RAID 60 Data Recovery Services
RAID 60 stripes across multiple RAID 6 sub-arrays, combining dual-parity fault tolerance per span with striped throughput. When one span degrades beyond its two-drive tolerance, the stripe layer takes the entire volume offline. We recover RAID 60 arrays by imaging every member through write-blocked channels, identifying span boundaries, reconstructing each sub-array independently, and assembling the cross-span stripe from cloned images. No data, no charge.
Updated April 2026
12 min read
RAID 60 Array Geometry
How is a RAID 60 array structured?
RAID 60 nests multiple RAID 6 sub-arrays (spans) under a RAID 0 stripe layer. Each span provides dual parity (P + Q) independently. The stripe layer distributes I/O across spans for sequential throughput that a single RAID 6 cannot match.
Drive Count and Layout
  • Minimum 8 drives: two spans of four. Each span must contain at least four members to support RAID 6 (two data + two parity).
  • Typical production deployments use 12 to 24 drives across three or four spans. A 24-drive array with four spans of six yields 16 drives of usable capacity (each span loses two to parity).
  • Adding spans increases sequential throughput linearly (more parallel I/O paths) at the cost of additional parity overhead and recovery complexity.
Fault Tolerance Per Span
  • Each RAID 6 span tolerates two simultaneous drive failures independently. A four-span array can lose up to eight drives total, provided the failures distribute across spans.
  • If a third drive fails within any single span before that span completes its rebuild, the span loses all parity protection. The RAID 0 stripe layer cannot compensate; the entire volume goes offline.
  • Usable capacity = (drives per span - 2) x number of spans x smallest member size.
RAID 60 Use Cases
Why do enterprises deploy RAID 60 over RAID 6?
RAID 6 provides dual-parity fault tolerance but bottlenecks on write performance as array size grows. RAID 60 solves this by distributing writes across multiple independent RAID 6 spans, each with its own P + Q parity calculations running in parallel.
Database Servers
SQL Server and Oracle instances on Dell PowerEdge R740xd or HP ProLiant DL380 Gen10 servers use RAID 60 across 12 to 24 SAS drives. The striped spans provide the IOPS density that single-span RAID 6 cannot match for transactional workloads.
Virtualization Hosts
VMware ESXi and Hyper-V hosts running 50+ VMs need both the fault tolerance and the parallel I/O paths that RAID 60 provides. A single RAID 6 with 24 drives creates excessive rebuild times.
Video Surveillance
Large-scale surveillance systems writing 200+ camera feeds continuously require sustained sequential write throughput that RAID 60 delivers through its parallel span architecture. The dual-parity per span ensures footage survives drive failures without interrupting recording.
Rebuild Risks on Large Drives
Why do RAID 60 rebuilds fail on 18 TB+ drives?
High-capacity enterprise drives (Seagate Exos X18/X20, WD Ultrastar DC HC550/HC560) reduce the per-drive cost of RAID 60, but they increase rebuild time per span and the probability of a secondary failure during that window.
  • A six-drive span with 18 TB members requires reading five surviving drives in parallel during a single-drive rebuild, with each surviving drive read in full. At a sustained 150 MB/s per drive, the arithmetic minimum is roughly 33 hours.
  • With 20 TB Ultrastar HC560 drives under throttled production throughput, rebuild time stretches well past 96 hours. The surviving drives in that span have been running for the same number of power-on hours as the one that already failed. Each additional hour of sustained sequential reads increases the probability of a latent sector error or secondary head failure.
  • The read volume matters as much as the clock. Nearline members like the Exos X18 and the Ultrastar DC HC550 carry a worst-case manufacturer specification of one unrecoverable read error per 10^15 bits, an order of magnitude tighter than the consumer-class specification of one per 10^14 bits. An 18 TB member holds 1.44 x 10^14 bits, so the three surviving members of a four-drive span are read for roughly 4.3 x 10^14 bits in a single rebuild pass. That pass covers a little under half of the enterprise-class specification interval, and it crosses the consumer-class interval several times over. The same span populated with desktop-class members is a different risk class from one populated with nearline members, which is why we image every member before a controller touches the rebuild instead of spending that read budget on live drives.
  • If the array loses one drive per span and both spans attempt simultaneous rebuilds (common with hot spares configured per span), the controller's I/O scheduler splits bandwidth between rebuild traffic and production I/O. Rebuild times double or triple under production load.
