How SSD Controller Encryption Works
Published March 8, 2026
Updated April 14, 2026
Most modern SSD controllers encrypt all data before writing it to NAND flash. This encryption happens transparently: the host sends plaintext data over the SATA or NVMe interface, the controller's hardware AES engine encrypts it in-line, and only ciphertext reaches the NAND cells. On read, the controller decrypts the data before sending it back to the host. The encryption key is generated during drive initialization and stored in the controller or a dedicated secure element, not on the NAND itself. This architecture is why professional SSD data recovery requires controller-level repair rather than simple NAND reading.
Always-On AES Encryption in Modern Controllers
Controllers from Samsung, Phison, Silicon Motion, and Marvell implement AES-256 or AES-128 encryption in hardware. On many controllers, this encryption is always active, even when the user has not set a drive password. The controller generates a random media encryption key (MEK) during the drive's first initialization and uses it for all subsequent writes.
The purpose of always-on encryption is not necessarily security for the user. It enables instant secure erase: instead of overwriting every NAND cell (which is slow and accelerates wear), the controller can "erase" the drive by discarding the MEK and generating a new one. All data on the NAND becomes permanently unreadable ciphertext because the decryption key no longer exists.
For user-facing encryption (self-encrypting drives, or SEDs), the MEK is itself encrypted with a key encryption key (KEK) derived from the user's password. Setting a drive password wraps the MEK with the KEK. Clearing the password unwraps it. The NAND data stays encrypted with the same MEK throughout; only the access control changes.
Key Storage and the Role of the Controller
Where the MEK is stored depends on the controller architecture:
Controller internal storage
Many SATA SSD controllers store the MEK in a protected region of their internal flash or OTP (one-time programmable) memory. The key is tied to the specific controller silicon. Replacing the controller chip means losing access to the MEK.
NAND reserved area
Some controllers store a wrapped (encrypted) copy of the MEK in a reserved NAND block. The unwrapping key is derived from the controller's silicon-specific ID. This allows the controller to reload the MEK after a power cycle but prevents a different controller from using it.
External secure element
Enterprise SSDs and Apple's T2/M-series designs use a dedicated secure element (separate chip or secure enclave within the SoC) to store the encryption key. The key never leaves the secure element; encryption and decryption operations are performed within it.
Apple T2/M-Series Secure Enclave Key Binding
Apple Macs with T2 security chips (2018-2020 Intel Macs) and M-series chips (M1, M2, M3, M4) use a different encryption architecture than standard SSDs. The volume encryption key is generated and stored in the Secure Enclave, a hardware-isolated processor within the T2 or M-series SoC. The key is derived from the user's password (or Touch ID biometric on supported models) and a hardware-unique identifier (UID) fused into the Secure Enclave silicon during manufacturing.
This binds the encryption key to the specific T2 or M-series chip. It cannot be read, extracted, or transferred. If the SSD controller fails but the T2/M-series chip is functional, board-level repair to restore the SSD controller's operation allows the Secure Enclave to decrypt the data normally. If the T2/M-series chip itself is damaged or destroyed, the encryption key is permanently lost and the data is unrecoverable regardless of the NAND state.
Chip-off NAND reads yield ciphertext on encrypted drives.
Desoldering the NAND chips and reading them directly with a programmer produces encrypted data. Without the controller's MEK (or the Secure Enclave key on Apple devices), this data cannot be decrypted. Chip-off recovery is not a viable technique forhardware-encrypted SSDs unless the controller itself can be made functional again to perform the decryption.
Encryption Behavior by Controller Manufacturer
ControllerEncryption DefaultRecovery Implication
Samsung (Elpis, the 970-series controller, and others)AES-256 always-onNAND reads require the original controller. Controller swap loses the MEK.
Phison (PS3111, E12, E18)Data scrambling always-on; AES optionalOlder Phison SATA controllers use scrambling without AES. PC-3000 can de-scramble. Newer NVMe models use AES.
Silicon Motion (SM2258, SM2259, SM2262)Hardware AES-256 supported; activation varies by OEM (many SATA variants use XOR scrambling only)If AES is active, MEK is tied to controller. If only XOR scrambling, PC-3000 SSD can reverse the scrambling polynomial & extract data through the controller's diagnostic path.
Marvell (88SS1074, 88SS1084)AES-256 always-onSimilar to Samsung: controller replacement without key transfer renders data unreadable.
Apple T2/M-seriesAES-256 via Secure EnclaveKey bound to silicon. Board repair is the only recovery path if the SSD controller fails.
