What Is SSD Firmware and Why Does It Fail?
The Flash Translation Layer (FTL) is the firmware component that maps logical block addresses to physical NAND pages. Firmware can get corrupted when the power cuts out in the middle of a write.
The FTL maintains a real-time map between the logical block addresses (LBAs) your operating system reads and writes, and the physical pages on the NAND flash where that data actually sits. This mapping is not static. Every write operation can change it because the controller must distribute writes across all NAND cells evenly (wear leveling) and reclaim pages that the OS has marked as deleted (garbage collection via TRIM).
The FTL, bad block tables, and wear-leveling metadata are stored in a reserved section of the same NAND flash that holds your data. This reserved section is called the service area. If the service area is corrupted or unreadable, the controller cannot boot its firmware. It falls back to a hardcoded safe mode identity or stops responding to the host entirely. Your data remains on the NAND flash cells; the controller has lost the map it needs to find it.
A power cut in the middle of a write to the service area can corrupt it. The controller was updating the FTL or garbage collection metadata when power dropped. The partially written update leaves the service area in an inconsistent state.
Firmware corruption is one of several SSD failure categories we recover at our Austin lab. The recovery path depends on which controller family is inside the drive and whether the service area NAND pages are still readable.
What Are the Symptoms of SSD Firmware Corruption?
Firmware corruption causes the controller to abandon normal operation. The drive stops presenting valid capacity and identification to the host system. Symptoms range from reporting a wrong model name or 0 bytes capacity to complete absence from BIOS, read-only lockouts, and boot failures on previously functional drives.
- Drive reports as "SATAFIRM S11" in BIOS, Disk Management, or System Information
- Drive shows 0 bytes total capacity
- Drive not detected in BIOS/UEFI at all
- Drive detected but hangs or times out when accessed
- Capacity misreported
- "No bootable device found" on a previously working boot drive
- Drive enters read-only mode unexpectedly
Why Can't Software Tools Fix Firmware Corruption?
Data recovery software operates through the OS storage stack, above the controller. It sends read commands that the controller translates to physical NAND addresses. When firmware is corrupted, the controller cannot perform translation. The drive reports 0 bytes or fails to enumerate. Software has no path to the data.
Consumer tools like Disk Drill, EaseUS, R-Studio, and Recuva require the operating system to present the drive as a block device with a valid capacity before they can scan a single sector. A drive in firmware safe mode reports 0 bytes. There is no volume for the software to scan. The software is not broken; it is being asked to read a device that does not exist from the OS perspective.
Running software on a firmware-failed drive that keeps dropping in and out is risky. The only safe approach is talking to the controller chip directly, with lab hardware that doesn't go through the OS storage stack.
For a detailed technical breakdown of the SATAFIRM S11 error and what causes it, see our SATAFIRM S11 Phison firmware guide.
How Do We Recover Data from Firmware-Corrupted SSDs?
Recovery uses the PC-3000 Portable III to bypass the corrupted firmware and communicate directly with the controller chip using vendor-specific commands. We enter technological mode, reconstruct the Flash Translation Layer from surviving NAND metadata, and image the data before the drive is powered down.
- 01
Controller Identification
First we identify the controller maker (Phison, Silicon Motion, Marvell) and the firmware revision. That tells us which PC-3000 loader module to use and which FTL structure to expect.
- 02
Technological Mode Access
The PC-3000 lets us put the controller into a diagnostic Safe Mode, where it doesn't boot from NAND. Then we load a working firmware loader into the drive's RAM.
- 03
Translation Layer Reconstruction
The FTL maps logical block addresses to physical NAND pages. When it is corrupt, PC-3000 reconstructs it from surviving metadata. This rebuild restores the logical-to-physical mapping without writing to the user data area.
- 04
Board Repair (If Needed)
If the controller is electrically damaged, we repair the board at component level with Hakko microsoldering and replace or rework the voltage regulators or passive components. Once the controller is functional, PC-3000 access is re-attempted. If the controller is beyond repair on an unencrypted drive, the case escalates to chip-off NAND recovery. That doesn't apply to Apple T2/M-series hardware. There the keys are bound to the Secure Enclave, so board repair is the only viable path.
- 05
Data Extraction and Verification
With the translator rebuilt, the drive presents its real capacity and file system. We image the entire drive sector-by-sector to a known-good destination before touching the file system. Files are verified against the original directory structure and transferred to your return media.
How Much Does SSD Firmware Recovery Cost?
SATA SSD firmware recovery costs $600–$1,200. NVMe SSD firmware recovery costs $900–$1,200. The price depends on how many bad areas the NAND has. Every case starts with a free evaluation and a firm quote before any paid work begins.
Firmware recovery: $600–$1,200 (SATA) to $900–$1,200 (NVMe). Free evaluation, firm quote, no data = no charge.