  • RAID 60's per-span isolation limits rebuild scope compared to a monolithic RAID 6. A 24-drive RAID 60 with four 6-drive spans only rebuilds within the affected span (five-drive read). The same 24 drives in a flat RAID 6 would require reading all 23 surviving members.
Critical: If your RAID 60 array shows a degraded span, do not force a rebuild on aging drives with high power-on hours. Power down the system, label each drive with its bay position and span assignment, and contact us. Offline imaging eliminates the rebuild risk entirely.
Controller-Specific RAID 60
Controller-Specific RAID 60 Implementations
Each RAID controller family stores span membership, parity rotation, and stripe configuration in proprietary on-disk metadata. Recovery requires parsing that metadata from cloned images to reconstruct the array without the original controller hardware.
Dell PERC H740P / H755
The PERC H740P supports RAID 60 and can address up to 240 physical devices through SAS expanders, though an individual virtual disk is typically constrained to 32 members total. Span membership is recorded in DDF (Disk Data Format) metadata headers on each member.
When one drive drops out of a span and rejoins with a stale timestamp, the controller marks it "Foreign." Importing a foreign config with stale data forces a backward resync that overwrites current blocks with outdated data across every stripe changed while the drive was absent.
We image all members, inspect DDF headers in a hex editor to identify epoch timestamps per drive, and determine span boundaries before any assembly decision. This prevents the stale-member resync failure that is the most common cause of PERC RAID 60 data destruction.
Broadcom MegaRAID 9460-16i
The MegaRAID 9460-16i handles RAID 60 with up to 240 drives and supports spanning across multiple enclosures via SAS expanders. The controller writes its own DDF metadata plus a proprietary MegaRAID configuration record to each member. Recovery from this controller requires parsing both metadata layers to correctly identify span membership, because the DDF layer may reference physical enclosure positions that changed if drives were reseated during troubleshooting.
Data Extractor Express RAID Edition includes a MegaRAID metadata parser that reads both DDF and proprietary records from cloned images. When metadata is partially corrupted (common after firmware crashes), we fall back to raw data continuity analysis across member images to determine span boundaries.
Broadcom MegaRAID Tri-Mode (9500 and 9600 series)
The MegaRAID 9500 series is Broadcom's first PCIe Gen4 RAID family. The 9560-16i is built on the SAS3916 RAID-on-Chip. The 9600 series is the 24G SAS family: the 9670-24i uses the SAS4124 RoC. The 9670-24i is a 9600-series part, not a 9500-series card, and its differentiator is 24G SAS on PCIe Gen4, not a PCIe generation bump.
Tri-Mode SerDes runs SAS, SATA, and NVMe members concurrently in one U.3 bay under Universal Backplane Management (UBM). A single RAID 60 span can therefore hold members on different transports, which changes how each member is imaged but not how the array is reconstructed.
The controller writes span membership and geometry as a SNIA DDF variant to the trailing sectors of each member, so a dead or foreign Tri-Mode card does not strand the array. We image every member, parse the DDF descriptors from the cloned images in Data Extractor Express RAID Edition, and reconstruct the RAID 60 without the original controller. The mixed-transport imaging workflow is covered in the NVMe Tri-Mode member imaging section below.
HP Smart Array P408i-a / P816i-a
HP Smart Array controllers on Gen10 ProLiant servers support RAID 60 but store configuration in a proprietary format distinct from the DDF standard used by Dell and Broadcom. The controller writes span membership to a proprietary RIS (RAID Information Sector) region, typically housed in a reserved partition on each member drive.
When the Smart Storage Battery fails (POST Error 313 on Gen9/Gen10), cached writes may be trapped in the volatile cache, and the controller may refuse to present the virtual disk until the battery is replaced or the cache is manually flushed.
We bypass the controller by imaging each member drive directly via HBA passthrough, reading the RIS metadata from each image, and reconstructing the RAID 60 in Data Extractor Express RAID Edition using the parsed span map. For cache-trapped writes, we power the cache module independently to flush pending data before imaging.
Per-span DDF validation when the controller is dead
A dead PERC or MegaRAID card does not strand a RAID 60, because the structure that defines the array lives on the drives, not in controller NVRAM.
The Dell PERC H740P and the LSI/Broadcom MegaRAID 9460 record RAID 60 span membership in the SNIA DDF (Disk Data Format) configuration metadata written to the trailing sectors of each member. That on-disk virtual-disk configuration enumerates which physical members belong to a given RAID 6 span and the order of spans under the outer stripe.
