PC-3000 SSD Recovery Workflows
Phison SSD Controller Recovery Procedures
This is the Phison controller-family page for our SSD data recovery. Phison controller recovery starts with Technological Mode: shorting the ROM_CS pin on the PCB to force the controller out of its firmware panic loop, then injecting a volatile microcode loader into RAM through PC-3000 SSD. The loader bypasses the corrupted firmware stored in NAND, disables TRIM & garbage collection, and provides raw read access to reconstruct the Flash Translation Layer.
This page covers the specific PC-3000 workflows for the PS3111-S11, PS5012-E12, PS5013-E13T, & PS5019-E19 controller families. SATA firmware recovery starts at $600–$1,200. NVMe firmware recovery starts at $900–$1,200; no diagnostic fee.
Updated May 2026
What should you do when a Phison SSD shows SATAFIRM S11?
Stop powering the SSD & do not run MPTool, PhisonToolBox, Disk Drill, EaseUS, or firmware flashers. SSD data recovery uses PC-3000 SSD Technological Mode to load temporary microcode, rebuild the FTL, & image the NAND without rewriting it.
Which Phison Controllers Does PC-3000 SSD
Which Phison Controllers Does PC-3000 SSD Support?
SSD data recovery for Phison controllers uses PC-3000 SSD's Phison utility, which covers eight controller families across SATA & NVMe. Support depth varies: some controllers get full FTL reconstruction while others are limited to firmware repair. The hardware platform matters too; NVMe controllers require the PC-3000 Portable III with its PCIe M.2 adapter.
UDMA-E & Express boards handle SATA only.
ControllerInterfacePC-3000 HardwareEncryptionSupport Level
PS3111-S11SATAExpress, Portable IIIXOR scramblingFull: loader injection, FTL rebuild, data extraction
PS3110-S10SATAExpress, Portable IIIXOR scramblingFull: loader injection, FTL rebuild, data extraction
PS5012-E12NVMe Gen3Portable III onlyOptional AES-256 + XOR scrambling + LDPCFull: loader injection, FTL rebuild, data extraction
PS5013-E13TNVMe Gen3Portable III onlyOptional AES-256 + XOR scrambling + LDPCFull: loader injection, FTL rebuild, data extraction
PS5016-E16NVMe Gen4Portable III onlyOptional AES-256 + XOR scrambling + LDPCFull: loader injection, FTL rebuild, data extraction
PS5018-E18NVMe Gen4Portable III onlyOptional AES-256 + XOR scrambling + LDPCFirmware repair only; full FTL extraction limited
PS5019-E19NVMe Gen4Portable III onlyOptional AES-256 / TCG Opal + XOR scrambling + LDPCFull: loader injection, FTL rebuild, data extraction
PS5021-E21TNVMe Gen4Portable III onlyOptional AES-256 + XOR scrambling + LDPCFull: loader injection, FTL rebuild, data extraction
PS5026-E26NVMe Gen5Not supported by PC-3000 SSD as of April 2026Optional AES-256 / TCG Opal + XOR scrambling + 5th Gen LDPCNot supported by PC-3000 as of April 2026; board-level repair only
PS5018-E18 support is limited to firmware repair operations. Full virtual translator data extraction is not available through PC-3000 for the E18. Board-level repair of PMIC or power-rail faults, followed by standard NVMe imaging if the original controller still enumerates, is the primary recovery path for non-responsive E18 drives.
Phison Flash ID and Controller Marking
How Do You Read a Phison Flash ID and Controller Marking?
A Phison controller marking & a Phison flash ID answer two different questions. The marking printed on the controller package fixes the silicon platform & the host interface. The flash ID is the identification bytes a NAND die returns to a READ ID command, & it fixes the memory configuration the recovery workflow has to match.
Intake reads both before anyone picks a workflow. The marking decides which PC-3000 SSD hardware the drive connects to; the flash ID decides which loader profile that silicon needs once it is talking.
Controller marking, NAND flash ID, and drive identity string
Phison controller part marking
The alphanumeric string printed on the controller package, read under the microscope with the drive open. A PS3111-S11 marking is SATA silicon. A PS5012-E12 or PS5016-E16 marking is NVMe silicon, which is where an NVMe SSD recovery job diverges from a SATA one: the drive has to come up on the PC-3000 Portable III through its M.2 adapter. The marking establishes the platform, not the state of the data.
NAND flash ID
The identification bytes a NAND die returns to a READ ID command. Those bytes establish the memory manufacturer, the die configuration, & the cell technology the loader has to address, which is what separates two drives carrying the same controller marking. The lab reads them through the controller once the drive is in Technological Mode, because PC-3000 SSD talks to a live controller over SATA or NVMe & never reads a desoldered die.
Drive-level identity string
What the host reads over ATA or NVMe during enumeration. The repair path for a drive reporting SATAFIRM S11 follows from the failure state, not from the package marking. The S11 in the panic string is not the same fact as the S11 suffix in PS3111-S11; one names a failure state, the other names a part.
Intake identification sequence
  1. Read the package marking. Open the case & photograph the controller under the microscope. Interface follows from the marking, & the interface decides the hardware: NVMe parts run on the Portable III M.2 adapter, & SATA parts including the PS3111-S11 run over SATA on the Portable III or the PC-3000 Express.
  2. Confirm the board is electrically sound. A drive that never enumerates cannot be identified over the host interface, and host power applied to a shorted rail drives the damage further into the controller & NAND, so the electrical check comes before the drive is powered for identification. We localize a shorted PMIC or regulator with a FLIR thermal camera & replace it with a Hakko FM-2032; that component-level tier runs $900–$1,200 on NVMe.
