without preheating the substrate creates a steep thermal gradient between the chip and the surrounding PCB. This differential warps the board, tears solder pads, and can fracture the silicon die internally. The Zhuo Mao BGA rework station used in our lab applies controlled bottom-side IR preheat to the entire PCB while the top-side nozzle targets only the NAND package. The Atten 862 hot air station handles smaller packages and precision touchup work.
Atten 862 for Smaller Packages & Precision Touchup
The Zhuo Mao handles full-size BGA-152 & BGA-132 NAND packages on standard 2.5" SATA SSD boards. Smaller packages need different tooling. TSOP-48 chips on older USB flash drives, single-chip NAND packages on compact M.2 drives, & monolithic devices with exposed test pads all sit close to neighboring components that can't tolerate the Zhuo Mao's broader heat zone.
The Atten 862 hot air station addresses this gap. Its smaller nozzle diameter concentrates airflow on the target package without heating adjacent ICs or capacitors. Adjustable airflow rate (measured in liters per minute) prevents the thin M.2 PCB substrate from flexing during localized heating. After initial extraction on the Zhuo Mao, the Atten 862 handles precision touchup: cleaning residual solder from exposed PCB pads, reflowing stray solder bridges, & prepping the pad field for inspection under the stereomicroscope before the chip moves to the reader.
NAND Chip Reballing After Extraction
Extracted BGA NAND chips can't go straight into a reader socket. The desoldering process leaves irregular solder residue on the chip's ball pads: flattened remnants, bridged contacts, & oxidized surfaces that prevent reliable electrical connection with the PC-3000 Flash reader's ZIF socket pins.
Pad cleaning comes first. A Hakko FM-2032 iron with a fine chisel tip & copper solder wick removes residual solder from each pad. Chemical flux residue is washed off with isopropyl alcohol under the stereomicroscope. Clean, flat copper pads are the starting point for fresh solder ball placement.
Reballing uses a laser-cut stainless steel BGA stencil matched to the chip's ball pitch (typically 1.0mm for BGA-152 and BGA-132 NAND packages). The stencil aligns over the cleaned pads, solder paste is applied through the apertures, & a controlled reflow at 235 to 245°C forms uniform spherical contacts. The result: a chip with consistent solder ball geometry that seats cleanly in the reader's ZIF adapter.
The Multiboard carrier approach skips reballing entirely. Instead of restoring the BGA ball grid, the chip is soldered directly to a disposable carrier board that plugs into the PC-3000 Flash reader. The tradeoff: each carrier is single-use.
Moisture Bake-Out Before Reflow (MSL Precondition)
NAND BGA packages are moisture-sensitive. The destructive event happens during the ramp to peak reflow temperatures of 220 to 260°C, where trapped moisture vapor pressure rises exponentially & exceeds the cohesive strength of the heat-softened epoxy mold compound, delaminating the wire-bonded die stack inside the BGA. A failed drive that sat in a humid environment for weeks before reaching the lab is the worst-case input.
Before any hot-air work, suspect packages go into a dry oven per IPC/JEDEC J-STD-033 to drive trapped moisture out of the epoxy mold compound. Skipping the bake-out on a damp chip can crack the die internally during the 220 to 260°C peak reflow, & the crack is invisible from the outside. The PC-3000 Flash reader will then return garbage from one or more die targets that were intact before the technician touched the chip. The bake-out is unglamorous & adds a day to turnaround, but on recovered-from-water-damage SSDs it is the difference between a clean dump & a destroyed die.
Flux Choice & Hakko Iron Dwell Discipline
Flux selection is not a detail. The Hakko FM-2032 sits on an FM-203 base station with closed-loop tip temperature regulation, but flux chemistry controls how quickly solder wets the pad & how cleanly the chip releases. A Rosin Mildly Activated (RMA) flux with viscosity matched to the BGA standoff height is used to wick under the package & reduce oxide on the solder balls.
Prolonged localized heat from the Hakko tip during pad cleanup drives the substrate laminate past its glass transition temperature, softening the adhesive that binds the ultra-thin copper pad to the package body. Combined with any lateral force from desoldering braid, that softened bond is how pads tear off (pad lifting). A ripped pad on the bottom of the NAND package destroys the electrical interface the ZIF socket needs to read that die target. Lead-free solder wicking is done in short passes with the iron lifted between zones, not in continuous contact.
Vacuum Lift & Controlled Cooling
The Zhuo Mao's vacuum pickup is engaged only after the package has soaked above the SAC305 liquidus long enough for every ball in the array to fully melt. Lifting at the instant the thermocouple grazes 217°C leaves the inner balls (shielded by the die thermal mass) still solid & guarantees pad damage. Once the array is fully molten, the chip is lifted straight up. Any lateral force on a partially molten BGA strips copper pads from the FR-4 substrate & can tear bond wires inside the package itself. Pads ripped from the PCB do not matter on a chip-off (the chip is leaving the board anyway), but a torn internal bond wire kills a die target permanently & cannot be undone.
The board itself is cooled with gentle bottom-fan airflow before any further work, which relieves stress on adjacent BGAs & passive components that have to survive for the controller-repair attempt.
NAND Reader Hardware And Chip Package
NAND Reader Hardware and Chip Package Adapters
After extraction, each NAND chip connects to a PC-3000 Flash reader through package-specific adapters. The chip package determines which adapter is required: TSOP-48 uses a ZIF socket, LGA-52 uses dedicated land grid adapter plates, and BGA-152/132 chips can use either specialized ZIF socket adapters or be soldered to disposable Multiboard carrier modules.
The PC-3000 Flash reader is purpose-built for raw NAND access. Unlike the PC-3000 SSD module (which communicates with controllers via SATA or NVMe protocol), the Flash reader bypasses the controller entirely and communicates directly with the NAND silicon through the chip's native ONFI or Toggle interface.
