External Hard Drive Data Recovery
$100–$2,000 | No Data, No Fee | Nationwide Mail-In
External hard drives fail for two reasons: the USB enclosure dies, or the internal drive mechanism fails. When the enclosure is the problem, the drive inside is often intact and recovery is straightforward. When the internal drive clicks, beeps, or is not detected, we use the same head swap and firmware repair techniques as any other HDD recovery.
WD My Passport drives add a complication: the bridge board encrypts all data by default. If that bridge fails, connecting the bare drive via SATA shows only encrypted gibberish. We extract the encryption key from the bridge flash chip using PC-3000 and recover through the original encryption path.
Why External Drives Fail
Every external hard drive is an internal hard drive inside a plastic or metal shell. That shell contains a USB bridge board that translates between SATA and USB. Either component can fail independently.
USB Bridge/Enclosure Failure
The most common cause of a dead external drive. The bridge chip fails, the USB connector cracks, or a voltage regulator blows. The internal drive is fine; it just lost its translator.
Recovery: Remove the drive from the enclosure and image it directly. $100-$300.
Warning: WD My Passport drives encrypt through the bridge. Do not remove them from the enclosure without professional help.
Dropped While Spinning
Portable drives travel in backpacks and get knocked off desks. A fall while the platters are spinning slams the read/write heads into the recording surface. The result is clicking or complete silence.
Recovery: Head swap in our 0.02 micron clean bench. $1,200-$1,500.
Power Surge Damage
Using the wrong power adapter or experiencing a surge can blow the TVS diodes on the PCB. The drive may be silent but the protection circuit saved the data.
Symptoms: Drive completely dead, no spin, no lights, possibly burnt smell.
Recovery: PCB repair or replacement with ROM chip transfer. $300-$800.
Firmware Corruption
The drive spins but the computer does not recognize it, or it shows the wrong capacity. The Service Area modules on the platters are damaged or the translator table is corrupt.
Recovery: PC-3000 firmware repair, translator rebuilding. $600-$900.
Motor Seizure / Beeping
A beeping external drive means the spindle motor cannot rotate the platters. Stiction (heads stuck to the platter surface) or bearing failure. Each power-on attempt risks scoring the magnetic coating.
Recovery: Head unsticking or platter transplant. $1,200-$2,000.
What Customers Say
WD My Passport Encryption: The Hidden Trap
Every WD My Passport and My Book manufactured since 2011 uses hardware AES-256 encryption through the USB bridge chip. This encryption is always active, even if you never set a password. The bridge chip generates a Data Encryption Key (DEK) stored in a flash chip on the bridge PCB.
When the bridge board fails, many users or repair shops remove the internal 2.5" drive and connect it directly to a SATA port. The data on the platters is encrypted. The result is gibberish. The drive appears to work, but every file is unreadable. This is not corruption; the data requires the original encryption key to decode.
We desolder the flash chip from the failed bridge board, read out the DEK using a programmer, and either repair the original bridge or transplant the key data to a donor board. The drive is then accessed through the encryption path, and your files come back intact.
Do not remove a WD Passport drive from its enclosure.
If you already have, stop. Do not format or write to the drive. The encryption key is on the bridge board, not the drive. Send both pieces to us.
If you set a password on your WD drive, you will need to provide it for recovery. We cannot bypass user-set passwords.
Affected WD Models
- ⚠My Passport (all models since 2011)
- ⚠My Passport Ultra
- ⚠My Book (desktop models)
- ⚠WD Easystore (newer models)
- ✓WD Elements (older models not encrypted; newer models may be)
- ✓Seagate / LaCie / Toshiba (not hardware encrypted by default)
Encryption Bridge Repair Cost
Bridge-only failure with healthy internal drive: $300-$600. If the internal drive also needs mechanical work, add the standard head swap or firmware tier on top.
External Hard Drive Brands We Recover
Western Digital
- • WD My Passport
- • WD My Passport Ultra
- • WD My Book
- • WD Elements
- • WD Easystore
- • Seagate Backup Plus
- • Seagate Expansion
- • Seagate One Touch
- • Seagate Portable Drive
- • Seagate Game Drive
LaCie
- • LaCie Rugged
- • LaCie Rugged Mini
- • LaCie Porsche Design
- • LaCie d2
- • LaCie Mobile Drive
Other Brands
- • Toshiba Canvio
- • Samsung T5/T7 (SSD)
- • G-Technology G-Drive
- • Buffalo MiniStation
- • Transcend StoreJet
External Hard Drive PCB and Recovery
This video examines the PCB on a LaCie Rugged external drive, showing how board-level components fail and what the recovery path looks like.