We publish pricing because you should know what you are paying before you ship anything.
See our full SSD data recovery page for all pricing tiers. Call (512) 212-9111 for a free evaluation.
Which SSD Controllers Have Known Firmware Failure Modes?
The Phison PS3111-S11 controller produces the SATAFIRM S11 error. Silicon Motion SM2258 and SM2259 controllers also have documented failure modes.
- Phison PS3111-S11
- SATAFIRM S11 means the PS3111-S11 has dropped into ROM mode, and the drive reports 0 bytes. ACE Lab lists the PS3111 as supported by PC-3000 SSD.
- Silicon Motion SM2258 / SM2259
- Drives enter a BSY state or report a wrong ID from NAND degradation or firmware error. PC-3000 SSD supports both the SM2258 and the SM2259. We short pins to put the controller in Safe Mode, then inject a loader.
- Samsung Elpis and the 990 Pro controller
- Samsung 980 Pro uses the Elpis controller and the 990 Pro uses another in-house Samsung part. Neither one is on ACELab's list, so we can't get firmware-level access or rebuild the FTL on them.
How Does Recovery Differ by SSD Controller Family?
Each controller family uses a different firmware architecture, diagnostic mode entry method, and FTL structure.
Recovery uses the PC-3000 Portable III as the primary firmware-level access tool. Vendor-specific command sets for each controller family allow direct communication with the controller at the diagnostic level, bypassing normal host interfaces.
- Phison Controllers (PS3111-S11, PS5012-E12, PS5013-E13T)
When the firmware service area gets corrupted, a Phison controller drops into ROM MODE. In ROM MODE, the controller responds to a minimal command set that allows a firmware loader to be injected into RAM. The PC-3000 Phison module sends the appropriate loader for the specific controller revision, which boots the controller enough to access the NAND and read the service area. FTL reconstruction rebuilds the translation tables from surviving page metadata. See our Phison controller recovery page for the full PS3111-S11, PS5012-E12, and PS5016-E16 workflow.
Common error states: SATAFIRM S11 model string, 0GB capacity, ROM MODE (drive detected but non-functional).
- Silicon Motion Controllers (SM2258, SM2259)
Silicon Motion SATA controllers enter BSY mode (busy state) when firmware corruption prevents normal boot. The controller hangs on a specific initialization step and does not complete enumeration.
Common error states: BSY mode (drive detected but hangs), ROM mode, 0GB capacity.
- Samsung NVMe Controllers
Samsung NVMe controllers implement hardware AES-256 encryption; the media encryption key is bound to the controller. Recovery requires the original controller to be functional enough to serve the decryption chain.
- Marvell Controllers (88SS1074)
Marvell 88SS1074 controllers use vendor-specific commands accessed through the PC-3000 Marvell utility for diagnostic mode entry. ACE Lab points out that some manufacturers run the same Marvell controller with rewritten firmware. That means we have to confirm compatibility for each OEM firmware build.
- Maxio MAP1602A (Budget NVMe)
The Maxio MAP1602 / MAP1602A NVMe controller is not on ACELab's PC-3000 SSD supported-controller list. Chip-off on these drives yields only ciphertext. The recovery path is board-level microsoldering to keep the original controller alive, not a PC-3000 active utility FTL rebuild. The original controller must remain functional for decryption.
PC-3000 SSD Firmware Recovery Workflows
Each controller family requires a different PC-3000 SSD utility module, a different diagnostic mode entry sequence, & a different FTL reconstruction algorithm.
Phison SATAFIRM S11 Firmware Panic Recovery
The PS3111-S11 controller enters ROM MODE when the service area stored in NAND becomes unreadable. ROM MODE is a minimal bootstrap state where the controller accepts a volatile microcode loader into RAM but can't access user data. Recovery requires the PC-3000 SSD Phison utility to inject the correct loader & reconstruct the FTL before extraction.
ROM MODE triggers when the controller's boot sequence fails to read valid firmware modules from the NAND service area. The drive responds to vendor-specific ATA commands but reports itself as "SATAFIRM S11" with 0 bytes capacity. PC-3000's Phison utility detects the ROM MODE state & sends the matching microcode loader for the specific PS3111-S11 revision. This loader executes from the controller's RAM without writing to NAND.
Once the loader boots, the utility rebuilds the FTL mapping table from whatever page metadata survived.
- SATAFIRM S11
- SATAFIRM S11 is a firmware panic: the controller can't read its own service area & falls back to ROM MODE, and the ROM-mode identity string is what the host then sees.
For a full technical breakdown of the SATAFIRM S11 error, see our dedicated Phison firmware panic recovery guide.
