What Does TRIM Do to Your SSD Data?
TRIM is a command your operating system sends to the SSD after you delete a file. It tells the controller which data blocks are no longer needed. The controller then schedules those blocks for erasure during garbage collection. This two-step process is why recovery software shows zeroes on your SSD within seconds of deletion, even though the physical memory chips may still hold data.
On a hard drive, deleting a file only removes a pointer. The magnetic data on the platter sits there until something new overwrites it. SSDs work differently. The controller actively erases old data in the background to keep fresh blocks available for future writes. That background process is garbage collection, and it runs on its own schedule.
TRIM is enabled by default on Windows 7+ and macOS 10.6.8+. If you deleted files from an SSD connected to a modern operating system, TRIM almost certainly ran. The question isn't whether TRIM ran; it's whether garbage collection has finished erasing the NAND cells. That's what our SSD data recovery determines.
What Is DZAT, and Why Does Recovery Software See Zeroes?
DZAT stands for Deterministic Read Zero After TRIM. It's a firmware behavior where the SSD controller intercepts read requests for deleted blocks and returns all zeroes. This happens instantly after TRIM processing, before the physical NAND cells are erased. Recovery software like Disk Drill, EaseUS, or R-Studio reads through the controller's standard interface, receives zeroes, and concludes the data is gone.
- DZAT (SATA SSDs)
- Defined by SATA specification Word 69 bit 5 in the device IDENTIFY data. The controller returns all zeroes for any read to a TRIMmed logical block address. Implemented on most SATA SSDs manufactured after 2015.
- DRAT (Older SATA SSDs)
- Defined by SATA Word 69 bit 14. Returns a consistent but not necessarily zero value for TRIMmed addresses. Common on drives before 2018. Slightly more favorable for software-based recovery since the returned pattern differs from genuine zeroes.
- DLFEAT=001b (NVMe SSDs)
- The NVMe equivalent of DZAT. Set in the namespace metadata, it forces reads to deallocated blocks to return all zeroes. Every major NVMe controller (Samsung Elpis, Phison PS5018-E18, Silicon Motion SM2262EN) enforces this behavior.
The result for you: any recovery tool you run from Windows, macOS, or Linux will see zeroes where your data used to be. The data may still physically exist on the NAND memory chips, but the controller blocks access through the normal read path. Getting past DZAT requires bypassing the controller entirely, which is what PC-3000 SSD does in our lab.
How the SSD Controller Returns Zeros Before NAND Is Erased
Why does a TRIMmed SSD return zeros even when the data is still in NAND?
The SSD controller intercepts every host read before it reaches the NAND array, checks an invalidation flag in the Flash Translation Layer, and synthesizes a zero buffer from controller memory whenever the target LBA is marked TRIMmed. The original charge states may still sit in the NAND cells, but the controller refuses to surface them through the user-facing read path.
DZAT is enforced inside the controller's read-completion logic, not on the NAND die. Every host read crosses the same four-stage decision path inside controller firmware before any data leaves the package. Recovery only becomes physically possible when an access layer below that completion logic is reached, which is why SSD data recovery for a TRIMmed drive is exclusively a lab problem.
The host-read decision path inside the controller
- Host read command arrives. The OS issues a SATA READ DMA EXT (0x25) or NVMe Read (opcode 0x02) targeting a logical block address. The command enters the controller's front-end FIFO over the SATA or PCIe PHY.
- FTL lookup against the L2P map. The controller's L2P engine resolves the LBA against the in-DRAM mapping table (or against the HMB-backed map on DRAM-less designs like Phison PS5021-E21 or Silicon Motion SM2263XT). The lookup returns either a physical page address or an invalidation marker.
- TRIM bitmap / invalidation flag check. Before any NAND fetch is queued, the controller inspects the per-LBA invalidation bit set by the prior DATA SET MANAGEMENT (SATA 0x06) or Dataset Management Deallocate (NVMe 0x09, AD=1) command. If the flag is asserted, the physical read is aborted.
- Synthetic zero buffer returned to the host. The controller allocates a zero-filled buffer in DRAM or SRAM and pushes it through the completion frame on the SATA or PCIe bus. The NAND array is never accessed for that read; the original charge states on the floating gates remain untouched until garbage collection runs.
Access modes: what each layer can recover from a TRIMmed drive
| Access mode | How it reaches the drive | What it sees on TRIMmed LBAs |
| User Mode (host OS, consumer software) | Standard SATA / NVMe commands through the OS block-device stack. Recuva, EaseUS, R-Studio, PhotoRec, Disk Drill all sit here. | Synthetic zeros from the controller's DZAT/DLFEAT response. No way to ask whether NAND still holds charge. |
| Translator Mode (Virtual FTL rebuild) | PC-3000 SSD reads page metadata, log-block headers, and sequence stamps, then rebuilds the L2P map in workstation RAM. Runs as a sub-function inside Technological Mode. | Reconstructs logical files from surviving valid pages and over-provisioned copies. Still bounded by what the controller's NAND-side metadata survived; will not recover LBAs that GC has erase-verified. |
| Technological Mode (Factory / vendor-command state) | Controller is forced past its standard firmware using test-point shorting (Phison, Silicon Motion, Marvell) or vendor command sequences (older Samsung MEX/MGX/MJX), and an SRAM loader is uploaded by PC-3000 SSD. | Direct Physical Block Address reads that bypass the DZAT response layer. Original charge states are recoverable wherever the cells still hold them. |
The practical consequence is that no consumer recovery product can defeat DZAT. Recuva, EaseUS Data Recovery Wizard, R-Studio, and Disk Drill all read through the same OS block-device APIs that User Mode exposes. They cannot issue vendor specific commands, cannot upload an SRAM loader, and cannot bypass the L2P invalidation check.
Marketing copy that claims SSD recovery from a TRIMmed drive without describing a vendor-command path is describing one of the narrow edge cases (a USB bridge that strips UNMAP, a filesystem corruption with no TRIM issued, or TRIM manually disabled via fsutil), not a defeat of DZAT itself. Technological Mode on PC-3000 SSD is the only access layer that bypasses the controller's zero-return logic on a healthy drive, and on controllers where ACELAB does not publish a loader (Samsung Elpis on the 980 Pro, Pascal on the 990 Pro, Phison E18/E26 NVMe with hardware-bound AES), the recovery path becomes board-level repair that revives the original controller so it can decrypt its own NAND.
How DZAT Returns Zeros Before NAND Is Erased
The SSD controller starts returning zeros to the host the instant TRIM is processed, but the NAND cells still carry the original programmed threshold voltages for some time after that. Recovery for an SSD data recovery customer is possible inside that gap, and only inside that gap, and only through the original controller while its Flash Translation Layer state is still intact.
OS to controller to NAND: the TRIM sequence
- OS issues TRIM/Deallocate. Windows, macOS, or Linux sends DATA SET MANAGEMENT (SATA opcode 0x06, TRIM feature bit) or NVMe Dataset Management (opcode 0x09, AD=1) carrying the deleted LBA ranges.
- Controller updates the FTL. The controller writes a journal entry to a reserved metadata region, invalidates the L2P entries for those LBAs in DRAM, and flushes the change to the NAND metadata area. The block is enqueued for garbage collection. The NAND user pages are not yet touched.
- DZAT mask activates. Any subsequent host read to a deallocated LBA is intercepted by the controller. The controller synthesizes a zero buffer in DRAM and returns it through the SATA or NVMe completion frame. No NAND fetch occurs on that read.