How Do TCG Opal, eDrive, and Vendor-Specific Encryption Compare?
Three self-encrypting drive (SED) standards control how SSDs manage hardware encryption: TCG Opal 2.0, Microsoft eDrive (IEEE 1667), & vendor-specific implementations like Samsung Class 0. Each standard handles key management, pre-boot authentication, & recovery differently. Understanding which standard your drive uses determines the recovery path when the controller fails.
TCG Opal 2.0
TCG Opal 2.0 is the industry standard for self-encrypting drives. The controller performs AES-256 encryption in hardware, offloading the CPU entirely. A Shadow MBR provides pre-boot authentication: the system boots into a minimal environment stored on the drive, the user enters credentials, & the controller unlocks the specified locking range. Each locking range maps to an LBA range on the NAND, allowing independent encryption zones on a single drive.
Recovery from a dead Opal drive requires the original controller to be operational. The MEK is bound to that controller's silicon. Board-level repair (PMIC replacement, capacitor swap) using a Hakko FM-2032 is the first step. Once the controller boots, PC-3000 SSD can enter diagnostic mode & extract data while the AES engine decrypts on-the-fly. SATA SSD board repair runs $450–$600; NVMe runs $900–$1,200.
eDrive IEEE 1667
eDrive is Microsoft's protocol for delegating BitLocker encryption to the SSD's Opal hardware. Instead of Windows performing software AES encryption on data before writing it, the OS tells the Opal-compliant controller to handle encryption at the hardware level. The result: faster writes, lower CPU usage, & no performance penalty from encryption.
The trap is invisible to most users. Windows shows BitLocker as "active," but the SSD controller is doing the actual encryption. If the controller dies, the BitLocker recovery key alone can't decrypt raw NAND reads. The recovery key authenticates a session with the Opal controller; without the controller, there's no session to authenticate. Recovery requires reviving the original controller first, then using the BitLocker recovery key to unlock the Opal session.
Samsung Class 0 Vendor-Specific Encryption
Samsung's Class 0 encryption is always-on from the factory. The controller generates a DEK during manufacturing & encrypts all NAND writes with AES-256. Setting an ATA password wraps the DEK with a key derived from the password. Without an ATA password, the encryption is transparent: the controller encrypts & decrypts automatically, & the user never interacts with it.
Class 0 isn't as structured as TCG Opal. There are no locking ranges, no Shadow MBR, & no standardized pre-boot authentication. But the recovery implication is identical: chip-off on a Class 0 Samsung drive yields ciphertext. The original Samsung controller must be functional to decrypt the data.
StandardKey ManagementPre-Boot AuthRecovery Complexity
TCG Opal 2.0MEK generated on-chip; KEK wraps MEK; user credential unlocks KEKShadow MBR with per-range lockingBoard repair to revive controller, then PC-3000 SSD extraction with hardware AES decryption
eDrive (IEEE 1667)BitLocker delegates to Opal hardware; recovery key authenticates the Opal session, not the NAND directlyWindows BitLocker pre-boot via Opal Shadow MBRBoard repair first, then BitLocker recovery key to unlock the Opal session; two-step recovery
Samsung Class 0Factory DEK; ATA password wraps DEK; no KEK hierarchyATA password only (no Shadow MBR)Original controller must boot; ATA password required if set; chip-off yields ciphertext
How Does the AES-256 Key Hierarchy Work Inside an SSD?
Self-encrypting SSDs use a three-layer key hierarchy: a Data Encryption Key (DEK) that encrypts the NAND, a Key Encryption Key (KEK) that wraps the DEK, & an Authentication Key (AK) derived from the user's credential. This hierarchy allows password changes without re-encrypting the entire drive. Only the KEK is re-wrapped; the DEK & NAND data stay untouched.
Data Encryption Key (DEK / Media Encryption Key)
The symmetric AES-256 key that encrypts every byte written to NAND. The controller generates this key during drive initialization using an on-chip hardware random number generator. The DEK never leaves the drive. It's stored in the controller's OTP memory or in a wrapped form in the NAND reserved area. If the DEK is lost or destroyed, every block on the NAND becomes permanent ciphertext.
Wraps the DEK so it's never stored in plaintext at rest. The KEK is derived from the user's authentication credential combined with a hardware-unique identifier on the controller. When the user changes their password, the controller re-wraps the DEK with a new KEK derived from the new credential. The NAND data doesn't change. No re-encryption is needed. A password change on a 2 TB SSD takes milliseconds, not the hours a full re-encryption would require.