External Hard Drive Recovery Pricing
External drives use the same internal mechanisms as laptop and desktop drives. Our five-tier pricing applies. Encrypted WD models add $200-$400 for bridge chip key extraction if the enclosure has failed.
| Service Tier | Price | Description |
| Simple CopyLow complexity | $100 | Your drive works, you just need the data moved off it Functional drive; data transfer to new media Rush available: +$100 |
| File System RecoveryLow complexity | From $250 | Your drive isn't recognized by your computer, but it's not making unusual sounds File system corruption. Accessible with professional recovery software but not by the OS Starting price; final depends on complexity |
| Firmware RepairMedium complexity – PC-3000 required | $600–$900 | Your drive is completely inaccessible. It may be detected but shows the wrong size or won't respond Firmware corruption: ROM, modules, or translator tables corrupted; requires PC-3000 terminal access Standard drives at lower end; high-density drives at higher end |
| Head SwapHigh complexity – clean bench surgery50% deposit | $1,200–$1,500 | Your drive is clicking, beeping, or won't spin. The internal read/write heads have failed Head stack assembly failure. Transplanting heads from a matching donor drive on a clean bench 50% deposit required. Donor parts are consumed in the repair |
| Surface / Platter DamageHigh complexity – clean bench surgery50% deposit | $2,000 | Your drive was dropped, has visible damage, or a head crash scraped the platters Platter scoring or contamination. Requires platter cleaning and head swap 50% deposit required. Donor parts are consumed in the repair. Most difficult recovery type. |
All tiers: Free evaluation and firm quote before any paid work. No data, no fee on simple copy, file system, and firmware tiers. Head swap and surface damage require a 50% deposit because donor parts are consumed in the attempt.
Target drive: The destination drive we copy recovered data onto. You can supply your own or we provide one at cost. For ultra-high-capacity drives (20TB and above), the target drive costs approximately $400+ due to the large media required. All prices are plus applicable tax.
See our clean bench validation data and particle test videoWhat to Do When Your External Drive Fails
Safe First Steps
- ✓Stop using it immediately. The less you use a failing drive, the better your recovery chances.
- ✓Try a different USB cable. USB 3.0 Micro-B cables fail often. Try a known-good cable first.
- ✓Try a different USB port or computer. Rule out port or driver issues before assuming the drive is dead.
- ✓Listen for sounds. Clicking, beeping, or grinding tells us what is wrong. Note what you hear.
What NOT to Do
- ✗Do not remove WD Passport drives from their enclosure. They are hardware encrypted through the USB bridge.
- ✗Do not open the drive itself. The internal mechanism requires a clean bench environment to access.
- ✗Do not keep powering on a clicking drive. Each power cycle can cause more platter damage.
- ✗Do not use data recovery software on a failing drive. It forces the drive to work harder and can make recovery impossible.
Seagate Backup Plus: Rosewood Platform Failures
Seagate Backup Plus Slim and Portable drives from 2016 onward use the Rosewood platform (model numbers ST1000LM035 and ST2000LM007). These 2.5" drives are among the most failure-prone mechanisms we receive.
Rosewood drives use a single-platter, two-head design with Seagate's Marvell-based controller. The common failure pattern is read/write head degradation that begins as slow reads and escalates to clicking within days. The firmware Service Area on these drives is also fragile; translator corruption causes the drive to hang at spin-up even when the heads are functional.
Recovery requires PC-3000 with the Seagate Rosewood utility module. We access the drive in factory mode, bypass the corrupted translator, build a temporary head map to skip damaged heads during imaging, and clone sector by sector using DeepSpar Disk Imager for error-tolerant reads. Donor heads for Rosewood require exact firmware revision matching; head compatibility varies between production batches even within the same model number.
LaCie Rugged: Rubber Bumpers Do Not Prevent Head Crashes
LaCie Rugged drives are marketed as drop-resistant. The orange rubber bumper absorbs some shock, but the internal mechanism is a standard Seagate 2.5" drive with no additional vibration isolation. A fall from desk height onto a hard floor while the drive is powered on will cause a head crash regardless of the bumper.