We read those descriptors from the cloned images in Data Extractor Express RAID Edition to identify span boundaries directly: which drives form each inner RAID 6 set, and the cross-span order that the outer RAID 0 layer used. That descriptor read is what separates a controlled reconstruction from guesswork.
When that configuration metadata is partially overwritten, the descriptors that survive narrow the geometry and the remaining unknowns are resolved through hex-level destriping across the member images. Note the metadata location differs by vendor: DDF sits on the trailing sectors for PERC and MegaRAID, while HP Smart Array writes its RIS at the start of each drive instead of DDF.
NVMe Tri-Mode
How do you image a mixed-transport NVMe RAID 60 on a Broadcom Tri-Mode controller?
You image each member on the transport it actually speaks, then reconstruct offline. An NVMe U.2/U.3 member uses native PCIe and cannot be imaged through a SAS HBA in IT mode; it is cloned on a native PCIe path with PC-3000 SSD. The SNIA DDF span geometry is identical to a SAS/SATA RAID 60, so the original Tri-Mode controller is not required.
Broadcom Tri-Mode MegaRAID controllers run SAS, SATA, and NVMe members in the same U.3 bay via Tri-Mode SerDes. The 9560-16i (SAS3916) and 9580-8i8e are 9500-series PCIe Gen4 cards; the 9670-24i (SAS4124) is a 9600-series 24G SAS card, not a 9500.
A RAID 60 built on one of these controllers can spread its spans across all three transports at once, which is exactly why the imaging step has to be planned before anything is powered back on. For the controller-level detail, see the Broadcom MegaRAID controller recovery page.
The transport is the only thing that changes for recovery. An NVMe member speaks native PCIe, not SAS, so it cannot be read through a SAS HBA in IT mode the way a SAS or SATA member can. It is cloned on a native PCIe attach path with PC-3000 SSD.
Conventional HDD members are imaged with PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager, and SAS members are imaged through a SAS HBA in IT mode behind a hardware write-blocker. A RAID 60 that mixes these transports needs both imaging workflows completed before any reconstruction begins.
Member typeTransportImaging path
Conventional HDD memberSATA over the controller backplaneRemoved from the chassis and imaged sector by sector with PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager behind a hardware write-blocker.
SAS memberSAS over the controller backplaneImaged through a SAS HBA in IT mode behind a hardware write-blocker.
NVMe member (U.2 / U.3)Native PCIeCannot be read through a SAS HBA in IT mode. Imaged on a native PCIe attach path with PC-3000 SSD, then treated as one more clone in the offline reconstruction.
RAID 60 raises the stakes on this discipline compared with a single-span array. Each span carries two independent parity blocks, P and Q, and a production RAID 60 mixes transports across many spans.
A blind rebuild on native hardware can eject a healthy NVMe member on a transient PCIe link timeout, the same way a slow SAS or SATA member gets dropped on a SCSI command timeout. Offline imaging removes the controller from that decision entirely, so a transient link event is handled at the imaging layer instead of pushing a span toward its two-fault threshold.
Once every member is cloned, the geometry is read the same way it is on any SAS/SATA RAID 60. The SNIA DDF metadata (stripe size, span and member order, per-span P and Q parity rotation, and epoch history) lives on the member disks, not in controller NVRAM, so controller death is not data loss and the original Tri-Mode controller is convenient but not required. Virtual reconstruction is performed offline from the clones with Data Extractor Express RAID Edition.
Process
Our RAID 60 Recovery Process
RAID 60 recovery has two layers: reconstruct each RAID 6 span from its member images, then assemble the RAID 0 stripe across all reconstructed spans. Both layers use offline reconstruction from cloned images. No data is written to original drives.
  1. Free evaluation and span mapping: Document the controller type, total drive count, span count, drives per span, stripe size, and parity rotation. If you have screenshots of the controller BIOS (MegaRAID WebBIOS, Smart Storage Administrator), these accelerate parameter detection.
  2. Write-blocked forensic imaging: Every member drive is connected to PC-3000 or DeepSpar hardware through a write-blocked channel. We clone the full LBA range of each member, including reserved sectors where controller metadata is stored. Drives with mechanical failures receive head swaps or motor work on our 0.02 µm filtered clean bench before imaging.
  3. Span boundary identification: Using controller metadata parsed from the cloned images, we map which drives belong to each RAID 6 sub-array. When metadata is damaged or missing, we analyze data continuity patterns across member images to determine span membership empirically.