- GC relocates valid pages, then applies the erase pulse. When the scheduler picks the block, the controller copies any surviving valid pages to a fresh block, then drives +15 to +20V onto the P-well. Reverse Fowler-Nordheim tunneling drains the charge storage layer of every cell in the block.
- Erase-verify closes the window. The controller reads every cell in the block at the 0xFF threshold. Once verify passes and the block is returned to the free pool, the data is physically gone and no lab procedure recovers it.
Controller read path vs NAND physical state, by lifecycle stage
| Lifecycle stage | Controller read path returns | NAND cells physically hold | Recovery viability |
| Before TRIM (file still live) | User data via valid L2P map | Original programmed threshold voltages | Standard read path; software backup works |
| FTL invalidated, pre-erase | 0x00 synthesized in DRAM (DZAT/DLFEAT) | Original programmed threshold voltages | Lab-only via PC-3000 SSD Safe/Techno Mode raw read |
| GC candidate queued | 0x00 synthesized in DRAM | Cells intact; valid pages may already be relocated | Lab-only; window seconds (Samsung) to hours (SMI lazy GC) |
| Erase pulse applied | 0x00 synthesized in DRAM | Charge actively draining via reverse Fowler-Nordheim tunneling | Closing; data being destroyed |
| Erase-verify passed | 0x00 (now matches physical state) | 0xFF erased state, block in free pool | None; physically destroyed |
Why chip-off cannot reverse this while the controller is bypassed
Desoldering the NAND and reading it on an external programmer skips the controller, which is exactly the problem. The data on those packages is bound to the original controller by four overlapping mechanisms: an AES-256 Media Encryption Key that is generated on and bound to the original controller, wrapped by a hardware-unique key fused into that controller, a per-block XOR randomizer driven by a vendor-specific LFSR polynomial, LDPC soft-decode tables that depend on the controller's voltage-threshold tracking, and a hybrid log-block L2P map that scatters one logical file across non-contiguous physical pages with sequence stamps the controller alone interprets.
A chip-off dump from a modern Samsung Elpis or Pascal, Phison E12/E16/E18/E26, or Silicon Motion SM2262EN drive is ciphertext under an unrecoverable key. Even on the rare unencrypted SATA controller (e.g., older Phison PS3111-S11), the dump is still unreadable without reversing the dynamic XOR scramble, decoding LDPC against the original controller's threshold model, and rebuilding the L2P map from page metadata. The FTL state has to stay intact on the original controller; lose that state and the page sequence stamps no longer reassemble into a filesystem.
The only viable path: board-level recovery on the original controller
For an SSD data recovery customer whose drive sits anywhere from stage 2 through stage 4 above, the recovery path is the same: keep the original controller alive, halt its background processing, and read the NAND through that controller's own decryption and ECC pipeline. If the controller is healthy, PC-3000 SSD forces it into Safe Mode (Phison, Silicon Motion, Marvell test-point shorting) or Techno Mode (older Samsung MEX/MGX/MJX vendor commands), uploads a volatile SRAM loader, and reads physical pages before the next GC cycle runs. If the controller is dead, the same loader cannot be uploaded until the board is revived; FLIR thermal imaging localizes the shorted PMIC or rail, and a Hakko FM-2032 on an FM-203 base station replaces the failed component so the original controller boots with its hardware-bound key still bound. Either path keeps the FTL state on the original controller, which is the only place that map exists.
The trade-off is timing. The longer the drive remains powered after a deletion, format, or TRIM event, the more stage-3 candidate blocks fall into stage 4. Power the drive off and ship it to our Austin, TX lab. The From $200 SATA and From $200 NVMe evaluation reads NAND through the original controller before any further GC can run. If the cells have already passed erase-verify, we say so and return the drive at no cost.
When Can a Lab Still Recover Your SSD Data After TRIM?
Recovery is possible when the NAND cells still hold their original electrical charge. DZAT hides the data from software, but the physical memory chips don't know the difference. Between the moment TRIM runs and the moment garbage collection applies the erase voltage, a narrow recovery window exists. How long that window lasts depends on the controller.
| Scenario | NAND State | Recoverable? |
| SSD lost power before GC ran | Cells hold original charge | Yes |
| Controller firmware crashed | GC never executed; cells intact | Yes |
| USB bridge chip blocked TRIM | Controller never received TRIM | Yes |
| TRIM disabled in OS settings | No TRIM sent; data persists | Yes |
| GC interrupted mid-erase by power loss | Some pages partially drained | Partial |
| GC completed; blocks fully erased | Cells at 0xFF (erased state) | No |
Power off the SSD immediately after accidental deletion. Don't run recovery software; it triggers controller activity that can start GC. Ship the drive powered off to our Austin, TX lab. We'll check the raw NAND state for free. If GC has already erased the target blocks, we tell you and return the drive at no cost. For the full diagnostic path across queued-TRIM failures, OP-block survival, and firmware-crash scenarios, see our SSD data recovery service. SATA recovery starts at $200; NVMe starts at $200.
When Does Recovery Software Work on an SSD?
Recovery software works when the SSD is physically healthy and the problem is logical: an accidentally deleted partition, a corrupted file system, or formatted volume where TRIM hasn't executed on the target blocks. Tools like Disk Drill, EaseUS, PhotoRec, and R-Studio scan the drive through the controller's standard interface and reconstruct file structures from whatever the controller returns.
That stops working the moment DZAT activates. Once the controller processes TRIM, software sees zeroes. If the controller is dead (the drive doesn't appear in BIOS), software can't communicate with the drive at all. And if the firmware is corrupted (the drive reports 0MB capacity or the wrong model name), software has no valid file system to scan.
Lab recovery picks up where software fails. PC-3000 SSD communicates with the controller at the vendor command level, below the SATA or NVMe protocol. For dead controllers, we diagnose the failure using FLIR thermal imaging and repair the original PCB with Hakko FM-2032 microsoldering. The distinction matters because many SSDs encrypt data using hardware AES-256, with the encryption key bound to the controller. A dead controller on an encrypted drive means chip-off yields only ciphertext. Board-level repair to revive the original controller is the only path to readable data on encrypted SSDs.
Once DZAT-induced zero returns rule out every software-only path, the workflow has nowhere to go but down to the NAND. That is what the rest of the lab process described on our SSD data recovery service page handles, from PC-3000 SSD Safe Mode entry through chip-off on unencrypted controllers.
How Much Does SSD Data Recovery Cost?
SATA SSD recovery ranges from $200–$1,500. NVMe SSD recovery ranges from $200–$2,500. Price depends on the failure type. If we determine that garbage collection has already erased your data, the evaluation costs nothing. +$100 rush fee to move to the front of the queue. No diagnostic fees. 4.9 stars across 1,837+ Google reviews.
Circuit board repair (SATA: $450–$600, NVMe: $600–$900) involves component-level microsoldering to revive the original controller. This tier preserves the AES-256 encryption key, which is why it's the primary recovery path for modern encrypted SSDs. NAND swap (SATA: $1,200–$1,500, NVMe: $1,200–$2,500) requires a 50% deposit and is reserved for cases where the original PCB is too damaged for repair. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
- The destination drive we copy recovered data onto. You can supply your own or we provide one at cost plus a small markup. All prices are plus applicable tax.
How Do NAND Cells Store Data at the Transistor Level?