Derived from the user's credential: an ATA password, a BitLocker PIN, a TPM-stored key, or biometric data on supported platforms. The AK unlocks the KEK, which unwraps the DEK, which decrypts the NAND. If the user forgets the credential & has no recovery key backed up to Microsoft Entra ID, Active Directory, or a USB .bek file, the data is inaccessible even with a fully functional controller. The lab can't bypass the authentication layer.
This hierarchy is why encrypted drive recovery is a two-part problem. Part one: revive the controller so the AES engine is operational. Part two: provide the authentication credential so the key chain unlocks. A lab handles part one through board-level repair. Part two requires the customer to have their password, recovery key, or TPM binding. Without both parts, the data stays encrypted.
How Is Data Recovered from a Dead SSD with Intact Encryption Keys?
When an SSD controller dies but the NAND & encryption keys are intact, recovery requires reviving the original controller through component-level microsoldering, then using PC-3000 SSD to extract data through the controller's diagnostic interface. The controller's AES engine decrypts data on-the-fly during extraction. Replacing the controller chip loses the encryption keys; repairing the original one preserves them.
Board-Level Fault Localization
The first step is finding what killed the controller. A FLIR thermal camera identifies shorted components by their heat signature: a failed PMIC pulling excess current shows as a hot spot on the thermal image within seconds of applying power. The technician then replaces the specific component (voltage regulator, capacitor, inductor) using a Hakko FM-2032 microsoldering iron on an FM-203 base station. The goal is to bring the original controller back to a state where it can initialize & respond to commands.
PC-3000 SSD Recovery Procedure
Once the controller responds, PC-3000 SSD connects through the controller's diagnostic interface. The procedure for encrypted drives with firmware corruption follows a specific sequence:
  1. Force safe mode / technological mode entry by shorting specific test points on the PCB. This bypasses the corrupted firmware boot sequence & loads the controller into a minimal diagnostic state.
  2. Inject a volatile loader (LDR) into the controller's RAM. This microcode provides PC-3000 with read/write access to the NAND through the controller, without relying on the corrupted on-chip firmware.
  3. Read the NAND reserved area to locate firmware modules, the Flash Translation Layer (FTL) tables, & the wrapped MEK. The reserved area is the controller's internal bookkeeping zone on the NAND.
  4. Reconstruct the Virtual Translator in RAM on the drive itself. PC-3000 reads the raw NAND blocks & rebuilds the logical-to-physical block mapping that the FTL normally maintains. This step can take hours on high-capacity drives with fragmented FTL tables.
  5. Extract data sector-by-sector through the controller's AES engine. The controller decrypts each sector as PC-3000 reads it. The output is plaintext user data, written to a target drive.
This entire procedure depends on the original controller being alive. A replacement controller won't have the MEK. A different controller from the same model won't have the same hardware fuses. Board repair isn't a separate service from SSD data recovery; for encrypted drives, board repair IS the data recovery. SATA SSD board repair runs $450–$600. NVMe board repair runs $900–$1,200. Firmware-level recovery (loader injection & FTL reconstruction) runs $600–$1,200 for SATA or $900–$1,200 for NVMe.
How Do PC-3000 SSD Extraction Procedures Differ by Controller Family?
The generic recovery procedure above applies broadly, but each controller family requires a different diagnostic entry method, microcode loader, & FTL reconstruction approach. Modern Samsung NVMe controllers are controller-bound, so recovery depends on board-level repair of the original controller rather than a loader-based logical dump. Silicon Motion controllers require a permanent test-point short & volatile loader injection. Phison controllers vary by generation: budget SATA models use XOR scrambling without AES, while NVMe models use hardware AES-256 encryption.
Samsung Elpis and Piccolo: Controller-Bound Recovery
Samsung SSDs use always-on AES-256 encryption with the MEK generated on and bound to the original controller silicon during factory initialization. The controller maintains multiple copies of its firmware table architecture across the NAND. A power loss during an FTL cascade write can corrupt all copies simultaneously, leaving the drive in one of several panic states: 0GB reported capacity, a complete drop off the PCIe bus, or a stuck read-only state that rejects all write commands.
For the modern Samsung Elpis and Piccolo NVMe controllers and the in-house controller in the 990 Pro, PC-3000 does not have a working technological-mode (loader-in-RAM) logical extraction path. There is no Factory/Technological-Mode logical dump for these controllers, so recovery depends on keeping the original controller alive rather than injecting a loader or streaming a logical image through a factory command interface.
