How Does Encrypted SSD Data Recovery Work?
Encrypted SSD recovery is electrical-first board-level work done in-house at our Austin, TX lab. Nationwide service is mail-in. Evaluation is free, there's no diagnostic fee, & no data means no recovery fee. The path is reviving the original controller, unlocking the OPAL session with your password or BitLocker recovery key, & imaging through the live controller so its AES engine decrypts on the fly.
This isn't a software job, & it isn't a chip-off job. The AES-256 Media Encryption Key never leaves the original controller die, so chip-off returns only ciphertext. We bring the original controller back to life, then let its own AES engine decrypt your data while we image it. Here is the sequence you go through, from intake to return:
- Free evaluation when your drive lands at the Austin, TX lab. There's no diagnostic fee, so you learn what failed before any charge.
- Electrical-first diagnosis. We verify the power rails & check whether the controller enumerates on the SATA or PCIe bus, using FLIR thermal localization to find shorted PMICs or decoupling capacitors.
- Board-level microsoldering to revive the original controller, with a Hakko FM-2032 on an FM-203 base, Atten 862 hot air rework, & a Zhuo Mao precision BGA station when the controller package needs work. The original controller is required because the AES-256 Media Encryption Key never leaves its die & chip-off yields only ciphertext.
- If the volume uses an OPAL/ATA password or BitLocker hardware mode, we unlock the OPAL session with the key you supply before imaging begins. That key authenticates the session so the controller drops the locking range; it doesn't decrypt raw NAND by itself.
- Image the unlocked drive through the original controller on PC-3000 SSD or PC-3000 Portable III, so every read passes through the live AES engine & reaches the imaging buffer as plaintext. A software-BitLocker volume with no hardware lock is instead imaged first, then decrypted offline with your recovery key.
- Verify the recovered files & return them on a target drive you choose.
To start, send the drive to the Austin, TX lab & include the 48-digit BitLocker recovery key or the OPAL/ATA password if your volume has one. You get a firm quote before any work begins, & there's no charge if the controller can't be revived under our no data, no recovery fee guarantee. SATA board repair runs $450–$600; NVMe runs $900–$1,200. If the controller boots but the firmware is corrupted, firmware reconstruction runs $600–$1,200 for SATA & $900–$1,200 for NVMe. Start the case on our contact page or call (512) 212-9111 before you ship.
The detail behind each step sits below: see why board-level repair is the only recovery path for the engineering, & how much encrypted SSD recovery costs for the full tier breakdown.
Why Are Most SSDs Already Encrypted?
Most SSDs manufactured after 2015 encrypt all data by default because always-on hardware encryption serves two functions: it enables instant Secure Erase by destroying the Media Encryption Key rather than erasing every NAND cell, and it provides the foundation for optional user-set passwords via ATA Security, TCG OPAL, or BitLocker.
Since approximately 2015, many enterprise and mainstream SSD controllers have implemented always-on AES-256 hardware encryption by default, without any user configuration. Samsung, Silicon Motion, Marvell, & Intel/Solidigm controllers commonly encrypt every write to NAND using a Media Encryption Key generated during manufacturing. The OS reads & writes plaintext; the controller handles all encryption and decryption in dedicated hardware, with negligible performance impact.
Notable exceptions exist: some DRAM-less NVMe drives (WD SN770) and gaming SSDs (Sabrent Rocket Q4) omit hardware AES-256.
The controller generates a Media Encryption Key (MEK) during manufacturing or first initialization. Every write to NAND passes through the AES engine, and every read is decrypted before being sent to the host. Performance impact is negligible because the AES engine is implemented in dedicated hardware on the controller die.
Always-on encryption exists for two reasons. First, it enables instant Secure Erase: instead of erasing every NAND cell, the controller destroys the MEK and generates a new one, making all existing data permanently unreadable in milliseconds. Second, it provides a foundation for user-set passwords.
When a user enables ATA Security, TCG OPAL, or BitLocker hardware mode, the MEK is itself encrypted with the user's authentication key. The NAND data was already encrypted; the user password simply locks access to the MEK.
How Do Competitor Claims About Encryption Bypass Compare to Technical Reality?
Several competitors market encryption bypass capabilities that don't match hardware engineering. The AES-256 Media Encryption Key on a Silicon Motion SM2262EN lives inside the controller die and never traverses the host bus, the DRAM, or the NAND interface in plaintext. No proprietary software can extract that key from raw NAND. Recovery requires reviving the original controller through board-level microsoldering, not bypassing the cipher.
| Claim Source | Marketing Claim | Technical Reality |
| TechFusion | Engineers will "carefully extract the AES encryption key" and "use proprietary programming to convert your information to legible text." | On a hardware-encrypted SSD, the AES key is stored within tamper-resistant secure elements or controller silicon. The plaintext Media Encryption Key exists only inside the controller while powered. It never resides in the host CPU, DRAM, or NAND. If the controller is dead, no proprietary programming can extract the AES key from raw NAND. Recovery requires reviving the original controller via board-level repair. |
| SecureData Recovery | Experts can "extract a temporary clear key embedded in the volume's metadata and unlock the drive" without user keys. | This is a software-level BitLocker phenomenon, not a hardware encryption bypass. When BitLocker is suspended or pre-provisioned but not fully activated, the Volume Master Key may be temporarily stored as a clear key in the volume header. Forensic tools can parse this if the metadata is intact. If BitLocker is fully enabled and the TPM is unreadable with no clear key active, the data is mathematically unrecoverable. This claim is technically accurate for a specific edge case but is often misunderstood as a universal bypass capability. |
| Physical Data Recovery (UK) | PC-3000 SSD allows them to "Bypass WD's proprietary encryption (including hardware encryption in WD Black SSDs)." | PC-3000 has decryption utilities for certain WD drives if the encryption key is still stored in the drive's Service Area or ROM. PC-3000 automates locating this key in SA modules and utilizing it to decrypt sector images. This is not bypassing or cracking encryption; it is utilizing factory-level diagnostic commands to retrieve the legitimate key that the drive generated for itself. If the SA is corrupted or the controller is physically shattered, this approach fails. |
AES-256 has a key space of 2^256. Brute-force attacks are mathematically impossible. The difference between extracting a BitLocker metadata clear key, a known Microsoft architectural feature, and brute-forcing an active Media Encryption Key is the difference between a recoverable software state and an unrecoverable hardware failure. "Proprietary programming" cannot break AES-256. When a company markets bypass capability, the engineering reality is usually either factory diagnostic key retrieval on a partially functional controller, or a software-level edge case that doesn't apply to hardware-encrypted NAND.
We don't claim to bypass AES-256. We diagnose the electrical failure with a FLIR thermal camera, replace the shorted PMIC or decoupling capacitor with a Hakko FM-2032 on an FM-203 base, and revive the original controller. When the controller boots, the Hardware Unique Key unwraps the Media Encryption Key, the AES engine initializes, and imaging through PC-3000 Portable III returns plaintext. SATA board repair: $450–$600. NVMe: $900–$1,200. No data, no fee.
How Do SSD Encryption Keys Work?
SSD hardware encryption uses a layered key hierarchy. The Media Encryption Key (MEK) encrypts all NAND data and is stored inside the controller chip; it never leaves that silicon. When a user password is set, a Key Encryption Key (KEK) wraps the MEK. Which key lives where determines whether recovery is possible after controller failure.
- Media Encryption Key (MEK)
- The AES-256 key used to encrypt and decrypt all data on the NAND. Stored in a secure region of the controller chip or in a protected area of the NAND that only the original controller can access. Unique per drive; no two SSDs share the same MEK.
- Key Encryption Key (KEK)
- When a user password is set (via ATA Security, OPAL, or OS-level encryption in hardware mode), the MEK is wrapped with the KEK derived from the password. The wrapped MEK is stored on the drive. Without the correct password, the MEK cannot be unwrapped and data remains encrypted.
- Self-Encrypting Drive (SED)
- An SSD that complies with the TCG OPAL specification for hardware encryption management. OPAL provides a standardized interface for setting user authentication, defining encryption ranges, and managing the key hierarchy. Samsung, Micron/Crucial, and Intel enterprise SSDs commonly support OPAL 2.0.
- Always-On Encryption (No User Password)
- Drives that encrypt all data by default without user authentication. The MEK is accessible to the controller without a password. Data is protected from raw NAND reads (chip-off) but not from normal host access through the controller.
How Is the MEK Generated and Stored Inside the Controller?
The MEK is generated once, at first power-on after manufacturing, by a hardware random number generator (TRNG) integrated into the controller die. The 256-bit output is written into a key-storage region that is electrically isolated from the host interface. On most modern NVMe controllers, that region is a dedicated OTP (one-time programmable) block or an internal key vault fused into controller silicon, depending on the manufacturer. In both architectures the key never traverses the SATA or PCIe bus, never appears in any externally readable register, and cannot be exported through any documented vendor command. The host sees only plaintext on read and writes plaintext on write; the encryption is performed inline by the controller as data crosses between the host interface and the NAND channels.