Older planar NAND used floating gate transistors: a conductive polysilicon gate isolated between oxide layers stores electrons that set the cell's threshold voltage. Most modern 3D NAND (Samsung V-NAND, Kioxia BiCS) uses Charge Trap Flash (CTF), where electrons are trapped in a non-conductive silicon nitride layer instead. Micron took a different path, retaining floating gate architecture through its 32-layer, 64-layer, and 96-layer 3D NAND generations before transitioning to a replacement-gate CTF design at 128 layers and above. The underlying principle is the same across both architectures: trapped charge determines threshold voltage, and the controller reads that voltage as a binary value. The difference matters for endurance and data retention, but both architectures follow the same erase and programming physics described below.
Programming: Fowler-Nordheim Tunneling
Writing data to a NAND cell pushes electrons through the tunnel oxide into the charge storage layer (floating gate or nitride trap) using Fowler-Nordheim (F-N) tunneling. A high voltage (+15V to +20V) applied to the control gate creates an electric field strong enough for electrons to quantum-tunnel through the oxide barrier. The accumulated charge raises the cell's threshold voltage. SLC cells store one bit across two voltage states; TLC cells store 3 bits across 8 voltage levels; QLC stores 4 bits across 16 levels.
Each program/erase (P/E) cycle degrades the tunnel oxide. The oxide traps electrons that don't fully clear during erase, gradually narrowing the voltage windows between states. Consumer TLC NAND is rated for roughly 1,000-3,000 P/E cycles; QLC for 500-1,000. This physical degradation is why SSDs have a write endurance limit and why older, heavily-used drives develop read errors that PC-3000 SSD must work around during recovery.
Erasure: Block-Level Constraint
NAND can write individual pages (4KB-16KB) but can only erase entire blocks (typically 256KB-4MB containing 64-256 pages). This is a physical limitation, not a firmware choice. Transistors in a NAND string share a common P-well substrate. The erase voltage is applied to the P-well, which drains the charge storage layer in every cell in the block simultaneously through reverse F-N tunneling. There is no way to erase a single page within a block without erasing every page in that block.
This page-write/block-erase asymmetry is the reason garbage collection exists. When you delete 3 files spread across a block that also contains 5 active files, the controller can't just erase the deleted pages. It reads the 5 valid pages, copies them to a clean block, then applies the erase voltage to the entire old block. The valid pages survive in their new location. The deleted data is electrically destroyed.
DZAT, DRAT, and DLFEAT Behavior by Controller Family
Every modern SSD controller family we recover implements deterministic post-TRIM behavior, but the aggressiveness of garbage collection varies by controller firmware. Samsung controllers erase TRIMmed blocks within seconds of idle. Silicon Motion controllers defer GC until free block counts drop below a firmware-defined threshold. This timing difference determines how large the recovery window is for any given drive.
| Controller | Interface | Post-TRIM Behavior | GC Aggressiveness | PC-3000 Entry Mode |
| Samsung Elpis (980 Pro) | NVMe | DLFEAT=001b | Seconds after idle | Not supported (board repair) |
| Samsung Pascal (990 Pro) | NVMe | DLFEAT=001b | Seconds after idle | Not supported (board repair) |
| Samsung Piccolo (990 EVO) | NVMe | DLFEAT=001b | Seconds after idle | Not supported (board repair) |
| Phison PS3111-S11 | SATA | DZAT (Word 69 bit 5) | Batched during idle | Safe Mode |
| Phison PS5012-E12 | NVMe | DLFEAT=001b | Batched during idle | Safe Mode |
| Phison PS5018-E18 | NVMe | DLFEAT=001b | Batched during idle | Safe Mode (repair only) |
| SM2258XT / SM2259XT | SATA | DZAT (Word 69 bit 5) | Deferred (lazy GC) | Safe Mode |
| SM2262EN / SM2263XT | NVMe | DLFEAT=001b | Deferred (lazy GC) | Safe Mode |
| Marvell 88SS1074 | SATA | DZAT (Word 69 bit 5) | Firmware-dependent | Safe Mode |
| WD/SanDisk in-house | NVMe / SATA | DZAT / DLFEAT=001b | Moderate | Not supported (board repair) |
Silicon Motion controllers (SM2258XT, SM2259XT, SM2262EN, SM2263XT) offer the largest recovery window for post-TRIM data. Their “lazy GC” strategy preserves TRIMmed pages on lightly-used drives until the free block pool drops below a firmware-defined threshold. Samsung Elpis and Pascal controllers offer the smallest window; their GC begins within seconds of the drive going idle. We see this pattern consistently on our PC-3000 SSD diagnostic bench.
PS3110, SM2258XT, and Samsung MEX/MGX: DZAT Firmware Behavior in Detail
Three controller families dominate the SATA SSD installed base and define what recovery looks like in practice. The Phison PS3110-S10 is an 8-channel quad-core SATA controller with onboard DRAM, shipped on PNY CS1311, Patriot Ignite, and Mushkin Striker drives, plus extensive Toshiba and Lite-On rebranding. The PS3110 advertises Word 69 bit 5 set and processes TRIM through the DATA SET MANAGEMENT opcode 0x06 path. GC runs in batched bursts during idle: the firmware selects candidate blocks by invalid-page ratio, copies surviving valid pages forward, then applies the +15-20V erase pulse. PC-3000 forces the PS3110 into Safe Mode by shorting designated ROM/Safe Mode test points on the PCB while cycling power, halting GC mid-batch and exposing the pre-erase NAND state.
Silicon Motion SM2258XT is the DRAM-less budget controller behind the Crucial BX500, ADATA SU650, Kingston A400, WD Green, and a long tail of OEM-rebranded drives. Because the SM2258XT has no onboard DRAM, the entire FTL lives in NAND flash, so every metadata flush costs a NAND program cycle and firmware batches both flushes and erases against an internal idle watermark. The same architectural choice makes SM2258XT firmware more prone to service-area corruption after sudden power loss because the L2P delta sitting in SRAM is lost on power-down. PC-3000 enters Safe Mode by shorting the designated ROM pins on the PCB during power-on, bypassing the corrupted on-NAND firmware, and uploads an SRAM-only loader that reads physical pages without triggering the deferred GC.
Samsung MEX (840 EVO), MGX (850 EVO), and MJX (860 EVO) are the consumer SATA controllers behind Samsung's 8xx EVO line. All three advertise DZAT through Word 69 bit 5. GC on MEX and MGX is among the most aggressive of any SATA controller family we work with: idle-detect kicks in shortly after the last host command, and recovery windows on a powered-on Samsung 840/850/860 EVO drive are tight enough that running consumer recovery software can close the window before a scan completes. PC-3000 Samsung forces the controller into Techno Mode by shorting ROM pins on the PCB, then issues vendor commands to read raw NAND past the FTL. Separately, the Linux libata kernel still blacklists queued TRIM on the Samsung 8xx EVO family today; that blacklist is host-side mitigation for a firmware bug, not a recovery workflow, but it is a useful reminder that this controller family's TRIM pipeline has a documented failure history. The downstream consequence of this controller-by-controller GC timing variance is detailed in our analysis of the garbage collection data loss mechanism.
What Does Each Controller Actually Return on a Read to a TRIMmed LBA?
DZAT zeros, DRAT fixed pattern, or undefined RZAT: which does your controller report?
A drive that advertises DZAT (SATA Word 69 bit 5) or DLFEAT=001b (NVMe Identify Namespace byte 33, bits 2:0) is contractually bound to return a synthetic all-zero payload for deallocated LBAs. A drive that advertises DRAT only (Word 69 bit 14) returns a consistent but non-zero pattern, sometimes 0xFF. A drive with neither bit set is pre-2015 SATA and may return stale data or undefined values across successive reads. The return value tells you what the host sees; it does not tell you what the NAND still holds.
