SSD Controller Architecture
Phison Controller Architecture Reference
This is the technical reference for Phison controllers and the bench workflows used during SSD data recovery on Phison-based drives. Phison controllers power everything from the entry-level Kingston A400 to the Corsair MP700 Gen5 flagship. Ten controller families, two interfaces, two encryption schemes.
The PS3111-S11's "SATAFIRM S11" firmware panic is the single most common SSD failure we see in the lab. Recovery follows the same core path across the Phison family: bypass the corrupted firmware through PC-3000 SSD's Phison utility, reconstruct the Flash Translation Layer from NAND metadata, and image the data. Pricing, turnaround, and shipping details for both SATA and NVMe drives live on the main service page. SATA recovery starts at $200. NVMe starts at $200. No diagnostic fee.
Updated June 2026
Why does Phison controller identity matter for SSD data recovery?
Phison controller identity determines whether SSD data recovery uses PC-3000 SSD firmware work, board-level microsoldering, or a NAND chip-off fallback. SATAFIRM S11 drives need Phison utility loader access & FTL reconstruction. Modern Phison NVMe drives often require original-controller board repair because AES-256 keys stay inside the controller silicon.
All Phison SSD data recovery work is performed in-house at our Austin, TX lab. Published SATA & NVMe pricing comes from the SSD pricing tables below.
Which Phison Controller Is in Your SSD?
Phison ships ten controller families across SATA, PCIe Gen3, Gen4, and Gen5. Three are DRAM-less (PS3111-S11 on SATA, PS5013-E13T and PS5021-E21T on NVMe), storing the Flash Translation Layer in NAND or host RAM instead of a dedicated cache chip. This table maps each controller to its common drives, interface, & the failure pattern that appears when it dies.
ControllerInterfaceDRAMCommon DrivesFailure Signature
PS3111-S11SATANoKingston A400, Patriot Burst, Silicon Power S55"SATAFIRM S11" in BIOS, 0GB capacity
PS3110-S10SATAYesPNY CS1311, Patriot Ignite, Mushkin Striker, OCZ Trion 100ROM mode, 2MB/20MB capacity, generic Phison name
PS3112-S12SATAYesSeagate FireCuda 120, GoodRam IRDM PRO Gen 2, Kingston DC500RPersistent BSY state, drive drops off SATA bus
PS5008-E8NVMe Gen3 x2YesMyDigitalSSD SBX, Patriot Scorch, Corsair MP300PCIe bus drop, 0MB capacity, NVMe identify failure
PS5012-E12NVMe Gen3YesCorsair MP510, Sabrent Rocket, PNY CS3030Firmware panic, not detected in BIOS
PS5013-E13TNVMe Gen3 x4No (HMB)Crucial P2, Patriot P300, Sabrent Rocket Nano RuggedHMB FTL loss, drive disappears from BIOS, 0MB capacity
PS5016-E16NVMe Gen4YesCorsair MP600, Sabrent Rocket 4.0, Seagate FireCuda 520Thermal shutdown, firmware panic
PS5018-E18NVMe Gen4YesCorsair MP600 Pro, Seagate FireCuda 530, Kingston KC3000Boot loop, not detected, thermal failure
PS5021-E21TNVMe Gen4No (HMB)Crucial P3, Kingston NV2, Sabrent Rocket 2230HMB FTL loss, 0MB capacity, data corruption
PS5026-E26NVMe Gen5YesCorsair MP700, Crucial T700Thermal throttle failures, not detected
What Is a NAND Flash ID on a Phison Drive?
The NAND behind a Phison controller carries a second identifier, the flash ID: the identification bytes a NAND die returns to a READ ID command, which establish the memory manufacturer, the die configuration, & the cell technology the loader has to address. That readout is what separates two drives carrying the same controller marking. Intake reads the flash ID together with the Phison controller marking before anyone picks a workflow.
How Do Phison SSDs Fail?
Phison SSD failures split into three categories: firmware corruption after power loss, controller death from electrical damage, & NAND degradation from cell wear. Each requires a different recovery approach & a different price tier.
SATAFIRM S11 Firmware Panic
The most common Phison SATA failure. The drive shows up in BIOS as "SATAFIRM S11" instead of its consumer brand name, reports 0GB capacity, & refuses all read commands. Your data is still on the NAND chips; the controller lost its address map and can't find it. SATA firmware recovery: $600–$1,200. Full SATAFIRM S11 recovery guide.
Controller Failure
A dead controller means the drive isn't detected anywhere: not in BIOS, not in Disk Management, not in a USB enclosure. Common causes include power surges, failed PMICs (power management ICs), & shorted capacitors on the PCB. We locate the failed component using FLIR thermal imaging & replace it with a Hakko FM-2032 microsoldering iron. SATA board repair: $450–$600. NVMe: $900–$1,200. Modern Phison NVMe controllers bind AES-256 encryption keys to the controller silicon, so board repair IS data recovery; the original controller must be revived for the data to be readable.
NAND Degradation
NAND flash cells have a finite write life. Budget SSDs pair Phison controllers with TLC or QLC NAND that degrades faster than enterprise-grade MLC. As cells wear, the controller's error correction threshold is exceeded, and the drive slows, returns read errors, or locks up entirely. PC-3000 SSD can apply voltage threshold shifts during extraction to read data from degraded cells that the controller has abandoned. Worn-NAND cases route into the same professional SSD recovery pricing tiers as firmware panic and board repair work.
When Does Recovery Software Work on a Phison
When Does Recovery Software Work on a Phison SSD?
Recovery software like Disk Drill, EaseUS, PhotoRec, & R-Studio works when the SSD is physically healthy but has a logical problem: accidentally deleted files (with TRIM disabled), a corrupted partition table, or a formatted volume. These tools send standard read commands through the operating system to a functioning controller.
Software can't help when the Phison controller is dead or stuck in firmware panic. A drive reporting "SATAFIRM S11" in BIOS doesn't respond to standard ATA read commands. A dead PS5018-E18 that doesn't appear on the PCIe bus can't receive any commands at all. Software requires hardware that's listening. When the hardware is broken, you need a lab with PC-3000 SSD & board-level repair capability.
One critical detail for deleted files: modern SSDs with TRIM enabled (the default on Windows 7+ and, on macOS, for Apple-shipped SSDs) invalidate deleted blocks within seconds to minutes. The OS tells the Phison controller which logical addresses are no longer needed; the controller unmaps them and schedules garbage collection to erase the underlying NAND pages. Recovery of deleted files is only possible if the drive was pulled immediately, TRIM was disabled, or the file system doesn't support TRIM.
How Much Does Phison SSD Recovery Cost?
Phison SATA SSDs (PS3111-S11, PS3110-S10) and NVMe SSDs (PS5012-E12, PS5018-E18, PS5021-E21T) have distinct data recovery pricing tiers. The required recovery method and overall cost are determined by the specific hardware failure type, including firmware corruption, PMIC failure, or NAND degradation, rather than the controller model.
SATA SSD Recovery (PS3111-S11, PS3110-S10)
NVMe SSD Recovery (PS5012-E12, PS5018-E18, PS5021-E21T)
+$100 rush fee to move to the front of the queue.
What Is the SATAFIRM S11 Firmware Panic?