The Hardware Unique Key (HUK) is a separate per-die secret fused into the controller at wafer test. The HUK is used to wrap (encrypt) the MEK before any persistent storage of key material, so even if the wrapped MEK is later read out of a firmware module, it remains an unintelligible blob unless unwrapped by the original HUK inside the original controller silicon. Destroying the controller package destroys the HUK, which destroys the ability to unwrap the MEK, which destroys the ability to decrypt any NAND block on that drive. There is no off-controller fallback by design.
How Does PC-3000 SSD Access Encrypted Drives Without Bypassing AES-256?
PC-3000 SSD doesn't crack or bypass AES-256. It uses Factory/Technological mode to inject a volatile Microcode Loader into the controller's RAM. This loader bypasses corrupted on-NAND firmware, disables background garbage collection, provides direct access to the System Area, and reconstructs a virtual translator in RAM on the drive itself. Once stable communication is established, read commands pass through the hardware AES engine and the drive outputs plaintext, making encryption transparent to the recovery workflow.
PC-3000 Portable III injects the volatile Microcode Loader into the controller's RAM during power-on. The loader replaces the corrupted firmware overlay with a temporary diagnostic image. It disables background garbage collection so the FTL doesn't remap blocks during imaging, and it exposes the System Area modules where the wrapped MEK blob and the translator tables live.
For Phison PS5012 and PS5016 controllers, entering Safe Mode requires shorting specific test points on the PCB during power-up. The PC-3000 Phison utility then uploads the LDR through the ROM bootstrap interface. For Silicon Motion SM2262EN and SM2263XT controllers, ROM pin bridging forces the controller to accept an external volatile microcode loader instead of loading damaged firmware from NAND. In both cases, the AES engine and the wrapped MEK blob remain physically intact inside the controller silicon; the recovery path provides a clean firmware environment that preserves the decryption chain.
After the LDR establishes stable communication, PC-3000 rebuilds a virtual FTL in RAM on the drive itself by reading the mapping tables from the System Area. The controller's hardware AES engine remains active; every read command passes through it, decrypting ciphertext on the NAND into plaintext before the data reaches the PC-3000 imaging buffer. The encryption is transparent to the recovery operator because the original controller is doing the decryption with its original MEK. SATA firmware reconstruction runs $600–$1,200; NVMe runs $900–$1,200.
Why Is the NAND Itself Only Ciphertext?
Every byte the host writes is encrypted with AES-256 (XTS mode on most NVMe controllers, ECB or CBC variants on older SATA designs) before it lands in a NAND page. The Flash Translation Layer, the wear-leveling metadata, the L2P (logical-to-physical) mapping table, and the user-visible LBA range are all stored as ciphertext keyed by the MEK. Firmware modules in the System Area are typically also encrypted, though some controllers use a separate firmware-encryption key distinct from the user MEK. The net effect is that a NAND die desoldered from a self-encrypting SSD contains no plaintext anywhere: every page is high-entropy ciphertext that is statistically indistinguishable from random data.
This is the structural reason chip-off recovery fails on a self-encrypting drive. Chip-off reads NAND pages with a programmer such as PC-3000 Flash; it returns the raw cells exactly as written. On an unencrypted controller, those raw pages still need ECC correction, descrambling, and FTL reconstruction, but the underlying user data is plaintext and recoverable. On a self-encrypting drive, the same chip-off read returns ciphertext, and no amount of off-controller post- processing can decrypt it. The decryption operation is mathematically bound to the MEK inside the original controller; without that controller alive on a working PCB, the ciphertext is unrecoverable.
Why Board-Level Repair Is the Only Path for Self-Encrypting SSDs
Because the MEK cannot leave the controller and the NAND holds only ciphertext, every recovery from a dead self-encrypting drive has to keep the original controller die alive long enough to image the user data through its own AES engine. That is a board-level repair problem, not a software problem. Imaging through the live controller is the only step that converts the ciphertext on the NAND back into the files the customer is asking for. No chip-off bench, no third-party decryption tool, and no controller transplant can substitute for that path.
Which Controller Families Implement Always-On Hardware AES?
The following NVMe controller families ship with hardware AES-256 enabled by default, regardless of whether the user activates OPAL or BitLocker eDrive. On these drives the NAND is ciphertext from the first write, and recovery requires reviving the original controller:
- Phison PS5013 (E13T), PS5016 (E16), PS5018 (E18), PS5019 (E19T) NVMe controllers, used across Kingston KC3000, Corsair MP510/MP600, PNY XLR8, Sabrent Rocket and Rocket 4 Plus, Crucial P2, Inland Performance, and many OEM-branded SSDs. PC-3000 SSD supports board-level recovery on E13T, E16, and E19T; the E18 module is firmware repair only. SATA board repair: $450–$600. NVMe: $900–$1,200.
- Silicon Motion SM2262, SM2262EN, SM2263, SM2263EN, SM2267XT, SM2269XT NVMe controllers, with the EN-suffix variants explicitly documented by ACELab as shipping with encryption enabled. These are the silicon under HP EX950/EX900, ADATA XPG SX8200 Pro, Kingston KC2500, Crucial P1, and a number of OEM NVMe drives. PC-3000 SSD has full recovery support on the Silicon Motion family through the Portable III chassis.
- Samsung in-house controllers (Polaris on 960 EVO/PRO, Elpis on 980 PRO, Pablo on 980 non-Pro, and the in-house parts in the 970 and 990 PRO). These ship with AES-256 always-on. Per the ACELab PC-3000 SSD supported list, modern Samsung in-house controllers are not on the supported list. These drives are taken case by case: one that still enumerates may need only a logical recovery, and on the 970, 980, and 990 families PC-3000 can sometimes read a drive a normal computer will not see. If a 970 EVO, 980 PRO, or 990 PRO arrives with a dead controller, see the separate Samsung SSD page for the current intake policy.
- Maxio MAP1602 / MAP1602A NVMe controllers, used on a range of value-segment PCIe 4.0 drives. These implement always-on AES. Rossmann does not currently offer in-lab recovery for Maxio MAP1602. Intake on these drives is limited to evaluation and consultation; no destructive attempts are made.
For an explanation of why chip-off on these families returns only encrypted blocks, see the dedicated section on why chip-off fails on self-encrypting SSDs. For the controller-specific recovery procedures we run on the supported families, see the Phison architecture page and the flagship SSD data recovery page.
How Does Encrypted SSD Recovery Differ from Unencrypted?
Hardware encryption changes the viable recovery methods. On an unencrypted drive, multiple paths exist: chip-off NAND extraction, controller swap, or firmware repair all yield readable data. On a hardware-encrypted drive, the original controller is the only key holder. Chip-off yields ciphertext; controller swap generates a new key; only controller repair preserves the decryption chain.
| Recovery Method | Unencrypted SSD | Encrypted SSD (Class 0) | Encrypted SSD + User Password |
| PC-3000 firmware repair | Works; data reads directly | Works; controller decrypts transparently | Works if password is known; controller decrypts after authentication |
| Board-level controller repair | Works; original controller not required | Required; only the original controller holds the MEK | Required; original controller + user password both needed |
| Chip-off NAND recovery | Viable; raw NAND is plaintext | Yields ciphertext; data unrecoverable | Yields ciphertext; data unrecoverable |
| Controller swap to donor | May work for some older controllers | Fails; new controller has different MEK | Fails; new controller has different MEK |
Hardware Encryption vs Software Encryption: Recovery Comparison
Hardware encryption (SED) is performed by the SSD controller using a key stored in the controller silicon. BitLocker software mode is performed by the host CPU using a key stored in the TPM or supplied by the user. FileVault on modern Macs (T2 and Apple Silicon) is not purely host-CPU software: encryption runs on a dedicated AES engine in the SoC data path, with keys bound to the Secure Enclave. Recovery path differs depending on which layer holds the key.
| Attribute | Hardware Encryption (SED / AES-256) | Software Encryption (BitLocker / FileVault) |
| Where encryption occurs | SSD controller AES engine (hardware) | Host CPU (BitLocker software mode) or SoC hardware AES engine (FileVault on T2/Apple Silicon) |
| Key storage location | HUK fused in controller silicon; MEK wrapped by KEK and never leaves the chip | TPM 2.0 (BitLocker), Secure Enclave UID (FileVault on T2/Apple Silicon), or user recovery key |
| Key is bound to | The specific SSD controller chip (non-transferable) | User credential or host security chip |
| Recovery path when drive dies | Must repair the original controller; chip-off yields only ciphertext | BitLocker: decrypt drive image offline with recovery key; controller swap viable. FileVault (T2/M-series): controller swap impossible (soldered NAND); logic-board repair required |
| Chip-off viability | Not viable; raw NAND is AES-256 ciphertext without the MEK | BitLocker: viable if recovery key is known; raw data can be decrypted offline. FileVault (T2/M-series): not viable; raw NAND is ciphertext bound to the Secure Enclave UID and cannot be decrypted offline |
| If key is lost | Data unrecoverable regardless of physical drive condition | Data unrecoverable regardless of physical drive condition |
What Does a Failing Encrypted SSD Look Like at the Interface Level?