  3. Record what the host already reports. With the board confirmed sound, log the identity string & the reported capacity before any recovery work begins. A 0GB, 2MB, or 20MB passport says the firmware never mounted a usable translator; it says nothing about the NAND behind the controller.
  4. Enter Technological Mode & read the flash ID. Shorting the ROM_CS pin to ground while cycling power drops the controller into BootROM. The test point is a per-board detail that follows the PCB layout, so it is located on the drive in front of the engineer rather than assumed. PC-3000 SSD then reads the NAND identification bytes through the controller's own bus.
  5. Pair the two identifiers & select the loader. The controller silicon plus the NAND chip ID select the LDR profile PC-3000 SSD injects into RAM. An incompatible profile doesn't run, so the engineer works through the profiles in that controller family until one loads.
Identification pitfalls on Phison drives
Two drive states defeat host-level identification. A controller in SAFE-MODE reports a masked capacity & an incomplete passport, so the geometry behind it stays hidden until a loader runs. A drive in BSY clears the interface bring-up its bus uses, PCIe link training on NVMe or out-of-band signaling on SATA, but never completes its ATA or NVMe Identify response, so SMART queries time out & the host has nothing to read.
Both sit in the family of firmware panics that strand a controller in ROM mode.
The marking can mislead too. OEMs relabel Phison silicon under their own part numbers, so the string on the package may not read Phison. When the marking doesn't resolve to a known platform, the drive's behavior under each utility in the family decides the profile.
Do not run a mass-production utility to read an ID on a drive that still holds data. MPTool, STTool, & PhisonToolBox rebuild the defect & translator tables as part of factory initialization, & user data does not survive that operation. Identification for recovery is read-only work on PC-3000 SSD, & there's no diagnostic fee for it.
PC-3000 SSD Technological-Mode Recovery for Phison Failure Modes
PC-3000 SSD technological-mode recovery for Phison failure modes
A Phison-failed SSD requires PC-3000 SSD because user-mode software cannot reach a controller that is stuck in BootROM. When the FTL is corrupted, the drive rejects ATA and NVMe read commands at the protocol layer, so Disk Drill, EaseUS, R-Studio, & every other host-level tool see no addressable LBAs to scan.
PC-3000 enters Technological Mode through vendor-specific commands and a hardware short to the controller's ROM_CS pin, then injects a volatile loader directly into controller RAM. The loader bypasses the dead firmware and exposes raw NAND through the controller's own DSP, which is the only path to the data since LDPC soft-decision decoding and XOR scrambling bind the bits to the original silicon.
Phison failure signatures and the PC-3000 utility that addresses each
SATAFIRM S11 device-ID
PC-3000 utility: Phison SATA module on PC-3000 SSD. Loader (LDR) matched to PS3110-S10 or PS3111-S11 silicon plus NAND chip ID, virtual translator rebuilt in RAM on the drive itself.
BSY / locked SMART
Root cause: The controller passes link training but never completes its NVMe or ATA Identify response. SMART queries time out, the BIOS hangs on the drive for several seconds, & the OS lists the device with no capacity. Typically a Phase 2 failure where the on-NAND firmware image has degraded past the LDPC correction threshold. PC-3000 utility: Phison Utility. Safe Mode pins shorted during power-on, then a clean firmware image is uploaded to controller RAM so the controller skips the corrupted on-NAND firmware partition.
Translator-loss read errors (0GB, 2MB, or 20MB capacity)
Root cause: The firmware loaded successfully but the active L2P map mounted with a corrupt or zero-length translator. The drive enumerates with a placeholder capacity & rejects user reads. Common on DRAM-less PS3111-S11 & HMB-backed PS5013-E13T after a power cut during an L2P commit. PC-3000 utility: Phison Data Extractor with virtual translator build. Block sequence numbers, wear-level counters, & spare-area LBA tags are scanned from physical NAND to reconstruct the L2P map in RAM on the drive itself; nothing is written back to the drive.
Five-step in-lab recovery workflow
  1. Enter Technological Mode. Short the ROM_CS pin on the PCB to ground while cycling power. The controller halts the normal firmware load from NAND & falls back into its factory BootROM state.
  2. Load the original firmware loader. Select the correct LDR profile in PC-3000 SSD matched to the controller silicon & NAND chip ID, then upload it into the controller's volatile RAM. The loader runs in place of the corrupted on-NAND firmware.
  3. Read NAND spare-area service data. The loader exposes raw NAND through the controller's DSP. PC-3000 scans every physical block's spare area for surviving block sequence numbers, wear-level counters, ECC checksums, & embedded LBA tags.
  4. Rebuild the FTL translator in RAM on the drive itself. PC-3000 sorts the scanned metadata by sequence number, resolves journal-tail conflicts, & constructs a full LBA-to-PBA map entirely in RAM on the drive itself. The on-NAND FTL is never rewritten.
  5. Extract the logical image. With the virtual translator active, Data Extractor walks the file system (NTFS, exFAT, ext4, APFS) & images user data to a target drive. Degraded NAND blocks fall through to multi-pass reads with voltage threshold shifts.
Supported controller scope on PC-3000 SSD
The PC-3000 SSD Phison utility currently supports the PS3110-S10 & PS3111-S11 on the SATA side (full loader injection, FTL rebuild, & data extraction) & the PS5012-E12, PS5013-E13T, PS5016-E16, PS5019-E19, & PS5021-E21T on the NVMe side through the Portable III M.2 adapter. The PS5018-E18 is firmware-repair only; the PS5026-E26 Gen5 controller has no published PC-3000 procedure as of May 2026 & recovers through board-level repair when the original silicon is intact.
Kingston A400, Patriot Burst, and Silicon Power S55 drives are built on the PS3111-S11. PC-3000 SATA firmware recovery: $600–$1,200.