The PS3111-S11 is Phison's cheapest SATA controller. It's a 2-channel, DRAM-less design that stores the Flash Translation Layer directly in TLC NAND rather than in dedicated cache memory. When the FTL pages in NAND become corrupted, the controller can't complete its boot sequence and enters ROM mode, reporting "SATAFIRM S11" as its identity string to the host.
Service Area Corruption Mechanism
The PS3111-S11 stores its firmware modules, bad block tables, & FTL backup in a reserved service area within the same TLC NAND chips that hold user data. TLC NAND degrades with every program/erase (P/E) cycle. As cells wear, the error rate in the service area climbs. When the ECC engine can no longer correct bit flips in the FTL pages, the controller halts its boot sequence and falls into ROM mode. Budget drives like the Kingston A400 use lower-binned NAND, which hits the ECC threshold sooner than enterprise-grade flash.
Why DRAM-less Phison SATA Stores FTL in NAND
A DRAM-equipped controller (like the PS3110-S10 with its dedicated DDR3 cache) holds the working FTL in dedicated memory and flushes periodic snapshots to NAND. If power drops, the NAND copy is a few seconds stale at worst; the controller rebuilds from it on the next boot. The PS3111-S11 doesn't have onboard DRAM. Its internal SRAM is a few kilobytes, enough for a small FTL fragment but not the entire table. The rest lives in NAND. A power cut during a write corrupts the in-flight FTL update, and there's no safe copy to fall back to.
ROM Mode Entry
When the PS3111-S11 detects unrecoverable FTL corruption during boot, it stops loading consumer firmware and drops to its BootROM. In this state, it reports "SATAFIRM S11" as the model name, shows 0GB or a few megabytes of capacity, & rejects all standard ATA read/write commands. The drive is electrically alive but functionally locked. PC-3000 recognizes this state and engages the Phison-specific recovery utility.
PC-3000's Volatile Microcode Injection
Volatile microcode injection is the core PC-3000 technique for recovering data from firmware-panicked Phison SSDs. The process uploads a temporary loader to the controller's RAM, bypassing the corrupted firmware stored in NAND without modifying the NAND contents. The loader is volatile; it vanishes on power loss and leaves the drive's stored data untouched.
SATA Recovery (PS3111-S11, PS3110-S10)
  1. Connect the drive via SATA to PC-3000 Express or Portable III. For BSY-locked PS3111-S11 drives, confirm the SATAFIRM S11 identity string in the ATA Identify response.
  2. Short the ROM test points on the PCB with tweezers while cycling power. This forces the controller out of its firmware panic loop into diagnostic ROM mode, bypassing the corrupted FTL in NAND.
  3. Select the Phison utility in PC-3000 SSD. Upload a temporary loader matched to the controller, NAND chip ID, & firmware version. The loader replaces the panicked firmware in volatile memory only.
  4. The loader reads raw NAND pages, reversing the XOR scrambling applied at the page level. XOR scrambling is a data integrity measure, not encryption; it complicates raw reads but PC-3000 handles it automatically with the correct loader profile.
  5. Build a virtual translator from surviving NAND page metadata (LBA stamps, sequence numbers, ECC checksums) to reconstruct the logical volume with correct file system structure.
NVMe Recovery (PS5012-E12)
The PS5012-E12 has full PC-3000 SSD support for firmware recovery, FTL reconstruction, and data extraction.
  1. Connect the M.2 NVMe drive to PC-3000 Portable III via the M.2 adapter on Port 0. Confirm PCIe link training status; a firmware-panicked drive will complete link training but fail NVMe initialization.
  2. Short ROM/Safe Mode pins on the controller while powering on to bypass the corrupted firmware boot sequence.
  3. Launch the PC-3000 SSD Phison Utility, confirm the firmware panic, then engage the Phison-specific recovery terminal for controller-specific loader injection.
  4. Remove tweezers when prompted. PC-3000 injects a controller-specific loader into the drive's internal RAM, disabling background TRIM & garbage collection to freeze the NAND state.
  5. Parse surviving metadata regions to rebuild the logical-to-physical block map. The E12's 8-channel interleaving requires correct channel stride & plane geometry to produce a valid logical image.
  6. Image the drive sector-by-sector. On heavily degraded NAND blocks, manual read retries and voltage threshold shifts may be required to maintain extraction integrity.
NVMe Recovery Limitations: PS5018-E18 and PS5021-E21T
PS5018-E18: PC-3000 SSD support for the E18 is limited to firmware repair operations. Full FTL reconstruction and data extraction are not available through PC-3000 for this controller. When E18 drives fail from PMIC or component-level damage, board-level repair to revive the original controller is the primary recovery path. Once the controller boots, standard NVMe read commands can image the data.
PS5021-E21T: Where the failure is PMIC or component-level damage, board-level repair to restore the controller comes first, then standard imaging once the drive enumerates.
Equipment Used
  • PC-3000 SSD
  • PC-3000 Portable III
  • PC-3000 SSD Phison Utility
  • Hakko FM-2032 microsoldering iron
  • FLIR thermal camera
  • Atten 862 hot air rework station
  • Zhuo Mao BGA rework station
PC-3000 Technological Mode Workflow for PS3110 and PS3111
Technological mode is a PC-3000 SSD diagnostic state where the controller executes a host-supplied loader instead of panicked firmware. This exposes the Service Area as raw data and allows the Flash Translation Layer to be rebuilt in RAM on the drive itself. This recovery path addresses SATAFIRM S11 drives with intact controller hardware.
1. Entering Technological Mode
A SATAFIRM S11 drive refuses normal ATA initialization because its firmware boot sequence fails partway through. Technological mode bypasses that boot sequence through one of the following entry paths:
  • ROM/Safe Mode pin short: On the PS3111-S11 PCB, a pair of test points adjacent to the controller routes the ROM_SEL line to ground. Shorting those points with tweezers while cycling power forces the controller to boot from internal mask ROM rather than from the corrupted firmware in NAND. PC-3000 SSD then detects the ROM-mode identity and offers the Phison active utility.
  • Vendor-specific ATA command entry: If the drive enumerates far enough to accept ATA commands, PC-3000 can push the controller into technological mode by issuing a sequence of Phison vendor commands through the SATA host adapter. This avoids handling the PCB when the drive is still partially responsive.
  • UART diagnostic access: Some Phison reference designs expose serial TX/RX pads on the PCB. When available, UART provides a boot log that identifies the firmware family before the loader is uploaded. UART is diagnostic only; the loader itself travels over SATA or PCIe, not over the serial link.
2. Loading the Correct Family Profile
A PS3110-S10 drive uses a different loader than a PS3111-S11 drive on SBFM-series firmware, even if both drives carry the same Kingston consumer identity. Picking the wrong loader produces read errors or garbled metadata; it does not damage the NAND, because the loader itself writes nothing.
3. Reading Raw NAND Through the Controller
Once the loader is resident in the controller's RAM, PC-3000 issues raw read commands that traverse the controller's native NAND interface. This is preferred over chip-off because the controller already knows the channel geometry, plane interleaving, and ECC configuration. For the PS3111-S11, that means reading 2 channels with the controller's original ECC engine applied; for the PS3110-S10, 8 channels. Raw pages include out-of-band (OOB) areas containing LBA stamps, sequence numbers, and wear-leveling metadata that the translator rebuild depends on.