An encrypted SSD whose firmware has panicked rarely reports its real identity to the host. The controller drops into a protective ROM mode and announces a generic factory string, a tiny diagnostic-mode capacity, or nothing at all. These interface-level markers are the first piece of evidence that the AES engine and the wrapped Media Encryption Key are still alive inside the controller, and that the recovery path is firmware repair or board-level rework rather than chip-off.
| Reported Identity / Capacity | Controller Family | What It Means |
| SATAFIRM Sx (S8, S9, S10, S11) | Phison SATA (PS3108, PS3109, PS3110, PS3111) | ROM-mode panic identity. Each Phison SATA silicon revision reports its own suffix: PS3108 reports SATAFIRM S8, PS3109 S9, PS3110 S10, and PS3111 S11. The firmware partition is unreadable; the controller booted ROM, the AES engine is dormant but intact, the wrapped MEK blob is still in the system area. PC-3000 SSD Phison utility enters Safe Mode via test-point shorting and rebuilds the system-area modules. |
| Raw controller name ("SM2262EN", "SM2263XT", "MAP1602") with 0-byte or 2MB capacity | Silicon Motion, Maxio NVMe | Controller failed to load the user-firmware overlay and is announcing its die identity in ROM mode. On supported families (SM2262EN, SM2263, SM2263XT, SM2267, SM2269) PC-3000 SSD injects a volatile microcode loader into controller RAM, rebuilds a virtual FTL in RAM on the drive itself, and images through the original AES engine. Maxio MAP1602 is not in the ACELab support matrix. Rossmann does not currently offer in-lab recovery for Maxio MAP1602. |
| 1.07 GB (1,073,741,824 bytes) capacity on a multi-terabyte drive | Silicon Motion SATA, some NVMe | Diagnostic-mode capacity reported when the FTL system area is corrupted but the ROM bootloader is intact. The wrapped MEK is preserved in a separate protected region; firmware reconstruction reads through the controller and the AES engine decrypts on the fly. |
| Drive enters and stays in BSY state; no command response on ATA or NVMe bus | Any family with corrupted boot-block translator | Controller is alive electrically but stuck in firmware initialization. The AES engine has not been keyed because the boot translator never completed. Service-mode entry via test-point short (Phison) or ROM pin bridging (Silicon Motion) bypasses the corrupted code path; the wrapped MEK remains addressable through the post-boot AES initialization sequence. |
| No enumeration in BIOS, no /dev node, no NVMe namespace | Any family with PMIC or power-rail failure | Electrical failure upstream of the controller die. The HUK fuse bank, the wrapped MEK blob, and the AES engine are physically intact; restoring the 0.9V to 1.2V controller core rail or the 1.8V to 3.3V NAND rails with component-level rework returns the drive to its pre-failure state. |
In all five rows the cryptographic chain is intact. The wrapped MEK lives in the system-area partition or the controller's on-die OTP region; the Hardware Unique Key fused into the silicon is untouched; the AES engine wakes the moment firmware initialization completes. Chip-off in any of these conditions destroys a recoverable case, because the moment the NAND is desoldered the HUK becomes unreachable and the wrapped MEK becomes mathematically inert. Board repair or firmware reconstruction through the original controller is the path that preserves the decryption chain: SATA board repair at $450–$600, NVMe at $900–$1,200, firmware reconstruction at $600–$1,200 (SATA) or $900–$1,200 (NVMe). For the full SSD service map, see ssd data recovery. For the contrast case of unencrypted legacy drives where chip-off remains viable, see chip-off NAND recovery.
What Is Cryptographic Erase, and Why Does Always-On AES Enable It?
Cryptographic Erase is the primary reason the SSDs that do implement always-on AES-256, typically enterprise and high-end consumer drives, encrypt everything by default. Instead of overwriting every NAND cell across wear-inducing erase cycles, the controller destroys the Media Encryption Key in milliseconds. Every byte of NAND ciphertext becomes mathematically inert, securely shredding the file system and user data without requiring physical NAND writes.
How Crypto-Erase Works at the Controller Level
The NVMe Sanitize command with the CryptoErase action, the ATA Security Erase Unit command on Class 0 SATA drives, and the TCG OPAL RevertSP method all converge on the same controller operation. The controller invalidates the wrapped MEK blob held in the system-area partition or in the on-die OTP region, the True Random Number Generator produces a new MEK, the new MEK is wrapped under the Hardware Unique Key, and the new wrapped blob is written to the same protected location. The NAND is left bit-for-bit identical to its pre-erase state. The data is still there as ciphertext. The decryption path is gone because the key that produced that ciphertext no longer exists in any addressable location.
PSID Revert: The Recovery-Hostile Form of Crypto-Erase
The Physical Security ID printed on the SSD label triggers a PSID revert under TCG OPAL: a factory-reset operation that destroys the current MEK regardless of any user PIN. PSID revert is intended for the case where the OPAL admin password is lost and the operator accepts data destruction in exchange for unlocking a bricked drive. Running PSID revert on a drive that still contains needed data is irreversible. No board-level repair, no firmware reconstruction, and no chip-off path recovers data after a successful PSID revert. The wrapped MEK blob has been overwritten with a new wrapped blob; the original key material is gone from every addressable location on the drive. We disclose this at evaluation when the intake symptom history includes an OPAL admin lockout that the user attempted to clear with a PSID revert.
Why Conventional Overwrite Tools Are Obsolete
Multi-pass overwrite utilities written for spinning magnetic media (DBAN-style zero-fills, Gutmann patterns) do not map cleanly to NAND. Wear-leveling and over-provisioning silently route writes around the cells the user intends to overwrite, leaving copies of plaintext in retired blocks that the controller still reads internally. Crypto-Erase sidesteps all of that: by destroying the MEK, every page on every cell across active capacity, over-provisioned capacity, and retired blocks becomes ciphertext with no key. Cryptographic destruction is complete the moment the wrapped MEK is overwritten, regardless of whether garbage collection has yet rewritten any NAND.
Recovery Implication: Crypto-Erase Cannot Be Reversed
A drive that arrives at intake with the symptom "I ran a secure erase and now I need the data back" is in the same category as failure class four in the diagnostic decision tree below: the cryptographic chain is permanently broken, the physical NAND is intact, and the data is mathematically inaccessible. We confirm this at evaluation by reading the TCG identity block with sedutil-cli --query and checking the date of last Sanitize via nvme sanitize-log; if either reports a completed cryptographic erase, we disclose the impossibility before any charge is incurred. The contrast is that an SSD with a dead controller and an intact wrapped MEK blob is a recoverable case: board-level microsoldering revives the original silicon, the AES engine wakes with the original MEK, and reads pass through as plaintext.
Why Is Board-Level Repair the Only Recovery Path?
When a hardware-encrypted SSD fails, the MEK is trapped inside the dead or malfunctioning controller. Replacing the controller destroys the key association. Component-level microsoldering to repair the power delivery circuit is the mandatory prerequisite for decryption: it revives the original controller, restores MEK access, & enables the AES engine to decrypt NAND reads during imaging.
- 01
Diagnose the failure point
Using FLIR thermal imaging and multimeter probing, we identify whether the failure is in the controller itself, the PMIC (Power Management IC), voltage regulators, decoupling capacitors, or the NAND interface. Many "dead controller" symptoms are actually failed passives on the power delivery circuit that prevent the controller from booting.
- 02
Component-level repair
Using Hakko FM-2032 microsoldering irons and Atten 862 hot air rework, we replace failed voltage regulators, capacitors, resistors, or rework BGA connections on the controller. The goal is to restore power delivery and signal integrity so the controller boots its firmware and initializes the AES engine with the original MEK.
- 03
Firmware stabilization and imaging
Once the controller boots, PC-3000 communicates with it via vendor-specific commands to stabilize the firmware and image the drive. Because the original controller is running, all reads pass through the AES decryption engine. The imaged data is plaintext, ready for file system analysis.
Rossmann's foundation in board-level repair applies directly to encrypted SSD recovery. Most data recovery labs handle firmware-level work but not component-level soldering. When the failure is electrical rather than logical, those labs cannot proceed. We can, because board-level repair is what this shop was built on.
The workflow runs under a no-fix-no-fee guarantee: free evaluation on arrival, firm quote before any work begins, and no charge if the controller cannot be revived and data cannot be imaged. Honest limit: when the original controller is physically destroyed (cracked die, burned silicon) on an SED or always-on encrypted drive, the Hardware Unique Key fused into that controller is lost; the wrapped Media Encryption Key can no longer be unwrapped, permanently severing the decryption chain. Chip-off will yield ciphertext with no path to decryption. We state this up front after evaluation rather than running up a bill on a job we cannot complete.
Why Does Hardware Encryption Force Board-Level SSD Recovery?
The data recovery industry pivoted with the arrival of always-on hardware AES-256. For modern NVMe and SATA solid-state drives implementing TCG OPAL 2.0, ATA Security, BitLocker eDrive hardware mode, Apple T2 or M-series Secure Enclave, or sitting behind Microsoft Pluton as the host root of trust, chip-off NAND extraction is cryptographically impossible. The only path to recovered data is microsoldering on the existing controller.
The Media Encryption Key Is Bound to the Original Controller
Modern SSD controllers generate the Media Encryption Key inside their secure boundary using an on-die True Random Number Generator. The MEK is held in controller SRAM or a logically isolated secure enclave, wrapped by a Key Encryption Key, and bound to a Hardware Unique Key fused into the silicon during semiconductor fabrication. The HUK is never exposed on the PCIe or SATA bus, never written to NAND in plaintext, and never readable by the host operating system. Every page written to NAND is transformed to AES-256 ciphertext before it leaves the controller; every page read passes through the same AES engine in the opposite direction.