TSOP-48 (Thin Small Outline Package, 48 pins)
Found in older USB flash drives, SD cards, and lower-capacity SATA SSDs. The rectangular package has pins exposed along two edges. Adapters use a ZIF (Zero Insertion Force) socket: the chip slides in without soldering. This is the simplest package to interface with the reader.
BGA-152 and BGA-132 (Ball Grid Array)
The standard package on modern SATA and NVMe SSDs. Solder balls are arranged in a grid under the chip with no externally accessible pins. The PC-3000 Flash supports these chips via a specialized BGA-152/132 ZIF socket adapter (non-destructive) or via Multiboard Adapter modules where the chip is soldered to a disposable carrier board.
LGA-52 (Land Grid Array, 52 pads)
A flat-pad package found in some compact flash storage devices. Requires a dedicated adapter plate with spring-loaded contact pins that press against the flat copper lands on the chip underside.
ONFI and Toggle DDR Interface Configuration
NAND chips communicate through one of two competing interface protocols, and the PC-3000 Flash reader must be configured for the correct one before reading begins. Wrong protocol selection produces garbage data or no response at all.
ONFI (Open NAND Flash Interface) is used by Micron, Intel, & SK Hynix. It runs in synchronous mode with a free-running clock signal that coordinates data transfers between the reader & the chip. Toggle DDR, developed by Samsung & Kioxia (formerly Toshiba), takes an asynchronous approach: a data strobe signal triggers reads on both rising & falling edges, doubling throughput without a dedicated clock line.
PC-3000 Flash identifies the protocol from the NAND chip's ID bytes during the READ ID command (0x90). The engineer confirms the setting against the chip's part number markings before starting a full dump. On a 16-chip SSD with 512GB of raw capacity, an incorrect protocol setting wastes hours of read time producing unusable output. Getting it right the first time is a basic competency check for any chip-off lab.
Multi-Die NAND Packages: Stacked Dies Inside a Single BGA Chip
A single BGA-152 NAND package can contain 4, 8, or 16 individual silicon dies stacked & wire-bonded inside one physical component. Reading the package as a single entity yields only a fraction of the data. The PC-3000 Flash reader must address each internal die separately through Chip Enable (CE) signal multiplexing.
SSD manufacturers stack dies to increase capacity without enlarging the package footprint. A 1TB SSD with four BGA-152 packages may contain 16 dies total (four per package). From the outside, each package looks identical. The die count is encoded in the chip's ID bytes, which the PC-3000 Flash reads during the initial READ ID command (0x90). The engineer cross-references the part number markings against the manufacturer's datasheet to confirm the target count before starting extraction.
Per the ONFI specification, each die inside a multi-die package is assigned to a Chip Enable (CE_n) signal or a Logical Unit Number (LUN). CE_n signals act as hardware select lines: asserting CE0_n activates the first die, CE1_n the second, & so on. When multiple dies share a single CE line, they're addressed by LUN identifiers through the ONFI command set. The PC-3000 Flash software must be configured with the correct number of CE targets & LUN topology. Misconfiguring this produces a partial dump that covers some dies but misses others entirely.
Multi-die packages also complicate reconstruction. SSD controllers interleave data across dies within the same package (die interleaving) to boost write throughput. The raw dump from each die contains fragments of the same logical file striped across multiple targets. The reconstruction software must de-interleave these fragments in the correct die order to produce a coherent disk image. Getting the die sequence wrong produces a file system where directory structures appear intact but file contents are scrambled.
Raw NAND Data Reconstruction
How Is Raw NAND Data Reconstructed After Chip-Off?
Raw NAND data is not a readable file system. The controller applied error correction codes (ECC), data scrambling via XOR transforms, and proprietary interleaving before writing to the NAND. Chip-off recovery must reverse all three transformations to reconstruct usable data from the raw hex dump.
BCH vs. LDPC Error Correction
NAND flash cells degrade with each program/erase cycle. Electrons leak from floating gates, and read operations disturb adjacent cells. Controllers append ECC data to the spare area (Out-Of-Band region) of every NAND page to detect and correct bit errors before the host sees the data.
BCH (Bose-Chaudhuri-Hocquenghem)
The standard ECC algorithm for SLC and MLC NAND. BCH uses algebraic hard-decision decoding: each cell is read as binary 1 or 0. During chip-off recovery, the BCH polynomial can be detected from the raw dump and applied to correct bit errors. PC-3000 Flash supports automated BCH correction.
LDPC (Low-Density Parity-Check)
Required for TLC and QLC NAND where the raw bit error rate exceeds BCH's correction capacity. LDPC uses soft-decision decoding: instead of reading a simple 1 or 0, the controller takes multiple voltage measurements per cell to estimate the probability of the bit state. Chip-off recovery loses the controller's hardware LDPC engine. Reconstructing LDPC corrections from a raw hard-decision dump is computationally intensive.
Page Scrambling and XOR Key Extraction
Flash controllers scramble all data before writing it to NAND. This is not encryption; it is a data-integrity measure that prevents adjacent cells from holding identical charge states (which accelerates charge leakage). The controller generates a pseudo-random key and XORs it with the user data. Recovery requires XORing the raw dump with the same key to reverse the transformation.
XOR keys can be extracted by finding NAND regions the operating system filled with logical zeros (0x00). Since 0x00 XOR Key = Key, zero-filled regions store the pure scrambling key. NAND reconstruction tools scan physical dumps for repeating vertical bit patterns with distinctive geometric shapes (triangles, diagonals), which indicate an extractable XOR key.
