Encrypted Data Recovery
Your encrypted drive failed, but you have the recovery key or password. We fix the hardware. You supply the decryption credentials. That is the only way encrypted recovery works. Our SSD data recovery service repairs the physical drive so your key can decrypt the data.
No Data, No Charge. Pricing based on drive type and failure, not encryption.
What We Cannot Do
We cannot crack, bypass, or brute-force modern encryption.
Any company that claims otherwise is lying. We will tell you that upfront rather than take your money.
Recovery by Encryption Type
We handle BitLocker (Windows), FileVault (macOS), LUKS (Linux), hardware self-encrypting drives (SEDs/OPAL), and VeraCrypt/TrueCrypt volumes on failed drives. The requirement is always the same: you must have the key.
BitLocker Recovery
Windows BitLocker and Windows 11 Device Encryption. TPM failures, corrupted metadata, failed drives with valid recovery keys.
Learn more
FileVault Recovery
macOS FileVault 2 on internal SSDs. T2/M-series Macs with Apple ID recovery or institutional keys.
Learn more
VeraCrypt & TrueCrypt Recovery
VeraCrypt and TrueCrypt volumes on failed drives. Hidden volumes, cascaded ciphers. Password required.
Learn more
Self-Encrypting Drive Recovery
Hardware-encrypted SSDs (OPAL/TCG). Samsung, Crucial, WD drives with ATA security or OPAL credentials.
Learn more
BitLocker vs FileVault vs LUKS: Recovery Path Comparison
The three dominant software-encryption stacks each anchor their key hierarchy differently. The table below summarizes where the decryption key lives, what an enterprise key-escrow path looks like, and whether brute-force is technically feasible against a strong passphrase. Hardware-bound encryption (Apple T2, Apple Silicon, OPAL SEDs) is covered in the sections below; it does not fit a software-stack comparison because the key never leaves the controller.
| Property | BitLocker (Windows) | FileVault 2 (macOS, Intel pre-T2) | LUKS (Linux) |
| Cipher and mode | AES-XTS 128 or 256-bit | XTS-AES-128 with a 256-bit key | AES-XTS (LUKS2 default) |
| Key wrapping | Recovery key or password unwraps the Volume Master Key, which unwraps the Full Volume Encryption Key | Password or institutional recovery key unwraps the Volume Encryption Key stored in the CoreStorage / APFS metadata | Passphrase derived through PBKDF2 (LUKS1) or Argon2 (LUKS2) unlocks a key slot holding the master key |
| Enterprise key escrow | Microsoft Account, Active Directory, Azure AD, or MBAM. 48-digit recovery key retrievable at account.microsoft.com/devices/recoverykey | Apple ID or institutional FileVault recovery key (FVMaster keychain) deployed through MDM | No native escrow. Operators back up the header with cryptsetup luksHeaderBackup or push key slots through configuration management |
| Header location on disk | Three redundant FVE metadata blocks marked -FVE-FS- | CoreStorage Volume Headers or APFS Container Superblock plus checkpoint copies | Single LUKS header at partition start |
| Brute-force feasibility (strong passphrase) | Not feasible against AES-XTS or against a 48-digit recovery key | Not feasible against AES-XTS with a strong passphrase | Not feasible; Argon2 in LUKS2 is memory-hard and resists GPU brute-force |
| Hardware binding | Bound to motherboard TPM by default; auto-unlock fails on hardware swap unless the 48-digit recovery key is supplied | Software-only on Intel pre-T2 hardware; T2 and Apple Silicon shift binding to the Secure Enclave | None by default; portable across hardware so long as the header survives |
| Lost-key outcome | Data is cryptographically unrecoverable | Data is cryptographically unrecoverable | Data is cryptographically unrecoverable |
All three stacks share the same architectural truth: the lab can recover from hardware damage, but no lab can substitute for a missing key. Brute-force is not a recovery path against modern AES-XTS with a strong passphrase regardless of which stack issued it.
How Does Encrypted Drive Recovery Work?
Encryption protects your data from unauthorized access. It does not protect against hardware failure. When the drive itself breaks, the encryption layer becomes an obstacle to recovery only if the key is missing. With the key, the process is straightforward.
- 1
Diagnose the hardware failure
We determine what is physically wrong with the drive: head failure, firmware corruption, PCB damage, controller death, or NAND degradation.
- 2
Repair or image the drive
Using PC-3000 or clean bench procedures, we get a complete sector-level image of the encrypted volume. Every sector matters because encryption means partial reads produce partial garbage.
- 3
Decrypt with your key
Once we have a clean image, we mount and decrypt it using your recovery key, password, or Apple ID credentials. The decrypted data is then copied to a new drive and returned to you.