The previous matrix listed garbage collection aggressiveness and PC-3000 entry mode. This section pins down the second axis: what the controller is contractually obligated to put on the SATA or PCIe bus when the host asks for a deallocated LBA, and what physical NAND-side evidence survives between FTL invalidation and the GC erase pulse.
Return-value semantics by controller family
| Controller family | Interface | Return-value semantics | NAND-side residue worth reading | ACELab PC-3000 SSD support |
| Phison E-series NVMe (PS5012-E12, PS5016-E16, PS5018-E18) | NVMe | DLFEAT=001b deterministic zero | Rolling FTL journal in reserved blocks; lazy-GC candidate pool sits hours on lightly used drives | E12 supported via SRAM loader in Safe Mode; E18 limited to board-level revival of the AES-bound controller |
| Silicon Motion SM2262EN / SM2263XT | NVMe | DLFEAT=001b deterministic zero | Multi-generation L2P snapshots in service area; deferred GC preserves OOB sequence stamps past idle | Supported via ROM-pin shorting and SRAM loader injection |
| Marvell 88SS1074 | SATA | DZAT deterministic zero (Word 69 bit 5) | Active background GC trims the window; OEM firmware variants (WD Blue 3D, SanDisk Ultra II) preserve OOB LBA stamps until block reclamation | Supported on mainstream OEM firmware via Safe Mode test points |
| Samsung Phoenix (970 PRO, 970 EVO Plus) | NVMe | DLFEAT=001b deterministic zero | Aggressive idle GC drains candidate blocks within seconds; AES-256 hardware-bound MEK wraps every NAND page | Rossmann does not currently offer in-lab recovery for Samsung Phoenix. |
| Samsung Pablo (PM981, PM9A1 OEM) | NVMe | DLFEAT=001b deterministic zero | Aggressive idle GC; eFuse-bound key encryption key (KEK) fused to controller silicon | Rossmann does not currently offer in-lab recovery for Samsung Pablo. |
| Realtek RTS5762DL / RTS5763 | NVMe | NVMe-standard DLFEAT, typically 001b, not independently verified by ACELab tooling | Vendor-proprietary FTL layout; no published loader to expose OOB metadata | Rossmann does not currently offer in-lab recovery for Realtek RTS5762DL. |
ACELab PC-3000 SSD v3.8.10 does not publish FTL reconstruction or SRAM loaders for modern Samsung in-house architectures (Polaris, Phoenix, Pablo, Elpis, Pascal, Piccolo) or for any Realtek NVMe controller. For drives built on those controllers, no firmware-level path exists to bypass DLFEAT and read raw NAND. The only path that touches user data is board-level revival of the original controller so that its hardware-bound AES-256 key remains paired with the NAND. Chip-off on these families yields ciphertext without the key, which is not a recovery.
What survives between FTL invalidation and the GC erase pulse
The DZAT or DLFEAT zero is fabricated by the controller; it is not read from NAND. Until garbage collection drives +15-20V onto the P-well and erase-verify confirms every cell at the 0xFF threshold, the physical residue stays addressable through a vendor-command bypass. Four signature classes survive that window on supported controllers:
- OOB spare-area LBA stamps and sequence numbers. Each NAND page carries an additional 256-1024 byte out-of-band region holding the logical address it was assigned to and a block-level sequence stamp. PC-3000 SSD reads OOB across every physical page, then uses the sequence stamps to disambiguate stale versus current copies of the same LBA.
- Rolling FTL journal entries in the service area. Phison E12 and Silicon Motion SM2259XT firmware flush historical L2P snapshots to reserved NAND blocks for power-loss survival. Those snapshots predate the TRIM event and can resurrect the pre-deallocation mapping even after DRAM-resident L2P entries are marked invalid.
- LFSR XOR seed and dynamic scrambler state. Data is never written to NAND in plaintext. The controller XOR-scrambles every page against an LFSR polynomial keyed by physical block address. The seed pattern is invariant across TRIM; descrambling only requires the controller-specific polynomial, which PC-3000 SSD applies during raw-NAND read.
- Mid-flight GC compaction artifacts. If a GC cycle is interrupted by power loss or a Safe Mode entry, the relocated valid pages live in two places at once: the source block (not yet erased) and the destination block. Finding duplicate LBA stamps across two distinct PBAs is forensic evidence that the block was in the middle of a compaction pass when the drive halted.
None of these signatures are visible through the SATA or NVMe command set the host OS uses, because every host read goes through the L2P invalidation check that fires the DZAT zero buffer. Reaching the OOB area, the rolling journal, or the in-flight compaction state requires the controller to be in a vendor diagnostic mode where the standard read-completion logic is suspended. That is what PC-3000 SSD Safe Mode and Techno Mode do on supported controller families.
How Does the DZAT ATA Command Protocol Physically Unmap NAND Blocks?
TRIM is not a single command. On SATA drives it is the DATA SET MANAGEMENT command (opcode 0x06) with the TRIM bit set in the feature register. On NVMe it is the Dataset Management command (opcode 0x09) with the Deallocate (AD) attribute. Both carry a payload of LBA ranges that the controller marks as invalid in the Flash Translation Layer. DZAT is the behavior enforced after those ranges are processed: any subsequent read to a deallocated LBA returns a deterministic zero payload sourced from the controller, not from NAND.
The sequence from host delete to physical NAND erase unfolds in four discrete steps, and the data is recoverable at every step except the last:
- Host TRIM/DSM Deallocate issued. The OS sends DATA SET MANAGEMENT (SATA opcode 0x06) or Dataset Management with AD=1 (NVMe opcode 0x09) carrying the LBA range list. The NAND cells still hold the original programmed threshold voltages at this instant.
- FTL marks the LBA range invalid. The controller writes a journal entry, updates the in-DRAM L2P table, and flushes the invalidated mapping to the NAND metadata region. DZAT/DLFEAT enforcement activates immediately; any subsequent host read to that LBA returns a zero payload fabricated by the controller, not fetched from NAND.
- Block enters the GC candidate pool. The physical block backing those LBAs is queued for garbage collection, but no erase voltage has been applied. On Silicon Motion lazy-GC firmware the block can sit in the candidate pool for hours on a lightly used drive; on Samsung Elpis and Pascal firmware the candidate pool is drained within seconds of the drive going idle.
- GC applies the +15-20V erase pulse. Reverse Fowler-Nordheim tunneling drains the charge storage layer across every cell in the block simultaneously. After this step the data is physically destroyed and no lab procedure recovers it. PC-3000 SSD's Safe Mode raw-NAND read path bypasses the DZAT mask at step 2 or 3; once step 4 completes, the cells read 0xFF at the physical level and the window is closed.
SATA DATA SET MANAGEMENT 0x06 with TRIM
The host sends a DATA SET MANAGEMENT command with the TRIM feature bit (bit 0 of the feature field) set. The data transferred is a 512-byte LBA Range Entry block: up to 64 entries per block, each 8 bytes, encoding a 48-bit starting LBA and a 16-bit sector count. The SATA 3.1 specification added Queued TRIM, which uses the SEND FPDMA QUEUED command (opcode 0x64) with a DSM subcommand rather than the non-queued DATA SET MANAGEMENT opcode 0x06, allowing TRIM to execute concurrently with other queued I/O. Word 69 bit 5 of the IDENTIFY DEVICE response advertises DZAT support; bit 14 advertises DRAT. If both bits are zero, the drive predates deterministic post-TRIM behavior, and stale data may be returned on reads to deallocated LBAs.