Controller-Specific Scrambling Patterns
Silicon Motion controllers , Phison controllers, and SandForce controllers each scramble differently. XOR scrambling breaks up repetitive bit patterns for NAND reliability. It is not encryption, and it is reversible once the controller's polynomial is known, which is why reconstruction is done per controller family rather than with one generic setting. SandForce parts (SF-2281) also combine real-time DuraWrite data compression with hardware encryption bound to the controller silicon (marketed as AES-256, though Intel discovered a silicon-level bug in 2012 that reduced effective strength to AES-128), which makes chip-off recovery infeasible on those drives when the controller is dead.
3D NAND Extraction: Layer Variation and Vertical Crosstalk
Modern SSDs use 3D NAND that stacks memory cells vertically in 128 to 232+ layers. Chip-off on 3D NAND is harder than on older planar (2D) NAND because error rates aren't uniform across the vertical stack. Different layers can need different read-retry modes.
Planar NAND spreads cells across a flat silicon surface. Every cell sits at the same distance from the substrate, experiences the same manufacturing conditions, & degrades at roughly the same rate. 3D NAND changes that. Cells at the bottom of a 176-layer stack are formed earlier in the deposition process than cells at the top. Process variation between layers creates non-uniform threshold voltage distributions: bottom-layer cells may read cleanly at the default reference voltage while top-layer cells in the same block produce uncorrectable errors.
Vertical crosstalk compounds the problem. Adjacent cells stacked along the Z-axis interfere with each other's stored charge through capacitive coupling. Most 3D NAND architectures use Charge Trap Flash (CTF), which stores electrons in a silicon nitride insulator layer rather than the conductive polysilicon floating gate used in planar NAND. Some manufacturers (Intel, Micron) retained floating gate designs for multiple 3D NAND generations. CTF traps charge locally, which reduces lateral cell-to-cell interference but doesn't eliminate vertical coupling between stacked layers.
During chip-off, this means a single read-retry setting will not clear the whole chip. The engineer works through the read-retry modes per block region, adjusting for layer-dependent variation.
Flash Translation Layer Reconstruction
How Is the Flash Translation Layer Rebuilt from Raw NAND?
After correcting bit errors and reversing scrambling, the raw data is readable but fragmented across thousands of physical blocks in non-sequential order. The Flash Translation Layer (FTL) maps logical addresses to physical NAND locations. When the controller dies, its FTL mapping tables (stored in volatile RAM) are lost. Recovery rebuilds this mapping from metadata embedded in each NAND page's spare area.
NAND flash cannot overwrite data in place. Every update writes to a new empty block and marks the old block obsolete. Over the lifetime of an SSD, a single logical sector may exist in dozens of physical locations. The controller's FTL maintained a real-time index of which physical copy was current. Without the controller, that index is gone.
When the controller is alive but its firmware is corrupted, PC-3000 can reconstruct the FTL through firmware-level recovery without ever desoldering a chip. Chip-off FTL reconstruction is the manual, from-scratch version of the same process. For a full overview of all SSD data recovery methods & pricing tiers, see the flagship service page.
Spare Area (OOB) Metadata and Sequence Numbers
Each NAND page contains a main data area (4KB, 8KB, or 16KB depending on the NAND generation) plus a smaller spare area, also called the Out-Of-Band (OOB) region. Controllers write metadata to this spare area on every page program operation: the Logical Page Number (the host address this physical page represents), block validity flags, and a sequence number that records the write order.
Sequence numbers are the key to reconstruction. When multiple physical pages claim the same logical address, the page with the highest sequence number is the most recent valid copy. Recovery tools parse the entire spare area dataset (which can span tens of gigabytes on large SSDs), extract the sequence numbers, and programmatically build a reverse mapping table that recreates the FTL. This table converts the fragmented physical dump into a linear disk image that a file system parser can mount.
Factory and Runtime Bad Block Handling
NAND flash chips ship from the factory with defective blocks. Per the ONFI specification, factory bad blocks are marked with a non-0xFF byte in the spare area of either the first or the last page of each bad block. The controller skips them during normal operation & maintains a factory defect map in its internal tables. During chip-off, those internal tables are gone.
PC-3000 Flash scans the spare area of every block in the raw dump to rebuild the bad block table from scratch. Factory markers (written by the NAND fabricator) must be distinguished from runtime bad blocks (blocks that failed during the drive's operational life & were remapped by the controller). Including a factory bad block in the reconstructed image corrupts the output. Excluding a runtime-remapped block that still holds valid data loses user files. The engineer cross-references block erase counts & ECC error rates per block to classify each marked block correctly.
Chip-Off Reconstruction Complexity by NAND Type
NAND TypeBits per CellECC RequiredReconstruction Difficulty
SLC1BCH (low redundancy)Low. Reliable page structures, minimal bit errors, straightforward FTL patterns.
MLC2BCH (moderate)Moderate. Shared-page programming and interleaving add complexity. Bit errors common but correctable.
TLC3LDPC (high redundancy)High. Requires LDPC soft-decision data that chip-off cannot capture. Severe read-disturb and complex wear-leveling fragmentation.
QLC4LDPC (maximum)Very high. 16 voltage levels per cell with tight margins. Pseudo-SLC cache areas require separate mapping and logical merging by FTL timestamps.
How Does Controller Architecture Affect Chip-Off
How Does Controller Architecture Affect Chip-Off Reconstruction?
Chip-off reconstruction difficulty varies by controller family because each manufacturer implements FTL structures, XOR scrambling, & page mapping differently. The same physical extraction process yields raw NAND data, but the reconstruction software & parameter sets needed to reassemble that data into a readable file system change depending on who made the controller.
PC-3000 Flash includes controller-specific reconstruction modules. The engineer selects the correct module, loads the chip dump, & configures the block size, page size, XOR key type, & spare area format for that controller family. Getting these parameters wrong produces garbage output even when the raw dump is clean.