Board-level repair of the original controller is the recovery path. The MEK is hardware-bound, so the original controller must be alive. A FLIR thermal camera localizes the failed component; a Hakko FM-2032 on an FM-203 base station replaces the shorted PMIC or voltage regulator. Recovery of these drives relies on restoring the original controller board, which is what allows the drive's intact AES-256 pipeline to read the NAND. NVMe board repair runs $900–$1,200.
Silicon Motion SM2258, SM2259, and SM2262: Volatile Loader Injection
Silicon Motion controllers implement AES-256 with optional TCG Opal support & NANDXtend ECC, which combines LDPC hard/soft decoding with RAID-like page parity for error correction. FTL corruption from a power loss during garbage collection causes either a BSY (Busy) hang on the ATA interface or a ROM Mode state where the drive reports 1GB or 0GB capacity. Both states mean the controller's firmware can't build a valid FTL from the NAND contents.
Recovery starts with a permanent Safe Mode pin short: the technician holds the ROM signature pins shorted while applying power, forcing the controller to ignore corrupted NAND firmware entirely. PC-3000's Silicon Motion utility then uploads a volatile loader (LDR) to the controller's RAM. The LDR must match the exact controller & NAND combination. An SM2258XT paired with SanDisk 64L BiCS3 TLC NAND requires a different loader than the same controller paired with Micron B0KB QLC NAND. Loading the wrong LDR produces ECC failures & no readable data.
PC-3000 builds the virtual FTL translator entirely in RAM on the drive itself, using block sequence numbers & page headers extracted from the NAND. AES decryption happens transparently through the original controller executing the LDR. SATA SSD board repair runs $450–$600; firmware-level FTL reconstruction runs $600–$1,200.
Phison PS3111, PS5012, and E18: Generational Encryption Variance
Phison's controller lineup spans a wider encryption range than any other manufacturer. The PS3111-S11 (budget SATA, DRAM-less) does not use AES-256; it applies XOR scrambling only. PC-3000 can reverse the XOR scrambling polynomial & extract data from these drives even with a dead controller through chip-off, because the "encryption" is a reversible mathematical transform, not a cryptographic cipher.
The PS5012-E12 (NVMe) supports hardware AES-256 encryption and cryptographically signed firmware; unsigned modifications are rejected. The PS5018-E18 implements hardware AES-256 encryption; when it is enabled, chip-off on an E18 drive yields only ciphertext.
SATAFIRM S11 Firmware Failure on Phison PS3111
When the PS3111's DRAM-less FTL (stored directly in TLC NAND) corrupts due to NAND cell degradation, the controller drops to its BootROM & reports the factory identity string "SATAFIRM S11" with 0GB capacity in BIOS. The drive rejects all standard ATA read/write commands. Data is still present on the NAND chips, but the controller can't build a valid FTL to access it.
Recovery requires forcing the controller into Safe Mode with a pin short during power-up. PC-3000's Phison utility injects a volatile loader to the controller's RAM, then scans surviving NAND page headers to reconstruct the primary & backup copies of the Flash Translation Layer (FTL). A controller-specific complication: corrupted internal log tables can stall FTL reconstruction, and PC-3000 may need to clear or bypass them before extraction proceeds. SATA SSD firmware recovery runs $600–$1,200.
Do not use PhisonToolBox or MPTools firmware flashers from internet forums.
Flashing new firmware over a SATAFIRM S11 drive overwrites the remaining FTL fragments in the NAND Service Area. This performs a de facto secure erase of the FTL metadata that PC-3000 needs to reconstruct the logical-to-physical block mapping. After a firmware flash, the data is still on the NAND cells, but the map to find it is gone. Recovery becomes a NAND chip-off with raw page reconstruction, running $1,200–$1,500 plus donor costs. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
What Happens When Someone Executes a PSID Revert?
A PSID (Physical Security ID) revert destroys all data on a self-encrypting drive. The operation deletes the existing DEK & generates a new one. Every byte of ciphertext on the NAND becomes permanently unreadable because the original decryption key no longer exists. No lab, no tool, & no amount of money can reverse a PSID revert.
The PSID is a 32-character alphanumeric code printed on the drive's physical label. Drive manufacturers include it as a last-resort factory reset mechanism for locked drives. The intended use case is an IT department recycling a locked drive for reuse when the authentication credentials are lost. The PSID revert wipes the encryption state, generates fresh keys, & returns the drive to factory defaults.
PSID revert is a data destruction operation, not a recovery tool.