Silicon Motion SM2258/SM2259XT BSY State Recovery
SM2258 & SM2259XT controllers enter a BSY (busy) state when the FTL becomes inconsistent. The controller stalls mid-boot & never completes host enumeration. We use the PC-3000 SSD Silicon Motion utility here. We short the controller into Safe Mode, put a loader into the drive's RAM, and rebuild the translator from the service area.
The interface matters. BSY behavior changes depending on how the drive connects to the host. A native SATA port correctly reports the BSY signal to PC-3000, allowing the utility to detect the stalled controller state. USB-SATA bridge adapters often mask the BSY signal entirely; the drive appears absent rather than busy. PC-3000 SSD requires a direct SATA connection to the controller for reliable BSY detection & vendor command access.
What a BSY stall looks like from the host
The BSY (Busy) bit on the ATA status register stays high, which means the controller will not accept or process any standard ATA commands.
ROM Pin Shorting for Safe Mode Entry
On SM2258/SM2258XT drives, the main way we get around corrupted firmware is to force the controller into Safe Mode (also called ROM Mode). The PCB of drives using SM2258 controllers has designated diagnostic test points (vias). By physically shorting specific ROM pins with precision tweezers during the drive's power-on sequence, the engineer interrupts the boot before the controller loads its firmware from NAND. Because the controller cannot access the corrupted NAND, it falls back to a minimal diagnostic state running entirely from its internal ROM.
Vendor-Specific ATA Commands for SM2258 Access
Once the drive is held in Safe Mode, standard SATA commands (READ DMA, IDENTIFY DEVICE) cannot access the firmware internals. The ATA specification reserves a set of vendor-specific command codes for manufacturer implementations. These proprietary commands allow the PC-3000 to write an external microcode loader directly into the controller's volatile RAM.
This is why USB-SATA bridge adapters cannot substitute for a PC-3000 connection. USB bridges apply their own command translation layer between the host and the SATA controller. VSCs are stripped or garbled by the bridge firmware. A drive that appears "not detected" through a USB adapter may still respond to VSCs through a direct SATA connection to PC-3000.
Samsung NVMe controller-bound encryption
Samsung NVMe controllers hold the media encryption key on the controller itself. Recovery therefore depends on the original silicon staying alive, not on reading the NAND.
The encryption constraint is the defining factor in Samsung recovery. Samsung NVMe controllers implement always-on AES-256 encryption; the media encryption key is bound to the controller. If the controller is dead, chip-off yields only ciphertext. The original controller must be functional enough to serve the decryption chain during data extraction.
If the controller is electrically dead, the path is board-level repair: FLIR thermal imaging for fault localization & Hakko FM-2032 microsoldering for PMIC replacement. Reviving the original controller preserves the encryption keys.
Samsung 980 Pro Elpis Controller
There is no vendor-tool path into the Elpis controller; on drives where the controller still responds, the move is a complete read-only image of everything still accessible, immediately. If the controller entered a full panic state, board-level diagnosis with FLIR thermal imaging checks for PMIC damage.
QLC NAND Firmware Recovery Challenges
QLC NAND stores 4 bits per cell using 16 discrete voltage states, compared to TLC's 8 states. The margin between adjacent voltage levels is narrower, which accelerates bit error rates as cells age.
Oxide layer degradation from Program/Erase cycles causes charge leakage that narrows these gaps further. When the bit error rate (BER) exceeds the controller's LDPC error correction capacity, the controller can't read its own service area. It panics into ROM mode or locks the drive to read-only.
Some DRAM-less NVMe controllers use a Host Memory Buffer (HMB). HMB caches the active FTL map in host system RAM over the PCIe bus rather than in dedicated on-board DRAM. If the system loses power before the drive saves those HMB contents back to NAND, the FTL ends up corrupted.
Phison NVMe Controller Recovery (PS5012-E12 / PS5016-E16)
Recovery uses the PC-3000 Portable III with the Phison Utility to bypass the panicked firmware & reconstruct the translation layer.
Volatile Microcode Loader Injection into Controller RAM
When an SSD controller's native firmware is corrupted, the NAND flash chips still retain their electrical charge and the user's data. The data is stranded because the translation map is broken. Recovery requires injecting an alternative firmware loader into the controller's volatile RAM to re-establish communication with the NAND array without touching the corrupted service area.
A "loader" in the PC-3000 SSD framework is a specialized, modified version of the SSD's internal firmware developed by ACE Lab engineers. It is injected exclusively into the controller's Random-Access Memory (RAM). Because RAM is volatile, powering down the SSD erases the injected loader completely. No data is written to the NAND flash at any point during loader injection. This makes the process non-destructive and repeatable.
Once the loader executes from RAM, the controller operates under the ACE Lab microcode. The loader performs three operations that the corrupted native firmware cannot:
- Suspends all autonomous controller functions. TRIM execution, wear-leveling, and garbage collection all halt. The loader prevents any write or erase operations from reaching the NAND.