NVMe Dataset Management 0x09 with Deallocate
The NVMe equivalent is the Dataset Management command (opcode 0x09). The host sets the AD (Attribute - Deallocate) bit in CDW11 and transfers a range list encoded as 16-byte entries (starting LBA, length, context attributes). Post-deallocate read behavior is controlled by the DLFEAT byte (byte offset 33 of the Identify Namespace data structure). Bits 2:0 of DLFEAT define the behavior: 000b means no guarantee on returned values; 001b returns all zeroes (DZAT-equivalent); 010b returns all ones. Every mainstream consumer and enterprise NVMe SSD manufactured after 2019 reports DLFEAT=001b.
Flag Table Zero Return Versus NAND Erase Block Cycle Timing
The DZAT zero return is not produced by reading a NAND page that has been wiped. It is produced by the controller checking a per-LBA invalid bit in the FTL flag table and, on a hit, synthesizing an all-zero buffer in DRAM and returning it to the host. That flag-table lookup completes in microseconds. The host receives a zero payload before the SATA or NVMe completion frame would have had time to round-trip a real NAND page read, which is why software-only recovery tools cannot distinguish a freshly TRIMmed block from a block whose cells have been fully drained: the bytes coming back over the wire look identical because both are fabricated by the controller, not fetched from silicon.
The actual NAND erase block cycle is on a different time scale entirely. The block must be selected by the GC scheduler, the surviving valid pages must be relocated, the charge pump must ramp the +15-20V erase pulse onto the P-well, the pulse must hold long enough for reverse Fowler-Nordheim tunneling to drain the charge storage layer, and an erase-verify pass must confirm every cell read at the 0xFF threshold before the block is returned to the free pool. Foreground GC under host pressure pushes that sequence through quickly; background GC on a lightly loaded drive can defer it. Between the flag-table lookup that fakes the zero return and the verified erase that actually drains the cells, the NAND still carries its original programmed threshold voltages. PC-3000 SSD's Safe Mode reads land inside that gap, which is the entire reason a lab-level solid state drive data recovery workflow can return data that consumer software has already declared gone.
Queued TRIM Bugs and the Survival Window
Queued TRIM implementations have shipped with firmware bugs that extend the recovery window. The Linux kernel's libata subsystem maintains an explicit blacklist (ATA_HORKAGE_NO_NCQ_TRIM) for Samsung 840 Pro, 850 Pro, and 860 Pro drives on older firmware, as well as certain Micron M500/M510/M550 models, because queued TRIM on those drives can corrupt the FTL. On a blacklisted drive, queued TRIMs may be dropped silently or processed out of order, leaving mapped LBAs whose NAND pages still hold the original charge state. PC-3000 SSD's Safe Mode read of physical NAND exposes this residue even though the standard read path still returns DZAT zeroes.
Power-Off Before the Erase Voltage
DZAT masking is a controller-side response, not a NAND-side change. At the moment TRIM is processed, the FTL entry is invalidated and the block is enqueued for garbage collection, but the NAND cells still carry the original programmed threshold voltages. The physical erase happens later, when GC applies +15-20V through the P-well and reverse Fowler-Nordheim tunneling drains the charge layer. If the drive loses power between TRIM invalidation and GC erase, the data survives. Continued power cycles without executing background tasks also accumulate wear that eventually becomes relevant to the NAND degradation failure mode, where retention loss itself becomes the obstacle rather than TRIM.
Over-Provisioned and Retired Blocks
The ATA DATA SET MANAGEMENT protocol operates only on LBAs the host can address. Over-provisioned blocks, spare blocks used for bad-block replacement, and retired blocks fenced by the controller are invisible to TRIM. Stale page copies relocated during wear leveling frequently survive in these controller-managed regions. When board-level repair or in-system PC-3000 access is not feasible, the final path for reading these regions is chip-off NAND recovery, where the NAND packages are desoldered and read on a dedicated hardware programmer. Chip-off yields useful plaintext only on unencrypted controllers; on AES-256 encrypted SSDs the harvested data is ciphertext without the controller-bound key.
For the full diagnostic and pricing path across SATA and NVMe failure modes, see the flagship SSD data recovery service.
Why Does TRIM Leave a Recoverable Window That SANITIZE Does Not?
TRIM is advisory. The ATA/ATAPI Command Set spec (ACS-4, INCITS 529-2018) defines DATA SET MANAGEMENT with the TRIM bit as a hint that lets the controller schedule garbage collection at its own discretion. It makes no promise about when the NAND cells are physically erased, only that subsequent reads to deallocated LBAs will return the deterministic payload specified by RZAT or DRAT. The entire recovery window examined on this page is a direct consequence of that scheduling freedom.
Word 169 bit 0 vs Word 69 bits 5 and 14
ACS-4 splits TRIM-related IDENTIFY DEVICE reporting across two words. Word 169 bit 0 advertises that the device supports DATA SET MANAGEMENT with the TRIM feature set at all. Word 69 bits 5 and 14 describe the post-deallocation read guarantee: RZAT (bit 5) when the controller must return zeroes, DRAT (bit 14) when it must return a deterministic but non-zero pattern. A drive that reports Word 169 bit 0 set but Word 69 bits 5 and 14 cleared still accepts TRIM commands; it simply does not guarantee what a subsequent read will see, which on a few pre-2015 SATA SSDs left stale NAND contents addressable through the standard read path until GC completed.
SANITIZE BLOCK ERASE Guarantees Physical Erasure
The SANITIZE feature set (ACS-3 and later) uses a single opcode, SANITIZE DEVICE (B4h), with the subcommand selected through the ATA Feature register: BLOCK ERASE EXT (feature 12h), CRYPTO SCRAMBLE EXT (feature 11h), and OVERWRITE EXT (feature 14h). Unlike TRIM, SANITIZE BLOCK ERASE EXT is contractually required to apply the NAND erase voltage to every user-addressable and over-provisioned block before reporting completion. The command runs as a long operation, not a queued one, and the device must report progress through SANITIZE STATUS EXT (00h) until erasure finishes. If SANITIZE was issued and completed, physical recovery is gone across the entire NAND array, including OP blocks the host cannot reach. TRIM, by contrast, operates only on host-visible LBAs and never promises physical erase. This is why a customer who ran TRIM may still have recoverable data while a customer who ran SANITIZE BLOCK ERASE does not. CRYPTO SCRAMBLE EXT on a hardware-encrypted drive simply rotates the Media Encryption Key, which renders the existing NAND contents ciphertext-without-key in microseconds.
NVMe Range-Count and Range-Size Ceilings via DMRL and DMRSL
The NVMe Base Specification (rev 2.0) places explicit ceilings on Dataset Management payloads through two fields in the I/O Command Set Specific Identify Controller data structure for the NVM Command Set (CNS 05h). DMRL (Dataset Management Ranges Limit) is the maximum number of 16-byte range entries a single DSM command may carry; DMRSL (Dataset Management Range Size Limit) is the maximum logical block count a single range may describe. When the host needs to deallocate a region larger than DMRSL or wider than DMRL, the operating system splits the operation into multiple DSM commands. Each split increases the number of moments at which a power loss or controller crash can land between range commits, which is why large delete operations on NVMe produce more partial-unmap residue than small ones.