  4. Per-span RAID 6 reconstruction: Each span is reconstructed independently using Data Extractor Express RAID Edition. We identify the stripe block size, P and Q parity rotation patterns, and member ordering within each span. Both parity calculations are validated against sample stripes before the span is marked as reconstructed.
  5. Cross-span RAID 0 stripe assembly: The reconstructed span images are loaded as virtual drives and striped according to the controller's cross-span configuration. We verify the assembled volume by checking filesystem superblocks, partition tables, and directory structures.
  6. Filesystem extraction and delivery: The virtual array is parsed (NTFS, EXT4, XFS, ZFS, VMFS) using R-Studio or UFS Explorer. Files are extracted to verified target media. You receive a file listing for review before final delivery.
Timing: RAID 60 recovery takes longer than RAID 6 due to the additional span identification and cross-span assembly steps. Arrays with 8-12 healthy members and no mechanical failures: 2-4 weeks. Arrays with 16+ members or drives requiring head swaps: 4-8 weeks, depending on donor sourcing for affected drives. Rush fee available (+$100 rush fee to move to the front of the queue).
Failure Scenarios
What Causes RAID 60 to Fail Despite Dual Parity?
RAID 60's per-span dual parity protects against drive failures, but several failure modes bypass the parity layer entirely. Three or more failures within a single span, controller firmware corruption, concurrent cross-span rebuilds, and accidental foreign config imports each collapse the volume without exhausting the array's theoretical fault tolerance.
Three+ Failures in One Span
RAID 60's fault tolerance is per-span, not per-array. If three drives fail in the same span (common when drives are from the same manufacturing batch with identical wear), that span loses all parity protection. The RAID 0 stripe layer treats the span as a missing stripe member, and the entire volume becomes inaccessible. Recovery from this scenario requires partial reconstruction using whatever parity data remains on the surviving drives within the affected span.
Controller Firmware Corruption
A firmware crash or bad flash on the RAID controller can corrupt the on-disk metadata that defines span membership. Without valid metadata, the controller cannot present the virtual disk, even though every member drive is physically healthy. Recovery requires parsing whatever metadata fragments survive on each member image and filling gaps through raw data analysis.
Extended Rebuild with Cross-Span Failures
When two spans each lose one drive simultaneously, both spans enter degraded mode and begin parallel rebuilds. The controller splits I/O bandwidth between production traffic and two concurrent rebuild streams.
Accidental Foreign Config Import
On Dell PERC controllers, importing a foreign configuration with stale member data forces the controller to resync the array backward, overwriting current data with outdated blocks. On RAID 60 arrays, this affects every span that contained the stale member. The same trap applies to Broadcom MegaRAID controllers when accepting a "consistency check" prompt after drive reseating.
Large-Drive Rebuild Failure Modes
Why do SMR drives and write-cache dropouts abort RAID 60 rebuilds?
SMR drives stall to flush their CMR cache during sustained rebuild writes and get ejected when the stall passes the controller timeout, collapsing the span. Write-back cache backed by a failed BBU loses unflushed writes, leaving torn stripes. The safe path is offline member-by-member imaging before any rebuild.
SMR drive ejection during sustained rebuild writes
Shingled Magnetic Recording drives absorb incoming writes into a small Conventional Magnetic Recording media cache before laying them down as overlapping shingled tracks. A RAID 60 rebuild generates uninterrupted sequential writes across the rebuilding span. That traffic overflows the CMR cache, and the drive firmware halts host I/O to perform background reshingling.
The SCSI Error Handling layer or the hardware RAID controller flags the member as dead and ejects it.
On a RAID 60 this turns a survivable event into a total loss. A span that is already rebuilding has one member logically offline.
If heavy rebuild I/O stalls and ejects two or more SMR members in that span, the span crosses its two-fault threshold. Because the top layer stripes across spans, the loss of one nested span takes the entire RAID 60 volume offline.
The consumer worst-case specification of roughly one unrecoverable read error per 10^14 bits, about one error every 12.5 TB, is a floor that field drives often beat, but on a live rebuild across aging 18 to 20 TB members the URE risk grows with member size and drive age, independent of the SMR problem.
We image every member block-by-block through a write-blocked interface using ddrescue or PC-3000 hardware before any reconstruction, so an SMR stall or a URE is handled at the imaging layer and never ejects a drive from a live array.