- Unlocks Physical Block Address (PBA) access. The loader bypasses the collapsed FTL entirely. Instead of requesting data through Logical Block Addresses (which the broken FTL cannot translate), the PC-3000 reads raw physical blocks directly from each NAND chip.
- Gets around RZAT masking. On a drive that advertises Deterministic Read Zero After TRIM (RZAT), the controller hands back zeros for TRIMmed blocks, even though the charge is still sitting in the NAND cells. With background activity switched off, we can rebuild the translator from older copies & read the data before garbage collection erases the blocks.
Loader Matching Requirements
Loaders are not universally interchangeable. A loader compiled for one controller and NAND combination will fail on a different combination, even if the controller model appears identical. The PC-3000 loader must match three parameters of the target SSD:
- Main Controller Unit (MCU): The specific controller variant.
- NAND memory chip manufacturer and type: The exact flash architecture. The NAND chip ID tells us which loader variant we need.
- Internal SSD firmware version: ACE Lab's support goes by the combination of firmware and controller. Some manufacturers run the same controller with different firmware & different technological commands.
FTL Reconstruction from NAND Page Spare Area Metadata
After the correct loader is injected and stable physical access to the NAND is established, raw NAND data is still unusable by an operating system. SSDs use wear-leveling and out-of-place writes, so a single file may be scattered across hundreds of physical pages on multiple NAND dies. The PC-3000 reconstructs the corrupted Flash Translation Layer by parsing metadata from the spare area of each physical NAND page.
NAND Page Anatomy: Data Area and Spare Area
A NAND page is not just the user data. Alongside the user-data region sits an Out-of-Band (OOB) region, called the spare area. The controller uses the spare area to store proprietary metadata required to manage the flash. This metadata is invisible to the operating system and to consumer recovery software, but it contains the information needed to rebuild the FTL.
- LBA Tag
- A marker indicating which logical sector (from the operating system's perspective) the data in this physical page corresponds to. This is the key field for FTL reconstruction.
- Wear-Leveling Counters
- Metrics tracking the number of Program/Erase (P/E) cycles the block has endured. The controller uses these to distribute wear evenly across the NAND. During recovery, high P/E counts indicate blocks with degraded retention, which may require adjusted read voltage thresholds.
- ECC Parity Data
- LDPC (Low-Density Parity-Check) checksums used to detect and correct bit-flips caused by electron leakage or read disturb in TLC/QLC NAND cells.
XOR Data Descrambling
Silicon Motion controllers apply XOR data scrambling to all data written to NAND. This is not encryption and not for security. The controller XORs incoming data with a pseudo-random bit sequence generated by a controller-specific polynomial before writing to NAND. Before the PC-3000 can parse the spare area metadata or the user data, it must apply the inverse XOR pattern using the correct polynomial for that controller revision.
NAND Interleave Reversal
SSD controllers split sequential host writes across multiple NAND dies & planes simultaneously to maximize throughput.
During FTL reconstruction, the PC-3000 must reverse this interleaving to reassemble contiguous logical data sequences from physically scattered NAND pages.
Virtual Translator Reassembly Process
The FTL reconstruction is a computational process executed entirely within RAM on the drive itself. No data is written to the SSD during this process.
- Raw physical imaging with ECC scanning. The PC-3000 commands the controller (via the injected loader) to read every physical page across all NAND chips. ECC algorithms specific to the controller correct bit errors during the read.
- XOR descrambling. The raw dump is descrambled using the controller-specific XOR polynomial. This converts scrambled binary into readable plaintext for both user data and spare area metadata.
- Virtual translator activation. The reconstructed LBA-to-physical map is loaded into RAM on the drive itself as a virtual translator. The PC-3000 presents the drive's real capacity, partition tables, and file system for standard sector-by-sector imaging to a target drive.
Partial Spare Area Corruption and Recovery Quality
When some of the OOB spare-area metadata can't be read, the recovery comes out worse. Missing LBA tags for some pages mean those data fragments cannot be placed in the correct logical position. The resulting disk image may have gaps where the file system shows corrupted or missing sectors. The PC-3000 can still extract data from all readable pages, but heavily degraded TLC NAND with high bit error rates may require multiple read passes with adjusted voltage thresholds (shifting the read reference voltage to compensate for charge loss in aging cells). That's why firmware recovery prices move. SATA SSD firmware cases run $600–$1,200, and NVMe cases run $900–$1,200, depending on how far the NAND has degraded.
Read Retry and Voltage Threshold Shifting
TLC NAND stores 3 bits per cell by maintaining 8 distinct voltage levels in a single cell. Over thousands of Program/Erase cycles, the trapped charge drifts. The voltage gap between adjacent states narrows until the controller's default read thresholds can't distinguish level 3 from level 4. The result: uncorrectable ECC errors on pages that are physically intact.
