Short Answer
Federal law (Magnuson-Moss Warranty Act, 15 U.S.C. 2302) prohibits manufacturers from voiding your warranty for using a third-party repair service unless they prove the service caused the damage. But if your SSD is dead and you need the data on it, a warranty claim sends you back an empty replacement drive. Data recovery and warranty replacement solve different problems.
Samsung's warranty terms treat an opened casing, a removed label or barcode, & a tampered or missing serial number as warranty-voiding, & Samsung doesn't recover data during an RMA. Most SSD work runs through the drive's SATA or NVMe interface with the enclosure sealed & the label intact, so the warranty question & the recovery question aren't the same question.
Magnuson-Moss Warranty Act and SSD Repair
The Magnuson-Moss Warranty Act (15 U.S.C. 2302(c)) is a federal statute that governs consumer product warranties. Section 2302(c) states that a warrantor cannot condition warranty service on the use of any article or service identified by brand, trade, or corporate name unless that article or service is provided free of charge. In plain terms: a manufacturer cannot require you to use only their authorized service centers as a condition of maintaining warranty coverage.
For SSD owners, this means sending your failed drive to an independent recovery lab does not automatically void the manufacturer warranty. The manufacturer must demonstrate that the third-party service caused the specific failure you are claiming under warranty. If the drive was already dead when it arrived at the lab, and the lab did not cause additional damage, the warranty claim stands.
In 2018, the FTC sent formal warning letters to six major companies stating that "Warranty Void If Removed" stickers and similar language violate the Magnuson-Moss Act. The FTC found that conditioning warranties on the use of specified parts or services, unless provided free of charge, is illegal under federal law.
This is a legal topic. If warranty preservation is critical to your situation, consult a lawyer for advice specific to your case, your drive manufacturer, and your warranty terms.
Warranty Replaces Hardware, Not Data
Every major SSD manufacturer handles warranty claims the same way: they swap the failed drive for a blank replacement. Samsung, Western Digital, Crucial, Kingston, and SK hynix all state in their warranty terms that data recovery, data transfer, and data backup are the customer's responsibility.
The warranty covers the physical hardware. It does not cover what was stored on it.
If you need the data on the failed drive, warranty service will not help. The replacement drive arrives empty. Your original drive is either destroyed or refurbished and sent to someone else. SSD data recovery is the only path to retrieving files from a dead SSD.
The real question is not whether data recovery voids your warranty. The question is whether the data on your SSD is worth more than a replacement drive that costs $30 to $150 retail.
Can Recovery Software Pull Data Off a Dead SSD Before a Warranty Claim?
Recovery software only works when the SSD still identifies correctly to the OS & TRIM has not erased the blocks you need. A dead controller, corrupt FTL, or shorted 3.3V PMIC cuts off logical access, so tools like Disk Drill or R-Studio have nothing usable to read.
Disk Drill, EaseUS, PhotoRec, & R-Studio are for logical damage on a physically healthy SSD. On Windows 7+, and on macOS with an Apple-shipped SSD, TRIM is usually active by default, so deleted blocks can be zeroed before any software scan finishes. If you need the full failure map, start with our SSD data recovery.
PC-3000 SSD works below consumer software. It can rebuild a corrupted FTL translator when the controller is still alive, but controller failure & NAND failure are different jobs. A damaged firmware path points toward firmware recovery; worn NAND pushes the work toward raw-flash reconstruction, and some newer NVMe drives still block chip-off because the decryption key path lives in the original controller.
On a dead board, FLIR thermal cameras locate the short before any rework starts. Once the fault is isolated, a Hakko FM-2032 replacement attempt tries to bring the original controller back online. That board-repair bridge matters on encrypted NVMe drives, because reviving the original controller can preserve the decryption path described on our hardware encryption recovery page.
SSD Manufacturer Warranty Policies and Data
Each manufacturer publishes specific language about data responsibility in their warranty terms. None of them offer data recovery as part of the warranty process.
- Samsung
- Samsung's SSD warranty terms state that the customer is responsible for backing up data before returning a drive for warranty service. Warranty replacements are new or refurbished units. Samsung does not recover data from failed drives. Samsung 870 EVO, 980 Pro, and 990 Pro all follow this same policy. For Samsung SSDs with hardware-encrypted controllers (980 Pro and 990 Pro bind AES-256 to Samsung's in-house controller), the encryption key is lost when the warranty replacement arrives because the key lived in the original controller's silicon.