BitLocker Recovery When TPM or Motherboard Fails
BitLocker binds its Volume Master Key to the motherboard's TPM chip. When that motherboard dies, the TPM dies with it, and the drive locks. Recovery requires your 48-digit recovery key. If the drive itself is also failing, we image the encrypted volume sector-by-sector using PC-3000 before decryption.
BitLocker on Windows 10 and 11 ties the Volume Master Key (VMK) to the Trusted Platform Module (TPM) chip on the motherboard. When the motherboard dies, the TPM dies with it, and the VMK cannot be unsealed automatically. The drive will not unlock on replacement hardware.
Your 48-digit recovery key is the alternative path: it decrypts the VMK stored in the BitLocker metadata, which then unwraps the Full Volume Encryption Key (FVEK) that protects the actual data. If you have that key, we image the encrypted volume sector-by-sector using PC-3000 and apply your recovery key to decrypt the image.
Self-encrypting drives (SEDs) that use the TCG Opal standard present a different challenge. The drive controller itself handles encryption transparently using an internal AES engine and a Media Encryption Key (MEK) stored on the controller. The OS may not even be aware the data is encrypted.
One critical warning: never allow a technician to issue a PSID Revert on a self-encrypting drive. It zeroizes the Media Encryption Key (MEK), triggering an irreversible Cryptographic Erase that no lab can undo.
FileVault Recovery on T2 and Apple Silicon Macs
T2 and Apple Silicon Macs encrypt their SSD at the hardware level through the Secure Enclave Processor. Desoldering the NAND chips produces only ciphertext. The sole recovery path is repairing the original logic board so the Secure Enclave can release the decryption key.
On Macs with a T2 chip (2017-2020 Intel models) and all Apple Silicon Macs, the internal SSD is encrypted at the hardware level by the Secure Enclave Processor (SEP). The APFS Volume Encryption Key (VEK) is bound to a unique identifier fused into the Secure Enclave on that specific logic board.
This is true whether FileVault is turned on or off; Apple Silicon Macs encrypt storage by default at the hardware layer. Desoldering the NAND flash chips and reading them on external equipment does not work. The raw data is encrypted, and the key exists only inside the Secure Enclave of the original logic board.
No amount of chip-off work or JTAG access produces usable data.
The only viable recovery path is repairing the original logic board so the Secure Enclave can authenticate your macOS password or institutional recovery key and release the VEK. We perform component-level micro-soldering on the logic board (replacing failed power management ICs, repairing broken traces, reballing BGAs) to bring the board back to a functional state.
Once the Secure Enclave is operational, decryption proceeds normally through macOS. For details on T2-specific recovery workflows, see our T2 chip data recovery page.
Why Does Encryption Make Recovery Harder?
On an unencrypted drive, a few unreadable sectors mean a few corrupt files. On an encrypted drive, a single bad sector in the wrong location can make an entire volume undecryptable. Encryption keys and metadata occupy specific disk locations; if those sectors are damaged, the volume will not mount even with the correct recovery key.
The BitLocker metadata headers, the FVEK (Full Volume Encryption Key) wrapped by the VMK (Volume Master Key), and the key protector blocks all occupy specific disk locations. If those sectors are damaged, the volume will not mount even with the correct recovery key.
This is why imaging quality matters more on encrypted drives than on unencrypted ones. We use PC-3000 with multi-pass head maps and adaptive read parameters to extract every recoverable sector before attempting decryption. Rushing the image or skipping unstable areas is not an option.
Why Data Recovery Software Cannot Bypass Hardware Encryption
Software operates at the OS level and reads logical sectors through the storage controller. When the controller is dead, the firmware is corrupt, or the drive does not spin, there are no logical sectors to read. Software tools cannot bypass encryption bound to a hardware security module or a failed controller.
Search results for "encrypted data recovery" are dominated by software vendors claiming their tools can recover files from BitLocker, FileVault, and self-encrypting drives. These claims collapse under technical scrutiny. When the controller is dead, the firmware is corrupt, or the drive does not spin, the software sees nothing.
Self-Encrypting Drives and Controller-Bound Encryption Keys
A self-encrypting drive (SED) following the TCG Opal specification performs AES encryption transparently inside the drive controller. The Media Encryption Key (MEK) never leaves the controller's security subsystem. Data written to the NAND flash or magnetic platters is already ciphertext.
If the controller firmware corrupts or the controller chip fails, software running on the host PC cannot extract or reconstruct the MEK.
TPM-Bound BitLocker and Motherboard Failure
Windows 10 and 11 tie BitLocker's Volume Master Key to the TPM chip on the motherboard. When that motherboard fails, the TPM fails with it. The drive will not auto-unlock on replacement hardware.
Software recovery tools installed on a new system cannot access the VMK because the TPM is physically gone. The 48-digit recovery key is the only alternative path.