Read Retry is a controller-level feature that shifts the sensing voltage margins to reread degraded cells. PC-3000 SSD sends vendor-specific commands that force the controller through read retry table entries, each shifting the voltage reference point.
Why Firmware Flashing Tools Destroy Data
Mass production tools (MPTools) are designed to initialize new, empty SSDs at the factory. Running them on a firmware-corrupted drive that contains user data overwrites the service area with factory defaults, permanently destroying the FTL mapping table. The data on the NAND becomes unrecoverable by any method.
These tools exist for one purpose: to flash blank firmware onto new controller silicon during SSD manufacturing. The MPTool erases the service area and writes a fresh FTL initialized to an empty state. On a drive containing user data, this operation destroys the existing logical-to-physical mapping.
The PC-3000 SSD approach is the opposite of flashing. It injects a volatile loader into RAM. It reads the NAND contents & reconstructs the FTL in RAM on the drive itself. Nothing is written to the drive's NAND at any point. This is why firmware recovery at $600–$1,200 (SATA) or $900–$1,200 (NVMe) costs more than a free MPTool download: the MPTool destroys the data, & the PC-3000 preserves it.
Why Can't an Adapter Stand In for the PC-3000 Portable III?
PC-3000 Portable III Hardware Path
A USB-to-SATA or USB-to-NVMe adapter can't stand in for the PC-3000 Portable III's hardware path. A drive that appears "not detected" through a USB enclosure can still respond to vendor commands when connected to the PC-3000 Portable III interface.
PC-3000 VSC Workflows vs Proprietary Extraction Hardware
What Competitors Publicly Claim
Ontrack describes its SSD method this way on its SSD data recovery page at ontrack.com/en-us/data-recovery/ssd: "We use proprietary tools and techniques to retrieve your data... decoding complex SSD data structures for individual brands, specialized controller chips." It doesn't name a hardware platform.
Why Chip-Off Alone Fails on Modern NVMe Drives
Parallel NAND imaging and single-chip chip-off readers share a common limitation on current-generation NVMe hardware. Samsung in-house NVMe controllers, the Maxio MAP1602A, and the Phison E26 use hardware-bound AES-256 encryption. A raw chip-off dump of those NAND dies yields ciphertext, and the plaintext never leaves the controller. Chip-off remains valid on USB thumb drives and SD cards where the controller does not enforce controller-bound encryption.
What We Actually Run in the Lab
Our SSD firmware recovery path is PC-3000 SSD and PC-3000 Portable III for VSC dispatch, FLIR thermal imaging to locate shorted components before power application, Hakko FM-2032 microsoldering on an FM-203 base station for PMIC or voltage regulator replacement, Atten 862 hot air for controller rework where the controller itself has failed electrically, and Zhuo Mao precision BGA rework stations for NAND chip transplant to a donor PCB when the board is beyond repair. The per-controller loader library is licensed from ACE Lab and is the same loader library every PC-3000 SSD user runs. What we add is the lab time and the discipline to keep the drive in Safe Mode until the extraction is done.
Firmware recovery pricing sits at $600–$1,200 for SATA SSDs and $900–$1,200 for NVMe SSDs, with 3-6 weeks typical turnaround on SATA cases and 3-6 weeks on NVMe. +$100 rush fee to move to the front of the queue service is available to move a case to the front of the queue. Free evaluation, firm quote before any paid work, and no charge if the data cannot be recovered. We quote a NAND chip transplant from a badly damaged circuit board onto a donor PCB at the $1,200–$2,500 tier. It needs a donor drive, which costs extra.
How does the PC-3000 SSD technological-mode workflow rebuild firmware?
A PC-3000 SSD recovery on a firmware-bricked drive moves through four discrete stages: forcing the controller into factory mode, identifying the correct loader microcode for that exact controller family and revision, dumping the service-area metadata, and reconstructing the FTL translator in RAM on the drive itself. The drive itself is never written to.
Stage 1: Controller falls back to factory mode after firmware bank corruption
SSD controllers ship with a small immutable bootloader hardcoded into on-die ROM and a much larger main firmware image stored in reserved NAND service-area blocks. When the active firmware bank in the service area fails its integrity check, the ROM bootloader stops the normal boot sequence and parks the controller in a minimal diagnostic state. The host sees one of three symptoms: the drive reports a placeholder identity (SATAFIRM S11 on Phison, generic vendor strings on Silicon Motion), it reports zero-byte capacity, or it stops responding to ATA/NVMe identify commands entirely. In all three cases the user data on the NAND is untouched. The controller has only lost the ability to translate logical block addresses to physical pages because the FTL it would normally load is unreadable.