Why These Drives Fail After Power Loss
The PS3111-S11 is a 2-channel, DRAM-less controller. It stores the working FTL directly in TLC NAND rather than in dedicated cache memory. A power cut during a write can corrupt the in-flight FTL update, and there's no safe copy to fall back to.
Budget drives pair this controller with lower-binned NAND that hits the ECC correction threshold sooner than enterprise-grade flash, compounding the failure rate.
Do Not Run MPTool or PhisonToolBox
MPTool and PhisonToolBox are factory mass-production tools. They reinitialize the NAND layout, create a new empty FTL, and destroy all user data. Reflashing will remove the SATAFIRM S11 string and make the drive appear functional.
The only non-destructive recovery method is PC-3000 SSD's volatile microcode injection. Every Phison job ships to our in-house SSD recovery lab in Austin, TX and never gets outsourced.
How Much Does Phison SSD Recovery Cost?
Recovery cost depends on the failure type, not the controller model. A SATAFIRM S11 firmware panic on a Kingston A400 falls into the same pricing tier as firmware corruption on a Patriot Burst. No diagnostic fee, no data, no recovery fee, and +$100 rush fee to move to the front of the queue.
SATA Phison Recovery (PS3111-S11, PS3110-S10)
NVMe Phison Recovery (PS5012-E12, PS5013-E13T, PS5019-E19)
PC-3000 SATA Workflow: PS3111-S11 &
How Is a PS3111-S11 & PS3110-S10 SATA SSD Recovered on PC-3000?
SATA Phison recovery connects through PC-3000 Express or Portable III over SATA. The PS3111-S11 requirement is on the drive side: Technological Mode has to be forced at the PCB before the utility can talk to the controller.
Technological Mode Entry & Loader Injection
  1. Connect the drive. Connect over SATA to the PC-3000 Express or Portable III bench, off any production host.
  2. Force technological mode. Locate the ROM_CS test point on the PCB, then short it to ground with precision tweezers while cycling the power supply. That short halts the normal firmware load from NAND and forces the controller into its factory BootROM state.
  3. Confirm ROM mode in PC-3000. Verify 0GB or 2MB capacity in the passport before proceeding.
  4. Launch the PC-3000 Phison utility. Select the correct utility variant in PC-3000 SSD. Match the loader (LDR) to the controller silicon, NAND chip ID, & firmware version. The LDR is uploaded directly into the controller's volatile RAM.
  5. Remove tweezers. PC-3000 prompts the engineer to release the short after the loader is injected. The controller now runs from the temporary loader instead of the corrupted NAND firmware.
  6. Reverse XOR scrambling. The loader reads raw NAND pages and reverses the XOR data scrambling applied at the page level. The XOR polynomial is deterministic, derived from the controller model & NAND chip ID. PC-3000 handles this automatically with the correct loader profile.
  7. Build the virtual translator. PC-3000 scans surviving NAND metadata: block sequence numbers, wear-level counters, & ECC checksums. It reconstructs the LBA-to-PBA mapping table entirely in RAM on the drive itself. The translator is never written back to the SSD.
  8. Extract data via Data Extractor. With the virtual translator active, PC-3000 presents the file system (NTFS, exFAT, ext4) and extracts user data to a target drive. Check "Ignore ECC errors" to handle degraded NAND blocks that fall below the correction threshold.
What Actually Corrupts During a SATAFIRM S11 Event?
Understanding which stage failed determines whether PC-3000 can rebuild the drive through microcode injection or whether the job escalates to NAND chip-off on the SATA controllers where that remains viable.
The sequence has four distinct phases, and the corruption signature on the NAND chips differs for each.
Phase 1: BootROM to Primary Loader Handoff
On cold power, the PS3111-S11 starts executing from its masked BootROM; a tiny, read-only program baked into the controller silicon that cannot be corrupted by NAND wear. The BootROM queries predefined physical blocks in the NAND service area searching for the primary loader signature.
At this stage, the FTL itself is still untouched on NAND. PC-3000 forces the drive into Safe/Technological Mode, injects a microcode loader (LDR) into the controller's RAM, reverses XOR scrambling on the surviving data pages, and scans the rest of the chip for the L2P journal blocks in later phases.
Phase 2: Primary Loader to Firmware Image
The primary loader reads the main firmware image (structured as BN*.BIN loader and FW*.BIN firmware binaries in Phison mass production tools) from the dedicated NAND service area. The firmware image holds the FTL code, wear-leveling tables, and the controller's configuration block. If the firmware image has degraded past the correction threshold of the controller's LDPC engine, the loader aborts and the drive drops back into BootROM.
PC-3000 bypasses this by uploading its own firmware image to volatile RAM instead of relying on the corrupted on-NAND copy.
Phase 3: Firmware to FTL Metadata Blocks
Once the firmware runs, it mounts the active FTL by reading metadata pages scattered across dedicated system blocks. Each metadata page carries a sequence number, a wear-level counter, and a page header identifying which LBA range it maps. On a DRAM-less PS3111-S11, the working L2P map is rebuilt into a small on-NAND cache during mount.
An unclean power cut during this mount procedure produces split-brain metadata: partial writes where half a 16 KiB page committed and the other half failed ECC.
The controller cannot resolve which metadata copy is authoritative and panics. The microcode injection reads every metadata page directly, ignores the controller's panic logic, and sorts the surviving pages by sequence number to identify the most recent consistent snapshot.
Phase 4: Journal Replay Against User Data Blocks
Between FTL snapshots, the controller records L2P deltas into journal blocks. Journal entries carry a monotonic sequence counter. On a clean boot, the firmware replays journal entries forward from the last snapshot to rebuild the live L2P.
