Free Recovery Method
How to recover data from a crashed hard drive for free
If the damage is mild, you can often clone the readable data at home using ddrescue. This is the method we recommend: grab the easy sectors first, then carefully retry the rest. If your drive clicks, beeps, or is not detected, skip this guide and talk to a lab.
How to recover data from a hard drive for free
To recover data from a failing hard drive for free, use GNU ddrescue inside SystemRescue Linux. Download SystemRescue, flash it to a USB drive, and boot from it. Run lsblk to identify your failing source drive and an empty target drive of equal or larger capacity. Run ddrescue in two passes. The first pass copies every sector that reads at normal speed and skips anything slow or unresponsive. The second pass goes back over what the first pass left unread, one sector at a time, then retries the bad sectors once. The second pass runs with direct disk access. Once both passes finish, disconnect the source drive, mount the clone read-only, and copy your files to a third healthy drive. This method works for drives with bad sectors, corrupted partitions, or degraded read speeds. It will not work if the drive clicks, beeps, or grinds. Those symptoms indicate physical head or motor failure requiring professional clean-bench recovery.
Is Your Drive Eligible for DIY Recovery?
DIY ddrescue recovery works on drives that still spin, get detected in BIOS, and have bad sectors, corrupted partitions, or slow reads. It does not work on drives that click, beep, grind, or go undetected. Check your SMART data first. If it shows a BAD status, skip DIY.
If your drive passes the eligibility check, the procedure clones the entire drive sector-by-sector to a healthy target. You recover files from that clone, never the original.
How this works
We use GNU ddrescue inside SystemRescue Linux to image the failing drive (source) onto an equal-or-larger healthy drive (target). ddrescue reads in two passes: a fast sweep that skips anything slow, then a retry pass that goes back for the difficult sectors. You work from the clone afterward, never the original.
Stop if your drive:
- Clicks or beeps. Persistent clicking is a hardware fault. The sound won't tell you which part failed. We find that out on the bench. A beeping external drive is most often short on power, so try another cable, port and power supply first.
- Screeches or grinds. That's a hardware fault too. Running it longer destroys the magnetic layer.
These need clean-bench recovery.
Do not open the drive. Dust and fingerprints on exposed platters crash the heads and score the surface once the drive spins again. Head swaps require a particle-controlled environment.
What you need
Gather these before starting
SystemRescue USB
Bootable Linux with ddrescue pre-installed. No setup required.
Download & create USB →Source Drive
Your failing hard drive. Leave it powered off until you are ready to image.
Target Drive
Empty drive, equal or larger capacity than the source. All data on the target will be overwritten.
SATA Dock or Adapter
USB-to-SATA dock, or a desktop with spare SATA ports for both drives.
Step-by-step recovery
Six steps, from making a SystemRescue USB stick to copying your files off the clone.
- 1
Create a SystemRescue USB
Download SystemRescue and flash the ISO to a USB drive (2 GB minimum). On Windows, use Rufus. On Linux, use
dd. SystemRescue includes ddrescue out of the box; no additional packages to install.Verify your download checksum against the one listed on the SystemRescue website before flashing. A corrupted boot USB will waste time. - 2
Boot into SystemRescue
Plug in the SystemRescue USB and reboot. Press your computer's boot-menu key at startup and select the USB stick. Choose the default SystemRescue environment when prompted. You will land at a Linux command line.
SystemRescue won't boot with UEFI Secure Boot turned on. Turn Secure Boot off in your BIOS/UEFI settings first. - 3
Identify source and target drives
Linux names drives differently than Windows. Run one of these commands to list every connected drive with its size:
# List drives with sizeslsblk# Or show partition tablesfdisk -lTriple-check drive letters before proceeding. Writing to the wrong drive destroys its contents. Match by size and partition layout, not by name alone. - 4
First pass: grab the easy data
This copies every sector that reads within a reasonable time and skips anything slow or unresponsive. Replace
/dev/sdXwith your source and/dev/sdYwith your target.ddrescue -f -n -a 5120000 /dev/sdX /dev/sdY logfile.log-nNo scraping (fast pass only)-a 5120000Skip regions below ~5 MB/slogfile.logTracks progress for resuming - 5
Second pass: retry the difficult sectors
Warning: Repeatedly retrying bad sectors on a mechanically degrading drive generates thermal and mechanical stress on the read-head assembly that can cause permanent head collapse and total data loss. The following command should only be used if the drive is NOT clicking, grinding, or dropping offline during the first pass.Once the fast pass finishes, run this command to go back for the sectors that were skipped. The logfile tells ddrescue exactly what still needs reading.