Stage 2: Engineer identifies the correct loader microcode for the controller family
ACE Lab licenses a per-family loader library with PC-3000 SSD: separate utility modules for Phison, Silicon Motion, and Marvell controllers among others. Each module contains microcode binaries keyed to a specific controller revision and to the NAND configuration behind it. A Phison loader will not initialize a Silicon Motion die. The PC-3000 SSD utility makes the match on its own for the major families. When a case is ambiguous, it flags it and we pick by hand.
Stage 3: PC-3000 SSD rebuilds the translator in the drive's RAM
Once the matched loader is injected into the controller's RAM, the controller stops running its corrupted factory firmware and starts executing under ACE Lab microcode. The loader exposes raw physical-block-address access to the NAND. Then the drive scans its own service area. PC-3000 SSD builds a new translator from the service-area modules that survived & from older translator copies. That rebuilt translator lives in RAM on the drive itself.
Stage 4: Why generic data recovery software cannot replicate this process
Disk Drill, Recuva, TestDisk, EaseUS, R-Studio, and ReclaiMe all run as host-side applications above the operating system's storage driver. They send standard ATA, SCSI, or NVMe read commands, and they depend on the controller to translate every LBA they request into the correct physical NAND page. On a firmware-bricked drive there is no working FTL for the controller to consult, so those LBA reads return zeros, error out, or hang. None of these tools can issue the vendor-specific commands required to enter factory mode, none can inject a microcode loader into controller RAM, and none has access to the per-family loader library at all.
This is the workflow that separates firmware-level recovery from file-level undelete. For the full price tier breakdown across every failure mode, see our ssd data recovery service overview. For Host Memory Buffer architectures and PCIe-specific recovery paths on M.2 drives, see our nvme data recovery page.
Firmware Corruption Triage by Controller Family
Controller family determines the triage path. Firmware corruption is logically reversible because the NAND cells still hold readable charge. We can rebuild the translator & load it into the drive's RAM. Cell wear is a different failure mode entirely, and that path lives on the NAND degradation page.
- Phison PS3111-S11 (SATA)
- Symptom: drive reports the SATAFIRM S11 model string, 0 bytes capacity, or ROM mode. Path: ROM-mode entry through the controller's minimal command set, vendor microcode loader injected into RAM, full FTL rebuild from surviving page metadata. See the Phison controller recovery page for the loader-injection procedure.
- Phison PS5012-E12 / PS5016-E16 (NVMe)
- Symptom: drive vanishes from PCIe enumeration or hangs the host during NVMe identify. Path: vendor-specific commands through the Phison NVMe module on PC-3000 SSD, then a translator rebuild. This is the recovery path for Phison-based NVMe drives of that generation.
- Silicon Motion SM2258 / SM2259 / SM2263 (SATA and NVMe)
- Symptom: BSY state on power, ID strings missing, drive enumerates but never serves data. Path: diagnostic-pad access on the PCB, vendor command set through the PC-3000 Silicon Motion module, then an FTL rebuild. See our Silicon Motion controller recovery page.
- Marvell 88SS1074 (SATA OEM)
- Symptom: drive presents to the host but reports the wrong capacity or 0 GB, or boots into a vendor-specific diagnostic ID. Path: the Marvell-specific PC-3000 module sends vendor commands to enter the controller's service mode, reads the translator and bad-block metadata from the system area, and rebuilds the FTL. OEM-specific microcode means each brand must be matched to its firmware revision before loader work begins.
System Area Service Tables and the Virtual Translator
In a firmware failure like this, what's broken is the System Area: a reserved set of NAND blocks that hold the controller's service tables. This is the exact scenario where SSD data recovery with the PC-3000 Portable III rebuilds a virtual translator in RAM on the drive itself and images the drive's logical volume from that map.
Where the rebuilt virtual translator lives
Once the loader is running in controller RAM and the PC-3000 SSD utility has swept the surviving service-area metadata, it compiles a virtual translator and uploads it into RAM on the drive itself. The translator is not flashed back to the NAND. The drive is still operating in volatile safe mode; the loader is still volatile; the user-area FTL on the NAND is still inconsistent. What's changed is that the drive now holds a coherent LBA-to-physical map in RAM and can answer logical read requests through the loader.
Firmware-tier pricing for these failure modes runs $600–$1,200 on SATA SSDs and $900–$1,200 on NVMe SSDs. Rush handling is an additional $100 rush fee to move to the front of the queue. No data, no recovery fee; evaluation is free.
Estimate Your Firmware Recovery Cost
What type of SSD do you have?
What is SSD firmware corruption?
SSD firmware is the embedded software on the controller chip that manages the Flash Translation Layer, wear leveling, garbage collection, and NAND cell mapping. If a power loss corrupts that firmware, the controller drops into safe mode or stops responding. The drive may show 0 bytes, report as SATAFIRM S11, or vanish from BIOS.
Can data recovery software fix a firmware-corrupted SSD?