Phison (PS3111)
Phison stores FTL journal logs in the NAND service area rather than in dedicated DRAM. If those journal blocks are corrupted or erased, the engineer must scan every die to extract page-level metadata (LBA tags & sequence numbers) from the OOB spare areas & reconstruct the translator from scratch. The PS3111 is DRAM-less.
Silicon Motion (SM2246EN, SM2258)
SMI uses a page mapping mode FTL with a well-defined mapping table stored in designated service blocks. The logical page number translates to a physical page number through a relatively standardized index.
Maxio (SATA Variants)
Recovery from MAS0902A-based drives requires the original controller to be alive; PC-3000 SSD communicates with it over the SATA interface. Modern NVMe variants (MAP1602A) implement hardware AES-256 encryption bound to the controller die, blocking chip-off entirely. If the Maxio controller is dead and board repair cannot revive it, the data is unrecoverable.
Samsung (Proprietary Controllers)
Samsung designs its own controllers with no published FTL documentation. The block management scheme & page mapping structure differ from every other controller family. Chip-off on older unencrypted Samsung SSDs requires reverse-engineering Samsung-specific page markers & spare area formats that aren't shared with any other manufacturer. The Samsung 980 Pro, 990 Pro, and 990 EVO implement always-on AES-256 encryption, blocking chip-off entirely.
Controller FamilyXOR TypeFTL StorageChip-Off Complexity
Phison (PS3111)Dynamic (base + seed)NAND service area (DRAM-less)High. Two-component key extraction required.
Silicon Motion (SM2246EN/SM2258)Static (block-indexed)Dedicated service blocksModerate. Predictable cyclical patterns.
Maxio (SATA variants)Dynamic (page-level)NAND with vendor-specific layoutNot viable. Requires live controller via PC-3000 SSD.
Samsung (proprietary)Proprietary (undocumented)Proprietary block managementVery high. No published documentation. Reverse-engineering required.
Controller identification happens during the initial evaluation. We check the markings on the controller IC, cross-reference the drive model number against our internal database, & confirm the encryption status before quoting a price. This step is free & takes minutes. It determines whether chip-off is even worth attempting on a given drive.
Monolithic Device Recovery
How Are Monolithic Flash Devices Recovered?
Monolithic flash devices fuse the controller, NAND memory, and passive components into a single silicon package encased in epoxy. Standard BGA desoldering is not possible because there are no separate chips to remove. Recovery requires physically exposing internal test pads and discovering the proprietary pinout using a logic analyzer.
MicroSD cards, many modern SD cards, and compact USB flash drives use monolithic construction. The entire device is a single piece of molded plastic with no visible components. Monolithic NAND recovery is the most labor-intensive form of chip-off because every step, from physical access to signal identification, requires manual reverse-engineering specific to that device.
Exposing Internal Test Pads
The outer epoxy layer must be carefully removed to expose microscopic copper test pads on the silicon die surface. Technicians use fine-grit abrasives or fiberglass pens under a stereomicroscope. The goal is to remove enough material to expose the pads without grinding through the copper traces or the silicon itself. Removing too much material destroys the pads permanently. Removing too little leaves an insulating layer that prevents electrical contact.
Pinout Discovery via Logic Analyzer
Manufacturers do not publish pinout documentation for monolithic test pads. The technician discovers which pad corresponds to which NAND signal by probing with a logic analyzer while the device powers on. A standard 8-bit NAND interface requires identifying data lines D0 through D7, Command Latch Enable (CLE), Address Latch Enable (ALE), Write Enable (/WE), Read Enable (/RE), Chip Enable (/CE), and Ready/Busy (R/B).
The identification process captures the device's initialization sequence. When the device powers up, the controller issues a READ ID command (0x90) to the NAND die. The logic analyzer shows CLE going high while /WE pulses and 0x90 appears on the data bus. ALE goes high, address 0x00 is written, and /RE pulses as the chip transmits its manufacturer ID. By matching these signal patterns to physical pads, the technician maps the complete pinout.
PC-3000 Flash Spider Board Connection
After pinout discovery, the monolithic die connects to the PC-3000 Flash reader via the Spider Board adapter. The Spider Board has adjustable microscopic needle probes positioned under a stereomicroscope. Each needle is lowered onto a specific test pad. The Spider Board software assigns NAND signal names (ALE, CLE, D0 through D7) to individual needles, establishing a clean electrical connection without soldering to pads that are fractions of a millimeter wide.
eMMC Extraction from Mobile and IoT Devices
eMMC (embedded MultiMediaCard) chips are NAND flash soldered directly to device mainboards in smartphones, drones, dashcams, & IoT hardware. When the device's application processor is destroyed but the flash chip survives, chip-off extraction recovers the stored data.
The physical extraction process uses the same Zhuo Mao BGA rework station. eMMC communicates through a parallel MMC interface.
Encryption is the barrier here, too. Most modern mobile SoCs (Qualcomm Snapdragon, Apple A-series, Samsung Exynos) encrypt eMMC storage with keys bound to the processor's secure enclave. If the SoC is destroyed, chip-off produces ciphertext. eMMC extraction is viable only on devices without full-disk encryption or where the encryption key can be recovered from a functioning processor. For full SSD data recovery pricing & methods, see the flagship service page.
eMMC chips use two common BGA package standards: BGA-153 (153-ball, defined by JEDEC MO-276) & BGA-169 (169-ball).
Which SSD Controllers Block Chip-Off Recovery
Which SSD Controllers Block Chip-Off Recovery?