If an operation was in flight when power dropped, the controller may record an inconsistent journal tail.
The firmware detects this metadata discrepancy and refuses to mount. PC-3000 handles this case differently: the virtual translator tolerates journal gaps by walking every physical NAND page's spare area, reading the embedded LBA tag that Phison writes alongside user data, and cross-referencing against the partial journal. Any LBA tag that appears in both the journal and the NAND spare area resolves to a valid mapping; conflicts are broken by taking the page with the highest sequence number.
Safety Mechanics of Microcode Injection
Every operation above happens in volatile RAM and host RAM. The injected loader never issues program or erase commands to NAND; it only reads. The virtual L2P map lives entirely on the host PC.
If extraction is interrupted, the drive can be repowered and the entire procedure restarted from Technological Mode entry. This is the key difference from OEM Mass Production utilities (MPTool), which reinitialize FTL system blocks and guarantee data loss. See the full SSD recovery workflow for how Phison procedures fit alongside our other controller programs.
PC-3000 SSD Workflow: PS5012-E12, PS5013-E13T,
How Are PS5012-E12, PS5013-E13T, & PS5019-E19 NVMe SSDs Recovered on PC-3000?
NVMe Phison recovery requires the PC-3000 Portable III with its M.2 PCIe NVMe adapter. UDMA-E & Express boards don't have PCIe interfaces and can't communicate with NVMe drives.
The core workflow follows the same injection-and-rebuild pattern as SATA, but with PCIe-specific link training, LDPC decoding through the original controller, and thermal management during extraction. On drives where the OEM enabled AES-256, the loader also re-activates the hardware decryption engine.
NVMe Loader Injection & FTL Reconstruction
  1. Connect via PC-3000 Portable III. Seat the M.2 NVMe drive on the dedicated adapter connected to Port 0. Verify PCIe link training status; a firmware-panicked drive will complete link training but fail NVMe initialization.
  2. Force safe mode. If the drive doesn't enumerate on the PCIe bus, short the controller's safe mode pins on the PCB while powering on. Pin locations are controller-specific; the PS5012-E12, PS5013-E13T, & PS5019-E19 each have different pad layouts.
  3. Launch the PC-3000 SSD Phison utility. Confirm the firmware panic state, then select the controller-specific recovery profile. Match the LDR to the controller & NAND chip ID (Toshiba/Kioxia BiCS, Micron 3D TLC, SK hynix).
  4. Inject the loader. PC-3000 uploads the loader into the controller's volatile RAM. The loader disables background TRIM & garbage collection to freeze the NAND state. On drives where the OEM enabled AES-256, the loader also re-activates the hardware cryptographic engine so data is decrypted in real time during extraction.
  5. Rebuild the FTL from NAND metadata. The PS5012-E12's 8-channel interleaving requires correct channel stride & plane geometry. The DRAM-less PS5013-E13T & PS5019-E19 use Host Memory Buffer to cache the FTL during normal operation. After a crash, PC-3000 bypasses the lost HMB cache entirely, scanning the physical NAND spare area for surviving block sequence numbers to reconstruct the logical address space.
  6. Manage thermals. Gen4 controllers (PS5016-E16, PS5019-E19) generate high thermal loads during sustained extraction. Active cooling is required to prevent the controller from entering thermal shutdown mid-recovery. If the controller throttles, extraction pauses and the read state may need to be re-established.
  7. Extract via Data Extractor. Image the drive sector-by-sector. On degraded NAND blocks, use multi-pass reading with voltage threshold shifts to maximize data yield from cells that the controller's ECC engine has abandoned.
PS5013-E13T & PS5019-E19: DRAM-less NVMe Recovery
The PS5013-E13T (Gen3x4, found in some batches of the Patriot P300 & Kingston NV1; both models swap controllers between production runs) and PS5019-E19 (Gen4x4, found in WD_BLACK SN750 SE) are both DRAM-less controllers that cache the FTL in the host PC's RAM through Host Memory Buffer. A power cut or system crash severs the PCIe link, and the in-flight FTL update in host RAM never commits to NAND.
Recovery on these controllers follows the standard NVMe injection workflow above. The PS5019-E19 adds Phison's 4th Gen LDPC ECC engine and optional TCG Opal support. When the OEM enables AES-256 media encryption, the controller handles both encryption and self-encrypting drive authentication.
Even without AES, the proprietary LDPC soft-decision decoding binds the data to the controller silicon. If the controller silicon fails, chip-off is not viable. Board-level repair only helps when the fault is in the surrounding PCB, PMIC, or power rails; NVMe board repair is $900–$1,200.
DRAM-less HMB Behavior After Unclean Shutdown
The failure chain on a DRAM-less Phison NVMe (PS5013-E13T, PS5019-E19, PS5021-E21T, PS5026-E26) during a power cut looks like this: the controller buffers the working L2P delta in a Host Memory Buffer region allocated inside the host PC's RAM. When the user writes data, the new L2P entries sit in that HMB region waiting for the next idle window to commit to NAND.
A power cut tears down the PCIe link before the commit finishes. The in-flight delta in host RAM is lost instantly; the drive never receives a clean shutdown notification.
On next boot, the controller reads its last checkpoint from NAND and finds it inconsistent with the block sequence numbers in the physical data region. Depending on how far the write was from completing, the controller either journal-replays through its on-NAND log (if the log survived) or panics into BootROM and emits the firmware-panic identity string.
PC-3000's recovery path bypasses the lost HMB region entirely. The injected loader scans physical NAND spare areas for surviving block sequence numbers, wear-level counters, and page headers, then rebuilds the L2P map into RAM on the drive itself from metadata that actually committed to flash. The original NAND contents are never modified.