Over-Provisioning Free-Block-Pool GC Trigger Thresholds
The duration of the survival window in the over-provisioned area is governed by the controller's free-block-pool management. A consumer SSD with 7% factory OP maintains a pool of clean erased blocks that the controller refills by compacting and erasing stale blocks during idle time. Firmware defines a low-water mark (the free-block count at which foreground GC begins blocking writes) and a high-water mark (the free-block count at which background GC stops). A TRIMmed block enters the candidate pool immediately, but whether it is erased next depends on its wear count, how many valid pages it still holds, and where the free pool currently sits relative to those thresholds. On a lightly used drive sitting near the high-water mark, a TRIMmed block with a low wear count and few valid pages may remain intact for hours on Silicon Motion SM2258XT or SM2262EN firmware. On a near-full drive approaching the low-water mark, that same block is erased within seconds because foreground GC is actively hunting candidates to keep host writes flowing.
Enterprise SSDs with 28% OP (e.g., 800GB usable from 1024GB raw) extend this window further because the pool of candidate blocks is deeper. Consumer drives with minimal OP (2-7%) have the shortest window because any deallocation is likely to be needed to keep the free pool above the low-water mark. This is why identical deletes on two drives of the same model but different fill levels produce different outcomes when the drive arrives in our lab.
Mid-Unmap FTL Journal Orphaning
A TRIM or DSM Deallocate is not atomic at the NAND level. The controller first writes a journal entry to a reserved metadata region recording the intent to invalidate a set of L2P mappings, then updates the in-DRAM L2P table, then flushes the updated L2P page to NAND, then eventually erases the backing blocks. Power loss or a firmware exception between any two of those steps leaves a specific residue signature. A crash after journal write but before L2P flush leaves the old L2P mapping valid on the next boot; the original NAND pages are still pointed at by valid logical addresses. A crash after L2P flush but before erase leaves the L2P marked invalid but the NAND still programmed. PC-3000 SSD's Safe Mode scans both the current FTL and the journal region, then reads the physical pages those orphaned mappings reference. Queued-TRIM firmware bugs on the blacklisted Samsung and Micron models referenced above are a specific sub-case of this orphaning: the journal records one LBA range, the FTL commits a different range, and the disagreement strands deallocated pages that the host still sees as valid. This is why power loss or a crash mid-unmap is a favorable arrival condition and why running recovery software on a suspect drive can resolve those orphans by triggering a clean journal replay.
Chip-off via a dedicated NAND programmer remains the final option when the controller is dead and no Safe Mode entry is available. Chip-off yields plaintext only on unencrypted controllers; on AES-256 encrypted SSDs the harvested dump is ciphertext without the controller-bound key. SATA chip-off recovery runs $1,200–$1,500; NVMe chip-off runs $1,200–$2,500. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
PC-3000 SSD: Safe Mode Entry and Techno Mode Workflow
PC-3000 SSD reads past DZAT and DLFEAT by forcing the controller into a diagnostic state where all standard processing halts. The entry method varies by controller family: shorting diagnostic test points on the PCB, issuing vendor-specific command sequences, or triggering a controlled firmware exception. Once in diagnostic mode, the controller stops processing TRIM, garbage collection, wear leveling, and standard read/write operations.
Safe Mode for Phison, Silicon Motion, and Marvell
For Phison and Silicon Motion controllers, PC-3000 SSD enters Safe Mode by shorting specific test points on the SSD's PCB during power-on. This forces the controller to boot with minimal firmware, halting all background processes. The PC-3000 Phison utility or SM utility then uploads a custom microcode loader to the controller's SRAM. This loader reads Physical Block Addresses (PBAs) directly from the NAND array, bypassing the FTL's logical-to-physical translation and the DZAT zero-return mask.
Techno Mode for Samsung
Older Samsung SATA controllers (e.g., MGX and MHX on the 840/850 EVO and Pro lines, MJX on the 860 EVO and Pro) enter Techno Mode through vendor-specific command sequences rather than test point shorting. PC-3000 SSD's Samsung utility issues these commands to halt GC, wear leveling, and DZAT enforcement. In Techno Mode, the utility reads the FTL mapping tables from the controller's DRAM or NAND-backed metadata area, maps logical addresses to physical NAND coordinates, and reads raw pages at those locations. If the cells still hold charge, the data is recoverable regardless of what the standard SATA interface reports.
Modern Samsung NVMe controllers (Elpis in the 980 Pro, Pascal in the 990 Pro, Piccolo in the 990 EVO) have no PC-3000 Techno Mode or firmware-level loader support. ACELAB does not publish microcode loaders or L2P reconstruction workflows for these architectures, so there is no software path to bypass DLFEAT on these drives. Recovery is strictly board-level: reviving a failed PMIC or voltage regulator using FLIR thermal fault localization and Hakko FM-2032 component replacement, then reading the drive through the revived original controller with its hardware-bound AES-256 key intact.
FTL Reconstruction
When the FTL mapping table itself is corrupted (common after sudden power loss or firmware crashes), PC-3000 SSD rebuilds the logical-to-physical map from NAND metadata pages. The utility scans every physical block, reads the page headers and ECC data, and reconstructs which logical address each page belongs to. This is the firmware recovery tier (SATA: $600–$900, NVMe: $900–$1,200) and represents a software-level lab procedure that consumer tools can't perform because they have no access to the controller's vendor command interface.
Why Board Repair Is Data Recovery for Encrypted SSDs
Many modern SSDs encrypt data automatically using AES-256 hardware encryption, though budget and mid-range drives (WD SN770, Crucial P3, older Phison PS3111-S11 designs) omit this feature. On encrypted drives, the Media Encryption Key is bound to the controller hardware. If the controller dies, the NAND chips contain only ciphertext. Desoldering the NAND and reading it on another controller (chip-off) yields encrypted data with no key. Board-level repair to revive the original controller is the only recovery path for encrypted SSDs.
NVMe SSDs implementing TCG Opal or IEEE 1667 bind the AES-256 key material to the controller's hardware fuses. A dead Phison PS5012-E12 on a Sabrent Rocket means the NAND contents are unreadable without the original controller's key. A dead Samsung Elpis on a 980 Pro means the same thing. Chip-off on an encrypted NVMe drive is not a recovery option; it's an expensive way to get a dump of ciphertext.
Most data recovery labs outsource board-level failures or declare them unrecoverable. We locate the failed component using FLIR thermal imaging, replace the shorted PMIC or voltage regulator with a Hakko FM-2032 on an FM-203 base station, and bring the original controller back to life. When the controller boots, the encryption keys are intact and the data is accessible. Board repair isn't a separate service from data recovery; for encrypted SSDs, it is the recovery. Circuit board repair runs $450–$600 for SATA SSDs, $600–$900 for NVMe.
How Does Wear Leveling Affect Data Persistence?
Wear leveling distributes writes across all NAND blocks to prevent any single block from wearing out prematurely. The controller tracks P/E cycle counts per block and periodically relocates data from low-wear blocks to high-wear blocks. This relocation creates stale copies of data in the old block locations, which persist until garbage collection erases them.
These stale copies are a secondary recovery target. When the primary copy of a file has been TRIMmed and GC-erased, an older version may still exist in a block that wear leveling has not yet reclaimed. PC-3000 SSD's Techno Mode reads every physical block on the drive, including blocks not mapped in the current FTL. Finding these remnant copies requires scanning the entire NAND array (a 1TB SSD contains roughly 8,192 to 16,384 erase blocks) and correlating page metadata with file system structures.
Over-provisioned space works similarly. A 1TB SSD with 7% over-provisioning reserves roughly 70GB of NAND for controller-managed operations. This space isn't visible to the OS and isn't targeted by TRIM. Stale data pages relocated during GC and wear leveling may persist in OP blocks. Retired bad blocks also contain unmapped remnant data accessible only through PC-3000 SSD's physical-level read functions, or through chip-off NAND recovery on unencrypted controllers.