- Western Digital and SanDisk
- Western Digital's warranty policy covers replacement of the defective product. Their terms explicitly state that WD is not responsible for any loss of data and recommend customers maintain backup copies. This applies to all WD Blue, WD Black, and SanDisk Extreme/Ultra branded SSDs. The WD warranty portal requires shipping the failed drive to WD, which means your original drive with your data on it leaves your possession.
- Crucial (Micron)
- Crucial's limited warranty covers defects in materials and workmanship. Their warranty terms state that Crucial is not liable for any data loss and the customer is responsible for data backup. Crucial MX500, P3, and P5 Plus warranty claims all result in replacement hardware with no data transfer.
The pattern is consistent across the industry. No SSD manufacturer offers data recovery under warranty. Seagate offers an optional paid add-on (Rescue Data Recovery Services) for some products, but this is a separate paid service, not a warranty benefit, and it applies primarily to their HDD product line.
Tamper-Evident Seals and Void Stickers
Some SSD enclosures (particularly 2.5-inch SATA drives in metal cases) have tamper-evident labels or "Warranty Void If Removed" stickers on the screws. These stickers do not override federal law. The FTC's 2018 enforcement action confirmed that manufacturers cannot condition warranties on unbroken seals unless they provide the sealed component free of charge.
Most professional SSD data recovery does not require opening the drive enclosure at all. Firmware-level recovery via the PC-3000 SSD connects to the drive through its standard SATA or NVMe interface. The drive's case stays sealed.
Board-level repair (replacing a failed capacitor or voltage regulator) requires accessing the PCB, which may involve removing a label. NAND chip-off, the last resort for drives with destroyed controllers, removes NAND packages from the board and is inherently destructive.
The practical reality: if your SSD is dead and needs data recovery, the sticker on its case is not the deciding factor. The data is either worth recovering or it is not.
How Professional SSD Recovery Works Without Damaging the Drive
Most SSD data recovery at our lab starts and finishes at the firmware level. The drive connects to the PC-3000 SSD diagnostic platform through its standard SATA or NVMe interface.
The PC-3000 puts the controller into technological (diagnostic) mode and communicates directly with the SSD's firmware. Corrupted firmware modules, damaged system area pages, and translation layer errors are repaired without any physical modification to the drive.
This type of recovery does not void any warranty because nothing on the drive is physically altered. The PC-3000 accesses the controller's factory technological mode to bypass damaged firmware and reconstruct translation tables. The drive's enclosure is never opened. No components are replaced. The serial number sticker and tamper labels stay intact.
When firmware recovery is insufficient (dead controller, failed power management IC, shorted capacitors), we move to board-level diagnostics. FLIR thermal imaging identifies hot spots on the PCB. Hakko FM-2032 microsoldering irons replace failed components. This restores controller functionality so the PC-3000 can access the data. Board-level repair modifies the PCB but preserves the controller and its hardware encryption keys.
SSD Recovery Escalation: Least Invasive First
Every SSD that arrives at our Austin lab follows the same escalation path, starting with the method least likely to affect warranty status.
- Firmware recovery (PC-3000 SSD). No physical modification. Drive connects through its standard interface. Controller enters diagnostic mode. Corrupted firmware is repaired. Drive enclosure stays sealed.
- Board-level component repair. Failed capacitors, voltage regulators, or PMICs are replaced using Hakko microsoldering. The original controller stays in place. Encryption keys remain intact because the controller silicon is preserved.
- NAND chip-off (last resort). Used only when the controller is destroyed and the drive does not use hardware encryption. NAND chips are desoldered, read individually, and data is reconstructed. This is destructive. See our chip-off NAND recovery page for details.
We will tell you which method your drive requires before starting work. You receive a firm quote and approve the approach. No work begins without your authorization.
Which SSD Recovery Procedures Preserve or Destroy Warranty Eligibility
The recovery procedure determines whether the drive can still pass a physical warranty inspection after work is complete. A firmware-level operation that never opens the case is invisible to the manufacturer. A desoldered NAND package is permanent, documented evidence that the PCB was reworked. This section enumerates specific procedures used at our lab and the physical trace each one leaves on the drive.