PS5018-E18: Limited PC-3000 Support
The PS5018-E18 (Gen4x4, found in Corsair MP600 Pro, Seagate FireCuda 530, Kingston KC3000) has limited PC-3000 SSD support. ACE Lab lists the E18 as "Only Repairing," meaning diagnostic mode entry and firmware repair are available, but full virtual translator data extraction is not supported for all NAND configurations.
When E18 drives fail from PMIC or component-level damage, board-level repair is the primary recovery path. Identify the failed component using FLIR thermal imaging, replace it with a Hakko FM-2032 microsoldering iron, and bring the original controller back to life.
Once the controller boots with functioning AES-256 keys, standard NVMe imaging extracts the data. NVMe board repair: $900–$1,200.
PS5026-E26 Gen5: Thermal Throttle to Firmware Panic
The PS5026-E26 is Phison's first retail PCIe 5.0 x4 NVMe controller, shipping in the Crucial T700, Corsair MP700, Gigabyte Aorus Gen5 10000, and Sabrent Rocket 5. The E26 pairs an 8-channel NAND interface with Phison's 5th Gen LDPC engine and a Gen5 PHY that sustains sequential reads above 12,000 MB/s. That bandwidth is what creates the recovery problem: the package routinely exceeds 80 °C under load, and many early retail drives shipped with marginal heatsinks or PMIC layouts that fail prematurely.
The typical failure chain on an E26 drive looks like this: sustained write load pushes controller die temperature past the thermal throttle threshold. The firmware aggressively derates link speed and clock frequency to cool the die. If the PMIC or DRAM buffer was already marginal, the thermal cycling accelerates the defect, and a power rail drops below spec.
The controller then fails during a metadata write, corrupts the on-NAND journal, and the next boot lands in BootROM with a firmware-panic identity string.
Users see the drive drop from the BIOS, re-enumerate as a tiny capacity, or stop enumerating entirely on the PCIe bus.
As of April 2026, the PS5026-E26 is not yet supported by ACE Lab's PC-3000 SSD utility.
When a Gen5 drive arrives dead at the lab, the primary recovery path is board-level: FLIR thermal imaging locates the failed PMIC or capacitor; a Hakko FM-2032 microsoldering iron and Atten 862 hot air station replace the component; the original controller boots with its AES-256 keys intact; standard NVMe imaging extracts the data. Chip-off is not viable; the 5th Gen LDPC decoder and XOR scrambling bind the raw NAND output to the original silicon.
Why a Phison NVMe Drive Trains the PCIe Link but Never Enumerates
A firmware-panicked Phison NVMe drive shows up in the BIOS and in lspci while Windows never sees a usable disk. That split looks contradictory until you separate the two jobs the controller runs. PCIe link training is handled by hardware PHY state machines that negotiate lane count and link speed. That negotiation runs entirely on silicon, independent of the flash-translation firmware, so it finishes even when the firmware behind it is dead.
What fails next is NVMe initialization. After the physical link comes up, the controller firmware has to finish booting, load the FTL, and expose a namespace.
A drive stuck in FTL-corruption boot-loop, one whose system-area NAND has degraded past what the LDPC engine can correct, or a DRAM-less PS5013-E13T that times out negotiating its Host Memory Buffer after an unclean shutdown all stop at the same place. The link is up; the namespace never appears. That is the "shows in BIOS but not in Windows" signature.
The PC-3000 Portable III with its M.2 PCIe adapter establishes the same physical link through the same controller PHY, then works at the layer below the failed NVMe init. The injected loader keeps that native PCIe link to the PC-3000 alive while bypassing the corrupted firmware, so the drive talks to the tool even though it refuses to mount on a host.
Why LDPC Forces the Read Through the Original Controller
The data on the NAND is not stored the way it reads off the bus. Phison layers proprietary scrambling and XOR over every page, then protects it with LDPC error correction. LDPC decoding is iterative belief-propagation across a sparse Tanner graph, run by dedicated hardware logic inside the controller. Pull the NAND with an external programmer and you get scrambled, error-laden pages that no generic reader can descramble or decode.
That is why chip-off is not the path for these drives. The decode is bound to the controller's own belief-propagation circuitry, and there is no external way to reconstruct it. The volatile microcode loader hooks into that native LDPC engine directly: it routes raw NAND page reads through the drive's own factory error correction while skipping the broken FTL.
The data comes back decoded by the silicon that wrote it, not reconstructed by guesswork. Revive the original controller and you have the decoder; lose it and the raw flash stays unreadable.
PS5016-E16: The First Consumer Gen4 Controller
Why Does the Phison PS5016-E16 Fail the Way It Does?
The PS5016-E16 was the first consumer PCIe 4.0 NVMe controller, and its design is the reason it lands on the recovery bench. Phison paired the Gen3 PS5012-E12 back-end core, built on TSMC 28nm silicon, with a faster Gen4 PHY. Pushing PCIe 4.0 bandwidth through a 28nm core that was engineered for Gen3 generates the thermal load that drives most E16 failures.
The silicon is a dual-core 32-bit ARM Cortex-R5 with 8 NAND channels, 32 chip-enable lines, and flash transfer rates up to 800 MT/s. It uses external DDR4 DRAM for the mapping tables, Phison's 4th Gen LDPC error correction, and hardware AES-256 with TCG Opal 2.0 and Pyrite. The package is rated near 70 °C operating and 125 °C junction, which leaves little headroom once a marginal PMIC or heatsink enters the picture.
Is My Drive a PS5016-E16 or a PS5018-E18?