How Does Wear Leveling Leave Recoverable Copies That DZAT Hides?
How does wear leveling interact with TRIM and the DZAT zero-read mask?
Standard TRIM is a logical deallocate command (ATA DATA SET MANAGEMENT 0x06 or NVMe Dataset Management 0x09) that marks the host-visible FTL mapping invalid; it erases no NAND. DZAT (SATA Word 69 bit 5 or NVMe DLFEAT=001b) is a separate firmware read-path rule that synthesizes an all-zero buffer for reads to a TRIMmed LBA. TRIM severs the logical map, DZAT enforces the zero-read illusion, and garbage collection is the only step that drains the cells. Wear leveling, meanwhile, scatters multiple physical copies of one LBA across NAND, and DZAT masks every one of them at once.
Wear leveling is the reason a single deleted file can leave several physical copies in NAND while the host read path shows nothing but zeros. The controller runs two distinct strategies, and each one programs a fresh physical page before it marks the old block for erase. That ordering is what creates the transient duplicate copies a lab can read on supported controllers.
Dynamic vs static wear leveling
Dynamic wear leveling steers each new host write to the least-worn block in the currently-active free pool. It only touches blocks the controller is already writing to, so cold data that never gets rewritten can sit on the same low-wear block for the life of the drive. That uneven wear is the problem static wear leveling exists to fix.
Static wear leveling proactively relocates cold, static data off low-wear blocks onto higher-wear blocks to even out the P/E count across the array. The relocation itself is the recovery-relevant event: the controller programs the destination physical page first, updates the L2P map to point at the new page, and only then marks the source block for erase. For a window measured in seconds to hours depending on firmware, both the source page and the destination page hold the same logical block. One LBA, two live physical copies.
Why DZAT masks every physical copy at once
DZAT operates at the FTL read-path layer, keyed on the logical address, not on any physical page. When an LBA is TRIMmed, every host read of that LBA returns the synthesized zero buffer regardless of how many stale relocated copies still hold the original charge in NAND. The host-visible read shows zeros across the board.
The raw NAND still holds each relocated copy until garbage collection selects those blocks and applies the +15-20V erase pulse. A copy that wear leveling moved minutes ago and a copy the OS deleted yesterday look identical from the host side: both are masked, neither is erased.
Reading the surviving copy past the mask with PC-3000 SSD
On supported controllers, PC-3000 SSD's Safe Mode or Techno Mode reads the raw NAND below the FTL, so the access path never consults the DZAT mask and instead returns the conflicting physical copies as they sit in silicon. The lab then reads each page's out-of-band (OOB) spare-area metadata, which stores that page's logical address and a block-level sequence stamp, and uses those stamps to tell the most-recent copy from the stale relocated copies and rebuild the correct FTL state.
This raw-NAND path is available on Phison (PS3111-S11, PS5012-E12), Silicon Motion (SM2258XT, SM2259XT, SM2262EN, SM2263XT), Marvell 88SS1074, and the older Samsung SATA families (S3C29, S4LJ, S4LN) that ACELab's PC-3000 SSD list covers. It is not available on modern Samsung in-house NVMe controllers, Realtek, Innogrit, Maxio MAP1602, SK Hynix, or WD/SanDisk in-house controllers; for those, no firmware-level raw-NAND read path exists and the only path to user data is board-level revival of the original controller.
Rossmann does not currently offer in-lab recovery for modern Samsung in-house NVMe controllers (Elpis, Pascal, Phoenix, Piccolo, Polaris), Realtek, Innogrit, Maxio MAP1602, SK Hynix, or WD/SanDisk in-house controllers via raw-NAND read. The OOB spare area carries a logical address and a sequence stamp, but its exact byte layout is controller-specific and is not published in a single public datasheet.
The practical takeaway is the same one that governs every TRIM case: power the drive off so garbage collection can't drain the relocated copies, then ship it to our Austin, TX lab. Each powered-on idle minute is another chance for the scheduler to erase the source block out from under the surviving copy. SATA evaluation starts at From $200, NVMe at From $200, and the raw-NAND read runs as part of our SSD data recovery service. If GC has already erase-verified the blocks, we say so and return the drive at no charge.
Why a 4KB Delete Erases a 4MB Block: NAND Granularity and the Read-Modify-Erase Cycle
The host operating system speaks in 4KB logical block addresses. The NAND die only erases in multi-megabyte blocks. A single TRIM for one 4KB LBA can eventually consume the program/erase budget of an entire erase block, because the controller cannot erase a single page in isolation. This granularity mismatch is the physical reason your data gets destroyed even though you only asked the drive to forget about one file.
The granularity stack: host LBA, NAND page, NAND erase block
| Layer | Unit size | What the controller can do at this size |
| Host LBA (Advanced Format 4Kn / 512e emulating 4K) | 4 KB | Read, write, or TRIM at this address. This is the only granularity the OS, the file system, and consumer recovery software ever see. |
| NAND page (Micron B47R / B58R, Samsung V7 / V8, Kioxia BiCS5 / BiCS8, YMTC X3-9070) | 16 KB on modern TLC and QLC dies | Program (one-shot) and read. Programming flips selected cells from the erased state toward target threshold voltages; it cannot push a cell back toward erase. |
| NAND erase block (pages-per-block * page size) | Roughly 4 MB to 64 MB; 1,024 to 4,248 pages per block on current TLC/QLC dies | Erase only. Erase is the only operation that resets cells toward 0xFF, and it cannot be applied to anything smaller than a full block. |
The ratio between the host's 4KB write unit and the NAND's 4MB to 64MB erase unit is roughly 1,000:1 to 16,000:1. Every TRIM the OS sends is a request to forget a unit that's three to four orders of magnitude smaller than what the NAND can actually erase. The controller absorbs that mismatch through garbage collection. That absorption is the read-modify-erase cycle.
NVMe Base Specification 1.4 / 1.4c: Identify Namespace, byte 33 (DLFEAT)
The bit-by-bit definition of post-deallocate read behavior on an NVMe SSD lives in one byte. Identify Namespace data structure (CNS 00h), byte offset 33, named “Deallocate Logical Block Features”:
- Bits 7:5 - Reserved
- Must be reported as zero by compliant controllers. Reserved for future revisions of the spec.
- Bit 4 - Guard CRC behavior on read of a deallocated block
- 1 = the Guard field is set to the CRC of the deallocated read value (the synthesized 00h or FFh payload). 0 = the Guard field is set to FFFFh (the Guard field is a 16-bit CRC, so the default all-ones value is two bytes wide). End-to-end data protection still computes a valid CRC across the synthetic payload, so the host never sees a metadata mismatch on a deallocated read.
- Bit 3 - Write Zeroes Deallocate Support
- 1 = the controller honors the Deallocate bit inside the Write Zeroes opcode (08h) for this namespace, meaning a Write Zeroes can be promoted into a deallocate that frees NAND in addition to returning zeros on subsequent reads.
- Bits 2:0 - Deallocate value behavior
- 000b - unspecified. Controller may return stale data, 00h, FFh, or any vendor pattern. Common on early NVMe drives and on some enterprise namespaces.
001b - controller shall return all 00h. This is the NVMe analogue of SATA DZAT.
010b - controller shall return all FFh.
011b through 111b - reserved.