Non-Invasive Procedures (No Physical Evidence)
- PC-3000 SSD vendor-command access through standard interface
- The drive is connected through its native SATA or NVMe interface with no modification. The PC-3000 SSD issues vendor-specific technological commands to put the controller into diagnostic mode, rebuilds the translator, replays damaged firmware modules, and reconstructs the system area. The enclosure stays sealed. No stickers are broken. Samsung, WD, Crucial, and SK hynix cannot distinguish a drive that went through this process from one that was never plugged into anything but the customer's computer.
- Controller ROM read through debug test points
- Many consumer SSD controllers expose JTAG or UART debug pads on the PCB. Reading the controller ROM through these pads requires the 2.5-inch case to be opened or the M.2 drive's top-side label peeled back. On bare M.2 drives with no label covering the controller, the read leaves no physical evidence at all. On labeled drives, the label is lifted with a heated blade and reapplied; an experienced technician can do this without visible deformation, but a manufacturer inspector looking for adhesive disturbance may detect it.
- Firmware module replay and translator rebuild
- Corrupted FTL tables, GCT entries, and module descriptors are rewritten to the drive's system area using the PC-3000 SSD. This is a write operation inside the drive's service area, invisible to SMART and invisible to any external inspection. The drive ships back to the customer or back to the manufacturer physically identical to when it arrived.
Invasive Procedures (Permanent Physical Evidence)
- Board-level component replacement
- Failed MLCCs (multi-layer ceramic capacitors), power management ICs, and DC-DC regulators are replaced at board level. We use a Hakko FM-2032 microsoldering iron for that work. The controller and NAND packages stay in place; encryption keys are preserved. This modifies the PCB but the drive still works. Manufacturer inspection will see reflowed solder on the replaced component under magnification. Warranty is typically void at this point, but the data is recoverable and the customer can keep the drive.
- Package lift on older SATA SSDs
- Older 2D planar packages found on Kingston V300 and assorted entry-level SATA SSDs from 2012-2016 are removed with hot air and a lift tool. These are usually TSOP-48 NAND packages. The package is read through a raw-flash workflow, then reseated or discarded. The pads are permanently marked. Warranty is void by definition. Any technician examining the board can see the lift scars.
- Package desolder on modern 3D flash SSDs
- BGA-packaged 3D flash (most NVMe drives since 2018) is removed with an Atten 862 hot air rework station at controlled preheat. The package then goes through a raw-flash read workflow with the correct socket or adapter. This is destructive: the solder joints are replaced with tin splashes on the pads, and any manufacturer RMA will reject the drive on physical inspection.
- Monolithic NAND die extraction (USB sticks and BGA SSDs)
- Monolithic flash (eMMC-style packages where the controller die and NAND die share a single substrate, common in budget USB sticks and some DRAMless SSDs) requires direct wire-bond tapping or polishing to expose die test pads. This is the most destructive procedure. The package is destroyed in the process. Nothing remains for warranty inspection.
Manufacturer Tamper Indicators
Consumer SSDs do not all use the same tamper evidence. Knowing which indicator lives on your specific drive helps predict what a warranty inspector will look for.
- WD Black SN850X and SN770
- Graphite heat-spreader label with strong acrylic adhesive. The label bonds to the controller and NAND packages and cannot be removed cleanly. Any attempt to lift it leaves visible fiber tearing on the back side. The label serves as both a thermal interface and a tamper indicator.
- Crucial T705 and T700
- Crucial's Gen5 drives ship with a thermally conductive tamper-evident label across the Phison E26 controller and the Micron 232-layer TLC NAND on the top side of the PCB, sitting directly under the bundled heatsink. Removing the heatsink exposes the label immediately. The label is checked at the Crucial RMA inspection stage, and lifting it tears the paper-and-foil composite and disturbs the thermal interface.