The same brand family splits across two different controllers with different recovery support, and the marketing names invite misdiagnosis. The original Corsair MP600, the Sabrent Rocket 4.0, and the Seagate FireCuda 520 run the E16. Their successors, the MP600 Pro, the Rocket 4 Plus, and the FireCuda 530, run the E18. PC-3000 SSD provides full virtual-translator reconstruction for the E16; E18 support is firmware-repair only. Confirm the controller before sending a drive in.
Drive FamilyPS5016-E16 ModelPS5018-E18 Model
Corsair MP600Force MP600 (original, 2019)MP600 Pro / Pro XT
Sabrent RocketRocket NVMe 4.0 (standard)Rocket 4 Plus
Seagate FireCudaFireCuda 520FireCuda 530
Kingstonn/aKC3000
Other verified E16 drives include the Gigabyte AORUS NVMe Gen4, the TeamGroup T-Force Cardea Zero Z440, the Patriot Viper VP4100, and the Silicon Power US70. E18 drives carry the firmware-repair-only constraint covered in the support matrix above; full translator reconstruction is an E16 capability.
The root mechanism on the E16 is an interrupted SLC-to-TLC fold during background garbage collection: the fold leaves the FTL journal in the SLC region with mismatched block sequence counters, the bootROM fails the Service Area integrity check, and the controller enters its protective panic state.
PS5016-E16 over PCIe
The drive either drops off the PCIe bus, failing NVMe initialization even after it passes PCIe link training and LTSSM negotiation, or it enumerates while abandoning its retail brand and reporting the factory generic alias "PS5016" with a placeholder capacity such as 0GB, 2MB, or 20MB.
Why the E16 Needs Active Cooling During Extraction
In normal use the E16 thermal-throttles to survive its own bandwidth. During recovery that safety net is gone. The controller is pinned in Technological Mode running the volatile loader, so its normal thermal-management and throttle routines are inactive or ineffective while the Data Extractor sustains a sector-by-sector read of the NAND.
If the controller overheats on the bench it can thermal-shutdown mid-recovery, drop the PCIe link, and lose the volatile RAM state, which forces a reset and a fresh loader re-injection before imaging can resume. Targeted active cooling runs on the E16 throughout prolonged imaging to hold the controller stable and protect the read state.
Why Chip-Off Cannot Work on the E16
The E16 fuses its AES-256 Media Encryption Key into the controller's One-Time Programmable memory, and that key never leaves the die. Desoldering the NAND and reading it on an external programmer yields ciphertext with no path to decryption. The recovery path for a dead E16 is reviving the original controller through board-level repair so the on-die key decrypts the data in place.
FLIR thermal imaging locates the shorted PMIC or regulator, a Hakko FM-2032 on its base station replaces the component, and the original controller boots with its key intact. NVMe board repair runs $900–$1,200; firmware-level reconstruction on a supported E16 runs $900–$1,200. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. For the broader process and pricing tiers, see our ssd data recovery service.
Phison Vs Silicon Motion
How Does Phison Recovery Differ from Silicon Motion Recovery?
Silicon Motion controllers (SM2258, SM2259, SM2263, SM2264, SM2267, SM2320) and Phison controllers share the same broad recovery model: vendor-specific commands enter a diagnostic state, a volatile loader mounts in controller RAM, PC-3000 scans NAND metadata, and a virtual translator rebuilds the logical image in RAM on the drive itself. The differences are in the entry mechanics and the destructive-tool trap.
Safe Mode entry
Phison enters Technological Mode by shorting the ROM_CS pin to ground during power-on. Silicon Motion uses a separate test-point layout that differs by controller model; SM2258 and SM2259 drives typically expose dedicated ROM-mode pads that must be bridged while the drive powers up.
Error correction engine
Phison brands its soft-decision decoder as 4th Gen and 5th Gen LDPC. Silicon Motion brands the equivalent technology as NANDXtend. Both engines bind the raw NAND output to the controller DSP, so chip-off recovery is equally unviable on either family when encryption or hard LDPC binding is active.
Destructive-tool trap
Phison's factory mass-production tools are MPTool and PhisonToolBox. Silicon Motion ships MPTool with a different codebase under the same name. Both reinitialize the Flash Translation Layer and destroy user data. If a drive shows a firmware panic string, do not run any manufacturer tool before a data recovery lab has pulled the NAND contents.
Shop workflow
Physically identical: PC-3000 Portable III with the M.2 NVMe adapter, active cooling during sustained reads on Gen4 and Gen5 drives, Hakko FM-2032 for any component-level repair. The adapters, cables, and extraction targets are interchangeable between vendors.
How the Flash Translation Layer Rebuilds on PC-3000
How Is the Flash Translation Layer Rebuilt on PC-3000?
The Flash Translation Layer maps logical block addresses (what your operating system requests) to physical NAND page locations (where the data is stored on the flash chips). When this map corrupts, PC-3000 reconstructs it from surviving NAND metadata without modifying the drive. The entire rebuilt map lives in RAM on the drive itself.
Physical Dump & Metadata Scanning
After the loader injection, PC-3000 gains low-level read access to the physical NAND chips without relying on the drive's dead firmware. The software scans every physical block for page headers, block sequence numbers, & wear-level counters. These are fragments of metadata that survived the crash.
Algorithmic Sorting & Map Reconstruction
PC-3000 uses heuristics specifically tailored for Phison's proprietary wear-leveling algorithms to sort the scattered blocks. The software matches block sequence numbers across NAND channels to determine which physical pages correspond to which logical addresses. On 8-channel controllers (PS3110-S10, PS5012-E12, PS5016-E16), the interleaving pattern and plane geometry must be correctly decoded for the logical image to be valid.