Always-on AES-256 encryption in enterprise and high-end consumer SSD controllers has made chip-off useless on those drives; many mainstream DRAM-less models omit hardware AES entirely. The controller generates a Media Encryption Key (MEK) internally, wraps it with a Key Encryption Key tied to silicon-unique hardware fuses or a secure enclave on the controller die, & encrypts every NAND write transparently. Desoldering the NAND yields only ciphertext.
The table below maps specific controller families to their encryption status & chip-off viability. This isn't a marketing classification; it's based on the controller's silicon architecture. A controller either has a hardware AES engine with silicon-bound root key or it doesn't. The full taxonomy of MEK derivation, KEK wrapping, and TCG Opal class behavior is documented on our SSD hardware encryption page.
Encrypted Controllers: Chip-Off Returns Ciphertext
ControllerInterfaceEncryptionMEK LocationChip-Off Viable?
Marvell 88SS1074SATA 6Gb/sAES-256 (always-on)Controller siliconNo
Samsung Elpis / 990 ProPCIe Gen4 x4AES-256 (Class 0)Wrapped by silicon root keyNo
Unencrypted Controllers: Chip-Off Is Viable
ControllerInterfaceEncryptionCommon DrivesChip-Off Viable?
Phison S11 (PS3111)SATA 6Gb/sNoneEarly Kingston A400 (A400 mid-life revisions ship a different controller)Yes (LDPC complexity)
The MEK is generated internally by the controller's hardware RNG and stored in wrapped (encrypted) form, protected by a Key Encryption Key tied to silicon-unique hardware fuses or a secure enclave on the controller die. Even without a user password set, every byte written to NAND passes through the AES engine. Moving NAND chips to a donor controller fails because the donor's silicon root key is different and cannot unwrap the original drive's MEK; the result is encrypted garbage.
Even on unencrypted controllers like the Phison S11, chip-off is a last resort. The S11's LDPC error correction & complex XOR scrambling make reconstruction labor-intensive. PC-3000 Technological Mode (loader injection) is preferred because it keeps the controller's hardware ECC engine in the loop, decoding pages that a raw chip reader can't correct.
Where the Key Actually Lives: TCG Opal, ATA Security & Silicon-Fused Roots
Three standards govern how modern SSDs handle encryption keys, & all three anchor the root of trust to controller silicon that cannot be transplanted. TCG Opal 2.0 is the storage industry specification implemented by most enterprise & prosumer NVMe drives. ATA Security (the older Security Feature Set) covers password-locked SATA drives. Vendor-specific always-on AES sits on top of either, or ships alone on consumer NVMe controllers that never expose the key management interface to the operating system at all.
Under TCG Opal, the Media Encryption Key is generated by an on-die True Random Number Generator at first power-on, then wrapped by a Key Encryption Key derived from an Authentication Credential. When a user sets a password, the credential supplied to the drive is run through a key derivation function to produce the KEK. The proprietary always-on AES layer that controller vendors implement underneath Opal is what anchors the root of trust to a hardware fuse value programmed into the controller silicon. That fuse value never leaves the die & is not readable through JTAG, the standard NVMe admin interface, or any vendor-specific command surface that PC-3000 SSD has access to.
Apple T2 & M-series SoCs implement the same architecture with different vocabulary: the Secure Enclave fuses a Unique ID & a Group ID into the silicon, and those wrap the volatile per-file class keys before they reach the AES engine on the storage path. The raw NAND chips Apple solders to the logic board carry no controller of their own; the SoC is the controller. Chip-off on those NAND packages returns AES-256 ciphertext keyed to the dead UID. Apple Platform Security documents this directly, & the conclusion is the same as for Samsung Elpis: revive the original silicon.
How Does Board-Level Repair Enable Encrypted
How Does Board-Level Repair Enable Encrypted SSD Recovery?
Board-level microsoldering is the prerequisite for recovering data from any encrypted SSD with a dead controller. The original controller must boot because the AES-256 decryption chain depends on a root key bound to its silicon. Replacing the controller destroys access to that key. Repairing the controller preserves it.
Most SSD “deaths” aren't controller failures. They're failures in the power delivery circuit surrounding the controller: a shorted PMIC, a blown capacitor, or a cracked voltage regulator. The controller IC itself is often intact. The diagnostic workflow below identifies the failed component before power is applied, preventing cascading damage to an already fragile board.
Pre-Power Diagnostic & Repair Workflow
  1. FLIR thermal imaging for fault localization. Before applying power, the board is briefly energized through a current-limited bench supply while a FLIR thermal camera identifies hotspots. A shorted PMIC or tantalum capacitor draws excess current & produces a visible thermal signature within seconds. This pinpoints the failed component without risking further damage.
  2. Hakko FM-2032 microsoldering for component replacement. The failed PMIC, capacitor, or voltage regulator is removed & replaced using a Hakko FM-2032 iron on an FM-203 base station. SATA SSD board repair runs $450–$600. NVMe board repair runs $900–$1,200.
  3. Zhuo Mao BGA rework for controller reflow or reball. If the controller IC has cold solder joints (intermittent detection, works after heating), a Zhuo Mao BGA rework station reflows or reballs the controller's BGA connections. This restores electrical contact without disturbing the silicon-bound hardware fuses holding the root key that wraps the MEK. Temperature profiles follow the same SAC305 parameters used for NAND extraction.
  4. PC-3000 SSD imaging through the restored controller. Once the controller boots, PC-3000 SSD connects via SATA or NVMe protocol & images the drive sector-by-sector. The controller's AES engine decrypts data in real-time during the imaging process. No key extraction is needed; the controller handles decryption transparently, the same way it did when the drive was healthy.
This is not chip-off. The controller stays in place. The encryption chain is preserved. The controller's hardware LDPC engine handles soft-decision decoding during imaging, producing clean data that a raw chip reader can't match. Board repair preserves everything chip-off destroys.