Write-back cache dropout and torn stripes
Enterprise controllers use a DRAM write-back cache with a battery- or capacitor-backed protection module to acknowledge writes instantly while delaying the physical write to the platters. The vendor terms are not interchangeable: Dell PERC H740P and H755 use lithium-ion battery-backed flush-to-NAND, the supercapacitor CacheVault is Broadcom's retail MegaRAID design, and FBWC is HPE's branding on Smart Array.
The prosumer parallel is the M.2 NVMe write cache on units like the Synology DS920+ and DS1621+, where a cache device dropping off the PCIe bus produces the same class of loss.
If power is lost and that protection module has degraded or failed before the flush completes, the in-flight writes held only in volatile cache vanish. On RAID 60 the data and the P and Q parity for a stripe are written together.
Dropping the uncommitted writes leaves torn stripes, where the data blocks and the parity blocks on the platters are desynchronized, and on a multi-span array that desynchronization can land across more than one span at once.
This is one of the few outcomes where honesty requires stating a limit. Cache contents that never reached the platters are not present in any member image, so they are physically irrecoverable from cloned drives.
We reconstruct everything that was committed to the platters before the event and report the torn-stripe boundary; we do not claim to recover writes that lived only in failed cache. This is the reason RAID is availability, not data protection, and why a tested backup is the only defense against a write-back cache loss.
The nested geometry adds a hazard that a single-span array does not have. When an FBWC or BBU-backed write cache fails mid-write, the in-flight stripes can land partially across two or more RAID 6 spans at once, because the outer RAID 0 layer was striping the same logical write across spans when power dropped.
On the next mount the controller's consistency check reads the P and Q syndromes per span and reports cross-span parity mismatch on every span that held part of the torn write, not just one.
Do not run a controller consistency check or a parity scrub on a live RAID 60 that took an unclean shutdown after a BBU or FBWC failure. A consistency check resolves each mismatch by recomputing P and Q and writing the corrected parity blocks back in place across every affected span.
That rewrite overwrites the very parity evidence an offline reconstruction needs, before the array has been imaged. Power the system down, image every member through a write-blocked interface, and let the cross-span parity be analyzed against the clones rather than rewritten on the live members.
Critical: If a span is degraded and the array contains SMR members, power the system down. Do not force a rebuild on a degraded SMR-populated span. Label every drive by bay position and span index, and contact us for offline member-by-member imaging.
Reconstruction Workflow
Data Extractor Express RAID Edition Workflow for Multi-Span Reconstruction
Data Extractor Express RAID Edition handles RAID 60 as a two-phase reconstruction: first the RAID 6 sub-arrays, then the RAID 0 stripe layer. This mirrors the hardware controller's own logical architecture.
  1. Member image loading: All cloned member images are loaded into Data Extractor Express RAID Edition. The software scans each image for controller metadata (DDF headers, MegaRAID records, HP RIS blocks) to auto-detect span assignments.
  2. Span separation: Members are grouped into their respective RAID 6 sub-arrays. When auto-detection fails, we use parity signature analysis: the P and Q parity patterns within a span are mathematically distinct from data, allowing us to identify which drives share parity relationships.
  3. Per-span parameter detection: For each sub-array, Data Extractor Express RAID Edition detects the stripe block size (typically 64 KB or 256 KB for enterprise controllers), parity rotation direction (left-symmetric, left-asymmetric, right-symmetric), and P/Q parity algorithm variant. Each span may use different parameters if the controller was configured with non-uniform spans.
  4. Parity validation: Before assembling the stripe layer, we validate P and Q parity consistency across sample stripes in each sub-array. Inconsistencies indicate a misidentified member or incorrect rotation, which we correct before proceeding.
  5. Cross-span stripe assembly: The reconstructed sub-array images are treated as virtual drives and striped according to the detected cross-span stripe size and ordering.
  6. Filesystem verification: The assembled virtual volume is checked for valid filesystem structures (MBR/GPT partition table, NTFS MFT, EXT4 superblock, ZFS uberblock, VMFS volume header). A valid parse confirms the reconstruction parameters are correct.
Dual-Parity Mathematics
How does RAID 60 dual-parity reconstruction work?
RAID 60 reconstruction is hard because each inner RAID 6 span protects data with two independent parity blocks computed by different math: P is a plain XOR, and Q is a Reed-Solomon syndrome computed over the Galois field GF(2^8). The outer RAID 0 stripe geometry has to be solved first, before either parity block can be validated.