Therefore, desoldering the NAND packages and reading them on a programmer yields high-entropy ciphertext with no decryption path. A theoretical attacker could attempt to decap the controller die and probe the fuse bank for the HUK, but modern secure silicon ships with active anti-tamper meshes and zeroization circuitry that destroy the volatile key state the moment package integrity is compromised. Commercial data recovery labs do not extract silicon-fused HUK material; the design intent of the fabricator is that no one does.
Encryption Schemes That Bind the Key to the Controller Silicon
The same cryptographic constraint applies regardless of whether the user actively configured a password. The following encryption topologies all keep the active MEK or its wrapping key inside silicon that must remain functional for any decryption to occur:
- TCG OPAL 2.0. Industry standard for Self-Encrypting Drives. The MEK lives in the SSD controller; user PINs unwrap a KEK that releases it at runtime.
- ATA Security (Class 0 always-on). The factory-generated MEK is active without user configuration. Password lockout, where present, wraps the MEK with a KEK derived from the password.
- BitLocker eDrive hardware mode. The Microsoft IEEE 1667 protocol offloads encryption to the SSD controller's AES engine. The BitLocker recovery key authenticates the controller; it does not itself decrypt NAND data.
- Apple T2 and M-series Secure Enclave. AES keys are bound to a hardware UID inside the SoC. The NAND packages are soldered to the logic board and have no independent cryptographic identity.
- Microsoft Pluton. A CPU-integrated security processor shipping in AMD Ryzen 6000 / 7000 / 8000 / 9000 / Ryzen AI, Intel Core Ultra 200V Series and Core Ultra Series 3, and Qualcomm Snapdragon 8cx Gen 3 and Snapdragon X Series. When Pluton acts as the BitLocker root of trust on a hardware-mode volume, it stores the wrapping key. The MEK still lives only in the SSD controller. Pluton being intact does not help if the SSD controller is dead.
Why the Controller Usually Survives the Failure
A drive that drops off the PCIe or SATA bus typically presents as a "dead controller" to the host, but the controller silicon is usually intact. The failure point is almost always in the surrounding power delivery network: a shorted Power Management IC stepping down 3.3V to the 0.9V to 1.2V controller core rail or the 1.8V / 2.5V / 3.3V NAND rails, a blown low-dropout regulator feeding the DRAM cache, a fractured multi-layer ceramic capacitor pulling a rail to ground, BGA solder cracking under thermal cycling, or ESD damage to the PCIe PHY transceiver pads. In each of these cases the controller die, the HUK fuse bank, and the wrapped MEK blob are physically intact. Restoring the power and signal environment lets the original controller boot, initialize its AES engine with the original MEK, and decrypt reads transparently during imaging.
The Microsoldering and Imaging Workflow
Board-level recovery on an encrypted SSD runs at an ESD-controlled bench, not in a laminar-flow environment, because solid-state silicon is hermetically packaged and immune to airborne particulate. The workflow our Austin, TX lab uses on hardware-encrypted SSDs is:
- Thermal localization. Inject a current-limited supply into the suspect rail and use a FLIR thermal camera to identify the component dissipating heat. This finds shorted PMICs, decoupling caps, and regulators in seconds without prolonged power application.
- Component-level rework. Replace shorted SMD passives and small ICs with a Hakko FM-2032 micro-soldering iron on an FM-203 base (an FX-951 base is interchangeable). For larger QFN PMICs and voltage regulators, use the Atten 862 hot-air rework station for temperature-controlled reflow.
- BGA reflow when required. When the controller or a NAND package needs reflow or transplantation to an electrically identical donor PCB, the Zhuo Mao precision BGA rework station runs the pre-heat, soak, reflow, and cool profile required for high-density packages without damaging adjacent silicon.
- Post-repair imaging through the original controller. Once the drive enumerates, interface it with the PC-3000 Portable III for vendor-specific firmware stabilization, FTL reconstruction in Technological Mode if the volatile mapping was lost, and full logical imaging. Because the original controller is running, every read passes through the AES engine and the imaged data is plaintext.
Board-level pricing for SATA encrypted drives starts at $450–$600; NVMe starts at $900–$1,200. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Repairing the original controller is the only recovery path when hardware encryption is in play, which is why every encrypted-drive case routes through our microsoldering bench rather than a chip-off rig. For the full controller family matrix, supported diagnostic interfaces, and firm tier pricing, see our ssd data recovery service overview.
Why Does Chip-Off NAND Extraction Fail on Modern Self-Encrypting SSDs?
Chip-off fails on self-encrypting SSDs because the AES-256 Media Encryption Key is wrapped by a Hardware Unique Key fused into the original controller silicon. The NAND packages hold only ciphertext. Desoldering the flash memory yields data with no mathematical path to plaintext. Board-level microsoldering to revive the original controller is the only valid recovery path.
MEK Generation Inside the Controller Secure Enclave
The Media Encryption Key is generated by the controller's on-die True Random Number Generator at first power-on and held in on-die SRAM inside a logically isolated secure region. The MEK never appears on the SATA or PCIe bus, never traverses the host DMA path, and never lives in NAND in plaintext. The wrapping chain is fixed: the MEK is encrypted under a Hardware Unique Key written into One-Time Programmable eFuses during semiconductor fabrication. Each die receives a statistically unique HUK at wafer test; the value is burned into the fuse bank, the test interface is permanently disabled, and the HUK is exposed only to the on-die AES engine through internal metal routing. Whatever wrapped MEK blob is persisted to a protected system-area partition on NAND, or to a small on-die OTP region, is unreadable without the HUK, and the HUK is not addressable from outside the die.
Why Raw NAND Becomes Mathematically Meaningless Ciphertext
Every user-data page reaching the NAND has already passed through the on-die AES-256-XTS engine with the MEK as the tweakable key. Once the NAND is separated from the original controller, three independent barriers collapse the attack: the HUK is no longer accessible, so the wrapped MEK cannot be unwrapped; the proprietary LDPC ECC parity layout, scrambler seed schedule, and per-channel interleaving pattern are controller-firmware-specific and absent from the raw dies; and the FTL logical-to-physical map that would order the encrypted pages into LBA sequence lives in controller DRAM and a controller-firmware-managed system area, not in any single NAND structure that can be reassembled externally. A chip-off programmer recovers high-entropy bytes that are indistinguishable from random data. There is no plaintext attack against a correctly implemented AES-256 block on consumer hardware; brute force is cosmologically infeasible.
Always-On AES by Controller Family
The following controller families implement always-on AES regardless of whether the user activates TCG OPAL 2.0, IEEE 1667 eDrive, or ATA Security Class 0 as protocol layers on top. Activating those layers changes the authentication wrapper around the MEK; it does not turn the AES engine on or off.
- Phison PS5000-series NVMe. PS5016/E16, PS5018/E18, PS5019/E19T, and PS5026/E26. Each uses an on-die AES-256 engine with the MEK held in controller SRAM and wrapped by a HUK derived from silicon eFuses. Encountered in Kingston, Corsair, PNY, Sabrent, Inland, and MyDigitalSSD NVMe lines. The recovery path for these controllers runs through our Phison architecture workflow with PC-3000 SSD Phison utilities for E16 and E19T families.
- Silicon Motion SM2262, SM2262EN, SM2263, SM2263XT. These controllers implement an AES-256-XTS engine on-die with the MEK held in controller-internal SRAM and wrapped by a HUK fused at fabrication. Found in ADATA XPG, HP EX, Patriot Viper, Lexar NM, and various OEM NVMe SKUs. PC-3000 SSD Silicon Motion utilities cover the SM226x family for firmware reconstruction and FTL repair after the controller is electrically revived.
- Samsung Polaris and Elpis. Proprietary AES blocks with the HUK fused at fabrication and never exposed outside the die. Polaris ships in the 960 EVO and 960 PRO; Elpis ships in the 980 PRO. Polaris and Elpis are absent from the ACELab PC-3000 SSD supported list; only the older Samsung families (S3C29, S4LJ, S4LN, used in 470, 830, 840, CM871, and PM-series SATA drives) are covered. Those drives are taken case by case; one that still enumerates may need only a logical recovery.
- Maxio MAP1602 (including MAP1602A). A DRAM-less 12 nm NVMe controller appearing in Lexar NM790, Fanxiang S790, and Acer Predator GM7. The AES engine is on-die with a fused HUK consistent with the rest of the modern controller cohort. The MAP1602 family is not present in the ACELab PC-3000 SSD support matrix. Rossmann does not currently offer in-lab recovery for Maxio MAP1602.