4. Dumping the Service Area
The Service Area is the reserved region of NAND where Phison controllers store firmware modules, translator snapshots, bad-block tables, and wear-leveling journals. On a panicked drive the SA is usually readable even when the operational FTL is not, because the panic is triggered by a single corrupted module rather than total SA destruction. PC-3000 dumps the SA to disk, parses each module header, and isolates the translator snapshot and bad-block list. These modules are the seed data for FTL reconstruction.
5. Rebuilding the Translator and Exposing User LBAs
The translator rebuild runs entirely in RAM on the drive itself. PC-3000 consumes the SA snapshot, reconciles it against the OOB metadata read from user-data blocks, and resolves conflicts by sequence number. XOR scrambling is reversed using the page-level seed derived from the loader profile. The output is a virtual LBA range that matches what the drive would have presented to the host before the panic. PC-3000 then images that virtual range sector by sector into a target container; the original NAND is never written.
Why Consumer Software Cannot Reach This State
Recuva, EaseUS, R-Studio, and DMDE all operate above the ATA or NVMe block layer. A SATAFIRM S11 drive never presents a block layer, so these tools see no device to scan. MPTool and PhisonToolBox can talk to the controller in production mode, but their intent is to initialize blank NAND for manufacturing; running either on a drive that holds user data reinitializes the FTL and destroys everything. The technological mode workflow exists specifically because no consumer tool exposes the SA or the raw NAND read path.
When We Decline a SATAFIRM S11 Job
Technological mode requires a controller that can still boot to ROM and a NAND service area that retains at least one readable translator snapshot. When either fails, the loader has nothing to attach to and FTL rebuild is not possible. We decline or refund these cases rather than spend bench time on a recovery that cannot finish.
  • Dead controller silicon: The PS3111-S11 die fails to draw expected current on the core rail under FLIR, or shows a dead short across a decoupling capacitor that traces back to the controller package. A controller that does not power up cannot accept a loader. We do not perform BGA controller swaps on the PS3111-S11 platform: the electrical faults that kill these controllers routinely propagate damage to the NAND power rails, and a controlled BGA reflow on a budget drive is not economically viable for the customer.
  • Total service area destruction: Every translator snapshot in the SA reads as uncorrectable. This usually appears on drives that were powered repeatedly through brownouts or that ran for years past the NAND endurance rating. Without at least one valid snapshot, there is no seed to reconcile against the OOB metadata on user-data blocks and no way to recover the logical-to-physical map.
  • NAND wear past the read-retry ceiling: Even with a valid SA snapshot, user-data blocks may have drifted past the voltage threshold range that PC-3000 read retries can recover. When the uncorrectable-page count crosses a threshold that would corrupt the file system being recovered, we report what was salvageable and stop rather than deliver an unusable image.
  • Prior MPTool or PhisonToolBox run: If the customer or a previous shop ran a factory production tool against the drive, the FTL has been reinitialized and the user-data blocks are no longer addressable. There is no surviving translator to rebuild. We do not accept these drives for SATAFIRM S11 recovery.
  • Drive arrived after a DIY chip-off attempt: Desoldered NAND chips on a PS3111-S11 can sometimes be read on a programmer, but pairing the raw NAND dump back to a virtual controller without the original SA context is research-grade work that we do not currently offer. For an undamaged PCB, technological mode through the original controller is the supported path; once the chips are off the board, that path is closed.
In each case we decline, we document what we found in the free evaluation. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Pricing for this workflow follows the SATA SSD tier that matches the drive's condition. A clean SATAFIRM S11 panic with no board damage falls within the firmware logic tier at $600–$1,200; drives that also show PMIC or clock-generator failure move into the board repair tier at $450–$600. NAND transplant to a donor PCB is $1,200–$1,500. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers. +$100 rush fee to move to the front of the queue.
Controller Family Workflows
Controller-Family Recovery Workflows
The core volatile microcode injection technique is the same across the Phison line, but each controller family has its own Safe Mode entry, ROM pin layout, loader profile, and outcome envelope depending on whether the silicon is dead or the firmware is corrupt. The eight families below cover the drives that make up most of the Phison workload in the lab.
PS3110-S10 (SATA, DRAM-equipped, 8-channel)
Typical signatures: Drive reports a generic Phison factory string or the controller model name instead of the consumer brand, with a placeholder capacity of 2MB or 20MB. Some units enter a persistent BSY state & fail ATA enumeration entirely.
Safe Mode entry: Locate the ROM test points adjacent to the controller die on the PCB. Short the pads with precision tweezers while PC-3000 Express applies power; the controller boots from its immutable Mask ROM & bypasses the corrupted NAND firmware. Because the S10 uses a standard SATA interface, UART terminal access is not required for FTL recovery.
Loader & translator rebuild: PC-3000 uploads a loader matched to the exact firmware version (e.g., SBFK71E0 mapping to loader SBFM 71.2). Once the loader is resident in RAM, PC-3000 reads the NAND pages, reverses the XOR scrambling, & parses the out-of-band spare area to reconstruct block sequence numbers and wear-leveling counters into a virtual translator.
Outcome: Full FTL reconstruction & data extraction is available through PC-3000 SSD as long as the S10 silicon is electrically alive. If the controller itself is dead, chip-off is a last-resort fallback because the S10 uses reversible XOR scrambling rather than AES. Firmware recovery tier: $600–$1,200.
PS3111-S11 (SATA, DRAM-less, 2-channel)
Typical signatures: Drive enumerates as "SATAFIRM S11" with 0GB, 2MB, or occasionally full capacity, but rejects every standard ATA read/write. Root cause is the in-NAND FTL degrading past the ECC threshold, usually after sudden power loss during a background garbage collection cycle on a drive that has been written hard on budget TLC.
Safe Mode entry: Identify the two ROM vias near the controller or NAND package. Short them briefly during power-up & release as soon as the drive enters a minimal ready state. The S11 does not require a sustained short; a momentary contact is enough to divert the boot flow from the panicked firmware into the Mask ROM.
Loader & translator rebuild: PC-3000's Phison active utility pushes a small volatile loader into the S11's limited RAM. The loader exposes raw physical block addresses. PC-3000 then applies the Phison-specific XOR polynomial, parses the OOB spare area for LBA markers & block pairing metadata, & compiles the virtual translator in RAM on the drive itself. One S11 quirk: if the SMART log is itself corrupt, parsing it during FTL compile triggers a controller reboot loop. The workflow clears or bypasses SMART entries before finalizing the translator.
Outcome: Firmware-corrupt S11 drives are the highest-yield target in the Phison family; PC-3000 recovery succeeds on the majority of SATAFIRM S11 cases where the PCB is intact. If the controller silicon is dead, chip-off remains viable because the S11 only applies reversible XOR scrambling. Firmware recovery tier: $600–$1,200. NAND swap fallback: $1,200–$1,500.
PS5012-E12 (NVMe Gen3, DRAM-equipped, 8-channel)
Typical signatures: Drive drops off the PCIe bus or enumerates with a 2MB/1GB placeholder capacity & ignores NVMe admin commands. The root cause is almost always FTL journal corruption after an unexpected power loss during SLC-to-TLC cache folding, when the controller is mid-way through promoting fast SLC writes into dense TLC storage.
