Recovery Software vs. Professional Lab Recovery
GetDataBack Alternative When Software Recovery Fails
GetDataBack Pro by Runtime Software is a Windows-only recovery tool that now covers NTFS, FAT, exFAT, ext, HFS+, and APFS. On a physically healthy drive with a corrupted partition table or accidentally deleted files, it does the job. Runtime has been publishing GetDataBack since the early 2000s, and IT departments still use it for its straightforward scan-and-recover workflow. But GetDataBack has hard limits: no NVMe controller access, no Btrfs or XFS support, Windows-only operation, and zero ability to interact with a drive whose hardware has failed. When the problem is a locked controller, degraded heads, or corrupted firmware, GetDataBack cannot see past the operating system layer.
9 min read
When GetDataBack works
When GetDataBack Is the Right Tool
GetDataBack scans for lost or damaged file system structures at the logical layer. It reads raw sectors, identifies partition boundaries, reconstructs directory trees, and locates deleted file entries. This approach works when:
  • The drive is detected in BIOS/UEFI with its correct model number and full capacity
  • The volume uses NTFS, FAT32, exFAT, ext2/3/4, HFS+, or APFS (all covered by a single GetDataBack Pro license)
  • Files were accidentally deleted, the partition was formatted, or the MBR/GPT was overwritten
  • The drive does not produce clicking, beeping, or grinding sounds when powered on
In these cases, GetDataBack, R-Studio, DMDE, and similar tools are the correct first step. Professional lab recovery would be unnecessary overhead. If you want a cross-platform alternative to GetDataBack that handles the same scenarios with broader file system coverage, see our R-Studio comparison or the free ddrescue guide.
GetDataBack limitations
Where GetDataBack Reaches Its Limits
GetDataBack was designed for a specific era of storage: NTFS and FAT volumes on SATA or IDE hard drives running Windows. The storage landscape has moved past that scope in several ways that GetDataBack has not fully addressed.
Windows-Only Operation
GetDataBack runs only on Windows. GetDataBack Pro can parse APFS, HFS+, and ext volumes from within Windows when the drive is connected as a secondary device. But if your NAS runs Btrfs or your Linux server runs XFS, GetDataBack cannot read those volumes at all. There is no native macOS or Linux version of the application.
No Btrfs, XFS, or ReFS Support
GetDataBack Pro added APFS and HFS+ support, but it still cannot parse Btrfs, XFS, or ReFS. Btrfs is the default on Synology NAS devices and increasingly common on Linux workstations. XFS is the default on Red Hat Enterprise Linux and CentOS. ReFS is Microsoft's resilient file system used on Windows Server. If you need to recover data from a Synology NAS running Btrfs or a RHEL server with XFS, GetDataBack will not parse the volume structure. R-Studio or UFS Explorer is required for those file systems at the software level.
No Direct NVMe Controller Access
GetDataBack accesses drives through the Windows storage driver stack. It sends standard read commands that pass through the NVMe driver to the controller. If the SSD controller has locked up, entered a firmware fault state (reporting 0 bytes or an incorrect model string), or stopped responding to standard NVMe commands, GetDataBack sees exactly what Windows sees: nothing usable. Recovery from a locked NVMe controller requires vendor-specific commands sent through hardware like PC-3000 SSD, which communicates with the controller outside the operating system.
Cannot Image Drives with Unstable Heads
GetDataBack reads sectors sequentially through the OS. If a hard drive has degraded read/write heads, each failed sector triggers the drive's internal retry logic, stalling for seconds per sector. The OS timeout expires; the USB bridge drops the connection; the scan dies. PC-3000 Data Extractor handles this differently: it disables the drive's internal retry mechanism, builds a head map to identify which heads are functional, images accessible sectors first, and returns to problem areas in later passes with adjusted read parameters. GetDataBack has no mechanism to control read behavior at the ATA command level.
TRIM Renders SSD Deletion Recovery Impossible
When you delete a file on an SSD with TRIM enabled (the default on Windows 7+, macOS, and most Linux distributions), the OS sends a TRIM command telling the controller those blocks are no longer in use. The controller drops the Flash Translation Layer mapping for those addresses and returns zeroes on any subsequent read (DZAT behavior). GetDataBack scans the logical volume, but every read to those addresses returns zeroes. No software tool can recover TRIMmed data; the mapping is gone and the controller will not serve the original content. See our TRIM recovery explanation for the technical details.
GetDataBack vs lab recovery
GetDataBack vs. R-Studio vs. Professional Recovery
Each tool operates at a different layer of the storage stack. The right choice depends on where the failure is.