Board-Level Repair as the Only Scientifically Valid Path
For supported controller families, the recovery sequence is electrical first, cryptographic never. FLIR thermal localization identifies the failed PMIC, regulator, or shorted decoupling cap on the 0.9V to 1.2V controller core rail or the 1.8V to 3.3V NAND rails. Hakko FM-2032 microsoldering on an FM-203 base replaces SMD passives and small ICs; the Atten 862 hot-air station reworks QFN PMICs and voltage regulators; a Zhuo Mao precision BGA station handles controller or NAND reflow when required. Once the controller boots, PC-3000 SSD enters vendor-specific service mode, rebuilds the FTL or system-area modules, and images the drive through the original controller. Every read passes through the AES engine with the original MEK; the imaged output is plaintext. Pricing for this path is $450–$600 for SATA and $900–$1,200 for NVMe board repair.
For the converse case where chip-off is being considered for an unencrypted older drive, see chip-off NAND recovery, which explains why the technique works on legacy unencrypted controllers and fails on every modern SED. For the full controller matrix and tier pricing, see the SSD data recovery hub.
How Does Apple T2 and M-Series Encryption Affect Recovery?
Apple T2 and M-series chips implement hardware encryption through a Secure Enclave coprocessor. The volume keys are derived from a UID fused into the Secure Enclave silicon, and the NAND storage is soldered directly to the logic board. There are no removable drives to send to another lab; recovery requires repairing the logic board so the Secure Enclave can serve the decryption keys.
On a MacBook with a T2 or M-series chip, the SSD controller is integrated into the Apple silicon. The NAND chips are soldered to the logic board and communicate with the SoC through a proprietary bus. The Secure Enclave generates and stores the volume encryption keys.
If the MacBook logic board fails, the Secure Enclave keys are inaccessible. Desoldering the NAND yields AES-256 ciphertext with no path to decryption.
Recovery requires repairing the logic board so the T2 or M-series chip boots and the Secure Enclave can serve the decryption keys. This is T2/M-series data recovery at the board level: identifying which power rail, capacitor, or IC failure prevents the SoC from initializing, repairing it, and imaging the drive through the running system.
How Much Does Encrypted SSD Recovery Cost?
Encrypted SSD recovery falls into the circuit board repair or firmware recovery tier. SATA SSD board repair: $450–$600. NVMe board repair: $900–$1,200. Firmware recovery (if controller boots but firmware is corrupted): SATA $600–$1,200, NVMe $900–$1,200.
If board repair requires a donor drive for component harvesting, the donor cost is additional. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Rush service: +$100 rush fee to move to the front of the queue. Call (512) 212-9111 for a free evaluation.
SATA SSD Recovery Pricing
NVMe SSD Recovery Pricing
How Does BitLocker Hardware Encryption Mode Fail?
BitLocker can delegate encryption to the SSD controller instead of encrypting in software. When the SSD controller dies in this configuration, the BitLocker recovery key alone isn't enough; the controller must decrypt the data first, then BitLocker's key unlocks the volume. Recovery requires reviving the original controller through board-level repair at $450–$600 for SATA or $900–$1,200 for NVMe.
Windows 10 & 11 automatic device encryption often selected hardware mode on OPAL-compliant SSDs without asking the user. The OS detected the drive's SED capability & delegated encryption to the controller's AES engine. The user's BitLocker recovery key protected the MEK wrapper, but the controller performed all encryption and decryption operations in hardware.
This changed after researchers published CVE-2018-12037 & CVE-2018-12038, demonstrating that several SSD manufacturers implemented hardware encryption with flaws that allowed bypassing the authentication layer. Microsoft responded with ADV180028 in November 2018. Microsoft subsequently changed the Group Policy default via the September 2019 cumulative update (KB4516071) so new BitLocker volumes use software encryption instead of delegating to the SSD controller. Systems encrypted before that change may still be running in hardware mode.
Recovery Procedure for a Hardware-Encrypted BitLocker Drive
- Revive the SSD controller via board-level repair using Hakko FM-2032 microsoldering & FLIR thermal imaging to locate failed components on the power delivery circuit.
- Authenticate the OPAL session. Because BitLocker delegated encryption to the hardware, the BitLocker recovery key is used to unlock the SED locking range before imaging begins.
- Image the plaintext data using PC-3000 SSD. Once authenticated, the controller's hardware AES engine transparently decrypts the NAND reads, yielding fully decrypted data.
If the controller can't be revived, the data is permanently locked: the SSD's AES-256 layer encrypts the raw NAND, and the Media Encryption Key required to decrypt it is trapped inside the dead controller. Chip-off yields ciphertext with no path to the key. Board repair at $450–$600 (SATA) or $900–$1,200 (NVMe) is the only option.
When Does the BitLocker Clear Key Exception Apply?
When BitLocker is suspended for system updates or pre-provisioned by an OEM but not fully activated by a Microsoft account login, the Volume Master Key may be temporarily stored in the volume header as a clear key. Forensic tools can parse this metadata if it is intact. However, if BitLocker was fully enabled and the TPM is unreadable with no clear key state active, the data is mathematically unrecoverable.
The clear key is a documented Microsoft architectural feature, not a vulnerability. When Windows 10 or 11 suspends BitLocker to install an update, or when an OEM pre-provisions device encryption before the user completes Microsoft account setup, the Volume Master Key is written to the volume header in unencrypted form. Forensic suites can read this header and decrypt the volume without the user's password. This is a software-level edge case that applies to specific BitLocker states, not a universal bypass for all hardware-encrypted drives.
Consumers often misunderstand marketing that references this edge case. A clear key exists only during suspension or pre-provisioning. Once BitLocker is fully enabled with a TPM-backed key and no suspension is active, the volume header contains no plaintext key material. Without the TPM and without a clear key, brute-forcing AES-256 is impossible. The clear key exception is a recoverable software state. A dead controller with an active MEK is a hardware failure that requires board-level repair.
The BitLocker recovery key alone is not sufficient when the SSD controller is dead in hardware mode. The recovery key authenticates the controller's OPAL session; it does not decrypt raw NAND. The controller must first be revived through board-level microsoldering so its AES engine can decrypt the physical NAND. Only then does the recovery key unlock the volume. SATA board repair runs $450–$600; NVMe runs $900–$1,200. Free evaluation, no data = no charge.
What Is an OPAL Self-Encrypting Drive?
TCG OPAL 2.0 is an industry specification that standardizes how hardware encryption is managed on Self-Encrypting Drives. OPAL defines user authentication, locking ranges, and the key hierarchy that protects data on the NAND. When an OPAL drive's controller dies, the authentication layer adds complexity to recovery beyond basic Class 0 always-on encryption.
- Always-On Encryption (ATA Security Class 0)
- The SSD encrypts all data by default using a factory-generated MEK. No user authentication is required. The controller decrypts reads transparently. Data is protected from raw NAND extraction (chip-off) but accessible to anyone who can boot the controller. Most consumer SSDs from Samsung, WD, Kingston, & Crucial ship in Class 0 mode.
- TCG OPAL 2.0 Authentication
- Full OPAL with user authentication, locking ranges, & admin/user password separation. The MEK is wrapped with a KEK derived from the user's credentials. Booting the controller alone isn't enough; the correct password or recovery key must also be supplied. Enterprise SSDs from Samsung (PM9A3, PM893), Micron (7450 PRO), & Intel/Solidigm commonly ship with Class 2 capability.
- MEK/KEK Hierarchy
- The Media Encryption Key encrypts the NAND contents. The Key Encryption Key encrypts the MEK. The KEK derives from the user password or from a TPM-stored secret. Destroying any link in this chain makes the data unrecoverable. A PSID revert destroys the MEK itself, permanently erasing all data regardless of password knowledge.
- PSID Revert (Factory Reset)
- The Physical Security ID is printed on the drive label. A PSID revert generates a new MEK, rendering all existing NAND data permanently unreadable. This is designed for situations where the admin password is lost. It is a data-destruction operation, not a recovery tool. Running PSID revert on a drive with needed data is irreversible.
OPAL drives are harder to recover when the controller dies because the authentication layer must also be satisfied after repair. The controller must boot, accept the user's credentials, unwrap the KEK, and then decrypt reads using the MEK. If the firmware module that stores the wrapped key is corrupted, PC-3000 SSD's firmware recovery utilities ($600–$1,200 SATA, $900–$1,200 NVMe) can reconstruct the damaged modules while preserving the key material.
How Do Different Controllers Implement Hardware Encryption?
Each SSD controller manufacturer implements AES-256 hardware encryption differently. Samsung, Phison, Silicon Motion, Marvell, & WD each store the MEK differently, use different authentication interfaces, and require different PC-3000 SSD recovery modules. Recovery procedures that work on a Silicon Motion SM2262EN controller won't work on a Phison PS5016. Each requires its own diagnostic mode entry sequence & FTL reconstruction method.