- Samsung 970 EVO Plus and 870 EVO
- Mainstream-tier Samsung drives use a paper-and-foil composite label across the controller and NAND. The 870 EVO uses the MKX controller; the 970 EVO Plus shipped with Samsung's earlier in-house NVMe controller at launch and was silently revised in 2021 to the Elpis controller (the same silicon used in the 980 Pro), so a 970 EVO Plus that arrives at the lab requires controller identification before the recovery path is chosen. The label is thinner than the copper heat-spreader used on the 980 Pro and 990 Pro, but it carries the serial number, model number, and the warranty barcode on the same surface. Tearing the label to access the controller destroys the inspection-grade identifiers; an RMA submission depends on the drive presenting a valid serial through SMART instead. The 970 EVO Plus and 870 EVO ship with Samsung V-NAND in BGA packages soldered to the PCB, so any destructive NAND extraction also leaves reflowed pads visible to manufacturer inspection.
- Crucial MX500
- The Crucial MX500 ships in a 7mm 2.5-inch aluminum case held by four Phillips screws. A small round paper void label sits over one of the rear screws. The label tears on first removal; it is not designed to be peeled and reapplied. Crucial's warranty terms publish the standard data-loss disclaimer. The MX500 uses Silicon Motion's SM2258 controller. The PC-3000 SSD can use that controller's vendor commands for firmware-level recovery without ever opening the case. Firmware-level work on an MX500 leaves the void label intact. Board-level work on the SM2258 or the Micron 64-layer TLC package requires breaking the label and ends RMA eligibility.
- WD Blue mainstream NVMe drives
- WD's mainstream consumer NVMe drives use an under-label tamper indicator rather than the graphite heat-spreader found on the SN850X. The SN570 and SN580 ship with a thin paper label across the top of the M.2 stick. Under that label sit the SanDisk-branded in-house WD controller and the BiCS5 112-layer TLC flash. Behind the label is a small printed indicator that smudges or tears if the label is lifted with heat. WD's warranty inspection process checks for this indicator before approving an RMA. The SanDisk-branded in-house WD controllers used on SN570 and SN580 are not currently tracked by ACELab in the PC-3000 SSD supported list, so Rossmann does not offer in-lab firmware-level recovery for these drives.
- Enterprise U.2 and U.3 NVMe drives
- Enterprise-grade U.2 drives (Intel D7-P5520, Micron 7450, Solidigm D5-P5430) are encased in sealed metal enclosures, often with tamper-evident labels across the seam. Opening one for recovery leaves visible evidence. The drive cannot be closed back up to look untouched. Enterprise warranty policies assume the drive will never be opened, so the RMA path and the recovery path are entirely mutually exclusive for this class of hardware.
Electrical Failures, NAND Survival, and the Burden of Proof
Most SSD failures we see at the lab are electrical, not media-level. A blown TVS diode on the 3.3V rail, a shorted power management IC, or a cold solder joint on a voltage regulator kills the drive's ability to enumerate over SATA or PCIe; this is the failure class our SSD electrical failure recovery work addresses. The NAND packages and the data inside them are unharmed; the drive simply has no functioning power path to read them.
This is the failure class where the controller-to-flash pairing matters. If board-level repair restores the original controller and its DRAM and PMIC, the firmware mapping tables stored in the system area come back online and the user data is reachable through the same translator the drive was using before failure.
The Magnuson-Moss Warranty Act's 15 U.S.C. 2302(c) language places the burden on the manufacturer to prove that a third-party action caused the failure being claimed. For a drive that arrived at the lab dead, board-level repair that replaces a single shorted MLCC capacitor or a failed PMIC restores function, but the underlying defect (often a manufacturing-stage component fault) predates any third-party work. The original failure and the repair are different events.
Whether the manufacturer accepts that distinction at RMA inspection depends on their policy and on what physical evidence the repair leaves behind; component-level microsoldering work is visible under magnification and a manufacturer can decline the RMA on those grounds. Magnuson-Moss does not force them to accept it; the statute only forces them to prove third-party causation if they want to deny on that basis.
The practical decision is the same on every electrically-dead consumer SSD still under coverage: file the warranty claim first if the data is not critical, because the manufacturer will replace the drive at no charge with no questions asked about data. If the data is critical, board-level recovery preserves the data but ends the realistic path back to a free RMA replacement, regardless of what the statute says about burden of proof. This is a legal topic with manufacturer-specific policies; consult a lawyer if a contested RMA decision turns on the third-party-causation clause.