ddrescue -f -d -r1 /dev/sdX /dev/sdY logfile.log-dDirect disk access (bypasses cache)-r1Retry bad sectors only once to minimize mechanical stresslogfile.logContinues where pass 1 left offStop here if needed: If you encountered a high number of bad sectors in the first pass, stop here and consult a professional lab. Continuing to retry on a drive with extensive bad sectors risks total head failure and permanent data loss. - 6
Mount the clone and copy your files
Disconnect the failing source drive. Mount the target (your clone) and copy files to a third healthy drive. If the file system is corrupted, run
fsckorchkdskon the clone only.Mount read-only first:mount -o ro /dev/sdY1 /mnt/recoverymounts the clone read-only while you look through the file system.
What Mistakes Destroy Hard Drive Data During DIY Recovery?
Three operations account for most avoidable data loss during DIY recovery: running repair tools on the original drive, using an undersized target, and continuing to power a clicking drive. Each one turns a recoverable failure into a permanent one.
Running CHKDSK or Disk Utility on the original
Both tools write to the drive during repair. On a failing drive with bad sectors, this overwrites recoverable data. Only run repair tools on the clone.
Using a target drive smaller than the source
ddrescue clones at the sector level. A smaller target truncates the image, corrupting file system structures that reference later sectors. Match or exceed the source capacity.
Repeatedly powering a clicking drive
Each power cycle on a clicking drive lets the damaged heads drag across the platters.
What DIY recovery software can actually recover
Consumer recovery tools like Recuva, Disk Drill, R-Studio, and PhotoRec work on one category of data loss: logical failures on physically healthy media. If the drive spins normally, gets detected at its correct capacity, and makes no unusual sounds, these tools can scan the file system and reconstruct deleted or corrupted data structures without opening the chassis.
- Accidental deletion
- When a file is deleted, the operating system marks its MFT (Master File Table) or FAT entry as available but does not overwrite the file contents immediately. Recovery software scans for these orphaned entries and rebuilds the directory structure. This works until the sectors are overwritten by new data.
- Quick-formatted partitions
- A quick format resets the file system metadata without zeroing the underlying sectors. R-Studio and PhotoRec can carve files directly from raw sectors by matching known file signatures (file headers) even after the file system is gone.
- Corrupted or RAW file systems
- When the file system is corrupted, recovery tools parse what's left of the metadata and the sector data to rebuild the file tree.
Prerequisite: healthy hardware
Every tool listed above reads sectors through the operating system's storage stack. The OS sends ATA commands, the drive's firmware translates those commands to physical head positions, and the heads read the magnetic signal off the platter. If any component in that chain is broken (dead PCB, seized motor, failed heads, corrupted firmware), the software never reaches the data.
No amount of scanning or retries changes that. The drive itself must be mechanically and electronically functional for consumer software to help.
ddrescue vs HDDSuperClone: Which Tool Fits Your Failure?
ddrescue works on drives that respond to ATA commands and read most sectors at normal speed. HDDSuperClone adds a Direct AHCI mode that bypasses the OS drivers, and it lets you set your own timeouts. Neither replaces a hardware imager for drives that click or drop offline.
When ddrescue is the right tool (and when it is not)
ddrescue is the right tool for logical recovery and for imaging drives that still respond to ATA commands and read most sectors at normal speed. Deleted partitions, corrupted file systems, and drives with scattered bad sectors that still complete identify-device are all in scope. A SMART PASSED status is not a guarantee of drive health, so judge eligibility by whether the drive still responds and reads most sectors, not by the overall SMART flag. Outside that envelope, ddrescue is destructive.
ddrescue reads through the Linux kernel block device layer. The kernel does not understand head geometry or service-area state; it issues a read, waits up to the standard I/O timeout for a reply, and then either accepts the data or returns an error.
On a mechanically failing drive, that wait period is spent with a degraded head dragging across damaged media, accelerating slider wear and head-disc contact damage. A drive that clicks intermittently is the worst case: ddrescue keeps the bus open while the head retries, turning a recoverable head-degradation event into a head crash.