The MEK storage location, the authentication interface, & the PC-3000 SSD recovery utility all vary by controller family.
| Manufacturer | Controller Family | Encryption Details | PC-3000 SSD Module |
| Samsung | Elpis, Piccolo, and the 970 and 990 PRO parts | Proprietary AES engine; HUK fused in controller silicon, MEK wrapped by KEK; proprietary LDPC ECC tied to controller | Samsung utility (SATA models; NVMe support limited) |
| WD / SanDisk | Marvell 88SS1074 (SATA); proprietary in-house (NVMe) | SATA: AES-256 via Marvell. NVMe: varies by model. The SN770 lacks hardware AES-256; portable/SED models (SanDisk Extreme, My Passport SSD) include it | Marvell utility (SATA and specific NVMe models via 88SS1093 support) |
| Micron / Crucial | Silicon Motion SM2259 variants (SATA); proprietary (NVMe) | Class 0 AES-256 on consumer models; TCG OPAL 2.0 on enterprise (7450 series) | Silicon Motion utility (SATA and NVMe via Portable III); Micron NVMe support varies by generation |
| Phison | PS5016 (E16), PS5018 (E18), PS5019 (E19T) | Most models implement AES-256; all use proprietary XOR scrambling. OEM configuration varies: some brands (e.g., Sabrent Rocket Q4 on E16) omit hardware AES. Used in Kingston, Corsair, PNY, Sabrent, Inland | Phison utility for E16, E19T. E18: firmware repair only (no data extraction) |
The PC-3000 SSD module for each controller family communicates using vendor-specific ATA or NVMe commands to enter diagnostic mode, read the FTL mapping table, & image the drive through the controller's decryption engine. Phison controllers require shorting diagnostic test points on the PCB to enter Safe Mode for firmware repair; Samsung controllers require a specific power-on sequence to enter service mode. These differences matter because using the wrong procedure on the wrong controller can overwrite firmware modules & destroy the MEK reference.
Board repair pricing depends on the controller complexity: SATA board repair runs $450–$600, NVMe runs $900–$1,200. The NVMe tier is higher because NVMe controllers have more complex power delivery circuits with multiple voltage rails feeding the PCIe PHY, DRAM interface, and NAND channels independently.
Why Is Hardware Write-Blocking Critical When Imaging Encrypted SSDs?
Hardware write-blocking prevents TRIM, UNMAP, and garbage collection commands from reaching the NAND during imaging. On encrypted drives, this is important because background OS tasks can rewrite firmware modules that store the wrapped Media Encryption Key blob or the FTL mapping tables. PC-3000 Portable III and Express intercept write commands at the bus level; software-only imaging can't do this.
How Bus-Level Interception Works
The PC-3000 Portable III and Express intercept write commands at the SATA or PCIe bus level before they reach the controller. TRIM, UNMAP, and Secure Erase are blocked. Read commands pass through unchanged. The NAND state is frozen exactly as it was when the drive arrived.
The Encrypted-Specific Risk of Unblocked Writes
On an encrypted SSD, garbage collection triggered by an unblocked TRIM command can rewrite system-area blocks. Those blocks hold the wrapped MEK blob, the FTL translator, and the firmware module index. Lose those blocks and the recovery path collapses even though the controller still powers on.
Why Software-Only Imaging Cannot Write-Block
Software-only imaging can't block the OS from sending UNMAP. The kernel owns the bus; the imaging tool is just another process. Background indexing or antivirus scans can send TRIM while sectors are being copied. Remote recovery sessions through the customer's OS carry this risk by design.
What to Look for in a Lab's Encrypted-SSD Workflow
For a customer evaluating labs, the presence or absence of hardware write-blocking in the workflow description is a credibility signal. Software-only imaging can't prevent OS background tasks from altering NAND state. We image every encrypted drive through PC-3000 Portable III or Express with hardware write-blocking active, then proceed to firmware stabilization. SATA board repair runs $450–$600; NVMe runs $900–$1,200.
How Does PC-3000 Handle Challenge/Response Authentication on OPAL-Encrypted Drives?
When an OPAL drive enters PC-3000 diagnostic mode, the AES engine is alive but locking ranges may stay locked. PC-3000 issues an OPAL authentication challenge; the user supplies the BitLocker recovery key or OPAL PSK; the controller verifies the KEK and unwraps the MEK. Without the correct key, data stays locked even on a functional controller.
The OPAL Authentication Flow in PC-3000
PC-3000 SSD communicates with OPAL controllers through vendor-specific diagnostic commands. When the controller boots into service mode, its AES engine initializes with the original MEK. The locking ranges remain in the locked state from the last OPAL session.
PC-3000 issues an authentication challenge to the OPAL security layer. The user supplies the 48-digit BitLocker recovery key or the OPAL Personal Security Key. The controller derives the KEK from that input, verifies it against the wrapped MEK blob, and unwraps the MEK if the credential matches.
How the Recovery Key Unlocks a BitLocker-Protected Drive
In BitLocker hardware mode, the recovery key unlocks the OPAL session. It doesn't itself decrypt raw NAND. The controller's AES engine performs the decryption transparently after the KEK verification succeeds. Every read command passing through the controller returns plaintext data to the PC-3000 imaging buffer.
What Happens When the Password or Recovery Key Is Lost?
If the original controller is revived through board-level repair but the user can't provide the BitLocker recovery key or OPAL PSK, the data remains locked. A functional controller with a locked OPAL range returns encrypted data just as a dead controller would. The difference is that the first case is recoverable if the key is found; the second case requires both board repair and key recovery.
Why Write-Blocking Matters During Authentication
Write-blocking during authentication prevents spurious writes from corrupting the OPAL state table. A TRIM command mid-session could alter locking range metadata, causing the controller to reject the KEK verification or remap the blocks holding the wrapped MEK. The PC-3000 bus-level interceptor keeps NAND state static.
Can Any Data Recovery Lab Bypass AES-256 Hardware Encryption?
No commercial data recovery lab can bypass AES-256 hardware encryption. The key space is 2^256, making brute-force attacks cosmologically infeasible. The Media Encryption Key is wrapped by a Hardware Unique Key fused into the controller silicon at wafer test. That HUK never appears on the SATA, PCIe, or NAND bus, and no software interface exports it.
The Mathematics of AES-256
AES-256 uses a 256-bit key. The total key space is 2^256, or roughly 1.15 x 10^77 possible combinations. Brute-forcing this key space would require more energy than exists in the observable universe. The cipher isn't the weak link in encrypted SSD recovery.
The HUK and MEK Wrapping Chain
The Media Encryption Key that encrypts every NAND page is itself encrypted by the Hardware Unique Key. The HUK is fused into One-Time Programmable eFuses inside the controller die during wafer test at the semiconductor foundry. Each die receives a statistically unique HUK. The test interface is permanently disabled after programming.
The HUK routes only to the on-die AES engine through internal metal layers. No external bus, JTAG port, or vendor command can read it. A donor controller has a different HUK. Every die is fused independently at manufacturing. A donor controller can't unwrap the MEK from the original drive.
Why "Proprietary Programming" Cannot Extract the Key
There's no software interface, JTAG port, or vendor diagnostic command that exports the HUK or the unwrapped MEK. Proprietary tools can't extract a key that has no export pathway by design. Modern secure silicon includes active anti-tamper meshes and zeroization circuitry that destroys the volatile key state the moment package integrity is compromised.
Competitor Claim vs. Cryptographic Reality
| Claim | Cryptographic Reality |
| "Carefully extract the AES encryption key" using proprietary methods | The plaintext MEK exists only inside the powered controller. No external interface exports it. Extraction is architecturally impossible. |
| "Proprietary programming converts encrypted data to legible text" | There is no vendor command or JTAG port that reads the HUK or unwrapped MEK. Without the HUK, ciphertext is mathematically indistinguishable from random data. |
| Brute-forcing a 256-bit AES key | 2^256 combinations. Cosmologically infeasible with any known or projected computing technology. Brute force is not a recovery strategy. |
No commercial data recovery lab decaps controller dies to probe fuse banks. The equipment cost, failure rate, and technical expertise required exceed the economics of any recovery job. Even if decapping were attempted, the anti-tamper mesh would trigger zeroization before the HUK could be read. Board-level repair to revive the original controller is the only viable path. SATA board repair runs $450–$600; NVMe runs $900–$1,200. No data, no fee.
How Do You Diagnose Whether Encryption Is the Recovery Blocker?
Most intake symptoms phrased as "encrypted drive can't be read" are not cryptographic dead-ends. The AES engine inside a modern SSD controller rarely fails on its own; it is the surrounding power-delivery and firmware infrastructure that fails. Triaging an encrypted SSD requires separating four distinct failure classes before treating any of them as an encryption problem. Three of the four are recoverable through board-level repair or firmware reconstruction, and the encryption layer remains transparent to the workflow.