Hardware-Encrypted SED Drives Force the Destructive Path
Self-encrypting drives (SED) that implement the TCG Opal 2.0 specification store the Data Encryption Key (DEK) inside the controller silicon itself. The Key Encryption Key (KEK) derived from the user password unlocks the DEK, but the DEK never leaves the controller.
When the controller is physically dead (cracked die, shorted power rail, or ESD damage to the internal key storage), no amount of NAND chip-off recovery will produce readable plaintext. The NAND pages are AES-256 ciphertext that cannot be decrypted without the original controller's DEK.
This forces a binary choice on any SED drive with a destroyed controller. Either the data is unrecoverable, or the recovery requires reviving the original controller through board-level power-path repair that preserves the original controller and its DEK access. There is no non-invasive path for a dead SED controller; the encryption architecture rules it out.
The Samsung 980 Pro and 990 Pro implement TCG Opal 2.0 / AES-256 Class 0 encryption at the controller level, and enterprise U.2 drives almost universally ship with Opal enabled at the factory. On those drives, the encryption engine is active even when the user never sets a password, because the factory-default null credential still gates the DEK. On NVMe drives that do not implement Opal hardware encryption at the controller level, chip-off recovery is not mathematically blocked by a controller-bound key.
Which SSD Manufacturers Publish a Written Data Recovery Exception
Not every SSD manufacturer treats third-party data recovery the same way. Two of the largest publish an explicit recovery exception in their warranty terms; the rest do not.
The distinction matters because Western Digital and SanDisk will keep the warranty alive on a returned drive if the recovery lab provides documentation on company letterhead. The other major brands do not offer that path.
- Western Digital and SanDisk: written exception
- Western Digital's data recovery policy page states that "Western Digital will not void the warranty associated with the disk drive you purchased from a Western Digital reseller or distributor" if the customer uses a third-party recovery service, provided that service supplies "written verification, on its company letterhead, that it has performed data recovery or other services on your hard drive." SanDisk publishes identical language under WD's warranty architecture. We provide that letterhead documentation on every WD Blue, WD Black, SanDisk Extreme, and SanDisk Ultra recovery so the customer can return the husk to WD for a free replacement after we hand them their data back. Source: westerndigital.com/support/store/warranty-services/data-recovery.
- Samsung: no written exception
- Samsung's consumer SSD warranty page states that "regardless of the method used, modifying or tampering with the Samsung SSD will void Samsung's warranty on the SSD," and lists "tampered or missing tape seal or serial number" as a specific warranty exclusion. The same page states that "data recovery is not covered under this warranty and is not part of the replacement process." Samsung publishes no letterhead exception. Source: semiconductor.samsung.com/consumer-storage/support/warranty.
- Kingston: no written exception
- Kingston's warranty page states that "the Kingston limited warranty does not apply to products that have undergone any unauthorized disassembly, repair, or modification," and that the warranty is void "if the original identification information on the product has been altered, obliterated, or removed." Kingston also publishes no letterhead exception. A drive shipped to us for board-level work on a Kingston KC3000, KC2000, or A2000 will not be eligible for RMA after the work. Source: kingston.com/en/company/warranty.
- Crucial / Micron: thermal-label tamper indicator
- Crucial's warranty page covers defects in materials and workmanship and does not publish an explicit third-party recovery exception. The factory thermal-pad label across the controller and NAND on Crucial Gen4 and Gen5 M.2 drives carries the warranty barcode and the "Warranty Void If Removed" instruction on the same sticker, so peeling that label to install an aftermarket heatsink is treated as tampering at the Crucial RMA inspection stage. Source: crucial.com/company/warranty.
FTC July 2024 Enforcement on "Warranty Void If Removed" Stickers
On July 3, 2024, the FTC sent formal warning letters to ASRock, Zotac, and Gigabyte over "warranty void if removed" sticker language placed on PC components in locations that obstruct routine maintenance and repair. The 2024 action is a direct continuation of the 2018 letters and signals that the FTC reads the same Magnuson-Moss tie-in-sales rule the same way today as it did six years ago.