HDDSuperClone vs ddrescue: Key Differences
| Feature | ddrescue | HDDSuperClone / OpenSuperClone |
| Drive interface | Linux kernel block device layer | Direct AHCI mode bypasses the OS drivers. ATA pass-through still goes through them |
| Reset timeouts | OS kernel default (seconds per sector) | User-set command timeouts that trigger a soft reset in its direct modes |
| Failing head zones | Skips ahead past read errors and slow areas | Self-adjusting skip that its author says tries to skip out of a bad head in about 7 bad reads |
| Read direction | Forward and reverse (the -R option reverses every pass) | Forward and reverse; approaches bad blocks from both sides |
| Power cycling | Not supported | Optional control of external USB power-relay switches for automated cycling |
| OS support | Linux, macOS, Windows (limited) | Linux only |
We go through each of these differences in our full HDDSuperClone and ddrescue comparison.
HDDSuperClone is a ddrescue-style imager with smarter head management. The original developer ceased commercial work in 2022 and released the source under GPL; it is now maintained as the community fork OpenSuperClone. It only runs on Linux. Its main advantage over ddrescue is its Direct AHCI mode, which talks to the SATA controller directly and bypasses the OS drivers.
HDDSuperClone also has a self-adjusting skip. Its author says it tries to skip out of a bad head in about seven bad reads. You set your own timeouts, and in its direct modes a timeout triggers a soft reset. It can also drive USB relay boards for automated power cycling.
It is a real upgrade for hobbyists with one failing drive. It is not a replacement for the PC-3000.
HDDSuperClone is software running on a commodity SATA controller, so it has no hardware command interception, cannot definitively map damaged physical heads, and cannot touch firmware-zone (service area) corruption or controller-level head map damage. When the drive needs service-area repair, ROM work, or head-stack replacement, the imaging tool stops being the bottleneck and the work moves to a full lab recovery workflow.
Where DIY recovery becomes destructive
Running recovery software on a drive with physical or firmware damage does not just fail to recover data. It actively makes the problem worse. The operating system's storage stack was designed for healthy drives, and its retry behavior turns minor degradation into permanent destruction.
Clicking or grinding: a hardware fault the bench identifies
A clicking sound means the drive cannot acquire its servo tracks, so the actuator arm seeks and retracts in a loop. Damaged heads do that. So does Service Area firmware corruption, a dead preamp, and a board carrying the wrong adaptive parameters. Running recovery software before anyone knows which forces the OS to send hundreds of read commands, each one working the mechanism across the platter surface.
The result is microscopic scoring on the magnetic layer. A drive that arrives at a lab clicking can leave a DIY session with surface damage or become unrecoverable, and the difference is a tier: $1,200–$1,500 for a head swap against $2,000 once the platters are scored.
Firmware corruption: Service Area damage
The Service Area (SA) is a reserved region of the platters that stores the drive's microcode, translator tables, and defect lists. The translator maps linear Logical Block Addresses (LBAs) to physical platter geometry. If the translator modules get corrupted, the drive loses its LBA-to-physical-sector map. It may drop into a firmware busy state.
Consumer software cannot access the Service Area. It operates above the firmware layer through standard ATA or SCSI commands. When the translator is corrupted, the drive cannot convert those standard commands to physical locations, so the software sees nothing to recover. Rebuilding the corrupted modules takes vendor-specific Techno Mode access with a PC-3000.
G-List exhaustion and firmware locks
Every hard drive maintains a Grown Defect List (G-List) that tracks sectors discovered as bad during normal operation. The firmware automatically remaps these sectors to spare areas. The G-List has a finite capacity that varies by drive model and manufacturer.
Aggressive scanning with recovery software forces the drive's firmware to process hundreds or thousands of bad sectors in rapid succession. If the G-List fills to capacity, the firmware has no remaining spare sectors for remapping. Some drives respond by entering a busy state where they accept commands but never complete them. Consumer tools can't get into a drive in that state.
CHKDSK on a failing drive
CHKDSK assumes healthy hardware. When it encounters file system inconsistencies, it overwrites MFT entries to restore volume consistency, orphaning actual files into numbered .chk fragments. On a drive with spreading bad sectors, CHKDSK forces intensive read/write operations across the entire volume while simultaneously rewriting the file system structures that recovery tools depend on.
That does damage both ways. The forced I/O wears the hardware down further, and the metadata that maps files to sectors gets overwritten.
The common thread: consumer tools assume the drive's own firmware is operational and that reading a sector is safe. On a degrading drive, every read command carries a cost measured in additional platter damage. Professional tools like PC-3000 bypass the OS entirely, disable internal retries, set millisecond-level timeouts, and image healthy regions first.