SSD data recovery is board repair. The Hakko FM-2032 & Zhuo Mao rework station aren't separate services from data recovery; for encrypted drives, they are the recovery tool. No other path exists when the controller's power circuit fails & the AES key is locked inside the silicon.
PC-3000 Technological Mode: The Alternative to Chip-Off
When an SSD powers on but won't mount (reports 0 bytes, enters BSY state, or identifies as “SATAFIRM S11”), the controller is alive but its firmware is corrupted. PC-3000 SSD bypasses the corrupted firmware by injecting a custom microcode loader into the controller's volatile RAM, giving it just enough logic to read raw NAND without executing the damaged code.
Technological Mode is the reason professional labs rarely need chip-off on modern SSDs. The controller is alive; its firmware isn't. Injecting a temporary loader into RAM sidesteps the corruption without touching the NAND physically. Firmware-level recovery using PC-3000 runs $600–$1,200 for SATA SSDs & $900–$1,200 for NVMe; chip-off costs $1,200–$1,500. The price difference reflects the labor difference.
Loader Injection Workflow
  1. Halt the boot sequence. PC-3000 issues vendor-specific ATA or NVMe commands to stop the controller from loading its corrupted firmware modules. This prevents the controller from executing destructive operations like TRIM, garbage collection, or a factory reset that some controllers trigger on boot failure.
  2. Inject the loader. A proprietary microcode payload is written into the controller's volatile RAM. This loader gives the controller minimal read logic: enough to address NAND pages & return raw data through the SATA or NVMe interface. The loader doesn't touch the corrupted firmware stored in NAND; it runs entirely from volatile memory & disappears on power cycle.
  3. Scan NAND for surviving metadata. PC-3000 reads raw NAND pages through the loader, scanning for page headers, spare area metadata, wear-level counters, & sequence numbers. It builds a virtual LBA-to-PBA mapping, reconstructing the Flash Translation Layer without relying on the drive's corrupted FTL tables.
  4. Image with real-time AES decryption. Because the original controller handles every read operation, data passes through the controller's hardware AES engine & is decrypted in real-time during imaging. The host receives plaintext data directly.
Professional labs prefer Technological Mode over chip-off even on unencrypted drives. The controller's hardware LDPC engine stays in the loop, performing soft-decision decoding that chip-off can't replicate. A raw chip reader does hard-decision reads (binary 1 or 0); the controller does multi-pass voltage sweeps across TLC & QLC cells to calculate bit probabilities. On a worn drive with high bit error rates, that difference determines whether pages decode cleanly or return corrupted data.
SATAFIRM S11 Firmware Corruption on Phison PS3111
The Phison PS3111-S11 controller powers a large share of budget SATA SSDs: Kingston A400, Patriot Burst, & dozens of OEM variants. When the S11's FTL corrupts from sudden power loss, the controller enters ROM mode & reports its identity as “SATAFIRM S11” with 0-byte capacity. The drive appears in BIOS but is inaccessible.
DIY forums recommend flashing the controller with Phison's MPTool utility. Don't. MPTool reinitializes the controller's firmware from scratch, which overwrites the FTL mapping tables. Once the FTL is gone, the link between logical addresses & physical NAND locations is destroyed. The data is still on the NAND cells, but no tool can reassemble it without the mapping.
PC-3000's Phison utility injects a loader that reads the S11's NAND without touching the corrupted FTL. The loader accesses raw pages, extracts surviving metadata from spare areas, & rebuilds the address mapping into RAM on the drive itself. Because the S11 doesn't implement hardware encryption, the data on the NAND is plaintext. Recovery runs $600–$1,200; chip-off on the same drive costs $1,200–$1,500 & takes 2 to 4 weeks longer.
SSD Recovery Calculator
Estimate Your Chip-Off Recovery Cost
What type of SSD do you have?
What is chip-off NAND data recovery?
Chip-off recovery physically removes the NAND flash memory chips from an SSD's circuit board using BGA rework equipment, then reads the raw data directly from each chip. It is the last-resort method used when the controller is destroyed beyond repair and firmware tools like the PC-3000 cannot establish communication.
Does chip-off work on encrypted SSDs?
No. For Apple T2/M-Series, the encryption hierarchy is anchored to a Unique ID fused into the Secure Enclave; that UID is the root of trust used to wrap the volatile class keys, so a dead silicon die means a dead key chain. For Samsung 980/990 Pro and other NVMe drives with always-on AES-256 hardware encryption, the Media Encryption Key is wrapped by a Key Encryption Key tied to the original controller's silicon-unique fuses or secure enclave. Transplanting NAND to a different controller yields only ciphertext because the donor controller has a different silicon root key and cannot unwrap the original MEK. The only viable path is restoring the original controller through board-level repair or firmware intervention. If the controller silicon is dead, the keys are unrecoverable and the data is unrecoverable. Any lab claiming they can read encrypted NAND on a donor controller is misrepresenting the technology.
How much does chip-off recovery cost?
Chip-off NAND recovery runs $1,200–$1,500 depending on the number of NAND chips, the controller's interleaving complexity, and reconstruction time. 50% deposit required. No data, no charge still applies. You receive a firm quote after a free evaluation.
When should I choose chip-off vs controller repair?
You do not choose. We always attempt PC-3000 firmware recovery and board-level controller repair first because these methods preserve the controller and its encryption keys. Chip-off is only used when the controller is completely unrecoverable and the drive does not use hardware encryption. It is destructive; the drive cannot be reassembled afterward.
Can data be recovered from a physically broken USB flash drive?