We see LaCie Rugged drives regularly from photographers and videographers who trusted the enclosure to protect against field drops. The internal Seagate mechanism suffers the same head failures as any other portable drive.
Recovery follows the standard head swap procedure: open the drive in our 0.02 micron ULPA-filtered clean bench, remove the failed head stack assembly, install matched donor heads, and image using PC-3000 with adaptive head mapping. For drives with platter scoring from a head crash, we clean the debris from the platter surface before installing new heads to prevent immediate secondary failure.
After a Drop
- ✓Power off immediately. Unplug the cable.
- ✓Note any sounds (clicking, grinding, silence).
- ✗Do not power it on again to check if it works.
- ✗Do not run recovery software on a clicking drive.
- ✗Do not shake or tap the drive to free stuck heads.
External SSD Recovery: Samsung T5/T7, SanDisk Extreme
External SSDs fail differently from spinning drives. There are no moving parts, so drops are less destructive. The failure modes are controller firmware bugs, NAND wear-out, and encryption lockouts.
Samsung T5 and T7: These use Samsung's own controller and V-NAND. The T7 encrypts data via the controller even without a user password, similar to the WD Passport problem. If the controller fails, the NAND cannot be read directly without the encryption key. Recovery depends on whether the controller can be restarted or a compatible replacement can be sourced.
SanDisk Extreme and Extreme Pro: These drives use a proprietary controller that is prone to firmware failure. The drive drops off USB, shows 0 bytes, or becomes completely unresponsive. Some batches exhibit premature failure tied to firmware versions. Recovery requires direct NAND access through chip-off or ISP techniques when the controller cannot be revived.
External SSD recovery pricing ranges from $100 for firmware-level fixes to $2,000 for chip-off NAND reads requiring page-level reconstruction.
External Hard Drive Recovery: Common Questions
How much does external hard drive data recovery cost?
External hard drive recovery ranges from $100 for a simple enclosure failure where the internal drive is healthy, to $1,200-$1,500 for a head swap after a drop. Encrypted WD My Passport bridge repairs cost $300-$600. We provide a firm quote after a free evaluation. No data recovered means no charge.
Can data be recovered from a dead external hard drive?
Yes. Most dead external drives have a failed USB bridge board, not a failed drive. We remove the internal mechanism and connect it directly using PC-3000. If the drive itself has mechanical damage, we perform head swaps in our 0.02 micron filtered clean bench. WD My Passport models require bridge-level encryption key extraction before direct connection.
Why is my external hard drive not showing up?
Common causes include: failed USB bridge/enclosure (drive is fine, interface is dead), USB cable failure, drive firmware corruption, mechanical failure (clicking/beeping), or PCB damage from power surge. Many "dead" external drives just have a failed enclosure; the internal drive is often fine.
Why is my external hard drive beeping?
Beeping from an external hard drive means the motor cannot spin the platters. This is caused by stiction (heads stuck to the platter surface) or spindle seizure. Both require clean bench work: stiction needs manual head unsticking, and spindle seizure requires a platter transplant to a donor chassis. Do not keep powering the drive on; each attempt risks scoring the platter surface.
Can you recover data from an encrypted WD My Passport?
Yes, but do not remove the drive from its enclosure. WD My Passport models use hardware AES-256 encryption through the USB bridge chip, even if you never set a password. If the bridge fails, the encryption key is stored in a flash chip on that bridge board. We desolder the flash chip, extract the key, and either repair the original bridge or transplant the key to a replacement board.
My external hard drive was dropped. Can you recover it?
Usually yes. Dropped drives often suffer head crashes or stuck heads. We perform head swaps in our clean bench environment using donor parts. Success depends on platter condition. The sooner you stop using it after the drop, the better the recovery chances.
Should I try to open the external drive enclosure myself?
Opening the plastic enclosure is usually safe. Opening the internal hard drive mechanism is not; that requires clean bench conditions. However, if you have a WD My Passport or other encrypted drive, do not remove the drive from its enclosure. The encryption keys are tied to the USB bridge.
Related Recovery Services
Internal HDD, desktop and laptop drives
NVMe, SATA, and external solid state drives
WD-specific recovery expertise
Motor seizure and stiction diagnosis
Ship from anywhere in the U.S.
External hard drive not working?
Free evaluation, firm quote before any paid work. No data, no charge. Mail-in from all 50 states.