SATA ACS-4 (INCITS 529-2018): IDENTIFY DEVICE response, words 69 and 169
The SATA equivalent is split across two 16-bit words in the IDENTIFY DEVICE response (opcode ECh, 512-byte / 256-word payload):
- Word 169, bit 0 - DATA SET MANAGEMENT TRIM supported
- 1 = the drive accepts the DSM TRIM command (opcode 06h with the TRIM bit set). This bit only declares that TRIM is supported; it says nothing about what a subsequent read of a TRIMmed LBA will return.
- Word 69, bit 14 - DRAT (Deterministic Read After TRIM)
- 1 = reads of a TRIMmed LBA return a consistent vendor-chosen pattern. The pattern isn't required to be zero; it just has to be the same byte sequence every time.
- Word 69, bit 5 - RZAT / DZAT (Deterministic Read Zero After TRIM)
- 1 = reads of a TRIMmed LBA return all 00h bytes. This is the SATA companion to NVMe DLFEAT = 001b and is what most SATA SSDs manufactured after 2015 report.
- Word 69 bit 5 = 0 and bit 14 = 0, Word 169 bit 0 = 1
- The drive supports TRIM but makes no guarantee about post-TRIM read content. Reads may return stale data, garbage, or whatever the controller's read path produces in the absence of a valid L2P entry. Common on pre-2015 SATA SSDs. This is the configuration most favorable to host-side software reads, but it still does not prevent the controller from eventually erasing the block.
The read-modify-erase cycle: what happens when you TRIM 4KB inside a 4MB block
When the host issues a TRIM for a single 4KB LBA, and that LBA maps into a 4MB erase block that still holds other live pages, the controller cannot erase that one page in isolation. Erase is a block-level operation in NAND. The eventual garbage collection pass that reclaims this block runs an ordered sequence:
- Identify the source block as a GC candidate based on its valid-page count and write age.
- Read every still-valid page in the source block into the controller's SRAM buffer.
- Write those valid pages into a fresh erase block, generating new page metadata and a new write timestamp.
- Update the L2P map so the affected LBAs now point at the new physical addresses.
- Drive the +15V to +20V Fowler-Nordheim pulse onto the P-well of the source block, which evicts electrons from every floating gate in every page of that block toward the erased threshold.
- Run erase-verify, comparing every cell against the 0xFF reference threshold; reissue the pulse on any cell that has not relaxed past the verify level.
- Return the now-erased block to the free pool for the next host write.
This is what consumes the program/erase budget of the entire block from a single 4KB host TRIM, and it is what guarantees that the LBA's original physical contents are destroyed once GC selects the block. There is no way for the controller to honor the TRIM more cheaply, because the NAND die does not implement page-level erase.
What this means for theoretical recoverability
Whether the drive reports DZAT, DRAT, or no determinism at all changes only what the controller's read path synthesizes for a TRIMmed LBA. It does not change whether GC eventually erases the block. The read-modify-erase cycle runs on the controller's idle schedule regardless of which determinism bit is set. A non-DZAT drive buys a slightly longer pre-erase window during which a host-side tool that bypasses the L2P map can still see the underlying NAND contents; it does not buy a permanent recovery path.
The only durable way to preserve TRIMmed data is to prevent the controller from running GC at all. That requires one of: a USB bridge that strips UNMAP / Data-Set-Management TRIM before it reaches the drive, TRIM disabled at the OS layer before the deletion (Windows fsutil behavior set DisableDeleteNotify 1, macOS sudo trimforce disable, Linux mount with the discard option absent and no periodic fstrim timer), or a controller crash that halts the GC scheduler. In every other case, the recovery path is PC-3000 SSD Safe Mode or Technological Mode reading physical block addresses before the next GC pass, on the controllers documented in our internal support matrix (Phison, Silicon Motion, Marvell, older Samsung S3C29 / S4LJ / S4LN, OCZ Barefoot 3, Intel; modern Samsung Polaris / Phoenix / Elpis / MEX / MGX, Realtek, Innogrit, and Maxio MAP1602 / MAP1602A are not currently in-lab serviceable). Pricing for SSD data recovery starts at From $200 for SATA and From $200 for NVMe, with the firmware-recovery tier where Safe / Techno Mode work lives priced at $600–$900 (SATA) and $900–$1,200 (NVMe).
Data Remanence on Erased NAND: Academic vs. Commercial Reality
Academic research has measured approximately 0.5V threshold voltage variance between NAND cells that were erased after storing data and cells that were never programmed. This variance is a measurable physical artifact of the programming and erasure process. It is not commercially recoverable. No data recovery lab, including ours, can extract usable data from this residual voltage difference using SSD controllers or PC-3000 SSD.
The 0.5V variance is detectable with semiconductor characterization equipment (probe stations, source-measure units) operated at the die level. This equipment costs six figures, operates on decapped NAND dies, and produces raw analog measurements that require statistical analysis to interpret. The distinction between “erased after storing a 1” and “erased after storing a 0” is a probability distribution, not a clean binary signal.
For TLC and QLC NAND with 8 or 16 voltage levels respectively, the margins between legitimate states are already tight (as narrow as 200mV for QLC). A 0.5V residual variance doesn't provide enough signal-to-noise ratio to reconstruct multi-bit cell states with any confidence. If a company claims they can recover data from physically erased NAND cells, they are either describing a different failure scenario (GC interrupted before completing) or describing a capability that doesn't exist commercially.
Does a Write Blocker Prevent SSD Garbage Collection?
No. A forensic write blocker prevents the host computer from sending write commands to the SSD, but garbage collection is an internal controller process. The controller runs GC, wear leveling, and read refresh operations autonomously whenever the drive is powered on, regardless of whether any host commands are issued. Powering on an SSD behind a write blocker still allows the controller to erase TRIMmed blocks.
This is a common misunderstanding in digital forensics. Write blockers were designed for magnetic hard drives where the storage medium (the platter) is passive. On an HDD, if you block writes, the data stays static. On an SSD, the storage controller is an active processor that modifies the NAND independently. The only way to freeze all controller operations is to force the controller into a diagnostic state using PC-3000 SSD, where TRIM processing, GC, and wear leveling all halt.
The safest approach: don't power the SSD at all after data loss. Keep it unpowered and ship it to a lab. We apply power for the first time inside PC-3000 SSD's controlled environment, entering Safe Mode or Techno Mode before the controller can resume background operations. This preserves the NAND state as of the moment you powered off the drive.
DZAT and NAND Physics FAQ
Can data be recovered from an SSD after TRIM?
What does DZAT mean for SSD data recovery?
What is the difference between DZAT and DRAT?
Does a write blocker prevent SSD garbage collection?
How does PC-3000 SSD read past DZAT?
How long after deletion does garbage collection erase data?
Does data remanence exist on erased NAND cells?
Can over-provisioned space contain recoverable data?
Can data be recovered after TRIM has fired but before garbage collection runs?
Why is logical-layer imaging useless on TRIMmed LBAs once DZAT is active?
Does wear leveling leave recoverable copies of deleted files?
Overview of the TRIM-to-GC pipeline, controller-specific timing, and when the recovery window is still open.
The recovery window between TRIM and garbage collection. How to disable TRIM, and when professional recovery is still possible.
SATAFIRM S11, 0GB capacity, BSY state. When the controller firmware crashes, GC stops and TRIMmed data may survive on the NAND.
Full SSD data recovery service. SATA from From $200, NVMe from From $200. Free evaluation, no data = no fee.
SSD Data Deleted? TRIM Doesn't Always Mean Gone.
DZAT hides data from software, but the NAND cells may still hold your files. Power off the drive and ship it to our Austin lab. We check the raw NAND state for free using PC-3000 SSD. SATA recovery starts at $200; NVMe starts at $200. No data, no charge.