Why CHKDSK Destroys Failing Drives
CHKDSK damages a physically failing hard drive. Both chkdsk /f & chkdsk /r write to the disk to repair the file system, & /r adds a full-surface read scan. On a drive with spreading bad sectors, those forced reads make weak heads retry over damaged media & score the platters.
CHKDSK has no read-only repair mode. Running it with /f or /r writes file-system metadata repairs to force the volume back to a consistent state. Run it with no switches and CHKDSK only reports the volume's status. It doesn't fix errors. That is why running CHKDSK on a failing drive is a write operation, not an inspection.
The damage is mechanical, not a firmware edit. chkdsk /r walks every logical block on the volume, & every weak or unreadable sector it hits forces read retries. Every retry drags a degrading head back across the same failing area, adding heat & wear until the head collapses or scores the platter.
CHKDSK talks to the drive only through standard ATA block commands, so it never reaches the firmware Service Area or the translator; it can't rewrite those modules, & the real cost is physical head & platter damage from the forced reads. A drive already throwing bad sectors is showing media or head degradation, & more reads make it worse.
CHKDSK also destroys the map recovery software needs. When it finds clusters it can't tie back to a valid file, it truncates or reassigns them & saves the lost chains as numbered File<nnnn>.chk files. The original filenames, folder paths, & directory tree are gone, replaced by numbered fragments a technician has to re-identify by content. Rebuilding the file tree during a professional recovery starts from the exact metadata CHKDSK just overwrote.
A drive that needs CHKDSK because of bad sectors is in a physical failure state. Running a file-system repair tool on physical damage is the wrong tool for the job & speeds up the loss.
Image first instead: clone the failing drive to a healthy equal-or-larger target with ddrescue or HDDSuperClone, then run chkdsk on the clone only, never the original. That keeps the failing original intact for lab recovery if the clone comes back incomplete, where head-stack work runs $1,200–$1,500 plus a donor drive under our no data, no charge guarantee.
How does PC-3000 differ from consumer recovery software?
Consumer recovery tools read data through the operating system. PC-3000 communicates directly with the drive's firmware through a hardware interface, bypassing the OS storage stack entirely. This gives it access to vendor-specific diagnostic modes and firmware structures that no software-only tool can reach.
| Capability | Consumer Software | PC-3000 |
| Interface | Reads through OS storage stack (ATA/SCSI commands via kernel driver) | PCIe host card (PC-3000 Express) or the USB-connected PC-3000 Portable III |
| Read timeout control | OS retries each bad sector multiple times (30+ second default timeout per sector) | Custom millisecond-level timeouts; disables drive's internal retry logic |
| Firmware access | None. Cannot read or modify Service Area modules | Puts the drive into vendor-specific Techno Mode for Service Area read and write |
| Translator rebuild | Not possible. If the LBA-to-PBA map is corrupted, the drive is inaccessible | Recalculates LBA-to-physical-sector mapping |
| Defect list management | Cannot read or clear G-List/P-List entries | Reads, edits, and clears SMART counters and the G-List to unlock busy drives |
| Selective head imaging | Reads sequentially across all heads; cannot skip a degraded head | Reads head map from firmware, images healthy heads first, skips or limits access to degraded heads |
| ROM adaptives transfer | Not applicable. Cannot read factory calibration data | Backs up the ROM so its adaptives move with it when the PCB is replaced |
| Cost | Free (Recuva, PhotoRec, ddrescue) to a paid license (R-Studio) | Professional lab only. Firmware repair starts at $600–$900; head swap at $1,200–$1,500 + donor |
The cost difference reflects the hardware gap. Consumer tools are software running on a standard computer. PC-3000 is a dedicated hardware platform (PCIe card or USB adapter with custom firmware) built by ACE Laboratory for drive-level diagnostics. Combined with clean bench work and donor head matching, it handles the failure modes that consumer tools cannot reach.
If your drive is still healthy enough for ddrescue, use ddrescue. If it is not, the professional recovery path starts at $600–$900 for firmware-level repair and carries our no data, no charge guarantee.
Opened the drive chassis?
The read/write heads in a hard drive fly fewer than 5 nanometers above the platter surface on modern high-density models. They ride on a thin air bearing generated by the spinning platters.
Any particle larger than the flying height risks a head crash on the next power cycle.
Airborne particles
Ordinary room air carries particles far larger than the head's few-nanometer flying height.
Fingerprint oils
Skin oils transfer onto a platter the moment you touch it.
What to do if you opened the drive
- 1Do not power on the drive. Spinning a contaminated drive can crash the heads and score the magnetic surface.