Safe Mode entry: Connect the M.2 drive to PC-3000 Portable III's M.2 adapter. A firmware-panicked E12 completes PCIe link training but stalls before NVMe initialization. Short the Safe Mode diagnostic pads near the controller or along the edge of the board during power-up; PC-3000 then forces PCIe link establishment at a reduced speed & loads the Phison Utility.
Loader & translator rebuild: PC-3000 sends vendor-specific NVMe commands over the PCIe bus to inject a controller-specific loader. The E12 loader is larger than the SATA family because it has to carry NVMe queue management & LDPC error tracking. Translator rebuild requires resolving SLC cache vs TLC main-array conflicts by reading the SLC block allocation table & picking the most recent valid version of each logical block.
Outcome: Full PC-3000 support. If the E12 silicon is alive, firmware recovery is reliable. If the controller is dead, chip-off is off the table: the E12 fuses its AES-256 Media Encryption Key to the controller silicon, so desoldered NAND yields ciphertext. Recovery then shifts to board-level repair to revive the original controller. NVMe firmware recovery tier: $900–$1,200.
Windows 11 KB5063878 / KB5062660 interaction: Following the August 2025 Windows 11 cumulative updates, a specific population of Phison-controller drives experienced mid-write lock-ups during sustained sequential transfers above roughly 50 GB. Subsequent forensic analysis by Phison and independent reviewers concluded that official production firmware was unaffected; the failing units carried pre-release engineering firmware that had reached retail by mistake, and the OS update exposed an interaction fault in that pre-release code. Affected drives skewed toward DRAM-less designs but included some E12-based drives. The drive vanishes from Device Manager mid-operation and returns unreadable SMART telemetry until a cold reboot. On the bench these drives respond to the standard E12 ROM-mode entry and loader injection described above; the recovery path is unchanged.
PS5018-E18 (NVMe Gen4, triple-core, DRAM-equipped)
Typical signatures: Drive disappears from BIOS after thermal stress under sustained Gen4 writes, or goes electrically dead after a PMIC short triggered by a voltage spike or PSU instability. Some failures present as boot loops where the drive enumerates briefly then falls off the bus.
PC-3000 support boundary: ACE Lab classifies the E18 as limited to firmware repair operations. Full virtual FTL reconstruction through loader injection is not available for this controller because of the combination of AES-256 encryption, TCG Opal 2.0 implementation, & 4th-generation LDPC with RAID ECC parity striping. There is no Safe Mode entry that yields a usable translator rebuild path.
Recovery path: Board-level repair is the primary route. Locate the failed component (typically the PMIC or a voltage regulator) with FLIR thermal imaging under limited power. Replace the component with a Hakko FM-2032 microsoldering iron or a Zhuo Mao BGA rework station for denser packages. Once the original E18 controller boots, the AES-256 keys are intact & the drive decrypts the NAND in real time across the standard NVMe path.
Outcome: If the failure is in the power delivery circuitry or a supporting component, the controller can be revived & the data extracted. NVMe board repair tier: $900–$1,200. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Thermal-throttle bench symptom: Before the controller dies, the E18 typically passes through a degraded read window that is easy to misread as a software problem. Once junction temperature crosses roughly 70°C, the controller engages aggressive throttle, dropping sustained sequential write throughput from roughly 7,000 MB/s down to approximately 1,800 MB/s. Elevated NAND temperature increases charge leakage, which raises the raw bit error rate; when that rate exceeds the 4th-generation LDPC plus RAID-ECC correction budget during an in-flight FTL metadata write, the commit lands with uncorrectable errors. The user-visible signature is file-system stalls, long boot times, and the drive intermittently dropping off the PCIe bus. Drives in this state are still imageable through PC-3000 if the controller silicon is alive; delay accelerates further charge-leakage damage and lengthens imaging time.
PS3112-S12 (SATA, DRAM-equipped, 8-channel)
Typical signatures: Drive enters a persistent BSY state during ATA identify or drops off the SATA bus entirely. Unlike the PS3111-S11, the S12 does not exhibit a documented "SATAFIRM" fallback identity string; the dominant failure mode is a non-responsive controller after service-area corruption or LDPC exhaustion on degraded 3D TLC or 3D QLC NAND. Built on a 28nm dual-CPU architecture with DDR3L or DDR4 cache, the S12 is a higher-tier SATA part deployed in drives like the Seagate FireCuda 120, GoodRam IRDM PRO Gen 2, and Kingston DC500R, not in entry-level Kingston A400-class hardware.
Safe Mode entry: PC-3000 SSD reaches the S12 through the Phison Active Utility using vendor-specific ATA commands. When the drive is fully unresponsive, technicians short the ROM test points adjacent to the controller during power-on to force the controller into Mask ROM and then upload the loader over SATA. Because the S12 has onboard DRAM, the boot sequence does not depend on reading the FTL from NAND first; the loader can rebuild the translator without the FTL panic loop seen on DRAM-less S11 silicon.
Loader & translator rebuild: PC-3000 injects a volatile S12 loader matched to controller revision and NAND ONFI ID. The loader exposes raw NAND pages and reverses the controller's scrambling. Translator rebuild consumes the surviving service-area modules plus OOB metadata and resolves conflicts by sequence number, the same pattern used on the S10 but with the S12's 8-channel page geometry.
Encryption boundary: The S12 implements hardware AES-256 with TCG Opal/Pyrite plus a XEX (XOR-Encrypt-XOR) tweakable block cipher across the data path. This is the encryption discontinuity inside the Phison SATA family: the S11 and S10 use reversible XOR scrambling and remain chip-off candidates as a last resort, while the S12 binds its Media Encryption Key to the controller silicon. Chip-off on a dead S12 yields ciphertext. Recovery on electrically dead S12 boards follows the same path as encrypted Phison NVMe parts: revive the original controller through board-level repair so the hardware engine can decrypt the NAND in real time. SATA firmware recovery tier: $600–$1,200. Board repair tier: $450–$600.
PS5008-E8 (NVMe Gen3 x2, 4-channel)
Typical signatures: Drive drops off the PCIe bus, reports 0MB capacity, or fails NVMe identify. The E8 is Phison's first-generation consumer NVMe controller, released in 2017 on a constrained PCIe 3.0 x2 lane budget to keep cost and thermal envelope down. It shipped in two variants: the baseline E8 with onboard DDR3L DRAM, and the E8T DRAM-less variant that uses Host Memory Buffer to cache the FTL in host RAM. Common drives include the MyDigitalSSD SBX, Patriot Scorch, and Corsair MP300. (The MyDigitalSSD BPX and Corsair MP500 use the older PS5007-E7 controller, not the E8; do not assume Phison generation from drive name alone.)
Safe Mode entry: Connect the M.2 drive to PC-3000 Portable III's M.2 adapter. A firmware-panicked E8 completes PCIe link training but stalls during NVMe initialization. Short the Safe Mode pads adjacent to the controller during power-on; PC-3000 then loads the Phison Utility and drives further interaction over vendor-specific NVMe commands.
Loader & translator rebuild: PC-3000 injects a controller-specific microcode loader into the E8's RAM. On the DRAM-equipped E8, the working FTL was held in onboard cache and flushed periodically to the service area; the loader rebuilds the translator from the most recent SA snapshot reconciled against OOB metadata. On the E8T variant, HMB content in host RAM is lost the moment the drive falls off the bus, so the rebuild is limited to whatever FTL state was committed to NAND before the panic. Either way, the loader writes nothing to NAND; the original data is preserved.