CapabilityGetDataBackR-StudioProfessional Lab
Operating SystemsWindows onlyWindows, macOS, LinuxAny (hardware-level)
NTFS / FAT / exFATYesYesYes
APFS (Mac)YesYesYes
Btrfs / XFS / ReFSNoYes (all three)Yes
ext2 / ext3 / ext4YesYesYes
HFS+YesYesYes
Virtual RAID reconstructionNoYesYes (Data Extractor Express RAID Edition)
Clicking / failing headsCannot handleCannot handleHead swap in clean bench
Locked SSD controllerCannot accessCannot accessPC-3000 SSD direct access
Firmware corruptionCannot accessCannot accessPC-3000 SA module repair
Price~$79 (Pro license)~$80 (single license)$100–$2,000 (HDD)
No-fix-no-fee guaranteeN/A (software license)N/A (software license)Yes
When you need a lab
When You Need Hardware-Level Recovery
If GetDataBack cannot see your drive, freezes during the scan, or returns empty results on an SSD where TRIM has run, the problem is below the software layer. Here is what lab-level recovery involves for the failure types GetDataBack cannot handle.
Head Failure on HDD
A clicking, beeping, or non-spinning drive needs its head stack assembly physically replaced. We open the drive inside a ULPA-filtered clean bench, transplant heads from a compatible donor, then image the platters using PC-3000 Data Extractor with a custom head map that reads accessible sectors first. This is $1,200–$1,500 for standard drives.
Firmware Corruption
When a drive is detected with the wrong capacity, wrong model string, or not detected at all despite spinning up, the Service Area (SA) firmware is likely corrupted. PC-3000 reads and edits firmware modules directly: translator tables that map logical addresses to physical platter locations, defect lists, and head configuration parameters. GetDataBack never sees these modules because they exist below the host interface. Firmware repair runs $600–$900.
SSD Controller Lockup
SSDs with controllers like the Phison S11 ("SATAFIRM S11" mode, 0-byte capacity) or Silicon Motion SM2258XT (100% disk activity, no data transfer) are invisible to GetDataBack and every other OS-level tool. PC-3000 SSD sends vendor-specific commands to the controller to unlock the firmware state or, in some cases, reads NAND chips directly by bypassing the controller entirely. SSD firmware recovery runs $600–$1,200.
We quote based on the fault type, not the perceived value of your data. Evaluation is free. No charge if we cannot recover your files.
Hard Drive Recovery
SSD Recovery
Frequently asked
Is GetDataBack good for logical data recovery?
GetDataBack Pro handles NTFS, FAT, exFAT, ext, HFS+, and APFS logical recovery well. It can rebuild partition tables, locate deleted files, and reconstruct damaged directory structures on those file systems. If the drive is physically healthy, shows up in BIOS with its correct capacity, and the problem is a deleted partition or formatted volume, GetDataBack is a reasonable tool for the job. Where it falls short is file system coverage: no Btrfs, no XFS, no ReFS. If your NAS runs Btrfs or your Linux server runs XFS, you need a different tool or a lab.
Why is GetDataBack not detecting my drive or freezing during scan?
GetDataBack sends read commands through the Windows storage stack. If the drive has degraded read/write heads, each failed sector triggers the drive's internal retry logic, stalling for seconds per sector. USB enclosures will drop the connection entirely when the drive stops responding within their timeout window. GetDataBack then shows the drive as disconnected or the scan hangs indefinitely. This is not a bug in GetDataBack; it is a hardware problem that no software can work around. If the drive clicks, does not spin, or drops off the USB bus mid-scan, power it down and contact a lab.
How does GetDataBack compare to professional recovery?
GetDataBack Pro costs $79 for a single lifetime license covering NTFS, FAT, exFAT, ext, HFS+, and APFS. Our data recovery starts at $100 for a simple copy on a functional HDD and $200 for SSDs, with firmware-level recovery at $600–$900 and head swaps at $1,200–$1,500. Evaluation is free, and there is no charge if we cannot recover data. These solve different problems: GetDataBack works when the hardware is functional and the file system is one it supports. We handle cases where the hardware has failed, the file system is unsupported (Btrfs, XFS, ReFS), or the controller has locked up. If software can solve your problem, use it. If it cannot, no amount of software will change the outcome.
Does GetDataBack support NVMe SSDs?
GetDataBack can read NVMe drives that Windows recognizes through the standard NVMe driver, but it has no direct access to the NVMe controller. If the SSD's controller has locked up, entered a firmware fault state, or reports incorrect capacity, GetDataBack sees the same broken view that Windows sees. It cannot send vendor-specific NVMe commands to reset the controller or bypass firmware corruption. PC-3000 SSD communicates with NVMe controllers at the protocol level, outside the operating system, which is the only way to recover data when the controller itself is the failure point.
GetDataBack not working on your drive?
Free evaluation, no data no fee. Ship your drive to our Austin lab and we will tell you what is wrong before you owe anything.