With that key, we image the encrypted volume sector-by-sector using PC-3000 and apply the recovery key to decrypt the image offline. Without the key, AES-XTS encryption makes the data permanently unreadable.
Apple T2 and M-Series Secure Enclave Recovery
On T2 and Apple Silicon Macs, the Secure Enclave Processor (SEP) holds the volume encryption key in a hardware security module fused to the logic board. The NAND flash stores only ciphertext. Desoldering the NAND chips and reading them externally produces encrypted data with no path to the key.
Software tools cannot interface with a Secure Enclave that is not powered and authenticated. The only recovery path is repairing the original logic board at the component level (replacing failed power ICs, repairing broken traces, reballing BGAs) so the Secure Enclave can authenticate the user's credentials and release the decryption key.
When Software Recovery Tools Are Appropriate
Software has a narrow valid use case: logical data loss on a physically healthy encrypted drive where the user has the decryption key. If the drive mounts, decrypts, and the files were accidentally deleted, a file recovery tool can scan the decrypted volume for remnants.
This works only on HDDs or SSDs with TRIM disabled. On modern SSDs with TRIM enabled, deleted file recovery is not possible regardless of encryption status, because the controller discards the underlying data blocks after TRIM.
How BitLocker Metadata Corruption Affects Recovery
BitLocker stores its encryption keys inside Full Volume Encryption (FVE) metadata blocks identified by the hex signature -FVE-FS- near the start of the partition. Microsoft builds in three redundant copies of this metadata at different disk offsets. If a failing hard drive develops bad sectors at all three locations, the Volume Master Key cannot be derived even with a correct 48-digit recovery key.
LUKS Recovery on Linux: Header Integrity
- LUKS Header
- The header region of a LUKS-encrypted volume contains the cryptographic salt, the master key digest, and multiple key slots (up to 8 in LUKS1, or up to 32 in LUKS2). Each key slot holds a copy of the master key encrypted with a different passphrase. Overwriting this header permanently destroys every path to the master key.
- Key Slot Damage
- If a drive develops bad sectors within the header region, specific key slots become unusable. LUKS volumes with a single passphrase have only one active key slot. One damaged sector in that slot's anti-forensic stripes makes the volume permanently unrecoverable. Volumes with multiple passphrases across separate key slots survive partial header damage if at least one slot remains intact.
- Header Backup
- Running
cryptsetup luksHeaderBackupbefore a drive fails is the single most effective safeguard for LUKS volumes. If you have a header backup stored on a separate device, we image the failed drive on a clean bench and apply your backup header to decrypt the raw data offline.
A LUKS volume can sit on a multi-bay NAS rather than a single drive. Synology DSM 7.2 and later offer optional full volume encryption with LUKS in aes-xts-plain64 mode with the wrapped keys held in an encryption key vault, and QNAP QuTS hero offers optional ZFS native encryption per dataset, so in both cases the key material lives in operating-system vault material rather than in bridge or controller silicon. That places the encryption layer last in the workflow: each member drive is imaged through write-blocked hardware, the array is virtually reassembled from those clones, and the encrypted container is mounted read-only against the reassembled set afterward.
If the drive has physical damage but the LUKS header is intact, we stabilize the read/write heads in our ULPA-filtered clean bench, extract a complete sector-level image, and decrypt it using your passphrase. No data recovered means no fee.
What to Do When Your Encrypted Drive Fails
If your encrypted drive stops responding, stop using it immediately and locate your recovery key before contacting any lab. Missteps with encrypted drives are permanent; there is no second chance once encryption keys or metadata are damaged. Do not run chkdsk, fsck, or any diagnostic tool on an encrypted volume.
- Stop using the drive immediately. Power it down. Do not run chkdsk, fsck, Disk Utility, or any diagnostic tool. On an encrypted volume, these utilities cannot repair what they cannot decrypt, and they risk overwriting the encryption metadata that makes recovery possible.
- Locate your recovery key before contacting any lab. For BitLocker: check your Microsoft Account at account.microsoft.com/devices/recoverykey, Active Directory, or the printed key you saved during setup. For FileVault: check your Apple ID or institutional recovery key. For VeraCrypt: confirm you have the password and know whether a hidden volume exists. Without a valid key, no lab can decrypt the data.
- Do not attempt software recovery on a drive with hardware symptoms. Clicking, grinding, beeping, or failure to appear in BIOS are hardware failures. On encrypted volumes, every lost sector reduces the chance of a complete decryption.
- Do not issue a PSID Revert on a self-encrypting drive. It destroys the Media Encryption Key, triggering an irreversible Cryptographic Erase. If a repair shop suggests this, decline and remove your drive.