Encryption boundary: The E8 implements hardware AES-256 with the Media Encryption Key generated on and bound to the original controller so it never leaves that silicon, plus TCG Opal and Pyrite support. Chip-off is non-viable; desoldered NAND yields ciphertext. If the E8 board has a dead PMIC or shorted regulator, recovery requires board-level repair before the controller can decrypt the NAND. NVMe firmware recovery tier: $900–$1,200. NVMe board repair tier: $900–$1,200.
PS5013-E13T (NVMe Gen3 x4, DRAM-less, HMB, 4-channel)
Typical signatures: Drive disappears from BIOS or enumerates with 0MB capacity after a power loss event. Built on a 28nm process with a single Cortex-R5 core paired with a CoXProcessor for NAND management, the E13T is one of the most prevalent Gen3 budget NVMe controllers in the field. It ships in the Crucial P2, Patriot P300, and Sabrent Rocket Nano Rugged among many other budget M.2 2230/2242/2280 drives. Because it is DRAM-less and depends on Host Memory Buffer, the Flash Translation Layer is cached in the host computer's RAM through the PCIe bus; a sudden power cut or PCIe link drop leaves the in-flight FTL update unflushed, and the controller fails to re-read the service area on the next boot.
Safe Mode entry: Connect to PC-3000 Portable III via the M.2 adapter. Short the Safe Mode pads while powering on to bypass the panicked firmware boot. The Phison Utility on PC-3000 recognizes the E13T and drives the recovery via vendor-specific NVMe commands.
Loader & translator rebuild: PC-3000 uploads an E13T loader to the controller's RAM. Because HMB content is gone the moment the drive fell off the bus, the rebuild starts from whatever FTL fragments survived in the service area, then scans NAND page headers across all four channels to virtually reconstruct the logical-to-physical map in RAM on the drive itself. This is the same technique used on the E12 but on a smaller channel count and without the safety net of an onboard DRAM cache, which is why E13T cases skew toward longer rebuild times when the SA itself is partially corrupt.
Encryption boundary: The E13T implements hardware AES-256 with the MEK generated on and bound to the original controller so it never leaves that silicon, and supports TCG Opal/Pyrite. Chip-off is non-viable; desoldered NAND yields ciphertext. If the E13T silicon is dead, board repair is the only path to preserve the encryption chain so PC-3000 can extract through the native NVMe path once the controller boots. NVMe firmware recovery tier: $900–$1,200. NVMe board repair tier: $900–$1,200.
PS5021-E21T (NVMe Gen4, DRAM-less, HMB, 4-channel)
Typical signatures: Drive enumerates with 0MB capacity, or Host Memory Buffer FTL loss after a PCIe link drop during an in-flight mapping update.
PC-3000 support boundary: Chip-off stays closed on this part: the controller's proprietary XOR scrambling and LDPC error correction leave a raw NAND dump unintelligible without it.
Recovery path: Board-level repair keeps the original controller electrically sound.
Outcome: Prognosis depends on whether the controller silicon is alive. If it is, recovery yield is high for HMB-only FTL loss. If the controller is dead, the data is unrecoverable. NVMe board repair tier: $900–$1,200.
PS5026-E26 (NVMe Gen5, dual ARM Cortex-R5, 8-channel)
Support disclosure: Rossmann does not currently offer in-lab recovery for PS5026-E26. The E26 is absent from the ACELab PC-3000 SSD supported-controllers list, and the silicon-bound AES-256 Media Encryption Key forecloses chip-off as a fallback. The information below describes the bench reality of how this controller fails so that the engineering tradeoff is visible; it is not an offer of service.
Typical signatures: The E26 is the first consumer Phison part on PCIe 5.0 x4, built on a TSMC 12nm process with a dual ARM Cortex-R5 architecture, CoXProcessors, and 8 NAND channels with 32 chip-enable lines. It powers the Corsair MP700, Crucial T700, and Seagate FireCuda 540. The dominant failure pattern is uncontrolled thermal shutdown: the controller can draw up to 10W under sustained sequential workloads and pushes junction temperatures past 100°C without a heatsink. Original Phison firmware on the MP700 reached file-system corruption or hard thermal cutoff within minutes of bench testing without active cooling; Phison subsequently released firmware 22.1, which introduces link-state thermal throttling that drops the PHY from PCIe 5.0 to PCIe 4.0 or 3.0 instead of crashing the drive outright. Other failures present as a shorted PMIC or low-dropout regulator, BGA solder fatigue from rapid thermal cycling on the controller die, or collapse of the NAND I/O (VCCQ), controller core, or NAND VCC rails after a power surge.
Why support is not offered today: The E26 combines a 5th-generation 4KB-frame LDPC ECC engine, AES-256 with TCG Opal 2.0, and a Media Encryption Key generated on and bound to the original controller so it never leaves that silicon. A raw chip-off of the Micron 232-layer B58R NAND yields ciphertext that cannot be decrypted off-controller. A working recovery path therefore requires both an ACELab PC-3000 SSD loader profile for the E26 and the ability to keep the original controller silicon electrically alive long enough to decrypt during NVMe imaging. The loader profile is not yet in ACELab's shipping support matrix. Once it is, this section will be updated and the disclaimer above removed.
+$100 rush fee to move to the front of the queue. For the SATAFIRM S11 workflow in more depth, see the SATAFIRM S11 recovery guide. For the broader firmware-panic recovery path, see SSD firmware corruption recovery. The full controller family catalog lives at Phison SSD controllers.
Phison FTL Architecture
How Phison's FTL Decides Whether a Failed Drive Is Recoverable
Every Phison failure mode in the workflows above traces back to the same architecture: a hybrid-mapping Flash Translation Layer, a pseudo-SLC write buffer that periodically folds into TLC or QLC main storage, and a metadata journal stored in the NAND service area. Understanding how those three pieces interact explains which corruption patterns are recoverable through PC-3000 loader injection at our SSD recovery lab and which require a full virtual translator rebuild from raw NAND.
Hybrid LBA Mapping
Pure page-level mapping (every 4-16 KB page tracked individually) is the most flexible scheme but demands large amounts of mapping RAM. Pure block-level mapping (hundreds to thousands of pages per entry) saves RAM but pays a heavy write amplification penalty on random updates. Phison's consumer parts use a hybrid approach: bulk user data is tracked at block granularity, and a smaller pool of log blocks dedicated to active updates is tracked at page granularity. On DRAM-equipped parts (PS3110-S10, PS3112-S12, PS5012-E12, PS5016-E16, PS5018-E18, PS5026-E26) the working mapping table lives in onboard DRAM and is checkpointed to NAND. On DRAM-less parts (PS3111-S11 SATA, PS5013-E13T and PS5021-E21T NVMe) the table is held either directly in NAND or in host RAM through the Host Memory Buffer feature; that arrangement is the structural reason DRAM-less Phison drives are more vulnerable to sudden power loss.