Every RAID 6 span carries two parity blocks so it can survive losing two members at once. The first block, P, is a plain exclusive-or across the data blocks in the stripe (P = a XOR b XOR c XOR d XOR e). That is the same single-parity arithmetic a RAID 5 uses. A RAID 5 has no Q block, so it tolerates only one missing member: with a single unknown, XOR alone reconstructs the lost block.
Any RAID 5 rebuild on a degraded array still has to read every surviving member in full, and the risk of an unrecoverable read error during that pass grows with array size and drive age, which is why we image member-by-member before any rebuild rather than letting a controller retry against live drives.
The second block, Q, is what separates RAID 6 from RAID 5. Q is a Reed-Solomon code computed with a generator over the finite field GF(2^8), so every parity byte stays inside 0 to 255 (one byte) instead of overflowing as the stripe grows.
Inside that field, addition and multiplication are redefined modulo an irreducible polynomial, which keeps the result bounded. The arithmetic resembles Q = 1·a + 2·b + 3·c + 4·d + 5·e, where the coefficients are field elements, not ordinary integers.
Two missing members in one span is the hard case. With two lost drives there are two unknowns, so P by itself is insufficient.
Recovery means solving a small system of linear equations built from both the P and Q syndromes. Because the parity generator matrix has linearly independent rows it is invertible, so the two missing blocks come out through Galois-field multiplications against that inverse. This is forensic software work performed in Data Extractor Express RAID Edition against cloned member images, not a controller "repair" button run against the original drives.
None of that per-span GF(2^8) solve is meaningful until the outer geometry is correct. The outer RAID 0 stripe order and chunk size, together with each inner span's parity rotation, have to be identified first, either from the DDF or RIS metadata parsed out of the cloned images, or from raw data-continuity analysis when that metadata is damaged.
Apply the parity math at the wrong block offsets and every span produces garbage. So the order is fixed: identify geometry across all members, validate P and Q per span against sample stripes, then assemble the outer stripe. Reverse that order and the math has nothing valid to operate on.
The same algebra explains the cascade threshold. Losing three drives inside one span gives three unknowns against only two parity equations, P and Q, so the GF(2^8) system for that span has no solution.
The outer RAID 0 layer then treats the span as a missing stripe member and takes the whole nested volume offline, the cross-span scenario covered in the failure section above. A degraded RAID 6 span inside a RAID 60 is still solvable while two equations cover two unknowns; the entire RAID recovery workflow is built to keep it in that solvable range by imaging first and reconstructing virtually.
That two-equation budget is spent by unknowns of both kinds, and it is spent per stripe. A failed member contributes an unknown to every stripe on that member; an unrecoverable read error contributes an unknown to the one stripe it lands in. They draw on the same P and Q budget.
A span already missing one member therefore has exactly one unknown of headroom left in each stripe: a URE on a surviving member is still solvable in that state, because two equations still cover two unknowns, and the same dual-parity erasure math recovers two lost symbols in a stripe where no member has failed at all. A second URE inside that same stripe is the third unknown, and that stripe has no solution.
Modern PERC and MegaRAID firmware handles that case by puncturing the affected stripe and leaving the virtual disk online, and mdadm records the address in its bad block log, so what is lost is the punctured region rather than the volume.
That is why the phrase "zero remaining fault tolerance" during a rebuild is a per-stripe statement and not a whole-array one, and why imaging first is not optional even with two parity blocks: every stripe the rebuild touches is spending headroom you cannot get back.
Enterprise Engagement
Working With Our Lab as an IT Department
RAID 60 arrays sit under production workloads: databases, virtualization clusters, surveillance archives. When one goes offline, the IT team on the other end of the engagement is answering to a recovery-point objective and a recovery-time objective that were set in a runbook, not invented during the outage. The sections below describe how our RAID recovery lab engages with enterprise IT teams during and after a case.
Recovery Time and Recovery Point Reality
A RAID 60 that is still mounting degraded has a different time profile than one that is fully offline. Arrays with 8-12 healthy members and no mechanical failures typically finish in 2-4 weeks from receipt. Arrays requiring head swaps on multiple members, or donor sourcing for 18-20 TB Exos and Ultrastar drives, run 4-8 weeks.
Rush scheduling moves a case to the front of the imaging queue (+$100 rush fee to move to the front of the queue). Per-member imaging throughput is governed by the slowest drive in the set; one drive with surface damage throttles the whole batch. We quote a target completion window after the free evaluation, once every member has been inspected.