- 2Do not reseal the chassis with tape, adhesive, or by replacing the screws. The contamination is already on the platter surface; closing the lid traps it inside.
- 3Do not blow compressed air into the drive. Many canned air dusters contain a bitterant, and it can leave a residue that adds to the contamination.
- 4Bag it. Place the drive in an antistatic bag or wrap it in a clean, lint-free cloth. Seal the bag to prevent further particle ingress.
- 5Send it to a lab with particle-controlled conditions. At our Austin lab, we clean contaminated platters under a ULPA-filtered laminar flow bench, match donor heads, and image the drive using PC-3000. Evaluation is free under our no data, no charge guarantee.
This applies equally if a local IT shop or big-box tech support opened the drive before returning it to you. An improperly opened drive is an improperly opened drive regardless of who unscrewed the lid.
SSDs are a different story
Solid-state drives have no platters, no read/write heads, and no air bearing. Opening an SSD enclosure carries zero contamination risk. SSD recovery involves board-level repair or firmware work. None of these procedures require particle-controlled conditions. The clean bench requirement applies only to drives with spinning magnetic platters. If your SSD has failed, opening the case to inspect the board is safe.
Why does opening a hard drive in room air destroy the data?
ISO 14644-1 particle limits versus ordinary office air
ISO 14644-1 is the international standard that classifies controlled environments by the maximum allowable concentration of airborne particles per cubic meter at specified sizes. It superseded the older U.S. Federal Standard 209E in 2001.
| Environment | FED-STD-209E equivalent | Particles ≥ 0.5 µm per m³ |
| ISO Class 4 | Class 10 | 352 |
| ISO Class 5 | Class 100 | 3,520 |
| ISO Class 9 (typical office air) | Uncontrolled | 35,200,000 |
Open a drive on a kitchen counter, an office desk, or a bedroom floor, and the platters sit in air carrying roughly 100,000 times the particulate load that ISO Class 4 permits. The particles consist of skin flakes, clothing fibers, dust, pollen, and aerosolized micro-droplets, all of which are large enough to be catastrophic at the head-disk interface.
Modern slider clearance is 1 to 5 nanometers
The read/write head does not touch the platter during operation. It rides on an air bearing generated by the spinning platter. As areal density climbed past 1 Tb/in² on perpendicular magnetic recording (PMR) and shingled magnetic recording (SMR) drives, the magnetic spacing between the transducer and the recording layer had to shrink to maintain signal integrity.
Production drives now use a femto slider (roughly 0.85 mm by 0.7 mm) with a baseline fly height of 3 to 5 nm. To close the final gap, manufacturers added Thermal Fly-height Control: an embedded heater inside the slider thermally protrudes the read and write elements toward the disk during operation, dropping the operational clearance to 1 to 2 nm.
The geometric mismatch is unforgiving. A 0.5 micron contaminant is a 500 nanometer object trying to fit inside a 1 to 2 nanometer gap; it is 250 to 500 times larger than the head-disk interface clearance.
How one particle can spread damage across the head stack
HDD platters are layered. The platter itself is glass or aluminum. On top of it is a hard magnetic recording layer, usually a cobalt-chromium-platinum alloy. Over that is a diamond-like carbon (DLC) protective overcoat and a perfluoropolyether lubricant film. A particle wedged between the slider and that surface can drive the slider into the platter. From there it can breach the DLC overcoat and gouge the magnetic layer, which strips the recording medium off the affected sectors.
That gouging produces secondary debris: jagged metallic shards carved from the platter and the slider itself. The platter is still spinning, so centrifugal force and the turbulent air inside the chassis throw that debris across the whole platter and into the path of the remaining heads on the head stack assembly.
Once rotational scoring reaches the magnetic layer, the data in those tracks no longer exists. The magnetic domains have been physically removed and converted into metallic dust. No laboratory technique can rebuild a magnetic surface that has been carved away. This is the failure mode that turns a $1,200–$1,500 head crash into a $2,000 surface-damage case, and surface-damage cases into permanent data loss.
How a ULPA-filtered laminar flow clean bench protects the work
ISO 14644-1 doesn't require a walk-in room. It specifies particle concentration in a volume of air.
A vertical laminar flow clean bench forces room air through a high-efficiency filter and pushes it downward across the work surface in a uniform stream. That moving curtain of filtered air bathes the technician's hands, tools, and the drive itself, actively pushing contaminants away from the platters and preventing ambient air from entering the work zone. Our Austin lab uses ULPA-filtered laminar flow benches for every head-stack procedure.