No. Consumer recovery software like Disk Drill, Recuva, and TestDisk operates through the OS storage driver above the controller. When firmware is corrupted, the controller cannot translate logical addresses to physical NAND locations. The drive appears as 0 bytes or is invisible to the OS. Software has no path to reach the data.
How much does SSD firmware recovery cost?
SATA SSD firmware recovery costs $600–$1,200. NVMe SSD firmware recovery costs $900–$1,200. The price depends on how many bad areas the NAND has. Free evaluation, firm quote before any paid work. No data recovered means no charge.
Which SSD controllers have known firmware failure modes?
The Phison PS3111-S11 is the controller behind the 'SATAFIRM S11' error. Silicon Motion SM2258 and SM2259 controllers also have documented firmware failure modes.
How is firmware corruption different from NAND degradation?
Firmware corruption damages translator metadata, bad-block tables, or service-area code while the NAND cells themselves still hold readable charge; PC-3000 SSD can rebuild the translator in RAM on the drive itself and extract user data. NAND degradation is physical cell wear-out: oxide layer breakdown, raised UECC rates, and unreliable reads from the silicon itself. A firmware fault is logically reversible. Cell-level wear is not, though chip-off into PC-3000 Flash can sometimes salvage what remains on unencrypted drives. See /services/ssd-data-recovery/nand-degradation for the cell wear-out path.
Which SSD controllers fall outside PC-3000 SSD firmware recovery?
Modern Samsung in-house NVMe controllers, Realtek, Innogrit, and Maxio MAP1602 are not on ACELab's supported list. Modern Samsung and Innogrit controllers implement hardware-bound AES-256 encryption, so chip-off NAND extraction yields ciphertext that cannot be decrypted off the original silicon; a dead drive from those families needs board-level repair to keep the original controller alive. Rossmann does not currently offer in-lab recovery for Realtek, Innogrit, or Maxio MAP1602. Samsung drives are taken case by case: one that still enumerates may need only a logical recovery.
Is a Phison SATAFIRM S11 drive easier to recover than a Silicon Motion BSY drive?
PC-3000 SSD supports both. On a Silicon Motion SM2258/SM2259 stuck in BSY, we have to short specific ROM diagnostic pins on the PCB at power-on to get it into safe mode. Recovery feasibility on either family depends on whether service-area metadata survived, not on which controller is in the drive. We quote firmly only after diagnostics.
What is volatile microcode injection on an SSD controller?
Volatile microcode injection is the technique our technicians use to push a stripped-down loader image directly into the SSD controller's RAM through the PC-3000 Portable III. ACELab calls that image a Loader (LDR). The LDR vanishes the moment power is cut, which is the point: it gives the PC-3000 read-only physical access to the NAND, disables wear leveling, garbage collection, and TRIM during imaging, and never writes to the user-area firmware on the drive.
How does the PC-3000 Portable III rebuild a destroyed FTL on an SM2258 or PS3111 drive?
Once the loader is running in the drive's RAM, the drive scans its own service area. The PC-3000 SSD utility then builds a new Logical-to-Physical (L2P) translator from the service-area modules that survived, older translator copies, and raw NAND metadata. It uploads that translator into the drive's RAM. Nothing gets written back to your drive.
Can the PC-3000 SSD utility's loader injection bypass Apple T2, M-series, or OPAL hardware encryption?
No, and we do not claim to. On Apple T2 and Apple Silicon Macs the data-encryption key is bound to the Secure Enclave on the logic board. On OPAL / eDrive SATA and NVMe drives, the media encryption key is wrapped by a hardware-unique key fused into the controller. We never advertise bypassing, cracking, or defeating manufacturer encryption.
Data Security During Firmware Recovery
Your SSD remains in our Austin lab for the entire recovery. PC-3000 firmware work and translation table reconstruction happen on air-gapped workstations. Full chain-of-custody and erasure protocols apply to every case. NDAs available on request.
Controller Identity Strings and OEM Firmware Matching
A dropped model string means the controller fell back to mask ROM
The model-string overwrite is the cleanest tell. A drive that posts as "Crucial BX500" in BIOS still has a controller running OEM firmware. A drive that posts as a raw silicon descriptor such as "SM2258AB-80-100000000" has dropped to its bare identity. Silicon Motion drives in that state either report the descriptor or hold BSY indefinitely.
Marvell 88SS1074 drives run OEM-specific firmware
The loader has to be matched to the firmware build on the board in front of the technician, not to the controller part number alone.
PC-3000 Portable III Workflow For SM2258, SM2259, & PS3111 Firmware Recovery
When a Silicon Motion SM2258, SM2259, or Phison PS3111-S11 drive arrives in a firmware panic, our technicians do not flash, repartition, or initialize the drive. The recovery sequence is hardware-led: force the controller into its diagnostic safe mode using vendor-specific entry methods, push a volatile loader into controller RAM with the PC-3000 Portable III, then rebuild the Flash Translation Layer in RAM on the drive itself by parsing per-page metadata from the NAND spare area. Nothing is written back to the patient drive during this workflow.