SATA (XOR) vs NVMe (AES-256) Translation Differences
On SATA controllers (PS3111-S11, PS3110-S10), the raw NAND data is XOR-scrambled but not encrypted. PC-3000 reverses the scrambling using the deterministic XOR polynomial matched to the controller model & NAND chip ID. The virtual translator maps descrambled pages to logical addresses.
On NVMe controllers (PS5012-E12, PS5013-E13T, PS5019-E19), the raw NAND data is bound by proprietary LDPC soft-decision error correction and XOR scrambling. When AES-256 is enabled by the OEM, the loader also re-activates the controller's hardware AES engine, which decrypts each page as PC-3000 reads it. Whether or not AES is active, the LDPC DSP and XOR scrambling make chip-off unviable: a standard programmer cannot reproduce the controller's soft-decision decoding, so the raw dump is mathematically undecodable.
Recovering TRIMmed Data on Phison Drives
PC-3000 SSD includes a physical reading mode for Phison drives that can access historical versions of the translation map. If a file was deleted & the OS issued a TRIM command, the controller unmapped the logical addresses and began returning zeroes through Deterministic Zero After TRIM masking.
But if garbage collection hasn't yet physically erased the underlying NAND pages, the data still exists on the flash cells. The physical reading mode parses older translation entries to locate these orphaned pages. The data is recoverable only if the NAND cells haven't been erased by the controller's background garbage collection.
Equipment for Phison SSD Recovery
What Equipment Is Used for Phison SSD Recovery?
Every Phison recovery at our Austin lab uses the same equipment set. SATA controllers connect through PC-3000 Express or Portable III. NVMe controllers go through Portable III's M.2 adapter.
Board-level repairs use Hakko microsoldering and FLIR thermal imaging for fault localization.
  • PC-3000 SSD (Phison utility module)
  • PC-3000 Express (SATA interface)
  • PC-3000 Portable III (NVMe M.2 adapter)
Board-Level Repair
  • Hakko FM-2032 microsoldering iron (FM-203 base)
  • FLIR thermal camera (fault localization)
  • Atten 862 hot air rework station
  • Zhuo Mao precision BGA rework station
Phison Controller Reference Pages
Phison PC-3000 Recovery FAQ
What is Technological Mode on a Phison SSD?
Technological Mode (also called Safe Mode or ROM Mode) is a diagnostic state where the Phison controller bypasses its stored firmware and boots from its internal BootROM. The controller responds to vendor-specific commands but rejects standard ATA or NVMe read/write operations. PC-3000 SSD uses this state as the entry point for microcode injection. The engineer forces entry by shorting the controller's ROM_CS pin to ground while cycling power.
How does a PS3111-S11 connect to PC-3000 for Technological Mode?
PS3111-S11 recovery runs on the PC-3000 Express or the PC-3000 Portable III, both of which reach the controller over SATA. Technological Mode entry is a hardware step on the drive itself: the ROM_CS pin is shorted to ground while power cycles, and the matched loader then goes into controller RAM from the PC-3000 Phison utility.
How much does PC-3000 Phison SSD recovery cost?
SATA Phison recovery (PS3111-S11 firmware panic) starts at $600–$1,200 for firmware-level recovery and ranges up to $1,200–$1,500 for NAND transplant. NVMe Phison recovery (PS5012-E12, PS5013-E13T, PS5019-E19) ranges from $900–$1,200 for firmware recovery to $1,200–$2,500 for NAND swap. Board-level repair for PMIC or power-rail faults: $900–$1,200. No diagnostic fee. No data, no fee. +$100 rush fee to move to the front of the queue.
Is data erased when a Phison SSD shows 0GB, 2MB, or 20MB capacity?
No. A Phison SSD that reports 0GB, 2MB, or 20MB usually lost access to its Flash Translation Layer, not the NAND contents. PC-3000 SSD enters Technological Mode, injects a temporary loader into controller RAM, and rebuilds the translator in RAM on the drive itself so the drive is read without rewriting its firmware.
Will MPTool or PhisonToolBox recover data from a SATAFIRM S11 drive?
No. MPTool and PhisonToolBox are factory mass-production tools that reinitialize the NAND layout from scratch. Running either tool on a drive that contains data permanently erases it by creating a new, empty Flash Translation Layer. The data on the NAND chips is severed from its logical addressing. If your drive shows SATAFIRM S11, do not flash any firmware utility. The only non-destructive recovery method is PC-3000 SSD's volatile microcode injection, which reads the NAND without modifying it.
Can I move Phison NAND chips to a donor SSD board?
No. A simple donor-board NAND move does not repair a Phison firmware panic because the damaged firmware fragments, FTL metadata, XOR scrambling, and controller-specific parameters live with the NAND set. On encrypted NVMe models, the AES-256 key is bound to the original controller silicon, so board-level repair of the original PCB is the recovery path.
Can chip-off recovery work on Phison NVMe SSDs?
Chip-off is not viable on Phison NVMe SSDs. Even when AES-256 encryption is not enabled by the OEM, all modern Phison NVMe controllers (PS5012-E12, PS5013-E13T, PS5016-E16, PS5019-E19, PS5021-E21T) use proprietary LDPC soft-decision error correction that mathematically binds the data to the controller's DSP. Desoldering the NAND and reading it on a standard programmer yields raw data with bit error rates that exceed any external correction threshold. Combined with page-level XOR scrambling, the dump is undecodable without the original controller. If the original controller silicon has failed, recovery is not viable; board-level repair only helps when the fault is in the surrounding PCB, PMIC, or power rails. Older SATA controllers (PS3111-S11, PS3110-S10) use simpler BCH error correction and XOR scrambling without AES, so chip-off remains viable as a last resort on those drives.
What is a virtual translator in PC-3000 SSD recovery?