Yes, provided the NAND memory chip inside the drive is intact. The data lives on the NAND silicon, not the USB connector or PCB traces. If the connector is snapped or the board is cracked but the NAND chip is undamaged, chip-off extraction removes the memory chip and reads it on a PC-3000 Flash reader. Monolithic USB drives (where controller and NAND are fused into one package) require a more complex extraction using exposed test pads and a Spider Board adapter. USB flash drive chip-off costs $1,200–$1,500.
What is monolithic NAND recovery?
Monolithic recovery extracts data from flash devices where the controller and NAND memory are fused into a single silicon package. MicroSD cards, SD cards, and compact USB drives commonly use this construction. There are no separate chips to desolder. The outer epoxy is mechanically removed to expose internal test pads, a logic analyzer identifies the proprietary pinout by capturing initialization signals, and the PC-3000 Flash Spider Board adapter connects to the NAND die via adjustable needle probes.
What makes chip-off reconstruction harder on TLC and QLC NAND?
TLC stores 3 bits per cell across 8 voltage levels and QLC stores 4 bits per cell across 16 voltage levels. Both require LDPC error correction, which uses soft-decision decoding: the controller reads the probability of each bit state via multiple voltage measurements. Chip-off recovery bypasses the controller and can only perform hard-decision reads (binary 1 or 0), losing the probability data LDPC needs. This makes TLC and QLC reconstruction computationally harder than SLC or MLC, where simpler BCH codes correct errors from a hard-decision raw dump.
How long does chip-off NAND recovery take?
Chip-off recovery takes 4 to 8 weeks depending on NAND complexity. A 4-chip SATA SSD with BCH error correction and a known interleaving pattern reconstructs faster than a 16-chip enterprise drive with LDPC and dynamic XOR scrambling. Monolithic devices add time for epoxy removal and pinout discovery. Rush service is available: +$100 rush fee to move to the front of the queue.
Which SSD controllers allow chip-off recovery?
Only controllers that lack hardware encryption. The Phison PS3111-S11 (early Kingston A400 revisions) has no hardware AES; it uses non-cryptographic XOR data scrambling. Note that Kingston has shipped mid-life A400 revisions with a different controller; controller identification at evaluation is mandatory. Chip-off on encrypted drives yields only ciphertext. Encryption status must be confirmed per-drive during evaluation.
Can data be recovered from a dead SSD controller?
On drives where hardware encryption is absent (older SATA SSDs with the Phison PS3111-S11), yes. Chip-off extracts raw NAND data from the memory chips, bypassing the dead controller entirely. On encrypted drives (Samsung 980/990 Pro, Apple T2/M-series, Maxio MAP1602A), no. The AES-256 Media Encryption Key is wrapped by a root key bound to the controller silicon. A dead controller means a dead key chain. The only recovery path for encrypted drives is board-level microsoldering to revive the original controller's power circuit. Board repair runs $450–$600 for SATA SSDs and $900–$1,200 for NVMe.
What happens to my SSD after chip-off recovery?
Chip-off is destructive. The NAND chips are permanently desoldered from the circuit board. The drive cannot be reassembled or returned to service afterward. We return the extracted NAND chips and the original PCB to you along with the recovered data on your choice of media. The SSD itself is non-functional after chip-off and cannot be used again.
What is SATAFIRM S11 and can chip-off fix it?
SATAFIRM S11 is the factory fallback identifier for SSDs using the Phison PS3111-S11 controller (early Kingston A400, Patriot Burst; Kingston has shipped mid-life A400 revisions with a different controller). It appears when the Flash Translation Layer corrupts, usually from sudden power loss. The drive reports 0-byte capacity. Chip-off is technically possible because the S11 lacks hardware encryption, but PC-3000 Technological Mode recovery via loader injection is faster, cheaper ($600–$1,200 vs. $1,200–$1,500), and non-destructive. Chip-off is only used if the S11 controller silicon is physically destroyed.
Why can't I move NAND chips to a donor SSD controller?
Two reasons. First, modern controllers encrypt all NAND writes with an AES-256 Media Encryption Key wrapped by a silicon-unique root key on the original controller. A donor controller has a different root key and cannot unwrap the original MEK, so it cannot decrypt the NAND contents. Second, even on unencrypted drives, the donor controller lacks the original drive's firmware adaptives: the specific wear-leveling maps, defect lists, and FTL configuration tailored to that NAND's physical degradation pattern. A transplanted NAND paired with foreign firmware produces corrupted or incomplete data.
Does chip-off work differently on 3D NAND versus older planar NAND?
Yes. 3D NAND stacks memory cells vertically in 128 to 232+ layers, creating non-uniform error rates across the vertical stack. Different layers can need different read-retry modes during raw NAND reading because manufacturing process variation causes bottom-layer cells to behave differently from top-layer cells. Planar NAND has uniform error characteristics across the die. Most 3D NAND architectures use Charge Trap Flash (silicon nitride insulator), though some manufacturers (Intel, Micron) used floating gate designs for multiple 3D NAND generations. Both architectures exhibit retention and read disturb behaviors distinct from planar memory. Reading degraded pages means working through the NAND's predefined read-retry modes across different block regions, adding time to the reconstruction process.
Can data be recovered from eMMC chips in phones and IoT devices?
Yes, if the flash chip is physically intact and the data isn't encrypted by the device's processor. eMMC chips are embedded flash memory soldered to device mainboards in smartphones, drones, dashcams, and IoT devices. If the application processor is destroyed but the flash chip survives, it can be desoldered using BGA rework and read on a PC-3000 Flash reader. The same encryption limitation applies: if the device's SoC encrypted the storage with a key bound to its secure enclave (Qualcomm, Apple, Samsung processors all do this), chip-off returns ciphertext with no key to decrypt it. eMMC extraction where viable falls under the chip-off tier at $1,200–$1,500.
Can I do chip-off data recovery at home?