The practical consequence for SSD owners: a thermal label printed with "Warranty Void If Removed" carries no more legal weight in 2026 than it did in 2018, but the manufacturer can still decline an RMA on the separate grounds that the physical evidence of tampering proves the customer caused the failure. The statute shifts the burden of proof; it does not auto-approve the RMA. Source: ftc.gov press release.
The realistic playbook for an SSD owner with a dead drive still under coverage: if the data is not critical, file the RMA and accept a free replacement; if the data is critical and the brand is WD or SanDisk, request letterhead documentation from your recovery lab and pursue both paths; if the brand is Samsung, Kingston, or Crucial, accept that board-level recovery and RMA replacement are mutually exclusive and pick the one that matches the value of the data. For more detail on the recovery work that precedes any of these warranty decisions, see our SSD data recovery service page.
Procedure Invasiveness, PCB Evidence, and Warranty Implication
Different recovery procedures leave different physical traces. The table below lists the procedures we run at the Austin lab, what each one physically does to the drive, whether the work is visible to a manufacturer inspector, and how the warranty status changes as a result. Use this as a reference before approving a quote.
| Procedure | What it does physically | PCB evidence | Warranty implication |
| PC-3000 SSD register-level imaging through SATA / PCIe | Drive connects through its native interface. PC-3000 issues vendor commands to enter the controller's diagnostic mode and reads logical sectors. | None. No enclosure opened. No label lifted. | Warranty preserved on every brand. Inspection cannot detect that the procedure occurred. |
| Firmware module replay and translator rebuild | PC-3000 SSD rewrites corrupted FTL tables, GCT entries, and module descriptors into the drive's system area through the same vendor command channel. | None. Service-area write only. Invisible to SMART and to external inspection. | Warranty preserved. The drive is physically identical after the procedure. |
| Test-pad short for controller safe mode | Technician shorts controller ROM debug pads on the PCB with metallic tweezers during power-on to force a busy-state drive into diagnostic mode. | Minimal on bare M.2 PCBs with exposed pads. Requires opening 2.5-inch SATA cases or lifting M.2 thermal labels if pads sit under the label. | Warranty preserved on M.2 drives where pads are exposed. Voided on 2.5-inch SATA (broken tape seal) and on M.2 drives with controllers buried under a thermal label. |
| Board-level component replacement (PMIC, MLCC, voltage regulator) | Failed power components are desoldered and replaced using a Hakko FM-2032 microsoldering iron. Original controller and NAND packages stay in place. | Reflowed solder on the replaced component is visible under magnification at manufacturer RMA inspection. | Voided in practice on Samsung, Kingston, and Crucial. WD and SanDisk may accept the RMA with our letterhead documentation; not guaranteed. |
| NAND chip-off (TSOP-48 or BGA package desolder) | NAND packages are removed from the PCB. Read individually in a programmer or adapter. Used only when the controller is destroyed and the drive is not hardware-encrypted. See our chip-off NAND page. | Permanent. Solder pads are marked or stripped. Tin splashes remain. No reseat hides the work. | Voided across all brands. RMA inspection will reject the drive on physical grounds. |
| Monolithic die extraction | Direct wire-bond tapping or substrate polishing on eMMC-style packages where the controller die and NAND die share one substrate. | Destructive. The package is destroyed during the procedure. | Voided. Nothing remains for the manufacturer to inspect or replace. |
We start every drive with the least invasive procedure that has any chance of succeeding. Most consumer SSD jobs that come into the lab stop at row one or row two, which is why most jobs leave warranty status untouched.
The PC-3000 SSD register-level path covers controllers from Silicon Motion, Phison, and Marvell that ACELab tracks as supported in PC-3000 SSD. Rossmann does not currently offer in-lab recovery for the SanDisk-branded in-house WD controllers on the SN770 and SN850X, Realtek, or Innogrit; those drives require an authorized partner that has direct vendor cooperation. Modern Samsung in-house silicon such as Elpis sits outside that list too, and those drives are taken case by case: one that still enumerates may need only a logical recovery.
Conditions That Void Your SSD Warranty Before the Drive Reaches Our Lab
A meaningful percentage of SSDs that arrive at the lab have warranties that were already void before shipping. The cause is usually a prior repair attempt, physical trauma, or a category of damage that every manufacturer publishes as a warranty exclusion.