A virtual translator is a temporary LBA-to-PBA mapping table that PC-3000 builds entirely in RAM on the drive itself. When the SSD's original Flash Translation Layer is corrupted, PC-3000 scans the physical NAND blocks for surviving metadata (block sequence numbers, wear-level counters, ECC checksums) and mathematically reconstructs the logical volume. The virtual translator is never written back to the SSD; the original NAND contents remain untouched throughout extraction.
Does PC-3000 SSD support the PS5013-E13T and PS5019-E19?
Yes. Both the PS5013-E13T (DRAM-less Gen3x4, found in some batches of the Patriot P300 and Kingston NV1; both models are subject to unannounced controller swaps) and the PS5019-E19 (DRAM-less Gen4x4, found in WD_BLACK SN750 SE) are supported on the PC-3000 Portable III platform. Recovery follows the standard NVMe protocol: M.2 adapter connection, safe mode pin shorting, microcode injection, and virtual translator build. Both controllers use proprietary LDPC error correction that binds data to the controller silicon, so board-level repair only helps when the fault is in the surrounding PCB, PMIC, or power rails.
Is PC-3000 SSD supported on the Phison E26 Gen5 controller?
As of April 2026, the PS5026-E26 is not yet supported by ACE Lab's PC-3000 SSD utility. When a Crucial T700, Corsair MP700, or Gigabyte Aorus Gen5 10000 arrives in firmware panic, the primary recovery path is board-level repair: identify the failed PMIC or power rail with FLIR thermal imaging, replace the component with the Hakko FM-2032 microsoldering iron, and boot the original controller. Once the controller enumerates on the PCIe bus, standard NVMe imaging extracts the data. Chip-off is not viable on E26 due to 5th Gen LDPC soft-decision decoding and XOR scrambling that bind the NAND contents to the original silicon.
Which SSDs use the Phison PS5016-E16?
The PS5016-E16 was the first consumer PCIe 4.0 NVMe controller. It runs the original Corsair Force MP600 (2019), the standard Sabrent Rocket NVMe 4.0 (not the Plus), the Seagate FireCuda 520, the Gigabyte AORUS NVMe Gen4, the TeamGroup T-Force Cardea Zero Z440, the Patriot Viper VP4100, and the Silicon Power US70. Their successors run the PS5018-E18 instead: the MP600 Pro, the Rocket 4 Plus, the FireCuda 530, and the Kingston KC3000. The distinction matters because PC-3000 SSD provides full virtual-translator reconstruction for the E16, while E18 support is firmware-repair only.
What if the NAND is monolithic and there are no separate flash chips to read?
Monolithic SSDs package the controller die and NAND die under a single epoxy lid, with the NAND interface routed internally rather than through pads accessible to a chip-off programmer. Recovery on a monolithic Phison-based drive runs entirely through the controller: PC-3000 SSD enters Technological Mode through the test points exposed on the PCB, injects the loader, and reads NAND through the controller's own DSP. Chip-off is not an option because the NAND die has no externally bonded contacts, and even if the package were ground open, the LDPC soft-decision decoding and XOR scrambling still bind the raw bits to the original controller silicon. If the controller die has failed inside a monolithic package, recovery is limited to board-level repair of the surrounding PCB, PMIC, or power rails; once the original controller boots, standard imaging follows.
How does Phison SSD recovery differ from Silicon Motion recovery?
Both controller families require vendor-specific command workflows on PC-3000 SSD, but the entry mechanics differ. Phison recovery enters Technological Mode by shorting the ROM_CS pin to ground during power-on, then injects a volatile loader into RAM. Silicon Motion controllers (SM2258, SM2259, SM2263, SM2264, SM2267, SM2320) use different test-point layouts and a separate Safe Mode entry sequence; the equivalent manufacturing tool is MPTool for SM, which is destructive on a populated drive. Error correction also differs: Phison uses its proprietary 4th Gen and 5th Gen LDPC engines, while Silicon Motion brands its equivalent NANDXtend. Both bind the raw NAND data to the original controller's DSP, so chip-off is equally unviable on encrypted or LDPC-bound drives from either vendor. The physical shop workflow (M.2 adapter, active cooling, virtual translator build) is identical.
Why Trust Rossmann for Phison SSD Data Recovery?
Phison SSD data recovery combines board-level repair, firmware diagnostics, & NAND translation work in one job. Our single Austin, TX lab handles these recoveries in-house with PC-3000 SSD, FLIR thermal cameras, Hakko FM-2032 microsoldering irons, Atten 862 hot air, & Zhuo Mao BGA rework equipment.
Single Austin Lab
All Phison SSD board and firmware work is performed at 2410 San Antonio Street in Austin, TX. Nationwide jobs arrive by mail-in service; there are no franchises, satellite benches, or outsourced SSD board repairs.
No Diagnostic Fee
Since 2008, we diagnose the SSD before quoting the SATA or NVMe tier. If there is no recovered data, there is no recovery fee. That matters when a Phison SSD has a PMIC fault, encryption barrier, or ROM-mode firmware panic.
Published SSD Pricing
SATA Phison recovery uses 5 published tiers from From $200 to $200–$1,500. NVMe Phison recovery uses 5 published tiers from From $200 to $200–$2,500.
Controller-Specific Workflow
A PS3111-S11, PS5012-E12, PS5018-E18, & PS5026-E26 do not fail the same way. The PC-3000 SSD Phison utility, Safe Mode entry method, LDPC behavior, & encryption limit change with the controller family.
Phison SSD not detected, stuck in firmware panic, or showing SATAFIRM S11?
Free evaluation. SATA firmware recovery from $600–$1,200. NVMe recovery from $900–$1,200. No data, no fee.