Pseudo-SLC Cache and the Fold Operation
Modern Phison controllers buffer incoming host writes by programming blocks of TLC or QLC NAND in single-bit (pseudo-SLC) mode. pSLC programming is faster and more tolerant of read disturb than direct TLC/QLC programming, which is why benchmark bursts look fast and steady-state writes do not. Because pSLC mode stores one bit per cell and so consumes three times the cell footprint on TLC (four times on QLC), the controller has to reclaim that capacity in the background. During idle, a fold operation reads several pSLC blocks and rewrites them as a single TLC or QLC block in dense mode. The fold runs entirely on the controller; the host sees only an idle drive.
Metadata Journal and Power-Loss Sensitivity
The FTL records its current state, including block sequence counters, the location of the live mapping table, the fold queue, and the garbage-collection cursor, in a metadata journal inside the NAND service area. Consumer Phison drives ship without the tantalum or polymer hold-up capacitors that enterprise drives use for power-loss protection. When power drops mid-fold or mid-garbage-collection, the journal's block sequence counters fail to advance atomically. On the next boot the controller reads a fragmented map and either drops off the bus mid-initialization, sits in a persistent BSY state, or falls back to ROM mode with a generic identity string.
Journal Corruption vs Total FTL Loss
The bench distinction that drives recovery time is whether at least one consistent journal snapshot survives.
  • Recoverable journal: The journal exists but the most recent transaction is incomplete. PC-3000 injects a loader, reads the surviving snapshot, replays the remaining log entries against OOB metadata on the user-data blocks, and reconstructs the active mapping table. Imaging usually begins within an hour of confirming Safe Mode entry.
  • Total FTL loss: Every snapshot in the service area reads as uncorrectable, or the service-area blocks themselves are bad. The translator has to be rebuilt from scratch by scanning the spare area of every physical NAND page across every die, extracting the LBA tag and sequence number, and stitching a virtual map from those tags in RAM on the drive itself. Wall-clock time scales with capacity and channel count; bench experience puts this in the 2-12 hour per terabyte range depending on bit-error retry behavior.
Service-area total loss is also the boundary where we decline a SATAFIRM S11 job for the reason described in the technological-mode workflow: with no snapshot to reconcile against, there is no seed for the rebuild.
Why This Matters for Pricing Tier Selection
A journal-replay recovery on an intact PCB falls inside the firmware logic tier ($600–$1,200 SATA, $900–$1,200 NVMe). Full virtual translator rebuilds and drives that also need PMIC or regulator replacement before the loader can be injected sit at the board repair tier ($450–$600 SATA, $900–$1,200 NVMe). NAND swap to a donor PCB on chip-off-eligible SATA parts (PS3111-S11, PS3110-S10) is $1,200–$1,500.
How Does Phison Wear Leveling Affect Recovery?
How Does Phison Wear Leveling Affect SSD Recovery?
Wear leveling is a function of the same Flash Translation Layer that maps your data. The controller spreads program/erase cycles across NAND blocks and tracks an erase count per block so no single block wears out far ahead of the rest. That erase-count metadata is controller bookkeeping, not user data, so it changes the shape of a recovery only through the FTL reconstruction already described above; it is not a separate recovery problem with its own price tier.
The erase-count and wear-leveling tables live in the reserved NAND service area, next to the FTL mapping snapshots and the bad-block table. They are written by the controller during normal operation and read back at boot. When a Phison drive boots cleanly, the controller consults these tables to decide where the next write lands; none of that is visible to the host, and none of it is something a consumer tool ever touches.
For recovery the practical point is narrow. PC-3000 SSD does not depend on a readable wear-leveling table to rebuild the logical volume. The translator rebuild keys off the OOB LBA stamps and sequence numbers stamped on the user-data pages and whatever service-area snapshots survived; those are the same reconstruction inputs used throughout the workflows on this page.
A corrupt service-area journal is what blocks the rebuild, exactly as described in the journal-corruption-versus-total-FTL-loss split above. There is no separate wear-table failure mode that we treat differently; if the journal snapshot survives, the loader replays it, and if every snapshot reads as uncorrectable, the translator has to be rebuilt from raw NAND page tags.
This is also why the DRAM-less power-loss vulnerability covered earlier still holds. A DRAM-less PS3111-S11 keeps its working tables in NAND and its OOB tags on the pages themselves, so a power cut during a write can leave the in-flight metadata inconsistent. The recovery answer is the same as for any FTL corruption on these parts: enter Safe Mode, inject the loader, and rebuild the map from the surviving snapshot or from the page-level tags.
How Does Recovery Differ Across E12, E16, and E18?
How Does Recovery Differ Across the Phison E12, E16, and E18?
The PS5012-E12 and PS5016-E16 have full PC-3000 SSD support: loader injection, a virtual translator/FTL rebuild, and extraction all run through the original controller. The PS5018-E18 has only limited PC-3000 support (firmware-repair operations, not full virtual FTL reconstruction), so board-level repair to revive the original controller is the primary recovery path for a dead E18.
ControllerPCIe GenPC-3000 SSD Support LevelRecovery Path
PS5012-E12PCIe Gen3Full (loader injection + virtual translator/FTL rebuild + extraction)Firmware recovery through the original controller
PS5016-E16PCIe Gen4Full (loader injection + virtual translator/FTL rebuild + extraction)Firmware recovery through the original controller
PS5018-E18PCIe Gen4Limited (firmware-repair operations only; no full virtual FTL reconstruction)Board-level repair to revive the original controller
The encryption posture is the same risk across all three. When the silicon-bound AES-256 Media Encryption Key is enabled, the key is generated on and bound to the original controller so it never leaves that silicon. Chip-off yields ciphertext on all three, so it is not a path on any of them. That is why the E18 outcome routes to board repair: reviving the original controller is what makes the data readable again.
Pricing follows the failure, not the model. An E12 or E16 firmware-recovery case sits in the NVMe firmware tier at $900–$1,200; a dead E18 that needs its controller revived sits in the NVMe board-repair tier at $900–$1,200. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
NVMe Gen4 vs Gen3 Host-Interface Failure Modes
Each of these controllers presents a characteristic failure signature on the bench. A Gen3 PS5012-E12 typically shows a firmware panic and is not detected in BIOS. A Gen4 PS5016-E16 tends toward thermal shutdown alongside firmware panic. A Gen4 PS5018-E18 commonly shows a boot loop, no detection, or thermal failure. These are the same signatures listed in the controller table near the top of this page.
Gen4 doubles the per-lane signaling rate over Gen3, which leaves tighter electrical margins on the host interface. Before choosing a recovery path, the bench engineer separates a host-interface or link problem from a controller that fails to enumerate at all. A link problem looks like a drive that appears, drops, or renegotiates on the bus.
A drive that fails to enumerate entirely points to either a firmware panic or a board-level electrical failure, and those two are told apart by FLIR thermal imaging and rail measurement rather than by the bus symptom alone: a firmware panic leaves the silicon electrically sound, while a dead PMIC, shorted capacitor, or collapsed power rail leaves the controller unable to boot. PC-3000 can establish the PCIe link at a reduced speed during imaging, the same general capability referenced in the E12 workflow above, so an unstable host interface does not by itself end a recovery; it just has to be told apart from a firmware panic and from a dead controller first.
XOR Scrambling vs AES-256 Encryption Across
XOR Scrambling vs AES-256 Encryption Across Phison Generations
Phison's older SATA controllers and newer NVMe controllers handle data obfuscation differently. This distinction determines whether chip-off recovery is viable or whether board-level repair is the only path to the data.