The recovery point is whatever was committed to the array before the failure. Controller write-back cache that never flushed to disk is not recoverable from the cloned images; that data lived in volatile memory on the controller module. If the Smart Storage Battery failed on an HP Gen10 before the outage, assume any writes staged for flush during that window are gone.
Chain of Custody
Every member drive is photographed on arrival with serial number, bay position label, and inbound condition. Each drive receives a case-specific asset tag that ties the physical unit to its bay assignment and span index. Imaging sessions, head swaps, motor work, and PCB repairs are logged against the asset tag.
When recovered data is shipped back, the log file and inbound photographs are available on request. For customers who cannot put media on a common carrier, we coordinate hand-off to a customer-supplied courier at the Austin lab.
NDA and Procurement Terms
We sign customer-supplied mutual NDAs before any drive leaves your facility, and we review standard master service agreement language. We do not hold SOC 2, ISO 27001, HIPAA, or FIPS 140-3 attestations, and we will not claim otherwise on a procurement questionnaire.
If your security review requires those attestations, the honest answer is that a single-lab data recovery shop our size does not carry them; any competitor that does should be asked for the auditor report. Payment on enterprise engagements is due after successful recovery under the no-fix-no-fee guarantee; invoice terms are handled case by case with your AP team before the array ships back.
Direct Engineer Communication
The engineer working on your array is the person answering your call. No account manager layer, no offshore triage desk, no ticket routing between a front-office CSM and a back-office technician. When you ask about parity rotation on span 3 or the epoch timestamp on the drive from bay 14, the answer comes from whoever ran the PC-3000 session.
Case status updates are sent when there is a state change to report, not on a marketing cadence. For multi-site engagements (enterprise server recovery cases spanning multiple controllers), we will schedule a standing call with your infrastructure team for the duration of the case.
RAID 60 Recovery Pricing
RAID 60 pricing follows the same two-component model as all RAID recovery: per-member imaging fees for each drive in the array, plus an array reconstruction fee. If we recover nothing, you owe $0.
Cost ComponentPrice RangeNotes
Per-member imaging: logical or firmware-level issues$250–$900 per driveCovers filesystem corruption, firmware module damage requiring PC-3000 terminal access, and SMART threshold failures that prevent normal reads.
Per-member imaging: mechanical failures (head swap, motor seizure)$1,200–$1,500 air-filled / $3,000–$4,500 helium per drive50% deposit required. Donor parts are consumed during the transplant. Head swaps are performed on a 0.02 µm filtered clean bench before write-blocked cloning.
Array reconstruction feeScoped per array at free evaluationQuoted after evaluation based on span count, members per span, filesystem type, and whether parameters must be detected from raw data versus parsed from surviving metadata. Includes per-span P+Q parity validation and cross-span stripe assembly.
Data Extractor Express RAID Edition performs span identification, per-span parameter detection, and virtual assembly from cloned member images. R-Studio and UFS Explorer handle filesystem-level extraction after the array is reconstructed.
No Data = No Charge: If we recover nothing from your array, you owe $0. Free evaluation, no obligation.
RAID 60 arrays with 16+ members or mechanical failures on multiple drives will receive a custom quote after free evaluation.
RAID 60 Recovery Questions
How many drives can fail in a RAID 60 before data is lost?
RAID 60 tolerates up to two drive failures per span. A four-span array with 24 drives can lose up to eight drives total, provided no single span loses more than two. If a third drive fails within the same span, that span loses its dual-parity protection, and the stripe layer collapses the entire volume.
What is the minimum number of drives for RAID 60?
Eight drives: two spans of four drives each. Each span requires four drives minimum to form a RAID 6 sub-array (two data, two parity). Production deployments typically use 12 to 24 drives across three or four spans for the throughput and capacity that justify the configuration overhead.
When should I choose RAID 60 over RAID 6?
RAID 60 adds a RAID 0 stripe layer across multiple RAID 6 sub-arrays, which increases sequential throughput and distributes rebuild load. Choose RAID 60 when the array exceeds 8 drives and write performance matters (database servers, virtualization hosts). RAID 6 is simpler to manage and recovers more predictably for arrays with 4 to 8 drives.
How long does a RAID 60 rebuild take with 18 TB drives?
Rebuild time depends on the span size, not the total array size. A four-drive span with 18 TB Exos or Ultrastar members requires reading three surviving drives in full: 54 TB under sustained sequential I/O. On enterprise controllers with background priority settings, this takes 48 to 96 hours per span.