The exact vendor opcode sequences and the internal structure of ACELab's loader microcode are proprietary to ACELab and are not published; our technicians use them only under the PC-3000 SSD utility's controlled framework, never as raw command injection. Firmware-tier pricing for SM2258, SM2259, & PS3111 recovery runs $600–$1,200 on SATA SSDs and $900–$1,200 on NVMe SSDs, with an additional $100 rush fee to move to the front of the queue. Evaluation is free; the no data, no recovery fee policy applies.
Vendor-mode entry by controller
Each controller family has its own way of entering the diagnostic state the PC-3000 needs. Phison PS3111-S11 drops into a responsive ROM identity when its NAND-resident firmware fails to validate, reporting the well-known SATAFIRM S11 string. Silicon Motion SM2258 and SM2259 are different: they hold the ATA BSY bit high indefinitely and require a physical short on a designated ROM diagnostic pad to break the boot loop. The table below summarizes the entry vector and the PC-3000 SSD utility mode our technicians use for each family.
| Controller | Panic identity / capacity | Diagnostic entry method | PC-3000 SSD utility mode |
| Phison PS3111-S11 (SATA) | SATAFIRM S11; reports 0 bytes, 2 MB, or 20 MB | Short the designated safe-mode test points during power-on if the controller does not drop into ROM identity on its own | Phison "Technological Mode" family utility |
| Silicon Motion SM2258 & SM2258XT (SATA) | BSY stall, or a generic vendor string like SM2258AB when the controller does fall through to ROM identity | Short the designated ROM test pad on the PCB. Its location differs from board to board | Silicon Motion "Safe / Techno Mode" family utility |
| Silicon Motion SM2259 & SM2259XT (SATA) | BSY stall; raw SM2259XT identity on ROM fallback | Short the designated ROM test pad, the same way as on the SM2258 | Silicon Motion "Safe / Techno Mode" family utility |
Volatile microcode loader injection into controller RAM
With the controller halted in its diagnostic state, the next step is loading a stripped-down microcode image directly into the controller's RAM. ACELab calls this image a Loader, abbreviated LDR. Because RAM is volatile, the LDR vanishes the moment power is cut. This is a deliberate property of the workflow, not a limitation.
The LDR exists to give the PC-3000 read-only physical access to the NAND. It explicitly disables wear leveling, garbage collection, and TRIM execution, so degraded blocks and recently "deleted" pages are preserved during imaging rather than being reclaimed mid-read. It also unlocks the vendor-specific commands that issue physical-page reads against the raw NAND, which the standard host command set has no opcodes for.
Factory Mass Production Tools (MPTool, SMI-style flashers) work differently. MPTool-class utilities are designed to initialize a drive for resale: they erase the NAND service area, build a fresh empty translator, and stamp a new identity. Running an MPTool on a SATAFIRM S11 or SM2258 BSY drive will revive it as a working blank disk and permanently destroy the user data. The PC-3000's LDR workflow is the opposite: it never writes to user-area NAND and never touches the corrupted service area.
Reconstructing the FTL L2P map from NAND spare-area metadata
Once the LDR is resident and the PC-3000 has raw physical-page access, the data is still scattered. The on-NAND translator is corrupt; the controller cannot answer logical reads. The recovery path is to rebuild the Logical-to-Physical (L2P) map in RAM on the drive itself by harvesting metadata from the spare area attached to every physical NAND page.
Every NAND page is split into a user-data region and an Out-of-Band spare area. The host never sees the spare area in normal operation. The controller uses it to carry per-page metadata: the Logical Block Address the host wrote to that page, the wear-leveling counters, and the ECC parity for the user-data region. These fields are written at the same instant as the user data and survive controller panic because they live on the same physical page as the payload they describe.
The PC-3000 SSD utility issues vendor-specific reads through the LDR to walk every physical page on every channel and harvest the spare-area metadata. As metadata streams in, the utility builds a virtual L2P table in RAM on the drive itself.
Nothing in this stage is written back to the patient drive.
Where the spare-area metadata is itself missing, because the relevant blocks degraded past the ECC correction threshold or were aggressively reclaimed before the panic, the corresponding LBAs cannot be reconstructed. Our technicians do not guarantee recovery percentages on firmware-panic drives; feasibility is a function of how much spare-area metadata survived, and that is only knowable after the drive is on the bench. Quotes are firm only after diagnostics, and the no data, no recovery fee policy applies if the rebuild cannot produce a usable image.
SSD stuck in firmware safe mode?
Free evaluation. SATA: $600–$1,200. NVMe: $900–$1,200. No data, no fee.