XOR Scrambling (PS3111-S11, PS3110-S10)
Older Phison SATA controllers apply XOR data scrambling at the page level. This isn't encryption; it's a data integrity technique that randomizes bit patterns to improve NAND programming reliability and reduce read disturb. The XOR pattern is deterministic and derived from the controller model, NAND chip ID, & firmware version. PC-3000's Phison utility reverses the scrambling automatically during extraction.
Because XOR scrambling is reversible without a secret key, chip-off is technically viable on PS3111-S11 drives as a last resort. An engineer desolders the NAND chips, reads them on a separate programmer, applies the correct XOR pattern, & reconstructs the logical volume. This is slower and riskier than controller-level recovery through PC-3000, but it provides an alternative path when the controller PCB is too damaged for repair. NAND swap: $1,200–$1,500. 50% deposit required; donor drive cost additional.
AES-256 Encryption (PS5012-E12, PS5016-E16, PS5018-E18, PS5026-E26)
Most NVMe Phison controllers implement hardware AES-256 encryption with the Media Encryption Key (MEK) generated on and bound to the original controller so it never leaves that silicon. All Phison controllers also apply proprietary XOR data scrambling regardless of AES status. On drives with AES-256 enabled, every byte written to NAND is encrypted; every byte read from NAND is decrypted in real time by the controller's hardware engine. Some E16-based drives ship without AES-256 (Sabrent Rocket Q4, Seagate FireCuda 520), but the XOR scrambling and proprietary FTL still make chip-off impractical.
Desoldering the NAND chips from a dead PS5018-E18 & reading them on a programmer yields ciphertext; the AES-256 key that could decrypt the data is embedded in the now-dead controller IC. Chip-off is not a recovery option on encrypted NVMe Phison SSDs. The only path is board-level repair: identify the failed component (typically a PMIC or voltage regulator) using FLIR thermal imaging, replace it with a Hakko FM-2032, & bring the original controller back to life. When the controller boots, the encryption keys are intact and the data is accessible. NVMe board repair: $900–$1,200.
PS5021-E21T: NVMe with AES-256 and HMB
The E21T combines the worst of both risk profiles. It's DRAM-less (using HMB for FTL caching, like the budget SATA controllers) but uses hardware AES-256 encryption (like the high-end NVMe controllers). A power cut corrupts the FTL through HMB failure, and if the controller dies from the resulting electrical stress, the encryption key is lost. Board-level repair is the only option; chip-off yields encrypted data without a key.
ControllerData ProtectionChip-Off Viable?Recovery Path
PS3111-S11XOR scramblingYes (last resort)PC-3000 firmware recovery preferred; chip-off if PCB destroyed
PS3110-S10XOR scramblingYes (last resort)PC-3000 firmware recovery preferred; chip-off if PCB destroyed
PS3112-S12AES-256 (key bound to controller) + XEXNo; yields ciphertextPC-3000 firmware recovery; board repair to revive controller if dead
PS5008-E8AES-256 (key bound to controller)No; yields ciphertextBoard repair to revive controller, then PC-3000 extraction
PS5012-E12AES-256 (key bound to controller)No; yields ciphertextBoard repair to revive controller, then PC-3000 extraction
PS5013-E13TAES-256 (key bound to controller)No; yields ciphertextBoard repair to revive controller, then PC-3000 extraction
PS5016-E16AES-256 (key bound to controller)No; yields ciphertextBoard repair to revive controller, then PC-3000 extraction
PS5018-E18AES-256 (key bound to controller)No; yields ciphertextBoard repair to revive controller, then PC-3000 extraction
PS5021-E21TAES-256 (key bound to controller)No; yields ciphertextBoard repair to revive controller, then PC-3000 extraction
PS5026-E26AES-256 (key bound to controller)No; yields ciphertextBoard repair to revive controller, then PC-3000 extraction
Why Board Repair Is Data Recovery for Encrypted
Why Board Repair Is Data Recovery for Encrypted Phison SSDs
Most data recovery labs outsource board-level failures or declare them unrecoverable. The distinction matters for Phison NVMe drives because the AES-256 encryption key is generated on and bound to the original controller so it never leaves that silicon. A dead controller means dead encryption keys. Without the original controller, the NAND contents are unreadable ciphertext.
We locate the failed component using FLIR thermal imaging. A shorted PMIC or voltage regulator on a PS5018-E18 PCB shows as a thermal hotspot before full operating power is applied. The failed component is replaced with a Hakko FM-2032 microsoldering iron on an FM-203 base station. For BGA components (controller reflow, PMIC replacement on dense M.2 boards), we use Zhuo Mao precision BGA rework stations & Atten 862 hot air.
When the controller boots, the AES-256 encryption keys are intact. PC-3000 SSD then accesses the drive through its Phison Utility, and the controller decrypts the data in real time as it's extracted. Board repair isn't a separate service from data recovery; for encrypted SSDs, it IS data recovery. This is why the board-level workflow is a precondition for SSD data recovery on every encrypted Phison NVMe part: there is no software-only path once the controller silicon is dead.
SATA board repair: $450–$600. NVMe board repair: $900–$1,200. Both tiers involve component-level microsoldering to revive the original controller and preserve the encryption key relationship. A donor drive is a matching SSD used for its circuit board. Typical donor cost: $40–$100 for common models, $150–$300 for discontinued or rare controllers.
Phison SSD Recovery Terminology
These terms appear throughout Phison SSD diagnostics & recovery documentation. Each definition below explains what the term means in the context of a failed Phison drive.
SATAFIRM S11
The ROM-mode identity string reported by the Phison PS3111-S11 controller when it enters firmware panic. The drive appears in BIOS as "SATAFIRM S11" instead of the consumer brand name (Kingston A400, etc.) and reports 0GB capacity. This is not a model name; it is a diagnostic state.
ROM Mode
A diagnostic state where the Phison controller bypasses its stored firmware and boots from its internal BootROM only. The controller responds to vendor-specific commands but rejects standard ATA read/write operations. PC-3000 uses ROM mode as the entry point for volatile microcode injection. ROM mode entry is forced by shorting designated test points on the PCB during power-on.
Flash Translation Layer (FTL)
The mapping table that converts logical block addresses (what your operating system requests) to physical NAND page locations (where the data is stored on the flash chips). DRAM-less Phison controllers (PS3111-S11, PS5021-E21T) are especially vulnerable to FTL corruption because they store the table in NAND or host RAM rather than dedicated cache memory. FTL corruption is the root cause of most Phison firmware panics.
Host Memory Buffer (HMB)
An NVMe specification feature (NVMe 1.2+) used by the PS5021-E21T to cache the Flash Translation Layer in the host PC's system RAM through the PCIe bus. Saves the cost of onboard DRAM but makes the FTL dependent on an uninterruptible PCIe connection. A power cut severs the PCIe link and the in-flight FTL update in RAM on the drive itself never commits to NAND.
The PC-3000 recovery technique that uploads a temporary firmware loader into the controller's RAM. The loader replaces the corrupted firmware stored in NAND, providing raw read access to the NAND pages without modifying the drive's stored data. The loader is volatile: it exists only in RAM and vanishes on power loss. Wear leveling, TRIM, & garbage collection are disabled in the loader code to freeze the NAND state during extraction.