Why is RAID 60 recovery harder than RAID 6?
RAID 60 requires identifying which drives belong to which span, reconstructing each span's P and Q parity independently, and then assembling the RAID 0 stripe across all reconstructed sub-arrays. Misidentifying a single span boundary produces garbled output across the entire volume. RAID 6 recovery works with a single flat array and one parity rotation pattern.
Can you recover a RAID 60 if the controller card failed?
Yes. Hardware RAID controllers (Dell PERC, Broadcom MegaRAID, HP Smart Array) write span membership and configuration metadata to reserved sectors on each member drive. We parse that metadata from cloned images to reconstruct the array without the original controller. When metadata is corrupted or missing, we determine span boundaries and parameters from raw data continuity patterns.
Do you sign NDAs and work under our procurement terms?
Yes. We sign customer-supplied mutual NDAs before any drive leaves the customer facility, and we will review standard master service agreement language. We do not claim SOC 2, ISO 27001, or HIPAA compliance; any vendor making those claims for a single-lab data recovery shop should be asked for an auditor report. Payment terms for enterprise engagements are net on invoice after successful recovery under the no-fix-no-fee guarantee.
Who inside your shop actually talks to our IT team during a recovery?
The engineer working on the array. No account manager layer, no ticket-routing queue, no offshore triage desk. When you call during a RAID 60 case, the person on the phone is the same person who mapped your span boundaries in Data Extractor Express RAID Edition the night before. Hand-off notes exist only when a case crosses a shift boundary, and they are written by the engineer.
How is chain of custody documented on an enterprise RAID 60 case?
Every member drive is photographed on arrival with serial number, bay position label, and inbound condition. Each drive receives a case-specific asset tag tied to its bay assignment and span. Imaging, head-swap, and reassembly steps are logged per drive. On request, we return the log file and inbound photographs with the recovered data, and we can hand-deliver media to a customer courier rather than ship common carrier.
Can SMR drives cause a RAID 60 rebuild to fail?
Yes. SMR drives absorb writes into a small CMR media cache before laying overlapping shingled tracks. The sustained sequential writes of a rebuild overflow that cache, and the firmware halts host I/O for background reshingling. The controller flags the stalled SMR member as dead and ejects it. If this happens to multiple members inside an already-degraded span, the span crosses its two-fault threshold and the striped RAID 60 volume collapses. The safe path is offline member-by-member imaging with ddrescue or PC-3000 before any rebuild.
Can you recover an NVMe RAID 60 array from a Broadcom Tri-Mode controller?
Yes. Broadcom Tri-Mode MegaRAID controllers run SAS, SATA, and NVMe members concurrently in one U.3 bay. The 9560-16i and 9580-8i8e are 9500-series PCIe Gen4 parts; the 9670-24i is a 9600-series 24G SAS part, not a 9500. Each RAID 6 span in a RAID 60 carries two parity blocks (P and Q), so mixed-transport imaging discipline matters across many spans at once. An NVMe U.2/U.3 member uses native PCIe and cannot be imaged through a SAS HBA in IT mode the way a SAS or SATA member can, so it is cloned on a native PCIe path with PC-3000 SSD, while SAS members are imaged through HBAs in IT mode and conventional HDD members through PC-3000 Express, PC-3000 Portable III, or DeepSpar Disk Imager. Every member is imaged before reconstruction begins, because a blind rebuild on native hardware can eject a healthy NVMe member on a transient PCIe link timeout. The SNIA DDF geometry (stripe size, span and member order, per-span P and Q parity rotation, epoch history) lives on the member disks, so the original Tri-Mode controller is convenient but not required. We reconstruct the array offline from the clones with Data Extractor Express RAID Edition.
What happens to RAID 60 data in the controller write-back cache after a power loss?
Unflushed writes that lived only in the controller DRAM write-back cache are lost if power fails and the cache protection module, whichever the vendor fitted, has degraded or failed before the flush completes. Because RAID 60 writes data and its P and Q parity together, dropping those uncommitted writes leaves torn stripes where data and parity on the platters are desynchronized, sometimes across more than one span. That cache content never reached the platters, so it is physically irrecoverable from cloned member images. We recover everything committed before the event and report the torn-stripe boundary. This is why a tested backup matters: RAID is availability, not data protection.
Degraded RAID 60? Power down before rebuilding.
Free evaluation. Offline multi-span reconstruction from cloned images. No data = no charge. Mail-in from anywhere in the U.S.