- Send the drive to a lab with hardware decryption capability. The lab needs PC-3000 or equivalent tools to image the encrypted volume sector-by-sector at the hardware level. We charge nothing if no data is recovered. Ship the drive with your recovery key provided separately through a secure channel.
How Do You Handle Enterprise and Forensic Encrypted Drive Cases?
For enterprise IT, in-house counsel, and healthcare administrators, encrypted-drive recovery is governed by chain-of-custody documentation, an image-first workflow where the hardware permits, and direct technical communication. What we offer is a single Austin lab, one engineer per case, and a documented physical workflow you can describe to your CISO in technical terms.
Recovery Time Objective is bounded by hardware, not decryption
Encrypted-volume RTO is set by the hardware imaging phase, not the decryption phase. BitLocker, FileVault, and LUKS anchor their key hierarchy in dedicated metadata regions on disk; the Volume Master Key, Full Volume Encryption Key, and key-slot blocks occupy specific sectors. If those sectors are unreadable, the volume cannot be unwrapped and will not mount even with a valid recovery key.
We image the failing drive sector-by-sector using PC-3000 Portable III or PC-3000 Express so that header redundancy can be searched across the full image rather than relied on from a partial read of the live drive. A drive with severe surface damage may require multiple imaging passes; the read condition of the media sets the timeline.
Recovery Point Objective: image-first where the hardware permits
For software-encrypted volumes (BitLocker on a non-SED drive, LUKS, FileVault on Intel pre-T2 Macs, VeraCrypt) we capture a complete forensic image first and attempt decryption only on the clone. The source drive is read on a strictly read-only path to a stable destination drive; the original sectors are not modified during imaging.
For hardware-bound encryption (Apple T2, Apple Silicon, and certain OPAL self-encrypting drives), an image-before-decryption workflow is physically impossible: the encryption key never leaves the original controller or Secure Enclave, so a raw NAND or platter image read off-board produces only ciphertext. In those cases we restore the original controller or logic board at the component level so it can decrypt the data inline during the imaging read. The forensic image captured during that read becomes the recovery point, and the source media still never leaves the lab.
The Recovery Point Objective (RPO) for an encrypted-volume engagement is the state of the data at the moment the forensic image was captured, not the state at the moment the drive failed. Anything written to the drive between the failure event and the imaging acquisition is unrecoverable if those sectors degraded further.
NDA, chain of custody, and lab-bound handling
We review and sign customer-supplied mutual non-disclosure agreements before drive intake. There is no proprietary Rossmann NDA you are required to accept. Chain of custody for forensic and litigation-adjacent cases is documented through:
- Photographic record
- Drive enclosure, serial numbers, PCB markings, and any tamper-evident seals are photographed before any internal work begins.
- ULPA-filtered clean bench
- Any internal physical intervention is performed inside the ULPA-filtered clean bench.
- In-lab policy
- Source media never leaves the Austin lab. All work is performed in-house. No third parties handle the drive at any stage.
Direct engineer communication, not a sales tier
The engineer working your case is the person you speak with about it. Status updates consist of bad-sector maps, firmware module integrity readings, and Flash Translation Layer rebuild status from PC-3000 SSD, rather than generic ticket text routed through an account manager. If your case involves an Apple Silicon Mac, a T2 logic board, an OPAL self-encrypting drive, or TPM-bound BitLocker, you speak directly to the engineer performing the micro-soldering, controller-firmware reconstruction, or header-recovery work.
How Much Does Encrypted Data Recovery Cost?
Encrypted drive recovery costs the same as standard recovery for that drive type. Encryption adds zero surcharge. You pay for the hardware repair, not the decryption. BitLocker, FileVault, LUKS, VeraCrypt, and self-encrypting drive volumes all fall within the same tiers; the cost is determined by the physical failure type.
The pricing below is identical to our standard hard drive and SSD recovery tiers. The cost is determined by the physical failure type, not by whether the data is encrypted.
Hard Drive (HDD) Recovery Pricing
- Low complexity
- Low complexity
- Medium complexity
- High complexity
- High complexity
SSD Recovery Pricing (SATA)
No diagnostic fee. No data, no recovery fee. All pricing includes the decryption step when you provide valid credentials.
Common Questions About Encrypted Recovery
Can you crack BitLocker or FileVault encryption?
My drive failed and I have the recovery key. Can you help?
How much does encrypted drive recovery cost?
What types of encryption do you support?
My Windows 11 PC died and the drive is encrypted, but I never turned on BitLocker. What happened?
Can data be recovered from a BitLocker encrypted drive?
Why did a repair shop's attempt to unlock my self-encrypting drive permanently erase my data?
Can you recover data by removing storage chips from a dead MacBook with FileVault?
Encrypted Drive Failed?
Send us your drive and your recovery key. We handle the hardware. You keep the key.