Phison SSD Recovery FAQ
What does SATAFIRM S11 mean in BIOS?
SATAFIRM S11 is not a model name. It is a firmware panic state reported by the Phison PS3111-S11 controller when it cannot read its own Flash Translation Layer from NAND. The controller drops its consumer identity (e.g., Kingston A400) and reports its ROM-mode identity string instead. PC-3000 SSD's Phison utility injects a temporary loader to bypass the corrupted firmware and extract the data.
How much does Phison SSD data recovery cost?
SATA Phison SSD recovery (PS3111-S11, PS3110-S10) starts at $200 for a simple copy and ranges up to $1,200–$1,500 for NAND transplant. NVMe Phison recovery (PS5012-E12, PS5018-E18, PS5021-E21T) starts at $200 and ranges up to $1,200–$2,500. Free evaluation. No data, no fee. +$100 rush fee to move to the front of the queue.
Can MPTool or PhisonToolBox fix a SATAFIRM S11 drive?
No. MPTool and PhisonToolBox are factory-line production tools designed to initialize blank NAND. Running either tool on a drive that contains data permanently erases it. MPTool reinitializes the NAND layout, wipes the Flash Translation Layer, and destroys all user data. PhisonToolBox performs the same type of low-level reinitialization. If your drive shows SATAFIRM S11 in BIOS, do not run any firmware utility. Send the drive for professional evaluation first.
Why can't recovery software fix a dead Phison SSD?
Recovery software (Disk Drill, EaseUS, R-Studio, PhotoRec) requires a functioning controller to communicate with the NAND. When a Phison controller enters firmware panic or dies from electrical failure, it doesn't enumerate as a storage device. Your operating system can't see the drive, and software can't send read commands to hardware that isn't responding. The first step is restoring communication through PC-3000 SSD's Phison utility, which injects a temporary loader into the controller's RAM. Only after the controller is stabilized can data be extracted.
What is the difference between Phison SATA and NVMe recovery?
SATA Phison controllers (PS3111-S11, PS3110-S10) use XOR data scrambling without full hardware encryption, so chip-off is technically viable as a last resort. Most NVMe Phison controllers (PS5012-E12, PS5018-E18, PS5021-E21T) use hardware AES-256 encryption with the key generated on and bound to the original controller so it never leaves that silicon; all apply proprietary XOR scrambling that makes chip-off impractical even on models without AES. If an NVMe Phison controller dies, board-level repair to revive the original controller is the only path. SATA recovery connects through PC-3000 Express via a SATA port; NVMe recovery uses PC-3000 Portable III's M.2 adapter. SATA firmware recovery: $600–$1,200. NVMe firmware recovery: $900–$1,200.
Can chip-off work on Phison NVMe SSDs?
No. Most Phison NVMe controllers (PS5012-E12, PS5016-E16, PS5018-E18, PS5026-E26) implement hardware AES-256 encryption with the key generated on and bound to the original controller so it never leaves that silicon. Even models without AES-256 use proprietary XOR data scrambling and dynamic FTL structures that make chip-off impractical. Desoldering the NAND chips from an NVMe Phison PCB yields either ciphertext or scrambled data without a usable address map. Board-level repair (reviving the original controller through PMIC replacement or component-level soldering) preserves the controller state and is the only viable recovery path. Older SATA controllers like the PS3111-S11 use simpler XOR scrambling, so chip-off is possible on those drives as a last resort.
Why do DRAM-less Phison SSDs fail more often after power loss?
DRAM-less Phison SATA controllers (PS3111-S11) store the Flash Translation Layer directly in TLC NAND. A power cut during a write can corrupt the FTL pages stored in NAND, and the controller can't boot. DRAM-less NVMe controllers (PS5021-E21T) cache the FTL in the host PC's RAM via Host Memory Buffer; a power cut severs the PCIe link and the in-flight FTL update never commits to NAND. DRAM-equipped controllers (PS3110-S10, PS5012-E12, PS5018-E18) hold the working FTL in dedicated onboard DRAM and flush to NAND periodically; they have a smaller vulnerability window because the onboard DRAM backup is at most a few seconds stale.
Can a SATAFIRM S11 drive be reused after data recovery?
No. We do not recommend returning a recovered PS3111-S11 drive to service. The firmware panic that produced SATAFIRM S11 is a symptom of TLC NAND that has worn past the point where its service area can hold a stable Flash Translation Layer. Even after PC-3000 SSD extracts the data, the underlying NAND degradation is permanent and progressive. Reformatting the drive with MPTool or PhisonToolBox would erase the data and rebuild the FTL, but the same NAND blocks that failed the first time will fail again, often within weeks. Recover the data, copy it to a healthy drive, and physically destroy or recycle the original.
What is volatile microcode injection?
Volatile microcode injection is the PC-3000 recovery technique used on Phison SSDs. The engineer shorts ROM test points on the PCB to force the controller out of its firmware panic loop into a diagnostic state. PC-3000 then uploads a temporary loader directly into the controller's volatile RAM. This loader replaces the corrupted firmware stored in NAND and provides raw read access to the NAND pages. The loader is volatile: it lives in RAM and vanishes on power loss. It doesn't write to NAND, doesn't trigger TRIM or garbage collection, and doesn't modify the drive's stored data in any way.
What is the difference between Phison E12 and E18 data recovery?
The PS5012-E12 (PCIe Gen3) has full PC-3000 SSD support: loader injection, a virtual translator/FTL rebuild, and extraction all run through the original controller. The PS5018-E18 (PCIe Gen4) has only limited PC-3000 support, covering firmware-repair operations rather than full virtual FTL reconstruction, so board-level repair to revive the original controller is the primary path when an E18 dies. Both bind an AES-256 Media Encryption Key to the controller silicon when enabled, so chip-off yields ciphertext on either; reviving the original controller is what makes the data readable. Both E12 and E18 cases are evaluated and recovered in-house through our professional SSD data recovery service.
Can an SSD be recovered if its wear-leveling table is corrupted?
Wear-leveling and erase-count data is controller bookkeeping stored in the reserved NAND service area, not user data, so PC-3000 SSD does not need a readable wear-leveling table to rebuild your volume. The translator rebuild keys off the LBA stamps and sequence numbers on the user-data pages and the surviving service-area snapshots. The condition that actually blocks recovery is a corrupt service-area journal with no consistent snapshot to replay, the same boundary that decides any Phison FTL reconstruction. If you suspect your drive failed during a write, stop using it and send it to our SSD data recovery lab for a free evaluation before the next power cycle.
Why does a Phison Gen4 NVMe SSD drop off the PCIe bus?
A drive that appears, drops, or renegotiates on the PCIe bus usually points to a host-interface or link problem rather than a dead controller; a controller that never presents a usable block device at all points to a firmware panic. Gen4 doubles the per-lane signaling rate over Gen3, leaving tighter electrical margins, so the bench engineer separates these two cases before choosing a path. PC-3000 can establish the link at a reduced speed during imaging, so an unstable interface does not by itself end a recovery. If your Gen4 Phison drive keeps dropping off the bus, our SSD data recovery bench can determine whether it is a link fault or a controller failure during the free evaluation.
Phison SSD showing SATAFIRM S11, not detected, or stuck in firmware panic?
Free evaluation. SATA recovery from $200. NVMe recovery from $200. No data, no fee.