No. Chip-off requires a PC-3000 Flash reader (thousands of dollars), a BGA rework station with controlled thermal profiles, BGA stencils matched to the chip's ball pitch, and controller-specific NAND reconstruction software. A standard heat gun overheats the silicon die within seconds, cracking the NAND and destroying data permanently. Even with the correct equipment, the raw hex dump requires reverse-engineering the controller's XOR scrambling keys and FTL mapping to produce a readable file system. This is not a DIY procedure.
What is the difference between chip-off data recovery and chip-off forensics?
Both use the same physical extraction process: BGA desoldering, NAND reading on a PC-3000 Flash reader, and raw dump reconstruction. The difference is what happens after the raw dump. Data recovery reconstructs a usable file system and delivers working files (photos, documents, databases). Chip-off forensics, used by law enforcement and legal proceedings, preserves the entire raw binary image including deleted fragments, obsolete NAND blocks, and metadata timestamps for chain-of-custody evidence. We perform data recovery. For forensic extraction with court-admissible chain-of-custody documentation, contact a digital forensics laboratory.
Can chip-off recover deleted files from an SSD?
On unencrypted drives where TRIM has not executed, some deleted files may survive in obsolete NAND blocks. Flash memory uses wear-leveling, so a deleted file's physical NAND blocks aren't immediately erased; they're marked obsolete and wait for garbage collection. A raw chip-off dump reads all physical blocks including obsolete ones, sometimes recovering file fragments that software tools can't see because the FTL no longer maps to those blocks. On encrypted drives, deleted or not, chip-off returns only ciphertext.
What is the difference between chip-off and JTAG extraction?
JTAG (Joint Test Action Group) probes designated test access ports on the PCB to read memory non-invasively through the device's debug interface. The chip stays soldered to the board. Chip-off physically desolders the NAND chip from the PCB and reads it on a separate chip reader. JTAG is less risky because the board isn't altered, but it only works when the debug interface is accessible and the processor can still execute commands. Chip-off works when the controller or processor is destroyed, but it is destructive and the drive can't be reassembled. For SSDs, we attempt non-destructive diagnostic access through PC-3000 Technological Mode (which injects a loader via vendor-specific commands, not JTAG) before escalating to chip-off.
How do stacked-die NAND packages affect chip-off recovery?
Modern BGA-152 NAND packages can contain 4, 8, or 16 individual silicon dies stacked and wire-bonded inside a single physical package. A chip that looks like one component may hold 16 separate memory targets. The PC-3000 Flash reader addresses each die through Chip Enable (CE) signals per the ONFI specification. Failing to configure the correct number of CE targets during the read produces only a fraction of the drive's data. The engineer identifies the die count from the chip's ID bytes and part number markings before starting the dump.
Why is preserving the original controller PCB the only recovery path on encrypted SSDs?
On any SSD with always-on AES-256 hardware encryption (Samsung 980 Pro and 990 Pro, Apple T2/M-series), the Media Encryption Key is generated internally by the controller's hardware RNG and stored in wrapped form, protected by a Key Encryption Key derived from silicon-unique hardware fuses or a secure enclave on the controller die. The unwrapped MEK never exists outside that controller's silicon at rest. Removing the NAND from the original PCB and reading it on a chip reader returns AES-256 ciphertext with no path to plaintext. Soldering the NAND onto a donor controller of the same model also fails because the donor's silicon root key is different and cannot unwrap the original drive's MEK. The only viable recovery is repairing the original PCB so the original controller boots and decrypts the NAND through its own AES engine. This is why SSD data recovery on modern drives is fundamentally a board-repair discipline: Hakko FM-2032 microsoldering to replace failed PMICs, voltage regulators, and capacitors, and Zhuo Mao BGA rework for cold-joint controller reflow, all aimed at restoring the controller's power circuit without disturbing the silicon-bound root key that wraps the MEK.
Does a water-damaged SSD need to be dried before chip-off?
Yes, & not just the surface. NAND BGA packages are moisture-sensitive. A package that absorbed humidity over days or weeks can popcorn at peak reflow temperatures of 220 to 260°C: trapped moisture vapor pressure rises exponentially, delaminating the wire-bonded die stack inside the chip & killing one or more internal die targets. Per IPC/JEDEC J-STD-033, suspect packages are baked in a dry oven before any hot-air work. Skipping the bake-out on a damp chip can convert a recoverable drive into an unrecoverable one during the desolder itself.
What is TCG Opal 2.0 and how does it affect chip-off recovery?
TCG Opal 2.0 is the Trusted Computing Group storage specification implemented by most modern NVMe & enterprise SATA SSDs. Under Opal, the Media Encryption Key is generated on-die by the controller's hardware random number generator at first power-on, then wrapped by a Key Encryption Key derived from an Authentication Credential supplied by the host. Independent of the Opal management layer, some controllers also implement proprietary always-on AES that anchors the root of trust to a unique hardware fuse value in the controller silicon. That silicon-fused value never leaves the die & is not readable through JTAG, NVMe admin commands, or any vendor-specific interface available to PC-3000 SSD. Chip-off on a drive with either Opal or proprietary always-on AES (Samsung Elpis) returns AES-256 ciphertext, & users often don't know their drive is encrypted at all.
Data Security
Data Handling During Chip-Off Recovery
Chip-off recovery involves direct contact with raw NAND storage. Your SSD stays in our Austin lab throughout the process. All NAND reads and reassembly happen on air-gapped workstations with no network access. Recovered data is delivered on encrypted external media, and working copies are purged after you confirm receipt.
NDAs are available on request. Full data security details cover our chain-of-custody, encryption, and erasure protocols.
SSD controller destroyed?
Free evaluation. We will tell you honestly whether chip-off can recover your data. No data, no fee.