If any of the conditions below apply to your drive, your warranty status is already settled. The recovery decision is independent of the RMA question.
- Visible PCB damage or prior rework
- Cracked PCBs, sheared M.2 or SATA connectors, bent contact pins, cold solder joints from a previous repair attempt, jumper wires across the board, or hot-glue residue. These are the conditions our physical SSD damage recovery work handles. Manufacturer inspection looks for these conditions first. Any of them ends the warranty path regardless of the underlying failure.
- Burnt voltage regulators, blown PMICs, scorch marks
- Power surge damage on the 3.3V rail typically leaves a small dark spot or a fully carbonized component on the PCB. This evidence is unambiguous at intake and unambiguous at manufacturer RMA inspection. Catastrophic overheating that discolors the PCB or scorches the controller package falls in the same category.
- Liquid intrusion and corrosion
- Water spills, condensation in laptop-mounted M.2 drives, and beverage damage produce visible corrosion on PCB pads and solder joints. Every major SSD manufacturer publishes liquid damage as a warranty exclusion.
- Removed or destroyed manufacturer label
- The factory label carries the serial number and warranty barcode on Samsung, Crucial, and most WD consumer NVMe drives. If the label is missing, torn beyond reading, or has been replaced with a third-party aftermarket sticker, the manufacturer cannot match the drive against its RMA database. Samsung's warranty page lists "tampered or missing tape seal or serial number" as a specific exclusion.
- Thermal label removed for aftermarket heatsink
- Peeling the M.2 thermal label to install a motherboard or aftermarket heatsink is one of the most common pre-existing void conditions we see. The label is treated as tamper evidence by Samsung, Crucial, Kingston, and most WD consumer NVMe SKUs. The FTC has flagged this exact sticker practice as legally questionable, but the manufacturer can still decline the RMA on the physical-evidence basis described earlier on this page.
- Endurance limit exceeded (TBW)
- Every consumer SSD warranty is capped by a Total Bytes Written value as well as a chronological term. Crypto mining (Chia farming in particular), database workloads on consumer drives, and chronic write-amplification scenarios can blow through the TBW figure well inside the calendar warranty period. Once SMART reports endurance past 100 percent of the rated TBW, the drive is out of warranty even if it failed yesterday.
- OEM and system-builder warranty differences
- SSDs that shipped inside a pre-built Dell, HP, or Lenovo system are usually covered by the system OEM's warranty rather than the SSD manufacturer's retail warranty. The OEM warranty often requires returning the entire system, not the drive alone, and frequently excludes drives that have been removed from the chassis. Check the system OEM's support portal before assuming an SSD manufacturer's retail warranty applies.
When a drive arrives at the lab in any of these conditions, we document the pre-existing damage during intake photography so the customer has a record. The warranty status is already what it is.
The recovery decision is independent: the data is either worth our pricing or it is not, and the manufacturer is no longer part of the conversation. This is a legal topic; consult a lawyer if a specific warranty dispute matters to your situation.
SSD Recovery Pricing
SATA SSD recovery: $200–$1,500. NVMe SSD recovery: $200–$2,500. The final price depends on the failure type and which recovery method is required. Firmware-level recovery and board-level repair both cost less than NAND chip-off.
No diagnostic fees. No data, no fee guarantee. A rush fee of +$100 is available to move to the front of the queue.
Tiers that require a donor drive (PCB/NAND swap) carry an additional donor cost. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
The flagship SSD data recovery page has the complete five-tier pricing table. Call (512) 212-9111 for a free evaluation.
Does data recovery void my SSD warranty?
Will the manufacturer recover my data under warranty?
Can recovery software get data off a dead SSD before I use the warranty?
What does the Magnuson-Moss Warranty Act protect?
Do 'Warranty Void If Removed' stickers have legal force?
Does professional SSD recovery damage the drive?
Will removing the warranty label void my Samsung SSD?
Does opening an M.2 NVMe enclosure leave visible evidence?
What conditions make my SSD warranty void at intake before recovery starts?
Will Western Digital or SanDisk honor the warranty after data recovery?
Need data from a dead SSD?
Free evaluation. $200–$1,500 for SATA, $200–$2,500 for NVMe. No data, no fee.