A HEPA filter's 0.3 micron rating is its most penetrating particle size. That's the size it stops least efficiently. Smaller particles get caught at higher efficiency.
Our bench is a ULPA-filtered laminar flow clean bench.
The bench is operated as a particle-controlled work surface, not certified to a specific ISO 14644-1 class; the controlled volume sits right where the platters are exposed instead of being spread across an entire room.
We use PC-3000 Portable III and PC-3000 Express for ROM and Service Area work, and FLIR thermal cameras to triage PCB faults before we open the chassis. We match donor head stacks on preamp revision, head map and firmware.
The full mechanical recovery sits at $1,200–$1,500 for a head swap (plus donor drive). Donor drives are matching drives used for parts. Typical donor cost: $50–$150 for common drives, $200–$400 for rare or high-capacity models. We source the cheapest compatible donor available. Surface-damage cases that already show platter scoring start at $2,000. Rush turnaround is available: +$100 rush fee to move to the front of the queue. Every evaluation runs under our no data, no charge guarantee.
Platter exposure: common questions
Can I reseal a hard drive after opening it?
No. Once the chassis is open, airborne particles and fingerprint oils reach the platter surface. Replacing the cover does not remove the contamination. The drive needs professional cleaning under a ULPA-filtered environment before imaging can begin.
Does opening a hard drive immediately destroy the data?
Not immediately. The data remains intact on the magnetic platters until the drive is powered on. Contamination particles on the surface cause head crashes during the next spin-up, which scores the magnetic layer and makes affected sectors unrecoverable. Keep the drive powered off and contact a professional lab with particle-controlled conditions.
Do SSDs need a cleanroom for data recovery?
No. SSDs contain no spinning platters or flying read/write heads. Opening an SSD enclosure carries no contamination risk. SSD data recovery uses board-level repair or firmware tools like PC-3000 SSD. None of these require environmental controls.
Why does a single dust particle destroy a hard drive?
Modern hard drive read/write heads fly 1 to 5 nanometers above the platter on an air bearing generated by the spinning platter. A 0.5 micron dust particle is far larger than that clearance. When the slider hits a particle, the impact can gouge the magnetic recording layer, and the debris can damage other heads and platter surfaces. Once the magnetic layer is physically removed, the data in those tracks no longer exists.
What are the ISO 14644-1 particle limits for cleanrooms used in hard drive recovery?
ISO 14644-1 specifies maximum airborne particle concentrations per cubic meter at 0.5 microns and larger. ISO Class 4 (Federal Standard 209E Class 10) permits 352 particles per cubic meter. ISO Class 5 (Class 100) permits 3,520. Typical office or residential air is ISO Class 9, with up to 35,200,000 particles per cubic meter at 0.5 microns and above. Hard drive head-stack work requires a tightly particle-controlled work surface, which a ULPA-filtered laminar flow bench delivers without the overhead of a walk-in room.
When Should You Stop DIY Recovery and Use a Lab?
Stop ddrescue and ship the drive if it stalls for extended periods, begins clicking or beeping mid-clone, or drops offline. Continued imaging at that point adds mechanical wear without recovering usable data; stopping early preserves more than grinding through retries.
If ddrescue stalls for extended periods, stop. More imaging adds wear without recovering meaningful data. Further attempts reduce what a professional lab can recover.
DIY attempts add wear to the drive.
Stopping early preserves more data than grinding through retries. Our hard drive data recovery service uses PC-3000 for firmware-level access and performs head swaps in a particle-controlled clean bench.
Drive clicking, beeping, or grinding?
Every second of operation with damaged heads scores the platter surface and reduces recoverable data. Ship it to our Austin lab; we evaluate every drive for free under our no data, no charge policy.
Is this an emergency?
Do you need data back in less than 48 hours?
Check UrgencyLet's assess your situation
“I need critical business files or legal documents immediately. Cost is less of a concern than speed.”
Go to Emergency Service“I want my data back, but I can wait 5-10 days to save significant money with standard pricing.”
Start Free EstimateWhat professional recovery looks like
When DIY cloning is not enough, the next step is firmware-level access and physical head replacement. Here's a Seagate Rosewood recovery we posted to YouTube in May 2020.
Professional Recovery Services
Nationwide Coverage
Popular Service Areas
Drive too far gone for ddrescue?
Free evaluation, no data = no charge. Mail-in from anywhere in the U.S.