IT administrators sometimes execute a PSID revert trying to "unlock" a drive that won't mount. The old DEK is deleted & replaced with a new one. The NAND still contains ciphertext encrypted with the old DEK, but that key no longer exists anywhere. This is irreversible. Before running a PSID revert, contact a hardware-encrypted SSD recovery lab if the data matters.
The PSID revert scenario is distinct from Secure Erase or Crypto Erase. All three destroy the DEK, but PSID revert also resets the drive's ownership & authentication state. The outcome is the same for data recovery: once the DEK is gone, the ciphertext is permanent. AES-256 has no known cryptographic weaknesses that would allow brute-force recovery of the key in any practical timeframe.
Why does chip-off recovery not work on encrypted SSDs?
Chip-off reads the raw NAND contents, which are ciphertext if the controller encrypted the data. The encryption key is stored in the controller or secure element, not on the NAND chips. Without the key, the data cannot be decrypted.
Can data be recovered from an Apple T2 or M-series Mac with a failed SSD?
The Secure Enclave key is bound to the specific silicon. If the SSD controller fails but the T2/M-series chip works, board-level repair to restore the SSD controller is the recovery path. If the T2/M-series chip is destroyed, the key is lost and data is unrecoverable.
What is the difference between TCG Opal and eDrive encryption on SSDs?
TCG Opal 2.0 is the SSD-side self-encrypting drive standard. eDrive (IEEE 1667) is Microsoft's protocol for delegating BitLocker encryption to the SSD's Opal hardware. With eDrive, BitLocker doesn't perform software encryption; the SSD controller does it. If the controller dies, the BitLocker recovery key can't decrypt raw NAND by itself. Recovery requires board-level repair to revive the controller, then the BitLocker key authenticates the Opal session.
Does a PSID revert destroy data on a self-encrypting drive?
Yes. A PSID revert deletes the existing Data Encryption Key & generates a new one. All ciphertext on the NAND becomes permanently unreadable. The 32-character PSID code on the drive's label is a factory reset mechanism, not a recovery tool. No lab can reverse it. If you need the data, contact a recovery lab before executing a PSID revert.
Can PC-3000 SSD recover data from an encrypted SSD with a dead controller?
Only if the original controller can be revived through board-level microsoldering. PC-3000 SSD communicates with the controller's diagnostic mode to extract data while the hardware AES engine decrypts each sector in real time. If the controller is dead, a technician replaces failed PMICs or voltage regulators with a Hakko FM-2032 to bring the controller back online. Without the original controller, the NAND contents are ciphertext & no software can decrypt them.
Why does the PC-3000 SSD recovery procedure differ between Samsung, Silicon Motion, & Phison controllers?
Each controller family stores firmware, FTL tables, & encryption keys differently. Modern Samsung NVMe controllers are controller-bound, so recovery depends on board-level repair of the original controller rather than a loader-based factory-mode logical dump. Silicon Motion controllers require a permanent test-point short, volatile loader injection to RAM, & a full virtual FTL rebuild in RAM on the drive itself. Phison controllers vary by generation: budget PS3111-S11 models use XOR scrambling (reversible by PC-3000) while NVMe E18 models use hardware AES-256 encryption. A loader compiled for the wrong controller-NAND combination produces ECC errors & no usable data.
What does "SATAFIRM S11" mean & can data be recovered?
"SATAFIRM S11" is the factory identity string of the Phison PS3111-S11 controller. It appears in BIOS when the controller's FTL corrupts & the CPU drops to BootROM. The drive reports 0GB or 1GB capacity & rejects standard read/write commands. Data is still on the NAND. Recovery requires PC-3000's Phison utility to inject a volatile loader, reconstruct the FTL from surviving page metadata, & extract data. Do not flash firmware using internet forum tools like PhisonToolBox; this overwrites remaining FTL fragments & destroys the data. SATA SSD firmware recovery runs $600–$1,200.
What is the difference between Safe Mode & Technological Mode in SSD recovery?
Safe Mode is a hardware state triggered by shorting specific test points on the SSD PCB during power-on. It forces the controller to ignore corrupted firmware & halt in a minimal diagnostic state. Technological Mode (also called Factory Access Mode) is the software state reached after communication is established: the volatile loader has been injected into the controller's RAM & factory diagnostic functions are unlocked. Safe Mode gets you physical access; Technological Mode gives PC-3000 the diagnostic commands needed to extract data.
If you are experiencing this issue, learn about our SSD recovery service.