- The drive does not enumerate on the SATA or PCIe bus at all. Symptom: no entry in BIOS, no /dev node on Linux, no Disk Management entry on Windows, no NVMe namespace via
nvme list. Diagnostic interface: a bench power supply current-limited at 1A, multimeter probing the 3.3V input rail and each downstream regulator output (typically 1.2V controller core, 1.8V NAND I/O, 2.5V DRAM if present), and FLIR thermal localization to find shorted decoupling capacitors or a failed PMIC die. The blocker is electrical, not cryptographic. Recovery path: component-level rework using a Hakko FM-2032 on an FM-203 base for SMD passives and an Atten 862 hot-air station for QFN PMICs. The AES engine, HUK fuse bank, and wrapped MEK blob are all physically intact; restoring power delivery boots the controller and reads pass through the decryption engine as plaintext. - The drive enumerates but reports wrong capacity, wrong model name, or zero bytes. Symptom:
hdparm -Ireturns garbled identity strings,nvme id-ctrlshows nonsense serial or model fields, or the LBA count reads as 0 / a tiny diagnostic-mode value (8MB, 30MB) instead of the advertised capacity. Diagnostic interface: PC-3000 SSD module identification for the controller family (Phison utility for E12 / E16 / E19T, Silicon Motion utility for SM2259 / SM2262 / SM2267 / SM2269, Marvell utility for 88SS1074 / 88SS1093). The blocker is firmware or FTL corruption: a damaged translator, lost block-allocation table, or corrupted system-area module. Recovery path: enter the controller's service mode (test-point shorting for Phison or ROM pin bridging for Silicon Motion) and rebuild the affected modules using PC-3000 SSD's reconstruction utilities at $600–$1,200 (SATA) or $900–$1,200 (NVMe). The AES engine and the wrapped MEK survive firmware corruption; once the FTL is rebuilt, the controller decrypts reads transparently. - The drive enumerates with correct identity but reads return I/O errors. Symptom: identity strings look right, the namespace is the expected size, but
dd if=/dev/sdX of=/dev/null bs=1Mreturns immediate or partway-through read failures. Diagnostic interface: query the security layer before assuming NAND wear. Runhdparm -I /dev/sdXand read the "Security" block for ATA Security state. Runsedutil-cli --query /dev/sdXto enumerate TCG OPAL 2.0 locking ranges, admin/user PIN configuration, and lock state. Runmanage-bde -statuson Windows to determine whether BitLocker is running in hardware mode and which recovery key applies. If a locking range is locked, supply the BitLocker recovery key or OPAL PSK before any imaging attempt; the controller will not return plaintext until the KEK has unwrapped the MEK. When the locking range is unlocked but reads still fail, the issue is NAND-level wear or read-disturb beyond ECC correction, which routes back to PC-3000 SSD firmware recovery rather than to the encryption layer. - The controller silicon itself is physically destroyed. Symptom: visible cracked package, burned silicon, delamination of the controller package, exposed bond wires, or any prior decap attempt. Diagnostic interface: stereo microscope at 20x to 80x, FLIR thermal imaging to confirm no rail can be brought up without a dead short through the controller die. This is the failure class where the Hardware Unique Key fused into the controller silicon is lost: the wrapped Media Encryption Key on NAND can no longer be unwrapped because the HUK that would unwrap it no longer exists. Chip-off would yield ciphertext with no decryption path. We disclose this category at evaluation rather than billing for a recovery the physics will not support.
The encryption layer is the true blocker only in failure class four. Classes one through three preserve the HUK, the wrapped MEK, and the AES engine; the recovery workflow proceeds exactly as on an unencrypted drive once the underlying electrical or firmware fault is corrected, because the controller decrypts reads transparently the moment it boots. Free evaluation determines which class the drive belongs to before any quote is issued. Call (512) 212-9111.
Which Controller Families Ship With Always-On AES, and When Is the DEK Still Recoverable?
On a Self-Encrypting Drive without a password, the Data Encryption Key (DEK) lives inside a controller-resident blob, wrapped by a Hardware Unique Key fused into the silicon during manufacturing. The DEK never leaves the controller in plaintext. The wrapped blob is stored in a protected NAND partition or on-die OTP area, rendering chip-off extraction mathematically useless.
SED with User PIN vs. ATA Security Class 0: Where the DEK Lives
On a Class 0 always-on drive, the controller initializes the DEK on first power-up with no user input. Anyone who can boot the controller reads plaintext through it. On a TCG OPAL drive with a user PIN, the controller adds a Key Encryption Key derived from the PIN and uses it to wrap the DEK. The wrapped DEK still lives in the controller's secure region; the PIN only unwraps it at runtime. Both architectures defeat chip-off recovery, but for different reasons. Class 0 defeats chip-off because the HUK is required to unwrap the DEK; OPAL defeats it for the same reason plus the PIN-derived KEK requirement. Decapping the controller die to read the HUK is not a service offered by mainstream data recovery labs; the silicon is designed to resist optical and electrical probing of the fuse bank.
Controllers That Default to AES-256 Always-On
- Phison E16, E18, E19T families. Most OEM configurations enable hardware AES-256 with a factory-generated DEK. Used by Kingston, Corsair, PNY, Sabrent, Inland, MyDigitalSSD. Some OEM SKUs (Sabrent Rocket Q4 on E16) ship with AES disabled in firmware; the drive label and TCG identify report disclose this.
- Silicon Motion SM2246EN, SM2258, SM2259, SM2262, SM2263, SM2264, SM2267, SM2269. AES-256 is on by default in the reference firmware. Used widely in Crucial MX SATA, Adata, Patriot, HP, Lexar, and Micron consumer NVMe.
- SandForce legacy SF-1200, SF-2281, and SF-3700. Originally LSI/Sandforce, later acquired by Seagate. Shipped with AES-128 (SF-1200/2281 early) or AES-256 (SF-2281 late silicon, SF-3700) always-on. Found in OCZ Vertex 3/4, Vector, Agility 3/4, Intel 330/335/520/530, and Kingston HyperX 3K. These drives implement always-on AES, but the AES key is stored in a controller-internal blob; controller swaps fail for the same reason as modern families.
- Marvell 88SS1074, 88SS1093, 88SS1100. These controllers support AES-256 and TCG Opal, but whether hardware encryption is active depends on the OEM drive. WD Blue and WD Green SATA ship without hardware AES enabled, so a Marvell controller on the board does not by itself mean the data is encrypted.
- Samsung Elpis, Piccolo, and the 970 and 990 PRO controllers. Proprietary AES engine with HUK fused in controller silicon. Default behavior is always-on; the user-visible "encryption status" in Samsung Magician reflects whether a user password has wrapped the MEK, not whether the AES engine is active.
When PMIC or Power-Rail Failure Preserves the DEK
An SSD that fails to enumerate on the SATA or PCIe bus is often diagnosed externally as "dead controller," but the controller silicon is frequently intact. Common electrical failure modes that leave the controller die undamaged: shorted decoupling caps on the 1.2V or 1.8V core rail, blown PMIC step-down converters, failed LDO regulators feeding the DRAM rail, cracked solder joints on BGA balls under thermal cycling, and ESD damage to the SATA or PCIe PHY transceiver pads (not the AES core).
In every one of these cases, the DEK and the wrapped key blob are physically intact. Restoring power delivery and signal integrity boots the controller, the AES engine initializes with the original DEK, and reads through the controller produce plaintext. The repair path uses Hakko FM-2032 microsoldering for cap and resistor replacement, Atten 862 hot-air rework for PMIC reflow or replacement, FLIR thermal imaging to locate shorts, and PC-3000 SSD for firmware stabilization once the drive enumerates. Chip-off in this scenario destroys a recoverable case: desoldering the NAND yields ciphertext that can never be decrypted because the DEK extraction step is no longer available once the original controller is removed from the PCB.
The contrast matters at intake. A drive that arrives with shorted passives or a dead PMIC is a board-repair candidate at $450–$600 (SATA) or $900–$1,200 (NVMe). A drive that arrives with a cracked controller die, burned silicon from a power surge, or visible delamination of the controller package is a different category: the HUK is gone with the silicon, the wrapped DEK can no longer be unwrapped, and chip-off would still yield ciphertext with no decryption path. We disclose this at evaluation rather than billing for a recovery the physics will not support. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
When Can Recovery Software Access an Encrypted SSD?
Recovery software works on encrypted SSDs only when the controller is functional. A running controller decrypts reads transparently, so Disk Drill, EaseUS, PhotoRec, or R-Studio sees plaintext. When the controller is dead or stuck in a firmware fault state, software can't communicate with the drive at all.
Software Works When
- The SSD is detected in BIOS & mounts (or partially mounts) in the OS, and the issue is logical: accidental deletion with TRIM disabled, corrupted partition table, formatted volume.
- The controller is running its AES engine normally, so the software's sector reads return plaintext data.
- TRIM has not already executed on the deleted blocks. Once the controller unmaps the logical addresses and garbage collection erases the NAND blocks, neither software nor a lab can recover the data.
Software Fails When
- The SSD isn't detected in BIOS (dead controller, shorted PMIC, failed voltage regulator). Software needs a functioning interface to send commands.
- The drive reports wrong capacity, wrong model name, or shows 0 bytes. These are firmware corruption symptoms that require PC-3000 SSD to repair the FTL & module tables.
- The controller is dead on an encrypted drive. Chip-off NAND extraction yields AES-256 ciphertext without the original key.
Software tools are worth trying first if the drive powers on and is recognized. They cost between $0 (PhotoRec, open source) and $90 (Disk Drill, R-Studio). If the SSD isn't detected or the controller is in a fault state, stop. Continued power cycling stresses degrading NAND cells. Send the drive for a free evaluation; board repair starts at $450–$600 for SATA and $900–$1,200 for NVMe.
Can you recover data from a hardware-encrypted SSD?
Yes, if the original controller can be revived through board-level repair. The AES-256 key is stored on the controller silicon. By repairing or reworking the controller, the decryption chain remains intact and the drive decrypts data transparently during imaging. SATA SSD board repair: $450–$600. NVMe: $900–$1,200. Free evaluation, no data = no charge.
Does chip-off recovery work on encrypted SSDs?
Not for drives with hardware encryption. Chip-off reads raw NAND data by desoldering the flash chips. On an encrypted drive, the raw NAND contains AES-256 ciphertext. Without the key stored in the original controller, the data cannot be decrypted. Chip-off is only viable for older drives without always-on encryption or for unencrypted controllers.
Is my SSD encrypted even if I never turned on encryption?
Many mainstream and enterprise SSDs manufactured after 2015 implement always-on hardware encryption (sometimes called Class 0 under the ATA Security specification). The controller encrypts every write and decrypts every read using a key generated during manufacturing. This happens transparently; the OS never sees it. The data on the NAND is ciphertext. Some consumer NVMe drives omit hardware encryption entirely. If you also set a user password (ATA Security, OPAL, or BitLocker hardware mode), the media encryption key itself is encrypted with your password.
What is the difference between hardware encryption and BitLocker?
Hardware encryption (SED) is performed by the SSD controller using a key stored in the controller silicon. BitLocker is software encryption performed by Windows using a key stored in the TPM or entered by the user. They can operate independently or together. When BitLocker uses 'hardware encryption mode,' it delegates encryption to the SSD controller via OPAL commands. Recovery from a dead hardware-encrypted drive requires reviving the controller, then authenticating with the BitLocker recovery key so the controller decrypts data during imaging.
What happens to the encryption key if the controller is replaced?
The AES-256 media encryption key is unique to the specific controller chip. Replacing the controller with an identical model does not transfer the key. The new controller generates its own key during initialization, making the existing NAND data permanently unreadable. This is why controller replacement is not a recovery option for encrypted drives; the original controller silicon must be repaired.
Can recovery software access data on an encrypted SSD?
Recovery software like Disk Drill, EaseUS, or R-Studio works when the SSD controller is functional and the issue is logical (accidental deletion with TRIM disabled, partition corruption). When the controller is running, it decrypts reads transparently, so software sees plaintext. If the controller is dead, software can't communicate with the drive at all. Lab recovery with PC-3000 SSD and board-level repair starts at $450–$600 for SATA and $900–$1,200 for NVMe.
Does a PSID revert destroy data on an OPAL SSD?
Yes. A PSID (Physical Security ID) revert is a factory reset for OPAL Self-Encrypting Drives. It destroys the current Media Encryption Key and generates a new one. All existing data becomes permanently unreadable because the ciphertext on the NAND no longer matches any accessible key. Never run a PSID revert on a drive that contains data you need.
Does Microsoft Pluton change SSD recovery when BitLocker fails?
No. Pluton stores the BitLocker wrapping key inside CPU silicon (AMD Ryzen 6000 / 7000 / 8000 / 9000 / Ryzen AI, Intel Core Ultra 200V Series and Core Ultra Series 3, Qualcomm Snapdragon 8cx Gen 3 and Snapdragon X Series). On a hardware-mode BitLocker volume, the actual Media Encryption Key still lives in the SSD controller. If the SSD controller dies, an intact Pluton chip cannot decrypt raw NAND; the wrapping key alone is mathematically insufficient. The path is board-level microsoldering on the SSD at $450–$600 for SATA or $900–$1,200 for NVMe. The reverse case is recoverable: if the host motherboard or CPU containing Pluton dies but the SSD is intact, the 48-digit BitLocker recovery key (backed up to a Microsoft Account or Entra ID) unlocks the controller in any compatible host or on a PC-3000 Portable III imaging suite.
Does TRIM behave differently on a hardware-encrypted SSD?
No. TRIM and NVMe UNMAP commands enter the controller and are processed inside the same data path that already performs AES on every write. When the OS reports a deleted file, the controller drops the logical-to-physical mapping for those LBAs and returns the underlying NAND blocks to the free pool for garbage collection. The recovery window for deleted files is the same as on any unencrypted SSD: effectively zero once garbage collection runs on the affected blocks, because the physical NAND is rewritten as part of the wear-leveling cycle. Cryptographic erase via the NVMe Sanitize command or the OPAL RevertSP method is a separate operation: it destroys the Media Encryption Key inside the controller, which renders all NAND ciphertext mathematically unreadable in milliseconds regardless of whether garbage collection has yet rewritten any blocks. If you need a free evaluation, call (512) 212-9111.
BitLocker on a Samsung Evo SSD: is hardware mode or software mode active?
It depends on when the volume was encrypted. Windows installations dating to before September 2019 on Samsung 840 EVO, 850 EVO, and 860 EVO with TCG OPAL capability frequently selected hardware encryption mode through BitLocker automatic device encryption. Microsoft advisory ADV180028 (November 2018) and the September 2019 cumulative update KB4516071 changed the Group Policy default to software encryption, but existing volumes encrypted under the prior default are still running in hardware mode unless they were decrypted and re-encrypted. To check on a live system, open an elevated command prompt and run `manage-bde -status`; the "Encryption Method" line reports "Hardware Encryption" when the SSD controller is performing the work and "XTS-AES 128" or "XTS-AES 256" when Windows is. The Samsung 840 EVO and 850 EVO were specifically named in the CVE-2018-12037 implementation findings. If an 850 EVO running BitLocker in hardware mode arrives with a dead controller, the recovery path is board-level repair of the original controller followed by OPAL authentication with the 48-digit BitLocker recovery key; chip-off on that drive yields only ciphertext. SATA board repair: $450–$600. Call (512) 212-9111 for a free evaluation.
How do I know whether encryption is the actual blocker on my SSD?
Encryption is rarely the primary blocker; electrical failure of power-delivery components is. The bench-test progression at intake is: (1) the drive does not enumerate on the SATA or PCIe bus at all, which means the blocker is electrical, not cryptographic, and board repair is the recovery path; (2) the drive enumerates but reports wrong capacity, wrong model name, or zero bytes, which means the FTL or firmware modules are corrupted and PC-3000 SSD can address it while the AES engine remains alive once firmware is stabilized; (3) the drive enumerates with correct identity but reads return errors, in which case running `hdparm -I` on Linux or `nvme id-ctrl` reveals the TCG security feature set and `sedutil-cli --query` enumerates OPAL state, so a locked locking range can be unlocked with the BitLocker recovery key or OPAL PSK before imaging; (4) the controller die itself is physically destroyed (cracked package, burned silicon visible under microscope), which means the Hardware Unique Key fused into that silicon is lost, the wrapped MEK can no longer be unwrapped, and no recovery path exists. SATA board repair: $450–$600. NVMe: $900–$1,200.
ATA Security vs TCG OPAL 2.0 vs IEEE 1667 eDrive: which one is on my SSD?
All three are protocol layers sitting on top of the same controller-resident AES engine; a given modern SSD typically supports all three concurrently, and which one is active depends on what the OS or the user configured. ATA Security is the legacy SATA password protocol (SECURITY SET PASSWORD and SECURITY UNLOCK ATA commands); it wraps the MEK with a password-derived KEK but does not expose key-rotation or locking-range features. TCG OPAL 2.0 is a richer SATA and NVMe protocol that adds locking ranges, admin and user PIN separation, and the PSID revert operation. IEEE 1667 with BitLocker eDrive is the Microsoft profile that lets the operating system delegate encryption operations to an OPAL-capable controller. To check which is active: `hdparm -I /dev/sdX` on Linux shows ATA Security state, `sedutil-cli --query /dev/sdX` shows OPAL state, and `manage-bde -status` on Windows shows BitLocker mode. Regardless of which layer is active, recovery from a dead controller requires reviving the original silicon; the MEK is bound to the controller in every case. Board repair: $450–$600 (SATA), $900–$1,200 (NVMe).
Can a data recovery lab bypass or crack AES-256 hardware encryption?
No. AES-256 has a key space of 2^256, making brute-force attacks cosmologically infeasible. The Media Encryption Key is wrapped by a Hardware Unique Key fused into the controller silicon at wafer test. That HUK never appears on any external bus, and no software interface, JTAG port, or vendor command exports it. A donor controller has a different HUK and can't unwrap the MEK from the original drive. Modern secure silicon includes anti-tamper meshes and zeroization circuitry that destroy key state if the package is compromised. Board-level repair to revive the original controller is the only path. SATA: $450–$600. NVMe: $900–$1,200.
Can recovery software unlock BitLocker on an encrypted SSD without the recovery key?
No. On a hardware-encrypted SSD with BitLocker in hardware mode, the SSD controller's AES engine performs all encryption and decryption. The BitLocker recovery key authenticates the OPAL session; it doesn't itself decrypt raw NAND. Without the recovery key, the controller keeps the locking range locked and returns ciphertext. Recovery software like Disk Drill, EaseUS, or R-Studio communicates through the operating system and can't bypass the controller's OPAL state. The only path is reviving the original controller through board-level repair, then supplying the recovery key to unlock the OPAL session before imaging. SATA board repair: $450–$600. NVMe: $900–$1,200.
Related Encryption Recovery Pages
Full SSD recovery service overview
Secure Enclave encrypted Mac recovery
Physical NAND extraction for unencrypted drives
BitLocker device encryption recovery
Firmware-level controller repair
Encrypted SSD stopped working?
Board-level repair preserves the decryption chain. SATA: $450–$600+. NVMe: $900–$1,200+. Free evaluation, no data = no fee.
